    3. Entwicklung
    4. Zigbee Error beim starten des Connect Mode
      weidlix @Asgothian last edited by weidlix
      @Asgothian
      Stick: CC2531
      HW: Proxmox Debian VM
      Node: 12.18.3
      npm: 6.16.6
      js-controller: 4.8.4
      2020-11-19 08:06:34.098 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2020-11-19 08:06:34.099 - error: zigbee.1 (5691) unhandled promise rejection: SREQ '--> AF - dataRequestExt - {"dstaddrmode":2,"dstaddr":"0x000000000000fffd","destendpoint":242,"dstpanid":0,"srcendpoint":242,"clusterid":33,"transid":1,"options":0,"radius":30,"len":6,"data":{"type":"Buffer","data":[25,2,2,11,254,0]}}' failed with status '(0x10: MEM_ERROR)' (expected '(0x00: SUCCESS)')
      2020-11-19 08:06:34.099 - error: zigbee.1 (5691) Error: SREQ '--> AF - dataRequestExt - {"dstaddrmode":2,"dstaddr":"0x000000000000fffd","destendpoint":242,"dstpanid":0,"srcendpoint":242,"clusterid":33,"transid":1,"options":0,"radius":30,"len":6,"data":{"type":"Buffer","data":[25,2,2,11,254,0]}}' failed with status '(0x10: MEM_ERROR)' (expected '(0x00: SUCCESS)')
      at Znp. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:291:27)
      at Generator.next ()
      at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:24:58)
      2020-11-19 08:06:34.100 - info: zigbee.1 (5691) cleaned everything up...
      2020-11-19 08:06:34.101 - info: zigbee.1 (5691) Zigbee: disabling joining new devices.
      2020-11-19 08:06:34.160 - error: zigbee.1 (5691) Failed to stop zigbee (Error: SREQ '--> AF - dataRequestExt - {"dstaddrmode":2,"dstaddr":"0x000000000000fffd","destendpoint":242,"dstpanid":0,"srcendpoint":242,"clusterid":33,"transid":2,"options":0,"radius":30,"len":6,"data":{"type":"Buffer","data":[25,3,2,11,0,0]}}' failed with status '(0x10: MEM_ERROR)' (expected '(0x00: SUCCESS)')
      at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:24:58))
      2020-11-19 08:06:34.190 - info: zigbee.1 (5691) terminating
      2020-11-19 08:06:34.193 - info: zigbee.1 (5691) Terminated (NO_ERROR): Without reason
      2020-11-19 08:06:34.718 - info: host.ioBrokerProd instance system.adapter.zigbee.1 terminated with code 0 (NO_ERROR)
      2020-11-19 08:06:34.721 - info: host.ioBrokerProd Restart adapter system.adapter.zigbee.1 because enabled
      • Asgothian
        Asgothian Developer @weidlix last edited by
        @weidlix
        Das ist leider nicht das korrekte log. Die Zeilen sind am Ende angeschnitten, daher fehlt die Fehler Ursache.
        A.
          @Asgothian
          Ach mist ... sorry. Habs unten nochmal angepasst
          • Asgothian
            @weidlix
            • Bei deinem Stick läuft der Speicher voll. (MEM_ERROR).
            • wie viele Geräte hast du ?
            • welche ?
            • läuft es wenn du den Stick abziehst und wieder ansteckst ?
            A.
              @Asgothian
              Ja wenn ich den Stick abziehe und die VM durchstarte funktioniert alles wieder.
              Hab 20 Geräte. Find ich jetzt nicht soo viel. Sind glaube ich schon 10 Aquara Temperatursensoren. Dann noch 4 Steckdosen und ein paar Fensterkontakte. Die habe ich auch schon eine Zeit lang. Das lief mal mindestens ein halbes Jahr stabil.
              Ich vermute das kam erst durch ein Adapter Update rein. Aber ich kann es nicht genau sagen.
              arteck Asgothian 2 Replies Last reply Reply Quote 0
                arteck Developer Most Active @weidlix last edited by arteck
                @weidlix sagte in Zigbee Error beim starten des Connect Mode:
                falsch.. mal so ganz neben bei
                es liegt an dem cc2531.. der läuft an seine grenzen..ohh wie wunder.. das passt zur deiner Aussage vor halben Jahr lief noch alles...
                • Asgothian
                  @Asgothian
                  Fein. Damit ist der Stick als Ursache ausgemacht.
                  20 am cc2531 ist schon ordentlich. Ich würde den gegen etwas vernünftiges austauschen.
                  Der Wechsel auf 1.2.1 ist schon über ein halbes Jahr her. Also lief es auch damit stabil.
                  A.
                    weidlix @arteck last edited by
                    @arteck Was meinst Du mit Coordinator? Ich habe mir diesen Stick geholt:
                    https://www.amazon.de/ITSTUFF-USB-Stick-ioBroker-openHAB-Firmware/dp/B07ZZ88BWZ/ref=sr_1_1?__mk_de_DE=ÅMÅŽÕÑ&dchild=1&keywords=ITStuff+cc2531&qid=1605774553&sr=8-1
                    Einfach eingesteckt und nix aufgespielt
                      @Asgothian said in Zigbee Error beim starten des Connect Mode:
                      Was kann ich denn da nehmen. Kannst Du mir Hardwarevorschläge machen?
                      W arteck 2 Replies Last reply Reply Quote 0
                        weidlix @weidlix last edited by
                        scheinbar bin ich nicht der Einzige mit dem Problem. Hier wurde auch auf deconz umgestellt weil es nicht stabil lief:
                        https://forum.iobroker.net/topic/20613/conbee-zigbee-usbstick-alternative-zu-cc2531
                          @weidlix schau im Marktplatz nach
                          • Asgothian
                            @weidlix
                            Was glaubst du wie ich so schnell aus der Fehlermeldung auf das Problem schließen konnte ? Der Fehler ist bekannt und zeigt die Grenzen des cc2531 auf. Immerhin ist der als “sniffer und Diagnose Werkzeug” designed worden und sollte nie selber als Koordinator arbeiten.
                            Zum Thema Alternativen:
                            • conbee ( mit zigbee Adapter oder deconz )
                            • verschiedene ti boards (siege zigbee2mqtt.io)
                            • cc2538+cc2592 (siehe Marktplatz)
                            Ich nutze ein ti board.
                            A.
                            1.0k
                            zigbee
                            1233
