    4. [Beendet] Test Adapter ecovacs-deebot v0.6.x Latest
      ChrisXY @stefande last edited by ChrisXY
      Hab nun auch massiv Probleme das er keine Befehle mehr annimmt .. der APP geht es jederzeit
      covacs-deebot.0	2020-11-18 15:01:48.846	info	(23887) Terminated (NO_ERROR): Without reason
      ecovacs-deebot.0	2020-11-18 15:01:48.845	info	(23887) terminating
      ecovacs-deebot.0	2020-11-18 15:01:48.844	info	(23887) cleaned everything up...
      ecovacs-deebot.0	2020-11-18 15:01:48.843	error	(23887) TypeError: Cannot read property 'x' of undefined at VacBot_950type._handle_position (/opt/iobroker/node_modules/ecovacs-deebot/library/vacBot_950type.js:54:79) at EcovacsMQTT_JSON._han
      ecovacs-deebot.0	2020-11-18 15:01:48.843	error	(23887) uncaught exception: Cannot read property 'x' of undefined
      ecovacs-deebot.0	2020-11-18 15:01:48.455	info	(23887) [vacbot] name: DEEBOT OZMO T8 AIVI
      ecovacs-deebot.0	2020-11-18 15:01:48.454	info	(23887) New Device 0 successfully connected
      ecovacs-deebot.0	2020-11-18 15:01:47.694	info	(23887) Using device Device[0]
      ecovacs-deebot.0	2020-11-18 15:01:47.694	info	(23887) Device[0]: {"did":"cb0e7e17-2fbb-462b-b661-5e47595da2ad","name":"E07D14004B09HDWA0470","class":"x5d34r","resource":"9Zrg","nick":null,"company":"eco-ng","bindTs":1602784388635}
      ecovacs-deebot.0	2020-11-18 15:01:47.693	info	(23887) Number of devices: 1
      ecovacs-deebot.0	2020-11-18 15:01:47.693	info	(23887) Successfully connected to Ecovacs server
      ecovacs-deebot.0	2020-11-18 15:01:46.649	info	(23887) starting. Version 1.0.6-alpha.1 in /opt/iobroker/node_modules/iobroker.ecovacs-deebot, node: v10.20.1, js-controller: 3.1.6
      ecovacs-deebot.0	2020-11-18 15:01:15.269	info	(22955) Terminated (NO_ERROR): Without reason
      ecovacs-deebot.0	2020-11-18 15:01:15.269	info	(22955) terminating
      ecovacs-deebot.0	2020-11-18 15:01:15.254	info	(22955) cleaned everything up...
      ecovacs-deebot.0	2020-11-18 15:01:15.253	error	at doWrite (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/readable-stream/lib/_stream_writable.js:409:139)
      ecovacs-deebot.0	2020-11-18 15:01:15.253	error	at Writable.writable._write (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/mqtt/lib/client.js:335:5)
      ecovacs-deebot.0	2020-11-18 15:01:15.253	error	at work (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/mqtt/lib/client.js:321:12)
      ecovacs-deebot.0	2020-11-18 15:01:15.253	error	at MqttClient._handlePacket (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/mqtt/lib/client.js:410:12)
      ecovacs-deebot.0	2020-11-18 15:01:15.253	error	at MqttClient._handlePublish (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/mqtt/lib/client.js:1277:12)
      ecovacs-deebot.0	2020-11-18 15:01:15.253	error	at MqttClient.emit (events.js:198:13)
      ecovacs-deebot.0	2020-11-18 15:01:15.253	error	at MqttClient.EcovacsMQTT.client.on (/opt/iobroker/node_modules/ecovacs-deebot/library/ecovacsMQTT.js:44:18)
      ecovacs-deebot.0	2020-11-18 15:01:15.253	error	at EcovacsMQTT_JSON._handle_message (/opt/iobroker/node_modules/ecovacs-deebot/library/ecovacsMQTT_JSON.js:230:14)
      ecovacs-deebot.0	2020-11-18 15:01:15.253	error	at EcovacsMQTT_JSON._handle_command (/opt/iobroker/node_modules/ecovacs-deebot/library/ecovacsMQTT_JSON.js:306:26)
      ecovacs-deebot.0	2020-11-18 15:01:15.253	error	at VacBot_950type._handle_position (/opt/iobroker/node_modules/ecovacs-deebot/library/vacBot_950type.js:54:79)
      ecovacs-deebot.0	2020-11-18 15:01:15.253	error	(22955) TypeError: Cannot read property 'x' of undefined
      ecovacs-deebot.0	2020-11-18 15:01:15.252	error	(22955) uncaught exception: Cannot read property 'x' of undefined
      ecovacs-deebot.0	2020-11-18 15:01:15.142	info	(22955) [vacbot] name: DEEBOT OZMO T8 AIVI
      ecovacs-deebot.0	2020-11-18 15:01:15.137	info	(22955) New Device 0 successfully connected
      ecovacs-deebot.0	2020-11-18 15:01:14.345	info	(22955) Using device Device[0]
      ecovacs-deebot.0	2020-11-18 15:01:14.345	info	(22955) Device[0]: {"did":"cb0e7e17-2fbb-462b-b661-5e47595da2ad","name":"E07D14004B09HDWA0470","class":"x5d34r","resource":"9Zrg","nick":null,"company":"eco-ng","bindTs":1602784388635}
      ecovacs-deebot.0	2020-11-18 15:01:14.345	info	(22955) Number of devices: 1
      ecovacs-deebot.0	2020-11-18 15:01:14.344	info	(22955) Successfully connected to Ecovacs server
      ecovacs-deebot.0	2020-11-18 15:01:13.351	info	(22955) starting. Version 1.0.6-alpha.1 in /opt/iobroker/node_modules/iobroker.ecovacs-deebot, node: v10.20.1, js-controller: 3.1.6
      ecovacs-deebot.0	2020-11-18 15:00:42.111	info	(22251) Terminated (NO_ERROR): Without reason
      ecovacs-deebot.0	2020-11-18 15:00:42.111	info	(22251) terminating
      ecovacs-deebot.0	2020-11-18 15:00:42.109	info	(22251) cleaned everything up...
      ecovacs-deebot.0	2020-11-18 15:00:42.108	error	at doWrite (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/readable-stream/lib/_stream_writable.js:409:139)
      ecovacs-deebot.0	2020-11-18 15:00:42.108	error	at Writable.writable._write (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/mqtt/lib/client.js:335:5)
      ecovacs-deebot.0	2020-11-18 15:00:42.108	error	at work (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/mqtt/lib/client.js:321:12)
      ecovacs-deebot.0	2020-11-18 15:00:42.108	error	at MqttClient._handlePacket (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/mqtt/lib/client.js:410:12)
      ecovacs-deebot.0	2020-11-18 15:00:42.108	error	at MqttClient._handlePublish (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/mqtt/lib/client.js:1277:12)
      ecovacs-deebot.0	2020-11-18 15:00:42.108	error	at MqttClient.emit (events.js:198:13)
      ecovacs-deebot.0	2020-11-18 15:00:42.108	error	at MqttClient.EcovacsMQTT.client.on (/opt/iobroker/node_modules/ecovacs-deebot/library/ecovacsMQTT.js:44:18)
      ecovacs-deebot.0	2020-11-18 15:00:42.108	error	at EcovacsMQTT_JSON._handle_message (/opt/iobroker/node_modules/ecovacs-deebot/library/ecovacsMQTT_JSON.js:230:14)
      ecovacs-deebot.0	2020-11-18 15:00:42.108	error	at EcovacsMQTT_JSON._handle_command (/opt/iobroker/node_modules/ecovacs-deebot/library/ecovacsMQTT_JSON.js:306:26)
      ecovacs-deebot.0	2020-11-18 15:00:42.108	error	at VacBot_950type._handle_position (/opt/iobroker/node_modules/ecovacs-deebot/library/vacBot_950type.js:54:79)
      ecovacs-deebot.0	2020-11-18 15:00:42.108	error	(22251) TypeError: Cannot read property 'x' of undefined
      ecovacs-deebot.0	2020-11-18 15:00:42.108	error	(22251) uncaught exception: Cannot read property 'x' of undefined
      ecovacs-deebot.0	2020-11-18 15:00:40.947	info	(22251) [vacbot] name: DEEBOT OZMO T8 AIVI
      ecovacs-deebot.0	2020-11-18 15:00:40.946	info	(22251) New Device 0 successfully connected
      ecovacs-deebot.0	2020-11-18 15:00:40.332	info	(22251) Using device Device[0]
      ecovacs-deebot.0	2020-11-18 15:00:40.332	info	(22251) Device[0]: {"did":"cb0e7e17-2fbb-462b-b661-5e47595da2ad","name":"E07D14004B09HDWA0470","class":"x5d34r","resource":"9Zrg","nick":null,"company":"eco-ng","bindTs":1602784388635}
      ecovacs-deebot.0	2020-11-18 15:00:40.332	info	(22251) Number of devices: 1
      ecovacs-deebot.0	2020-11-18 15:00:40.332	info	(22251) Successfully connected to Ecovacs server
      ecovacs-deebot.0	2020-11-18 15:00:39.460	info	(22251) starting. Version 1.0.6-alpha.1 in /opt/iobroker/node_modules/iobroker.ecovacs-deebot, node: v10.20.1, js-controller: 3.1.6
      ecovacs-deebot.0	2020-11-18 15:00:34.339	info	(21868) Terminated (NO_ERROR): Without reason
      ecovacs-deebot.0	2020-11-18 15:00:34.339	info	(21868) terminating
      ecovacs-deebot.0	2020-11-18 15:00:34.338	info	(21868) cleaned everything up...
      ecovacs-deebot.0	2020-11-18 15:00:34.337	error	at doWrite (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/readable-stream/lib/_stream_writable.js:409:139)
      ecovacs-deebot.0	2020-11-18 15:00:34.337	error	at Writable.writable._write (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/mqtt/lib/client.js:335:5)
      ecovacs-deebot.0	2020-11-18 15:00:34.337	error	at work (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/mqtt/lib/client.js:321:12)
      ecovacs-deebot.0	2020-11-18 15:00:34.337	error	at MqttClient._handlePacket (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/mqtt/lib/client.js:410:12)
      ecovacs-deebot.0	2020-11-18 15:00:34.337	error	at MqttClient._handlePublish (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/mqtt/lib/client.js:1277:12)
      ecovacs-deebot.0	2020-11-18 15:00:34.337	error	at MqttClient.emit (events.js:198:13)
      ecovacs-deebot.0	2020-11-18 15:00:34.337	error	at MqttClient.EcovacsMQTT.client.on (/opt/iobroker/node_modules/ecovacs-deebot/library/ecovacsMQTT.js:44:18)
      ecovacs-deebot.0	2020-11-18 15:00:34.337	error	at EcovacsMQTT_JSON._handle_message (/opt/iobroker/node_modules/ecovacs-deebot/library/ecovacsMQTT_JSON.js:230:14)
      ecovacs-deebot.0	2020-11-18 15:00:34.337	error	at EcovacsMQTT_JSON._handle_command (/opt/iobroker/node_modules/ecovacs-deebot/library/ecovacsMQTT_JSON.js:306:26)
      ecovacs-deebot.0	2020-11-18 15:00:34.337	error	at VacBot_950type._handle_position (/opt/iobroker/node_modules/ecovacs-deebot/library/vacBot_950type.js:54:79)
      ecovacs-deebot.0	2020-11-18 15:00:34.337	error	(21868) TypeError: Cannot read property 'x' of undefined
      ecovacs-deebot.0	2020-11-18 15:00:34.336	error	(21868) uncaught exception: Cannot read property 'x' of undefined
      ecovacs-deebot.0	2020-11-18 15:00:31.707	info	(21868) [vacbot] name: DEEBOT OZMO T8 AIVI
      ecovacs-deebot.0	2020-11-18 15:00:31.706	info	(21868) New Device 0 successfully connected
      ecovacs-deebot.0	2020-11-18 15:00:31.009	info	(21868) Using device Device[0]
      ecovacs-deebot.0	2020-11-18 15:00:31.009	info	(21868) Device[0]: {"did":"cb0e7e17-2fbb-462b-b661-5e47595da2ad","name":"E07D14004B09HDWA0470","class":"x5d34r","resource":"9Zrg","nick":null,"company":"eco-ng","bindTs":1602784388635}
      ecovacs-deebot.0	2020-11-18 15:00:31.009	info	(21868) Number of devices: 1
      ecovacs-deebot.0	2020-11-18 15:00:31.008	info	(21868) Successfully connected to Ecovacs server
      ecovacs-deebot.0	2020-11-18 15:00:29.985	info	(21868) starting. Version 1.0.6-alpha.1 in /opt/iobroker/node_modules/iobroker.ecovacs-deebot, node: v10.20.1, js-controller: 3.1.6
      ecovacs-deebot.0	2020-11-18 14:59:58.900	info	(21000) Terminated (NO_ERROR): Without reason
      ecovacs-deebot.0	2020-11-18 14:59:58.900	info	(21000) terminating
      ecovacs-deebot.0	2020-11-18 14:59:58.898	info	(21000) cleaned everything up...
      ecovacs-deebot.0	2020-11-18 14:59:58.897	error	at doWrite (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/readable-stream/lib/_stream_writable.js:409:139)
      ecovacs-deebot.0	2020-11-18 14:59:58.897	error	at Writable.writable._write (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/mqtt/lib/client.js:335:5)
      ecovacs-deebot.0	2020-11-18 14:59:58.897	error	at work (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/mqtt/lib/client.js:321:12)
      ecovacs-deebot.0	2020-11-18 14:59:58.897	error	at MqttClient._handlePacket (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/mqtt/lib/client.js:410:12)
      ecovacs-deebot.0	2020-11-18 14:59:58.897	error	at MqttClient._handlePublish (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/mqtt/lib/client.js:1277:12)
      ecovacs-deebot.0	2020-11-18 14:59:58.897	error	at MqttClient.emit (events.js:198:13)
      ecovacs-deebot.0	2020-11-18 14:59:58.897	error	at MqttClient.EcovacsMQTT.client.on (/opt/iobroker/node_modules/ecovacs-deebot/library/ecovacsMQTT.js:44:18)
      ecovacs-deebot.0	2020-11-18 14:59:58.897	error	at EcovacsMQTT_JSON._handle_message (/opt/iobroker/node_modules/ecovacs-deebot/library/ecovacsMQTT_JSON.js:230:14)
      ecovacs-deebot.0	2020-11-18 14:59:58.897	error	at EcovacsMQTT_JSON._handle_command (/opt/iobroker/node_modules/ecovacs-deebot/library/ecovacsMQTT_JSON.js:306:26)
      ecovacs-deebot.0	2020-11-18 14:59:58.897	error	at VacBot_950type._handle_position (/opt/iobroker/node_modules/ecovacs-deebot/library/vacBot_950type.js:54:79)
      ecovacs-deebot.0	2020-11-18 14:59:58.897	error	(21000) TypeError: Cannot read property 'x' of undefined
      ecovacs-deebot.0	2020-11-18 14:59:58.897	error	(21000) uncaught exception: Cannot read property 'x' of undefined
      ecovacs-deebot.0	2020-11-18 14:59:58.178	info	(21000) [vacbot] name: DEEBOT OZMO T8 AIVI
      ecovacs-deebot.0	2020-11-18 14:59:58.177	info	(21000) New Device 0 successfully connected
      ecovacs-deebot.0	2020-11-18 14:59:57.548	info	(21000) Using device Device[0]
      Und alle paar minuten taucht das im Log auf:
      ecovacs-deebot.0	2020-11-18 15:02:24.853	error	(24615) TypeError: Cannot read property 'x' of undefined at VacBot_950type._handle_position (/opt/iobroker/node_modules/ecovacs-deebot/library/vacBot_950type.js:54:79) at EcovacsMQTT_JSON._han
      ecovacs-deebot.0	2020-11-18 15:02:24.852	error	(24615) uncaught exception: Cannot read property 'x' of undefined
      mrbungle64 2 Replies Last reply Reply Quote 0
      • mrbungle64
        mrbungle64 Developer @ChrisXY last edited by
        @ChrisXY
        Wieso hast Du die (Alpha) Version von GitHub installiert?
        • mrbungle64
          @ChrisXY said in Test Adapter ecovacs-deebot v0.6.x Latest:
          Und: wer hat denn noch "massiv" Probleme?
            ChrisXY @mrbungle64 last edited by
            @mrbungle64
            wieso nicht zurück auf die 1.0.5 und es geht wieder.
            Ich hab paar Wochen kein Update des Adapters gemacht und bevor ich nu mit den Spots und VIS rum mache wollte ich es aktuell haben.
            Wohl zu "aktuell"
            mrbungle64 1 Reply Last reply Reply Quote 0
            • mrbungle64
              @mrbungle64
              wieso nicht
              Weil Du dann hier von massiven Problemen berichtest anstatt mal auf unsere Fragen bzw. unsere Bitte einzugehen
              • boriswerner
                boriswerner Developer @boriswerner last edited by
                @ChrisXY wenn du schonmal dabei bist, könntest du das hier einmal ansehen und das Ergebnis posten?
                  ChrisXY @boriswerner last edited by
                  @boriswerner
                  ohhhhh sorry das hab ich nicht gesehen. Hab es direkt mal gemacht. Gerne auch PN wenn du genaueres testen willst.
                  Leider kommt nicht mehr soll ich mal eien Reinigung durchlaufen lassen?
                  [VacBot] action: GetCleanLogsPullCleanF
                  [EcovacsMQTT_JSON] Logs: {"resultCode":"0","resultCodeMessage":"ok","resultData":{"ret":"ok","logs":[]}}
                  boriswerner 1 Reply Last reply Reply Quote 0
                  • boriswerner
                    boriswerner Developer @ChrisXY last edited by
                    @ChrisXY Okay, dank dir. Du hast aber weiterhin
                    unter "cleaninglog.last20Logs" und "cleaninglog.lastCleaningMapImageURL" keine einträge
                    wie du letztens mal geschrieben hast? Auch nicht mit der alternativen Funktion in der Instanzkonfiguration (unter "weiteres")?
                    Dann haben wir wohl leider doch nicht die neue magische Log-Abruffunktion gefunden...
                      @boriswerner genau da war noch nie etwas glaub ich .. Zeigt mir nur die Totale Laufzeiten.
                      Ich hab mit den alternativ API schon rumprobiert ändert nichts
                      Gibt es etwas zur Erkennung in welchem Raum er sich aktuell befindet ? 90% hab ich immer unknown dort stehen.
                      • boriswerner
                        @ChrisXY Komisch. Bei mir funktioniert das sehr zuverlässig, außer in Randbereichen/Übergängen zwischen zwei Räumen. Siehe meine Erklärung hier:
                        https://github.com/mrbungle64/ioBroker.ecovacs-deebot/issues/94
                        Wichtig ist halt, dass es in der Karte in der App vom farbigen Bereich abgedeckt sein muss. Nur das Polygon wird dann als Raum erkannt
                        krobipd created this issue in mrbungle64/ioBroker.ecovacs-deebot
                        closed optimierung: raum erkennung #94
                        C S 2 Replies Last reply Reply Quote 0
                          @boriswerner ja habe eine saubere Karte mit Bereichen.
                          Glaube es trifft einen Raum den ich zusammengefügt und wieder getrennt habe. Danach wieder sauber beschriftet. Unter den Objekten bei Control stehen die Räume drin aber nicht mit meinem Namen.
                          Kann man das irgendwie neu updaten ? Cool wäre auch wenn die Spots verschwinden die nicht aktiv sind.
                          • boriswerner
                            @ChrisXY Im control stehen die auch nicht mit den Namen drin (ich glaube, die werden mittlerweile auch gar nicht mehr angelegt, wenn man neu aufsetzt, oder @mrbungle64 ? also du meinst die spotArea_0, spotArea_1 usw. oder?).
                            Die Namen gibt es nur unter den Objekten unter dem map-Ordner.
                            Da findest du dann alle Karten als Ordner (die Ordner, wo mapIsAvailable auf false steht, kannst du manuell löschen, ebenso die spotAreas wo spotAreaIsAvailable false ist um aufzuräumen). Da gibt es dann u.a. auch für jede existierende spotArea einen clean-Button/State
                            Beobachte mal, ob der Bot bei einer Reinigung auch unknown als currentSpotArea liefert, wenn er sich "mitten" in einem farbigen Bereich der Karte befindet oder nur in Randbereichen.
                              stefande @boriswerner last edited by
                              @boriswerner @mrbungle64
                              Bei meinem 950er bekomme ich seit rund einer Woche öfters mal den Status "unknown" in den Objekten: chargestatus, cleanstatus und deviceStatus.
                              Aktuell bin ich auf der Version 1.0.5
                              Blöderweise nutze ich den chargestatus, um zu detektieren, ob der Saugi in der Station ist.
                              In den Log Dateien ist nix zu erkennen.
                              Debug hab ich aktuell noch nicht aktiviert, da der Fehler immer nur mal sporadisch auftritt. Trotzdem war ich letzte Nacht etwas angepisst, als mir Alexa gegen kurz nach 4 Uhr mitteilte, dass "Saugi unterwegs ist".
                              Hat jemand von Euch ne Idee, woher das "unknown" plötzlich kommt, oder zumindest eine Idee, wie ich zuverlässig erkennen kann, ob Saugi in der Station ist?
                              mrbungle64 boriswerner 2 Replies Last reply Reply Quote 0
                              • mrbungle64
                                mrbungle64 Developer @stefande last edited by mrbungle64
                                @stefande said in Test Adapter ecovacs-deebot v0.6.x Latest:
                                Hallo @stefande
                                wird die Adapter Instanz nachts um 4 Uhr autom. neu gestartet?
                                Der Wert "unknown" wird nämlich beim Start eingetragen (quasi als Reset) und wieder direkt befüllt (vorausgesetzt die Verbindung wird erfolgreich hergestellt).
                                Evtl. kam heute Nacht dann keine Verbindung zum Ecovacs Server zustande.
                                Ich werde das evtl. mal wieder ausbauen, dass die Status resettet werden.
                                • mrbungle64
                                  mrbungle64 Developer @boriswerner last edited by
                                  @boriswerner said in Test Adapter ecovacs-deebot v0.6.x Latest:
                                  Da steckt noch was im Code was die mit den Ordnern unter "map" synchronisieren sollte - aber das Löschen ist auskommentiert und das Anlegen scheint nicht richtig zu funktionieren.
                                  Das hatte ich wegen diesem Issue hier mal eingebaut - aber vom Ersteller dann keine Rückmeldung mehr bekommen...
                                  • boriswerner
                                    boriswerner Developer @stefande last edited by
                                    @stefande mir ist das auch aufgefallen. Ich bekomme auch ab und an mal den Status "alert". Ecovacs scheint da etwas an der API getan zu haben soweit ich das auf die schnelle beurteilen kann. Ich wollte mir das am Wochenende mal genauer ansehen.
                                    Das mit dem reset des Status, den @mrbungle64 erwähnt hat ist aber natürlich auch ein guter Punkt.
                                      In der Tat wird bei mir, in jeder Nacht zum Mittwoch, die Internet Verbindung kurz getrennt.
                                      Nicht desto trotz hatte ich das "unknown" in der letzten Woche zwei oder drei Mal, ohne dass die Internet Verbindung weg war.
                                      Ihr werde jetzt erstmal die Ansage deaktivieren, bevor ich nachts wieder geweckt werde.
                                      Vielleicht überdenkt ihr das Feature noch mal. 👼
                                      • mrbungle64
                                        Hatte ich ja schon geschrieben 😉
                                          stefande @mrbungle64 last edited by
                                          @mrbungle64 sagte in Test Adapter ecovacs-deebot v0.6.x Latest:
                                            Fände es auch gut wenn er sich vielleicht den letzten Ort merkt auch wenn er mal an den Rand der Karte fährt. Hab bei mir eine anzeige gebaut und wenn er nur im schmalen Flur ist zeigt diese oft keinen Standort mehr an 😉
                                            Und oft steht bei mir Status Idle obwohl er was macht. Gibt es einen zuverlässigen Status wenn er Reinigt ?
                                            31.7k
                                            79.8k
                                            deebot ecovacs saugroboter vacuum
                                            12
                                            138
                                            12320
