    4. Test Adapter MercedesMe v0.0.x
      K_o_bold @Philipp.Schlegel last edited by
      @Philipp-Schlegel ,
      der Adapter ist momentan nur lesend, remote control ist noch nicht möglich.
        Philipp.Schlegel @tombox last edited by
        @tombox
        Also trotz neuer Installation via Github kommen bei mir noch folgende Fehlermeldungen:
        mercedesme.0	2020-11-18 11:58:52.473	error	at processImmediate (timers.js:658:5)
        mercedesme.0	2020-11-18 11:58:52.473	error	at tryOnImmediate (timers.js:676:5)
        mercedesme.0	2020-11-18 11:58:52.473	error	at runCallback (timers.js:706:11)
        mercedesme.0	2020-11-18 11:58:52.473	error	at Immediate.adapterStates.getStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6757:17)
        mercedesme.0	2020-11-18 11:58:52.473	error	at getStates (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:363:72)
        mercedesme.0	2020-11-18 11:58:52.473	error	(2872) TypeError: Cannot read property 'val' of undefined
        mercedesme.0	2020-11-18 11:58:52.470	error	(2872) uncaught exception: Cannot read property 'val' of undefined
          wellknownasmax last edited by
          Ich bekomme über den OBD Adapter gar keine Werte.
            jhg @K_o_bold last edited by
            Verbindung zum Wagen klappt wieder.
            Allerdings erhalte ich folgende Fehlermeldungen:
            This value will not be set in future versions. Please report this to the developer.
            State value to set is invalid for mercedesme.0.WDBXX.state.ecoSpeedHistogram.ecoHistogramValue: The state contains the forbidden properties ecoHistogramBinsList!
            State value to set is invalid for mercedesme.0.WDBXX.state.ecoShiftingHistogram.ecoHistogramValue: The state contains the forbidden properties ecoHistogramBinsList!
            State value to set is invalid for mercedesme.0.WDBXX.state.ecoDecelerationHistogram.ecoHistogramValue: The state contains the forbidden properties ecoHistogramBinsList!
            State value to set is invalid for mercedesme.0.WDBXX.state.ecoAccelerationHistogram.ecoHistogramValue: The state contains the forbidden properties ecoHistogramBinsList!
            • amg_666
              amg_666 @jhg last edited by
              @jhg guck mal weiter oben, das hatte schon jemand gepostet, das sind "nur" Warnungen kannste ignorieren, er sagt ja nur dass die angefragten values IN ZUKUNFT nicht mehr geliefert werden.
              • Thomas Jansen
                Thomas Jansen @Rumpeltec last edited by
                @Rumpeltec hallo, guten Abend. Hat was mit Deiner Fhem Aussage zu tun bezüglich Arlo. Ich suche seit 1 Jahr eine Möglichkeit Arlo in IOBroker einzubinden. Fhem sagt mir nix, hast Du da eine Anleitung für Doofis??😋😜
                  tombox @Thomas Jansen last edited by
                  Jetzt kann man auch commandos ausführen. Einfach unter commands das commando auf klappen und den button unter start drücken.
                  P 2 Replies Last reply Reply Quote 1
                    @tombox Nice! Update via Github erforderlich, oder geht's gleich so?
                    Und: DANKE vorab! Klasse!
                      @tombox
                      Funktioniert bei meinem PreConditioning leider nicht:
                      (22964) [{"code":"CMD_FAILED","message":"Command failed. Normally, there should be additional business errors detailing what exactly went wrong","attributesMap":[],"subErrorsList":[]},{"code":"4051","message":"","attributesMap":[],"subErrorsList":[]}]
                        tombox @Philipp.Schlegel last edited by
                        @Philipp-Schlegel kommt der Fehler immer? Aktivierst du über die datenpunkte commands? Welches Baujahr hast du?
                          @tombox
                          Hab es jetzt ein paar Mal probiert, der Fehler kam immer, ja. Ich geh über Commands/ZEV_PRECONDITIONING_START/start
                          Meiner ist BJ2016, Baumuster 2052471 (S205 Hybrid)...und damit VorMopf...
                          • Pedder007
                            Pedder007 @klassisch last edited by
                            @tombox, super, danke!
                            Gerade erst entdeckt und direkt installiert. Keinerlei Fehlermeldungen!
                            Ich suche allerdings noch die Datenpunkte für den Status des Schiebedachs und die Gesamtreichweite.
                            state.rangeelectric.displayValue und state.rangeliquid.displayValue sind da aber anscheinend nichts mehr insgesamt.
                            doorsclosed und windowsclosed sind auch vorhanden und klappen
                            Danke nochmal!
                              tombox @Pedder007 last edited by tombox
                              @Pedder007
                              mercedesme.0.x.state.overallRange
                              mercedesme.0.x.state.sunroofstatus
                              @Philipp-Schlegel
                              Es gibt jetzt wieder ein Delay in v.0.40 für alte Modelle einfach auf 1 setzen dann sollte precond auch bei dir gehen.
                                @tombox
                                Top, teste ich gleich mal. Danke!
                                  darkiop Most Active last edited by
                                  @tombox Nochmal Danke für die Weiterentwicklung!! Commands / Remotes teste ich heute mal mit dem EQC.
                                  Die API liefert sehr viele Datenpunkte. Könntest du dir Vorstellen eine Möglichkeit zu schaffen diese vorher auswählen zu können? Analog dem Unifi Adapter von @braindead. Er hat hier mit Hilfe von @Scrounger folgendes realisiert:
                                    tombox @darkiop last edited by tombox
                                    @darkiop eher weniger weil ich den Wartungsaufwand eher gering halten will falls mb wieder was änder und jeder kann für dich entscheiden wie er was nutzen möchte
                                    Bei manchen Sachen weiß ich ja selber nicht was es ist und was bei einem kompatiblen Fahrzeug angezeigt wird
                                      @tombox Ok, verständlich 🙂
                                      Der EQC hängt gerade an der normalen Steckdose und quält sich langsam aber sich wieder an die 100% SoC (wird Zeit das die Wallbox kommt :))
                                      Folgender DP sollte doch true sein, wenn der Ladevorgang läuft oder?
                                        @tombox Der hier zeigt den Ladestatus korrekt an:
                                          So, und jetzt erstmal das aktuelle Ergebnis meiner "Wallbox Lite mit schaltbarer Steckdose" 😄
                                          2 1 Reply Last reply Reply Quote 0
                                            @darkiop
                                            Sollte er er ist abhängig von mercedesme.0.xx.state.chargingstatus.intValue der muss 0 sein dann wird es auf true gesetzt
                                            Bitte im Auge behalten ob das dauerhaft so ist.
                                            mercedes
                                            120
                                            929
                                            230319
