    4. Amazon Dash fehler?
    UNSOLVED Amazon Dash fehler?
      denjo last edited by
      Hallo, ich habe ein update meines JS Controller gemacht auf Node.js v12.20.0 und nur läuft mein amazon Dash adapter nicht mehr, bekomme folgende Fehler meldung.
      host.raspberrypi	2020-11-28 09:47:19.445	info	Restart adapter system.adapter.amazon-dash.0 because enabled
      host.raspberrypi	2020-11-28 09:47:19.445	info	instance system.adapter.amazon-dash.0 terminated with code 0 (NO_ERROR)
      amazon-dash.0	2020-11-28 09:47:18.907	info	(9839) Terminated (NO_ERROR): Without reason
      amazon-dash.0	2020-11-28 09:47:18.906	info	(9839) terminating
      amazon-dash.0	2020-11-28 09:47:18.865	info	(9839) cleaned everything up...
      amazon-dash.0	2020-11-28 09:47:18.864	error	(9839) Error: socket: Operation not permitted at new PcapSession (/opt/iobroker/node_modules/pcap/pcap.js:60:39) at Object.exports.createSession (/opt/iobroker/node_modules/pcap/pcap.js:131:12
      amazon-dash.0	2020-11-28 09:47:18.861	error	(9839) unhandled promise rejection: socket: Operation not permitted
      amazon-dash.0	2020-11-28 09:47:18.861	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      amazon-dash.0	2020-11-28 09:47:18.856	info	(9839) starting pcap session on default interface
      amazon-dash.0	2020-11-28 09:47:18.819	info	(9839) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.amazon-dash, node: v12.20.0, js-controller: 3.1.6
      host.raspberrypi	2020-11-28 09:47:16.883	info	instance system.adapter.amazon-dash.0 started with pid 9839
      host.raspberrypi	2020-11-28 09:46:46.839	info	Restart adapter system.adapter.amazon-dash.0 because enabled
      host.raspberrypi	2020-11-28 09:46:46.835	info	instance system.adapter.amazon-dash.0 terminated with code 0 (NO_ERROR)
      amazon-dash.0	2020-11-28 09:46:46.313	info	(9064) Terminated (NO_ERROR): Without reason
      amazon-dash.0	2020-11-28 09:46:46.312	info	(9064) terminating
      amazon-dash.0	2020-11-28 09:46:46.285	info	(9064) cleaned everything up...
        denjo @denjo last edited by
        hat sich erledigt habe den fixer vergessen
        amazon dash
