    4. FHEM
    FHEM
    • Bluefox
      Bluefox last edited by
      @Holliwyoming:
      Hallo
      Ich hätte auch Interesse
      Könnte ein Dimmer und ein Rolladen Modul Posten
      Was wird genau benötigt
      Gruss Holli `
      Benötigt wird die Ausgabe von JsonList2 vom Rolladen- und Dimmer-Geräten.
      JsonList2 GeräteName
      Und hier posten.
        Holliwyoming last edited by
        Hallo
        Hier das gewünschte List für Dimmer
        "Arg":"DIM_Wohnzimmer_A200",
        "Results": [
        "Name":"DIM_Wohnzimmer_A200",
        "PossibleSets":"assignHmKey clear:readings,trigger,register,oldRegs,rssi,msgEvents,attack,all deviceRename down getConfig getDevInfo getRegRaw getSerial getVersion inhibit:on,off off old on on-for-timer on-till pair pct:slider,0,1,100 peerBulk peerIODev press raw regBulk regSet reset sign:on,off statusRequest stop toggle unpair up",
        "PossibleAttrs":"verbose:0,1,2,3,4,5 room group comment:textField-long alias eventMap userReadings:textField-long do_not_notify:1,0 showtime:1,0 rawToReadable unit expert:0_defReg,1_allReg,2_defReg+raw,3_allReg+raw,4_off,8_templ+default,12_templOnly,251_anything param actAutoTry:0_off,1_on aesCommReq:1,0 ignore:1,0 dummy:1,0 IODev IOList IOgrp rssiLog:1,0 actCycle hmKey hmKey2 hmKey3 serialNr firmware .stc .devInfo actStatus autoReadReg:0_off,1_restart,2_pon-restart,3_onChange,4_reqStatus,5_readMissing,8_stateOnly burstAccess:0_off,1_auto msgRepeat hmProtocolEvents:0_off,1_dump,2_dumpFull,3_dumpTrigger aesKey:5,4,3,2,1,0 repPeers peerIDs tempListTmpl levelRange levelMap event-on-change-reading event-on-update-reading event-aggregator event-min-interval stateFormat model:ASH550,ASH550I,CCU-FHEM,CMM,DORMA_BRC-H,DORMA_RC-H,DORMA_atent,HM-CC-RT-DN,HM-CC-RT-DN-BoM,HM-CC-SCD,HM-CC-TC,HM-CC-VD,HM-Dis-TD-T,HM-Dis-WM55,HM-ES-PMSw1-DR,HM-ES-PMSw1-Pl,HM-ES-PMSw1-Pl-DN-R1,HM-ES-PMSw1-Pl-DN-R2,HM-ES-PMSw1-Pl-DN-R3,HM-ES-PMSw1-Pl-DN-R4,HM-ES-PMSw1-Pl-DN-R5,HM-ES-PMSw1-SM,HM-ES-TX-WM,HM-LC-BL1-FM,HM-LC-BL1-PB-FM,HM-LC-BL1-SM,HM-LC-Bl1-FM-2,HM-LC-Bl1-SM-2,HM-LC-Bl1PBU-FM,HM-LC-DDC1-PCB,HM-LC-DIM1L-CV,HM-LC-DIM1L-PL,HM-LC-DIM1T-CV,HM-LC-DIM1T-FM,HM-LC-DIM1T-PL,HM-LC-DIM2L-CV,HM-LC-DIM2L-SM,HM-LC-DIM2T-SM,HM-LC-Dim1L-CV-2,HM-LC-Dim1L-CV-644,HM-LC-Dim1L-Pl-2,HM-LC-Dim1L-Pl-3,HM-LC-Dim1L-Pl-644,HM-LC-Dim1PWM-CV,HM-LC-Dim1PWM-CV-2,HM-LC-Dim1T-CV-2,HM-LC-Dim1T-CV-644,HM-LC-Dim1T-FM-2,HM-LC-Dim1T-FM-644,HM-LC-Dim1T-FM-LF,HM-LC-Dim1T-Pl-2,HM-LC-Dim1T-Pl-3,HM-LC-Dim1T-Pl-644,HM-LC-Dim1TPBU-FM,HM-LC-Dim1TPBU-FM-2,HM-LC-Dim2L-SM-2,HM-LC-Dim2L-SM-644,HM-LC-Dim2T-SM,HM-LC-Dim2T-SM-2,HM-LC-RGBW-WM,HM-LC-SW1-BA-PCB,HM-LC-SW1-FM,HM-LC-SW1-PB-FM,HM-LC-SW1-PL,HM-LC-SW1-PL-OM54,HM-LC-SW1-PL2,HM-LC-SW1-SM,HM-LC-SW1-SM-ATMEGA168,HM-LC-SW2-DR,HM-LC-SW2-FM,HM-LC-SW2-PB-FM,HM-LC-SW2-SM,HM-LC-SW4-BA-PCB,HM-LC-SW4-DR,HM-LC-SW4-PCB,HM-LC-SW4-SM,HM-LC-SW4-SM-ATMEGA168,HM-LC-SW4-WM,HM-LC-Sw1-DR,HM-LC-Sw1-FM-2,HM-LC-Sw1-Pl-3,HM-LC-Sw1-Pl-CT-R1,HM-LC-Sw1-Pl-CT-R2,HM-LC-Sw1-Pl-CT-R3,HM-LC-Sw1-Pl-CT-R4,HM-LC-Sw1-Pl-CT-R5,HM-LC-Sw1-Pl-DN-R1,HM-LC-Sw1-Pl-DN-R2,HM-LC-Sw1-Pl-DN-R3,HM-LC-Sw1-Pl-DN-R4,HM-LC-Sw1-Pl-DN-R5,HM-LC-Sw1-SM-2,HM-LC-Sw1PBU-FM,HM-LC-Sw2-DR-2,HM-LC-Sw2-FM-2,HM-LC-Sw2PBU-FM,HM-LC-Sw4-DR-2,HM-LC-Sw4-PCB-2,HM-LC-Sw4-SM-2,HM-LC-Sw4-WM-2,HM-MOD-Em-8,HM-MOD-Re-8,HM-OU-CF-PL,HM-OU-CFM-PL,HM-OU-CFM-TW,HM-OU-CM-PCB,HM-OU-LED16,HM-PB-2-FM,HM-PB-2-WM,HM-PB-2-WM55,HM-PB-2-WM55-2,HM-PB-4-WM,HM-PB-4DIS-WM,HM-PB-4DIS-WM-2,HM-PB-6-WM55,HM-PBI-4-FM,HM-RC-12,HM-RC-12-B,HM-RC-12-SW,HM-RC-19,HM-RC-19-B,HM-RC-19-SW,HM-RC-2-PBU-FM,HM-RC-4,HM-RC-4-2,HM-RC-4-3,HM-RC-4-3-D,HM-RC-4-B,HM-RC-8,HM-RC-Dis-H-x-EU,HM-RC-KEY3,HM-RC-KEY3-B,HM-RC-Key4-2,HM-RC-Key4-3,HM-RC-P1,HM-RC-SEC3,HM-RC-SEC3-B,HM-RC-Sec4-2,HM-RC-Sec4-3,HM-SCI-3-FM,HM-SEC-KEY,HM-SEC-KEY-O,HM-SEC-KEY-S,HM-SEC-MDIR,HM-SEC-MDIR-2,HM-SEC-MDIR-3,HM-SEC-RHS,HM-SEC-RHS-2,HM-SEC-SC,HM-SEC-SC-2,HM-SEC-SCo,HM-SEC-SD,HM-SEC-SD-2,HM-SEC-SFA-SM,HM-SEC-TIS,HM-SEC-WDS,HM-SEC-WDS-2,HM-SEC-WIN,HM-SEN-EP,HM-SEN-MDIR-SM,HM-SWI-3-FM,HM-Sec-Cen,HM-Sec-Sir-WM,HM-Sen-DB-PCB,HM-Sen-LI-O,HM-Sen-MDIR-O,HM-Sen-MDIR-O-2,HM-Sen-MDIR-WM55,HM-Sen-RD-O,HM-Sen-Wa-Od,HM-Sys-sRP-Pl,HM-TC-IT-WM-W-EU,HM-WDC7000,HM-WDS10-TH-O,HM-WDS100-C6-O,HM-WDS100-C6-O-2,HM-WDS20-TH-O,HM-WDS30-OT2-SM,HM-WDS30-OT2-SM-2,HM-WDS30-T-O,HM-WDS40-TH-I,HM-WDS40-TH-I-2,HM-WS550,HM-WS550LCB,HM-WS550LCW,HM-WS550Tech,IS-WDS-TH-OD-S-R3,KFM-Display,KFM-Sensor,KS550,KS550LC,KS550TECH,KS888,OLIGO-smart-iq-HM,PS-Th-Sens,PS-switch,ROTO_ZEL-STG-RM-DWT-10,ROTO_ZEL-STG-RM-FDK,ROTO_ZEL-STG-RM-FEP-230V,ROTO_ZEL-STG-RM-FSA,ROTO_ZEL-STG-RM-FST-UP4,ROTO_ZEL-STG-RM-FWT,ROTO_ZEL-STG-RM-FZS,ROTO_ZEL-STG-RM-FZS-2,ROTO_ZEL-STG-RM-HS-4,ROTO_ZEL-STG-RM-WT-2,Roto_ZEL-STG-RM-FFK,Roto_ZEL-STG-RM-FSS-UP3,S550IA,Schueco_263-130,Schueco_263-131,Schueco_263-132,Schueco_263-133,Schueco_263-134,Schueco_263-135,Schueco_263-144,Schueco_263-145,Schueco_263-146,Schueco_263-147,Schueco_263-155,Schueco_263-157,Schueco_263-158,Schueco_263-160,Schueco_263-162,Schueco_263-167,Schueco_263-xxx,SensoTimer-ST-6,WDF-solar,WS888 subType:AlarmControl,KFM100,THSensor,blindActuator,blindActuatorSol,dimmer,keyMatic,motionAndBtn,motionDetector,outputUnit,powerMeter,powerSensor,pushButton,remote,repeater,rgb,senBright,sensRain,sensor,singleButton,siren,smokeDetector,swi,switch,thermostat,threeStateSensor,timer,tipTronic,virtual,winMatic cmdIcon devStateIcon devStateStyle icon sortby webCmd widgetOverride userattr",
        "Internals": {
        "DEF": "34DCA0",
        "HMLAN1_MSGCNT": "10",
        "HMLAN1_RAWMSG": "E34DCA0,0000,09FC0222,FF,FFDA,0AA41034DCA00E007006010000",
        "HMLAN1_RSSI": "-38",
        "HMLAN1_TIME": "2016-08-15 08:10:11",
        "LASTInputDev": "HMLAN1",
        "MSGCNT": "10",
        "NAME": "DIM_Wohnzimmer_A200",
        "NR": "194",
        "NTFY_ORDER": "50-DIM_Wohnzimmer_A200",
        "STATE": "off",
        "TYPE": "CUL_HM",
        "lastMsg": "No:0A - t:10 s:34DCA0 d:0E0070 06010000",
        "peerList": "Taster_DIM_Wohnzimmer,",
        "protLastRcv": "2016-08-15 08:10:11",
        "protSnd": "10 last_at:2016-08-15 08:10:11",
        "protState": "CMDs_done",
        "rssi_HMLAN1": "avg:-40 min:-40 max:-40 lst:-40 cnt:1 ",
        "rssi_at_HMLAN1": "avg:-38.5 min:-40 max:-35 lst:-38 cnt:10 "
        "Readings": {
        "CommandAccepted": { "Value":"yes", "Time":"2016-08-05 18:15:19" },
        "D-firmware": { "Value":"2.3", "Time":"2016-08-05 18:11:07" },
        "D-serialNr": { "Value":"NEQ0044007", "Time":"2016-08-05 18:11:07" },
        "PairedTo": { "Value":"0x0E0070", "Time":"2016-08-05 18:15:23" },
        "R-Taster_DIM_Wohnzimmer-lgActionTypeDim": { "Value":"toggelDim", "Time":"2016-08-05 18:15:26" },
        "R-Taster_DIM_Wohnzimmer-lgOnLevel": { "Value":"100 %", "Time":"2016-08-05 18:15:26" },
        "R-Taster_DIM_Wohnzimmer-shActionTypeDim": { "Value":"jmpToTarget", "Time":"2016-08-05 18:15:26" },
        "R-Taster_DIM_Wohnzimmer-shOnLevel": { "Value":"100 %", "Time":"2016-08-05 18:15:26" },
        "R-loadAppearBehav": { "Value":"off", "Time":"2016-08-05 18:11:12" },
        "R-pairCentral": { "Value":"0x0E0070", "Time":"2016-08-05 18:11:12" },
        "R-powerUpAction": { "Value":"off", "Time":"2016-08-05 18:11:12" },
        "RegL_00.": { "Value":"02:01 0A:0E 0B:00 0C:70 15:FF 16:00 00:00", "Time":"2016-08-05 18:15:23" },
        "RegL_01.": { "Value":"12:01 30:06 31:00 56:00 57:24 00:00", "Time":"2016-08-05 18:15:24" },
        "RegL_03.Taster_DIM_Wohnzimmer": { "Value":"01:00 02:00 03:00 04:32 05:64 06:00 07:FF 08:00 09:FF 0A:01 0B:14 0C:52 0D:63 0E:20 0F:00 10:14 11:C8 12:0A 13:05 14:05 15:00 16:C8 17:0A 18:0A 19:04 1A:04 81:00 82:00 83:00 84:32 85:64 86:00 87:FF 88:00 89:FF 8A:26 8B:14 8C:52 8D:63 8E:20 8F:00 90:14 91:C8 92:0A 93:05 94:05 95:00 96:C8 97:0A 98:0A 99:04 9A:04 00:00", "Time":"2016-08-05 18:15:26" },
        "deviceMsg": { "Value":"off (to VCCU)", "Time":"2016-08-15 08:10:11" },
        "dim": { "Value":"stop:off", "Time":"2016-08-15 08:10:11" },
        "level": { "Value":"0", "Time":"2016-08-15 08:10:11" },
        "overheat": { "Value":"off", "Time":"2016-08-15 08:10:11" },
        "overload": { "Value":"off", "Time":"2016-08-15 08:10:11" },
        "pct": { "Value":"0", "Time":"2016-08-15 08:10:11" },
        "peerList": { "Value":"Taster_DIM_Wohnzimmer,", "Time":"2016-08-13 08:26:27" },
        "recentStateType": { "Value":"info", "Time":"2016-08-15 08:10:11" },
        "reduced": { "Value":"off", "Time":"2016-08-15 08:10:11" },
        "state": { "Value":"off", "Time":"2016-08-15 08:10:11" },
        "timedOn": { "Value":"off", "Time":"2016-08-15 08:10:11" }
        "Attributes": {
        "IODev": "HMLAN1",
        "autoReadReg": "4_reqStatus",
        "expert": "2_raw",
        "firmware": "2.3",
        "model": "HM-LC-DIM1L-CV",
        "peerIDs": "00000000,393B3101,",
        "room": "CUL_HM,Wohnzimmer",
        "serialNr": "NEQ0044007",
        "subType": "dimmer",
        "webCmd": "statusRequest:toggle:on:off:up:down"
        "totalResultsReturned":1
        Rollo folgt
        Gruss Holli
          Hallo
          Mit welchen Widget in I/O Broker kann ich einen normalen Ausgang in Fhem (on/off) testen
          Gruss Holli
            Hallo
            Und hier das Rollo
            "Arg":"Tim_Rollo1",
            "Results": [
            "Name":"Tim_Rollo1",
            "PossibleSets":" config raw reset:noArg settings ",
            "PossibleAttrs":"verbose:0,1,2,3,4,5 room group comment:textField-long alias eventMap userReadings:textField-long autoReadConfig:atstartup,always,never configReadRetries do_not_notify:0,1 ignore:1,0 dummy:1,0 showtime:1,0 serialNr model:HMW_Generic,HMW_IO_12_Sw14_DR,HMW_IO_12_FM,HMW_Sen_SC_12_FM,HMW_LC_Bl1_DR,HMW_IO_12_Sw7_DR,HMW_LC_Dim1L_DR,HMW_LC_Sw2_DR,HMW_Sen_SC_12_DR,HMW_IO_4_FM,HMW_IO_SR_FM subType stateFormat firmwareVersion setList event-min-interval event-aggregator IODev event-on-change-reading event-on-update-reading cmdIcon devStateIcon devStateStyle icon sortby webCmd widgetOverride userattr",
            "Internals": {
            "DEF": "0000EA87",
            "FW_VERSION": "3.06",
            "FailedConfigReads": "0",
            "MODEL": "HMW_LC_Bl1_DR",
            "NAME": "Tim_Rollo1",
            "NR": "183",
            "STATE": "ACK",
            "TYPE": "HM485",
            "channel_01": "Tim_Rollo1_Ab",
            "channel_02": "Tim_Rollo1_Auf",
            "channel_03": "Tim_Rollo1_Motor",
            "peer_act_0": "channel_01 → Tim_Rollo1_Motor",
            "peer_act_1": "channel_02 → Tim_Rollo1_Motor",
            "peer_sen_0": "channel_03 ← Tim_Rollo1_Ab",
            "peer_sen_1": "channel_03 ← Tim_Rollo1_Auf"
            "Readings": {
            "R-central_address": { "Value":"00000001", "Time":"2016-08-13 08:26:48" },
            "R-logging_time": { "Value":"2.00", "Time":"2016-08-13 08:26:48" },
            "configStatus": { "Value":"OK", "Time":"2016-08-13 08:26:48" },
            "state": { "Value":"ACK", "Time":"2016-08-13 08:26:48" }
            "Attributes": {
            "IODev": "HM485_LAN",
            "firmwareVersion": "3.06",
            "model": "HMW_LC_Bl1_DR",
            "room": "HM485,Tim",
            "serialNr": "leq1182362"
            Gruss Holli
              Hallo
              Ein Raumthermostat wäre auch noch Interessant
              "Arg":"TH_Tim_1",
              "Results": [
              "Name":"TH_Tim_1",
              "PossibleSets":"assignHmKey clear:readings,trigger,register,oldRegs,rssi,msgEvents,attack,all deviceRename fwUpdate getConfig getRegRaw getSerial inhibit:on,off raw regBulk regSet reset sysTime unpair",
              "Internals": {
              "CFGFN": "",
              "DEF": "3AE4DB",
              "HMLAN1_MSGCNT": "69",
              "HMLAN1_RAWMSG": "E3AE4DB,0000,001D602C,FF,FFB3,8E84703AE4DB00000000EC3E",
              "HMLAN1_RSSI": "-77",
              "HMLAN1_TIME": "2016-08-15 21:51:19",
              "MSGCNT": "69",
              "NAME": "TH_Tim_1",
              "NR": "227",
              "STATE": "CMDs_done",
              "TYPE": "CUL_HM",
              "channel_01": "HM_3AE4DB_Weather",
              "channel_02": "HM_3AE4DB_Climate",
              "channel_03": "HM_3AE4DB_WindowRec",
              "channel_06": "HM_3AE4DB_remote",
              "channel_07": "HM_3AE4DB_SwitchTr",
              "lastMsg": "No:8E - t:70 s:3AE4DB d:000000 00EC3E",
              "protLastRcv": "2016-08-15 21:51:19",
              "protSnd": "59 last_at:2016-08-15 21:49:34",
              "rssi_at_HMLAN1": "avg:-70.69 min:-78 max:-65 lst:-77 cnt:69 "
              "Readings": {
              "Activity": { "Value":"alive", "Time":"2016-08-15 21:49:14" },
              "CommandAccepted": { "Value":"yes", "Time":"2016-08-15 21:49:19" },
              "D-firmware": { "Value":"1.2", "Time":"2016-08-15 21:49:09" },
              "D-serialNr": { "Value":"MEQ0476401", "Time":"2016-08-15 21:49:09" },
              "PairedTo": { "Value":"0x0E0070", "Time":"2016-08-15 21:49:19" },
              "R-burstRx": { "Value":"on", "Time":"2016-08-15 21:49:19" },
              "R-cyclicInfoMsg": { "Value":"on", "Time":"2016-08-15 21:49:19" },
              "R-cyclicInfoMsgDis": { "Value":"0", "Time":"2016-08-15 21:49:19" },
              "R-pairCentral": { "Value":"0x0E0070", "Time":"2016-08-15 21:49:19" },
              "RegL_00.": { "Value":" 01:01 02:01 09:01 0A:0E 0B:00 0C:70 0F:00 11:00 12:16 16:01 18:00 19:00 1A:00 00:00", "Time":"2016-08-15 21:49:19" },
              "RegL_07.": { "Value":"", "Time":"2016-08-15 21:51:11" },
              "battery": { "Value":"ok", "Time":"2016-08-15 21:51:09" },
              "batteryLevel": { "Value":"3", "Time":"2016-08-15 21:51:09" },
              "desired-temp": { "Value":"24.0", "Time":"2016-08-15 21:51:09" },
              "measured-temp": { "Value":"23.6", "Time":"2016-08-15 21:51:09" },
              "state": { "Value":"CMDs_done", "Time":"2016-08-15 21:49:34" },
              "time-request": { "Value":"-", "Time":"2016-08-15 21:49:15" }
              "Attributes": {
              "IODev": "HMLAN1",
              "actCycle": "000:10",
              "actStatus": "alive",
              "expert": "2_raw",
              "firmware": "1.2",
              "model": "HM-TC-IT-WM-W-EU",
              "msgRepeat": "1",
              "room": "CUL_HM,Tim",
              "serialNr": "MEQ0476401",
              "subType": "thermostat",
              "webCmd": "getConfig:clear msgEvents"
              Gruss Holli
                Hallo
                Also heute Abend einige Sachen getestet
                Rolladen Steuerung funktioniert einwandfrei (up down)
                mit hqwidget
                Dimmer Steuerung funktioniert mit Einschränkungen
                Slider springt. Mein Eindruck hier gibt es ein zeitliches Problem
                mit der Rückmeldung aus Fhem
                Normale Lichtsteuerung (on,off,toggle) schalten geht
                Rückmeldung kommt im widget nicht an
                Raumthermostat Ist-Werte für Temperatur und Feuchtigkeit
                werden sauber übertragen und angezeigt im hqwidget
                Sollwert schreiben funktioniert sowohl im widget wie auch im ioBroker direkt nicht
                Gruss Holli
                  Hallo
                  Nachtrag Lichtsteuerung funktioniert einwandfrei
                  Gruss Holli
                    jojoman3 last edited by
                    ich wollte das Plugin mal ausprobieren, bin aber darüber gestolpert, dass mein FHEM telnet port Passwort geschützt ist und ich in der Plugin Konfig keine Möglichkeit gefunden habe, dass PW mitzugeben.
                    Ist es hier geplant, dass das Plugin das unterstützt?
                    jojoman3
                    • Bluefox
                      @jojoman3:
                      jojoman3 `
                      Wie schalte ich password ein?
                      define tPort telnet 7072 global
                      attr tPort SSL
                      attr allowed_tPort allowed
                      attr allowed_tPort validFor tPort
                      attr allowed_tPort globalpassword mySecret
                      macht bei mir nichts, obwohl ich von einer anderen Machine mich verbinde.
                      Ich kann natürlich blind einbauen, dafür muss ich aber wissen, warum ganz am Anfang muss man 3 mal Enter drücken, nachdem die Verbindung aufgebaut ist?
                      Und was ist mit "
                      > ein Passwort, welches als allererster String eingegeben werden muss, nachdem die Verbindung aufgebaut wurde
                      gemeint ist.
                      Wirklich aller erster oder nach dem als man 3 mal Enter gedrückt hat?
                      • Lenny.CB
                        Lenny.CB Most Active last edited by
                        hallo BF,
                        da ja Z-wave unter IoB nicht so recht rockt, bin ich auch den Umweg über FHEM gegangen. Ich sage gleich dazu, habe von FHEM keine Ahnung!
                        Hier eins meiner Rollos (FIBARO Roller Shutter 2 / FGR-222)
                        Die ausgabe ist gezogen kurz nachdem ich das Gerät angelernt habe.
                        Steuerung von IoB aus:
                        on/off –> komplett hoch oder runter
                        dim --> Zahl zwischen 0-99 (hier musste ich aber noch die "[" bei "states" löschen --> siehe Bild FHEM2.img)
                        JsonList2:
                        ! "Arg":"ZWave_SWITCH_MULTILEVEL_2",
                        ! "Results": [
                        ! "Name":"ZWave_SWITCH_MULTILEVEL_2",
                        ! "PossibleSets":"associationAdd associationDel configByte configDefault configLong configWord dim:slider,0,1,99 dimWithDuration mcaAdd mcaDel meterReset:noArg neighborUpdate:noArg off:noArg on:noArg powerlevel powerlevelTest protectionBytes protectionOff:noArg protectionOn:noArg protectionSeq:noArg returnRouteAdd returnRouteDel:noArg sceneActivate stop:noArg toggle on-till off-till off-for-timer intervals on-for-timer on-till-overnight blink off-till-overnight",
                        ! "PossibleAttrs":"alias comment:textField-long eventMap group room suppressReading userReadings:textField-long verbose:0,1,2,3,4,5 IODev WNMI_delay noWakeupForApplicationUpdate:1,0 classes do_not_notify:1,0 dummy:1,0 extendedAlarmReadings:0,1,2 ignore:1,0 noExplorerFrames:1,0 eventForRaw secure_classes showtime:1,0 vclasses zwaveRoute neighborListPos event-on-change-reading event-on-update-reading event-aggregator event-min-interval stateFormat:textField-long timestamp-on-change-reading cmdIcon devStateIcon devStateStyle icon sortby webCmd widgetOverride userattr",
                        ! "Internals": {
                        ! "DEF": "c003b538 2",
                        ! "LASTInputDev": "ZWDongle_0",
                        ! "MSGCNT": "22",
                        ! "NAME": "ZWave_SWITCH_MULTILEVEL_2",
                        ! "NR": "23",
                        ! "STATE": "dim 99",
                        ! "TYPE": "ZWave",
                        ! "ZWDongle_0_MSGCNT": "22",
                        ! "ZWDongle_0_RAWMSG": "000400020a320221440000001c0000",
                        ! "ZWDongle_0_TIME": "2016-10-03 12:27:08",
                        ! "ZWaveSubDevice": "no",
                        ! "homeId": "c003b538",
                        ! "isWakeUp": "",
                        ! "lastMsgSent": "1475489993.04154",
                        ! "nodeIdHex": "02"
                        ! "Readings": {
                        ! "energy": { "Value":" 0.28 kWh", "Time":"2016-10-03 12:27:08" },
                        ! "power": { "Value":"0.0 W", "Time":"2016-10-03 12:19:55" },
                        ! "reportedState": { "Value":"dim 99", "Time":"2016-10-03 12:19:55" },
                        ! "state": { "Value":"dim 99", "Time":"2016-10-03 12:19:55" },
                        ! "timeToAck": { "Value":"0.592", "Time":"2016-10-03 12:19:53" },
                        ! "transmit": { "Value":"OK", "Time":"2016-10-03 12:19:53" }
                        ! "Attributes": {
                        ! "IODev": "ZWDongle_0",
                        ! "classes": "MULTI_CHANNEL_ASSOCIATION MANUFACTURER_SPECIFIC VERSION CONFIGURATION ASSOCIATION POWERLEVEL METER SWITCH_MULTILEVEL SENSOR_MULTILEVEL SWITCH_BINARY MANUFACTURER_PROPRIETARY PROTECTION MARK METER SENSOR_MULTILEVEL MANUFACTURER_PROPRIETARY SCENE_ACTIVATION SWITCH_MULTILEVEL SWITCH_BINARY",
                        ! "room": "ZWave"
                        ! "totalResultsReturned":1
                        Kann noch anbieten:
                        FIBARO Universalsensor (FGBS-001)
                        AEOTEC Home Energy Meter (2nd Edition)
                        Grüße, Lenny…
                        • Lenny.CB
                          Hallo Bluefox, sag mal, sprechen IoB und FHEM schon in beiden Richtungen miteinander?
                          mir ist heut Folgendes aufgefallen:
                          IoB:
                          "state" im Reiter "Objekte" setzen –> geht (0-99)
                          "state" über Adapter "Szenen" setzen --> geht (0-99)
                          "state" mit "jqui-mfd - Shutter + jqui Dialog" setzen --> geht (0-99)
                          Bei allen Aktionen die in <u>IoB</u> ausgelößt werden, aktualisiert sich FHEM.
                          FHEM:
                          Rollos hoch, runter und dazwischen –> geht
                          Bei allen Aktionen die in <u>FHEM</u> ausgelößt werden, aktualisiert sich IoB <u>nicht</u>.
                          am Rollo-Taster:
                          Bei allen Aktionen die am <u>Taster</u> ausgelößt werden, aktualisiert sich FHEM, aber IoB <u>nicht</u>.
                          Die "state´s" werden auch nach einem FHEM-Adapter-Neustart nicht aktualisiert.
                          Grüße, Lenny
                          49
                          13050
