    4. Anzahl Tage berechnen
      albi_63 @paul53 last edited by
      Wie funktioniert das mit Spoiler oder Export? Coole Sache
        paul53 @albi_63 last edited by paul53
        @albi_63 sagte:
        Script:
        Der Trigger funktioniert so nicht. Korrektur:
         <variables>
           <variable id="QyKrT,r/Z.uEZuB1cCk6">Voll</variable>
           <variable id="S(r:dJ+2zJ_K^*ns[%8h">Leer</variable>
           <variable id="}wmbN}pP_^UnXdMM~xr6">Anz_Tage</variable>
           <variable id="qWVLn7Ak;m,K|)ybk+kg">Restzeit</variable>
         </variables>
         <block type="variables_set" id="-/BuYzQg0[woH]GqqkmV" x="38" y="38">
           <field name="VAR" id="QyKrT,r/Z.uEZuB1cCk6">Voll</field>
             <block type="convert_from_date" id="@E9qvt%M_zlAE|3|:Mj">
               <field name="OPTION">object</field>
                 <block type="get_value" id="%g#U.;ImFrh34~Czzn%">
                   <field name="OID">javascript.0.Eigene_Datenpunkte.Wassertank.Voll</field>
             <block type="on" id="{55TC3}K4a@l:4$@M,U$">
               <field name="OID">sonoff.0.Wassertank/WemosD1.SR04_Distance</field>
                 <block type="controls_if" id="jp{,^R.Vr7#:6PH_$dZ(">
                     <block type="logic_operation" id="ZC1vr^8*rX!jy77q0luR">
                       <field name="OP">AND</field>
                         <block type="logic_compare" id="tP3HSdaED,eW3Th9bku">
                           <field name="OP">LTE</field>
                             <block type="on_source" id="^bnv/L~4N2zUJ/EOs{aK">
                             <block type="math_number" id="]TnH[?LEi@ag6z/Pl:-">
                               <field name="NUM">21</field>
                         <block type="logic_compare" id=".*-dan4oBu[5*I@Swff5">
                           <field name="OP">GT</field>
                             <block type="on_source" id="K$:D!0`Y2I%P.$-Nvb!?">
                               <field name="ATTR">oldState.val</field>
                             <block type="math_number" id=":DII$nq|U6*;TH22X4D}">
                     <block type="variables_set" id="O=4X@^|$adiI^q*scv~3">
                         <block type="on_source" id="7Wkmj?g:@4}?o%R~=J;X">
                           <field name="ATTR">state.lc</field>
                         <block type="update" id="z^%m8=RBV218J=[!|/G">
                             <block type="convert_from_date" id="aF.d{;oE?N|V.N^3O?Lg">
                               <mutation xmlns="http://www.w3.org/1999/xhtml" format="true" language="false"></mutation>
                               <field name="OPTION">custom</field>
                               <field name="FORMAT">JJJJ.MM.TT SS:mm:ss</field>
                                 <block type="variables_get" id="WI:]LM3-YGa8s+:4zrRQ">
                     <block type="controls_if" id="s3pcZMzD*9}%R6rGX9cs">
                         <block type="logic_operation" id="fe]*DHUv|Be7@%1fTNWz">
                             <block type="logic_compare" id="~@;s{nvZFR+h!nRAKGb8">
                               <field name="OP">GTE</field>
                                 <block type="on_source" id="gw5@LR7.5sA-$iT7pZX@">
                                 <block type="math_number" id="CaIX0%!CYQivKFqO~Ou(">
                                   <field name="NUM">110</field>
                             <block type="logic_compare" id="ti}P_tBRivXN/aNu:9Fw">
                               <field name="OP">LT</field>
                                 <block type="on_source" id=");aj?@zfWjF[:=/bW=:l">
                                 <block type="math_number" id="jjgusYbSD;6@-P;tl8K+">
                         <block type="variables_set" id="gXHSbLd-*=_JDmNEl">
                           <field name="VAR" id="S(r:dJ+2zJ_K^*ns[%8h">Leer</field>
                             <block type="on_source" id="h[X6_8+8x[JCPy9DEq}">
                             <block type="update" id="[2[cL{Ua|eK:qZ^(CRoP">
                               <field name="OID">javascript.0.Eigene_Datenpunkte.Wassertank.Leer</field>
                                 <block type="convert_from_date" id="QDIgRy%}5wUrj@3MMoW/">
                                     <block type="variables_get" id="ECaK}:wet.T.pe:lBSi">
                                 <block type="variables_set" id="b}sNlY!L7iE,_ER:h]1Y">
                                   <field name="VAR" id="}wmbN}pP_^UnXdMM~xr6">Anz_Tage</field>
                                     <block type="math_round" id="0nnYv?v$QA?..gN_X^#q">
                                       <field name="OP">ROUNDDOWN</field>
                                       <value name="NUM">
                                         <shadow type="math_number" id="c5,$:16H1bT-cf+;moF:">
                                           <field name="NUM">3.1</field>
                                         <block type="math_arithmetic" id="o|Zy%2G/,HaU{)XJo?P" inline="false">
                                           <field name="OP">DIVIDE</field>
                                             <shadow type="math_number" id=")suP~j2q)26gS7.9,{[">
                                               <field name="NUM">1</field>
                                             <block type="math_arithmetic" id="]x!sFAc$XT$n}vik|^2E">
                                                 <shadow type="math_number">
                                                 <block type="variables_get" id="}X5~oVvVh;LtbI;d(_0Q">
                                                 <block type="variables_get" id=":2JcyX$-f:2ocE;S)l5@">
                                             <shadow type="math_number" id="_-E7:Y6H*,,b5e3qdH}S">
                                               <field name="NUM">86400000</field>
                                     <block type="variables_set" id="KBIKf2YRpM{:%#n?Q">
                                       <field name="VAR" id="qWVLn7Ak;m,K|)ybk+kg">Restzeit</field>
                                         <block type="math_arithmetic" id="BbO/)KNt2#)?|5=4J_+">
                                             <shadow type="math_number" id="4-GS=lP3h.#XLw.}c@@">
                                             <block type="math_arithmetic" id="v)(k;?Zk!jW_S!PWI$Pt">
                                                 <shadow type="math_number" id="Z,m#-rT3Xws-6F%Wby0">
                                                 <block type="variables_get" id="aq1P9afQZ(Gj7xacgg%S">
                                                 <shadow type="math_number" id="c_D}!OO@RhR206Zi#qH">
                                                 <block type="variables_get" id="@=p=s3Xd@!0!AyDnwOR">
                                             <shadow type="math_number" id=",)dgsw$E3)c+,bbY[ls7">
                                             <block type="math_arithmetic" id="|yhqib-MuvJYdFtP+!2t">
                                                 <shadow type="math_number" id="yN!fz~;Et7r6xD{=Wn3b">
                                                 <block type="variables_get" id="lmsK+|J1FexT+-BVgNK_">
                                                 <shadow type="math_number" id="jq7@Dz?:VequK|F^;@si">
                                         <block type="variables_set" id="@$to!AA:!3r)YTw(M8w@">
                                             <block type="text_join" id=",_l}mgscm0WIlT(=)qA">
                                               <value name="ADD0">
                                                 <block type="variables_get" id="Za[vF^ZYI8l|IL+e,Fx%">
                                               <value name="ADD1">
                                                 <block type="text" id="orElMSg28TSabR{~Mq[">
                                                   <field name="TEXT"> Tage </field>
                                               <value name="ADD2">
                                                 <block type="convert_from_date" id="6U5O/X{y0dqn%u(Ut3_" inline="false">
                                                   <field name="OPTION">hh:mm:ss</field>
                                                     <block type="math_arithmetic" id="QW/i!vUXb*H@qfM;z;ci" inline="false">
                                                       <field name="OP">ADD</field>
                                                         <shadow type="math_number" id="VlPS%BH2i:Plhhh24mK^">
                                                         <block type="variables_get" id="%xcj_vFN#c.wmDHKTt">
                                                         <shadow type="math_number" id="ae}2S1rscE%C]^fGP-{A">
                                                         <block type="convert_from_date" id="BS_@AFOR/~XqgA2Qo;h(" inline="false">
                                                             <block type="text" id="B8[|sbLGSynC0]eae6jv">
                                                               <field name="TEXT">1970-01-01 00:00</field>
                                             <block type="update" id="Xh9:~6:6U8:~j:I_hy5u">
                                               <field name="OID">javascript.0.Eigene_Datenpunkte.Wassertank.Anz_Tage</field>
                                                 <block type="text_join" id="ty!AHeO0jd#MR+Yf,KYU">
                                                   <value name="ADD0">
                                                     <block type="text" id="_E+FYD:XnDs+/v7Or#DK">
                                                       <field name="TEXT">Der Wassertank reichte </field>
                                                   <value name="ADD1">
                                                     <block type="variables_get" id="5bAUP@U9SX:+m1iDMhYF">
        @albi_63 sagte in Anzahl Tage berechnen:
        Im Spoiler bitte noch Code tags verwenden.
        A 4 Replies Last reply Reply Quote 0
          So Paul
          Jetzt habe ich alles so angepasst wie es sein muss. Habe das script mit dem SR04 Sensor getestet und, "oh staune", es klappt.
          Du bist der Beste, tausend Dank 😇 🤗
          Im Anhang noch das fertige script:
           <variables>
           </variables>
                               <block type="telegram" id="1p.mr=8zIRf}BXy2,~TD">
                                 <field name="LOG"></field>
                                 <value name="MESSAGE">
                                   <shadow type="text" id="*rldG[s+n+4?Hv%`=e(V">
                                   <block type="text_join" id="fb,%OO7l,[v7]4,z$gg:">
                                     <value name="ADD0">
                                       <block type="text" id="/:PON)p~%~g~TqP(};v!">
                                         <field name="TEXT">Der Wassertank wurde am </field>
                                     <value name="ADD1">
                                       <block type="get_value" id="k;G4V{=C!bk5m|~B8TlC">
                                     <value name="ADD2">
                                       <block type="text" id=")3HsTjlX8YJOhm:deQmf">
                                         <field name="TEXT"> gefüllt.</field>
                                         <value name="NUM">
                                                 <value name="ADD0">
                                                 <value name="ADD1">
                                                 <value name="ADD2">
                                                     <value name="ADD0">
                                                     <value name="ADD1">
                                                   <block type="telegram" id="S;]L}vZUyveWjFgtk0ft">
                                                       <shadow type="text" id="V7*Wd]Z%7G-s^uLr06/.">
                                                       <block type="text_join" id="AJ=O/^]z=_KNPcModUu%">
                                                         <mutation items="4"></mutation>
                                                         <value name="ADD0">
                                                           <block type="text" id="6o(;tNl-a|~cFL|Ug.^R">
                                                             <field name="TEXT">Der Wassertank ist leer seit </field>
                                                         <value name="ADD1">
                                                           <block type="get_value" id="MAH;/TMbltFf!?ztUE:3">
                                                         <value name="ADD2">
                                                           <block type="text_newline" id="tu:(+934mUCU4uak|W-n">
                                                             <field name="Type">\n</field>
                                                         <value name="ADD3">
                                                           <block type="get_value" id="T,OMM$ZfT*p;B]qy{{@!">
          Script für all diejenigen die es interessiert:
            Homoran Global Moderator Administrators @albi_63 last edited by
            Du bist der Beste
            kann hier jeder bestätigen!
              Hallo Paul
              Ich hoffe du bist wohl auf.......
              Beim letzten Script der Tagebrechnung meines Wassertankes hatten wir ja den Trigger mit Wert und verheriger Wert gesetzt.
              Jetzt kommt es leider zeitweise vor, dass der Trigger auslöst und mir das Startdatum neu setzt. Ich vermute dass der Sensor zeitweise Fehlmessungen verursacht und so den Trigger neu startet.
              Wenn ich jetzt die Range höher setze zb: Wert < 23 und vorheriger > 30, wird der Trigger nicht ausgelöst.
              Wie könnte man das definieren damit es trotzdem funktioniert?
                Ich habe mal den Sensor geloggt, dieser schwankt tatsächlich mal hoch mal runter
                30.018 	true 		2020-11-10 21:12:16.361
                30.035 	true 		2020-11-10 21:11:46.334
                30.018 	true 		2020-11-10 21:11:16.401
                30.018 	true 		2020-11-10 21:10:16.385
                30 	true 		2020-11-10 21:09:46.321
                30.035 	true 		2020-11-10 21:09:16.325
                29.561 	true 		2020-11-10 21:08:46.202
                29.579 	true 		2020-11-10 21:08:16.281
                29.579 	true 		2020-11-10 21:07:46.301
                30 	true 		2020-11-10 21:07:16.303
                29.982 	true 		2020-11-10 21:06:46.306
                29.579 	true 		2020-11-10 21:06:16.314
                30.035 	true 		2020-11-10 21:05:46.249
                30.053 	true 		2020-11-10 21:05:16.294
                30.018 	true 		2020-11-10 21:04:46.261
                29.579 	true 		2020-11-10 21:04:16.321
                29.561 	true 		2020-11-10 21:03:51.669
                null 	true 		2020-11-10 21:03:51.669
                  Hallo Paul
                  Könnte mein Trigger so funktionieren?
                    @albi_63 sagte:
                    Ist es ein Problem, wenn als Startdatum die Zeit des letzten Unterschreiten des Grenzwertes verwendet wird (außer das die Telegram-Meldung mehrfach kommt) ? Offenbar schwankt der Pegel etwas.
                      Hy Paul
                      Wenn er mir das Startdatum ändert, dann stimmt doch die Berechnung nicht mehr, wie lange der Tank reichte.
                      Oder liege ich hier falsch.
                        @albi_63 sagte:
                        Solange der Wert um 30 schwankt, ist der Tank voll. Oder ?
                        A 2 Replies Last reply Reply Quote 0
                          Ja
                            Aber wenn der Tankinhalt fällt, zb, auf 50cm , dann wird der Sensor mir wieder ein wenig auf und ab varieren und das reicht aus um das Startdatum wieder zu ändern
                              @albi_63 sagte:
                              Was sind 50 cm ? Fast voll ?
                              Wenn der Wert über 30 bleibt, wird das Startdatum nicht mehr geändert.
                                Der Wert steigt dauernd mit jedem Verbrauch. 30 cm voll, 110 cm leer
                                blockly
                                1494
