    4. tr-064 startet nicht
    UNSOLVED tr-064 startet nicht
      Trusit last edited by
      Ich bin gerade neu mit dem Thema ioBroker angefangen und wollte den Adapter tr-064 installieren.
      Dieser startet aber nur einmal ganz kurz und wird dann sofort wieder rot.
      Das Log gibt mir folgende Fehler raus
      host.raspberrypi	2020-11-26 16:40:42.687	info	Restart adapter system.adapter.tr-064.0 because enabled
      host.raspberrypi	2020-11-26 16:40:42.686	error	instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      tr-064.0	2020-11-26 16:40:42.155	warn	(5229) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
      tr-064.0	2020-11-26 16:40:42.153	error	(5229) ~
      tr-064.0	2020-11-26 16:40:42.153	error	(5229) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
      tr-064.0	2020-11-26 16:40:42.153	error	(5229) ~~ Fatal error. Can not connect to your FritzBox.
      tr-064.0	2020-11-26 16:40:42.152	error	(5229) ~
      tr-064.0	2020-11-26 16:40:42.151	error	(5229) !device - "!device"
      tr-064.0	2020-11-26 16:40:42.046	info	(5229) starting. Version 4.2.1 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.17.0, js-controller: 3.1.6
      host.raspberrypi	2020-11-26 16:40:39.726	info	instance system.adapter.tr-064.0 started with pid 5229
      host.raspberrypi	2020-11-26 16:40:09.702	info	Restart adapter system.adapter.tr-064.0 because enabled
      host.raspberrypi	2020-11-26 16:40:09.702	error	instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      tr-064.0	2020-11-26 16:40:09.170	warn	(5214) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
      tr-064.0	2020-11-26 16:40:09.169	error	(5214) ~
      tr-064.0	2020-11-26 16:40:09.169	error	(5214) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
      tr-064.0	2020-11-26 16:40:09.168	error	(5214) ~~ Fatal error. Can not connect to your FritzBox.
      tr-064.0	2020-11-26 16:40:09.167	error	(5214) !device - "!device"
      tr-064.0	2020-11-26 16:40:09.056	info	(5214) starting. Version 4.2.1 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.17.0, js-controller: 3.1.6
      host.raspberrypi	2020-11-26 16:40:07.095	info	instance system.adapter.tr-064.0 started with pid 5214
      Ich habe schon in anderen Forenbeiträgen gelesen dass man in den Adapter einstellungen die IP-Adresse des Routers direkt einstellen soll und neu starten, leider hat dies auch nichts gebacht.
      Ich hoffe ihr könnt mir helfen.
      Lg
      |Systemdata| Bitte Ausfüllen|
      |Hardwaresystem:| Pi 4|
      |Arbeitsspeicher:| 4GB |
      |Nodejs-Version:| 10.17.0 |
      |NPM-Version:| 6.11.3 |
        sigi234 Forum Testing Most Active @Trusit last edited by
        @Trusit
          Trusit @sigi234 last edited by
          @sigi234
          Super vielen dank!
          Der Adapter startet nun.
            Thomas Braun Most Active @Trusit last edited by Thomas Braun
            @Trusit
            node: v10.17.0
            Würde ich mal auf node12 heben, mindestens aber aktuell halten: nodeJS 10.23.0
            Du hast da ohnehin eine schräge Version drin, die kleinste Version die mit einem aktuellen Raspberry OS mitkommt ist nämlich 10.21.0.
            Was hast du denn da installiert?
              Trusit @Thomas Braun last edited by
              @Thomas-Braun
              Hallo Thomas, ich habe mir die aktuelle Version von der ioBroker seite runtergeladen und installiert.
              Ich dachte dies wäre die aktuelle Version.
              Für die Node JS Version ist bei mir auch eine Nachricht, dass es eine aktuellere Version gibt aber ich habe leider noch keine Ahnung wie ich diese update.
              Lg
                @Trusit
                Ein vorgekochtes Image?
                Die sind 'steinalt'.
                Schau dir hier an, wie man nodeJS und auch das restliche System aktuell hält:
                https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
                  @Thomas-Braun
                  Vielen Dank für deine Hilfe Thomas.
                  Ich bin leider ganz neu in diesem Thema und arbeite mich gerade langsam rein.
                  Ich würde zwar sagen dass ich nicht gerade doof bin was Technik angeht aber ich hatte leider vorher noch gar keine Berührungspunkte mit diesen Themen aber ich gebe mein bestes mich da rein zu fuchsen.
                  Ich danke euch schon jetzt für die ganzen hilfreichen Antworten.
                  LG
                    Termina last edited by Termina
                    Ich habe tatsächlich ein ähnliches Problem.
                    System: Proxmox -> Iobroker in einer VM
                    Node.js v14.15.1
                    NPM 6.14.8
                    In der Fritzbox ist der Haken für die Anwendungen gesetzt. Fritzbox neustart ebenfalls schon erledigt.
                    Folgende Fehlermeldung erhalte ich im Log:
                    tr-064.0	2020-12-04 17:47:01.870	warn	(28985) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                    tr-064.0	2020-12-04 17:47:01.867	error	(28985) ~
                    tr-064.0	2020-12-04 17:47:01.866	error	(28985) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                    tr-064.0	2020-12-04 17:47:01.865	error	(28985) ~~ Fatal error. Can not connect to your FritzBox.
                    tr-064.0	2020-12-04 17:47:01.864	error	(28985) ~
                    tr-064.0	2020-12-04 17:47:01.862	error	(28985) Error: connect ETIMEDOUT 192.168.178.1:49000 - {"errno":-110,"code":"ETIMEDOUT","syscall":"connect","address":"192.168.178.1","port":49000}
                    tr-064.0	2020-12-04 17:46:30.204	info	(28985) starting. Version 4.0.13 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.15.1, js-controller: 3.1.6
                    • haselchen
                      haselchen Most Active @Termina last edited by haselchen
                      @Termina
                      Als erstes auf die empfohlene Nodejs Version wechseln (V12)
                      @Thomas-Braun hat da ein How To zu gemacht.
                      Dann könntest du auf die Latest gehen. Aber dran denken, ist eine Beta.
                      4.2.1 ist das momentan.
                      Und dann in den Einstellungen die IP der Box eingeben ( wenn nicht schon geschehen). Nicht fritz.box.
                      Und dann Iobroker neu starten und dann die Fritzbox.
                      Das wäre so meine Vorgehensweise.
                      adapter fritzbox iobroker neu hier tr-064 tr-064 adapter fehler
