    4. eBus Adapter Vaillant
    • Glasfaser
      Glasfaser @morpheus999 last edited by Glasfaser
      @morpheus999 sagte in eBus Adapter Vaillant:
      Weder bei http oder local wird was erkannt.
      Wenn du die Config änderst ... startest du dann auch den Ebusd neu !?
      Zeige mal die Ausgabe von :
      ebusctl i
      systemctl status ebusd.service
        morpheus999 @Glasfaser last edited by
        @Glasfaser said in eBus Adapter Vaillant:
        root@loxberry:~# ebusctl i
        version: ebusd 3.4.v3.3-51-g57eae05
        update check: revision v3.4 available, broadcast.csv: newer version available
        signal: acquired
        symbol rate: 23
        max symbol rate: 148
        reconnects: 0
        masters: 5
        conditional: 0
        poll: 0
        update: 4
        address 01: master #6
        address 03: master #11
        address 06: slave #6, scanned "MF=Vaillant;ID=PMS02;SW=0209;HW=8402"
        address 08: slave #11, scanned "MF=Vaillant;ID=BAI00;SW=0703;HW=7401"
        address 0a: slave, scanned "MF=Vaillant;ID=PMW01;SW=0205;HW=8302"
        address 10: master #2
        address 12: slave, scanned "MF=Vaillant;ID=PMW01;SW=0205;HW=8302"
        address 26: slave, scanned "MF=Vaillant;ID=SOLSY;SW=0500;HW=6301"
        address 31: master #8, ebusd
        address 36: slave #8, ebusd
        address 50: slave, scanned "MF=Vaillant;ID=SOLSY;SW=0500;HW=6301"
        address ec: slave, scanned "MF=Vaillant;ID=SOLSY;SW=0500;HW=6301"
        address ed: slave, scanned "MF=Vaillant;ID=PMS02;SW=0209;HW=8402"
        address f7: master #20
        address fc: slave #20, scanned "MF=Vaillant;ID=PMW01;SW=0205;HW=8302"
        root@loxberry:~# systemctl status ebusd.service
        ● ebusd.service - ebusd, the daemon for communication with eBUS heating systems.
           Loaded: loaded (/lib/systemd/system/ebusd.service; disabled; vendor preset: e
           Active: active (running) since Mon 2020-09-28 09:54:38 CEST; 10h ago
         Main PID: 931 (ebusd)
            Tasks: 4 (limit: 2200)
           Memory: 6.9M
           CGroup: /system.slice/ebusd.service
                   └─931 /usr/bin/ebusd -d /dev/ttyUSB0 --scanconfig --configpath=/etc/e
        Sep 28 16:13:14 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFil
        Sep 28 17:13:10 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFil
        Sep 28 17:13:12 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFil
        Sep 28 17:13:14 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFil
        Sep 28 18:13:11 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFil
        Sep 28 18:13:12 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFil
        Sep 28 18:13:14 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFil
        Sep 28 19:13:10 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFil
        Sep 28 19:13:12 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFil
        Sep 28 19:13:14 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFil
        lines 1-19/19 (END)...skipping...
           Loaded: loaded (/lib/systemd/system/ebusd.service; disabled; vendor preset: enabled)
           Memory: 6.9M
                   └─931 /usr/bin/ebusd -d /dev/ttyUSB0 --scanconfig --configpath=/etc/ebusd
        Sep 28 16:13:14 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below
        Sep 28 17:13:10 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below
        Sep 28 17:13:12 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below
        Sep 28 17:13:14 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below
        Sep 28 18:13:11 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below
        Sep 28 18:13:12 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below
        Sep 28 18:13:14 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below
        Sep 28 19:13:10 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below
        Sep 28 19:13:12 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below
        Sep 28 19:13:14 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below
        lines 1-19/19 (END)
           Memory: 6.9M
        Sep 28 16:13:14 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below leg
        Sep 28 17:13:10 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below leg
        Sep 28 17:13:12 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below leg
        Sep 28 17:13:14 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below leg
        Sep 28 18:13:11 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below leg
        Sep 28 18:13:12 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below leg
        Sep 28 18:13:14 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below leg
        Sep 28 19:13:10 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below leg
        Sep 28 19:13:12 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below leg
        Sep 28 19:13:14 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below leg
        lines 1-19/19 (END)
           Memory: 6.9M
        Sep 28 16:13:14 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below legacy directory /var
        Sep 28 17:13:10 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below legacy directory /var
        Sep 28 17:13:12 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below legacy directory /var
        Sep 28 17:13:14 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below legacy directory /var
        Sep 28 18:13:11 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below legacy directory /var
        Sep 28 18:13:12 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below legacy directory /var
        Sep 28 18:13:14 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below legacy directory /var
        Sep 28 19:13:10 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below legacy directory /var
        Sep 28 19:13:12 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below legacy directory /var
        Sep 28 19:13:14 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below legacy directory /var
        lines 1-19/19 (END)
           Memory: 6.9M
        Sep 28 16:13:14 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below legacy directory /var/run/, up
        Sep 28 17:13:10 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below legacy directory /var/run/, up
        Sep 28 17:13:12 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below legacy directory /var/run/, up
        Sep 28 17:13:14 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below legacy directory /var/run/, up
        Sep 28 18:13:11 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below legacy directory /var/run/, up
        Sep 28 18:13:12 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below legacy directory /var/run/, up
        Sep 28 18:13:14 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below legacy directory /var/run/, up
        Sep 28 19:13:10 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below legacy directory /var/run/, up
        Sep 28 19:13:12 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below legacy directory /var/run/, up
        Sep 28 19:13:14 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below legacy directory /var/run/, up
        lines 1-19/19 (END)
           Memory: 6.9M
        Sep 28 16:13:14 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/ebusd.pid → /run/ebusd.pid; please update the unit file accordingly.
        Sep 28 17:13:10 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/ebusd.pid → /run/ebusd.pid; please update the unit file accordingly.
        Sep 28 17:13:12 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/ebusd.pid → /run/ebusd.pid; please update the unit file accordingly.
        Sep 28 17:13:14 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/ebusd.pid → /run/ebusd.pid; please update the unit file accordingly.
        Sep 28 18:13:11 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/ebusd.pid → /run/ebusd.pid; please update the unit file accordingly.
        Sep 28 18:13:12 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/ebusd.pid → /run/ebusd.pid; please update the unit file accordingly.
        Sep 28 18:13:14 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/ebusd.pid → /run/ebusd.pid; please update the unit file accordingly.
        Sep 28 19:13:10 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/ebusd.pid → /run/ebusd.pid; please update the unit file accordingly.
        Sep 28 19:13:12 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/ebusd.pid → /run/ebusd.pid; please update the unit file accordingly.
        Sep 28 19:13:14 loxberry systemd[1]: /lib/systemd/system/ebusd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/ebusd.pid → /run/ebusd.pid; please update the unit file accordingly.
           Memory: 6.9M
        Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @morpheus999 last edited by Thomas Braun
          root@loxberry
          Nicht machen...
          Log dich als user ein.
          [Edit:] Ach, die Wahnsinnigen von loxberry. Die haben sudo aus irgendwelchen unerfindlichen Gründen auf Eis gelegt. (Wenn man das System nicht ordentlich voreinstellen kann sollte man es lassen...)
          • Glasfaser
            @morpheus999
            Nimm nochmal meine Config und starte den Dienst dann neu !
            -d /dev/ttyUSB0 --httpport=8889 --scanconfig=full --enablehex --latency=0 --configpath=/etc/ebusd -l /var/log/ebusd.log
            • Glasfaser
              Glasfaser @Thomas Braun last edited by
              @Thomas-Braun sagte in eBus Adapter Vaillant:
                also das muss mir jemand erklären...
                ich geb deine Befehlszeile ein und auf einmal wertet er die BAI.csv aus....
                aber sonst nix mehr... ich starte einfach nochmal neu... erkennt garnix mehr...
                Hab bei 19:14 mit deinen Werten neu gestartet
                meine ebusd.log
                • Glasfaser
                  @morpheus999
                  2020-09-29 19:15:34.378 [update notice] received scan-read scan.06  QQ=10: Vaillant;PMS02;0209;8402
                  2020-09-29 19:15:34.753 [main error] scan config ed: ERR: read timeout
                  2020-09-29 19:15:36.795 [main error] unable to load scan config fc: no file from vaillant with prefix fc matches ID "pmw01", SW0205, HW8302
                  2020-09-29 19:15:36.795 [main error] scan config fc: ERR: read timeout
                  Dort sind ein haufen ERR: read timeout Fehler drin ... als würde dein Ebus Schnittstelle nicht richtig die Kommunikation aufbauen.
                    @Glasfaser Ja, da hab ich auf READ ALL geklickt. Da fragt er auch die ab die nicht per CSV erkannt wurden. Wenn ich das richtig verstehe.
                      mameier1234 last edited by
                      Ich habe jetzt mal seit langer Zeit wieder angefangen, meine Heizung per IOBroker zu optimieren..
                      Unter anderem setze ich die Zeiten für Warmwasser , Warmwasser Zirkulation und die Heizzeiten..
                      Jetzt fällt auf, dass die Werte, die der Ebusd liefert nicht immer aktuell sind... Wenn man dann im Telnet einmal von Hand z.B. die Warmwasserzirkulation von heute ausliest
                      read -c cc Timer.Saturday
                      Dann kommt sofort (im Telnet) der richtige Wert und wird mit dem nächsten Ebus Lauf auch in den Iobroker übertragen...
                      So.. dann dachte ich: kein Problem ... frag halt die Timer mit dem Ebus Adapter manuell ab...
                      Das läuft aber nicht richtig, da mehrere Timer.Saturday existieren...
                      im Telnet ...
                      find Timer.Saturday
                      cc Timer.Saturday = 07:00;11:00;-:-;-:-;-:-;-:-;Sa-So
                      hc Timer.Saturday = no data stored
                      hwc Timer.Saturday = 05:30;08:30;-:-;-:-;-:-;-:-;Mo-So
                      mc Timer.Saturday = no data stored
                      Sprich, die muss man einzeln mit read -c cc Timer.Saturday , dann den nächsten mit read -c hwc Timer.Saturday und soweiter auslesen..
                      Der Adapter macht aber nur ein read -f Timer.Saturday und bringt damit nur das Ergebniss des ersten Timer Eintrages, den er findet ...
                      Schön wäre es, wenn man im Adapter nicht nur den Namen, den man auslesen möchte , sondern auch den Circuit (-c) angeben könnte...
                      • Rene_HM
                        Rene_HM Developer @mameier1234 last edited by
                        @mameier1234 wenn du den ebus-Adapter verwendest, gibt es den cmd-DP. Dort kannst du beliebige Kommandos verwenden... einfach per script den Befehl dort hinein schreiben. Beim Ausführen des Adapters wird der Befehl ausgeführt...
                          mameier1234 @Rene_HM last edited by
                          @Rene_HM Das ist ne Idee.. So schreibe ich ja auch meine Werte..
                          • MassiveAttack
                            MassiveAttack last edited by
                            Gibt es hier Kollegen die wie ich eine Vaillant Flexotherm 87/4 besitzen? Ich kann aktuell viele Daten auslesen, jedoch fehlt mir die komplette Fachhandwerkebene (Kompressorstarts etc) sowie der Live Monitor. Vermutlich wurden diese Parameter noch nicht entschlüsselt, oder kann das jemand auslesen? Wenn ja, wie?
                            Weiß jemand ob die csv's erweitert werden?
                            Bei mir wird ein slave zwar erkannt, aber kein csv dazu geladen. Die anderen 3 werden erkannt.
                            version: ebusd 21.2.v21.2
                            update check: OK
                            access: *
                            signal: acquired
                            symbol rate: 24
                            max symbol rate: 182
                            min arbitration micros: 584
                            max arbitration micros: 4311
                            min symbol latency: 7
                            max symbol latency: 17
                            reconnects: 0
                            masters: 5
                            conditional: 0
                            poll: 0
                            update: 10
                            address 00: master #1
                            address 04: slave #25, ebusd
                            address 08: slave #11, scanned "MF=Vaillant;ID=HMU00;SW=0307;HW=0403", loaded "vaillant/08.hmu.csv"
                            address 15: slave #2, scanned "MF=Vaillant;ID=70000;SW=0509;HW=6403", loaded "vaillant/15.700.csv"
                            address 26: slave, scanned "MF=Vaillant;ID=VR_71;SW=0104;HW=0503", loaded "vaillant/26.vr_71.csv"
                            address 71: master #9
                            address 76: slave #9, scanned "MF=Vaillant;ID=VWZ00;SW=0307;HW=0403"
                            address ff: master #25, ebusd
                              Dre83 last edited by Dre83
                              Hallo in die Runde,
                              ich habe ein Problem mit meinem Vaillant EBus Adapter.
                              Ich habe mir diesen von Esera zugelegt:
                              https://www.esera.de/produkte/ebus/142/ebus-koppler-ethernet?c=20
                              Diesen habe ich auf die EBus Schnittstelle auf meine Vaillant VR700 aufgeklemmt.
                              Leider erhalte ich im iO Broker bzw. über eine Abfrage im Terminal keine Daten der EBus Geräte. Die Datenlampe am EBus Koppler flackert auch fleißig, so dass ich davon ausgehe, dass da alles passt.
                              Bei der Installation habe ich mich an diese Seite (https://github.com/john30/ebusd) sowie an die Beiträge in diesem Thread gehalten.
                              Der EBus Dienst auf dem Raspberry ist gestartet und wenn ich "ebusctl info" eingebe, bekomme ich folgendes.
                              Was mich dabei stutzig macht das die Vaillant Therme oder der VRC700 Regler nicht gefunden wird.
                              Das Config File sieht wie folgt aus:
                              Im iO Broker im EBUS Adapter habe ich als Zieladresse die IP-Adresse meines Raspberrys hinterlegt, auf welchem der ioBroker und der ebus Dienst läuft.
                              Wenn ich diese Zeilen im Raspberry richtig interpretiere liegen allerdings irgendwo Daten vor:
                              Ruf ich den Webbrowser über (http://192.168.2.118:8889/data) auf erhalte ich folgendes:
                              Anbei noch eine Übersicht der gelieferten Objekte im ioBroker
                              Vllt. hilft der Inhalt des EBus Ordners noch weiter. Das rot markierte scheint für mich auch ein Problem zu sein.
                              Ich vermute das ich irgendwo einen größeren Denkfehler bei der Konfiguration habe. Es wäre schön wenn jmd eine Idee bzw. einen Lösungsansatz für mich hätte.
                              Viele Grüße
                              André
                              • Glasfaser
                                Glasfaser @Dre83 last edited by
                                @dre83 sagte in eBus Adapter Vaillant:
                                die sieht ein wenig kurz aus , ich sehe keine Zuweisung zur Schnittstelle ( USB )
                                https://forum.iobroker.net/topic/29359/ebus-adapter-vaillant/110?_=1617082689322
                                  Dre83 @Glasfaser last edited by Dre83
                                  @glasfaser: Mein Adapter läuft über LAN-Schnittsstelle.
                                  Wie und wo kann ich denn da die Zuweisung machen?
                                  Ich hatte es so verstanden das er damit selbst die Zuweisung macht um die Geräte zu finden:
                                  EBUSD_OPTS="--scanconfig --httpport=8889"
                                  • Glasfaser
                                    aber nicht für die Schnittstelle .
                                    Sieht dann so als Beispiel aus , für Ethernet
                                    EBUSD_OPTS="--device=192.168.243.86:5000 --httpport=8889 --scanconfig --latency=30000 --configpath=/etc/ebusd/ebusd-2.1.x/de"
                                      @glasfaser danke für Deine Antwort.
                                      Als IP Adresse hinterlege ich die des Raspberrys oder des EBus Adapters?
                                      Ergänzung: Wenn ich meine Konfiguration durch deine angepasste ersetze habe ich keine Signal mehr:
                                      • Glasfaser
                                        Glasfaser @Dre83 last edited by Glasfaser
                                        @dre83
                                        Bei dem " IP "Esera kann ich dir nicht helfen , da ich die USB Version betreibe .
                                        Eigentlich in der Config die IP vom Esera , ist Sie von deinem Raspberry per Ping erreichbar !?
                                        EDIT :
                                        Das habe ich in der Wiki gefunden :
                                        commercial:
                                        ESERA-Automation / E-Service GmbH: eBUS Koppler Ethernet (not working reliably due to latency issues)
                                        https://github.com/john30/ebusd/wiki/6.-Hardware
                                          @glasfaser Den Adpater kann ich problemlos anpingen. Das funktioniert.
                                          Ich vermute das hier in dem Statement ein Fehler ist:
                                          Kann es sein das ich in dem Tool von Esera noch etwas einstellen muss?
                                          Edit:
                                          Habe jetzt mal die Einstellung in dem Esera Tool angepasst und schon erkennt er ein Gerät
                                          Jetzt ist nur noch die Frage ob ich wie ich an die Daten komme.
                                          • Glasfaser
                                            es müßte eigentlich mehr kommen kann in deinen Schnipsel nicht viel erkennen , auch die geladenen config Files im Log zu sehen sein ( z.B vom VRC700 )
                                            So sieht das Beispielweise aus ... öffne meine Ausgaben im Thread
                                            https://forum.iobroker.net/topic/9844/adapter-ebus/242
                                            was kommt jetzt bei http://192.168.2.118:8889/data
                                            ebus ebus adapter error erste schritte problem
                                            49
                                            388
                                            101143
