    3. Entwicklung
    4. VisualStudio Code und Devcontainer
    • AlCalzone
      AlCalzone Developer @Asgothian last edited by
      @Asgothian sagte in VisualStudio Code und Devcontainer:
      ich hab keinen Adapter für den ich im ioBroker eine Instanz hinzufügen kann
      Ich seh im Log nichts von der Adapter-Installation. Wie sieht denn deine devcontainer.json aus?
      • Asgothian
        Asgothian Developer @AlCalzone last edited by Asgothian
        @AlCalzone
        Ich hatte mir das .devcontainer Verzeichnis von @UncleSam geholt (vom iobroker.loxone adapter) und angepasst.
        devcontainer.json
        // For format details, see https://aka.ms/vscode-remote/devcontainer.json or this file's README at:
        // https://github.com/microsoft/vscode-dev-containers/tree/v0.101.1/containers/docker-existing-docker-compose
        // If you want to run as a non-root user in the container, see .devcontainer/docker-compose.yml.
            "name": "ioBroker Docker Compose",
            // Update the 'dockerComposeFile' list if you have more compose files or use different names.
            // The .devcontainer/docker-compose.yml file contains any overrides you need/want to make.
            "dockerComposeFile": ["docker-compose.yml"],
            // The 'service' property is the name of the service for the container that VS Code should
            // use. Update this value and .devcontainer/docker-compose.yml to the real service name.
            "service": "iobroker",
            // The optional 'workspaceFolder' property is the path VS Code should open by default when
            // connected. This is typically a file mount in .devcontainer/docker-compose.yml
            "workspaceFolder": "/workspace",
            // Set *default* container specific settings.json values on container create.
            "settings": {
                "terminal.integrated.shell.linux": null
            // Add the IDs of extensions you want installed when the container is created.
            "extensions": ["dbaeumer.vscode-eslint", "esbenp.prettier-vscode"]
            // Uncomment the next line if you want start specific services in your Docker Compose config.
            // "runServices": [],
            // Uncomment the next line if you want to keep your containers running after VS Code shuts down.
            // "shutdownAction": "none",
            // Uncomment the next line to run commands after the container is created - for example installing git.
            // "postCreateCommand": "apt-get update && apt-get install -y git",
            // Uncomment to connect as a non-root user. See https://aka.ms/vscode-remote/containers/non-root.
            //"remoteUser": "iobroker"
        docker-compose.yml
        version: '3'
        services:
            iobroker:
                build: .
                container_name: iobroker-dvlp
                hostname: iobroker-dvlp
                ports:
                    - '8081:8081'
                volumes:
                    - ./..:/workspace:cached
                    - iobrokerdata-dvlp:/opt/iobroker
                environment:
                    - LANG=en_US.UTF-8
                    - LANGUAGE=en_US:en
                    - LC_ALL=en_US.UTF-8
                    - TZ=Europe/Zurich
                    - SETGID=1000
        volumes:
            iobrokerdata-dvlp:
        Dockerfile
        FROM buanet/iobroker:latest
        RUN ln -s /opt/iobroker/node_modules/ /root/.node_modules
        UncleSam 1 Reply Last reply Reply Quote 0
        • UncleSam
          UncleSam Developer @Asgothian last edited by
          Er voilà, da haben wir den Fehler. Den Loxone Adapter habe ich noch nicht auf den neusten Stand von create-adaper gebracht. Nimm bitte entweder i2c oder create-adaper und schau dir die Migrationshilfen in create-adapter an.
          • Asgothian
            Asgothian Developer @UncleSam last edited by Asgothian
            @UncleSam
            Schwere Geburt. Aber - es geht jetzt. Ich hab den Adapter im Container aktiv, und kann also jetzt mal versuchen mich da entsprechend zu verbinden.
            Für die Hilfe schon einmal vielen Dank.
            Jetzt bleibt noch eine Frage: Beim Zigbee Adapter kann es vorkommen das ich zusätzlich auch in einer der verwendeten Bibliotheken Änderungen machen muss. Dazu habe ich auch davon einen Github Fork. In meinem aktuellen Workflow lade ich die geänderten Daten von Hand von meinem Entwicklungsrechner in den ioBroker. Das kann ich im Moment nicht, da ich nicht direkt auf das Dateisystem im Container zugreifen kann.
            Hast Du dafür einen Vorschlag für mich ?
            A.
            • OliverIO
              OliverIO @UncleSam last edited by OliverIO
              @UncleSam sagte in VisualStudio Code und Devcontainer:
              Wenn's geht empfehlen wir immer den Adapter Creator (npx @iobroker/create-adapter) zu nutzen
              Ich wollte nochmal nachfragen, da ich gerade auch am rumprobieren bin:
              Man braucht aber dann auf jeden Fall eine Node-Installation unter Windows (und nur dafür) um den adapter-creator aufzurufen, der einem dann die Anfangsdateien für den Container und vs code erstellt?
              Wäre es nicht besser dafür ein basis image zur Verfügung zu stellen und erst im container dann adapter-creator auszuführen für ein (oder auch weitere adapter)?
              Asgothian AlCalzone 2 Replies Last reply Reply Quote 0
              • Asgothian
                Asgothian Developer @OliverIO last edited by
                @OliverIO du kannst das tun was ich getan hab:
                • den container von buanet laden,
                • starten.. in die Konsole gehen,
                • da den adapter creator aufrufen,
                • Daten kopieren, dann weiter machen.
                • OliverIO
                  OliverIO @Asgothian last edited by OliverIO
                  @Asgothian
                  so ähnlich habe ich das gemacht:
                  1.) neuer Ordner irgendwo in Windows angelegt
                  2) VS code lokal geöffnet (also normal geöffnet) und den obigen Ordner als Workspace geöffnet
                  3) Dann Befehl "add Developement container configuration files" ausgeführt
                  4) Dann die Inhalte gegen die 3 Dateien aus dem loxone-Adapter ersetzt und überall wo "loxone" steht gegen "dev" getauscht. Wenn man vis nutzen möchte sollte auch der port 8082 in docker-compose noch geöffnet werden
                  5) Rebuild container ausgeführt (das erste mal dauert, da so 300-500MB heruntergeladen werden, festplattenspeicher sollte man auch ordentlich frei haben, da das endgültige Image ca 1,2GB groß ist und buanet ebenfalls noch da ist. )
                  6) Ergebnis: Container startete und iobroker lief
                  7) Dann create-adapter remote im workspace ordner ausgeführt
                  8 ) dann workspace auf den neu erzeugten ordner gesetzt (open folder)
                  9) dann rebuild container ausgeführt
                  10) nun ist das problem, das zwar 2 container laufen (iobroker und nginx), aber iobroker nicht erreichbar ist und im gegensatz zu oben steht in der statuszeile von vscode nun "0 ports available" steht.
                  Ergänzung nach weiteren 2h:
                  also ich habe jetzt einige zeit mit der Konfiguration direkt aus dem create-adapter rumprobiert.
                  die container laufen zwar, aber ich komme mit dem browser einfach nicht drauf.
                  irgendwas mit der nginx-kombination für den reverse-proxy scheint da nicht zu stimmen.
                  mit localhost:8081 oder auch localhost:80 kommt nichts.
                  wenn ich localhost:8082 aufrufe kommt bad gateway.
                  wenn ich noch das access_log und das error_log dazu konfiguriere, dann kommt da kein zugriff an. das errorlog zeigt keinen fehler an.
                  daher switche ich nochmal zur oben beschriebenen Schrittanleitung bis Schritt 7 um, da funktioniert für mich alles. auch die admin-oberfläche
                  Was ist nochmal der Grund warum der nginx als reverse proxy hier eingesetzt wird?
                  sorry für den langen post, habe aber die Schrittanleitung etwas ausgebaut, damit andere das ebenfalls nachvollziehen können.
                  • AlCalzone
                    AlCalzone Developer @OliverIO last edited by
                    @OliverIO sagte in VisualStudio Code und Devcontainer:
                    Sofern du im devcontainer weiterarbeiten willst, ist das korrekt.
                    Damit du im Devcontainer die Admin-UI bearbeiten kannst, ohne bei jeder Änderung ein iobroker upload machen zu müssen. Mit dem reverse proxy kommt die Admin-UI für deinen Adapter direkt aus dem Dev-Verzeichnis.
                    Teile doch mal deine Konfiguration inkl. docker-compose.yml und welche Ports ioBroker (web/vis/...) in seinem container nutzt. Da passt garantiert was nicht zusammen.
                    • OliverIO
                      OliverIO @AlCalzone last edited by
                      @AlCalzone
                      Ich habe initial ja nur den adaptercreator ausgeführt und den container gestartet, sonst nichts.
                      Zur Sicherheit habe ich das soeben komplett nochmal von vorne gemacht.
                      Ich selbst habe nichts an den Dateien verändert.
                      Ergebnis:
                      Gemäß docker Desktop laufen die beiden container iobroker+nginx
                      iobroker ist über localhost:8081 aber nicht erreichbar
                      Wenn du noch weitere Dateien benötigst, sag Bescheid.
                      Datei .devcontainer
                          "dockerComposeFile": [ "docker-compose.yml" ],
                          "settings": {},
                          "extensions": ["dbaeumer.vscode-eslint"],
                          // When creating the container, delete unnecessary adapters, disable error reporting, set the license as confirmed, and install/update this adapter
                          "postCreateCommand": "iob del discovery && iob plugin disable sentry && iob object set system.config common.licenseConfirmed=true && NPM_PACK=$(npm pack) && iob url \"$(pwd)/$NPM_PACK\" --debug && rm \"$NPM_PACK\""
                      Datei docker-compose
                      version: '3'
                      services:
                          iobroker:
                              build: ./iobroker
                              container_name: iobroker-mytest
                              hostname: iobroker-mytest
                              # This port is only internal, so we can work on this while another instance of ioBroker is running on the host
                              expose:
                                  - 8081
                              volumes:
                                  - ..:/workspace:cached
                                  - iobrokerdata-mytest:/opt/iobroker
                              environment:
                                  - LANG=en_US.UTF-8
                                  - LANGUAGE=en_US:en
                                  - TZ=Europe/Berlin
                                  - SETGID=1000
                          # Reverse proxy to load up-to-date admin sources from the repo
                          nginx:
                              image: nginx:latest
                              depends_on:
                                  - iobroker
                              links:
                                  - iobroker
                              container_name: nginx-mytest
                              volumes:
                                  - ./nginx/nginx.conf:/etc/nginx/nginx.conf
                              ports:
                                  # Make the ioBroker admin available under http://localhost:8082
                                  - 8082:80
                      volumes:
                      • AlCalzone
                        AlCalzone Developer @OliverIO last edited by AlCalzone
                        Nein, er ist unter :8082 erreichbar. Steht auch in der README im .devcontainer-Ordner 😉 UND in docker.compose.yml
                        Ist deswegen nicht der Standardport, weil es sein kann, dass schon eine Instanz unter 8081 läuft.
                        • EdgarM
                          EdgarM Developer last edited by
                          ebnis ist aber das gleiche - ich hab keinen Adapter für d
                          Hi, bei mir klappt das Debuggen nicht, es kommt ein Fehler:
                          /usr/bin/node ./main.js --debug 0
                          Process exited with code 6
                          meine launch.json:
                              // Use IntelliSense to learn about possible attributes.
                              // Hover to view descriptions of existing attributes.
                              // For more information, visit: https://go.microsoft.com/fwlink/?linkid=830387
                              "version": "0.2.0",
                              "configurations": [
                                       "type": "node",
                                      "request": "launch",
                                      "name": "Launch TypeScript Adapter",
                                      "skipFiles": ["<node_internals>/**"],
                                      "program": "${workspaceFolder}/main.js",
                                      "args": ["--debug", "0"],
                                      "outFiles": ["${workspaceFolder}/build/**/*.js"]
                          jemand eine Idee?
                          E
                          • OliverIO
                            @AlCalzone
                            auch hier unverändert, wie ich oben geschrieben habe.
                            EdgarM AlCalzone 2 Replies Last reply Reply Quote 0
                            • EdgarM
                              EdgarM Developer @OliverIO last edited by EdgarM
                              @OliverIO Bei mir lag da daran, dass auf dem Rechner schon lokal iobroker lief, und er Post 8082 für den web adapter reserviert war.
                              Habe den Port in der docker-compose.yml einfach auf 9092 gesetzt, dann ging es auch:
                                  nginx:
                                      image: nginx:latest
                                      depends_on:
                                          - iobroker
                                      links:
                                          - iobroker
                                      container_name: nginx-countstates
                                      volumes:
                                      ports:
                                          - 9082:80
                              • AlCalzone
                                Dann zeig mir bitte noch deine nginx.conf
                                • EdgarM
                                  Bei mir war es ein echter Fehler im Adapter.
                                  grüße
                                  E
                                  • OliverIO
                                    OliverIO @AlCalzone last edited by OliverIO
                                    @AlCalzone
                                    Auch hier nix verändert, stammt alles so aus dem adapter-creator.
                                    nginx.conf
                                    worker_processes 1;
                                    events { worker_connections 1024; }
                                    http {
                                      sendfile           on;
                                      keepalive_timeout  65;
                                      server {
                                        listen 80;
                                        location / {
                                          proxy_redirect off;
                                          proxy_pass     http://iobroker:8081;
                                        location /socket.io/ {
                                          proxy_http_version 1.1;
                                          proxy_set_header   Upgrade $http_upgrade;
                                          proxy_set_header   Connection "Upgrade";
                                        location /adapter/mytest/ {
                                          alias /workspace/admin/;
                                        access_log /var/log/nginx/accessx.log combined;
                                    error_log /var/log/nginx/errorx.log warn;
                                    Ich denke nicht das es an nginx liegt, siehe mein nächsten Post
                                    • OliverIO
                                      OliverIO @OliverIO last edited by
                                      @EdgarM Auf dem Windowsrechner läuft sonst kein weiterer Server und iobroker lief da noch nie, da mein Produktionssystem auf einem NUC läuft.
                                      @AlCalzone
                                      ich hab nun ein wenig weiter recherchiert und im iobroker log die folgende Warnung gefunden:
                                      warn: host.iobroker-mytest does not start any instances on this host
                                      Nach ein bisschen Suche im Forum soll man den admin adapter installieren
                                      iobroker add admin
                                      Danach klappt der Zugriff auf iobroker, aber ich habe nun 2 admin instanzen (0=inaktiv und 1=aktiv)
                                      an was könnte das liegen?
                                      • AlCalzone
                                        Das gibts eigentlich nur, wenn sich der Hostname ändert. Ist mir beim Devcontainer noch nicht untergekommen, vielleicht ist das wegen deiner Container-zu-Container-Migration passiert?
                                        • OliverIO
                                          @AlCalzone
                                          kann natürlich alles sein, aber ich habe visual studio mit dem ordner, der durch den adapter creator erzeugt wurde neu geöffnet und den container mit diesen Informationen neu erzeugt (rebuild). Wo stehen den in den ganzen Dateien noch irgendwelche hostnamen?
                                          • AlCalzone
                                            @OliverIO Nicht im Adapter, aber in dem ioBroker, der im Container läuft. Der ordnet Instanzen bestimmten Hosts zu, was bei manuellen Umzügen gern mal für "does not start any instances" sorgt.
                                            adapter entwicklung docker remote vscode
                                            13
                                            127
                                            19307
