    3. Entwicklung
    4. ZigBee neue/unbekannte Geräte - ab 1.3.0
    • D3ltoroxp
      D3ltoroxp @arteck last edited by
      @arteck Die Steckdose habe ich auch und mit der neusten Git Version funktioniert sie wunderbar.
      Danke @arteck
        DocGame last edited by DocGame
        Ich habe Probleme dieses Tuya-Relais reinzubekommen.
        Supportet müsste es eigentlich sein. Ist da sonst noch eine Fehler?
        zigbee.0	2020-11-21 16:04:50.610	error	(26307) Device 0x588e81fffed981fe "TS011F_socket_module" not described in statesMapping.
        zigbee.0	2020-11-21 16:04:49.417	error	(26307) Device 0x588e81fffed981fe "TS011F_socket_module" not described in statesMapping.
        zigbee.0	2020-11-21 16:04:17.193	error	(26307) Device 0x588e81fffed981fe "TS011F_socket_module" not described in statesMapping.
        zigbee.0	2020-11-21 16:04:14.487	error	(26307) Device 0x588e81fffed981fe "TS011F_socket_module" not described in statesMapping.
        zigbee.0	2020-11-21 16:04:14.053	error	(26307) Device 0x588e81fffed981fe "TS011F_socket_module" not described in statesMapping.
        zigbee.0	2020-11-21 16:04:14.052	error	(26307) Device 0x588e81fffed981fe "TS011F_socket_module" not described in statesMapping.
        zigbee.0	2020-11-21 16:04:13.492	error	(26307) Device 0x588e81fffed981fe "TS011F_socket_module" not described in statesMapping.
        zigbee.0	2020-11-21 16:04:13.487	error	(26307) Device 0x588e81fffed981fe "TS011F_socket_module" not described in statesMapping.
        zigbee.0	2020-11-21 16:04:13.487	info	(26307) Device '0x588e81fffed981fe' is supported, identified as: TuYa Socket module (TS011F_socket_module)
        zigbee.0	2020-11-21 16:04:13.486	info	(26307) Successfully interviewed '0x588e81fffed981fe', device has succesfully been paired
        zigbee.0	2020-11-21 16:04:13.377	error	(26307) Device 0x588e81fffed981fe "TS011F_socket_module" not described in statesMapping.
        zigbee.0	2020-11-21 16:04:13.273	error	(26307) Device 0x588e81fffed981fe "TS011F_socket_module" not described in statesMapping.
        zigbee.0	2020-11-21 16:04:13.202	error	(26307) Device 0x588e81fffed981fe "TS011F_socket_module" not described in statesMapping.
        zigbee.0	2020-11-21 16:04:12.949	error	(26307) Device 0x588e81fffed981fe "TS011F_socket_module" not described in statesMapping.
        zigbee.0	2020-11-21 16:04:12.844	error	(26307) Device 0x588e81fffed981fe "TS011F_socket_module" not described in statesMapping.
        zigbee.0	2020-11-21 16:04:12.740	error	(26307) Device 0x588e81fffed981fe "TS011F_socket_module" not described in statesMapping.
        zigbee.0	2020-11-21 16:04:12.637	warn	(26307) should configure with NULL : {"ID":38,"_type":"Router","_ieeeAddr":"0x588e81fffed981fe","_networkAddress":20649,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"deviceID":9,"inpu
        zigbee.0	2020-11-21 16:04:11.674	info	(26307) Starting interview of '0x588e81fffed981fe'
        zigbee.0	2020-11-21 16:04:10.161	info	(26307) Zigbee: allowing new devices to join.
        TuYa TS011F zigbee2mqtt.io Link
        • toni
          toni @arteck last edited by
          @arteckBildschirmfoto 2020-11-22 um 15.41.39.png Bildschirmfoto 2020-11-22 um 15.40.44.png
            arteck Developer Most Active @DocGame last edited by
            @DocGame jetzt
              arteck Developer Most Active @toni last edited by
              @toni neue adapter version installieren und nochmal checken
                DocGame @arteck last edited by
                @arteck 👍 Danke....Ist drin
                  RS last edited by
                  Hallo hätte eine bitte,
                  wäre es möglich diese Lampe von HUE hinzuzufügenKachel.JPG Informationen.JPG
                  https://www.amazon.de/Philips-Hue-Erweiterung-warmweißes-kompatibel/dp/B0152WXI0E/ref=sr_1_13?adgrpid=72789819002&dchild=1&gclid=EAIaIQobChMIjP77zpmZ7QIVUud3Ch2DVAwiEAAYASAAEgJscPD_BwE&hvadid=352756286125&hvdev=c&hvlocphy=9042250&hvnetw=g&hvqmt=b&hvrand=2324547971509752261&hvtargid=kwd-299530017350&hydadcr=13860_1725593&keywords=philips+hue+e27&qid=1606152887&sr=8-13&tag=googhydr08-21
                  ich hoffe die Infos sind ok so.
                  MfG
                  RS
                  • Holger Etzel
                    Holger Etzel last edited by
                    ich hätte mal wieder einen Schalter.
                    Vielleicht kann sich jemand dem Schalter annehmen und hinzufügen.
                    Danke schon mal im voraus.
                      RS @RS last edited by
                      @RS
                      mit der Version 1.3.9dev funktioniert es jetzt.
                      Trotzdem Danke
                        arteck Developer Most Active @RS last edited by arteck
                        @RS du hast eine alpha Version isntalliert... mal so ganz neben bei..da geht vielles aber noch nicht alles
                        https://forum.iobroker.net/topic/38971/zigbee-neue-version-1-3-1dev-auf-git
                        • toni
                          @arteck erstmal Danke für die Hilfe der Aqara Wall Switch ist jetzt drin! Jedoch funktioniert das "click event" nicht. Vielleicht kannst du auch dieses Problem noch lösen?
                          Zur Info: Ich konnte den switch nur über den CC2531 Stick, jedoch nicht über den Conbee 2 verbinden (Zigbee2MQTT, V.: 1.3.1)
                            Holgee last edited by
                            Servus,
                            gerade eben habe ich auf gut Glück einen Viessmann ViCare Heizkörper-Thermostat "Model ZK03840" ausprobiert, der mir aber leider nicht korrekt in der 1.3.9dev erkannt wurde. Über zigbee2mqtt solle er angeblich laufen.
                            Model ZK03840
                            Kopplungsfortschritt:
                            Error: Device 0x90fd9ffffe4a5ee3 "ZK03840" not described in statesMapping.. undefined
                            New device joined '0x90fd9ffffe4a5ee3' model ZK03840
                            Interview successful: {"friendly_name":"0x90fd9ffffe4a5ee3","model":"ZK03840","vendor":"Viessmann","description":"ViCare radiator thermostat valve","supported":true}
                            Device '0x90fd9ffffe4a5ee3' announced itself
                            Interview started: 0x90fd9ffffe4a5ee3
                            Pairing started
                            Wäre cool, den in ioBroker nutzen zu können 😎
                            Holger
                              arteck Developer Most Active @Holgee last edited by
                              @Holgee der ist zwar drin aber nich nicht zu ende ausgeprägt..das wird dauern
                              Holger Etzel 1 Reply Last reply Reply Quote 0
                              • Holger Etzel
                                Holger Etzel @arteck last edited by
                                @arteck
                                Ich habe aber immer ein Pech
                                • Asgothian
                                  Asgothian Developer @Holger Etzel last edited by
                                  @Holgee
                                  Wir können zusammen versuchen die fehlenden Teile in Gang zu bekommen - entweder per discord + anydesk, oder Du sendest mir einen Thermostat als Arbeitsobjekt und ich schick den zurück wenn ich durch bin.
                                  Das wäre der 4. Thermostat für mich.
                                  A.
                                    MartyBr last edited by MartyBr
                                    ich habe hier 4 NeoSmart Plugs.
                                    Hersteller: immax
                                    Typ: 07048L
                                    Edit 13:46 Uhr
                                    Zigbee Adapter 1.3.1
                                    code_text
                                    zigbee.0	2020-11-27 13:27:42.262	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 13:27:36.685	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 13:27:36.231	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 13:27:36.230	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 13:27:36.116	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 13:27:36.115	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 13:27:35.707	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 13:27:35.570	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 13:27:35.454	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 13:27:35.335	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 13:27:35.220	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 13:27:35.109	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 13:27:34.987	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 13:27:34.871	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 13:27:34.759	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 13:27:34.613	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 13:27:11.275	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 13:27:10.856	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 13:27:10.736	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 13:27:10.286	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 13:27:10.170	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 13:27:10.055	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 13:27:09.940	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 13:27:09.825	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 13:27:09.709	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 13:27:09.588	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 13:27:09.476	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 13:27:09.362	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 13:27:09.238	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 13:27:09.233	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    Werden weitere Daten benötigt? Muss der Adapter im Debug Modus laufen?
                                    Edit 17:25 Uhr
                                    Start Adapter im Debug Modus:
                                    zigbee.0	2020-11-27 17:24:52.646	debug	(28071) No converter available for 'RB 250 C' with cluster 'genOta' and type 'commandQueryNextImageRequest'
                                    zigbee.0	2020-11-27 17:24:52.645	debug	(28071) Type commandQueryNextImageRequest device {"type":"device","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x14b457fffe2be766","_networkAddress":53069,"_manufacturerID":4454,"_endpoints":[{"ID":
                                    zigbee.0	2020-11-27 17:24:52.645	debug	(28071) Received Zigbee message from '0x14b457fffe2be766', type 'commandQueryNextImageRequest', cluster 'genOta', data '{"fieldControl":0,"manufacturerCode":4454,"imageType":281,"fileVersion":27730795
                                    zigbee.0	2020-11-27 17:24:52.645	debug	(28071) handleMessage. {"type":"commandQueryNextImageRequest","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x14b457fffe2be766","_networkAddress":53069,"_manufacturerID":4454,"_endpoints":[{"ID":1,"p
                                    zigbee.0	2020-11-27 17:24:49.615	debug	(28071) No converter available for 'RB 250 C' with cluster 'genOta' and type 'commandQueryNextImageRequest'
                                    zigbee.0	2020-11-27 17:24:49.613	debug	(28071) Type commandQueryNextImageRequest device {"type":"device","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x14b457fffe2be766","_networkAddress":53069,"_manufacturerID":4454,"_endpoints":[{"ID":
                                    zigbee.0	2020-11-27 17:24:49.612	debug	(28071) Received Zigbee message from '0x14b457fffe2be766', type 'commandQueryNextImageRequest', cluster 'genOta', data '{"fieldControl":0,"manufacturerCode":4454,"imageType":281,"fileVersion":27730795
                                    zigbee.0	2020-11-27 17:24:49.612	debug	(28071) handleMessage. {"type":"commandQueryNextImageRequest","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x14b457fffe2be766","_networkAddress":53069,"_manufacturerID":4454,"_endpoints":[{"ID":1,"p
                                    zigbee.0	2020-11-27 17:24:46.580	debug	(28071) No converter available for 'RB 250 C' with cluster 'genOta' and type 'commandQueryNextImageRequest'
                                    zigbee.0	2020-11-27 17:24:46.579	debug	(28071) Type commandQueryNextImageRequest device {"type":"device","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x14b457fffe2be766","_networkAddress":53069,"_manufacturerID":4454,"_endpoints":[{"ID":
                                    zigbee.0	2020-11-27 17:24:46.579	debug	(28071) Received Zigbee message from '0x14b457fffe2be766', type 'commandQueryNextImageRequest', cluster 'genOta', data '{"fieldControl":0,"manufacturerCode":4454,"imageType":281,"fileVersion":27730795
                                    zigbee.0	2020-11-27 17:24:46.578	debug	(28071) handleMessage. {"type":"commandQueryNextImageRequest","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x14b457fffe2be766","_networkAddress":53069,"_manufacturerID":4454,"_endpoints":[{"ID":1,"p
                                    zigbee.0	2020-11-27 17:24:43.548	debug	(28071) No converter available for 'RB 250 C' with cluster 'genOta' and type 'commandQueryNextImageRequest'
                                    zigbee.0	2020-11-27 17:24:43.546	debug	(28071) Type commandQueryNextImageRequest device {"type":"device","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x14b457fffe2be766","_networkAddress":53069,"_manufacturerID":4454,"_endpoints":[{"ID":
                                    zigbee.0	2020-11-27 17:24:43.546	debug	(28071) Received Zigbee message from '0x14b457fffe2be766', type 'commandQueryNextImageRequest', cluster 'genOta', data '{"fieldControl":0,"manufacturerCode":4454,"imageType":281,"fileVersion":27730795
                                    zigbee.0	2020-11-27 17:24:43.545	debug	(28071) handleMessage. {"type":"commandQueryNextImageRequest","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x14b457fffe2be766","_networkAddress":53069,"_manufacturerID":4454,"_endpoints":[{"ID":1,"p
                                    zigbee.0	2020-11-27 17:24:40.507	debug	(28071) No converter available for 'RB 250 C' with cluster 'genOta' and type 'commandQueryNextImageRequest'
                                    zigbee.0	2020-11-27 17:24:40.505	debug	(28071) Type commandQueryNextImageRequest device {"type":"device","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x14b457fffe2be766","_networkAddress":53069,"_manufacturerID":4454,"_endpoints":[{"ID":
                                    zigbee.0	2020-11-27 17:24:40.504	debug	(28071) Received Zigbee message from '0x14b457fffe2be766', type 'commandQueryNextImageRequest', cluster 'genOta', data '{"fieldControl":0,"manufacturerCode":4454,"imageType":281,"fileVersion":27730795
                                    zigbee.0	2020-11-27 17:24:40.504	debug	(28071) handleMessage. {"type":"commandQueryNextImageRequest","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x14b457fffe2be766","_networkAddress":53069,"_manufacturerID":4454,"_endpoints":[{"ID":1,"p
                                    zigbee.0	2020-11-27 17:24:07.156	error	(28071) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 17:24:07.156	debug	(28071) Publish available for 0xccccccfffeeaa411 = true
                                    zigbee.0	2020-11-27 17:24:07.156	debug	(28071) Publish available for 0x14b457fffe2be766 = true
                                    zigbee.0	2020-11-27 17:24:07.151	debug	(28071) Publish available for 0x00158d0004186d23 = true
                                    zigbee.0	2020-11-27 17:24:06.222	error	(28071) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 17:24:06.157	info	(28071) Zigbee started
                                    zigbee.0	2020-11-27 17:24:06.156	info	(28071) 0xccccccfffeeaa411 (addr 10186): 07048L - Immax NEO SMART plug (Router)
                                    zigbee.0	2020-11-27 17:24:06.156	debug	(28071) New device event: {"type":"device","device":{"ID":4,"_type":"Router","_ieeeAddr":"0xccccccfffeeaa411","_networkAddress":10186,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"devi
                                    zigbee.0	2020-11-27 17:24:06.156	info	(28071) 0x14b457fffe2be766 (addr 53069): RB 250 C - Innr E14 bulb RGBW (Router)
                                    zigbee.0	2020-11-27 17:24:06.155	debug	(28071) New device event: {"type":"device","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x14b457fffe2be766","_networkAddress":53069,"_manufacturerID":4454,"_endpoints":[{"ID":1,"profileID":260,"devi
                                    zigbee.0	2020-11-27 17:24:06.154	info	(28071) 0x00158d0004186d23 (addr 11972): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                    zigbee.0	2020-11-27 17:24:06.152	debug	(28071) New device event: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x00158d0004186d23","_networkAddress":11972,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"d
                                    zigbee.0	2020-11-27 17:24:06.150	debug	(28071) DeviceConfigure 0xccccccfffeeaa411 Plug-230V-ZB3.0 not needed
                                    zigbee.0	2020-11-27 17:24:06.150	debug	(28071) DeviceConfigure 0x14b457fffe2be766 RB 250 C not needed
                                    zigbee.0	2020-11-27 17:24:06.150	debug	(28071) DeviceConfigure 0x00158d0004186d23 lumi.weather not needed
                                    zigbee.0	2020-11-27 17:24:06.150	error	(28071) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 17:24:06.150	debug	(28071) Publish available for 0xccccccfffeeaa411 = true
                                    zigbee.0	2020-11-27 17:24:06.149	debug	(28071) Publish available for 0x14b457fffe2be766 = true
                                    zigbee.0	2020-11-27 17:24:06.149	debug	(28071) Publish available for 0x00158d0004186d23 = true
                                    zigbee.0	2020-11-27 17:24:06.149	info	(28071) Currently 3 devices are joined:
                                    zigbee.0	2020-11-27 17:24:06.144	info	(28071) --> transmitPower : high
                                    zigbee.0	2020-11-27 17:24:06.144	info	(28071) Unable to disable LED, unsupported function.
                                    zigbee.0	2020-11-27 17:24:06.144	info	(28071) Disable LED
                                    zigbee.0	2020-11-27 17:24:06.144	debug	(28071) Zigbee network parameters: {"panID":6756,"extendedPanID":"0xddddddddddddddde","channel":11}
                                    zigbee.0	2020-11-27 17:24:06.139	info	(28071) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20200925}}
                                    zigbee.0	2020-11-27 17:24:06.138	debug	(28071) zigbee-herdsman started
                                    zigbee.0	2020-11-27 17:24:05.740	debug	(28071) system.adapter.admin.0: logging true
                                    zigbee.0	2020-11-27 17:24:04.251	debug	(28071) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2020_11_27-17_24_04.tar.gz success
                                    zigbee.0	2020-11-27 17:24:04.199	debug	(28071) Starting zigbee-herdsman...
                                    zigbee.0	2020-11-27 17:24:04.199	info	(28071) Starting Zigbee npm ...
                                    zigbee.0	2020-11-27 17:24:04.181	debug	(28071) Using zigbee-herdsman with settings: {"network":{"panID":6756,"extendedPanID":[222,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"datab
                                    zigbee.0	2020-11-27 17:24:04.170	info	(28071) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.19.1, js-controller: 3.1.6
                                    zigbee.0	2020-11-27 17:24:03.198	debug	(28071) statesDB connected
                                    zigbee.0	2020-11-27 17:24:03.197	debug	(28071) States connected to redis: 127.0.0.1:6379
                                    zigbee.0	2020-11-27 17:24:03.195	debug	(28071) States create System PubSub Client
                                    zigbee.0	2020-11-27 17:24:03.194	debug	(28071) States create User PubSub Client
                                    zigbee.0	2020-11-27 17:24:03.193	debug	(28071) Redis States: Use Redis connection: 127.0.0.1:6379
                                    zigbee.0	2020-11-27 17:24:03.192	debug	(28071) objectDB connected
                                    zigbee.0	2020-11-27 17:24:03.190	debug	(28071) Objects connected to redis: 0.0.0.0:9001
                                    zigbee.0	2020-11-27 17:24:03.177	debug	(28071) Objects client initialize lua scripts
                                    zigbee.0	2020-11-27 17:24:03.177	debug	(28071) Objects create User PubSub Client
                                    zigbee.0	2020-11-27 17:24:03.177	debug	(28071) Objects create System PubSub Client
                                    zigbee.0	2020-11-27 17:24:03.176	debug	(28071) Objects client ready ... initialize now
                                    zigbee.0	2020-11-27 17:24:03.159	debug	(28071) Redis Objects: Use Redis connection: 0.0.0.0:9001
                                    zigbee.0	2020-11-27 17:23:59.796	error	(28055) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 17:23:33.334	error	(28055) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 17:23:32.392	error	(28055) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 17:23:32.331	error	(28055) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 17:23:21.247	error	(28016) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 17:19:16.051	error	(28016) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 17:19:13.026	error	(28016) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 17:19:10.002	error	(28016) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 17:19:06.969	error	(28016) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 17:19:03.956	error	(28016) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 17:16:43.654	error	(28016) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 17:16:42.720	error	(28016) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 17:16:42.650	error	(28016) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 17:16:36.392	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 17:13:54.250	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 17:08:54.158	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 17:08:51.133	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 17:08:48.108	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 17:08:45.077	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 17:08:42.059	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 17:04:21.209	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:59:21.099	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:58:32.259	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:58:29.234	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:58:26.210	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:58:23.184	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:58:20.159	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:58:10.552	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:53:10.461	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:48:10.366	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:48:07.342	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:48:04.317	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:48:01.283	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:47:58.267	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:47:48.656	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:42:48.563	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:37:48.470	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:37:45.444	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:37:42.419	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:37:39.385	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:37:36.372	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:34:07.066	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:29:06.974	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:29:01.062	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:29:01.061	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:28:44.719	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:27:26.571	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:27:23.545	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:27:20.523	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:27:17.499	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:27:14.473	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:27:04.869	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:22:04.777	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:17:04.683	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:17:01.657	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:16:58.635	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:16:55.600	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:16:52.589	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                    zigbee.0	2020-11-27 16:16:42.972	error	(1488) Device 0xccccccfffeeaa411 "07048L" not described in statesMapping.
                                      Servus,
                                      @Asgothian: kein Problem, schicke ich Dir gerne zu, wenn Du mir Deine Adresse schreibst.
                                      Ich hätte da gleich noch einen Kandidaten:
                                      Heizkörperthermostat Saswell SEA802-Zigbee:
                                      Der wird zwar dem Anschein nach problemlos eingebunden,
                                      liefert aber leider keine verwertbaren Datenpunkte.
                                      e9bf85fc-8a36-4abb-828f-404ea4ede5da-image.png.
                                      Vielleicht lässt sich da ja auch gleich noch etwas optimieren 😉
                                      Holger
                                        @arteck
                                        Ich habe Log-Dateien in dem Beitrag eingefügt.
                                        https://forum.iobroker.net/topic/37453/zigbee-neue-unbekannte-geräte-ab-1-3-0/204
                                        • I
                                          io_laurent @MartyBr last edited by io_laurent
                                          @MartyBr hast du die 1.3.1 von GIT installiert? Wenn nicht, dann versuch das mal, ich hab die Plugs nämlich auch und bei mir laufen die mit der GIT-Version.
                                            MartyBr @io_laurent last edited by
                                            @io_laurent
                                            Danke für die Info. Ich habe jetzt auch die Git 1.3.9 installiert. Damit funktionieren die Plugs.
                                            converter herdsman neuer adapter zigbee
                                            50
                                            231
                                            28644
