    5. Bewegungsmelder blockly nach Zeit
      paul53 @sandro_gera last edited by
      @sandro_gera sagte:
      was denkst du?
      Poste bitte den vom Blockly erzeugten Javascript-Code ohne die letzte Zeile in Code tags </>.
        sandro_gera @paul53 last edited by sandro_gera
          <variables>
            <variable id="$A5sBj~`{HnEyT{S,,zX">manuell</variable>
            <variable id="#dn^Ntk#4RGe)Tvz4()W">Wert</variable>
            <variable id="wvB)ss3.ucMJXeJk!`Nw">level</variable>
            <variable id="T/$YV2jdcBsf-M4JRM:$">Ursprung</variable>
            <variable id="43M!).Z=m=7SbhCJ0PR7">ct</variable>
          </variables>
          <block type="on_ext" id="YM.#/9w.1y~Z9?XJhnN5" x="-463" y="-337">
            <value name="OID0">
              <shadow type="field_oid" id="%jTnyCDn%PgYB{8*.0lt">
                <field name="oid">alias.0.Bewegungsmelder.Flur.Philips_Hue_motion_Flur_Presence_presence</field>
              <block type="controls_if" id="f`]_ZnrJPO+/s2gj8/sr">
                  <block type="variables_get" id="O[pSy)Kfw_-kt1|cB[Fg">
                    <field name="VAR" id="$A5sBj~`{HnEyT{S,,zX">manuell</field>
                  <block type="controls_if" id="NH=-h0lX^4/=9@l*M@AR">
                      <block type="logic_operation" id="Yy~I1gw@#1s|eb*^QU]s" inline="false">
                        <field name="OP">AND</field>
                          <block type="logic_compare" id="r[c7):%ov;xLJI)7=6ST">
                            <field name="OP">EQ</field>
                            <comment pinned="false" h="53" w="139">Hier nog den wert Bewegung rein</comment>
                              <block type="get_value" id=".,__.+a+Wr7b#I}`Z*iw">
                                <field name="OID">alias.0.Bewegungsmelder.Flur.Philips_Hue_motion_Flur_Presence_presence</field>
                              <block type="logic_boolean" id="`]V~(Hc7DDwYjOh=4tq=">
                          <block type="logic_compare" id="%YGQ;ENgMFDy/{+4))4`">
                            <field name="OP">LT</field>
                              <block type="get_value" id="wIdF:8b9kA*~F/qff=5Z">
                                <field name="OID">alias.0.Bewegungsmelder.Flur.Philips_Hue_motion_Flur_LightLevel_lux</field>
                              <block type="math_number" id="r@hhmCSZfyq;E~yWe[7[">
                                <field name="NUM">20</field>
                      <block type="timeouts_cleartimeout" id="7rw,zduV-62(pcZLAR4;">
                          <block type="controls_if" id="3fj!d?TBRKep-,c|*lQj">
                              <block type="time_compare" id="eH5pwmI/c8:YbF7GW]sC">
                                <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true"></mutation>
                                <field name="START_TIME">07:00</field>
                                <field name="END_TIME">22:00</field>
                              <block type="variables_set" id="Scu~MVz4F@OM%mFcE~KX">
                                <field name="VAR" id="wvB)ss3.ucMJXeJk!`Nw">level</field>
                                  <block type="math_number" id="_EpOy)y6a0$sp/sIba,.">
                                    <field name="NUM">30</field>
                                  <block type="variables_set" id="E4Q*^fQ6+C/n4N@M!m$[">
                                    <field name="VAR" id="43M!).Z=m=7SbhCJ0PR7">ct</field>
                                      <block type="math_number" id="H_Z*fxFw(#jSs)7Wd8YX">
                                        <field name="NUM">200</field>
                            <statement name="ELSE">
                              <block type="variables_set" id="tWx:S(byeyltmOeQ-?]M">
                                  <block type="math_number" id="babJi+Cy8jxk=04m3X{2">
                                    <field name="NUM">10</field>
                                  <block type="variables_set" id="SiHG^!%c/k%y?Af[iQo!">
                                      <block type="math_number" id="ln?v`wnB*8uYuFnHLZyN">
                                        <field name="NUM">340</field>
                              <block type="control" id="fn32UPV8!EY@LVl@l441">
                                <field name="OID">alias.0.Licht.Flur.Deckenlampe_Flur_Dimmwert</field>
                                  <block type="variables_get" id="5qj76%LX)ir}oZ/6QU8K">
                                  <block type="control" id="B)IfBUKu~Bwh#Oo%=N!E">
                                    <field name="OID">alias.0.Licht.Flur.Deckenlampe_Flur_Farbtemperatur</field>
                                      <block type="variables_get" id="ME}sOV}Kh}+K+|TvMu=E">
                                      <block type="control" id="qKv$`19TYKeN05R74=7Y">
                                        <field name="OID">alias.0.Licht.Flur.Deckenlampe_Flur</field>
                                          <block type="logic_boolean" id="?a2capuBWyh$zJU(u%Xr">
                      <block type="timeouts_cleartimeout" id="48kyiz7c9o!iu:6.^{Vw">
                          <block type="timeouts_settimeout" id="EWUG;n=f.[20rin0,hE9">
                            <field name="DELAY">3</field>
                              <block type="control" id="H[A{jz0[.Mvj%H7h(gW^">
                                  <block type="logic_boolean" id=";NZ=bc({k|F;n{%dcYa}">
              <block type="on_ext" id="Kg6m`;VxfJ,iWYG6m6vl">
                <value name="OID0">
                  <shadow type="field_oid" id="Huz,enH*$,(K(Q2~6Iyi">
                    <field name="oid">alias.0.Licht.Flur.Deckenlampe_Flur</field>
                  <block type="variables_set" id="H.X]pVt-[.SG*mSo2%;G">
                      <block type="logic_operation" id="5X;VDBZ5|G0)6[t;_Ill" inline="false">
                          <block type="variables_get" id="8TMk}zGgebAp9:Rf9o|c">
                            <field name="VAR" id="#dn^Ntk#4RGe)Tvz4()W">Wert</field>
                          <block type="logic_compare" id="g,4XFQ{VIRAB~u$kAFec">
                            <field name="OP">NEQ</field>
                              <block type="variables_get" id="kbwC;%yg]U9~H/zS1n(O">
                                <field name="VAR" id="T/$YV2jdcBsf-M4JRM:$">Ursprung</field>
                              <block type="text" id="g%jGCj+)5XnCikl8P}Ni">
                                <field name="TEXT">system.adapter.javascript.0</field>
        so meinst du?
          paul53 @sandro_gera last edited by paul53
          @sandro_gera sagte:
          so meinst du?
          Eigentlich nicht, aber so geht es auch. Habe korrigiert:
           <variables>
           </variables>
             <value name="OID0">
                   <block type="logic_negate" id="[-C5S33I3Q{{u@3~+E`s">
                     <value name="BOOL">
                       <block type="variables_get" id="k9`-[bG6-ZPqt$}C4,!`">
                           <block type="on_source" id=",?sb*{!q|?vcfgqoJR^D">
                 <value name="OID0">
                           <block type="on_source" id="o4-9,(o#HTx:}]|7zyCy">
                               <block type="on_source" id="avL^M)Ct_sI32]4a1]X.">
                                 <field name="ATTR">state.from</field>
            Vielen Dank aber mit der Korrektur tut sich nichts ich glaube ohne den Baustein der bei mir am und steht geht es nicht
              Ich meine Wert von Objekt ID = wahr
                @sandro_gera sagte:
                Wert enthält das gleiche, nämlich den Wert des Trigger-Datenpunktes.
                  sorry ich bin ja kein Experte. Ich hab nur gefagt weil mit der anderen Version das Licht an geht
                    @sandro_gera
                    Habe gerade gesehen: Es fehlt das "nicht" vor manuell !
                      Was doch so ein kleines Wörtchen "nicht" alles ausmachen kann.
                      Das Licht geht an!
                      Ich glaube jetzt gehts vielen vielen Dank
                        @sandro_gera sagte:
                        Ja, es bewirkt halt das Gegenteil.
                          Jap logisch. Ok dann beobachte ich jetzt mal ob alles funktioniert.
                          Sollte etwas nicht klappen melde ich mich.
                          Nochmals vielen Dank und sorry das ich mich manchmal so dumm angestellt habe.
                            Hallo Paul, ich hab nochmal eine Frage zu einem anderen Blockly das ich erstellen möchte.
                            Ich hab einen Osram Motion+ Bewegungsmelder und möchte, dass wenn dieser eine Bewegung erfasst zwei Lampe geschalten werden, allerdings nur nach Sonnenuntergang und vor Sonnenaufgang und wenn diese nicht schon durch einen Sonoff Schalter eingeschaltet wurden.
                              <variables>
                                <variable id="Ik?`;_^3$2,9W6VQSQ~3">manuell</variable>
                              </variables>
                              <block type="on_ext" id="m^ctya_*xjD8-KQUH,61" x="-387" y="-312">
                                <value name="OID0">
                                  <shadow type="field_oid" id="_T7NQNq|6_KL]8~#AmPL">
                                    <field name="oid">alias.0.Bewegungsmelder.Küche.OSRAM_Smart_plus_Motion_presence</field>
                                  <block type="controls_if" id="AjIawNtDhM8SXPVhw{e`">
                                      <block type="logic_negate" id="Hjw[|jxFGlaK+tB[Xzic">
                                        <value name="BOOL">
                                          <block type="variables_get" id="}CE3k{LCn40h(vIrYV=x">
                                            <field name="VAR" id="Ik?`;_^3$2,9W6VQSQ~3">manuell</field>
                                      <block type="controls_if" id="vQFC4G#mtRRlX.VWnqrI">
                                              <block type="time_compare_ex" id="ey-,zU=|GQ~-lu2{d?05">
                                                <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true" actual_time="true"></mutation>
                                                <value name="START_TIME">
                                                  <shadow type="text" id="CW1)M1p;$JsM:Cj5%}.p">
                                                    <field name="TEXT">12:00</field>
                                                  <block type="time_astro" id="Q?9@xZ*n9t/b-X?z:FKX">
                                                    <field name="TYPE">sunset</field>
                                                    <field name="OFFSET">0</field>
                                                <value name="END_TIME">
                                                  <shadow type="text" id="Lrv[#^v+EiYT/RyF-38]">
                                                    <field name="TEXT">18:00</field>
                                                  <block type="time_astro" id="?M!.Ij2q~S:14)nF3-B5">
                                                    <field name="TYPE">sunrise</field>
                                          <block type="control" id="j{iYD3~l*zpr@KNEtMr[">
                                            <field name="OID">alias.0.Licht.Kueche.Sitzecke_Küche</field>
                                              <block type="logic_boolean" id="gNB|jW2JqpYR-b@gT~z:">
                                              <block type="control" id="`={{)Zg80|j]CRJ(JS]]">
                                                <field name="OID">alias.0.Licht.Kueche.Spuele_Kueche</field>
                                                  <block type="logic_boolean" id="f(oqs-6ORlXavV(2OF+8">
                                  <block type="on_ext" id="Cc5FGM]lHd;8*-vEl(87">
                                    <value name="OID0">
                                      <shadow type="field_oid" id="J82_w$aysD(,n#TfjKi$">
                                        <field name="oid">alias.0.Steckdosen.Kueche.Fernseher-Kueche</field>
                                      <block type="controls_if" id="kI2O[+^*EQe-N6{_73pC">
                                          <block type="time_compare_ex" id="6is|BuqK]*6m-aPwb/@U">
                                              <shadow type="text" id="];F}z@vB:nYR+}[8e-G?">
                                              <block type="time_astro" id="GwzCWWG4p:b:!@RlUvDM">
                                              <shadow type="text" id="sWBH}U%x5Sqx#y@V3iaI">
                                              <block type="time_astro" id="0DjcAfg98o6D]UOHKB4!">
                                          <block type="control" id=";7,M0kAz=I9`8,J[ExVE">
                                              <block type="logic_boolean" id="VgHRkw8$KYyY]:/Mu[1s">
                                              <block type="control" id="7Rz9IM61s?Uy?Q!t7v1U">
                                                  <block type="logic_boolean" id="vEgYr##hR+SBQasU|zU`">
                            Das Problem ist, wenn ich zum Beispiel am Küchentisch sitze erkennt der Bewegungsmelder manche Bewegungen nicht und schaltet die Lampe dann sofort ab. Hast du eine idee ob ich das irgendwie lösen kann oder funktioniert das nur mit einem Präsenzmelder?
                              @sandro_gera sagte:
                              Bei Astrozeiten muss Beginn vor Ende liegen (funktioniert nicht Tag übergreifend), also für nachts: nicht zwischen SA und SU
                              @sandro_gera sagte in Bewegungsmelder blockly nach Zeit:
                              Ich sehe nur, dass der Fernseher das Licht ausschalten soll ?
                              Anstelle der Trigger auf "wahr" nimm besser "ist größer als letztes", die nur bei Änderung von false --> true triggern. Soll der BWM das Licht dauerhaft einschalten ?
                              Da ich weder BWM noch Präsenzmelder habe, kenne ich das Verhalten nicht.
                                @paul53 said in Bewegungsmelder blockly nach Zeit:
                                @sandro_gera sagte:
                                Also muß ich ein Blockly für Sonnenuntergang erstellen und ein 2. für vor dem Sonnenaufgang? und wie stelle ich das ein mit - Minuten?
                                sorrry ich hatte vergessen das auf Bewegungsmelder umzustellen.
                                Das Licht soll so lange an bleiben bis ich das Zimmer länger Zeit verlasse.
                                Der Unterschied ist, das ein Präsenzmelder nicht über die Bewegung steuert, sonder die Anwesenheit über die Wärmequelle erkennt.
                                Der wäre also eigentlich ideal. Den Bewegungsmelder habe ich aber noch zu Hause und dachte ich kann ihn trotzdem irgendwie verwenden.
                                  Hat der BWM eine eigene Ausschaltverzögerung ? Dann sollte es so funktionieren:
                                   <variables>
                                   </variables>
                                     <value name="OID0">
                                           <block type="logic_operation" id="np6DF~Z57YL_4:oC@ot6" inline="false">
                                                 <value name="BOOL">
                                                 <field name="OPTION">not between</field>
                                               <block type="on_source" id="c(.$0bbY@%eg$Ft*!+(3">
                                                   <block type="on_source" id="}|}r{Tsv9nSt4uM.8TcG">
                                       <block type="on_ext" id="bC{yAAD)cQ4#p29#C@#_">
                                         <value name="OID0">
                                           <shadow type="field_oid" id=";n6#=sBC`|uZj*^.+N3j">
                                           <block type="text" id="X0_^|HM$QaYHn,*+W%`h">
                                             <field name="TEXT">alias.0.Licht.Kueche.Sitzecke_Küche</field>
                                         <value name="OID1">
                                           <shadow type="field_oid" id="cCX-Z1VJNG9*RN;paA1M">
                                           <block type="text" id="aXD=w(l=78}W$Q!7%g/0">
                                             <field name="TEXT">alias.0.Licht.Kueche.Spuele_Kueche</field>
                                                   <block type="logic_operation" id="w02V0-,Xdr^{n-JYU{ia" inline="false">
                                                     <field name="OP">OR</field>
                                                       <block type="get_value_var" id="#3!yRfmWIjb^~=F87f}J">
                                                         <value name="OID">
                                                           <shadow type="text" id="g)?W76,0dY|I8sIuL~(h">
                                                       <block type="get_value_var" id="m%{V/b4yi]7q$9z-#CB7">
                                                         <value name="OID">
                                                           <shadow type="text" id="[Od,*@MTq]#Uy9Jh+K%)">
                                  S 3 Replies Last reply Reply Quote 0
                                    das sind die datenpunkte des Bewegungsmelders
                                      Danke nochmals, aber orgendwo muß ich nen Fehler habe, das Licht bleibt aus wenn ich in den Raum komme.
                                      Ich habe auch noch ein 2. Blockly erstellt bei dem eine Wandlampe im Arbeitszimmer angehen sollte, wenn der Computer angeschaltet ist und wenn die sonne untergeht. Das funktioniert leider auch nicht.
                                        <variables>
                                          <variable id="BBlob__c0O4~vBzD]b(?">Wert</variable>
                                        </variables>
                                        <block type="on_ext" id="m^ctya_*xjD8-KQUH,61" x="-887" y="-512">
                                          <value name="OID0">
                                              <field name="oid">alias.0.Steckdosen.Arbeitszimmer.Computer_1_Arbeitszimmer</field>
                                                      <value name="BOOL">
                                                  <field name="OID">alias.0.Licht.Arbeitszimmer.Wandlampe_Arbeitszimmer</field>
                                                    <block type="variables_get" id="VN}?Y*5!:[PlA6u|23xm">
                                                      <field name="VAR" id="BBlob__c0O4~vBzD]b(?">Wert</field>
                                              <value name="OID0">
                                                  <field name="oid">alias.0.Licht.Arbeitszimmer.Wandlampe_Arbeitszimmer</field>
                                                        <block type="get_value" id="@+/Xwx$oMqUW?R;Y3SRF">
                                        @sandro_gera sagte:
                                        Stimmt die Zeitzone im OS ? Log-Ausgabe rechts:
                                        Sind die richtigen Ortskoordinaten in der Konfiguration der Javascript-Instanz eingetragen ?
                                          javascript.0	2020-11-25 17:28:02.139	info	(5105) script.js.common.Test.Zeit: registered 0 subscriptions and 0 schedules
                                          javascript.0	2020-11-25 17:28:02.138	info	(5105) script.js.common.Test.Zeit: 17:28:02
                                          javascript.0	2020-11-25 17:28:02.100	info	(5105) Start javascript script.js.common.Test.Zeit
                                            @sandro_gera sagte:
                                            Der Standort wird auf der Karte richtig angezeigt
                                            blockly
                                            5111
