    5. Bewegungsmelder blockly nach Zeit
      sandro_gera @paul53 last edited by
      ich hab das jetzt mal so erstellt
        <variables>
          <variable id="bgX:Wxxn%S[O^9f,wDcC">computer</variable>
          <variable id="Ik?`;_^3$2,9W6VQSQ~3">manuell</variable>
        </variables>
        <block type="procedures_defnoreturn" id="li@;?QwWuFbHVeb0uMoX" x="-813" y="-562">
          <field name="NAME">wandlampe</field>
          <statement name="STACK">
            <block type="controls_if" id="vQFC4G#mtRRlX.VWnqrI">
                <block type="logic_operation" id="Yy~I1gw@#1s|eb*^QU]s" inline="false">
                  <field name="OP">AND</field>
                    <block type="logic_negate" id="Hjw[|jxFGlaK+tB[Xzic">
                      <value name="BOOL">
                        <block type="variables_get" id="}CE3k{LCn40h(vIrYV=x">
                          <field name="VAR" id="Ik?`;_^3$2,9W6VQSQ~3">manuell</field>
                    <block type="time_compare_ex" id="ey-,zU=|GQ~-lu2{d?05">
                      <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true" actual_time="true"></mutation>
                      <field name="OPTION">not between</field>
                      <value name="START_TIME">
                        <shadow type="text" id="CW1)M1p;$JsM:Cj5%}.p">
                          <field name="TEXT">12:00</field>
                        <block type="time_astro" id="Q?9@xZ*n9t/b-X?z:FKX">
                          <field name="TYPE">sunrise</field>
                          <field name="OFFSET">0</field>
                      <value name="END_TIME">
                        <shadow type="text" id="Lrv[#^v+EiYT/RyF-38]">
                          <field name="TEXT">18:00</field>
                        <block type="time_astro" id="?M!.Ij2q~S:14)nF3-B5">
                          <field name="TYPE">sunset</field>
                <block type="control" id="j{iYD3~l*zpr@KNEtMr[">
                  <field name="OID">alias.0.Licht.Arbeitszimmer.Wandlampe_Arbeitszimmer</field>
                    <block type="variables_get" id="Zeh(oy7gF`2K[w|gV%fs">
                      <field name="VAR" id="bgX:Wxxn%S[O^9f,wDcC">computer</field>
        <block type="astro" id=";As25$]xOo`YtG[bxc^R" x="-813" y="-387">
            <block type="procedures_callnoreturn" id="Zedx!5eNEb4Piu^Zg*%;">
              <mutation name="wandlampe"></mutation>
            <block type="on_ext" id="m^ctya_*xjD8-KQUH,61">
              <value name="OID0">
                <shadow type="field_oid" id="_T7NQNq|6_KL]8~#AmPL">
                  <field name="oid">alias.0.Steckdosen.Arbeitszimmer.Computer_1_Arbeitszimmer</field>
                <block type="variables_set" id="0s5m=A-i`}%1M~;LoAg;">
                    <block type="on_source" id="7[bt@dS+Kz?Lxlo-dOGP">
                    <block type="procedures_callnoreturn" id="vGo?PRoGS~,Qg8tE26#e">
                <block type="on_ext" id="Cc5FGM]lHd;8*-vEl(87">
                  <value name="OID0">
                    <shadow type="field_oid" id="J82_w$aysD(,n#TfjKi$">
                      <field name="oid">alias.0.Licht.Arbeitszimmer.Wandlampe_Arbeitszimmer</field>
                    <block type="variables_set" id="H.X]pVt-[.SG*mSo2%;G">
                        <block type="logic_operation" id="5X;VDBZ5|G0)6[t;_Ill" inline="false">
                            <block type="on_source" id=";,DoXcaNX$3MumBC`(t%">
                            <block type="logic_compare" id="g,4XFQ{VIRAB~u$kAFec">
                              <field name="OP">NEQ</field>
                                <block type="on_source" id="avL^M)Ct_sI32]4a1]X.">
                                  <field name="ATTR">state.from</field>
                                <block type="text" id="g%jGCj+)5XnCikl8P}Ni">
                                  <field name="TEXT">system.adapter.javascript.0</field>
      Ich hab die Wandlampe manuell ausgeschaltet und dann das skirp gestartet. Leider bleibt sie aus.
        paul53 @sandro_gera last edited by
        @sandro_gera sagte:
        Bei Skripstart passiert nichts, sondern nur beim Computer-Ein-/Ausschalten oder Sonnenuntergang.
          ok dann werd ich morgen mal sehen obs klapptDanke dir dann kann ich meine anderen Skripte nach dem Muster erstellen. du bist der Beste!!
            @sandro_gera sagte:
            Damit es bei Skriptstart klappt erweitere es um 2 Befehle:
              Danke nochmal hat super geklappt
                @paul53 said in Bewegungsmelder blockly nach Zeit:
                @sandro_gera sagte in Bewegungsmelder blockly nach Zeit:
                Das Licht soll so lange an bleiben bis ich das Zimmer länger Zeit verlasse.
                Hat der BWM eine eigene Ausschaltverzögerung ? Dann sollte es so funktionieren:
                 <variables>
                 </variables>
                 <block type="on_ext" id="m^ctya_*xjD8-KQUH,61" x="-387" y="-312">
                   <value name="OID0">
                       <field name="oid">alias.0.Bewegungsmelder.Küche.OSRAM_Smart_plus_Motion_presence</field>
                     <block type="controls_if" id="AjIawNtDhM8SXPVhw{e`">
                         <block type="logic_operation" id="np6DF~Z57YL_4:oC@ot6" inline="false">
                               <value name="BOOL">
                           <field name="OID">alias.0.Licht.Kueche.Sitzecke_Küche</field>
                             <block type="on_source" id="c(.$0bbY@%eg$Ft*!+(3">
                             <block type="control" id="`={{)Zg80|j]CRJ(JS]]">
                               <field name="OID">alias.0.Licht.Kueche.Spuele_Kueche</field>
                                 <block type="on_source" id="}|}r{Tsv9nSt4uM.8TcG">
                     <block type="on_ext" id="bC{yAAD)cQ4#p29#C@#_">
                       <value name="OID0">
                         <shadow type="field_oid" id=";n6#=sBC`|uZj*^.+N3j">
                         <block type="text" id="X0_^|HM$QaYHn,*+W%`h">
                           <field name="TEXT">alias.0.Licht.Kueche.Sitzecke_Küche</field>
                       <value name="OID1">
                         <shadow type="field_oid" id="cCX-Z1VJNG9*RN;paA1M">
                         <block type="text" id="aXD=w(l=78}W$Q!7%g/0">
                           <field name="TEXT">alias.0.Licht.Kueche.Spuele_Kueche</field>
                                 <block type="logic_operation" id="w02V0-,Xdr^{n-JYU{ia" inline="false">
                                   <field name="OP">OR</field>
                                     <block type="get_value_var" id="#3!yRfmWIjb^~=F87f}J">
                                       <value name="OID">
                                         <shadow type="text" id="g)?W76,0dY|I8sIuL~(h">
                                     <block type="get_value_var" id="m%{V/b4yi]7q$9z-#CB7">
                                       <value name="OID">
                                         <shadow type="text" id="[Od,*@MTq]#Uy9Jh+K%)">
                Dann muß ich das hier aber auch noch anpassen oder?
                  @sandro_gera sagte:
                  Nur, wenn der BWM dauerhaft Bewegung meldet, was in der Küche sicherlich nicht der Fall ist.
                    sandro_gera @paul53 last edited by sandro_gera
                    also das hat gerade nicht funktioniert. Ich bin in die Küche und hatte vorher den Fernsehr angeschaltet aber die Lampen gingen nicht an. Ich glaube nicht das der Bewegunsmelder ein Ausschaltverzögerung hat.
                    Ich glaube es wäre besser, das in der Küche unanhäging von Fernseher zu steunern. Also das nach Sonnenuntergang und auslösen einer Bewegung die beiden Lampen in der Küche an gehen. Genau so vor Sonnenaufgang, Wenn ich dauerhaft aus der Küche gehe muß ich sie dann eben per Sprachbefehl ausschalten.
                      @sandro_gera sagte:
                      Wo spielt der Fernseher rein (sehe ich nicht) ?
                        Nein sorry, das war mein Fehler ich hatte 2 Skripte erstellt.
                        Eins das bei eingeschltetem Fernseher und wenn der Sonnenuntergang erreicht wird die Lampen angehen aber noch nicht mit dem richtigen Trigger. Das muß ich noch so änders wie im Arbeitszimmer.
                        Zusätzlich möchte ich aber ich das die beiden Lampen an gehen wenn der Bewegungsmelder ein Bewegung erkennt und es nach Sonnenuntegang bzw vor Sonnenaufgang ist
                          Im Arbeitzimmer fange ich ja oben mit Funktion Wandlampe and wie mache ich das wenn ich 2 Lampen steuern will?
                            @sandro_gera sagte:
                            Bitte nur ein Skript für die Steuerung von Aktoren verwenden !
                              Also muß ich alles in ein skript bringen. Dann wirds ja noch komplexer.
                                @sandro_gera sagte:
                                Alles, was das Küchenlicht steuert.
                                Welche Wirkung hat der Fernseher auf das Licht ?
                                  also, ich hab in alexa eine Routine "guten Morgen! angelegt nach der mir die Nachrichten vorgelesen werden sowie in der Küche die Kaffeemaschine sowie der Fernseher angehen.
                                  Das wolle ich nutzen um die beiden Lampen mit einzuschalten. Allerdings nur vor Sonnenaufgang, weil ja im Sommer die Sonne früher auf geht. Des weiteren wollte ich, das wenn ich zum Beispiel koche und der Fernseh läuft und währen dessen der Sonnenuntegangszeitpunt erreicht wird die Lampen eingeschaltet werden.
                                  Zusätzlich sollen die Lampen aber auch an gehen wenn ich die Küche nach Sonnenuntergang oder vor Sonnenaufgang betrete
                                    paul53 @sandro_gera last edited by paul53
                                     <variables>
                                       <variable id="axMt%fdpcxl0ZEo+-^HT">fernseher</variable>
                                       <variable id="L)cHX_fLlM2)1`,Cb?ZH">licht</variable>
                                       <variable id=".VA02`Dw=+s=*(s%bZEX">bewegung</variable>
                                     </variables>
                                     <block type="procedures_defnoreturn" id="!?h]+p0}P#pP;6#IOY7#" x="-362" y="-588">
                                       <field name="NAME">kuechenlicht</field>
                                                   <value name="BOOL">
                                             <block type="variables_set" id="Tn$c[{MmcwAH5wE8]P!O">
                                               <field name="VAR" id="L)cHX_fLlM2)1`,Cb?ZH">licht</field>
                                                 <block type="logic_operation" id="]K8pv,d!7wGC.YT-gbHq">
                                                     <block type="variables_get" id="bMP|)z;2rtBSS8a;@D{2">
                                                       <field name="VAR" id=".VA02`Dw=+s=*(s%bZEX">bewegung</field>
                                                     <block type="variables_get" id="b{VNtQwu8`MQ932vdUk8">
                                                       <field name="VAR" id="axMt%fdpcxl0ZEo+-^HT">fernseher</field>
                                                     <block type="variables_get" id="e0m%|tA6J6/a}OCo-Ff^">
                                                         <block type="variables_get" id="3I{3^0kG*Js|^qD5cKhJ">
                                     <block type="variables_set" id="T)Tl.(nxk9B=33_to2t," x="-362" y="-337">
                                         <block type="get_value" id="?g7c$*k*X3YuCW{.M#w=">
                                           <field name="OID">ID auswählen</field>
                                         <block type="procedures_callnoreturn" id="Mo18#iZR0ri[q=)x(JU_">
                                           <mutation name="kuechenlicht"></mutation>
                                             <block type="astro" id="26+g;)_^]K`o8.|$=]8Q">
                                                 <block type="procedures_callnoreturn" id="gdZWlXzftnQa+d3GYH@X">
                                                 <block type="astro" id="sgYx[8F56y4DK;Ge;1uE">
                                                     <block type="procedures_callnoreturn" id="gek^ebTP[slOlzo~g;A5">
                                                     <block type="on_ext" id="uSv(/$*c[/_7KFrx6c6V">
                                                       <value name="OID0">
                                                         <shadow type="field_oid" id="Vi6D8so`ee[Uxz@S+Yh!">
                                                         <block type="variables_set" id="IF=z=n7=E@;4?5bAFa1z">
                                                             <block type="on_source" id="RIj;e,oFer^Eq:*wzk4H">
                                                             <block type="procedures_callnoreturn" id="TM,Kv;4*-=gt%:AO]y)P">
                                                           <value name="OID0">
                                                             <block type="variables_set" id="B8UvUuFlFaKLr4~{4|^|">
        <block type="procedures_callnoreturn" id="TtX6er44A!AAZ]UE+EhT">
                                                               <value name="OID0">
                                                               <value name="OID1">
        <value name="OID">
        <value name="OID">
                                      Ich bin beeindruckt wie du das so schnell hin bekommst. Wie machst du das ? Es tut mir leid das ich dich mit meinen Wünschen ständig nerve, aber ich würd das so nicht hinbekommen.
                                        Eine Frage. bei Astro Sonnenaufgang beudetet das nicht das bei Sonnenaufgang etwas passiert und nicht vorher?
                                          @sandro_gera sagte:
                                          Soll zum Zeitpunkt "Sonnenaufgang" das Licht nicht ausgeschaltet werden ? Dann aber so:
                                          S 3 Replies Last reply Reply Quote 0
                                            Doch natürlich ich dachte das war der Einschaltzeitpunkt. Wiedrmal mein Fehler
                                            blockly
                                            5107
