    3. Cloud Dienste
    4. Allgemein Google Home mit Iobroker (gelöst)
    • Marco Willi
      Marco Willi @Thomas Braun last edited by
      @Thomas-Braun na toll, bin doch anfänger. Wie meinste das?
      • Marco Willi
        Marco Willi @Marco Willi last edited by
        Log.txt
        • Marco Willi
          @Thomas-Braun besser so?
            Thomas Braun Most Active @Marco Willi last edited by
            @Marco-Willi
            Nee. Entsprechenden Text markieren und dann das Icon </> anklicken.
            Marco Willi 1 Reply Last reply Reply Quote 0
            • Marco Willi
              2020-11-11 20:45:43.328 - info: web.0 (1997) ==>Connected system.user.admin from ::ffff:192.168.1.154
              2020-11-11 20:45:44.851 - info: web.0 (1997) <==Disconnect system.user.admin from ::ffff:192.168.1.154 vis.0
              2020-11-11 20:45:46.220 - info: web.0 (1997) ==>Connected system.user.admin from ::ffff:192.168.1.154
              2020-11-11 20:45:51.888 - info: web.0 (1997) <==Disconnect system.user.admin from ::ffff:192.168.1.154 vis.0
              2020-11-11 20:45:52.490 - info: web.0 (1997) ==>Connected system.user.admin from ::ffff:192.168.1.154
              2020-11-11 20:45:58.741 - info: web.0 (1997) <==Disconnect system.user.admin from ::ffff:192.168.1.154 vis.0
              2020-11-11 20:46:38.826 - info: host.raspberrypi "system.adapter.iot.0" enabled
              2020-11-11 20:46:38.864 - info: host.raspberrypi instance system.adapter.iot.0 started with pid 25632
              2020-11-11 20:46:40.925 - info: iot.0 (25632) starting. Version 1.5.3 in /opt/iobroker/node_modules/iobroker.iot, node: v12.19.0, js-controller: 3.1.6
              2020-11-11 20:46:40.965 - info: iot.0 (25632) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
              2020-11-11 20:46:41.560 - info: iot.0 (25632) Connection changed: connect
              2020-11-11 20:46:41.629 - error: iot.0 (25632) [GHOME] Url Key error. Google Request and Response are working. But device states are not reported automatically. If you have pro license please try to delete iot.0.certs: {"error":"Email not found or URL key not found"}
              2020-11-11 20:46:41.630 - warn: iot.0 (25632) [GHOME] Invalid URL Pro key. Status auto-update is disabled you can set states but receive states only manually: {"error":"Email not found or URL key not found"}
              2020-11-11 20:46:47.353 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              2020-11-11 20:46:47.354 - error: iot.0 (25632) unhandled promise rejection: Test is not defined
              2020-11-11 20:46:47.359 - error: iot.0 (25632) ReferenceError: Test is not defined
              at eval (eval at (/opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2920:62), :1:1)
              at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2921:63
              at Array.forEach ()
              at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2917:43
              at Array.forEach ()
              at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2825:61
              at Array.forEach ()
              at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2802:37
              at Array.forEach ()
              at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2799:35
              2020-11-11 20:46:47.375 - info: iot.0 (25632) terminating
              2020-11-11 20:46:47.377 - info: iot.0 (25632) Terminated (NO_ERROR): Without reason
              2020-11-11 20:46:47.407 - info: iot.0 (25632) Connection changed: disconnect
              2020-11-11 20:46:47.408 - info: iot.0 (25632) Connection lost
              2020-11-11 20:46:47.927 - error: host.raspberrypi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
              2020-11-11 20:46:47.928 - error: host.raspberrypi Caught by controller[1]: ReferenceError: Test is not defined
              2020-11-11 20:46:47.929 - error: host.raspberrypi Caught by controller[1]: at eval (eval at (/opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2920:62), :1:1)
              2020-11-11 20:46:47.929 - error: host.raspberrypi Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2921:63
              2020-11-11 20:46:47.930 - error: host.raspberrypi Caught by controller[1]: at Array.forEach ()
              2020-11-11 20:46:47.930 - error: host.raspberrypi Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2917:43
              2020-11-11 20:46:47.931 - error: host.raspberrypi Caught by controller[1]: at Array.forEach ()
              2020-11-11 20:46:47.931 - error: host.raspberrypi Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2825:61
              2020-11-11 20:46:47.932 - error: host.raspberrypi Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2802:37
              2020-11-11 20:46:47.932 - error: host.raspberrypi Caught by controller[1]: at Array.forEach ()
              2020-11-11 20:46:47.933 - error: host.raspberrypi Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2799:35
              2020-11-11 20:46:47.933 - info: host.raspberrypi instance system.adapter.iot.0 terminated with code 0 (NO_ERROR)
                @Marco-Willi
                • Marco Willi
                  @Thomas-Braun jap, das habe ich schon ein paar mal gelesen und an den Kopf bekommen. Trotz Mailadressenwechsel und Neuregistrierung immer die gleiche Meldung. Was muss ich tun?
                  Thomas Braun Meister Mopper 2 Replies Last reply Reply Quote 0
                    @Marco-Willi
                    Hab kein iot pro, daher musste ich da auch noch nie was machen.
                    • Marco Willi
                      @Thomas-Braun soll ich es mal mit free versuchen? Meinste das könnte klappen? Ich will auch keine Lizenz für meine 2 Anfragen am Tag kaufen.
                      • Marco Willi
                        also mit free account bleibt der adapter auf gelb
                        • Meister Mopper
                          Meister Mopper @Marco Willi last edited by
                          @Marco-Willi sagte in Allgemein Google Home mit Iobroker:
                          Da steht ja, dass Du die certs löschen sollst. Hast Du das getan, mal auf den Mülleimer (s. Bild) geklickt?
                          Marco Willi 1 Reply Last reply Reply Quote 1
                          • Marco Willi
                            Marco Willi @Meister Mopper last edited by
                            @Meister-Mopper neiiin hab ich noch nicht. Fürs erste setzt ich das Projekt mal einer Pause aus. Nächste Woche nochmal.
                            Müsste ich dann was neues anfordern?
                            • Meister Mopper
                              @Marco-Willi Kostet ja nichts!
                              • Marco Willi
                                @meister-mopper
                                Hi Leute. Habe es jetzt in der zwischenzeit hinbekommen. Lag eher bei einem Verständnisproblem denke ich.
                                Alles nochmals auf. Sämtliche Verknüpfungen aufgehoben.
                                Alles neu registiert und wieder verknüpft. Ging nachher relativ flott.
                                Dann beim Broker die Sensoren die ich abfragen wollte reingeknallt und als Thermostat gekennzeichnet.
                                „Hey Google aktualisiere Geräte“ dann war iobroker auch mit von der Party und ich konnte die Geräte einem Raum zuordnen. Jetzt klappt es auch mit abfragen der Temps.
                                google home iot
                                2470
