    4. Material Design Widgets: Line History Chart Widget
      sigi234 Forum Testing Most Active @Bostil last edited by sigi234
      @Bostil
      Erhöhe das Diagramm Time Out unter Allgemein
      Edit: geht bei mir auch nicht.
      Welche Version hast du?
      Bostil 1 Reply Last reply Reply Quote 0
      • Bostil
        Bostil @sigi234 last edited by
        @sigi234 Danke dir. Habe Version 0.3.19 der Material Design Widgets.
        • besterquester
          besterquester Developer @Scrounger last edited by
          @Scrounger Hi, I am testin the lineHistory Chart. I would like to extend the chart to'bar' mode. I would like to support you in the development. I tried to fork and change the properties. Maybe you can give me a hint where to start.
          With the json chart i developed a javascript class but would be better to have it as widget available
          regards Chris
          • Scrounger
            Scrounger Developer @besterquester last edited by
            @besterquester sagte in Material Design Widgets: Line History Chart Widget:
            That would be great!
            The code of the line chart history can be found here https://github.com/Scrounger/ioBroker.vis-materialdesign/blob/f72f81203c23cbb6e750d7033052d27605f9017e/widgets/materialdesign/js/widgets/materialdesign.chart.js#L334.
            Think this is a good point to start. Please note that some functions are used by all charts, so you always have to test this too.
            I use Minify to merge all widgets *.js files into one minifed file.
            Im using VS Code as IDE and there it has a plugin Minify that will do this automatically.
            If you have further questions, just contact me.
            besterquester 2 Replies Last reply Reply Quote 1
            • Steff
              Steff last edited by
              gibt es eine Möglichkeit in den Tooltips die Einheit des entsprechenden Datenpunkts anzuzeigen?
              Ich kann im Tooltip Layout unter Text Anhang eine Einheit angeben, die gilt dann aber für alle Linien.
              Gruß Steffen
              • besterquester
                @Scrounger Thanks i try to start to extend the history chart also used to visualize bar charts. I will get in contact when i have a ready version
                regards Chris
                • besterquester
                  besterquester Developer @Scrounger last edited by besterquester
                  @Scrounger said in Material Design Widgets: Line History Chart Widget:
                  Just one question. I installed minify and what is to do in order to test the adapter. I am using visual code remote so i am directly on the adapter (RASPI PI). It seems the adapter do not accept changes I make in the code. The minify works but there is no change. Restarting adapter stop and start also is not working.
                  Maybe you can give a hint. 🙂
                  regards Chris
                  • Scrounger
                    Scrounger Developer @besterquester last edited by Scrounger
                    regards Chris
                    To see the changes immideatly, change the files in iobroker\iobroker-data\files\vis\widgets\materialdesign and make a reload of the page. After you are finished with the changes dont forget to copy these into your project folder.
                    @Steff sagte in Material Design Widgets: Line History Chart Widget:
                    Gruß Steffen
                    Stimmt für tooltip geht das nur global. Schreib bitte nen issue auf github, dann bau ich das mit ein.
                    • werner2000x
                      werner2000x @Coffeelover last edited by
                      @Coffeelover Wie kann man die Zahlen der Datenpunkte entfernen?
                      Mit "Linien zwischen Punkten ohne Daten" geht es nicht.
                        sigi234 Forum Testing Most Active @werner2000x last edited by
                        @werner2000x
                        werner2000x 1 Reply Last reply Reply Quote 0
                        • werner2000x
                          werner2000x @sigi234 last edited by
                          @sigi234 Danke, hat geklappt 🙂
                          • CKMartens
                            CKMartens last edited by
                            ich versuche das Widget mit Daten von influx zu füttern.
                            Leider kommt nur die Meldung Error: [0] [object Object], [1] [object Object]
                            Eingestellt habe ich als Adapterinstanz influxdb.0
                            Bei Datensätze habe ich die OIDs der Datenpunkte angegeben die in mittels influxdb gespeichert werden.
                            Was muss ich wo einstellen damit es funktioniert? Danke für eure Hilfe.
                            Carsten
                              Snapergy last edited by Snapergy
                              1. Gibt es eventuell ne Möglichkeit den Min- und den Max-Wert für den angezeigten Zeitraum hervorheben zu lassen?
                              2. Gibt es ne Möglichkeit die History-Daten zeitlich zu shiften? Ich würde gerne pro Tag den Max- und Min-Wert loggen und dann am Ende des Tages in einen Datenpunkt eintragen, der history-mäßig dann gespeichert wird. Wenn ich mir dann aber eine gestufte Grafik ausgeben lasse, ist der Sprung ja immer erst am Ende des Tages, ich bräuchte ihn aber ja 24h eher
                                Andi81 last edited by
                                Guten Morgen,
                                ich finde die Widgets echt genial.
                                Ich experimentiere gerade mit dem Line History Chart. Da kommt mir folgende Frage: Kann man die Object ID's auch dynamisieren?
                                Ich hätte gerne nur ein Chart und möchte die anzuzeigenden Variablen dynamisch hinzufügen und entfernen, um mir in der vis.runtime das Diagramm so zu gestalten wie ich es in dem Moment benötige.
                                Andi
                                S Scrounger 2 Replies Last reply Reply Quote 0
                                  Snapergy @Andi81 last edited by
                                  @Andi81
                                  Sowas habe ich mit nem ViewInWidget8 umgesetzt
                                  • Scrounger
                                    Scrounger Developer @Andi81 last edited by Scrounger
                                    @Andi81 sagte in Material Design Widgets: Line History Chart Widget:
                                    Guten Morgen,
                                    Andi
                                    Ja das geht anscheinend, wenn man als Objekt ID nen Binding verwendet und in das Objekt dann die Id der verschiedenen DPs zum anzeigen schreibt (z.B. mittels Select Widget). Das hatten wir auch schon mal diskutiert, entweder hier oder in den verschiedenen testing threads des MDW Adapters. Musst mal suchen. Ich selber hab das aber nicht in Verwendung.
                                      kristina.da @Scrounger last edited by
                                      ich bin gerade dabei meine Handy Visualiserung umzusetzen und habe ein Skalierungsproblem.
                                      Ich habe auf meine iPhone X nur 375x770px zur Verfügung und schaffe es nicht ein Diagramm mit Temperaturen in meiner
                                      View unterzubringen, ohne das es mir die Beschriftung der Y-Achse "wegschneidet" (siehe Screenshot).
                                      Anbei das exportierte Widget:
                                      [{"tpl":"tplVis-materialdesign-Chart-Line-History","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","dataCount":"4","aggregate":"average","timeIntervalToShow":"1 hour","refreshMethod":"timeInterval","refreshTimeInterval":"1 minute","chartTimeout":"2","pointStyle":"circle","showLegend":true,"legendPosition":"bottom","legendPointStyle":true,"showTooltip":false,"tooltipTimeFormats":"{\"millisecond\":\"lll:ss\",\"second\":\"lll:ss\",\"minute\":\"lll\",\"hour\":\"lll\",\"day\":\"lll\",\"week\":\"lll\",\"month\":\"lll\",\"quarter\":\"lll\",\"year\":\"lll\"}","tooltipShowColorBox":false,"lineSpanGaps0":"true","lineSpanGaps1":"true","xAxisPosition":"bottom","xAxisBounds":"dataSet","xAxisTimeFormats":"{\"minute\":\"H:mm [Uhr\\\\n] DD.MM[.]\",\"hour\":\"H:00 [Uhr\\\\n] DD.MM[.]\"} ","xAxisValueDistanceToAxis":"0","xAxisShowAxis":true,"xAxisShowAxisLabels":true,"xAxisShowGridLines":true,"xAxisShowTicks":"true","xAxisMinRotation":"0","xAxisMaxRotation":"0","yAxisValueDistanceToAxis":"10","showYAxis0":"true","yAxisPosition0":"left","yAxisShowGridLines0":"true","yAxisShowTicks0":"true","yAxisShowAxisBorder0":"true","showYAxis1":"true","yAxisPosition1":"left","yAxisShowGridLines1":"true","yAxisShowTicks1":"true","yAxisShowAxisBorder1":"true","showValues0":false,"valuesPositionAnchor0":"end","valuesPositionAlign0":"top","valuesTextAlign0":"center","showValues1":false,"valuesPositionAnchor1":"end","valuesPositionAlign1":"top","valuesTextAlign1":"center","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"historyAdapterInstance":"sql.0","lineSpanGaps2":"true","lineSpanGaps3":"true","lineSpanGaps4":"true","showYAxis2":"true","yAxisPosition2":"left","yAxisShowGridLines2":"true","yAxisShowTicks2":"true","yAxisShowAxisBorder2":"true","showYAxis3":"true","yAxisPosition3":"left","yAxisShowGridLines3":"true","yAxisShowTicks3":"true","yAxisShowAxisBorder3":"true","showYAxis4":"true","yAxisPosition4":"left","yAxisShowGridLines4":"true","yAxisShowTicks4":"true","yAxisShowAxisBorder4":"true","showValues2":false,"valuesPositionAnchor2":"end","valuesPositionAlign2":"top","valuesTextAlign2":"center","showValues3":false,"valuesPositionAnchor3":"end","valuesPositionAlign3":"top","valuesTextAlign3":"center","showValues4":false,"valuesPositionAnchor4":"end","valuesPositionAlign4":"top","valuesTextAlign4":"center","oid0":"zigbee.0.00158d000272e8b2.temperature","oid1":"zigbee.0.00158d000272ffb6.temperature","oid2":"zigbee.0.00158d0002774718.temperature","oid3":"zigbee.0.00158d0002797b32.temperature","oid4":"zigbee.0.00158d0002797b32.temperature","commonYAxis0":"4","commonYAxis1":"4","commonYAxis2":"4","commonYAxis3":"4","commonYAxis4":"","legendFontColor":"#FFFFFF","legendFontSize":"12","legendFontFamily":"helvetica","legendBoxWidth":"5","lineThikness0":"3","dataColor0":"#FFA500","useFillColor0":true,"lineThikness1":"3","dataColor1":"#21833b","dataColor2":"#1410bc","lineThikness2":"3","useFillColor2":true,"dataColor3":"#e51010","lineThikness3":"3","useFillColor3":true,"dataColor4":"#fc1df5","lineThikness4":"3","useFillColor4":true,"xAxisTitle":"","xAxisTitleColor":"#FFFFFF","xAxisTitleFontFamily":"helvetica","xAxisTitleFontSize":"10","xAxisValueLabelColor":"#FFFFFF","xAxisValueFontFamily":"helvetica","xAxisValueFontSize":"10","xAxisGridLinesColor":"#FFFFFF","xAxisGridLinesWitdh":"0.5","yAxisTitleColor":"#FFFFFF","yAxisTitleFontFamily":"helvetica","yAxisTitleFontSize":"","yAxisValueLabelColor":"#FFFFFF","yAxisValueFontFamily":"helvetica","legendText0":"Wohnzimmer","legendText1":"Küche","legendText2":"Bad","legendText3":"Schlafzimmer","lineTension3":"0","lineTension2":"0","lineTension1":"0","lineTension0":"0","lineTension4":"0","yAxisGridLinesWitdh4":"0.5","yAxisGridLinesColor4":"#FFFFFF","g_layoutForData_§5":false,"lineSpanGaps5":"true","g_lineValuesLayout_§5":false,"showValues5":"true","valuesPositionAnchor5":"end","valuesPositionAlign5":"top","valuesTextAlign5":"center","yAxisValueFontSize":"10","g_yAxisLayoutForData_§5":false,"showYAxis5":"true","yAxisPosition5":"left","yAxisShowGridLines5":"true","yAxisShowTicks5":"true","yAxisShowAxisBorder5":"true","yAxisValueMaxDigits1":"","yAxisValueMaxDigits4":"0","yAxisMaxLabel4":"","yAxisValueAppendText4":" °C","maxDataPoints":"","xAxisTickLength":"","xAxisOffsetGridLines":false,"xAxisMaxLabel":"","yAxisMinValue4":"","yAxisMaxValue4":"","yAxisStep4":"","valuesSteps0":"","valuesMaxDecimals0":"","valuesMaxDecimals4":""},"style":{"left":"12px","top":"326px","width":"471px","height":"430px"},"widgetSet":"materialdesign"}]
                                      Habt Ihr dazu ein Idee, wie ich das Diagramm evtl. noch zusammenschrumpfen könnte?
                                      Danke und Grüße,
                                      Kristina
                                        micklafisch @kristina.da last edited by
                                        @kristina-da
                                        versuch mal unter Diagramm Layout -> Abstand von links zu setzen. Hatte mal mit dem oberen Rand Schwierigkeiten und das hatte geholfen.
                                        • O
                                          oranggila @MarEhg last edited by
                                          @MarEhg Unter group_yAxisLayoutForData[0] die Werte yAxisValueMinDigits[0] und yAxisValueMaxDigits[0]=3 setzen:
                                          • O
                                            oranggila @sveni_lee last edited by
                                            @sveni_lee Das interessiert mich auch. Kann man für yAxisMin/MaxValue keine Kommazahl eingeben?
                                            vis
                                            61
                                            202
                                            34015
