    4. [How-to] Node.js für ioBroker richtig updaten
      stephan2k @Thomas Braun last edited by
      @Thomas-Braun sagte in [How-to] Node.js für ioBroker richtig updaten:
      @stephan2k
      ps aux | grep io
      hilft dir das was?
        Thomas Braun Most Active @stephan2k last edited by
        @stephan2k
        Bitte keine Screenshots, Konsolentexte auch als Text (in CodeTags) posten.
          @Thomas-Braun
          natürlich
          root@iobroker:/opt/iobroker#
          root@iobroker:/opt/iobroker# ps aux | grep io
          root         1  0.0  0.0   4292   768 pts/0    Ss   18:40   0:00 sh /opt/scripts
          /iobroker_startup.sh
          avahi       40  0.0  0.0  47144  2912 ?        S    18:40   0:00 avahi-daemon: r
          egistering [iobroker-33.local]
          root        60 23.0  1.7 858300 174416 pts/0   Sl   18:40   1:27 iobroker.js-con
          troller
          root        78  2.5  0.9 807972 93212 pts/0    Sl   18:40   0:09 io.admin.0
          root        93  0.5  0.5 626700 53700 pts/0    Sl   18:41   0:01 io.web.0
          root       123  1.1  0.4 621292 47996 pts/0    Sl   18:41   0:04 io.history.0
          root       216  0.4  0.5 633560 54664 pts/0    Sl   18:41   0:01 io.sonoff.0
          root       232  0.6  0.5 781860 54532 pts/0    Sl   18:41   0:02 io.tankerkoenig
          .0
          root       243  1.4  0.5 786468 59444 pts/0    Sl   18:41   0:04 io.telegram.0
          root       258  0.3  0.4 623060 48760 pts/0    Sl   18:41   0:01 io.socketio.0
          root       273  0.4  0.5 641172 50816 pts/0    Sl   18:41   0:01 io.mihome-vacuu
          m.0
          root       293  0.4  0.4 638540 48988 pts/0    Sl   18:41   0:01 io.scenes.0
          root       308  0.3  0.4 620596 45960 pts/0    Sl   18:41   0:01 io.text2command
          .0
          root       323  1.9  0.6 920968 62944 pts/0    Sl   18:42   0:06 io.alexa2.0
          root       339  0.4  0.5 642520 52452 pts/0    Sl   18:42   0:01 io.terminal.0
          root       354  0.5  0.4 622056 49388 pts/0    Sl   18:42   0:01 io.yeelight-2.0
          root       370  0.5  0.5 641940 51488 pts/0    Sl   18:42   0:01 io.harmony.0
          root       385  1.1  0.6 729596 68944 pts/0    Sl   18:42   0:03 io.iot.0
          root       400  0.4  0.4 620552 45812 pts/0    Sl   18:42   0:01 io.mihome.0
          root       415  1.0  0.8 668528 80532 pts/0    Sl   18:42   0:02 io.backitup.0
          root       426  2.2  0.5 704000 58936 pts/0    Sl   18:42   0:06 io.info.0
          root       449  0.9  0.6 858420 64512 pts/0    Sl   18:42   0:02 io.nuki2.0
          root       747  3.3  0.6 654744 66296 pts/0    Sl   18:42   0:09 io.shelly.0
          root       773  0.5  0.5 641760 51968 pts/0    Sl   18:42   0:01 io.mihome-vacuu
          m.1
          root       844  0.5  0.4 621580 48040 pts/0    Sl   18:42   0:01 io.sonos.0
          root       866  0.8  0.5 643076 54156 pts/0    Sl   18:42   0:02 io.deconz.0
          root       936  2.0  0.5 630032 56112 pts/0    Sl   18:42   0:05 io.hue.0
          root       963  1.8  0.6 784284 63124 pts/0    Sl   18:43   0:04 io.yahka.0
          root      1033  1.7  0.4 622848 49736 pts/0    Sl   18:43   0:04 io.sourceanalyt
          ix.0
          root      1054  0.8  0.5 646108 57384 pts/0    Sl   18:43   0:02 io.tuya.0
          root      1131  4.3  0.5 646480 59616 pts/0    Sl   18:43   0:10 io.influxdb.1
          root      1153  0.4  0.4 620576 46884 pts/0    Sl   18:43   0:01 io.hm-rpc.0
          root      1227  1.1  0.5 642152 54700 pts/0    Sl   18:43   0:02 io.hm-rega.0
          root      1254  1.1  0.5 639544 50544 pts/0    Sl   18:43   0:02 io.hm-rpc.1
          root      3418  0.0  0.0  12788   980 pts/0    S+   18:47   0:00 grep io
          root@iobroker:/opt/iobroker# iobroker upgrade self
          Thomas Braun Diginix 2 Replies Last reply Reply Quote 0
            @stephan2k
            kill 60
            • Diginix
              Diginix @stephan2k last edited by
              @stephan2k Das kann keine Prozessliste eines gestoppten iobroker sein.
              Sowohl der JS-Controller läuft, als auch Adapterinstanzen. Wie sieht die Ausgabe aus nachdem du "iobroker stop" gemacht hast?
              Zu dem alles mit root wird sich Thomas sicher noch äußern 😉
                Thomas Braun Most Active @Diginix last edited by
                @Diginix sagte in [How-to] Node.js für ioBroker richtig updaten:
                docker / synology halt. Zu meinem Leidwesen muss das da ja wohl so laufen.
                  @Thomas-Braun
                  Danke Thomas-Braun! nun ging es.
                  Danke!
                    @stephan2k
                    Kann es sein, dass der ioBroker da doppelt installiert ist?
                      @Thomas-Braun
                      nein eigentlich nicht (nicht das ich wüsste)
                        apollon77 @stephan2k last edited by
                        @stephan2k Der Thread hier geht eigentlich um nodejs update ... js.controller Update ist formal hier fehlt am Platze ...
                          Kuddel @apollon77 last edited by
                          für alle Interessierten. Habe gerade auf meiner Testinstanz ein NodeJS Update von 10.17.0 auf 12.20.0 gemacht und mir dafür einn Shell Skript geschrieben
                          clear
                          echo
                          echo --- NODE JS UPDATE ---
                          echo
                          echo
                          read -p "NodeJS Version (Beispiel: 12.x): " version
                          echo
                          echo --- Abfrage NodeJS version ---
                          echo
                          node -v
                          echo
                          read -p "Press any key to continue..."
                          echo
                          echo
                          echo --- ioBroker stoppen ---
                          echo
                          echo
                          echo
                          iobroker stop
                          echo
                          echo --- Download Nodejs Version $version ---
                          echo
                          echo
                          echo
                          curl -sL https://deb.nodesource.com/setup_$version | sudo -E bash -
                          echo
                          echo --- NodeJS installieren ---
                          echo
                          echo
                          echo
                          sudo apt-get install -y nodejs
                          echo
                          echo
                          node -v
                          echo
                          echo --- ioBroker starten ---
                          echo
                          echo
                          echo
                          iobroker start
                          echo
                          echo --- ioBroker status ---
                          echo
                          iobroker status
                          echo
                            Thomas Braun Most Active @Kuddel last edited by
                            @Kuddel
                            Ja, und wo ist die Vereinfachung?
                            Änder einfach ein Zeichen in der /etc/apt/sources.list.d/nodesource.list und du bist da. Oder schreib direkt die passende neue Zeile per tee da rein.
                              Kuddel @Thomas Braun last edited by
                              @Thomas-Braun oh so einfach 😄
                              okay, dann ist mein Skript überflüssig ^^
                                @Kuddel
                                Hier hab ich mal erklärt, wie das imho am besten und schnellsten und saubersten zu handeln ist:
                                https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
                                Das könnte man natürlich auch in ein skript packen. Aber so wenige und unregelmäßig vorkommende Dinge muss man meiner Meinung nach nicht skripten.
                                Einmal das passende Repo anlegen und dann hat man da ja bis zum nächsten Release-Wechsel Ruhe. Und ob ich mich beim Wechsel auf eine weitere node-Version dann an ein herumliegendes shell-skript erinner wage ich auch mal zu bezweifeln.
                                • Diginix
                                  Diginix @Thomas Braun last edited by
                                  @Thomas-Braun
                                  Wann ist
                                  npm rebuild
                                  notwendig?
                                    Thomas Braun Most Active @Diginix last edited by Thomas Braun
                                    @Diginix
                                    Das ist ggf. bei Wechseln der node-Version erforderlich, dann muss das modul gegen die neue Version gebaut werden. In den meisten Fällen macht der js-controller das aber selbstständig, wenn der Bedarf erkannt wurde.
                                    Mit direktem hantieren mit npm im Verzeichnis /opt/iobroker wäre ich aber vorsichtig, besser mit dem wrapper iobroker da ran gehen:
                                    iobroker rebuild <adapter>|self [--install]
                                      MyMeyer last edited by MyMeyer
                                      Hallo , habe auf meinen Master und Slave das Update auf Node 12.20.2 gemacht. Master läuft alles , aber auf dem Slave kommt der Smartmeter Adapter nicht hoch. Siehe Meldung aus dem Log:
                                      host.iobroker-slave	2021-02-20 10:53:52.948	info	Rebuild for adapter system.adapter.smartmeter.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                      host.iobroker-slave	2021-02-20 10:53:52.948	error	instance system.adapter.smartmeter.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                      host.iobroker-slave	2021-02-20 10:53:52.946	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
                                      host.iobroker-slave	2021-02-20 10:53:52.946	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
                                      host.iobroker-slave	2021-02-20 10:53:52.945	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
                                      host.iobroker-slave	2021-02-20 10:53:52.944	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
                                      host.iobroker-slave	2021-02-20 10:53:52.943	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/@serialport/bindings/node_modules/bindings/bindings.js:112:48)
                                      host.iobroker-slave	2021-02-20 10:53:52.942	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
                                      host.iobroker-slave	2021-02-20 10:53:52.941	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
                                      host.iobroker-slave	2021-02-20 10:53:52.940	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
                                      host.iobroker-slave	2021-02-20 10:53:52.939	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
                                      host.iobroker-slave	2021-02-20 10:53:52.939	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1057:18)
                                      host.iobroker-slave	2021-02-20 10:53:52.938	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                                      host.iobroker-slave	2021-02-20 10:53:52.937	error	Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                                      host.iobroker-slave	2021-02-20 10:53:52.936	error	Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
                                      host.iobroker-slave	2021-02-20 10:53:52.935	error	Caught by controller[0]: was compiled against a different Node.js version using
                                      host.iobroker-slave	2021-02-20 10:53:52.934	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'
                                      host.iobroker-slave	2021-02-20 10:53:52.933	error	Caught by controller[0]: ^
                                      host.iobroker-slave	2021-02-20 10:53:52.932	error	Caught by controller[0]: throw e;
                                      host.iobroker-slave	2021-02-20 10:53:52.930	error	Caught by controller[0]: /opt/iobroker/node_modules/@serialport/bindings/node_modules/bindings/bindings.js:121
                                      host.iobroker-slave	2021-02-20 10:53:49.275	info	instance system.adapter.smartmeter.0 started with pid 628
                                      8416b3da-5a69-4dda-9cca-3bf1dbdbf6ec-image.png f875dc8d-101b-45eb-a5ab-982b36c4e103-image.png
                                      Was kann ich tun ?
                                        Thomas Braun Most Active @MyMeyer last edited by
                                        @mymeyer Bitte LogFiles in CodeTags setzen
                                          @mymeyer
                                            MyMeyer @Thomas Braun last edited by MyMeyer
                                            @thomas-braun sagte in [How-to] Node.js für ioBroker richtig updaten:
                                            @mymeyer
                                            Direkt auf dem Slave im Adapter Verzeichnis oder reicht /opt/iobroker ?
                                            Oder gesagt das habe ich bereist auf dem Slave gemacht.
                                            pi@iobroker-slave:~ $ cd /opt/iobroker/
                                            pi@iobroker-slave:/opt/iobroker $ npm install --production
                                            npm ERR! code ENOTDIR
                                            npm ERR! syscall open
                                            npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller/node_modules/ms/npm-shrinkwrap.json
                                            npm ERR! errno -20
                                            npm ERR! ENOTDIR: not a directory, open '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ms/npm-shrinkwrap.json'
                                            npm ERR!     /home/iobroker/.npm/_logs/2021-02-20T09_53_20_943Z-debug.log
                                            1.0k
                                            installation linux node node.js nodejs windows
                                            106
                                            1105
                                            734008
