    4. Script Hilfe für Abfrage Serielle Kommunikation gesucht!
    • wendy2702
      wendy2702 @Axel Koeneke last edited by
      @Axel-Koeneke ich kann mein Script nochmal neu posten wenn ich zu Hause bin. Frühestens Donnerstag denke ich.
      • wendy2702
        Hi nochmal mein aktuell funktionierendes Script:
        Script zur Abfrage welches alle 3 minuten gestartet, gestoppt wird:
        createState('Waterkotte.Daten.Abfrage_Rohdaten');
        //createState('Waterkotte.Daten.Abfrage_Error');
        setState("javascript.2.Waterkotte.Daten.Abfrage_Error"/*Waterkotte.Daten.Abfrage_Error*/, false);
        // To use the `ByteLength` parser:
        const SerialPort = require('serialport');
        const ByteLength = SerialPort.parsers.ByteLength;
        var buffer = new Buffer(12);
        buffer[0] = 0x10;
        buffer[1] = 0x02;
        buffer[2] = 0x01;
        buffer[3] = 0x15;
        buffer[4] = 0x00;
        buffer[5] = 0x00;
        buffer[6] = 0x00;
        buffer[7] = 0xf3;
        buffer[8] = 0x10;
        buffer[9] = 0x03;
        buffer[10] = 0x7c;
        buffer[11] = 0x32;
        const port = new SerialPort("/dev/ttyUSB1", {
           baudRate: 9600,
           dataBits : 8,
           parity : 'none',
           stopBits: 1
        //  flowControl : false
        }, function (err) {
           if (err) {
        //        port.close();
               console.log('Error1: ', err.message);
               setState("javascript.2.Waterkotte.Daten.Abfrage_Error"/*Waterkotte.Daten.Abfrage_Error*/, true);
           const parser = port.pipe(new ByteLength({ length: 253 }));
           parser.on('data', function (data) {
           	console.log('Data received: ' + data.toString('hex'));
           	var daten = data.toString('hex');
           	setState('Waterkotte.Daten.Abfrage_Rohdaten', daten, true);
           	//port.close();
           // Flush input
           port.flush();
           // send Data
               port.write(buffer, function(err) {
           	    if (err) {
           		    return console.log('Error on write: ', err.message);
           	    console.log('Daten send');
        // 		    port.close();
        port.on('open', function() {
           console.log('Connected');
        port.on('error', function(err) {
           console.log('Error2: ', err.message);
        //	port.close();
        // close port if the script stopped (to be able to open it again)
        onStop(function (callback) {
           if (port && port.isOpen) {
           	port.close();
           	console.log('port closed');
        Scipt zur Auswertung der Abfrage, ist ständig aktiv:
        //createState('Waterkotte.Daten.Rohdaten');
        createState('Waterkotte.Daten.Version');
        createState('Waterkotte.Daten.Temp_Aussen_Ist');
        createState('Waterkotte.Daten.Temp_Aussen_24h');
        createState('Waterkotte.Daten.Temp_Aussen_1h');
        createState('Waterkotte.Daten.Temp_Ruecklauf_Soll');
        createState('Waterkotte.Daten.Temp_Ruecklauf_Ist');
        createState('Waterkotte.Daten.Temp_Vorlauf');
        createState('Waterkotte.Daten.Temp_WW_Soll');
        createState('Waterkotte.Daten.Temp_WW_Ist');
        createState('Waterkotte.Daten.Temp_Raum');
        createState('Waterkotte.Daten.Temp_Raum_1h');
        createState('Waterkotte.Daten.Temp_WQuelle_Ein');
        createState('Waterkotte.Daten.Temp_WQuelle_Aus');
        createState('Waterkotte.Daten.Temp_Verdampfer');
        createState('Waterkotte.Daten.Temp_Kondensator');
        createState('Waterkotte.Daten.Temp_Saugleitung');
        createState('Waterkotte.Daten.Temp_frei');
        createState('Waterkotte.Daten.Druck_Verdampfer');
        createState('Waterkotte.Daten.Druck_Kondensator');
        createState('Waterkotte.Daten.Status_Heizung');
        createState('Waterkotte.Daten.Status_Warmwasser');
        createState('Waterkotte.Daten.Status_Handabschaltung');
        createState('Waterkotte.Daten.Status_WPumpe');
        createState('Waterkotte.Daten.Mode_Heizung');
        createState('Waterkotte.Daten.Mode_Heizung_EIN_Normal');
        createState('Waterkotte.Daten.Mode_Heizung_EIN_Solar');
        createState('Waterkotte.Daten.Mode_Heizung_EIN_externe_Anhebung');
        createState('Waterkotte.Daten.Mode_Heizung_EIN_Schnellaufheizung');
        createState('Waterkotte.Daten.Mode_Heizung_AUS_Zeitprogramm');
        createState('Waterkotte.Daten.Mode_Heizung_AUS_Unterdrueckung');
        createState('Waterkotte.Daten.Mode_Heizung_AUS_kein_Bedarf');
        createState('Waterkotte.Daten.Mode_Heizung_AUS_wegen_Fuehlerfehler');
        createState('Waterkotte.Daten.Mode_Warmwasser');
        createState('Waterkotte.Daten.Mode_Warmwasser_EIN_Normal');
        createState('Waterkotte.Daten.Mode_Warmwasser_EIN_Solar');
        createState('Waterkotte.Daten.Mode_Warmwasser_AUS_Zeitprogramm');
        createState('Waterkotte.Daten.Mode_Warmwasser_AUS_kein_Bedarf');
        createState('Waterkotte.Daten.Mode_Warmwasser_AUS_Unterbrechung_wegen_Fuehlerfehler');
        createState('Waterkotte.Daten.Mode_Warmwasser_AUS_Unterdrueckung');
        createState('Waterkotte.Daten.Mode_Warmwasser_Solar');
        createState('Waterkotte.Daten.Mode_Warmwasser_AUS_Solarnutzung');
        createState('Waterkotte.Daten.Mode_Kuehlung_EIN_Normal');
        createState('Waterkotte.Daten.Mode_Kuehlung_AUS');
        createState('Waterkotte.Daten.Mode_Kuehlung_AUS_Unterbrechung');
        createState('Waterkotte.Daten.Mode_Kuehlung_AUS_kein_Bedarf');
        createState('Waterkotte.Daten.Mode_Kuehlung_AUS_Unterbrechung_wegen_Fuehlerfehler');
        createState('Waterkotte.Daten.DI_Motorschutz_Kompressor');
        createState('Waterkotte.Daten.DI_Niederdruck_Pressostat');
        createState('Waterkotte.Daten.DI_Hochdruck_Pressostat');
        createState('Waterkotte.Daten.DI_Pumpe_Quelle');
        createState('Waterkotte.Daten.DI_Externe_Sollwertbeeinflussung');
        createState('Waterkotte.Daten.DI_Externe_Abschaltung');
        createState('Waterkotte.Daten.DO_Magnetventil');
        createState('Waterkotte.Daten.DO_Kompressor1');
        createState('Waterkotte.Daten.DO_Sammelstoermeldung');
        createState('Waterkotte.Daten.DO_Umschaltventil_Kuehlung');
        createState('Waterkotte.Daten.DO_Umschaltventil_Stufe2');
        createState('Waterkotte.Daten.DO_Umschaltventil_Pumpe_Heizung');
        createState('Waterkotte.Daten.DO_Umschaltventil_Pumpe_Warmwasser');
        createState('Waterkotte.Daten.DO_Umschaltventil_Pumpe_Quelle');
        var id = 'javascript.2.Waterkotte.Daten.Abfrage_Rohdaten';
        var daten;
        var Satz;
        var inp;
        var out;
        var VersionsNr;
        var TempAussenIst;
        var TempAussen24h;
        var TempAussen1h;
        var TempRuecklaufSoll;
        var TempRuecklaufIst;
        var TempVorlauf;
        var TempWWSoll;
        var TempWWIst;
        var TempRaum;
        var TempRaum1h;
        var TempWQuelleEin;
        var TempWQuelleAus;
        var TempVerdampfer;
        var TempKondensator;
        var TempSaugleitung;
        var Tempfrei;
        var DruckVerdampfer;
        var DruckKondensator;
        var KuehlungTempRuecklaufSoll;
        var KuehlungTempRuecklaufIst;
        var TempWWIst;
        var Zeit;
        var Datum;
        var BetriebsstundenKompressor;
        var BetriebsstundenHeizung;
        var BetriebsstundenWW;
        var BetriebsstundenStufe2;
        var BetriebsStundenMessZeitKompressor;
        var BetriebsStundenMessDatumKompressor;
        var BetriebsStundenMessZeitWPumpe;
        var BetriebsStundenMessDatumWPumpe;
        var BetriebsStundenResetKompressor;
        var BetriebsStundenResetWPumpe;
        var Kennwort;
        var WerksEinstellungen;
        var ResetWPumpe;
        var CrcSumme;
        var NStart;
        var DisplayZeile1;
        var DisplayZeile2;
        var AusfallTime;
        var AusfallDate;
        var AusfallBetriebsZustaende;
        var AusfallDoBuffer;
        var AusfallDoMagnetventil;
        var AusfallDoKompressor1;
        var AusfallDoBufferBit3;
        var AusfallDoUmschaltventilKuehlung;
        var AusfallDoStufe2;
        var AusfallDoPumpeHeizung;
        var AusfallDoPumpeWarmwasser;
        var AusfallDoPumpeQuelle;
        var AusfallDiBuffer;
        var AusfallDiMotorschutzkompressor;
        var AusfallDiNiederdruckPressostat;
        var AusfallDiHochdruckPressostat;
        var AusfallDiPumpeQuelle;
        var AusfallDiSoleMinnimum;
        var AusfallDiBufferBit6;
        var AusfallDiExterneSollwertbeeinflussung;
        var AusfallDiExterneAbschaltung;
        var AusfallAiTempQuelleEin;
        var AusfallAiError;
        var AusfallAiDi;
        var AusfallAiTempAussen;
        var AusfallAiTempQuelleAus;
        var AusfallAiVerdampfung;
        var AusfallAiTempHeizEin;
        var AusfallAiTempHeizAus;
        var AusfallAiKondensation;
        var AusfallAiTempWWasser;
        var AusfallAuxAiError;
        var AusfallAuxAiDi;
        var AusfallAiTempRaum;
        var ClearAusfaelle;
        var Unterbrechung;
        var WarnungEingangsSeite;
        var WarnungAusgangsSeite;
        var WarnungSonstige;
        var Ausfall;
        var AiError;
        var AiDi;
        var AiCounter0;
        var AuxAiError;
        var AuxAiDi;
        var BetriebsZustaende;
        var DoBuffer;
        var DiBuffer;
        var GesStatus;
        var StatusVerriegelung;
        var StatusHeiz;
        var StatusKuehl;
        var StatusStufe2;
        var StatusWWasser;
        var StatusWPumpe;
        var ModeHeiz;
        var ModeHeizEINNormal;
        var ModeHeizEINSolar;
        var ModeHeizEinextAnhebung;
        var ModeHeizEINSchnellaufheidzung;
        var ModeHeizAUSZeitprogramm;
        var ModeHeizAUSUnterdrueckung;
        var ModeHeizAUSkeinBedarf;
        var ModeHeizAUSwFuehlerf;
        var ModeKuehl;
        var ModeKuehlEINNormal;
        var ModeKuehlAUS;
        var ModeKuehlAUSUnterdrueckung;
        var ModeKuehlAUSkeinBedarf;
        var ModeKuehlAUSUnterbrechwFuehlerf;
        var ModeWWasser;
        var ModeWWassserINNormal;
        var ModeWWasserEINSolar;
        var ModeWWasserAUSZeitprogramm;
        var ModeWWasserAUSkeinBedarf;
        var ModeWWasserAUSUnterbrwFuehlerf;
        var ModeWWasserAUSUnterdrueckung;
        var ModeWWasserSolar;
        var ModeWWasserAUSSolarNutzung;
        var LoggerError;
        var LoggerInitTime;
        var LoggerInitDate;
        var LoggerMaxRec;
        var LoggerActRec;
        var LoggerMaxActRec;
        var LoggerSizeOfData;
        var LoggerSizeOfDatenLoggerBuffer;
        var DiMotorschutzkompressor;
        var DiNiederdruckPressostat;
        var DiHochdruckPressostat;
        var DiPumpeQuelle;
        var DiSoleMinnimum;
        var DiBufferBit6;
        var DiExterneSollwertbeeinflussung;
        var DiExterneAbschaltung;
        var DoMagnetventil;
        var DoKompressor1;
        var DoSammelstoermeldung;
        var DoUmschaltventilKuehlung;
        var DoStufe2;
        var DoPumpeHeizung;
        var DoPumpeWarmwasser;
        var DoPumpeQuelle;
        var VerdampfungstemperaturNiedrig;
        var TempQuelleAustrittNiedrig;
        var DiffQuelleEinQuelleAusHoch;
        var DiffQuelleAusVerdampfungHoch;
        var KondensationstemperaturHoch;
        var DiffHzgVorlaufRuecklaufNiedrig;
        var DiffHzgVorlaufRuecklaufHoch;
        var DiffKondensationVorlaufHoch;
        var HzgRuecklauffuehlerdefekt;
        var HzgVorlauffuehlerdefekt;
        var Aussenwandfuehlerdefekt;
        var DoBufferHandstellung;
        var SolestandMinimum;
        var Handabschaltung;
        var HzgEinsatzzeitpunktSollwert;
        var HzgRuecklaufSollwertamEinsatzp;
        var HeizkennlineSteigungSoll;
        var HeizkennlineObereBegrenzung;
        var HeizgSollwertanhebung4kfuer24h;
        var PilotraumSollwert;
        var PilotraumFaktor;
        var ExterneAnhebung;
        var FreigabeHeizung;
        var SperrenHeizung;
        var SollwertaenderungEin;
        var SollwertaenderungAus;
        var St2KlObereBegrenzung;
        var KennlinieHysterese;
        var PumpenNachlaufzeit;
        var AbschaltungHeizung;
        var KuehlungEinsatzzeitpunkt;
        var RuecklauftempSollwertamEinsatzzeitp;
        var KuehlungKennlinieSteigungSoll;
        var KennlinieuntereBegrenzung;
        var AbschaltungWW;
        var WWZeitEin;
        var WWZeitAus;
        var WWSoll;
        var BeckenwasserTempSoll;
        var WarmwasserHysterese;
        var BeckenwasserHysterese;
        var ModemKlingelzeichen;
        var Fremdzugriff;
        var Schluesselnummer;
        var SetBetriebsMode;
        var HzgExterneFreigabe;
        var HzgExterneRuecklaufsteuerung;
        var St2TempQAusMin;
        var St2TempVerdMin;
        var EstrichAufheizen;
        var HzgExterneSteuerung;
        var St2beiEVUAbsch;
        var FrgBeckenwasser;
        var ScaleFaktor;
        var OffsetNiederdr;
        var OffsetHochdr;
        var DoHandkanal;
        var DoHandkanalEin;
        var UnterdrWarnAus;
        var UnterdrWarnSonst;
        var UnterdrWarnEin;
        var NeuStart;
        var RunFlag;
        on(id, function (obj) {
        //function myScript() {
        //Bitauswertung
        function bitauswertung(Adresse)
        //Bit 1
        inp = Woerter[Adresse];
        out = parseInt(inp,16);
        out &= 1;
        if (out == 1) { Bit1 = 1; }
         else { Bit1 = 0; }
        //Bit 2
        out &= 2;
        if (out == 2) { Bit2 = 1; }
         else { Bit2 = 0; }
        //Bit 3
        out &= 4;
        if (out == 4) { Bit3 = 1; }
         else { Bit3 = 0; }
        //Bit 4
        out &= 8;
        if (out == 8) { Bit4 = 1; }
         else { Bit4 = 0; }
        //Bit 5
        out &= 16;
        if (out == 16) { Bit5 = 1; }
         else { Bit5 = 0; }
        //Bit 6
        out &= 32;
        if (out == 32) { Bit6 = 1; }
         else { Bit6 = 0; }
        //Bit 7
        out &= 64;
        if (out == 64) { Bit7 = 1; }
         else { Bit7 = 0; }
        //Bit 8
        out &= 128;
        if (out == 128) { Bit8 = 1; }
         else { Bit8 = 0; }
        // Formatierung des Integerbereichs
        function dezInt(num,size,prefix)
         prefix=(prefix)?prefix:"0";
         var minus=(num<0)?"-":"", result=(prefix=="0")?minus:"";
         num=Math.abs(parseInt(num,10)); size-=(""+num).length;
         for(var i=1;i<=size;i++) { result+=""+prefix; }
         result+=((prefix!="0")?minus:"")+num; return result;
        //IEEE nach Hex umrechnen
        function IEEE754_Hex32ToDez(hexstr)
         var dez,bin1,bin2,bin3,bin4,bin,sign,expo,mant,nul8='00000000';
         bin1=nul8+parseInt(hexstr.substr(0,2),16).toString(2);
         bin2=nul8+parseInt(hexstr.substr(2,2),16).toString(2);
         bin3=nul8+parseInt(hexstr.substr(4,2),16).toString(2);
         bin4=nul8+parseInt(hexstr.substr(6,2),16).toString(2);
         bin1=bin1.substr(bin1.length-8,8);
         bin2=bin2.substr(bin2.length-8,8);
         bin3=bin3.substr(bin3.length-8,8);
         bin4=bin4.substr(bin4.length-8,8);
         bin=bin1+bin2+bin3+bin4;
         sign=parseInt(bin.charAt(0),2);    // Vorzeichen
         expo=parseInt(bin.substr(1,8),2);  // Exponent
         mant=parseInt(bin.substr(9,23),2); // Mantisse
         dez=(1-2*sign)*Math.pow(2,expo-127)*(1+mant/Math.pow(2,23));
           dez = dez*100;
           dez = Math.round(dez);
           dez = dez/100;
         return(dez);
        daten = getState("javascript.2.Waterkotte.Daten.Abfrage_Rohdaten").val;
        console.log('Daten:' + daten);
        i = 0;
        var Satz = [];
        while (i < daten.length) {
           var byte = daten.substr(i, 2);
           Satz = Satz + ' ' + byte;
           i=i+2;
        console.log('Daten split:' + Satz);
        //WP-Antwort auf 10 10 durchsuchen und durc 10 ersetzen
        Satz = Satz.replace(/10 10/g, "10");
        // WP-Antwort in einzelne Bytes zerlegen
        var Woerter = Satz.split(" ");
        // Versions-Nr. berechnen
        inp = Woerter[6]+ Woerter[7];
        out=parseInt(inp,16);
        VersionsNr = out;
        console.log('Daten split:' + inp);
        // Versions-Datum berechnen
        inp = Woerter[8];
        out =dezInt(out,2);
        Merker1 = out;
        inp = Woerter[9];
        out =dezInt(out,2);
        Merker2 = out;
        inp = Woerter[10];
        out =dezInt(out,2);
        Merker3 = out;
        VersionsDatum = Merker1+ "." +Merker2+ "." +Merker3;
        //Betriebsmode auslesen
        inp = Woerter[11];
        out =dezInt(out,2);
        Merker1 = out;
        inp = Woerter[12];
        out =dezInt(out,2);
        Merker2 = out;
        inp = Woerter[13];
        out =dezInt(out,2);
        Merker3 = out;
        Betriebsmode = Merker1+ "." +Merker2+ "." +Merker3;
        //Temp-Aussen-Ist auslesen
        TempAussenIst = IEEE754_Hex32ToDez(Woerter[17]+ Woerter[16]+ Woerter[15]+ Woerter[14]);
        //Temp-Aussen-24h auslesen
        TempAussen24h = IEEE754_Hex32ToDez(Woerter[21]+ Woerter[20]+ Woerter[19]+ Woerter[18]);
        //Temp-Aussen-1h auslesen
        TempAussen1h = IEEE754_Hex32ToDez(Woerter[25]+ Woerter[24]+ Woerter[23]+ Woerter[22]);
        //Temp-Ruecklauf Soll auslesen
        TempRuecklaufSoll = IEEE754_Hex32ToDez(Woerter[29]+ Woerter[28]+ Woerter[27]+ Woerter[26]);
        //Temp-Ruecklauf IST auslesen
        TempRuecklaufIst = IEEE754_Hex32ToDez(Woerter[33]+ Woerter[32]+ Woerter[31]+ Woerter[30]);
        //Temp-Vorlauf auslesen
        TempVorlauf = IEEE754_Hex32ToDez(Woerter[37]+ Woerter[36]+ Woerter[35]+ Woerter[34]);
        //Temp-WW Soll auslesen
        TempWWSoll = IEEE754_Hex32ToDez(Woerter[41]+ Woerter[40]+ Woerter[39]+ Woerter[38]);
        //Temp-WW Ist auslesen
        TempWWIst = IEEE754_Hex32ToDez(Woerter[45]+ Woerter[44]+ Woerter[43]+ Woerter[42]);
        //Temp-Raum auslesen
        TempRaum = IEEE754_Hex32ToDez(Woerter[49]+ Woerter[48]+ Woerter[47]+ Woerter[46]);
        //Temp-Raum-1h auslesen
        TempRaum1h = IEEE754_Hex32ToDez(Woerter[53]+ Woerter[52]+ Woerter[51]+ Woerter[50]);
        //Temp-WQuelle-Ein
        TempWQuelleEin = IEEE754_Hex32ToDez(Woerter[57]+ Woerter[56]+ Woerter[55]+ Woerter[54]);
        //Temp-WQuelle-Aus
        TempWQuelleAus = IEEE754_Hex32ToDez(Woerter[61]+ Woerter[60]+ Woerter[59]+ Woerter[58]);
        //Temp-Verdampfer
        TempVerdampfer= IEEE754_Hex32ToDez(Woerter[65]+ Woerter[64]+ Woerter[63]+ Woerter[62]);
        //Temp-Kondensator
        TempKondensator = IEEE754_Hex32ToDez(Woerter[69]+ Woerter[68]+ Woerter[67]+ Woerter[66]);
        //Temp-Saugleitung
        TempSaugleitung = IEEE754_Hex32ToDez(Woerter[73]+ Woerter[72]+ Woerter[71]+ Woerter[70]);
        //Temp-frei
        Tempfrei = IEEE754_Hex32ToDez(Woerter[77]+ Woerter[76]+ Woerter[75]+ Woerter[74]);
        //Druck-Verdampfer
        DruckVerdampfer = IEEE754_Hex32ToDez(Woerter[81]+ Woerter[80]+ Woerter[79]+ Woerter[78])
        //Druck-Kondensator
        DruckKondensator = IEEE754_Hex32ToDez(Woerter[85]+ Woerter[84]+ Woerter[83]+ Woerter[82]);
        TempRuecklaufSoll = IEEE754_Hex32ToDez(Woerter[89]+ Woerter[88]+ Woerter[87]+ Woerter[86]);
        //Temp-Ruecklauf Ist
        TempRuecklaufIst = IEEE754_Hex32ToDez(Woerter[93]+ Woerter[92]+ Woerter[91]+ Woerter[90]);
        //Kuehlung Temp Ruecklauf Soll
        KuehlungTempRuecklaufSoll = IEEE754_Hex32ToDez(Woerter[97]+ Woerter[96]+ Woerter[95]+ Woerter[94]);
        //Kuehlung Temp Ruecklauf Ist
        KuehlungTempRuecklaufIst = IEEE754_Hex32ToDez(Woerter[101]+ Woerter[100]+ Woerter[99]+ Woerter[98]);
        //Warmwasser Temp Ist
        TempWWIst = IEEE754_Hex32ToDez(Woerter[105]+ Woerter[104]+ Woerter[103]+ Woerter[102]);
        //Zeit
        inp = Woerter[108];
        out =dezInt(out,2);
        Merker1 = out;
        inp = Woerter[107];
        out =dezInt(out,2);
        Merker2 = out;
        inp = Woerter[106];
        out =dezInt(out,2);
        Merker3 = out;
        Zeit = Merker1+ ":" +Merker2+ ":" +Merker3;
        //Datum
        inp = Woerter[109];
        out =dezInt(out,2);
        Merker1 = out;
        inp = Woerter[110];
        out =dezInt(out,2);
        Merker2 = out;
        inp = Woerter[111];
        out =dezInt(out,2);
        Merker3 = out;
        //Betriebsstunden Kompressor
        BetriebsstundenKompressor = IEEE754_Hex32ToDez(Woerter[115]+ Woerter[114]+ Woerter[113]+ Woerter[112]);
        //Betriebsstunden Heizung
        BetriebsstundenHeizung = IEEE754_Hex32ToDez(Woerter[119]+ Woerter[118]+ Woerter[117]+ Woerter[116]);
        //Betriebsstunden WW
        BetriebsstundenWW = IEEE754_Hex32ToDez(Woerter[123]+ Woerter[122]+ Woerter[121]+ Woerter[120]);
        //Betriebsstunden Stufe 2
        BetriebsstundenStufe2 = IEEE754_Hex32ToDez(Woerter[127]+ Woerter[126]+ Woerter[125]+ Woerter[124]);
        //BetriebsStunden MessZeit Kompressor
        inp = Woerter[128];
        out =dezInt(out,2);
        Merker1 = out;
        inp = Woerter[129];
        out =dezInt(out,2);
        Merker2 = out;
        inp = Woerter[130];
        out =dezInt(out,2);
        Merker3 = out;
        BetriebsStundenMessZeitKompressor = Merker1+ ":" +Merker2+ ":" +Merker3;
        //BetriebsStunden MessDatum Kompressor
        inp = Woerter[133];
        out =dezInt(out,2);
        Merker1 = out;
        inp = Woerter[132];
        out =dezInt(out,2);
        Merker2 = out;
        inp = Woerter[131];
        out =dezInt(out,2);
        Merker3 = out;
        BetriebsStundenMessDatumKompressor = Merker1+ "." +Merker2+ "." +Merker3;
        //BetriebsStunden MessZeit WPumpe
        inp = Woerter[134];
        out =dezInt(out,2);
        Merker1 = out;
        inp = Woerter[135];
        out =dezInt(out,2);
        Merker2 = out;
        inp = Woerter[136];
        out =dezInt(out,2);
        Merker3 = out;
        BetriebsStundenMessZeitWPumpe = Merker1+ ":" +Merker2+ ":" +Merker3;
        //BetriebsStunden MessDatum WPumpe
        inp = Woerter[139];
        out =dezInt(out,2);
        Merker1 = out;
        inp = Woerter[138];
        out =dezInt(out,2);
        Merker2 = out;
        inp = Woerter[137];
        out =dezInt(out,2);
        Merker3 = out;
        BetriebsStundenMessDatumWPumpe = Merker1+ "." +Merker2+ "." +Merker3;
        //BetriebsStunden Reset Kompressor
        inp = Woerter[140];
        BetriebsStundenResetKompressor = parseInt(inp,16);
        //BetriebsStunden Reset WPumpe
        inp = Woerter[141];
        BetriebsStundenResetWPumpe = parseInt(inp,16);
        //Kennwort
        inp = Woerter[142];
        Kennwort = parseInt(inp,16);
        //WerksEinstellungen
        inp = Woerter[143];
        WerksEinstellungen = parseInt(inp,16);
        //Reset WPumpe
        inp = Woerter[144];
        //Crc Summe
        inp = Woerter[145]+ Woerter[146];
        CrcSumme = parseInt(inp,16);
        //NStart
        inp = Woerter[147];
        NStart = parseInt(inp,16);
        //Display Zeile 1
        inp = Woerter[148]+ Woerter[149];
        DisplayZeile1 = parseInt(inp,16);
        //Display Zeile 2
        inp = Woerter[150];
        DisplayZeile2 = parseInt(inp,16);
        //AusfallTime
        inp = Woerter[153];
        out =dezInt(out,2);
        Merker1 = out;
        inp = Woerter[152];
        out =dezInt(out,2);
        Merker2 = out;
        inp = Woerter[151];
        out =dezInt(out,2);
        Merker3 = out;
        AusfallTime = Merker1+ ":" +Merker2+ ":" +Merker3;
        //Ausfalldatum
        inp = Woerter[154];
        out =dezInt(out,2);
        Merker1 = out;
        inp = Woerter[155];
        out =dezInt(out,2);
        Merker2 = out;
        inp = Woerter[156];
        out =dezInt(out,2);
        Merker3 = out;
        AusfallDate = Merker1+ "." +Merker2+ "." +Merker3;
        //Ausfall BetriebsZustaende.dec
        inp = Woerter[157];
        out = out.toString(2);
        AusfallBetriebsZustaende = dezInt(out,8)
        //Ausfall DoBuffer.dec
        inp = Woerter[158];
        AusfallDoBuffer = dezInt(out,8)
        //Bitauswertung Ausfall DoBuffer
        bitauswertung(158);
        AusfallDoMagnetventil = Bit1;
        AusfallDoKompressor1 = Bit2;
        AusfallDoBufferBit3 = Bit3;
        AusfallDoUmschaltventilKuehlung = Bit4;
        AusfallDoStufe2 = Bit5;
        AusfallDoPumpeHeizung = Bit6;
        AusfallDoPumpeWarmwasser = Bit7;
        AusfallDoPumpeQuelle = Bit8;
        //Ausfall DiBuffer.dec
        inp = Woerter[159];
        AusfallDiBuffer = dezInt(out,8)
        // Bitauswertung Ausfall DiBuffer
        bitauswertung (159);
        AusfallDiMotorschutzkompressor = Bit1;
        AusfallDiNiederdruckPressostat = Bit2;
        AusfallDiHochdruckPressostat = Bit3;
        AusfallDiPumpeQuelle = Bit4;
        AusfallDiSoleMinnimum = Bit5;
        AusfallDiBufferBit6 = Bit6;
        AusfallDiExterneSollwertbeeinflussung = Bit7;
        AusfallDiExterneAbschaltung = Bit8;
        //AusfallAiError.dec
        inp = Woerter[160];
        AusfallAiError = dezInt(out,8);
        //AusfallAiDi.dec
        inp = Woerter[161];
        AusfallAiDi = dezInt(out,8);
        //AusfallAiTempAussen
        AusfallAiTempAussen = IEEE754_Hex32ToDez(Woerter[165]+ Woerter[164]+ Woerter[163]+ Woerter[162]);
        //AusfallAiTempQuelleEin
        AusfallAiTempQuelleEin = IEEE754_Hex32ToDez(Woerter[169]+ Woerter[168]+ Woerter[167]+ Woerter[166]);
        //AusfallAiTempQuelleAus
        AusfallAiTempQuelleAus = IEEE754_Hex32ToDez(Woerter[173]+ Woerter[172]+ Woerter[171]+ Woerter[170]);
        //AusfallAiVerdampfung
        AusfallAiVerdampfung = IEEE754_Hex32ToDez(Woerter[177]+ Woerter[176]+ Woerter[175]+ Woerter[174]);
        //AusfallAiTempHeizEin
        AusfallAiTempHeizEin = IEEE754_Hex32ToDez(Woerter[181]+ Woerter[180]+ Woerter[179]+ Woerter[178]);
        //AusfallAiTempHeizAus
        AusfallAiTempHeizAus = IEEE754_Hex32ToDez(Woerter[185]+ Woerter[184]+ Woerter[183]+ Woerter[182]);
        //AusfallAiKondensation
        AusfallAiKondensation = IEEE754_Hex32ToDez(Woerter[189]+ Woerter[188]+ Woerter[187]+ Woerter[186]);
        //AusfallAiTempWWasser
        AusfallAiTempWWasser = IEEE754_Hex32ToDez(Woerter[193]+ Woerter[192]+ Woerter[191]+ Woerter[190]);
        //AusfallAuxAiError.dec
        inp = Woerter[194];
        AusfallAuxAiError = dezInt(out,8);
        //AusfallAuxAiDi.dec
        inp = Woerter[195];
        AusfallAuxAiDi = dezInt(out,8);
        //AusfallAiTempRaum
        AusfallAiTempRaum = IEEE754_Hex32ToDez(Woerter[199]+ Woerter[198]+ Woerter[197]+ Woerter[196]);
        //ClearAusfaelle
        inp = Woerter[200];
        ClearAusfaelle = out
        //Unterbrechung.dec
        inp = Woerter[201];
        Unterbrechung = dezInt(out,8);
        //WarnungEingangsSeite.dec
        inp = Woerter[202];
        WarnungEingangsSeite = dezInt(out,8);
        //Bitauswertung WarnungEingangsSeite.dec
        bitauswertung(202);
        VerdampfungstemperaturNiedrig = Bit1;
        TempQuelleAustrittNiedrig = Bit2;
        DiffQuelleEinQuelleAusHoch = Bit3;
        DiffQuelleAusVerdampfungHoch = Bit4;
        //WarnungAusgangsSeite.dec
        inp = Woerter[203];
        WarnungAusgangsSeite = dezInt(out,8);
        //Bitauswertung WarnungAusgangsSeite.dec
        bitauswertung(203);
        KondensationstemperaturHoch = Bit2;
        DiffHzgVorlaufRuecklaufNiedrig = Bit3;
        DiffHzgVorlaufRuecklaufHoch = Bit4;
        DiffKondensationVorlaufHoch = Bit6;
        //WarnungSonstige.dec
        inp = Woerter[204];
        WarnungSonstige = dezInt(out,8);
        //Bitauswertung WarnungSonstige.dec
        bitauswertung(204);
        HzgRuecklauffuehlerdefekt = Bit1;
        HzgVorlauffuehlerdefekt = Bit2;
        Aussenwandfuehlerdefekt = Bit3;
        DoBufferHandstellung = Bit4;
        SolestandMinimum = Bit5;
        //Ausfall.dec
        inp = Woerter[205];
        Ausfall = dezInt(out,8);
        //AiError.dec
        inp = Woerter[206];
        //AiDi.dec
        inp = Woerter[207];
        //AiCounter0
        inp = Woerter[208]+ Woerter[209];
        AiCounter0 = out;
        //AuxAiError.dec
        inp = Woerter[210];
        //AuxAiDi.dec
        inp = Woerter[211];
        //BetriebsZustaende.dec
        inp = Woerter[212];
        BetriebsZustaende = dezInt(out,8);
        //DoBuffer.dec
        inp = Woerter[213];
        DoBuffer = dezInt(out,8);
        //Bitauswertung DoBuffer
        bitauswertung(213);
        DoSammelstoermeldung = Bit3;
        DoStufe2 = Bit5;
        //DiBuffer.dec
        inp = Woerter[214];
        DiBuffer = dezInt(out,8);
        //Bitauswertung DiBuffer
        bitauswertung(214);
        //GesStatus
        inp = Woerter[215];
        Merker1 = dezInt(out,8);
        inp = Woerter[216];
        Merker2 = dezInt(out,8);
        GesStatus = Merker1+ "&nbsp;" +Merker2;
        //StatusVerriegelung
        inp = Woerter[217];
        inp = Woerter[218];
        StatusVerriegelung = Merker1+ "&nbsp;" +Merker2;
        //StatusHeiz
        inp = Woerter[219];
        inp = Woerter[220];
        StatusHeiz = Merker1+ "&nbsp;" +Merker2;
        //StatusKuehl
        inp = Woerter[221];
        inp = Woerter[222];
        StatusKuehl = Merker1+ "&nbsp;" +Merker2;
        //StatusStufe2
        inp = Woerter[223];
        inp = Woerter[224];
        StatusStufe2 = Merker1+ "&nbsp;" +Merker2;
        //StatusWWasser
        inp = Woerter[225];
        inp = Woerter[226];
        StatusWWasser = Merker1+ "&nbsp;" +Merker2;
        //StatusWPumpe
        inp = Woerter[227];
        inp = Woerter[228];
        StatusWPumpe = Merker1+ "&nbsp;" +Merker2;
        //ModeHeiz.dec
        inp = Woerter[229];
        ModeHeiz = dezInt(out,8);
        //Bitauswertung ModeHeizung
        bitauswertung(229);
        ModeHeizEINNormal = Bit1;
        ModeHeizEINSolar = Bit2;
        ModeHeizEinextAnhebung = Bit3;
        ModeHeizEINSchnellaufheidzung = Bit4;
        ModeHeizAUSZeitprogramm = Bit5;
        ModeHeizAUSUnterdrueckung = Bit6;
        ModeHeizAUSkeinBedarf = Bit7;
        ModeHeizAUSwFuehlerf = Bit8;
        //ModeKuehl.dec
        inp = Woerter[230];
        ModeKuehl = dezInt(out,8);
        //Bitauswertung ModeKuehlen
        bitauswertung(230);
        ModeKuehlEINNormal = Bit1;
        ModeKuehlAUS = Bit2;
        ModeKuehlAUSUnterdrueckung = Bit3;
        ModeKuehlAUSkeinBedarf = Bit4;
        ModeKuehlAUSUnterbrechwFuehlerf = Bit5;
        //ModeWWasser
        inp = Woerter[231];
        ModeWWasser = dezInt(out,8);
        //Bitauswertung ModeWWasser
        bitauswertung(231);
        ModeWWassserINNormal = Bit1;
        ModeWWasserEINSolar = Bit2;
        ModeWWasserAUSZeitprogramm = Bit3;
        ModeWWasserAUSkeinBedarf = Bit4;
        ModeWWasserAUSUnterbrwFuehlerf = Bit5;
        ModeWWasserAUSUnterdrueckung = Bit6;
        ModeWWasserSolar = Bit7;
        ModeWWasserAUSSolarNutzung = Bit8;
        //LoggerError
        inp = Woerter[232];
        LoggerError = out;
        //LoggerInitTime
        inp = Woerter[235];
        out =dezInt(out,2);
        Merker1 = out;
        inp = Woerter[234];
        out =dezInt(out,2);
        Merker2 = out;
        inp = Woerter[233];
        out =dezInt(out,2);
        Merker3 = out;
        LoggerInitTime = Merker1+ ":" +Merker2+ ":" +Merker3;
        //LoggerInitDate
        inp = Woerter[236];
        out =dezInt(out,2);
        Merker1 = out;
        inp = Woerter[237];
        out =dezInt(out,2);
        Merker2 = out;
        inp = Woerter[238];
        out =dezInt(out,2);
        Merker3 = out;
        LoggerInitDate = Merker1+ "." +Merker2+ "." +Merker3;
        //LoggerMaxRec
        inp = Woerter[239]+ Woerter[240];
        LoggerMaxRec = out;
        //LoggerActRec
        inp = Woerter[241]+ Woerter[242];
        LoggerActRec = out;
        //LoggerMaxActRec
        inp = Woerter[243]+ Woerter[244];
        LoggerMaxActRec = out;
        //LoggerSizeOfData
        inp = Woerter[245]+ Woerter[246];
        LoggerSizeOfData = out;
        //LoggerSizeOfDatenLoggerBuffer
        inp = Woerter[247]+ Woerter[248];
        LoggerSizeOfDatenLoggerBuffer = out;
        //Handabschaltung
        inp = Woerter[249];
        Handabschaltung = out;
        //Hzg Einsatzzeitpunkt Sollwert
        //HzgEinsatzzeitpunktSollwert = IEEE754_Hex32ToDez(Woerter[253]+ Woerter[252]+ Woerter[251]+ Woerter[250]);
        //Hzg Ruecklauf Sollwert am Einsatzp.
        //HzgRuecklaufSollwertamEinsatzp = IEEE754_Hex32ToDez(Woerter[257]+ Woerter[256]+ Woerter[255]+ Woerter[254]);
        //Heizkennline Steigung Soll
        //HeizkennlineSteigungSoll = IEEE754_Hex32ToDez(Woerter[261]+ Woerter[260]+ Woerter[259]+ Woerter[258]);
        //Heizkennline Obere Begrenzung
        //HeizkennlineObereBegrenzung = IEEE754_Hex32ToDez(Woerter[265]+ Woerter[264]+ Woerter[263]+ Woerter[262]);
        //Heizung - Sollwertanhebung 4k fuer 24 Stunden
        inp = Woerter[266];
        HeizgSollwertanhebung4kfuer24h = out
        //Pilotraum Sollwert
        //PilotraumSollwert = IEEE754_Hex32ToDez(Woerter[270]+ Woerter[269]+ Woerter[268]+ Woerter[267]);
        //Pilotraum Faktor
        inp = Woerter[271];
        PilotraumFaktor = out;
        //Externe Anhebung
        //ExterneAnhebung = IEEE754_Hex32ToDez(Woerter[275]+ Woerter[274]+ Woerter[273]+ Woerter[272]);
        //Freigabe Heizung
        inp = Woerter[278];
        Merker1 = out;
        inp = Woerter[277];
        Merker2 = out;
        inp = Woerter[276];
        Merker3 = out;
        FreigabeHeizung = Merker1+ ":" +Merker2+ ":" +Merker3;
        //Sperren Heizung
        inp = Woerter[281];
        Merker1 = out;
        inp = Woerter[280];
        Merker21 = out;
        inp = Woerter[279];
        Merker3 = out;
        SperrenHeizung = Merker1+ ":" +Merker2+ ":" +Merker3;
        //Sollwertaenderung Ein
        inp = Woerter[284];
        Merker1 = out;
        inp = Woerter[283];
        Merker2 = out;
        inp = Woerter[282];
        Merker3 = out;
        SollwertaenderungEin = Merker1+ ":" +Merker2+ ":" +Merker3;
        //Sollwertaenderung Aus
        inp = Woerter[287];
        Merker1 = out;
        inp = Woerter[286];
        Merker2 = out;
        inp = Woerter[285];
        Merker3 = out;
        SollwertaenderungAus = Merker1+ ":" +Merker2+ ":" +Merker3;
        //Stufe 2 Kl. Obere Begrenzung
        //St2KlObereBegrenzung = IEEE754_Hex32ToDez(Woerter[291]+ Woerter[290]+ Woerter[289]+ Woerter[288]);
        //Kennlinie Hysterese
        //KennlinieHysterese = IEEE754_Hex32ToDez(Woerter[295]+ Woerter[294]+ Woerter[293]+ Woerter[292]);
        //Pumpen Nachlaufzeit
        inp = Woerter[296];
        PumpenNachlaufzeit = out;
        //Abschaltung Heizung
        inp = Woerter[297];
        AbschaltungHeizung = out;
        //Kuehlung Einsatzzeitpunkt
        //KuehlungEinsatzzeitpunkt = IEEE754_Hex32ToDez(Woerter[301]+ Woerter[300]+ Woerter[299]+ Woerter[298]);
        //Ruecklauftemp. Sollwert am Einsatzzeitp.
        //RuecklauftempSollwertamEinsatzzeitp = IEEE754_Hex32ToDez(Woerter[305]+ Woerter[304]+ Woerter[303]+ Woerter[302]);
        //Kuehlung Kennlinie Steigung Soll
        //KuehlungKennlinieSteigungSoll = IEEE754_Hex32ToDez(Woerter[309]+ Woerter[308]+ Woerter[307]+ Woerter[306]);
        //Kennlinie untere Begrenzung
        //KennlinieuntereBegrenzung = IEEE754_Hex32ToDez(Woerter[313]+ Woerter[312]+ Woerter[311]+ Woerter[310]);
        //Abschaltung Warmwasser
        inp = Woerter[314];
        AbschaltungWW = out;
        //Warmwasser Zeit ein
        inp = Woerter[317];
        Merker1 = out;
        inp = Woerter[316];
        Merker2 = out;
        inp = Woerter[315];
        Merker3 = out;
        WWZeitEin = Merker1+ ":" +Merker2+ ":" +Merker3;
        //Warmwasser Zeit aus
        inp = Woerter[320];
        Merker1 = out;
        inp = Woerter[319];
        Merker2 = out;
        inp = Woerter[318];
        Merker3 = out;
        WWZeitAus = Merker1+ ":" +Merker2+ ":" +Merker3;
        //Warmwasser Soll
        //WWSoll = IEEE754_Hex32ToDez(Woerter[324]+ Woerter[323]+ Woerter[322]+ Woerter[321]);
        //Beckenwasser Temperatur Soll
        //BeckenwasserTempSoll = IEEE754_Hex32ToDez(Woerter[328]+ Woerter[327]+ Woerter[326]+ Woerter[325]);
        //Warmwasser Hysterese
        //WarmwasserHysterese = IEEE754_Hex32ToDez(Woerter[332]+ Woerter[331]+ Woerter[330]+ Woerter[329]);
        //Beckenwasser Hysterese
        //BeckenwasserHysterese = IEEE754_Hex32ToDez(Woerter[336]+ Woerter[335]+ Woerter[334]+ Woerter[333]);
        //Modem Klingelzeichen
        inp = Woerter[337];
        ModemKlingelzeichen = out;
        //Fremdzugriff
        inp = Woerter[338];
        Fremdzugriff = out;
        //Schluesselnummer
        inp = Woerter[339];
        Schluesselnummer = out;
        //SetBetriebsMode
        inp = Woerter[340];
        Merker1 = out;
        inp = Woerter[341];
        Merker2 = out;
        inp = Woerter[342];
        Merker3 = out;
        SetBetriebsMode = Merker1+ "." +Merker2+ "." +Merker3;
        //Hzg: Externe Freigabe
        inp = Woerter[343];
        HzgExterneFreigabe = out;
        //Hzg: Externe Ruecklaufsteuerung
        //HzgExterneRuecklaufsteuerung = IEEE754_Hex32ToDez(Woerter[347]+ Woerter[346]+ Woerter[345]+ Woerter[344]);
        //St2: TempQAus < Min
        //St2TempQAusMin = IEEE754_Hex32ToDez(Woerter[351]+ Woerter[350]+ Woerter[349]+ Woerter[348]);
        //St2: TempVerd < Min
        //St2TempVerdMin = IEEE754_Hex32ToDez(Woerter[355]+ Woerter[354]+ Woerter[353]+ Woerter[352]);
        //Estrich Aufheizen
        inp = Woerter[356];
        EstrichAufheizen = out;
        //Hzg: Externe Steuerung
        inp = Woerter[357];
        HzgExterneSteuerung = out;
        //St2 bei EVU Absch.
        inp = Woerter[358];
        St2beiEVUAbsch = out;
        //Frg. Beckenwasser
        inp = Woerter[359];
        FrgBeckenwasser = out;
        //Scale Faktor
        //ScaleFaktor = IEEE754_Hex32ToDez(Woerter[363]+ Woerter[362]+ Woerter[361]+ Woerter[360]);
        //Offset Niederdr.
        //OffsetNiederdr = IEEE754_Hex32ToDez(Woerter[367]+ Woerter[366]+ Woerter[365]+ Woerter[364]);
        //Offset Hochdr.
        //OffsetHochdr = IEEE754_Hex32ToDez(Woerter[371]+ Woerter[370]+ Woerter[369]+ Woerter[368]);
        //DO-Handkanal
        inp = Woerter[372];
        DoHandkanal = out
        //DO-Handkanal Ein
        inp = Woerter[373];
        DoHandkanalEin = out;
        //Unterdrückung Warnmeldungen Eingänge
        inp = Woerter[374];
        UnterdrWarnEin = dezInt(out,8);
        //Unterdrückung Warnmeldungen Ausgänge
        inp = Woerter[375];
        UnterdrWarnAus = dezInt(out,8);
        //Unterdrückung Warnmeldungen Sonstige
        inp = Woerter[376];
        UnterdrWarnSonst = dezInt(out,8);
        //Neu-Start
        inp = Woerter[377];
        NeuStart = out;
        //Run-Flag
        inp = Woerter[378];
        RunFlag = out;
        console.log('Temp aussen ist:' + TempAussenIst);
        setState('Waterkotte.Daten.Version', VersionsNr);
        setState('Waterkotte.Daten.Temp_Aussen_Ist', TempAussenIst);
        setState('Waterkotte.Daten.Temp_Aussen_24h', TempAussen24h);
        setState('Waterkotte.Daten.Temp_Aussen_1h', TempAussen1h);
        setState('Waterkotte.Daten.Temp_Ruecklauf_Soll', TempRuecklaufSoll);
        setState('Waterkotte.Daten.Temp_Ruecklauf_Ist', TempRuecklaufIst);
        setState('Waterkotte.Daten.Temp_Vorlauf', TempVorlauf);
        setState('Waterkotte.Daten.Temp_WW_Soll', TempWWSoll);
        setState('Waterkotte.Daten.Temp_WW_Ist', TempWWIst);
        setState('Waterkotte.Daten.Temp_Raum', TempRaum);
        setState('Waterkotte.Daten.Temp_Raum_1h', TempRaum1h);
        setState('Waterkotte.Daten.Temp_WQuelle_Ein', TempWQuelleEin);
        setState('Waterkotte.Daten.Temp_WQuelle_Aus', TempWQuelleAus);
        setState('Waterkotte.Daten.Temp_Verdampfer', TempVerdampfer);
        setState('Waterkotte.Daten.Temp_Kondensator', TempKondensator);
        setState('Waterkotte.Daten.Temp_Saugleitung', TempSaugleitung);
        setState('Waterkotte.Daten.Temp_frei', Tempfrei);
        setState('Waterkotte.Daten.Druck_Verdampfer', DruckVerdampfer);
        setState('Waterkotte.Daten.Druck_Kondensator', DruckKondensator);
        setState('Waterkotte.Daten.Status_Heizung', StatusHeiz);
        setState('Waterkotte.Daten.Status_Handabschaltung',Handabschaltung);
        setState('Waterkotte.Daten.Status_Warmwasser', StatusWWasser);
        setState('Waterkotte.Daten.Status_WPumpe', StatusWPumpe);
        setState('Waterkotte.Daten.Mode_Heizung', ModeHeiz);
        setState('Waterkotte.Daten.Mode_Heizung_EIN_Normal', ModeHeizEINNormal);
        setState('Waterkotte.Daten.Mode_Heizung_EIN_Solar', ModeHeizEINSolar);
        setState('Waterkotte.Daten.Mode_Heizung_EIN_externe_Anhebung', ModeHeizEinextAnhebung);
        setState('Waterkotte.Daten.Mode_Heizung_EIN_Schnellaufheizung', ModeHeizEINSchnellaufheidzung);
        setState('Waterkotte.Daten.Mode_Heizung_AUS_Zeitprogramm', ModeHeizAUSZeitprogramm);
        setState('Waterkotte.Daten.Mode_Heizung_AUS_Unterdrueckung', ModeHeizAUSUnterdrueckung);
        setState('Waterkotte.Daten.Mode_Heizung_AUS_kein_Bedarf', ModeHeizAUSkeinBedarf);
        setState('Waterkotte.Daten.Mode_Heizung_AUS_wegen_Fuehlerfehler', ModeHeizAUSwFuehlerf);
        setState('Waterkotte.Daten.Mode_Warmwasser', ModeWWasser);
        setState('Waterkotte.Daten.Mode_Warmwasser_EIN_Normal', ModeWWassserINNormal);
        setState('Waterkotte.Daten.Mode_Warmwasser_EIN_Solar', ModeWWasserEINSolar);
        setState('Waterkotte.Daten.Mode_Warmwasser_AUS_Zeitprogramm', ModeWWasserAUSZeitprogramm);
        setState('Waterkotte.Daten.Mode_Warmwasser_AUS_kein_Bedarf', ModeWWasserAUSkeinBedarf);
        setState('Waterkotte.Daten.Mode_Warmwasser_AUS_Unterbrechung_wegen_Fuehlerfehler', ModeWWasserAUSUnterbrwFuehlerf);
        setState('Waterkotte.Daten.Mode_Warmwasser_AUS_Unterdrueckung', ModeWWasserAUSUnterdrueckung);
        setState('Waterkotte.Daten.Mode_Warmwasser_Solar', ModeWWasserSolar);
        setState('Waterkotte.Daten.Mode_Warmwasser_AUS_Solarnutzung', ModeWWasserAUSSolarNutzung);
        setState('Waterkotte.Daten.Mode_Kuehlung_EIN_Normal', ModeKuehlEINNormal);
        setState('Waterkotte.Daten.Mode_Kuehlung_AUS', ModeKuehlAUS);
        setState('Waterkotte.Daten.Mode_Kuehlung_AUS_Unterbrechung', ModeKuehlAUSUnterdrueckung);
        setState('Waterkotte.Daten.Mode_Kuehlung_AUS_kein_Bedarf', ModeKuehlAUSkeinBedarf);
        setState('Waterkotte.Daten.Mode_Kuehlung_AUS_Unterbrechung_wegen_Fuehlerfehler', ModeKuehlAUSUnterbrechwFuehlerf);
        setState('Waterkotte.Daten.DI_Motorschutz_Kompressor', DiMotorschutzkompressor);
        setState('Waterkotte.Daten.DI_Niederdruck_Pressostat', DiNiederdruckPressostat);
        setState('Waterkotte.Daten.DI_Hochdruck_Pressostat', DiHochdruckPressostat);
        setState('Waterkotte.Daten.DI_Pumpe_Quelle', DiPumpeQuelle);
        setState('Waterkotte.Daten.DI_Externe_Sollwertbeeinflussung', DiExterneSollwertbeeinflussung);
        setState('Waterkotte.Daten.DI_Externe_Abschaltung', DiExterneAbschaltung);
        setState('Waterkotte.Daten.DO_Magnetventil', DoMagnetventil);
        setState('Waterkotte.Daten.DO_Kompressor1', DoKompressor1);
        setState('Waterkotte.Daten.DO_Sammelstoermeldung', DoSammelstoermeldung);
        setState('Waterkotte.Daten.DO_Umschaltventil_Kuehlung', DoUmschaltventilKuehlung);
        setState('Waterkotte.Daten.DO_Umschaltventil_Stufe2', DoStufe2);
        setState('Waterkotte.Daten.DO_Umschaltventil_Pumpe_Heizung', DoPumpeHeizung);
        setState('Waterkotte.Daten.DO_Umschaltventil_Pumpe_Warmwasser', DoPumpeWarmwasser);
        setState('Waterkotte.Daten.DO_Umschaltventil_Pumpe_Quelle', DoPumpeQuelle);
        Blockly Script zum Starten/Stoppen der Abfrage, ist immer aktiv:
         <variables>
           <variable type="cron" id="schedule1">schedule1</variable>
         </variables>
         <block type="schedule_create" id="U^a/a|R.Ag0SUHC5`R_X" x="-512" y="-63">
           <field name="NAME">schedule1</field>
           <value name="SCHEDULE">
             <shadow type="field_cron" id="RoVW,)EZwML}A7XD8Xc/">
               <field name="CRON">12 */3 * * * *</field>
             <block type="debug" id=";E~}`cmu%ZUC50DV#p?Y">
               <value name="TEXT">
                 <shadow type="text" id="0w!y-Pmlm,f`O0?~@jC@">
                   <field name="TEXT">Abfrage_Waterkotte</field>
                 <block type="controls_if" id="WEoLFzJ0#-xub!Bwhv~H">
                     <block type="logic_operation" id="%[579SWxQ72Thpq|e}II" inline="false">
                       <field name="OP">AND</field>
                         <block type="logic_compare" id=";I2G)sOC7K3E#aG*1^{n">
                           <field name="OP">EQ</field>
                             <block type="get_value" id="2wot(2t*g8UEm.+2pLu@">
                               <field name="OID">javascript.2.scriptEnabled.Waterkotte.Abfrage_Waterkotte_Test</field>
                             <block type="logic_boolean" id="/w]{^LZ9,e*gI5Na*=AX">
                         <block type="logic_operation" id="DFqv1XTuf5Jcd6~d4Pl9">
                             <block type="logic_compare" id="Q%hn`r~GuwSiW|`lwXy4">
                                 <block type="get_value" id="=gAZ0qIl%Q2=a)w=}wsm">
                                   <field name="OID">javascript.2.scriptEnabled.Waterkotte.WW_Temp_45</field>
                                 <block type="logic_boolean" id="z(f3588pY)X5T1JY`L}o">
                             <block type="logic_compare" id="QF-a*[%R+[u!Z(LIu]Nj">
                                 <block type="get_value" id="`P_T2QF-wSoJ!ZJN0:^y">
                                   <field name="OID">javascript.2.scriptEnabled.Waterkotte.WW_Temp_60</field>
                                 <block type="logic_boolean" id="nI4s86@mVMZfHAb+k9u+">
                     <block type="debug" id="-twd|JK7:Q5Q6+M2lTmO">
                       <value name="TEXT">
                         <shadow type="text" id="e+uKa0:h7S7tL{x@5ZIM">
                           <field name="TEXT">Aktiviere Abfrage Waterkotte</field>
                         <block type="control" id="Hh@%xY%GsRI1g208b7ce">
                             <block type="logic_boolean" id="dJ]azVd7r~N1IN8Wdlr-">
                             <block type="control" id="S[V15.2;~h|N4vnsb3J0">
                               <field name="DELAY_MS">3</field>
                                 <block type="logic_boolean" id="c`7aVan7RyUsJ=0=)={!">
        So sieht das im log bei mir aus:
        javascript.2	2020-11-11 17:39:15.061	info	(24856) script.js.Waterkotte.Abfrage_Waterkotte_Test: port closed
        javascript.2	2020-11-11 17:39:15.059	info	(24856) Stop script script.js.Waterkotte.Abfrage_Waterkotte_Test
        javascript.2	2020-11-11 17:39:12.527	info	(24856) script.js.Waterkotte.Auswertung_Waterkotte: Temp aussen ist:12.57
        javascript.2	2020-11-11 17:39:12.522	info	(24856) script.js.Waterkotte.Auswertung_Waterkotte: Daten split:1fbe
        javascript.2	2020-11-11 17:39:12.521	info	(24856) script.js.Waterkotte.Auswertung_Waterkotte: Daten split: ff 10 02 00 17 1f be 12 0c 06 03 05 29 a8 2b 49 41 17 4c 4c 41 3d 4d 53 41 2b 5d a5 41 4a a4 c1 41 69 8e d4 41 23 00 34 42 8e 8d 35 42
        javascript.2	2020-11-11 17:39:12.519	info	(24856) script.js.Waterkotte.Auswertung_Waterkotte: Daten:ff100200171fbe120c06030529a82b4941174c4c413d4d53412b5da5414aa4c141698ed441230034428e8d35425238dec200007041f919e540c5cf08419e970641dc93c841000
        javascript.2	2020-11-11 17:39:12.509	info	(24856) script.js.Waterkotte.Abfrage_Waterkotte_Test: Data received: ff100200171fbe120c06030529a82b4941174c4c413d4d53412b5da5414aa4c141698ed441230034428e8d35425238dec200007041f919e540c5cf08419e970641
        javascript.2	2020-11-11 17:39:12.160	info	(24856) script.js.Waterkotte.Abfrage_Waterkotte_Test: Daten send
        javascript.2	2020-11-11 17:39:12.153	info	(24856) script.js.Waterkotte.Abfrage_Waterkotte_Test: Connected
        javascript.2	2020-11-11 17:39:12.147	info	(24856) script.js.Waterkotte.Abfrage_Waterkotte_Test: registered 0 subscriptions and 0 schedules
        javascript.2	2020-11-11 17:39:12.085	info	(24856) Start javascript script.js.Waterkotte.Abfrage_Waterkotte_Test
        javascript.2	2020-11-11 17:39:12.016	info	(24856) script.js.Waterkotte.Restart_Abfrage_Waterkotte_Test: Aktiviere Abfrage Waterkotte
        javascript.2	2020-11-11 17:39:12.014	info	(24856) script.js.Waterkotte.Restart_Abfrage_Waterkotte_Test: Abfrage_Waterkotte
        So sehen die DP's aus:
        Axel Koeneke 1 Reply Last reply Reply Quote 0
        • Axel Koeneke
          Axel Koeneke @wendy2702 last edited by
          @wendy2702 Moin, es finktioniert leider immer noch nicht.
          Beim Blockly habe ich mal die UND-Verknüpfung entfernt. Vermutlich hast du da noch ein anderes Script mit drin.
          Die Instanzen habe ich überall bei mir auf ".0." gesetzt.
          Beim Aufruf musste ich das Abfrage-Script unter .common. ansprechen.
          Ich vermute ganz stark das an der Schnittstelle liegt. Kann ich die irgendwie unter iO prüfen?
          VG
          Axel
          • Axel Koeneke
            Axel Koeneke @Axel Koeneke last edited by
            @Axel-Koeneke Juhu, habe es gefunden:
            Schnittstelle hat mich auf die Idee gebracht mal meine Instanzen zu checken.
            Das Problem war der Multihost Modus. Dies hatte ich dato noch nie berücksichtigen müssen.
            Also habe ich einen zweiten JS-Adapter installiert und dazu noch eine Instanz. Beides dem Client zugewiesen und dann noch den Scripten gesagt das sie auf dem Client laufen sollen. Evtl. sollte man die Doku dazu nochmal erweitern.
            Vielen Dank für das geile Script. Werde meine Visu demnächst mal posten.
            VG
            Axel
            • wendy2702
              @Axel-Koeneke Sorry... hättest du das mit dem Multihost mal erwähnt wären wir der Sache schneller auf die Schliche gekommen.
              Aber nun ist ja gut.
              Bin mal auf deine Visu gespannt.
              • Axel Koeneke
                @wendy2702 Moin, leider habe noch ein kleines Problem: Die Werte wurden nur einmal übertragen. Ich sehe auch im Log keinen Fehler... Muss ich am Wochenende noch mal in Ruhe drüber schauen.
                Hier mal ein Screenshot:
                Ich kann morgen auch mal die View hochladen.
                VG
                Axel
                • wendy2702
                  @Axel-Koeneke was heißt immer nur einmal?
                  Ablauf bei mir ist so:
                  Das Blockly Script aktiviert das Abfrage Script, nach 3 Sekunden wird es wieder deaktiviert damit der Com Port geschlossen wird. Langer string wird ausgelesen und vom auswerte Script entschlüsselt.
                  Nach 3 Minuten beginnt das von vorne.
                  Das die Werte nur einmal ausgelesen werden könnte daran liegen das der COM Port noch geschlossen wird. Das hatte ich zu Beginn als ich das anfrage Script per Cron gestartet/gestoppt hatte.
                  • Axel Koeneke
                    @wendy2702 sagte in Script Hilfe für Abfrage Serielle Kommunikation gesucht!:
                    Ich werde es morgen testen. Was mir noch aufgefallen ist, sehe ich auch den Status der Pumpe?
                    Vielleicht erkenne ich es auch nicht, weil ich ja aktuell keine Änderung habe...
                    • wendy2702
                      @Axel-Koeneke gibt zwei DP's für Pumpe. Ich meine die Verändern sich auch bei mir je nach Status.
                      • Axel Koeneke
                        @wendy2702 Moin, läuft jetzt alles richtig gut. Abfrage machen ich alle 30 sek. Ich habe noch im Intervall Blockly einen zusätzlichen Datenpunkt für die Warmwasserpumpe erstellt. Außerdem färbe ich die Rohrleitung hinter dem 3-Wege-Ventil ein, damit ich sehe ob gerade Heizung oder Warmwassererzeugung läuft.
                        Dies habe ich schon lange vermisst, da ich in drei Kellerräumen Kovektorheizkörper habe, welche an der Wärmepumpe hängen und die Wärme mittels Ventilator abgeben. Wenn der Ventilator läuft, aber die WP keine Wärme erzeugt, bläst das eher unangenehm in den Raum. Jetzt kann ich bei Bedarf und wenn die WP auf Heizbetrieb ist, mittels Funksteckdose die Gebläse zuschalten.
                        Hier die View:
                        Waermepumpe.txt
                        Die Grafik als svg - Bitte Endung anpassen.
                        Waterkotte.svg.txt
                        VG
                        Axel
                        wendy2702 2 Replies Last reply Reply Quote 0
                        • wendy2702
                          wendy2702 @Axel Koeneke last edited by wendy2702
                          @Axel-Koeneke Hi, kannst du mir sagen welche Widget Sätze du für den View verwendet hast und wo du das SVG abgelegt hast?
                          Und wieso hast du eine SVG Grafik hochgeladen? Laut deinem View Export benutzt du eine "png" ?
                          Wenn ich die SVG im Widget auswähle passen die Seitenverhältnisse nicht.
                          Kannst du das Bild bitte nochmal hochladen. Irgendwie kann ich das nur mit einem Browser öffnen und dann ist ein Teil davon abgeschnitten.
                          Danke!
                          • Axel Koeneke
                            @wendy2702 Moin, ich benutze fast ausschließlich die InvenTwo Widgets.
                            In der View hast du richtig erkannt benutze ich die PNG Grafik. Die SVG habe ich hochgeladen, damit du sie z.B. mit Inkscape nach deinen Bedürfnissen anpassen kannst. Dazu einfach das ".TXT" an Ende entfernen und mit Inkscape bearbeiten. Ich werde mal mein Projekt aufräumen (Grafiken in vernünftige Ordnerstrukturen packen) und kann ich es als Projekt hochladen.
                            VG
                            Axel
                            • wendy2702
                              @axel-koeneke sagte in Script Hilfe für Abfrage Serielle Kommunikation gesucht!:
                              kannst du mir das mal kurz zeigen.
                              • Axel Koeneke
                                Axel Koeneke @wendy2702 last edited by Axel Koeneke
                                Ich habe das zusammen mit dem Soll-, Istwert des Homematic Thermostaten gekoppelt.
                                Außerdem soll das nur passieren, wenn der PC in dem Raum läuft (IP)
                                • wendy2702
                                  @axel-koeneke Hallo Axel,
                                  Danke für die Antwort aber ich glaube wir haben uns missverstanden.
                                  Du hast geschrieben das zu einen Datenpunkt erstellt hast, dein Blockly zeigt aber nur wie du nach Zeitplan etwas steuerst.
                                  Icn deinem View benutzt du hier:
                                  In dem Widget das den Grünen Kreis einblendet diesen DP:
                                  Diesen Datenpunkt gibt es aber bei mir nicht und ich wollte wissen wie du diesen erstellt hast bzw. welcher wert aus den Rohdaten den befüllt.
                                  Danke und Gruß
                                  • Axel Koeneke
                                    @wendy2702 Okay siehe hier:
                                    • wendy2702
                                      @axel-koeneke Danke!
                                        etzeste13 @wendy2702 last edited by
                                        @wendy2702
                                        Hallo, dieser Post sieht sehr interessant aus, habe auch eine Waterkotte mit Resümat4 Steuerung im Betrieb und würde die Steuerung gerne in den ioBroker übernehmen. Eine grundlege Frage habe ich zu eurer Lösung: Ist mit eurer Lösung nur das Auslesen des aktuellen Status der WP möglich, oder könnt Ihr auch Sollwerte, wie die Basistemperatur oder WW-Temperatur ändern?
                                        vG
                                        Etze
                                        • wendy2702
                                          wendy2702 @etzeste13 last edited by
                                          @etzeste13
                                          Sollwerte schreiben geht auch. Wegen Belegung der COM Schnittstelle minimal aufwendiger.
                                          Ich ändere zum Beispiel in Abhängigkeit von der PV Erzeugung die Wassertemperatur um Energie im Warmwasser zu speichern.
                                          • AlCalzone
                                            AlCalzone Developer @Axel Koeneke last edited by
                                            Warum streicht es das Buffer durch?
                                            Der Konstruktor new Buffer ist deprecated. Stattdessen sollte Buffer.from verwendet werden:
                                            https://nodejs.org/api/buffer.html#buffer_new_buffer_array
                                            192
                                            23302
