    4. [Vorstellung] Meine dritte VIS
      Kuddel @hofmannha last edited by
      @hofmannha
      Blockly Export
       <variables>
         <variable type="cron" id="Wecklicht_Daniel">Wecklicht_Daniel</variable>
       </variables>
       <block type="comment" id="-c)[#MFP9p;fa*.zCm9:" x="-312" y="-162">
         <field name="COMMENT">Cron Restart</field>
           <block type="update" id="Z|G(lkOVhj1O467p~(%Z">
             <field name="OID">javascript.0.wecklicht.weckzeit_cron_restart</field>
             <field name="DELAY_MS">1</field>
               <block type="time_get" id="YEc@`GZ$/=;kZ-eC]Nu%">
                 <mutation xmlns="http://www.w3.org/1999/xhtml" format="true" language="false"></mutation>
                 <field name="OPTION">custom</field>
                 <field name="FORMAT">TT.MM.JJJJ SS:mm</field>
               <block type="comment" id="O#Q1_Ela_+Mr;!O;Z=f}">
                 <field name="COMMENT">Weckzeit Daniel</field>
                   <block type="on_ext" id="`naW5ol;4hGCGrtd-k@X">
                     <value name="OID0">
                       <shadow type="field_oid" id="HDUsrjtBjbo4Ajl%TF.b">
                         <field name="oid">javascript.0.wecklicht.daniel.weckzeit</field>
                     <value name="OID1">
                       <shadow type="field_oid" id="XYXzIGcB$6wbcLBlv^VD">
                         <field name="oid">javascript.0.wecklicht.weckzeit_cron_restart</field>
                       <block type="schedule_clear" id="t#O!h9zZ3V/@hn@bSiQk">
                         <field name="NAME">Wecklicht_Daniel</field>
                           <block type="schedule_create" id="8K~gctx^YtpHl:]@Y47+">
                             <value name="SCHEDULE">
                               <shadow xmlns="http://www.w3.org/1999/xhtml" type="field_cron" id="c0]4[b/)BfLxIM[_D4J?">
                                 <field name="CRON">* * * * *</field>
                               <block type="cron_builder" id="C`(+:liW#9W(#xc)mEg/">
                                 <mutation xmlns="http://www.w3.org/1999/xhtml" seconds="false" as_line="false"></mutation>
                                 <field name="LINE">FALSE</field>
                                 <field name="WITH_SECONDS">FALSE</field>
                                 <value name="DOW">
                                   <shadow type="text" id="K@u6,n+x!GvmZmT5*AF4">
                                     <field name="TEXT">*</field>
                                 <value name="MONTHS">
                                   <shadow type="text" id="./q}[72rzJG[}fKabV@h">
                                 <value name="DAYS">
                                   <shadow type="text" id=":e.|M#BI`c+`|Esj(yMy">
                                 <value name="HOURS">
                                   <shadow xmlns="http://www.w3.org/1999/xhtml" type="text" id="Fv4;rbdTd_RVt(!HOV~1">
                                   <block type="text_getSubstring" id="w@|7BFvYtoVjNue+tIXO">
                                     <mutation at1="false" at2="true"></mutation>
                                     <field name="WHERE1">FIRST</field>
                                     <field name="WHERE2">FROM_START</field>
                                     <value name="STRING">
                                       <block type="get_value" id="@-JweVPP`)=~[+@7[ZjH">
                                         <field name="OID">javascript.0.wecklicht.daniel.weckzeit</field>
                                     <value name="AT2">
                                       <block type="math_number" id="6*$wfg#FCfAVbJz)Fp`Z">
                                         <field name="NUM">2</field>
                                 <value name="MINUTES">
                                   <shadow xmlns="http://www.w3.org/1999/xhtml" type="text" id="9l6T6FkfTzbV%V~YR8yg">
                                   <block type="text_getSubstring" id="m)`Ugg[9F=AWaVP4p6S3">
                                     <mutation at1="true" at2="false"></mutation>
                                     <field name="WHERE1">FROM_START</field>
                                     <field name="WHERE2">LAST</field>
                                       <block type="get_value" id="jd3{3gjHRjm(V3vKVV0*">
                                     <value name="AT1">
                                       <block type="math_number" id="z51@{mors+6c8^##rsfG">
                                         <field name="NUM">4</field>
                               <block type="comment" id="3l{X|AfIp$]T^Y8`xkFm">
                                 <field name="COMMENT">Werktags</field>
                                   <block type="controls_if" id="m=i+7#wV]oNOuYOO$VK4">
                                       <block type="logic_operation" id="l$M?1_BKdfzhO?v)98@y" inline="false">
                                         <field name="OP">AND</field>
                                           <block type="logic_compare" id="$^R.L)w/!CMEg:Mz3V78">
                                             <field name="OP">NEQ</field>
                                               <block type="time_get" id="YF:l4ee9WV4P}=T81ho_">
                                                 <mutation xmlns="http://www.w3.org/1999/xhtml" format="false" language="true"></mutation>
                                                 <field name="OPTION">wdt</field>
                                                 <field name="LANGUAGE">de</field>
                                               <block type="text" id="U`swyZV.*TJL9irCj6}x">
                                                 <field name="TEXT">Samstag</field>
                                           <block type="logic_compare" id="RquU@!}?c!$HTMT(UHC*">
                                               <block type="time_get" id=",{[i6FF@-u0)e:qhHh..">
                                               <block type="text" id="?30EGBs$-k*6=@_1AH2V">
                                                 <field name="TEXT">Sonntag</field>
                                       <block type="controls_if" id="=oW7|a:_JXWDx^(%!67m">
                                           <block type="logic_operation" id="qA1S+)7Nq]-XvrlJz2kB" inline="false">
                                               <block type="logic_operation" id="nOEUVr^fmyamNUD(@Fej" inline="false">
                                                   <block type="logic_compare" id="OfQ@Ko|_c+MFdIb|U~Xc">
                                                     <field name="OP">EQ</field>
                                                       <block type="get_value" id="2o+sk[?Z^8N|bdd;i9*,">
                                                         <field name="OID">feiertage.0.heute.boolean</field>
                                                       <block type="logic_boolean" id="N=)}U3G5-4X$J)s{(_UW">
                                                   <block type="logic_compare" id="*V+%v#7?rw4]qT@G.e;5">
                                                       <block type="get_value" id=",F_KAqq2VXl3u28^wZ(y">
                                                         <field name="OID">javascript.0.Anwesenheit.Daniel</field>
                                                       <block type="logic_boolean" id="Tu^ZdPS6;|p4^OzR}rpU">
                                               <block type="logic_operation" id="ew*eL`i{bi7VZetiI.Y)" inline="false">
                                                 <field name="OP">OR</field>
                                                   <block type="logic_operation" id="({,0TBVgh=]=So7Ukj3Y" inline="false">
                                                       <block type="logic_compare" id="RaB4)oBZFr_Ko%3:0#BM">
                                                           <block type="get_value" id="QQ?4BnZ:={K^MswDnY9p">
                                                             <field name="OID">javascript.0.sonstige.arbeitsstatus</field>
                                                           <block type="math_number" id="7{#-VU+F,zV#wrL4-/3?">
                                                             <field name="NUM">0</field>
                                                       <block type="logic_compare" id="oRR2$m)Gb?a1YDF}o|*`">
                                                           <block type="get_value" id="p7)QFzEz=VE:P;EK*LtP">
                                                           <block type="math_number" id="wJ}35sn!rz_m@f[emxth">
                                                   <block type="logic_compare" id="):DH4h,JgZYGv,^@yQY#">
                                                       <block type="get_value" id="UB:)tDdM?DEX)p1nIgv{">
                                                       <block type="math_number" id="d0=?n:1SMz|+0gSvLKcw">
                                                         <field name="NUM">5</field>
                                           <block type="control" id="]LuR;nP7T|JX$[]+pTQ1">
                                             <field name="OID">javascript.0.wecklicht.daniel.wecklicht</field>
                                               <block type="logic_boolean" id=";QtoD%ru`DwQ|1+]JT%B">
                                               <block type="control" id="ugDi{R}7AU9+~1U3^lb5">
                                                 <field name="DELAY_MS">15</field>
                                                   <block type="logic_boolean" id="R/qWKDfh6oxn8~#})|.o">
                                     <value name="IF1">
                                       <block type="logic_operation" id="T_K?9ep!``,)o(7u3-fa" inline="false">
                                           <block type="logic_compare" id="?oyg84|8q9k%|O%CdX#K">
                                               <block type="time_get" id="XxDJ([Q/krzl)8bC[73R">
                                               <block type="text" id="[diw~YlKbN*QZ.^x~1g9">
                                           <block type="logic_compare" id="%jM+lj|QFkV%3YJ|3W3y">
                                               <block type="time_get" id="j^in7`l(Z=Yd3[wyYW)w">
                                               <block type="text" id="XacY]dNg2rv%K+[hl$J5">
                                     <statement name="DO1">
                                       <block type="controls_if" id="pqT{._OGO4w~MyDfX0PK">
                                           <block type="logic_compare" id="JobPVbc@UlsqE3CkUFVp">
                                               <block type="get_value" id="OVO|jrL-WT30Jry2OZ(e">
                                                 <field name="OID">javascript.0.wecklicht.daniel.wecklicht_we</field>
                                               <block type="text" id="TwtR*YRvRHno7v[?BC{y">
                                                 <field name="TEXT">1</field>
                                           <block type="control" id="u-9CIbd[zCSSHU.g#p=`">
                                               <block type="logic_boolean" id="w7eIGh@d(,`QJhL]6C)B">
                                               <block type="control" id="X{K:=U%hgz2W~}JQ}6wN">
                                                   <block type="logic_boolean" id="Vpp:;aE*:=r$NGFhtMQ-">
      H J 2 Replies Last reply Reply Quote 0
        hofmannha @Kuddel last edited by
        Hallo @Kuddel,
        was ist das wecklicht.weckzeit_cron_restart für ein DB?
          @hofmannha bei jeder Änderung oder Neustart des Skripts wird darüber der Cron-Job neugestartet
            jannis last edited by
            erstmal Respekt...Super Visualisierung und tolle, praktische Skripts! Ich habe dadurch eine Menge gelernt.
            Mein Tablet hat Probleme die Visualisierung darzustellen bzw. es dauert ewig Am Seite zur Seite zu wechseln.
            Am PC funktioniert es eigentlich relativ flüssig.
            Ich benutze dafür ein Lenovo Tab 2 A10-70F.
            Meint Ihr liegt es am Tablet oder könnte mit der Visualisierung zu tun haben?
            Welches Tablet würdet Ihr mir vorschlagen? Reichen die 2GB RAM?
              jwerlsdf @Kuddel last edited by jwerlsdf
              @Kuddel
              vielen Dank für deine View. Nun eine Frage: benutze dein Menü. Ich habe es soweit verstanden, wie ich meine Views einbinden kann. Aber an den submenüs scheitere ich. Die Hauptviews werden angezeigt, aber nicht die Subviews...
                Kuddel @jannis last edited by
                @jannis ich benutzte ein Samsung Galaxy TAB A 9.7
                Ist mitlerweile auch schon ein paar Jahre alt und braucht auch so 5 Sekunden und mehr um eine andere Seite darzustellen
                  Kuddel @jwerlsdf last edited by
                  @jwerlsdf kannst du mal posten, was du so eingetragen hast?
                  Dann kann ich das mit meinen Einstellungen vergleichen
                    SARCux @Kuddel last edited by
                    @Kuddel
                    Moin, derzeit verwende ich bei uns zuhause den MagicMirror, wenn ich aber das hier sehe haut es mich von den Socken.
                    Habe mir nun eunen neuen pi 4 mit 4GB bestellt und eine sandisk ultra mit 128 GB (sollte dafür doch ausreichen)
                    Sollte ich Fragen bei der Einrichtung haben, darf ich da auf dich oder die Community zukommen?
                    Habe für die Visualisierung noch ein älteres Tablet in der Schublade, welches ich dafür verwenden möchte.
                    Welche App zur Darstellung ist am Besten geeignet? KioskBrowser?
                    Freue mich von euch zu hören
                    BG
                    SARCux
                      Kuddel @SARCux last edited by
                      @SARCux du kannst natürlich gerne Fragen stellen. Entweder hier oder auch gern per PN.
                      Ich nutze auf meinem schon etw. älteren Galaxy Tab A 9.7 den Fully Kiosk Browser.
                      Gerade mit einer Lizenz ist der Brwoser Top, da man das Tablet auslesen kann (Akkustand z.B.).
                        SARCux @Kuddel last edited by SARCux
                        @Kuddel
                        Hatte mir vor zwei Jahren mal so ein China Tablet zugelegt.
                        Hoffe das ich den Fully da noch raufbekomme.
                        Werde es vorher mal testen und sobal der pi angekommen ist, geht es los. Bin gespannt ob ich meine Shellys einbinden kann und auch steuern.
                        Klappt das auch mit Sonos und Alexa?
                        Ein Fire Tab habe ich auch noch rumfliegen....
                          @SARCux was genau meinst du mit "Klappt das auch mit Sonos und Alexa"?
                          Ich habe keine Sonos Geräte, nutze aber verschiedene Echode Devices zur Steuerung.
                          S K 2 Replies Last reply Reply Quote 0
                            @Kuddel
                            ich stelle mir eine Vis für die Küche vor (dort hängt der Sonos) und beim antippen eines Sender (wenn drei zur auswahl als Icon) das es dann über den Sonos in der Küche wiedergegeben wird
                              @SARCux wenn man den Sonos in ioBroker integrieren kann, geht das bestimmt.
                              Mit Sonos kenne ich mich allerdings nicht aus.
                                @Kuddel
                                Vorab schonmal danke für die schnellen Antworten.
                                Ich warte jetzt mal auf die Lieferung des pi und gehen dann Schritt für Schritt an den io broker ran.
                                Es werden dann sicherlich Fragen auftauchen, die ich ier bestimmt beantwortet bekomme.
                                BG
                                SARCux
                                  marhal @Kuddel last edited by Negalein
                                  @Kuddel
                                  Hallo Kuddel,
                                  ich bin ja von deiner Vis begeistert und baue sie fleissig nach 🙂 ich bin gerade bei den iobroker Adaptern und dem Javascript (adapter_infos.). Leider bekomme ich folgende Meldungen bei dem Script kannst du mir da helfen was der Fehler dort ist ?
                                  12:58:07.905	error	javascript.0 (1355) at script.js.java.abfragen.adapter_infos:14:39
                                  12:58:07.905	error	javascript.0 (1355) at Object.<anonymous> (script.js.java.abfragen.adapter_infos:13:19)
                                  12:58:22.813	warn	javascript.0 (1355) at script.js.java.abfragen.adapter_infos:35:18
                                  12:58:22.814	warn	javascript.0 (1355) at Object.<anonymous> (script.js.java.abfragen.adapter_infos:13:19)
                                  12:58:22.815	warn	javascript.0 (1355) at script.js.java.abfragen.adapter_infos:47:19
                                  12:58:22.816	warn	javascript.0 (1355) at Object.<anonymous> (script.js.java.abfragen.adapter_infos:13:19)
                                  wäre super wenn mir da jemand helfen kann
                                  gruß
                                  Marhal
                                    Kuddel @marhal last edited by
                                    @marhal das ist meine aktuelle Version:
                                    // Liest die ioBroker Adapter aus und legt verschiedenen State's an.
                                    //on({id:"system.adapter.admin.0.uptime",change:'any'}, function (obj) {
                                       createState('Adapter.Anzahl', 0, { name: 'Anzahl', desc: 'Anzahl der Adapter', type: 'number', unit: '', min: '0', max: '255', role: '',read: true, write: true });
                                       createState('Adapter.AdapterNummer', 0, { name: 'Adapter zum schalten', desc: 'Adapter zum schalten', type: 'number', unit: '', min: '0', max: '255', role: '',read: true, write: true });
                                       //var counterAlt = getState("javascript.0.Adapter.Anzahl").val;
                                       var counter =0;
                                       var on = 0
                                       var manuell=0
                                       var cacheSelector = $('[id=system.adapter.*.alive]');
                                       cacheSelector.each(function(id, i) {
                                           var devicename = getObject(id).common.name;
                                       	//Instanzen ausklammern
                                       	instanz0 = devicename.indexOf('daswetter');
                                       	instanz1 = devicename.indexOf('dwd');
                                           instanz2 = devicename.indexOf('ical');
                                       	instanz3 = devicename.indexOf('feiertage');
                                       	instanz4 = devicename.indexOf('snmp.1');
                                           instanz5 = devicename.indexOf('vis.0');
                                           instanz6 = devicename.indexOf('yamaha.0');
                                       	if(instanz0 !=0 && instanz1 != 0 && instanz2 !=0 && instanz3 != 0 && instanz4 != 0 && instanz5 !=0 && instanz6 !=0){
                                       		var devicenameName=devicename;
                                       		var instanzname=getObject(id).common.name;
                                       		var test = devicenameName;
                                       		var devicename_array = devicenameName.split(' ');
                                       		devicenameName = devicename_array[0];
                                       		counter = counter+1;
                                       		var strStatePath = "system.adapter." + devicenameName + ".alive";
                                       		if (isState(strStatePath, true)) {
                                       			var uptime = getState("system.adapter." + devicenameName + ".uptime").val;
                                       			var tage = Math.floor(uptime / (24*3600));
                                       			var stunden = Math.floor((uptime % (24*3600))/3600);
                                       			var minuten = Math.floor((uptime % (3600))/60);
                                       			//var sekunden = Math.floor(uptime % 60);
                                       			if (stunden < 10) {stunden = "0"+stunden};
                                                   if (minuten < 10) {minuten = "0"+minuten};
                                       			if (tage == 1) {uptime = tage.toString()+" Tag, "+stunden.toString()+" Std, "+minuten.toString()+" Min ";};
                                       			if (tage != 1) {uptime = tage.toString()+" Tage, "+stunden.toString()+" Std, "+minuten.toString()+" Min ";}
                                       			//var total = getState("system.adapter." + devicenameName + ".memHeapTotal").val;
                                       			//var used = getState("system.adapter." + devicenameName + ".memHeapUsed").val;
                                       			//var rss = getState("system.adapter." + devicenameName + ".memRss").val;
                                       			var connect = getState("system.adapter." + devicenameName + ".alive").val;
                                       			if(connect == false){var con = 0;}
                                       			else {
                                       				var con = 1;
                                       				var strStatePath = devicenameName + ".info.connection";
                                       					var connectS = getState(devicenameName + ".info.connection").val;
                                       					if (connectS == false) {
                                       						con = 2;
                                       			if(con==1) {on = on + 1}
                                       		devicename="Adapter.Adapter"+counter.toString()+".KompletterNameAdapter";
                                       		createState(devicename, 'empty', { name: 'Kompletter Name des Adapters', desc: '', type: 'string', role: '',read: true, write: true });
                                       		setStateDelayed(devicename, devicenameName, 800);
                                       		var contentstring = devicenameName;
                                       		var suchstring = /(ical)/g;
                                       		var suchergebnis = suchstring.test( contentstring );
                                       		if (suchergebnis != true) {
                                       			var devicename_array = devicenameName.split('.');
                                       		if (devicenameName == "daswetter") {
                                       			var bild = "/" + devicenameName + ".admin/" + devicenameName + "com.png";
                                       		} else if (suchergebnis != false) {
                                       			var icalName = devicename_array[0];
                                       			var bild = "/" + icalName + ".admin/" + icalName + ".png";
                                       		} else {
                                       			var bild = "/" + devicenameName + ".admin/" + devicenameName + ".png";
                                       		//Alexa2
                                       		if (devicenameName == 'alexa2') {var bild = "/" + devicenameName + ".admin/" + "alexa.png";}
                                       		//FritzDECT
                                       		if (devicenameName == 'fritzdect') {var bild = "/" + devicenameName + ".admin/" + "fritzdect_logo.png";}
                                       		//FullyBrowser
                                       		if (devicenameName == 'fullybrowser') {var bild = "/" + devicenameName + ".admin/" + "fully.png";}
                                       		//HM-Rega
                                       		//if (devicenameName == 'hm-rega') {var bild = "/" + devicenameName + ".admin/" + "homematic.png";}
                                       		if (devicenameName == 'hm-rega') {var bild = "/vis.0/VIS/Meine_Icons/Adapter_Icons/homematic.gif";}
                                       		//HomeMatic
                                       		//if (instanzname == 'hm-rpc.0 alive') {var bild = "/" + devicenameName + ".admin/" + "homematic.png";}
                                       		if (instanzname == 'hm-rpc.0 alive') {var bild = "/vis.0/VIS/Meine_Icons/Adapter_Icons/homematic.gif";}
                                       		//HomeMatic-IP
                                       		//if (instanzname == 'hm-rpc.1 alive') {var bild = "/" + devicenameName + ".admin/" + "homematic.png";}
                                       		if (instanzname == 'hm-rpc.1 alive') {var bild = "/vis.0/VIS/Meine_Icons/Adapter_Icons/homematic_ip.jpg";}
                                       		//UPNP
                                       		if (devicenameName == 'upnp') {var bild = "/" + devicenameName + ".admin/" + "upnp-discovery.png";}
                                               //Pushover.1
                                       		if (instanzname == 'pushover.1 alive') {var bild = "/mihome-vacuum.admin/mihome-vacuum.png";}
                                               //Pushover.2
                                       		if (instanzname == 'pushover.2 alive') {var bild = "/daswetter.admin/daswettercom.png";}
                                       		//AdapterName anpassen
                                               //DasWetter
                                       		if (instanzname == 'daswetter.0 alive') {devicenameName='DasWetter'; manuell=1}
                                       		//DWD
                                       		if (instanzname == 'dwd.0 alive') {devicenameName='DWD'; manuell=1}
                                       		//HM-REGA
                                       		if (instanzname == 'hm-rega.0 alive') {devicenameName='HM-Rega'; manuell=1}
                                       		//HM-RPC.0
                                       		if (instanzname == 'hm-rpc.0 alive') {devicenameName='HomeMatic'; manuell=1}
                                       		//HM-RPC.1
                                       		if (instanzname == 'hm-rpc.1 alive') {devicenameName='HM-IP'; manuell=1}
                                       		//MiHome-Vacuum
                                       		if (instanzname == 'mihome-vacuum.0 alive') {devicenameName='Nono'; manuell=1}
                                       		//Pushover
                                       		if (instanzname == 'pushover.0 alive') {devicenameName='Pushover.0'; manuell=1}
                                       		if (instanzname == 'pushover.1 alive') {devicenameName='Pushover.1'; manuell=1}
                                       		if (instanzname == 'pushover.2 alive') {devicenameName='Pushover.2'; manuell=1}
                                       		//Simple-API
                                       		if (instanzname == 'simple-api.0 alive') {devicenameName='Simple-API'; manuell=1}
                                       		//SNMP.0
                                       		if (instanzname == 'snmp.0 alive') {devicenameName='SNMP.0'; manuell=1}
                                       		//SNMP.1
                                       		if (instanzname == 'snmp.1 alive') {devicenameName='SNMP.1'; manuell=1}
                                               //Spotify
                                               if (instanzname == 'spotify-premium.0 alive') {devicenameName='Spotify'; manuell=1}
                                               //TR-064.0
                                       		if (instanzname == 'tr-064.0 alive') {devicenameName='TR-064.0'; manuell=1}
                                       		//TR-064.1
                                       		if (instanzname == 'tr-064.1 alive') {devicenameName='TR-064.1'; manuell=1}
                                               //XPEnology
                                               if (instanzname == 'synology.1 alive') {devicenameName='XPEnology'; manuell=1}
                                       		//Instanz-Namen setzen
                                       		if(manuell!=1) {devicenameName = devicenameName.substring(0, 1).toUpperCase() + devicenameName.substring(1).toLowerCase();}
                                               //devicenameName = devicenameName.substring(0, 1).toUpperCase() + devicenameName.substring(1).toLowerCase();
                                       		devicename="Adapter.Adapter"+counter.toString()+".NameInstanz";
                                       		createState(devicename, 'empty', { name: 'Name des Geräts', desc: '', type: 'string', role: '',read: true, write: true });
                                       		//Bild Pfad setzen
                                       		devicename="Adapter.Adapter"+counter.toString()+".Bild";
                                       		createState(devicename, 'empty', { name: 'Speicherort Bild', desc: '', type: 'string', role: '',read: true, write: true });
                                       		setStateDelayed(devicename, bild, 800);
                                       		//Uptime setzen
                                       		devicename="Adapter.Adapter"+counter.toString()+".Uptime";
                                       		createState(devicename, 'empty', { name: 'Uptime', desc: '', type: 'string', role: '',read: true, write: true });
                                       		setStateDelayed(devicename, uptime, 800);
                                       		//MemUsed setzen
                                       		//devicename="Adapter.Adapter"+counter.toString()+".MemUsed";
                                       		//createState(devicename, 0, { name: 'Link MemUsed', desc: '', type: 'number', role: '',read: true, write: true });
                                       		//setStateDelayed(devicename, used, 800);
                                       		//MemToal setzen
                                       		//devicename="Adapter.Adapter"+counter.toString()+".MemTotal";
                                       		//createState(devicename, 0, { name: 'Link MemTotal', desc: '', type: 'number', role: '',read: true, write: true });
                                       		//setStateDelayed(devicename, total, 800);
                                       		//MemRSS setzen
                                       		//devicename="Adapter.Adapter"+counter.toString()+".MemRSS";
                                       		//createState(devicename, 0, { name: 'Link MemRSS', desc: '', type: 'number', role: '',read: true, write: true });
                                       		//setStateDelayed(devicename, rss, 800);
                                       		//Connected setzen
                                       		devicename="Adapter.Adapter"+counter.toString()+".Connected";
                                       		createState(devicename, 0, { name: 'Status Adapter', desc: '', type: 'number', role: '',read: true, write: true });
                                       		setStateDelayed(devicename, con, 800);
                                               //Wert zurücksetzen
                                               var manuell=0
                                       //Adaptet Icon Übersicht
                                       visstatus="javascript.0.VIS-Status.alle_adapter_gestartet";
                                       if(on == counter){setState(visstatus, true);}
                                       if(on == counter -1){setState(visstatus, true);}
                                       if(on < counter -1){setState(visstatus, false);}
                                       setStateDelayed('Adapter.Anzahl', counter, 800);
                                       function isState(strStatePath, strict) {
                                           let mSelector;
                                           if (strict) {
                                               mSelector = $('state[id=' + strStatePath + '$]');
                                           } else {
                                               mSelector = $('state[id=' + strStatePath + ']');
                                           if (mSelector.length > 0) {
                                               return true;
                                           } else {
                                               return false;
                                    on({id:"javascript.0.Adapter.AdapterNummer", change: 'any'}, function (dpobj) {
                                       if (getState("javascript.0.Adapter.AdapterNummer").val != 0) {
                                           const instanz = "javascript." + instance;
                                           var adapterNummer = getState(instanz + ".Adapter.AdapterNummer").val;
                                           var adapter = getState(instanz + ".Adapter.Adapter" + adapterNummer + ".KompletterNameAdapter").val; // Name und Instanz des Adapters
                                           var idAdapter = "system.adapter." + adapter;
                                           var obj = getObject(idAdapter);
                                           if (dpobj.state.val == false) {
                                               obj.common.enabled = true;  // Adapter einschalten
                                           } else if (dpobj.state.val == true) {
                                               obj.common.enabled = false;  // Adapter ausschalten
                                           setObject(idAdapter, obj);
                                           setStateDelayed('javascript.0.Adapter.AdapterNummer', 0, 800);
                                    C M I 4 Replies Last reply Reply Quote -2
                                      ChrisXY @Kuddel last edited by
                                      @Kuddel hast du zufällig vom Nono ein Update mit der Room funktion ?
                                        Kuddel @ChrisXY last edited by
                                        @ChrisXY ne habe ich mich bis jetzt noch nicht wieder mit beschäftigt
                                        • Slowman
                                          Slowman last edited by Slowman
                                          erledigt
                                          • Bluelinux
                                            Bluelinux last edited by
                                            Halli Hallo Ihr leiben,
                                            erst einmal allen einen schönen Nikolaus und 2. Advent. Ich hoffe mir kann hier jemand helfen, denn ich habe ein Problem mit dem Menü in meiner VIS. Im VIS-Editor Materialdesign - Top App Bar fehlt der reiter Untermenü wie kommt das?? Habe das System gewechselt und seid dem ist das. Hat jemand eine Ahnung wo das Problem ist? Anbei ist noch ein Bild vom VIS-Editor.
                                            Das ganze hat zufolge, dass ich die Seiten nicht wechseln kann.
                                            Grüße und vielen Dank
                                            vis vis projekte
                                            83
                                            640
                                            172238
