    3. Entwicklung
    4. [Projekt] ioGo # Smarthome to go 2.0
      Fox1985 @Guest last edited by
      @nis
      So, jetzt habe ich mal etwas im Log
      javascript.0	2020-04-29 21:37:17.614	info	(919) script.js.Log_Kugelarhorn: Wert:#24010800
      javascript.0	2020-04-29 21:37:15.864	info	(919) script.js.Log_Kugelarhorn: Wert:#24151800
      javascript.0	2020-04-29 21:37:13.073	info	(919) script.js.Log_Kugelarhorn: Wert:#15172400
      javascript.0	2020-04-29 21:37:12.724	info	(919) script.js.Log_Kugelarhorn: Wert:14
      javascript.0	2020-04-29 21:37:11.563	info	(919) script.js.Log_Kugelarhorn: Wert:#92A2FC00
      javascript.0	2020-04-29 21:37:10.204	info	(919) script.js.Log_Kugelarhorn: Wert:#0A2EFC00
      javascript.0	2020-04-29 21:37:00.909	info	(919) script.js.Log_Kugelarhorn: registered 3 subscriptions and 0 schedules
      javascript.0	2020-04-29 21:37:00.901	info	(919) Start javascript script.js.Log_Kugelarhorn
      javascript.0	2020-04-29 21:37:00.794	info	(919) Stop script script.js.Log_Kugelarhorn
      javascript.0	2020-04-29 21:34:42.801	info	(919) script.js.Log_Kugelarhorn: registered 1 subscription and 0 schedules
      javascript.0	2020-04-29 21:34:42.781	info	(919) Start javascript script.js.Log_Kugelarhorn
      javascript.0	2020-04-29 21:34:40.275	info	(919) Stop script script.js.Log_Kugelarhorn
      Viele Grüße
        Jackal last edited by
        Tasmota
        "_id": "sonoff.0.Raum 1.Hue",
        "common": {
        "type": "number",
        "role": "level.color.hue",
        "read": true,
        "write": true,
        "min": 0,
        "name": "Raum 1 Hue"
        "native": {},
        "type": "state",
        "from": "system.adapter.sonoff.0",
        "user": "system.user.admin",
        "ts": 1588206948326,
        "acl": {
        "object": 1638,
        "state": 1638
        Yeelight
        "type": "state",
        "common": {
        "name": "hue",
        "write": true,
        "read": true,
        "type": "number",
        "min": 0,
        "max": 360,
        "smartName": {
        "de": "",
        "smartType": "LIGHT"
        "native": {},
        "from": "system.adapter.yeelight-2.0",
        "ts": 1584471519452,
        "_id": "yeelight-2.0.Lampe.control.hue",
        "acl": {
        "object": 1638,
        "state": 1638
          A Former User @Fox1985 last edited by
          @Fox1985 Funktioniert es wenn du in der App den Wert "#15172400" oder einen der anderen Werte direkt eingibst?
          J F 2 Replies Last reply Reply Quote 0
            Jackal @Guest last edited by
            @nis Ja. Aber man kann keine Buchstaben eingeben. Wäre bei Hex-Werten ja auch interessant. 😉
              A Former User @Jackal last edited by
              @Jackal das wäre sehr praktisch. Laut Dokumentation sollen jedoch nur numerische Werte in States mit einer level.* Rolle gespeichert werden.
              siehe dazu: https://github.com/ioBroker/ioBroker.docs/blob/master/docs/en/dev/stateroles.md#levels-numbers-read-write
              Komisch nur das dort auch RGB als HEX als möglicher Wert genannt wird...
                e-s @Guest last edited by
                @nis
                Naja wenn man so sieht heißt das ja auch hexadezimale zahl. Die Form ist zwar anders, da mit Buchstaben, aber vom Grundprinzip ist und bleibt es ja eine Zahl.
                  A Former User @e-s last edited by
                  @e-s achdumeinegüte du hast Recht und ich hab Arbeit 🙂
                    @nis
                    Ja das funktioniert, die Werte werden automatisch etwas korrigiert.
                    Man tippt halt ziemlich im dunkeln.
                      cortana last edited by cortana
                      Hallo @nis
                      ich hoffe der Thread hier ist noch aktuell.
                      Habe mir mal die App, den Adapter und eine Lizens gegönnt.
                      Mich interessiert bei der ganzen Geschichte hier die Location Angelegenheit.
                      Leider stoße ich bereits bei Adapter auf Probleme. Ich bekomme einfach keine Datenpunkte.
                      Mache ich was falsch? Ich hoffe du kannst mir helfen.
                      Nach ca. einer halben Stunde trudeln so langsam die ersten datenpunkte ein, allerdings anscheinend unvollständig.
                      Auch von der Location ist nichts zu sehen.
                      ? 2 Replies Last reply Reply Quote 0
                        A Former User @cortana last edited by
                        @cortana sagte in [Projekt] ioGo # Smarthome to go 2.0:
                        Das sollte deutlich schneller gehen. Kannst du dazu Logeinträge posten woraus die halbe Stunde hervorgeht?
                          Wie sieht die Location im Smartphone aus? Gut wäre ein Screenshot.
                          Hast du zufällig auch in der App Logging aktiviert und kannst das Logfile zur Verfügung stellen?
                            cortana @Guest last edited by
                            @nis
                            Ich sende dir mal das komplette log.
                            iogo.txt
                            Kann ich hier irgendwie eine PN senden. Ich möchte ungern ein Screenshot meiner location hier veröffentlichen.
                              am besten im Discord
                                @nis
                                wie finde ich dich auf discord
                                  @cortana https://discord.gg/wTVZV2b7 das ist ein eigener Raum, da findest du auch mich drin und kannst mir direkt schreiben
                                    cortana @Guest last edited by cortana
                                    ich habe folgende Beobachtungen währen der Einrichtung des Adapters und der App gemacht.
                                    Vielleicht kann mal jemand schauen ob das nachvollziehbar ist.
                                    1. In der App angelegte Locations welche dann auch im Adapter zu finden sind, werden nach dem Löschen in der App im Adapter nicht mehr gelöscht und werden zu Datenpunkt Leichen.
                                      Auch ein Neustart der Instanz bringt keine Lösung
                                      iogo.0.(device ID).locations.(location ID)
                                    2. Der Datenpunkt für die Akku Ladeanzeige hinkt der tatsächlichen Ladeanzeige des Gerätes hinterher und aktualisiert sich mit Verzögerungen bis zu 10 Minuten
                                      iogo.0.(device ID).battery.level
                                    iogo.0	2020-11-24 21:21:58.549	info	(9260) device update received: {"alive":false,"batteryCharging":true,"batteryLevel":100,"name":"Galaxy S9+"
                                    iogo.0	2020-11-24 21:06:58.125	info	(9260) device update received: {"alive":false,"batteryCharging":true,"batteryLevel":95,"name":"Galaxy S9+"
                                    iogo.0	2020-11-24 21:03:36.753	info	(9260) device update received: {"alive":false,"batteryCharging":true,"batteryLevel":84,"name":"Galaxy S9+"
                                    iogo.0	2020-11-24 20:52:58.287	info	(9260) device update received: {"alive":true,"batteryCharging":true,"batteryLevel":84,"name":"Galaxy S9+"
                                    iogo.0	2020-11-24 20:36:58.114	info	(9260) device update received: {"alive":true,"batteryCharging":true,"batteryLevel":69,"name":"Galaxy S9+"
                                    iogo.0	2020-11-24 20:31:42.829	info	(9260) device update received: {"alive":true,"batteryCharging":true,"batteryLevel":47,"name":"Galaxy S9+"
                                    iogo.0	2020-11-24 20:31:39.669	info	(9260) device update received: {"alive":false,"batteryCharging":true,"batteryLevel":47,"name":"Galaxy S9+"
                                      Neue Beobachtung im Bereich Location.
                                      Habe jetzt an zwei Tagen in Folge festgestellt, dass sich das Device nicht selbstständig im Homebereich anmeldet. Ich musste erst die App öffnen damit sich das Device anmeldet.
                                      iogo.0.(device ID).locations.(location ID)=false
                                        @cortana Hast du der App erlaubt Daten im Hintergrund zu übertragen?
                                          @nis
                                          Ich meine ja. Aber du kannst mir gern schreiben welche Einstellungen du genau meinst. Dann schau ich gleich noch mal nach und mach screens
                                            @cortana In den Einstellungen bei Apps müsstest du mal bei der App schauen. Dort solltest du Einstellungen zu "mobile Daten im Hintergrund erlauben" und auch "Daten im Standby" geben.
                                            1.0k
                                            android app iogo
                                            21
                                            223
                                            31322
