    4. Adapter "iobroker.nut" - UPS Daten im iobroker
      @rascal:
      blöde Frage: Wie? `
      Pfad für Installation aus eigenem Repo über den admin wäre IMHO:
      https://github.com/Apollon77/ioBroker.nut
      Rainer
        rascal last edited by
        hey,
        ich dachte, man muss das Intervall nun in den Adaptereinstellungen angeben, aber er fragt nach wie vor nach dem schedule:
        system-adapter-nut-0	2016-10-03 15:02:35.012	error	schedule attribute missing
        host-Mastermind	2016-10-03 15:02:32.510	warn	stopInstance system.adapter.nut.0 not scheduled
        host-Mastermind	2016-10-03 15:02:32.509	info	stopInstance system.adapter.nut.0
        der Adapter funktioniert nur, wenn man im Schedule die Werte eingibt, mit dem Wert im Adapter setup fängter er nichts an.
        Ebenfalls schreibt er nun einiges mehr in das Log:
        nut.0	2016-10-03 15:06:51.561	debug	host. redis publish io.nut.0.status.bypass {"val":false,"ack":true,"ts":1475500011533,"q":0,"from":"system.adapter.nut.0","lc":1472998201460}
        nut.0	2016-10-03 15:06:51.561	debug	host. redis publish io.nut.0.status.discharging {"val":false,"ack":true,"ts":1475500011533,"q":0,"from":"system.adapter.nut.0","lc":1475167426054}
        nut.0	2016-10-03 15:06:51.560	debug	host. redis publish io.nut.0.status.charging {"val":false,"ack":true,"ts":1475500011533,"q":0,"from":"system.adapter.nut.0","lc":1475169226032}
        nut.0	2016-10-03 15:06:51.560	debug	host. redis publish io.nut.0.status.replacebattery {"val":false,"ack":true,"ts":1475500011532,"q":0,"from":"system.adapter.nut.0","lc":1472998201459}
        nut.0	2016-10-03 15:06:51.560	debug	host. redis publish io.nut.0.status.highbattery {"val":false,"ack":true,"ts":1475500011532,"q":0,"from":"system.adapter.nut.0","lc":1472998201459}
        nut.0	2016-10-03 15:06:51.560	debug	host. redis publish io.nut.0.status.lowbattery {"val":false,"ack":true,"ts":1475500011532,"q":0,"from":"system.adapter.nut.0","lc":1474118700977}
        nut.0	2016-10-03 15:06:51.560	debug	host. redis publish io.nut.0.status.onbattery {"val":false,"ack":true,"ts":1475500011531,"q":0,"from":"system.adapter.nut.0","lc":1475167426048}
        nut.0	2016-10-03 15:06:51.560	debug	host. redis publish io.nut.0.status.online {"val":true,"ack":true,"ts":1475500011531,"q":0,"from":"system.adapter.nut.0","lc":1475167426048}
        nut.0	2016-10-03 15:06:51.560	debug	host. redis publish io.nut.0.ups.vendorid {"val":"051d","ack":true,"ts":1475500011530,"q":0,"from":"system.adapter.nut.0","lc":1472998201458}
        nut.0	2016-10-03 15:06:51.560	debug	host. redis publish io.nut.0.ups.timer-shutdown {"val":"-1","ack":true,"ts":1475500011530,"q":0,"from":"system.adapter.nut.0","lc":1472998201458}
        nut.0	2016-10-03 15:06:51.560	debug	host. redis publish io.nut.0.ups.timer-reboot {"val":"0","ack":true,"ts":1475500011530,"q":0,"from":"system.adapter.nut.0","lc":1472998201457}
        nut.0	2016-10-03 15:06:51.560	debug	host. redis publish io.nut.0.ups.status {"val":"OL","ack":true,"ts":1475500011529,"q":0,"from":"system.adapter.nut.0","lc":1475169226029}
        nut.0	2016-10-03 15:06:51.560	debug	host. redis publish io.nut.0.ups.serial {"val":"5B1349T03604 ","ack":true,"ts":1475500011529,"q":0,"from":"system.adapter.nut.0","lc":1472998201456}
        nut.0	2016-10-03 15:06:51.560	debug	host. redis publish io.nut.0.ups.productid {"val":"0002","ack":true,"ts":1475500011529,"q":0,"from":"system.adapter.nut.0","lc":1472998201455}
        nut.0	2016-10-03 15:06:51.560	debug	host. redis publish io.nut.0.ups.model {"val":"Back-UPS ES 700G","ack":true,"ts":1475500011528,"q":0,"from":"system.adapter.nut.0","lc":1472998201455}
        nut.0	2016-10-03 15:06:51.560	debug	host. redis publish io.nut.0.ups.mfr-date {"val":"2013/12/04","ack":true,"ts":1475500011528,"q":0,"from":"system.adapter.nut.0","lc":1472998201455}
        nut.0	2016-10-03 15:06:51.560	debug	host. redis publish io.nut.0.ups.mfr {"val":"APC","ack":true,"ts":1475500011527,"q":0,"from":"system.adapter.nut.0","lc":1472998201454}
        nut.0	2016-10-03 15:06:51.559	debug	host. redis publish io.nut.0.ups.load {"val":"28","ack":true,"ts":1475500011527,"q":0,"from":"system.adapter.nut.0","lc":1475167411043}
        nut.0	2016-10-03 15:06:51.559	debug	host. redis publish io.nut.0.ups.firmware-aux {"val":"O3 ","ack":true,"ts":1475500011527,"q":0,"from":"system.adapter.nut.0","lc":1472998201454}
        nut.0	2016-10-03 15:06:51.559	debug	host. redis publish io.nut.0.ups.firmware {"val":"871.O3 .I","ack":true,"ts":1475500011526,"q":0,"from":"system.adapter.nut.0","lc":1472998201453}
        nut.0	2016-10-03 15:06:51.559	debug	host. redis publish io.nut.0.ups.delay-shutdown {"val":"20","ack":true,"ts":1475500011526,"q":0,"from":"system.adapter.nut.0","lc":1472998201452}
        nut.0	2016-10-03 15:06:51.559	debug	host. redis publish io.nut.0.ups.beeper-status {"val":"enabled","ack":true,"ts":1475500011525,"q":0,"from":"system.adapter.nut.0","lc":1472998201452}
        nut.0	2016-10-03 15:06:51.559	debug	host. redis publish io.nut.0.input.voltage-nominal {"val":"230","ack":true,"ts":1475500011525,"q":0,"from":"system.adapter.nut.0","lc":1472998201448}
        nut.0	2016-10-03 15:06:51.559	debug	host. redis publish io.nut.0.input.voltage {"val":"232.0","ack":true,"ts":1475500011525,"q":0,"from":"system.adapter.nut.0","lc":1475499511669}
        nut.0	2016-10-03 15:06:51.559	debug	host. redis publish io.nut.0.input.transfer-low {"val":"180","ack":true,"ts":1475500011524,"q":0,"from":"system.adapter.nut.0","lc":1472998201447}
        nut.0	2016-10-03 15:06:51.559	debug	host. redis publish io.nut.0.input.transfer-high {"val":"266","ack":true,"ts":1475500011524,"q":0,"from":"system.adapter.nut.0","lc":1472998201447}
        nut.0	2016-10-03 15:06:51.559	debug	host. redis publish io.nut.0.input.sensitivity {"val":"medium","ack":true,"ts":1475500011523,"q":0,"from":"system.adapter.nut.0","lc":1472998201447}
        nut.0	2016-10-03 15:06:51.559	debug	host. redis publish io.nut.0.driver.version-internal {"val":"0.38","ack":true,"ts":1475500011523,"q":0,"from":"system.adapter.nut.0","lc":1472998201447}
        nut.0	2016-10-03 15:06:51.559	debug	host. redis publish io.nut.0.driver.version-data {"val":"APC HID 0.95","ack":true,"ts":1475500011523,"q":0,"from":"system.adapter.nut.0","lc":1472998201446}
        nut.0	2016-10-03 15:06:51.559	debug	host. redis publish io.nut.0.driver.version {"val":"2.7.2","ack":true,"ts":1475500011522,"q":0,"from":"system.adapter.nut.0","lc":1472998201446}
        nut.0	2016-10-03 15:06:51.559	debug	host. redis publish io.nut.0.driver.parameter-port {"val":"auto","ack":true,"ts":1475500011522,"q":0,"from":"system.adapter.nut.0","lc":1472998201445}
        nut.0	2016-10-03 15:06:51.558	debug	host. redis publish io.nut.0.driver.parameter-pollinterval {"val":"2","ack":true,"ts":1475500011522,"q":0,"from":"system.adapter.nut.0","lc":1472998201445}
        nut.0	2016-10-03 15:06:51.558	debug	host. redis publish io.nut.0.driver.parameter-pollfreq {"val":"30","ack":true,"ts":1475500011521,"q":0,"from":"system.adapter.nut.0","lc":1472998201445}
        nut.0	2016-10-03 15:06:51.558	debug	host. redis publish io.nut.0.driver.name {"val":"usbhid-ups","ack":true,"ts":1475500011521,"q":0,"from":"system.adapter.nut.0","lc":1472998201444}
        nut.0	2016-10-03 15:06:51.558	debug	host. redis publish io.nut.0.device.type {"val":"ups","ack":true,"ts":1475500011520,"q":0,"from":"system.adapter.nut.0","lc":1472998201444}
        nut.0	2016-10-03 15:06:51.558	debug	host. redis publish io.nut.0.device.serial {"val":"5B1349T03604 ","ack":true,"ts":1475500011520,"q":0,"from":"system.adapter.nut.0","lc":1472998201443}
        nut.0	2016-10-03 15:06:51.558	debug	host. redis publish io.nut.0.device.model {"val":"Back-UPS ES 700G","ack":true,"ts":1475500011520,"q":0,"from":"system.adapter.nut.0","lc":1472998201443}
        nut.0	2016-10-03 15:06:51.558	debug	host. redis publish io.nut.0.device.mfr {"val":"APC","ack":true,"ts":1475500011519,"q":0,"from":"system.adapter.nut.0","lc":1472998201442}
        nut.0	2016-10-03 15:06:51.558	debug	host. redis publish io.nut.0.battery.voltage-nominal {"val":"12.0","ack":true,"ts":1475500011519,"q":0,"from":"system.adapter.nut.0","lc":1472998201442}
        nut.0	2016-10-03 15:06:51.558	debug	host. redis publish io.nut.0.battery.voltage {"val":"13.7","ack":true,"ts":1475500011518,"q":0,"from":"system.adapter.nut.0","lc":1475499511664}
        nut.0	2016-10-03 15:06:51.558	debug	host. redis publish io.nut.0.battery.type {"val":"PbAc","ack":true,"ts":1475500011518,"q":0,"from":"system.adapter.nut.0","lc":1472998201441}
        nut.0	2016-10-03 15:06:51.558	debug	host. redis publish io.nut.0.battery.runtime-low {"val":"120","ack":true,"ts":1475500011518,"q":0,"from":"system.adapter.nut.0","lc":1472998201441}
        nut.0	2016-10-03 15:06:51.558	debug	host. redis publish io.nut.0.battery.runtime {"val":"1672","ack":true,"ts":1475500011517,"q":0,"from":"system.adapter.nut.0","lc":1475169241007}
        nut.0	2016-10-03 15:06:51.558	debug	host. redis publish io.nut.0.battery.mfr-date {"val":"2013/12/04","ack":true,"ts":1475500011517,"q":0,"from":"system.adapter.nut.0","lc":1472998201440}
        nut.0	2016-10-03 15:06:51.558	debug	host. redis publish io.nut.0.battery.date {"val":"not set","ack":true,"ts":1475500011516,"q":0,"from":"system.adapter.nut.0","lc":1472998201440}
        nut.0	2016-10-03 15:06:51.558	debug	host. redis publish io.nut.0.battery.charge-warning {"val":"50","ack":true,"ts":1475500011516,"q":0,"from":"system.adapter.nut.0","lc":1472998201440}
        nut.0	2016-10-03 15:06:51.557	debug	host. redis publish io.nut.0.battery.charge-low {"val":"10","ack":true,"ts":1475500011516,"q":0,"from":"system.adapter.nut.0","lc":1472998201440}
        nut.0	2016-10-03 15:06:51.557	debug	host. redis publish io.nut.0.battery.charge {"val":"100","ack":true,"ts":1475500011515,"q":0,"from":"system.adapter.nut.0","lc":1475169241004}
        nut.0	2016-10-03 15:06:51.557	info	nut.0 All Nut values set
        nut.0	2016-10-03 15:06:51.557	debug	nut.0 Set State status.severity = 0
        nut.0	2016-10-03 15:06:51.557	debug	nut.0 Set State status.shutdown = false
        nut.0	2016-10-03 15:06:51.557	debug	nut.0 Create State status.shutdown
        nut.0	2016-10-03 15:06:51.557	debug	nut.0 Set State status.boosting = false
        nut.0	2016-10-03 15:06:51.557	debug	nut.0 Create State status.boosting
        nut.0	2016-10-03 15:06:51.557	debug	nut.0 Set State status.trimming = false
        nut.0	2016-10-03 15:06:51.557	debug	nut.0 Create State status.trimming
        nut.0	2016-10-03 15:06:51.557	debug	nut.0 Set State status.overload = false
        nut.0	2016-10-03 15:06:51.557	debug	nut.0 Create State status.overload
        nut.0	2016-10-03 15:06:51.557	debug	nut.0 Set State status.offline = false
        nut.0	2016-10-03 15:06:51.557	debug	nut.0 Create State status.offline
        nut.0	2016-10-03 15:06:51.556	debug	nut.0 Set State status.calibration = false
        nut.0	2016-10-03 15:06:51.556	debug	nut.0 Create State status.calibration
        nut.0	2016-10-03 15:06:51.556	debug	nut.0 Set State status.bypass = false
        nut.0	2016-10-03 15:06:51.556	debug	nut.0 Create State status.bypass
        nut.0	2016-10-03 15:06:51.556	debug	nut.0 Set State status.discharging = false
        nut.0	2016-10-03 15:06:51.556	debug	nut.0 Create State status.discharging
        nut.0	2016-10-03 15:06:51.556	debug	nut.0 Set State status.charging = false
        nut.0	2016-10-03 15:06:51.556	debug	nut.0 Create State status.charging
        nut.0	2016-10-03 15:06:51.556	debug	nut.0 Set State status.replacebattery = false
        nut.0	2016-10-03 15:06:51.556	debug	nut.0 Create State status.replacebattery
        nut.0	2016-10-03 15:06:51.556	debug	nut.0 Set State status.highbattery = false
        nut.0	2016-10-03 15:06:51.556	debug	nut.0 Create State status.highbattery
        nut.0	2016-10-03 15:06:51.556	debug	nut.0 Set State status.lowbattery = false
        nut.0	2016-10-03 15:06:51.556	debug	nut.0 Create State status.lowbattery
        nut.0	2016-10-03 15:06:51.555	debug	nut.0 Set State status.onbattery = false
        nut.0	2016-10-03 15:06:51.555	debug	nut.0 Create State status.onbattery
        nut.0	2016-10-03 15:06:51.555	debug	nut.0 Severity Flag idle=true
        nut.0	2016-10-03 15:06:51.555	debug	nut.0 Set State status.online = true
        nut.0	2016-10-03 15:06:51.555	debug	nut.0 Create State status.online
        nut.0	2016-10-03 15:06:51.555	debug	nut.0 Create Channel status
        nut.0	2016-10-03 15:06:51.555	debug	nut.0 Set State ups.vendorid = 051d
        nut.0	2016-10-03 15:06:51.555	debug	nut.0 Create State ups.vendorid
        nut.0	2016-10-03 15:06:51.555	debug	nut.0 Set State ups.timer-shutdown = -1
        nut.0	2016-10-03 15:06:51.555	debug	nut.0 Create State ups.timer-shutdown
        nut.0	2016-10-03 15:06:51.555	debug	nut.0 Set State ups.timer-reboot = 0
        nut.0	2016-10-03 15:06:51.555	debug	nut.0 Create State ups.timer-reboot
        nut.0	2016-10-03 15:06:51.555	debug	nut.0 Set State ups.status = OL
        nut.0	2016-10-03 15:06:51.555	debug	nut.0 Create State ups.status
        nut.0	2016-10-03 15:06:51.554	debug	nut.0 Set State ups.serial = 5B1349T03604
        nut.0	2016-10-03 15:06:51.554	debug	nut.0 Create State ups.serial
        nut.0	2016-10-03 15:06:51.554	debug	nut.0 Set State ups.productid = 0002
        nut.0	2016-10-03 15:06:51.554	debug	nut.0 Create State ups.productid
        nut.0	2016-10-03 15:06:51.554	debug	nut.0 Set State ups.model = Back-UPS ES 700G
        nut.0	2016-10-03 15:06:51.554	debug	nut.0 Create State ups.model
        nut.0	2016-10-03 15:06:51.554	debug	nut.0 Set State ups.mfr-date = 2013/12/04
        nut.0	2016-10-03 15:06:51.554	debug	nut.0 Create State ups.mfr-date
        nut.0	2016-10-03 15:06:51.554	debug	nut.0 Set State ups.mfr = APC
        nut.0	2016-10-03 15:06:51.554	debug	nut.0 Set State ups.load = 28
        nut.0	2016-10-03 15:06:51.554	debug	nut.0 Create State ups.load
        nut.0	2016-10-03 15:06:51.554	debug	nut.0 Set State ups.firmware-aux = O3
        nut.0	2016-10-03 15:06:51.554	debug	nut.0 Create State ups.firmware-aux
        nut.0	2016-10-03 15:06:51.553	debug	nut.0 Set State ups.firmware = 871.O3 .I
        nut.0	2016-10-03 15:06:51.553	debug	nut.0 Create State ups.firmware
        nut.0	2016-10-03 15:06:51.553	debug	nut.0 Set State ups.delay-shutdown = 20
        nut.0	2016-10-03 15:06:51.553	debug	nut.0 Create State ups.delay-shutdown
        nut.0	2016-10-03 15:06:51.553	debug	nut.0 Set State ups.beeper-status = enabled
        nut.0	2016-10-03 15:06:51.553	debug	nut.0 Create State ups.beeper-status
        nut.0	2016-10-03 15:06:51.553	debug	nut.0 Create Channel ups
        nut.0	2016-10-03 15:06:51.553	debug	nut.0 Set State input.voltage-nominal = 230
        nut.0	2016-10-03 15:06:51.553	debug	nut.0 Create State input.voltage-nominal
        nut.0	2016-10-03 15:06:51.553	debug	nut.0 Set State input.voltage = 232.0
        nut.0	2016-10-03 15:06:51.553	debug	nut.0 Set State input.transfer-low = 180
        nut.0	2016-10-03 15:06:51.553	debug	nut.0 Create State input.transfer-low
        nut.0	2016-10-03 15:06:51.553	debug	nut.0 Set State input.transfer-high = 266
        nut.0	2016-10-03 15:06:51.552	debug	nut.0 Create State input.transfer-high
        nut.0	2016-10-03 15:06:51.552	debug	nut.0 Set State input.sensitivity = medium
        nut.0	2016-10-03 15:06:51.552	debug	nut.0 Create State input.sensitivity
        nut.0	2016-10-03 15:06:51.552	debug	nut.0 Create Channel input
        nut.0	2016-10-03 15:06:51.552	debug	nut.0 Set State driver.version-internal = 0.38
        nut.0	2016-10-03 15:06:51.552	debug	nut.0 Create State driver.version-internal
        nut.0	2016-10-03 15:06:51.552	debug	nut.0 Set State driver.version-data = APC HID 0.95
        nut.0	2016-10-03 15:06:51.552	debug	nut.0 Create State driver.version-data
        nut.0	2016-10-03 15:06:51.552	debug	nut.0 Set State driver.version = 2.7.2
        nut.0	2016-10-03 15:06:51.552	debug	nut.0 Set State driver.parameter-port = auto
        nut.0	2016-10-03 15:06:51.552	debug	nut.0 Create State driver.parameter-port
        nut.0	2016-10-03 15:06:51.551	debug	nut.0 Set State driver.parameter-pollinterval = 2
        nut.0	2016-10-03 15:06:51.551	debug	nut.0 Create State driver.parameter-pollinterval
        nut.0	2016-10-03 15:06:51.551	debug	nut.0 Set State driver.parameter-pollfreq = 30
        nut.0	2016-10-03 15:06:51.551	debug	nut.0 Create State driver.parameter-pollfreq
        nut.0	2016-10-03 15:06:51.551	debug	nut.0 Set State driver.name = usbhid-ups
        nut.0	2016-10-03 15:06:51.551	debug	nut.0 Create State driver.name
        nut.0	2016-10-03 15:06:51.551	debug	nut.0 Create Channel driver
        nut.0	2016-10-03 15:06:51.551	debug	nut.0 Set State device.type = ups
        nut.0	2016-10-03 15:06:51.551	debug	nut.0 Create State device.type
        nut.0	2016-10-03 15:06:51.551	debug	nut.0 Set State device.serial = 5B1349T03604
        nut.0	2016-10-03 15:06:51.551	debug	nut.0 Create State device.serial
        nut.0	2016-10-03 15:06:51.551	debug	nut.0 Set State device.model = Back-UPS ES 700G
        nut.0	2016-10-03 15:06:51.550	debug	nut.0 Create State device.model
        nut.0	2016-10-03 15:06:51.550	debug	nut.0 Set State device.mfr = APC
        nut.0	2016-10-03 15:06:51.550	debug	nut.0 Create State device.mfr
        nut.0	2016-10-03 15:06:51.550	debug	nut.0 Create Channel device
        nut.0	2016-10-03 15:06:51.550	debug	nut.0 Set State battery.voltage-nominal = 12.0
        nut.0	2016-10-03 15:06:51.550	debug	nut.0 Create State battery.voltage-nominal
        nut.0	2016-10-03 15:06:51.550	debug	nut.0 Set State battery.voltage = 13.7
        nut.0	2016-10-03 15:06:51.550	debug	nut.0 Set State battery.type = PbAc
        nut.0	2016-10-03 15:06:51.550	debug	nut.0 Create State battery.type
        nut.0	2016-10-03 15:06:51.550	debug	nut.0 Set State battery.runtime-low = 120
        nut.0	2016-10-03 15:06:51.549	debug	nut.0 Create State battery.runtime-low
        nut.0	2016-10-03 15:06:51.549	debug	nut.0 Set State battery.runtime = 1672
        nut.0	2016-10-03 15:06:51.549	debug	nut.0 Set State battery.mfr-date = 2013/12/04
        nut.0	2016-10-03 15:06:51.549	debug	nut.0 Create State battery.mfr-date
        nut.0	2016-10-03 15:06:51.549	debug	nut.0 Set State battery.date = not set
        nut.0	2016-10-03 15:06:51.549	debug	nut.0 Create State battery.date
        nut.0	2016-10-03 15:06:51.549	debug	nut.0 Set State battery.charge-warning = 50
        nut.0	2016-10-03 15:06:51.549	debug	nut.0 Create State battery.charge-warning
        nut.0	2016-10-03 15:06:51.547	debug	nut.0 Set State battery.charge-low = 10
        nut.0	2016-10-03 15:06:51.547	debug	nut.0 Create State battery.charge-low
        nut.0	2016-10-03 15:06:51.547	debug	nut.0 Set State battery.charge = 100
        nut.0	2016-10-03 15:06:51.547	debug	nut.0 Create Channel battery
        nut.0	2016-10-03 15:06:51.547	debug	nut.0 Got values, start setting them
        nut.0	2016-10-03 15:06:51.542	debug	nut.0 NUT Connection ready
        nut.0	2016-10-03 15:06:51.541	info	nut.0 Start NUT update
        nut.0	2016-10-03 15:06:51.385	debug	host. redis publish io.system.adapter.nut.0.uptime {"val":196,"ack":true,"ts":1475500011384,"q":0,"from":"system.adapter.nut.0","lc":1475500011384}
        nut.0	2016-10-03 15:06:51.385	debug	host. redis publish io.system.adapter.nut.0.memHeapUsed {"val":17.8,"ack":true,"ts":1475500011384,"q":0,"from":"system.adapter.nut.0","lc":1475500011384}
        nut.0	2016-10-03 15:06:51.385	debug	host. redis publish io.system.adapter.nut.0.memHeapTotal {"val":20.82,"ack":true,"ts":1475500011384,"q":0,"from":"system.adapter.nut.0","lc":1475500011384}
        nut.0	2016-10-03 15:06:51.385	debug	host. redis publish io.system.adapter.nut.0.memRss {"val":41.21,"ack":true,"ts":1475500011383,"q":0,"from":"system.adapter.nut.0","lc":1475500011383}
        nut.0	2016-10-03 15:06:51.385	debug	host. redis publish io.system.adapter.nut.0.connected {"val":true,"ack":true,"ts":1475500011383,"q":0,"from":"system.adapter.nut.0","lc":1475499816328}
        nut.0	2016-10-03 15:06:51.385	debug	host. redis publish io.system.adapter.nut.0.alive {"val":true,"ack":true,"ts":1475500011383,"q":0,"from":"system.adapter.nut.0","lc":1475499816327}
        Mastermind	2016-10-03 15:06:50.533	warn	host.Mastermind instance system.adapter.nut.0 already running with pid 14081
        nut.0	2016-10-03 15:06:46.578	debug	nut.0 NUT Connection closed. Done.
        nut.0	2016-10-03 15:06:46.577	debug	host. redis publish io.nut.0.status.severity {"val":0,"ack":true,"ts":1475500006547,"q":0,"from":"system.adapter.nut.0","lc":1475498551530}
        nut.0	2016-10-03 15:06:46.577	debug	host. redis publish io.nut.0.status.shutdown {"val":false,"ack":true,"ts":1475500006547,"q":0,"from":"system.adapter.nut.0","lc":1472998201462}
        nut.0	2016-10-03 15:06:46.577	debug	host. redis publish io.nut.0.status.boosting {"val":false,"ack":true,"ts":1475500006546,"q":0,"from":"system.adapter.nut.0","lc":1472998201461}
        nut.0	2016-10-03 15:06:46.577	debug	host. redis publish io.nut.0.status.trimming {"val":false,"ack":true,"ts":1475500006546,"q":0,"from":"system.adapter.nut.0","lc":1472998201461}
        nut.0	2016-10-03 15:06:46.577	debug	host. redis publish io.nut.0.status.overload {"val":false,"ack":true,"ts":1475500006546,"q":0,"from":"system.adapter.nut.0","lc":1472998201461}
        nut.0	2016-10-03 15:06:46.577	debug	host. redis publish io.nut.0.status.offline {"val":false,"ack":true,"ts":1475500006545,"q":0,"from":"system.adapter.nut.0","lc":1472998201461}
        nut.0	2016-10-03 15:06:46.577	debug	host. redis publish io.nut.0.status.calibration {"val":false,"ack":true,"ts":1475500006545,"q":0,"from":"system.adapter.nut.0","lc":1472998201460}
        nut.0	2016-10-03 15:06:46.577	debug	host. redis publish io.nut.0.status.bypass {"val":false,"ack":true,"ts":1475500006545,"q":0,"from":"system.adapter.nut.0","lc":1472998201460}
        nut.0	2016-10-03 15:06:46.577	debug	host. redis publish io.nut.0.status.discharging {"val":false,"ack":true,"ts":1475500006544,"q":0,"from":"system.adapter.nut.0","lc":1475167426054}
        nut.0	2016-10-03 15:06:46.577	debug	host. redis publish io.nut.0.status.charging {"val":false,"ack":true,"ts":1475500006544,"q":0,"from":"system.adapter.nut.0","lc":1475169226032}
        nut.0	2016-10-03 15:06:46.577	debug	host. redis publish io.nut.0.status.replacebattery {"val":false,"ack":true,"ts":1475500006543,"q":0,"from":"system.adapter.nut.0","lc":1472998201459}
        nut.0	2016-10-03 15:06:46.577	debug	host. redis publish io.nut.0.status.highbattery {"val":false,"ack":true,"ts":1475500006543,"q":0,"from":"system.adapter.nut.0","lc":1472998201459}
        nut.0	2016-10-03 15:06:46.577	debug	host. redis publish io.nut.0.status.lowbattery {"val":false,"ack":true,"ts":1475500006542,"q":0,"from":"system.adapter.nut.0","lc":1474118700977}
        nut.0	2016-10-03 15:06:46.577	debug	host. redis publish io.nut.0.status.onbattery {"val":false,"ack":true,"ts":1475500006542,"q":0,"from":"system.adapter.nut.0","lc":1475167426048}
        nut.0	2016-10-03 15:06:46.577	debug	host. redis publish io.nut.0.status.online {"val":true,"ack":true,"ts":1475500006541,"q":0,"from":"system.adapter.nut.0","lc":1475167426048}
        nut.0	2016-10-03 15:06:46.576	debug	host. redis publish io.nut.0.ups.vendorid {"val":"051d","ack":true,"ts":1475500006540,"q":0,"from":"system.adapter.nut.0","lc":1472998201458}
        nut.0	2016-10-03 15:06:46.576	debug	host. redis publish io.nut.0.ups.timer-shutdown {"val":"-1","ack":true,"ts":1475500006538,"q":0,"from":"system.adapter.nut.0","lc":1472998201458}
        nut.0	2016-10-03 15:06:46.576	debug	host. redis publish io.nut.0.ups.timer-reboot {"val":"0","ack":true,"ts":1475500006537,"q":0,"from":"system.adapter.nut.0","lc":1472998201457}
        nut.0	2016-10-03 15:06:46.576	debug	host. redis publish io.nut.0.ups.status {"val":"OL","ack":true,"ts":1475500006536,"q":0,"from":"system.adapter.nut.0","lc":1475169226029}
        nut.0	2016-10-03 15:06:46.576	debug	host. redis publish io.nut.0.ups.serial {"val":"5B1349T03604 ","ack":true,"ts":1475500006535,"q":0,"from":"system.adapter.nut.0","lc":1472998201456}
        nut.0	2016-10-03 15:06:46.576	debug	host. redis publish io.nut.0.ups.productid {"val":"0002","ack":true,"ts":1475500006535,"q":0,"from":"system.adapter.nut.0","lc":1472998201455}
        nut.0	2016-10-03 15:06:46.576	debug	host. redis publish io.nut.0.ups.model {"val":"Back-UPS ES 700G","ack":true,"ts":1475500006534,"q":0,"from":"system.adapter.nut.0","lc":1472998201455}
        nut.0	2016-10-03 15:06:46.576	debug	host. redis publish io.nut.0.ups.mfr-date {"val":"2013/12/04","ack":true,"ts":1475500006533,"q":0,"from":"system.adapter.nut.0","lc":1472998201455}
        nut.0	2016-10-03 15:06:46.576	debug	host. redis publish io.nut.0.ups.mfr {"val":"APC","ack":true,"ts":1475500006532,"q":0,"from":"system.adapter.nut.0","lc":1472998201454}
        nut.0	2016-10-03 15:06:46.576	debug	host. redis publish io.nut.0.ups.load {"val":"28","ack":true,"ts":1475500006531,"q":0,"from":"system.adapter.nut.0","lc":1475167411043}
        nut.0	2016-10-03 15:06:46.576	debug	host. redis publish io.nut.0.ups.firmware-aux {"val":"O3 ","ack":true,"ts":1475500006531,"q":0,"from":"system.adapter.nut.0","lc":1472998201454}
        nut.0	2016-10-03 15:06:46.576	debug	host. redis publish io.nut.0.ups.firmware {"val":"871.O3 .I","ack":true,"ts":1475500006530,"q":0,"from":"system.adapter.nut.0","lc":1472998201453}
        nut.0	2016-10-03 15:06:46.576	debug	host. redis publish io.nut.0.ups.delay-shutdown {"val":"20","ack":true,"ts":1475500006529,"q":0,"from":"system.adapter.nut.0","lc":1472998201452}
        nut.0	2016-10-03 15:06:46.576	debug	host. redis publish io.nut.0.ups.beeper-status {"val":"enabled","ack":true,"ts":1475500006528,"q":0,"from":"system.adapter.nut.0","lc":1472998201452}
        nut.0	2016-10-03 15:06:46.575	debug	host. redis publish io.nut.0.input.voltage-nominal {"val":"230","ack":true,"ts":1475500006528,"q":0,"from":"system.adapter.nut.0","lc":1472998201448}
        nut.0	2016-10-03 15:06:46.575	debug	host. redis publish io.nut.0.input.voltage {"val":"232.0","ack":true,"ts":1475500006527,"q":0,"from":"system.adapter.nut.0","lc":1475499511669}
        nut.0	2016-10-03 15:06:46.575	debug	host. redis publish io.nut.0.input.transfer-low {"val":"180","ack":true,"ts":1475500006526,"q":0,"from":"system.adapter.nut.0","lc":1472998201447}
        nut.0	2016-10-03 15:06:46.575	debug	host. redis publish io.nut.0.input.transfer-high {"val":"266","ack":true,"ts":1475500006525,"q":0,"from":"system.adapter.nut.0","lc":1472998201447}
        nut.0	2016-10-03 15:06:46.575	debug	host. redis publish io.nut.0.input.sensitivity {"val":"medium","ack":true,"ts":1475500006525,"q":0,"from":"system.adapter.nut.0","lc":1472998201447}
        nut.0	2016-10-03 15:06:46.575	debug	host. redis publish io.nut.0.driver.version-internal {"val":"0.38","ack":true,"ts":1475500006523,"q":0,"from":"system.adapter.nut.0","lc":1472998201447}
        nut.0	2016-10-03 15:06:46.575	debug	host. redis publish io.nut.0.driver.version-data {"val":"APC HID 0.95","ack":true,"ts":1475500006523,"q":0,"from":"system.adapter.nut.0","lc":1472998201446}
        nut.0	2016-10-03 15:06:46.575	debug	host. redis publish io.nut.0.driver.version {"val":"2.7.2","ack":true,"ts":1475500006523,"q":0,"from":"system.adapter.nut.0","lc":1472998201446}
        nut.0	2016-10-03 15:06:46.575	debug	host. redis publish io.nut.0.driver.parameter-port {"val":"auto","ack":true,"ts":1475500006522,"q":0,"from":"system.adapter.nut.0","lc":1472998201445}
        nut.0	2016-10-03 15:06:46.575	debug	host. redis publish io.nut.0.driver.parameter-pollinterval {"val":"2","ack":true,"ts":1475500006522,"q":0,"from":"system.adapter.nut.0","lc":1472998201445}
        nut.0	2016-10-03 15:06:46.575	debug	host. redis publish io.nut.0.driver.parameter-pollfreq {"val":"30","ack":true,"ts":1475500006522,"q":0,"from":"system.adapter.nut.0","lc":1472998201445}
        nut.0	2016-10-03 15:06:46.575	debug	host. redis publish io.nut.0.driver.name {"val":"usbhid-ups","ack":true,"ts":1475500006521,"q":0,"from":"system.adapter.nut.0","lc":1472998201444}
        nut.0	2016-10-03 15:06:46.575	debug	host. redis publish io.nut.0.device.type {"val":"ups","ack":true,"ts":1475500006521,"q":0,"from":"system.adapter.nut.0","lc":1472998201444}
        nut.0	2016-10-03 15:06:46.575	debug	host. redis publish io.nut.0.device.serial {"val":"5B1349T03604 ","ack":true,"ts":1475500006520,"q":0,"from":"system.adapter.nut.0","lc":1472998201443}
        nut.0	2016-10-03 15:06:46.574	debug	host. redis publish io.nut.0.device.model {"val":"Back-UPS ES 700G","ack":true,"ts":1475500006520,"q":0,"from":"system.adapter.nut.0","lc":1472998201443}
        nut.0	2016-10-03 15:06:46.574	debug	host. redis publish io.nut.0.device.mfr {"val":"APC","ack":true,"ts":1475500006520,"q":0,"from":"system.adapter.nut.0","lc":1472998201442}
        nut.0	2016-10-03 15:06:46.574	debug	host. redis publish io.nut.0.battery.voltage-nominal {"val":"12.0","ack":true,"ts":1475500006519,"q":0,"from":"system.adapter.nut.0","lc":1472998201442}
        nut.0	2016-10-03 15:06:46.574	debug	host. redis publish io.nut.0.battery.voltage {"val":"13.7","ack":true,"ts":1475500006518,"q":0,"from":"system.adapter.nut.0","lc":1475499511664}
        nut.0	2016-10-03 15:06:46.574	debug	host. redis publish io.nut.0.battery.type {"val":"PbAc","ack":true,"ts":1475500006517,"q":0,"from":"system.adapter.nut.0","lc":1472998201441}
        nut.0	2016-10-03 15:06:46.574	debug	host. redis publish io.nut.0.battery.runtime-low {"val":"120","ack":true,"ts":1475500006517,"q":0,"from":"system.adapter.nut.0","lc":1472998201441}
        nut.0	2016-10-03 15:06:46.574	debug	host. redis publish io.nut.0.battery.runtime {"val":"1672","ack":true,"ts":1475500006516,"q":0,"from":"system.adapter.nut.0","lc":1475169241007}
        nut.0	2016-10-03 15:06:46.574	debug	host. redis publish io.nut.0.battery.mfr-date {"val":"2013/12/04","ack":true,"ts":1475500006515,"q":0,"from":"system.adapter.nut.0","lc":1472998201440}
        nut.0	2016-10-03 15:06:46.574	debug	host. redis publish io.nut.0.battery.date {"val":"not set","ack":true,"ts":1475500006515,"q":0,"from":"system.adapter.nut.0","lc":1472998201440}
        nut.0	2016-10-03 15:06:46.574	debug	host. redis publish io.nut.0.battery.charge-warning {"val":"50","ack":true,"ts":1475500006514,"q":0,"from":"system.adapter.nut.0","lc":1472998201440}
        nut.0	2016-10-03 15:06:46.574	debug	host. redis publish io.nut.0.battery.charge-low {"val":"10","ack":true,"ts":1475500006514,"q":0,"from":"system.adapter.nut.0","lc":1472998201440}
        nut.0	2016-10-03 15:06:46.574	debug	host. redis publish io.nut.0.battery.charge {"val":"100","ack":true,"ts":1475500006513,"q":0,"from":"system.adapter.nut.0","lc":1475169241004}
        nut.0	2016-10-03 15:06:46.573	info	nut.0 All Nut values set
        nut.0	2016-10-03 15:06:46.573	debug	nut.0 Set State status.severity = 0
        nut.0	2016-10-03 15:06:46.573	debug	nut.0 Set State status.shutdown = false
        nut.0	2016-10-03 15:06:46.573	debug	nut.0 Create State status.shutdown
        nut.0	2016-10-03 15:06:46.573	debug	nut.0 Set State status.boosting = false
        nut.0	2016-10-03 15:06:46.573	debug	nut.0 Create State status.boosting
        nut.0	2016-10-03 15:06:46.573	debug	nut.0 Set State status.trimming = false
        nut.0	2016-10-03 15:06:46.573	debug	nut.0 Create State status.trimming
        nut.0	2016-10-03 15:06:46.573	debug	nut.0 Set State status.overload = false
        nut.0	2016-10-03 15:06:46.573	debug	nut.0 Create State status.overload
        nut.0	2016-10-03 15:06:46.573	debug	nut.0 Set State status.offline = false
        nut.0	2016-10-03 15:06:46.573	debug	nut.0 Create State status.offline
        nut.0	2016-10-03 15:06:46.573	debug	nut.0 Set State status.calibration = false
        nut.0	2016-10-03 15:06:46.572	debug	nut.0 Create State status.calibration
        nut.0	2016-10-03 15:06:46.572	debug	nut.0 Set State status.bypass = false
        nut.0	2016-10-03 15:06:46.572	debug	nut.0 Create State status.bypass
        nut.0	2016-10-03 15:06:46.572	debug	nut.0 Set State status.discharging = false
        nut.0	2016-10-03 15:06:46.572	debug	nut.0 Create State status.discharging
        nut.0	2016-10-03 15:06:46.572	debug	nut.0 Set State status.charging = false
        nut.0	2016-10-03 15:06:46.572	debug	nut.0 Create State status.charging
        nut.0	2016-10-03 15:06:46.572	debug	nut.0 Set State status.replacebattery = false
        nut.0	2016-10-03 15:06:46.572	debug	nut.0 Create State status.replacebattery
        nut.0	2016-10-03 15:06:46.572	debug	nut.0 Set State status.highbattery = false
        nut.0	2016-10-03 15:06:46.572	debug	nut.0 Create State status.highbattery
        nut.0	2016-10-03 15:06:46.572	debug	nut.0 Set State status.lowbattery = false
        nut.0	2016-10-03 15:06:46.572	debug	nut.0 Create State status.lowbattery
        nut.0	2016-10-03 15:06:46.571	debug	nut.0 Set State status.onbattery = false
        nut.0	2016-10-03 15:06:46.571	debug	nut.0 Create State status.onbattery
        nut.0	2016-10-03 15:06:46.571	debug	nut.0 Severity Flag idle=true
        nut.0	2016-10-03 15:06:46.571	debug	nut.0 Set State status.online = true
        nut.0	2016-10-03 15:06:46.571	debug	nut.0 Create State status.online
        nut.0	2016-10-03 15:06:46.571	debug	nut.0 Create Channel status
        nut.0	2016-10-03 15:06:46.571	debug	nut.0 Set State ups.vendorid = 051d
        nut.0	2016-10-03 15:06:46.571	debug	nut.0 Create State ups.vendorid
        nut.0	2016-10-03 15:06:46.571	debug	nut.0 Set State ups.timer-shutdown = -1
        nut.0	2016-10-03 15:06:46.571	debug	nut.0 Create State ups.timer-shutdown
        nut.0	2016-10-03 15:06:46.571	debug	nut.0 Set State ups.timer-reboot = 0
        nut.0	2016-10-03 15:06:46.571	debug	nut.0 Create State ups.timer-reboot
        nut.0	2016-10-03 15:06:46.571	debug	nut.0 Set State ups.status = OL
        nut.0	2016-10-03 15:06:46.571	debug	nut.0 Create State ups.status
        nut.0	2016-10-03 15:06:46.570	debug	nut.0 Set State ups.serial = 5B1349T03604
        nut.0	2016-10-03 15:06:46.570	debug	nut.0 Create State ups.serial
        nut.0	2016-10-03 15:06:46.570	debug	nut.0 Set State ups.productid = 0002
        nut.0	2016-10-03 15:06:46.570	debug	nut.0 Create State ups.productid
        nut.0	2016-10-03 15:06:46.570	debug	nut.0 Set State ups.model = Back-UPS ES 700G
        nut.0	2016-10-03 15:06:46.570	debug	nut.0 Create State ups.model
        nut.0	2016-10-03 15:06:46.570	debug	nut.0 Set State ups.mfr-date = 2013/12/04
        nut.0	2016-10-03 15:06:46.570	debug	nut.0 Create State ups.mfr-date
        nut.0	2016-10-03 15:06:46.570	debug	nut.0 Set State ups.mfr = APC
        nut.0	2016-10-03 15:06:46.570	debug	nut.0 Set State ups.load = 28
        nut.0	2016-10-03 15:06:46.570	debug	nut.0 Create State ups.load
        nut.0	2016-10-03 15:06:46.570	debug	nut.0 Set State ups.firmware-aux = O3
        nut.0	2016-10-03 15:06:46.570	debug	nut.0 Create State ups.firmware-aux
        nut.0	2016-10-03 15:06:46.569	debug	nut.0 Set State ups.firmware = 871.O3 .I
        nut.0	2016-10-03 15:06:46.569	debug	nut.0 Create State ups.firmware
        nut.0	2016-10-03 15:06:46.569	debug	nut.0 Set State ups.delay-shutdown = 20
        nut.0	2016-10-03 15:06:46.569	debug	nut.0 Create State ups.delay-shutdown
        nut.0	2016-10-03 15:06:46.569	debug	nut.0 Set State ups.beeper-status = enabled
        nut.0	2016-10-03 15:06:46.569	debug	nut.0 Create State ups.beeper-status
        nut.0	2016-10-03 15:06:46.569	debug	nut.0 Create Channel ups
        nut.0	2016-10-03 15:06:46.569	debug	nut.0 Set State input.voltage-nominal = 230
        nut.0	2016-10-03 15:06:46.569	debug	nut.0 Create State input.voltage-nominal
        nut.0	2016-10-03 15:06:46.569	debug	nut.0 Set State input.voltage = 232.0
        nut.0	2016-10-03 15:06:46.568	debug	nut.0 Set State input.transfer-low = 180
        nut.0	2016-10-03 15:06:46.567	debug	nut.0 Create State input.transfer-low
        nut.0	2016-10-03 15:06:46.567	debug	nut.0 Set State input.transfer-high = 266
        nut.0	2016-10-03 15:06:46.567	debug	nut.0 Create State input.transfer-high
        nut.0	2016-10-03 15:06:46.567	debug	nut.0 Set State input.sensitivity = medium
        nut.0	2016-10-03 15:06:46.567	debug	nut.0 Create State input.sensitivity
        nut.0	2016-10-03 15:06:46.567	debug	nut.0 Create Channel input
        nut.0	2016-10-03 15:06:46.567	debug	nut.0 Set State driver.version-internal = 0.38
        nut.0	2016-10-03 15:06:46.567	debug	nut.0 Create State driver.version-internal
        nut.0	2016-10-03 15:06:46.567	debug	nut.0 Set State driver.version-data = APC HID 0.95
        nut.0	2016-10-03 15:06:46.567	debug	nut.0 Create State driver.version-data
        nut.0	2016-10-03 15:06:46.567	debug	nut.0 Set State driver.version = 2.7.2
        nut.0	2016-10-03 15:06:46.567	debug	nut.0 Set State driver.parameter-port = auto
        nut.0	2016-10-03 15:06:46.566	debug	nut.0 Create State driver.parameter-port
        nut.0	2016-10-03 15:06:46.566	debug	nut.0 Set State driver.parameter-pollinterval = 2
        nut.0	2016-10-03 15:06:46.566	debug	nut.0 Create State driver.parameter-pollinterval
        nut.0	2016-10-03 15:06:46.566	debug	nut.0 Set State driver.parameter-pollfreq = 30
        nut.0	2016-10-03 15:06:46.566	debug	nut.0 Create State driver.parameter-pollfreq
        nut.0	2016-10-03 15:06:46.566	debug	nut.0 Set State driver.name = usbhid-ups
        nut.0	2016-10-03 15:06:46.566	debug	nut.0 Create State driver.name
        nut.0	2016-10-03 15:06:46.566	debug	nut.0 Create Channel driver
        nut.0	2016-10-03 15:06:46.566	debug	nut.0 Set State device.type = ups
        nut.0	2016-10-03 15:06:46.566	debug	nut.0 Create State device.type
        nut.0	2016-10-03 15:06:46.566	debug	nut.0 Set State device.serial = 5B1349T03604
        nut.0	2016-10-03 15:06:46.566	debug	nut.0 Create State device.serial
        nut.0	2016-10-03 15:06:46.566	debug	nut.0 Set State device.model = Back-UPS ES 700G
        nut.0	2016-10-03 15:06:46.566	debug	nut.0 Create State device.model
        nut.0	2016-10-03 15:06:46.565	debug	nut.0 Set State device.mfr = APC
        nut.0	2016-10-03 15:06:46.565	debug	nut.0 Create State device.mfr
        nut.0	2016-10-03 15:06:46.565	debug	nut.0 Create Channel device
        nut.0	2016-10-03 15:06:46.565	debug	nut.0 Set State battery.voltage-nominal = 12.0
        nut.0	2016-10-03 15:06:46.565	debug	nut.0 Create State battery.voltage-nominal
        nut.0	2016-10-03 15:06:46.565	debug	nut.0 Set State battery.voltage = 13.7
        nut.0	2016-10-03 15:06:46.565	debug	nut.0 Set State battery.type = PbAc
        nut.0	2016-10-03 15:06:46.565	debug	nut.0 Create State battery.type
        nut.0	2016-10-03 15:06:46.565	debug	nut.0 Set State battery.runtime-low = 120
        nut.0	2016-10-03 15:06:46.565	debug	nut.0 Create State battery.runtime-low
        nut.0	2016-10-03 15:06:46.565	debug	nut.0 Set State battery.runtime = 1672
        nut.0	2016-10-03 15:06:46.565	debug	nut.0 Set State battery.mfr-date = 2013/12/04
        nut.0	2016-10-03 15:06:46.565	debug	nut.0 Create State battery.mfr-date
        nut.0	2016-10-03 15:06:46.564	debug	nut.0 Set State battery.date = not set
        nut.0	2016-10-03 15:06:46.564	debug	nut.0 Create State battery.date
        nut.0	2016-10-03 15:06:46.564	debug	nut.0 Set State battery.charge-warning = 50
        nut.0	2016-10-03 15:06:46.564	debug	nut.0 Create State battery.charge-warning
        nut.0	2016-10-03 15:06:46.564	debug	nut.0 Set State battery.charge-low = 10
        nut.0	2016-10-03 15:06:46.564	debug	nut.0 Create State battery.charge-low
        nut.0	2016-10-03 15:06:46.564	debug	nut.0 Set State battery.charge = 100
        nut.0	2016-10-03 15:06:46.564	debug	nut.0 Create Channel battery
        nut.0	2016-10-03 15:06:46.564	debug	nut.0 Got values, start setting them
        nut.0	2016-10-03 15:06:46.564	debug	nut.0 NUT Connection ready
        nut.0	2016-10-03 15:06:46.564	info	nut.0 Start NUT update
        Mastermind	2016-10-03 15:06:45.531	warn	host.Mastermind instance system.adapter.nut.0 already running with pid 14081
        obwohl der Adapter auf log Level "info" steht
          apollon77 last edited by
          Korrekt Homoran … sorry hab den Pfad vergessen anzugeben.
            hast du nach dem download ein
            iobroker upload nut
            gemacht?
            sonst ist ggf. noch die alte Version aktiv, obwohl im admin schon die neue angezeigt wird.
            Rainer
              Ja, habe ich
              Gesendet von meinem HUAWEI CRR-L09 mit Tapatalk
                Habe iobroker auch neu gestartet
                  @rascal:
                  hey,
                  ich dachte, man muss das Intervall nun in den Adaptereinstellungen angeben, aber er fragt nach wie vor nach dem schedule: `
                  Bitte versuche mal wie von Homoran gesagt das upload.
                  AN sich ist im Adapter ein Stück Code drin der den "Tausch" machen sollte …
                  Wenn es dann immer noch nicht tut dann geh mal zu "Objekte".
                  Dort dann bei Type auf "instance" und auf den "Nut.0" (o.ä.) hinten auf edit klicken. Dann bekommst Du das Konfigobjekt angezeigt. poste das mal bitte.
                  Falls dort bei "mode" noch "schedule" steht dann schreib einfach "daemon" rein ... aber eigentlich sollte das der Adapter selbst machen ...den Tip dazu hatte mit Bluefox gegeben. Wenn nicht muss ich da nochmal ran 😞
                  Zum Logging: Häää ... komisch. Er gibt bei Dir "debug" Meldungen aus. ALs ob der Adapter auf Debug stehen würde. AUch das Loglevel findest Du in diesem Konfigobjekt von oben.
                    das "raw" Feld des system.adapter.nut.0
                      "common": {
                        "name": "nut",
                        "version": "1.0.0",
                        "title": "Network UPS Adapter",
                        "desc": "Read all data from your UPS/USV via nut protocol",
                        "platform": "Javascript/Node.js",
                        "mode": "schedule",
                        "schedule": "*/5 * * * * *",
                        "icon": "nut.png",
                        "extIcon": "https://raw.githubusercontent.com/Apollon77/ioBroker.nut/master/admin/nut.png",
                        "readme": "https://github.com/Apollon77/ioBroker.nut",
                        "license": "MIT",
                        "type": "hardware",
                        "loglevel": "info",
                        "installedVersion": "1.0.0",
                        "host": "Mastermind",
                        "subscribe": "messagebox",
                        "enabled": true,
                        "messagebox": true,
                        "news": {
                          "0.3.0": {
                            "en": "add better usable status states under 'status channel",
                            "de": "Besser nutzbare Stati States unter 'status' eingefügt",
                            "ru": "add better usable status states under 'status channel"
                          "1.0.0": {
                            "en": "change mode from schedule to deamon, implement message support to receive messages from upsmon, add status.severity",
                            "de": "Adapter arbeitet nun als Deamon, Notify-Support per upsmon hinzugefügt, status.severity hinzugefügt",
                            "ru": "change mode from schedule to deamon, implement message support to receive messages from upsmon, add status.severity"
                        "npmLibs": [],
                        "keywords": [
                          "iobroker",
                          "nut",
                          "ups",
                          "usv"
                      "native": {
                        "host_ip": "127.0.0.1",
                        "host_port": "3493",
                        "ups_name": "Powerplant",
                        "update_interval": "5"
                      "acl": {
                        "object": 1638,
                        "owner": "system.user.admin",
                      "_id": "system.adapter.nut.0",
                      "type": "instance"
                    allgemein:
                      Schreib bei mode mal "daemon" rein und starte neu. was passiert dann?
                      … und du willst wirklich alle 5 Sekunden neu lesen?
                        hey,
                        ja, es läuft.
                        einziger Schönheitsfehler ist wieder das Log:
                        host-Mastermind	2016-10-03 17:37:10.012	warn	instance system.adapter.nut.0 already running with pid 21959
                        nut-0	2016-10-03 17:37:08.906	info	All Nut values set
                        nut-0	2016-10-03 17:37:08.886	info	Start NUT update
                        nachdem ich iobroker neu gestartet habe, scheint es auch mit dem Log zu funktionieren
                        Danke für die Hilfe, falls mir was auffällt, melde ich mich wieder.
                          Mit Loglevel "warn" sollte fast nichts im Log stehen.
                            Soooo … jetzt ist die Version im Github auch wirklich mit der Logik die von Schedule- auf Daemon-Modus automagisch umbaut 🙂
                            Also wenn noch jemand testen will 🙂
                            Update am besten per Kommandozeile und danach "upload" manuell machen - nötig wegen dem Direktinstall vom Github.
                            Theoretisch sollte er nach dem Update dann die DInger erstmal noch als "Schedule" haben und beim ersten Start wird dann umgeschrieben.
                            Ggf ist danach ein iobroker restart nötig bis dann alles echt rund läuft. Bei meinen Tests lief er als Daemon, wurde aber trotzdem einmal pro Stunde zusätzlich gestartet was nur eine Fehlerzeile im Log gab. Rest lief rund.
                            Nach neustart war alles super.
                            Kann das noch jemand testen?
                            Ingo F
                            • wendy2702
                              wendy2702 last edited by
                              versuche gerade den Adapter zum laufen zu bekommen.
                              Wenn ich meine UPS Abfrage welche direkt am iobroker Server hängt sieht das so aus:
                              > upsc ups@127.0.0.1
                              battery.charge: 100
                              battery.charge.low: 10
                              battery.charge.warning: 50
                              battery.date: 2001/09/25
                              battery.mfr.date: 2013/11/18
                              battery.runtime: 11440
                              battery.runtime.low: 120
                              battery.type: PbAc
                              battery.voltage: 27.1
                              battery.voltage.nominal: 24.0
                              device.mfr: American Power Conversion
                              device.model: Back-UPS RS 900G
                              device.serial: 3B1329X15638
                              device.type: ups
                              driver.name: usbhid-ups
                              driver.parameter.pollfreq: 30
                              driver.parameter.pollinterval: 2
                              driver.parameter.port: auto
                              driver.parameter.vendorid: 051d
                              driver.version: 2.6.4
                              driver.version.data: APC HID 0.95
                              driver.version.internal: 0.37
                              input.sensitivity: medium
                              input.transfer.high: 294
                              input.transfer.low: 176
                              input.voltage: 231.0
                              input.voltage.nominal: 230
                              ups.beeper.status: enabled
                              ups.delay.shutdown: 20
                              ups.firmware: 879.L4 .I
                              ups.firmware.aux: L4
                              ups.load: 5
                              ups.mfr: American Power Conversion
                              ups.mfr.date: 2013/07/19
                              ups.model: Back-UPS RS 900G
                              ups.productid: 0002
                              ups.realpower.nominal: 540
                              ups.serial: 3B1329X15638
                              ups.status: OL
                              ups.test.result: No test initiated
                              ups.timer.reboot: 0
                              ups.timer.shutdown: -1
                              ups.vendorid: 051d
                              Wenn ich den Adapter mit den default Werten starte erscheint das im log:
                              nut.0	2017-01-10 21:41:30.887	error	Error happend: Error: connect ECONNREFUSED 127.0.0.1:3493
                              Das ganze ist Debian Wheezy mit folgenden Node und NPM Versionen:
                               npm -v
                              2.15.11
                              root@openmediavault /opt/iobroker/node_modules/iobroker.nut/test > node -v
                              v4.7.0
                              Fehlt mir etwas auf meinem System oder liegt das an meiner USV?
                              Danke und Gruß
                              Mirko
                                In welchem Modus läuft denn der nut? (/etc/nut/nut.conf). Es sollte nicht auf "none" stehen … must vllt mal die modi durchprobieren ... netserver geht in jedem Fall denke ich.
                                • wendy2702
                                  Läuft auf:
                                   cat /etc/nut/nut.conf
                                  MODE=standalone
                                  Mal auf netserver und netclient gestellt.
                                  Geht mit beiden nicht oder muss ich nach ändern der nut.conf noch mehr machen als nur den Adapter neu starten?
                                  Ist es richtig das in der nut.conf nur diese eine Zeile steht?
                                    Wenn Du auf netserver stellst und neu startest … was sagt das log? Ich glaube aber da muss dann noch mehr rein in ein anderes File.
                                    Schau mal z.B. hier: https://wiki.openwrt.org/inbox/software.nut
                                    http://zackreed.me/installing-nut-on-ubuntu/
                                    • wendy2702
                                      so sieht es mit netserver aus:
                                      nut.0	2017-01-10 23:22:53.415	error	Error happend: Error: connect ECONNREFUSED 127.0.0.1:3493
                                      nut.0	2017-01-10 23:22:53.410	info	Start NUT update
                                      nut.0	2017-01-10 23:22:53.397	info	starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.nut, node: v4.7.0
                                      • wendy2702
                                        Mal von dem einen link die Befehle abgefragt:
                                        MODE=netserver
                                         cat /etc/nut/ups.conf
                                        [ups]
                                        driver = usbhid-ups
                                        port = auto
                                        vendorid = 051d
                                        upsdrvctl start
                                        Network UPS Tools - UPS driver controller 2.6.4
                                        Network UPS Tools - Generic HID driver 0.37 (2.6.4)
                                        USB communication driver 0.32
                                        Using subdriver: APC HID 0.95
                                         cat /etc/nut/upsd.conf
                                        MAXAGE 15
                                        MAXCONN 1024
                                        LISTEN 127.0.0.1 3493
                                        Hier bei ist der einzige fehler:
                                        upsd
                                        Network UPS Tools upsd 2.6.4
                                        fopen /var/run/nut/upsd.pid: No such file or directory
                                        listening on 127.0.0.1 port 3493
                                        Connected to UPS [ups]: usbhid-ups-ups
                                         upsc ups@localhost ups.status
                                        OL
                                        root@openmediavault /opt/iobroker/node_modules/iobroker.nut/test > upsc ups@localhost
                                        battery.charge: 100
                                        battery.runtime: 12810
                                        battery.type: PbAc
                                        device.type: ups
                                        input.voltage: 230.0
                                        ups.load: 5
                                        ups.productid: 0002
                                        ups.status: OL
                                        ups.timer.reboot: 0
                                        ups.vendorid: 051d
                                        gerade einen letzten Versuch gestartet.
                                        Mir war nicht bewusst das ich scheinbar:
                                         upsdrvctl start
                                        root@openmediavault /var/run/nut > upsd
                                        /var/run/nut is world readable
                                        selber starten muss.
                                        Ist das so richtig oder sollte das nicht eigentlich der Adapter erledigen?
                                        Wenn ich nach manuellem start den Adapter starte sieht es so im log aus:
                                        nut.0	2017-01-10 23:46:57.134	info	All Nut values set
                                        nut.0	2017-01-10 23:46:57.122	info	Start NUT update
                                        nut.0	2017-01-10 23:46:57.108	info	starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.nut, node: v4.7.0
                                          Hey, den UPS/NUT Prozess musst Du starten. Der Adapter verbindet sich nur da hin und liesst die Daten. Der Adapter kann ja auch den UPS/NUT-Prozess gar nicht starten weil er ja auch nicht lokal laufen kann …
                                          Aber jetzt scheint es ja zu tun, oder ?!
                                          • wendy2702
                                            Ja. So funktioniert es.
                                            Muss das jetzt später noch restart resistent machen.
                                            Jetzt aber schlafen.
                                            Gute Nacht und danke für deine Hilfe.
                                            31.7k
                                            79.8k
                                            83
                                            14868
