    4. BLE Adapter Update Problem?
    UNSOLVED BLE Adapter Update Problem?
      M-A-X last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Qnap NAS
      Arbeitsspeicher: 2GB
      Festplattenart: virtuelle HDD
      Betriebssystem: Debian
      Node-Version: 12.19.0
      Nodejs-Version: 12.19.0
      NPM-Version: 6.14.8
      Installationsart: Skript
      Kaum ein "Problem" gelöst, kommt das nächste? Oder ist das normal?.
      Ich hab den BLE Adapter von 0.11.8 auf 0.12.0 geupdatet (über den Info Tab). Der dortige Log zeigt:
      npm install iobroker.ble@0.12.0 --loglevel error --prefix "/opt/iobroker" (System call)
      In file included from ../src/BluetoothHciSocket.cpp:8:../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
      In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node_buffer.h:25,                 from ../src/BluetoothHciSocket.cpp:7:../src/BluetoothHciSocket.cpp: At global scope:/home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:727:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]       (node::addon_register_func) (regfunc),                          \                                           ^/home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:761:3: note: in expansion of macro ‘NODE_MODULE_X’   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)   ^~~~~~~~~~~~~../src/BluetoothHciSocket.cpp:578:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(binding, BluetoothHciSocket::Init); ^~~~~~~~~~~
      upload [7] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/words.js words.js application/javascript
      Update "system.adapter.ble.0"
      upload [6] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/style.css style.css text/css
      upload [5] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/index_m.html index_m.html text/html
      upload [4] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/index.html index.html text/html
      upload [3] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.map build/index.map application/json
      upload [2] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.js.map build/index.js.map application/json
      upload [1] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.js build/index.js application/javascript
      upload [0] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/ble.png ble.png image/png
      Adapter "ble" updated
      process exited with code 0
      Die langen Zeilen 2&3 sehen für mich nach einem Fehler aus. Der Adapter läuft aber (erstmal?).
      Muss ich mir Sorgen machen?
      Danke im Voraus
      Max
        Thomas Braun Most Active @M-A-X last edited by
        @M-A-X
        Nein, alles i. O.
          M-A-X @Thomas Braun last edited by
          @Thomas-Braun Top, danke 🙂 diese Warnings haben mich verunsichert zusammen mit den endlos langen Zeilen 🙂
            @M-A-X
            Warning = Hinweis
            Error = Fehler
            Warnings sind erstmal nicht wild.
            ble adapter bluetooth low energy
