    4. Frage : Migrate MySQL nach Influxdb
      MezzoDO @JackGruber last edited by MezzoDO
      @JackGruber said in Frage : Migrate MySQL nach Influxdb:
      @MezzoDO ok, das ack feld ist bereits als boolen angelegt, kommt nun aber als int.
      Ihc könnte es anpassen, dass dies beim import convertiert wird.
      Das wäre grandios 🙂
      Mein Script, was ich einsetze:
      ### MySQL DB info ###
      #import MySQLdb
      import pymysql
      conn = pymysql.connect(host="localhost",  # your host, usually localhost
                           user="xxx",         # your username
                           passwd="xxx",  # your password
                           db="iobroker")        # name of the data base
      ### PostgreSQL DB info ###
      import psycopg2
      import psycopg2.extras
      # connection data for PostgreSQL
      #conn = psycopg2.connect("dbname=xxx user=xxx password=xxx host=xxx.xxx.xxx.xxx port =5432")
      # InfluxDB info #
      from influxdb import InfluxDBClient
      #####connection data for InfluxDB#####
      influxClient = InfluxDBClient(host='localhost', port=8086, username='xxx', password='xxx', database='iobroker')
      #influxClient.delete_database(influx_db_name)
      #influxClient.create_database(influx_db_name)
      # dictates how columns will be mapped to key/fields in InfluxDB
      schema = {
          "time_column": "time", # the column that will be used as the time stamp in influx
          "columns_to_fields" : ["ack","q", "from","value"], # columns that will map to fields
          # "columns_to_tags" : ["",...], # columns that will map to tags
          "table_name_to_measurement" : "name", # table name that will be mapped to measurement
      Generates an collection of influxdb points from the given SQL records
      def generate_influx_points(records):
          influx_points = []
          for record in records:
              #tags = {},
              fields = {}
              #for tag_label in schema['columns_to_tags']:
              #   tags[tag_label] = record[tag_label]
              for field_label in schema['columns_to_fields']:
                  fields[field_label] = record[field_label]
              influx_points.append({
                  "measurement": record[schema['table_name_to_measurement']],
                  #"tags": tags,
                  "time": record[schema['time_column']],
                  "fields": fields
          return influx_points
      # query relational DB for all records
      #curr = conn.cursor('cursor', cursor_factory=psycopg2.extras.RealDictCursor)
      curr = conn.cursor(cursor=pymysql.cursors.DictCursor)
      # curr = conn.cursor(dictionary=True)
      # SQL query for PostgreSQL, syntax for MySQL differs
      # query provide desired columns as a view on the sql server
      # request data from SQL, adjust ...from <view name>
      curr.execute("Select * from InfluxData;")
      row_count = 0
      # process 1000 records at a time
      while True:
          print("Processing row #" + str(row_count + 1))
          selected_rows = curr.fetchmany(1000)
          influxClient.write_points(generate_influx_points(selected_rows))
          row_count += 1000
          if len(selected_rows) < 1000:
              break
      conn.close()
      JackGruber 1 Reply Last reply Reply Quote 0
      • JackGruber
        JackGruber @MezzoDO last edited by
        @MezzoDO
        Ersetze in deinem Script Zeile 47 mit folgenden zwei zeilen. Auf das einrücken achten!:
                    if field_label == "ack":
                        record[field_label] = bool(record[field_label])
        • simatec
          simatec Developer Most Active @JackGruber last edited by
          @JackGruber
          Ich komme leider auch nicht weiter ...
          Habe deinen Script von Github installiert und bekomme folgende Ausgabe:
          pi@raspberrypi:~/iobroker_mysql_2_influxdb $ python3 migrate.py all
          Migrate 'all' datapoint(s) ...
          Total metrics in ts_number: 0
          Total metrics in ts_bool: 0
          Total metrics in ts_string: 0
          Migrated: 0
          Das ganze passiert innerhalb einer Sekunde .
          Die Influxdb habe ich über den iobroker Adapter angelegt.
          • JackGruber
            JackGruber @simatec last edited by
            Hi @simatec, hab einen mini Fehler im Script gefunden. Durch einen BUG musste das ALL großgeschrieben werden.
            Hab das Script angepasst, einfach neu herunterladen oder das ALL großschreiben.
            • simatec
              @JackGruber
              Danke für den Tipp ... Ich hatte es auch einzeln versucht und dann auch jedes Objekt einzeln importiert.
              War zwar etwas Aufwand aber ging super 😉
                base last edited by
                Wie und wo kann ich das Script benutzen? In iobroker javascript oder Konsole? iobroker läuft bei mir im Docker Container....
                • JackGruber
                  JackGruber @base last edited by
                  @base python auf deinem PC installieren, das script wie auf der git seite beschrieben installieren und benutzen.
                    base @JackGruber last edited by
                    @JackGruber
                    ich bekomme in diese Zeile einen Syntax Error:
                                print(f"Processing row {processed_rows + 1:,} to {processed_rows + len(selected_rows):,} from LIMIT {start_row:,} / {start_row + query_max_rows:,} " + table + " - " + metric['name'] + " (" + str(metric_nr) + "/" + str(metric_count) + ")")
                    er meckert die Anführungsstriche vor table an
                    simatec JackGruber 2 Replies Last reply Reply Quote 0
                    • simatec
                      simatec Developer Most Active @base last edited by
                      @base
                      So war es bei mir auch.
                      Hast du mal versucht, die Daten einzeln pro Objekt zu importieren? Das half bei mir.
                        base @simatec last edited by base
                        @simatec habe dein Script von oben ausprobiert, dass holt aber nicht alle Objekte...
                        was muss ich da ändern?
                        ok, habs gefunden. Muss natürlich die SQL Abfrage anpassen. Jetzt klappts
                        • JackGruber
                          @base was für eine python version nutzt du?
                          Bei mir läuft das script ohne probleme durch.
                            @JackGruber hab jetzt Version 3.7.9, hatte vorher 3.9, da ging gar nichts.
                            Den Befehl pip install -r requirements.txt habe ich in der Eingabeaufforderung im entsprechenden Ordner durchgeführt, war das so richtig?
                            • JackGruber
                              @base Ja, genau, dann sollte er alle nötigen module installieren.
                              Hm, muss ich mir mal mit python 3.9 anschauen ...
                                @JackGruber wie gesagt, 3.9 hat gar nicht funktioniert bei mir und bei der 3.7.9 bekomme ich die Fehlermeldung
                                  @JackGruber Habe gerade festgestellt, dass die Fehlermeldung nur bei der 64bit Version kommt.
                                  Bei der 32èr gehts.
                                  Leider bekomme ich jetzt noch einen:
                                  MySQL connection error
                                  '192.168.1.100'
                                  • JackGruber
                                    @base hm komisch grad mit Python 3.9 64 bit getetet und geht 1a.
                                    Python 3.9.0 (tags/v3.9.0:9cf6752, Oct 5 2020, 15:34:40) [MSC v.1927 64 bit (AMD64)]
                                    Das ist die ganze Fehlerausgabe?
                                      @JackGruber ja
                                      RESTART: C:\Users\Base\Downloads\iobroker_mysql_2_influxdb-master\iobroker_mysql_2_influxdb-master\migrate.py
                                      '192.168.1.100'
                                      • JackGruber
                                        @base teste doch mal in einer powershell folgendes:
                                        Test-NetConnection 192.168.1.100 -p 3307
                                          @JackGruber Lernen Sie das neue plattformübergreifende PowerShell kennen – https://aka.ms/pscore6 PS C:\Users\Base> Test-NetConnection 192.168.1.100 -p 3307 WARNUNG: TCP connect to (192.168.1.100 : 3307) failed
                                          ComputerName : 192.168.1.100
                                          RemoteAddress : 192.168.1.100
                                          RemotePort : 3307
                                          InterfaceAlias : WiFi
                                          SourceAddress : 192.168.1.72
                                          PingSucceeded : True
                                          PingReplyDetails (RTT) : 6 ms
                                          TcpTestSucceeded : False
                                            @JackGruber PS C:\Users\Base> Test-NetConnection 192.168.1.100 -p 3306 ComputerName : 192.168.1.100
                                            RemotePort : 3306
                                            TcpTestSucceeded : True
                                            PS C:\Users\Base>
                                            151
                                            24984
