    • simatec
      simatec Developer Most Active @Zefau last edited by
      @Zefau
      Bisher konnte ich nur dies loggen:
      Failed to load resource: the server responded with a status of 404 (Not Found)
      Connection.js:39 Connecting to http://192.168.123.34:8082 unsuccessful.
      (anonymous) @ Connection.js:39
      s.emit @ events.js:153
      (anonymous) @ Socket.js:48
      a.emit @ index.js:145
      h.emit @ socket.js:138
      h.emitAll @ manager.js:82
      (anonymous) @ manager.js:243
      d.onError @ socket.js:690
      (anonymous) @ socket.js:281
      i.onError @ transport.js:71
      (anonymous) @ polling-xhr.js:132
      c.onError @ polling-xhr.js:314
      (anonymous) @ polling-xhr.js:261
      Connection.js:67 Failed connecting to http://192.168.123.34:8082!
      (anonymous) @ Connection.js:67
      Failed to decode downloaded font: <URL>
      index.html:1 Failed to decode downloaded font: http://192.168.123.34:8082/jarvis/fonts/materialdesignicons-webfont.woff2?v=5.8.55
      index.html#tab=home-0:1 Failed to decode downloaded font: http://192.168.123.34:8082/jarvis/fonts/materialdesignicons-webfont.woff2?v=5.8.55
      index.html#tab=klima-1:1 Failed to decode downloaded font: http://192.168.123.34:8082/jarvis/fonts/materialdesignicons-webfont.woff2?v=5.8.55
      index.html#tab=rollladen-2:1 Failed to decode downloaded font: http://192.168.123.34:8082/jarvis/fonts/materialdesignicons-webfont.woff2?v=5.8.55
      13OTS parsing error: Failed to convert WOFF 2.0 font to SFNT
      index.html:1 OTS parsing error: Failed to convert WOFF 2.0 font to SFNT
      index.html#tab=home-0:1 OTS parsing error: Failed to convert WOFF 2.0 font to SFNT
      index.html#tab=klima-1:1 OTS parsing error: Failed to convert WOFF 2.0 font to SFNT
      index.html#tab=rollladen-2:1 OTS parsing error: Failed to convert WOFF 2.0 font to SFNT
      DevTools failed to load SourceMap: Could not load content for http://192.168.123.43:8082/lib/js/socket.io.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
      Dazu kommen noch die Meldungen von allen Geräten ... Hier ein Auszug davon:
      Bad_Deckenleuchte -32 0 -Infinity 0 0 0 32
      StateListItem.js:139 Bad_Spiegelschrank -32 0 -Infinity 0 0 0 32
      StateListItem.js:139 HWR_Dauerlicht -32 0 -Infinity 0 0 0 32
      StateListItem.js:139 Flur_Dauerlicht -32 0 -Infinity 0 0 0 32
      StateListItem.js:139 Außenlampe_vorn_1vl -32 0 -Infinity 0 0 0 32
      StateListItem.js:139 Außenlampe_vorn_2vl -32 0 -Infinity 0 0 0 32
      StateListItem.js:139 Außenlampe_vorn_3vl -32 0 -Infinity 0 0 0 32
      StateListItem.js:139 Außenlampe_vorn_4vl -32 0 -Infinity 0 0 0 32
      StateListItem.js:139 Außenlampe_vorn_5vl -32 0 -Infinity 0 0 0 32
      StateListItem.js:139 Außenlampe_seite_1vl -32 0 -Infinity 0 0 0 32
      StateListItem.js:139 Außenlampe_seite_2vl -32 0 -Infinity 0 0 0 32
      StateListItem.js:139 Außenlampe_seite_3vl -32 0 -Infinity 0 0 0 32
      StateListItem.js:139 Außenlampe_hinten_1vl -32 0 -Infinity 0 0 0 32
      StateListItem.js:139 Außenlampe_hinten_2vl -32 0 -Infinity 0 0 0 32
      StateListItem.js:139 Aussenbeleuchtung_hinten -32 0 -Infinity 0 0 0 32
      StateListItem.js:139 Aussenbeleuchtung_vorn -32 0 -Infinity 0 0 0 32
      StateListItem.js:139 Aussenbeleuchtung_Seite -32 0 -Infinity 0 0 0 32
      StateListItem.js:139 Aussenbeleuchtung_Gesamt -32 0 -Infinity 0 0 0 32
      StateListItem.js:139 Licht Terrasse -32 0 -Infinity 0 0 0 32
      Hilft dir das etwas?
      • Zefau
        Zefau @stephan1827 last edited by
        @stephan1827 sagte in jarvis - just another remarkable vis:
        Dies ist die gleiche Einstellung wie ganz oben aber jetzt bekomme ich einen weißen Bildschirm mit der folgenden Fehlermeldung.
        Versuch mal bitte die v1.1.0-beta.129.
        stephan1827 1 Reply Last reply Reply Quote 0
        • Zefau
          Zefau @simatec last edited by
          @simatec sagte in jarvis - just another remarkable vis:
          Jo, hilft sehr. Bin sehr verwundert, dass bei dir -Infinity steht. Sehr merkwürdig. Prüf mal bitte die v1.1.0-beta.129.
          simatec M 3 Replies Last reply Reply Quote 0
          • simatec
            @Zefau
            Nun steht -Infintity nicht mehr im Log
            Außenlampe_vorn_1vl 353 500 0.706 500 56 59 32
            StateListItem.js:140 Außenlampe_vorn_2vl 353 500 0.706 500 56 59 32
            StateListItem.js:140 Außenlampe_vorn_3vl 353 500 0.706 500 56 59 32
            StateListItem.js:140 Außenlampe_vorn_4vl 353 500 0.706 500 56 59 32
            StateListItem.js:140 Außenlampe_vorn_5vl 353 500 0.706 500 56 59 32
            StateListItem.js:140 Außenlampe_seite_1vl 353 500 0.706 500 56 59 32
            StateListItem.js:140 Außenlampe_seite_2vl 353 500 0.706 500 56 59 32
            StateListItem.js:140 Außenlampe_seite_3vl 353 500 0.706 500 56 59 32
            StateListItem.js:140 Außenlampe_hinten_1vl 353 500 0.706 500 56 59 32
            StateListItem.js:140 Außenlampe_hinten_2vl 353 500 0.706 500 56 59 32
            StateListItem.js:140 Aussenbeleuchtung_hinten 353 500 0.706 500 56 59 32
            StateListItem.js:140 Aussenbeleuchtung_vorn 353 500 0.706 500 56 59 32
            StateListItem.js:140 Aussenbeleuchtung_Seite 353 500 0.706 500 56 59 32
            StateListItem.js:140 Aussenbeleuchtung_Gesamt 353 500 0.706 500 56 59 32
            StateListItem.js:140 Licht Terrasse 353 500 0.706 500 56 59 32
            Auf den ersten Blick, scheint die Auflösung nun auch zu passen ... Aber oft passierte es noch einiger Zeit erst ... Ich beobachte mal eine Weile
              Bloody last edited by
              @Zefau
              Ich habe mit der Beta 129 das Problem beim verschieben der Geräte in der Widget Konfiguration, dass dann alle Geräte so heißen, wie das was ich verschoben habe. Im Beispiel halt Briefkasten.
              Vorher:
              Nachher:
                MCU @Zefau last edited by MCU
                @Zefau v1.1.0-beta.130
                Sehr schöne Gruppierung bei den Geräten:
                Leider kann man bei den nicht importierten Geräten keine Manufacturer angeben, kommt das noch?
                Beim Wechsel von Geräte auf Einstellungen und zurück wird immer wieder "Gewerk" als Auswahl genommen, obwohl man vorher "Manufacturer" ausgewählt hatte.
                Bei jedem Popup-Klick bekommt man ein Eintrag ins Log:
                jarvis.0	2020-11-23 06:03:07.717	info	(8545) Retrieved 1 states for device Aktuelle Alexa Lautstärke. ["0"]
                jarvis.0	2020-11-23 06:02:51.184	info	(8545) Retrieved 4 states for device HUE-BAD-Temp5. ["0","1","2","3"]
                jarvis.0	2020-11-23 06:02:48.521	info	(8545) Retrieved 5 states for device Bad. ["0","1","2","3","4"]
                jarvis.0	2020-11-23 06:01:24.918	info	(8545) Retrieved 4 states for device HUE-BAD-Temp5. ["0","1","2","3"]
                jarvis.0	2020-11-23 06:01:07.291	info	(8545) Retrieved 4 states for device HUE-BAD-Temp5. ["0","1","2","3"]
                Eigentlich sinnvoll, besser wäre es optional einstellbar in den Einstellungen.
                Kann man bei den Elementen in den Geräten den Status vom Dark-Mode mit einfließen lassen?
                Also es geht um einzelne DP, die bei Dark-Mode: False den Hintergrund ändern. Bei Dark-Mode:true würde diese Hintergrund-Änderung aber nicht mehr passen.
                Gibt es eine Einstellung mit der man die Schriftgröße für die Überschriften allgemein ändern kann:
                Man würde gerade beim Handy mehr auf den Bildschirm bekommen.
                http://192.168.178.89:8082/jarvis/index.html#tab=termine-3 springt nicht zur gewünschten Seite. Bleibt auf der Seite, die gerade geöffnet ist. Bei neuem leerem Tab(Firefox) , wird der letzte geöffnete Tab (Jarvis) damit geöffnet.
                Wünschenswert wäre noch das man mit "wischen links/rechts swipe" den Tab wechseln könnte.
                Danke.
                • stephan1827
                  stephan1827 @Zefau last edited by stephan1827
                  @Zefau said in jarvis - just another remarkable vis:
                  Danke für die schnelle Antwort. Habe gerade die 130 getestet, leider immer noch das gleiche Problem.
                  Ich habe das Problem noch etwas genauer unter die Lupe genommen. Wenn ich bei Heizung Küche die Werte ändere wird einer der Eigenschaften nicht erstellt. Der Code für die Wohnzimmer Heizung sieht so aus
                                             "type": "device",
                                             "deviceId": "wohnzimmerheizung_61c1f",
                                             "primaryStateKey": "temperature",
                                             "secondaryStatesKeys": [
                                                "setTemperature"
                                             "label": "Heizung",
                                             "actionType": "state",
                                             "actionElement": "",
                                             "bodyElement": "LevelBody",
                                             "bodyStateKey": "setTemperature",
                                             "LevelBodyConfig": {
                                                "temperature-step": "0.5",
                                                "temperature-markStep": "10",
                                                "setTemperature-step": "0.5",
                                                "setTemperature-markStep": "15"
                  Der Code für die Heizung Küche sieht so aus
                                             "type": "device",
                                             "deviceId": "kücheheizung_a2252",
                                                "setTemperature"
                                             "label": "Küche",
                  Bei LevelBodyConfig fehlt hier der Eintrag "temperature-markStep": "10",
                  Zefau 2 Replies Last reply Reply Quote 0
                    WW1983 @Zefau last edited by
                    Gibt es jetzt noch irgendwelche Bugs ?
                    Außer
                    1. das mit den Charts (in Klärung mit @creatsher)
                    2. den nicht-aktualisierenden States (in Klärung mit @WW1983 / @MarkusMac)
                    3. den Design Abweichungen (in Klärung mit @simatec).
                    Bei mir lief Jarvis nun die Nacht durch und die States aktualisieren sich immer noch. Scheint als wäre das Problem behoben. Danke
                    • simatec
                      Bekommt man die markierten Icons farblich angepasst?
                      Konnte leider nichts finden ...
                      W C 2 Replies Last reply Reply Quote 0
                        WW1983 @simatec last edited by
                        @simatec Ja, du kannst die über Icon-Stil anpassen. Hier ein Beispiel von mir. Dor habe ich nur den Wert "true" farblich angepasst:
                        • simatec
                          simatec Developer Most Active @WW1983 last edited by
                          @WW1983 sagte in jarvis - just another remarkable vis:
                          true
                          Danke für den Tipp ... Dann muss ich jedes Gerät anfassen. Dachte es gibt eventuell etwas globales 😉
                            creatsher @simatec last edited by
                            @simatec Bei mir sind sie das automatisch!?
                            simatec 1 Reply Last reply Reply Quote 1
                              @simatec Ja geht auch. Die richten sich nach der Primärfarbe (wie deine Menüleiste oben)
                                Weiß zufällig jemand wie ich meine Menüleiste oben abweichend von der Primärfarbe einfärben kann?
                                • simatec
                                  simatec Developer Most Active @creatsher last edited by
                                  @creatsher Ja im Dark und wenn man den Theme nicht händisch anpasst
                                  • simatec
                                    @WW1983 und genau die Menüleiste soll eine andere Farbe bekommen
                                      @simatec wie gesagt, die Menüleiste und die Icons sind an die Primärfarbe gekoppelt. Wenn das für dich passt, dann musst du nur die Primärfarbe in der Einstellung ändern:
                                      Wie man die entkoppelt von einander bearbeitet, weiß ich leider auch nicht.
                                      • simatec
                                        @WW1983 Ja genau da liegt das Problem. Ich will das unabhängig bearbeiten.
                                        Die Menüleiste soll Blau bleiben
                                          WW1983 @simatec last edited by WW1983
                                          @simatec Dann geht es aktuell wohl nur so, dass man die einzelnen Icons bearbeitet
                                          Die Theme-Anpassungen sind ab der Versionen 3.0 geplant (wenn ich das richtig gesehen habe)
                                            MarkusMac @WW1983 last edited by
                                            @WW1983 said in jarvis - just another remarkable vis:
                                            Außer
                                            @WW1983, darf ich fragen, wie dein Setup aussieht? Tablet mit dem Fully Kiosk Browser? Lässt du den Screen dauerhaft eingeschaltet (und dimmst ihn ggf. nur herunter) oder schaltest du den Screen richtig aus und wieder an?
                                            Ich habe momentan noch die 126laufen und bei mir frieren sie States jetzt nicht mehr ein, allerdings habe ich umgestellt, so dass mein Screen nur auf Helligkeit 1 von 255 abdunkelt. Ich meine, dass ich vorher mit der 126 auch das normale Ausschalten des Screens getestet hatte und da sind die States weiterhin eingefroren.
                                            316
                                            6126
                                            4115785
