    4. Daten Seriell von Paradigma Solaranlage lesen
      glitzi @AlCalzone last edited by glitzi
      @AlCalzone
      Stecke jetzt schon ewig fest...
      Den String der später von der seriellen Schnittstelle kommt habe ich erstmal zum Testen so reinkopiert.
      Das finden der Startsequenz habe ich irgendwie hinbekommen... (Optimierung notwendig?)
      Jetzt kommts...
      Der String muss gesplittet, von HEX in INT gewandelt und dann HIGH und LOW Byte tauschen werden.
      createState('Paradigma_String');
      createState('Paradigma_Kollektor');
      // Test-String bevor ich die serielle Anbindung realisiere
      var text = "0000000 fc 3e 24 01 09 02 87 02 43 01 49 00 00 00 56 01 00 00 00 00 00 00 00 00 00 00 10 10 0c 0b 14 05 00 00 00 00 00 05 44 00 00 00 00 00 00 00 00 00 00 00 09 02 00 00 00 00 00 00 00 00 00 00 00 00 85 fc 3e 24 01 09 02 87 02 43 01 4a 00 00 00 57 01 00 00 00 00 00 00 00 00 00 00 10 10 0c 0b 14 05 00 00 00 00 00 05 44 00 00 00 00 00 00 00 00 00 00 00 09 02 00 00 00 00 00 00 00 00 00 00 00 00 83 23 03 d0 00 09 01 fc 3e 24 01 09 02 87 02 43 01 4a 00 00 00 57 01 00 00 00 00 00 00 00 00 00 00 10 10 0c 0b 14 05 00 00 00 00 00 05 44 00 00 00 00 00 00 00 00 00 00 00 08 02 00 00 00 00 00 00 00 00 00 00 00 00 84 fc 3e 24 01 08 02 87 02 43 01 49 00 00 00 57 01 00 00 00 00 00 00 00 00 00 00 10 10 0c 0b 14 05 00 00 00 00 00 05 44 00 00 00 00 00 00 00 00 00 00 00 09 02 00 00 00 00 00 00 00 00 00 00 00 00 85 23 03 d0 00 08 02 fd 05 aa 24 01 02 04 29 fc 3e 24 01 08 02 87 02 43 01 49 00 00 00 57 01 00 00 00 00 00 00 00 00 00 00 10 10 0c 0b 14 05 00 00 00 00 00 05 44 00 00 00 00 00 00 00 00 00 00 00 09 02 00 00 00 00 00 00 00 00 00 00 00 00 85 fc 3e 24 01 09 02 87 02 43 01 4a 00 00 00 58 01 00 00 00 00 00 00 00 00 00 00 10 11 0c 0b 14 05 00 00 00 00 00 05 44 00 00 00 00 00 00 00 00 00 00 00 09 02 00 00 00 00 00 00 00 00 00 00 00 00 81 23 03 d0 00 09 01 fc 3e 24 01 0a 02 87 02 43 01 49 00 00 00 58 01 00 00 00 00 00 00 00 00 00 00 10 11 0c 0b 14 05 00 00 00 00 00 05 44 00 00 00 00 00 00 00 00 00 00 00 0a 02 00 00 00 00 00 00 00 00 00 00 00 00 80 fc 1f 0b 01 02 0a 01 58 02 87 00 00 00 00 00 00 00 00 10 11 0c 0b 00 00 00 00 00 00 00 00 44"
      // ca. 52 Grad auf Position 4 und 5 nach dem match
      var match = "fc 3e 24 01"
      var buffer
      var wert
      var position
          position = text.indexOf(match);
          if (position == 0)
          else
          text = text.substring(position);
          setState('Paradigma_String', text, true);
      // AB HIER BEKOMME ICH ES NICHT MEHR GEREGELT
      function()
      var request= require('request');
      request.post(text, function(error, response, body){
        if (body) {
            var parts_Paradigma = body.split('\n')[0];
      //Hier muss gerechnet werden
      //parts[5] (ist in HEX) *256 + parts[4] (ist in HEX) -> int /10
      //      setState('Paradigma_Kollektor',wert, true);
      • AlCalzone
        AlCalzone Developer @glitzi last edited by AlCalzone
        @glitzi Mit binären Daten kannst du mit Buffern sehr schön arbeiten, da sie dir das lästige Rechnen und so abnehmen - dazu musst du aber aus text alle Leerzeichen entfernen.
        Und die erste 0 scheint auch überzählig, wie kommst du denn an die Daten? Greifst du nicht direkt auf die Schnittstelle zu? Mir scheint es, als wäre der delimiter-parser für deine Zwecke super geeignet:
        const SerialPort = require('serialport')
        const Delimiter = require('@serialport/parser-delimiter')
        const port = new SerialPort('/dev/tty-usbserial1')
        const parser = port.pipe(new Delimiter({ delimiter: Buffer.from("fc3e2401", "hex") }))
        parser.on('data', chunk => {
        	// Wird für jeden Abschnitt der Nutzdaten aufgerufen, d.h. beim ersten Aufruf wäre es ein Buffer mit Inhalt
        	// 0902870243014900000056010000000000000000000010100c0b1405000000000005440000000000000000000000090200000000000000000000000085
        	// High und low byte tauschen (wirklich nötig??)
        	chunk = chunk.swap16();
        	// Auf Daten zugreifen (die 4 bytes Startsequenz sind hier nicht enthalten)
        	let val = chunk[1] * 256 + chunk[0] / 10;
        	// Das /10 kommt mir spanisch vor, alternativ kannst du auch direkt mehrbytige
        	// Zahlen aus dem Buffer lesen
        	val = chunk.readUInt16BE(0) // liest eine 2-byte-Zahl ab Position 0 ohne Bytes zu tauschen
        	val = chunk.readUInt16LE(0) // liest eine 2-byte-Zahl ab Position 0 und tauscht Bytes
        Wenn du die Daten nicht direkt vom Serialport bekommst, kannst du trotzdem den Parser nutzen:
        const Passthrough = require('stream').PassThrough;
        const myStream = new Passthrough();
        const parser = myStream.pipe(new Delimiter({ delimiter: Buffer.from("fc3e2401", "hex") }))
        	// wie vorher
        // Bei jedem Dateneingang:
        myStream.push(hexDatenOhneLeerzeichen, "hex");
        Denk aber dran, @serialport/parser-delimiter und ggf. serialport in den Adaptereinstellungen als zusätzliche Module zu laden.
          @AlCalzone
          Das sieht super aus, obwohl ich das erstmal verdauen muss 😉
          die /10 kommen wegen der Kommastellen, nach Umrechnung 520 > auf 52,0
          Die Daten werden nach dem Wechsel von OpenHAB auf IOBroker direkt von Serial Port kommen. In der Übergangsphase muss ich erstmal alle Daten, Schnittstellen, Influx, VIS usw. vorbereiten.
          Daher noch eine Frage:
          Wo könnte ich den Test-Datensatz z.B. "0000000 fc 3e 24 01 09 02 87 02 43 01 49 00 00 00 56 01 00 00 00 00 00 00 usw." einfügen?
          const myStream = new Passthrough(HIER?);
          MfG
          • AlCalzone
            @glitzi sagte in Daten Seriell von Paradigma Solaranlage lesen:
            Dann musst du aber erst addieren und dann teilen, nicht nur das eine Byte. Also
            chunk.readUInt16LE(0) / 10
            Vor Zeile 12:
            const hexDatenOhneLeerzeichen = "fc3e240109...";
            Führende Nullen am besten weglassen, sonst wird versucht, daraus was zu lesen. Und wie gesagt ohne Leerzeichen
              @AlCalzone
              jetzt kämpfe ich noch mit folgender Fehlermeldung:
                  setState('Paradigma_Kollektor', text, true);
              const hexDatenOhneLeerzeichen = "fc3e24010902870243014900000056010000000000000000000010100c0b1405000000000005440000000000000000000000090200000000000000000000000085fc3e24010902870243014a00000057010000";
              19:08:50.225	error	javascript.0 (11358) script.js.Paradigma_Test: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/lib/../../stream'
              19:08:50.227	error	javascript.0 (11358) at script.js.Paradigma_Test:2:21
              19:08:50.233	error	javascript.0 (11358) script.js.Paradigma_Test: script.js.Paradigma_Test:2
              19:08:50.234	error	javascript.0 (11358) at script.js.Paradigma_Test:2:38
              Die Module habe ich eingebunden.
              • AlCalzone
                @glitzi Komisch, "stream" ist ein eingebautes Modul von Node.js - das müsste er finden (aber nicht da wo es gesucht wird).
                Alternativ (ungetestet) lass mal Zeilen 2 und 5 weg, ändere 6 zu
                const parser = new Delimiter({ delimiter: Buffer.from("fc3e2401", "hex") });
                und ersetze myStream in Zeile 15 durch parser
                  @AlCalzone
                  Einfach KLASSE es funktioniert...
                  Noch eine Frage:
                  Ist es egal wenn folgende Zeilen erst am Ende stehen?
                  AlCalzone G 2 Replies Last reply Reply Quote 0
                  • AlCalzone
                    @glitzi Wichtig ist dass das .push nach dem .on("data") steht. Und die Definition der Daten muss vor dem push bekannt sein.
                      glitzi @glitzi last edited by glitzi
                      @AlCalzone
                      Wenn ich Testweise einige Zeichen vor das fc3... einfüge sollte das Skript ja trotzdem erst bei fc3 etc Anfangen.
                      Leider macht er das nicht?
                      	val = chunk.readUInt16LE(4) // liest eine 2-byte-Zahl ab Position 0 ohne Bytes zu tauschen
                          setState('Paradigma_Kollektor', val /10, true);
                      @AlCalzone
                      Noch eine Frage:
                      Parser.push(hexDatenOhneLeerzeichen, "hex");
                      • AlCalzone
                        Nein, der teilt die eingehenden Daten an fc3e2401 auf. D.h. alles was vorher kommt, wird auch an die verarbeitende Methode gegeben.
                        Du könntest z.B. bevor du die Daten auswertest prüfen, ob die erhaltene Datenmenge dem entspricht, was zu erwarten ist, z.B.:
                        if (chunk.length < 10) return;
                        (ich weiß nicht wie viele Bytes Nutzdaten üblicherweise kommen, ggf. muss die Schwelle kleiner oder größer gewählt werden.)
                          @AlCalzone
                          Da kommen auch noch sehr viele andere (und unbekannte) Daten über die Schnittstelle rein, daher benötige ich x Byte nach dem fc3e2401 und nur diese sollen dann verarbeitet werden.
                          Eventuell versteh ich das auch falsch?
                          aktuell nutze ich ja nur einen Test Datensatz, später kommt das ja von der Seriellen Schnittstelle
                          • AlCalzone
                            @glitzi Hmm, scheint so als würde der Parser genau anders herum arbeiten als du das brauchst. Er wartet immer bis die Byte-Folge kommt und gibt alles davor aus.
                            Ich hab so einen ähnlichen Anwendungsfall in meinem Adapter, ich bau dir mal ne Alternative.
                            • AlCalzone
                              @glitzi schau mal hier. Ab Zeile 56 steht wie du es nutzen kannst. Zeile 63 bitte mit deiner bestehenden Auswertung ersetzen, ich hab das nur zum Testen mal geloggt. Außerdem war noch ein kleiner Fehler drin (letzte Zeile). Die Daten müssen per write in den Parser geschrieben werden, nicht per push.
                              const { Transform } = require("stream");
                              class PreambleParser extends Transform {
                              	 * @param {Buffer} preamble
                              	 * @param {number} payloadLength
                              	constructor(preamble, payloadLength) {
                              		super();
                              		this.receiveBuffer = Buffer.allocUnsafe(0);
                              		this.preamble = preamble;
                              		this.payloadLength = payloadLength;
                              	_transform(chunk, encoding, callback) {
                              		this.receiveBuffer = Buffer.concat([this.receiveBuffer, chunk]);
                              		while (this.receiveBuffer.length >= this.preamble.length) {
                              			// Check if the buffer starts with the preamble
                              			const preambleIndex = this.receiveBuffer.indexOf(this.preamble);
                              			if (preambleIndex === -1) {
                              				// not found, wait for the next chunk
                              				break;
                              			// Skip bytes before the preamble
                              			this.receiveBuffer = skipBytes(this.receiveBuffer, preambleIndex);
                              			// Check if we still have enough data
                              			if (
                              				this.preamble.length + this.payloadLength
                              				// Yes, emit it
                              				this.push(
                              					this.receiveBuffer.slice(
                              						this.preamble.length,
                              						this.preamble.length + this.payloadLength,
                              				// And skip the bytes
                              					this.receiveBuffer,
                              		callback();
                              /** Skips the first n bytes of a buffer and returns the rest */
                              function skipBytes(buf, n) {
                              	return Buffer.from(buf.slice(n));
                              const parser = new PreambleParser(
                              	Buffer.from("fc3e2401", "hex"), // Start der Datenpakete
                              	10, // Wie viele Bytes nach dem Start ausgewertet werden
                              parser.on("data", (chunk) => {
                              	console.log(chunk.toString("hex"));
                              	"00112233fc3e24010902870243014900000056010000000000000000000010100c0b1405000000000005440000000000000000000000090200000000000000000000000085fc3e24010902870243014a00000057010000";
                              parser.write(hexDatenOhneLeerzeichen, "hex");
                              Eine Testausgabe auf der Konsole zeigt die gewünschten 10 Bytes nach den Anfangs-Bytes.:
                              $ node preambleParser.js
                                Ich bin Stolz auf mich 😉
                                so geht es
                                const parser = new Ready({ delimiter: Buffer.from("fc3e2401", "hex") });
                                und
                                Nächste Woche benötige ich dann dieses Skript und muß das Empfangene dann in die obere Zeile bringen?
                                Der Vollständigkeit nochmal das ganze...
                                const Ready = require('@serialport/parser-ready')
                                createState('Paradigma_Speichertemperatur');
                                createState('Paradigma_Solarvorlauf');
                                createState('Paradigma_Aussentemperatur');
                                createState('Paradigma_Solarrücklauf');
                                createState('Paradigma_Durchfluss');
                                createState('Paradigma_PWMPumpe');
                                createState('Paradigma_Tagesleistung');
                                createState('Paradigma_Gesamtleistung');
                                createState('Paradigma_Status');
                                createState('Paradigma_StatusText');
                                createState('Paradigma_Fehlercode');
                                createState('Paradigma_FehlercodeText');
                                //const parser = new Delimiter({ delimiter: Buffer.from("fc3e2401", "hex") });
                                //const parser = new PreambleParser(Buffer.from("fc3e2401", "hex"), 10, );
                                	val = chunk.readUInt16LE(0) // liest eine 2-byte-Zahl ab Position 0 ohne Bytes zu tauschen
                                    val = chunk.readUInt16LE(2) // liest eine 2-byte-Zahl ab Position 0 ohne Bytes zu tauschen
                                    setState('Paradigma_Speichertemperatur', val /10, true);
                                    setState('Paradigma_Solarvorlauf', val /10, true);
                                    val = chunk.readInt16LE(6) // liest eine 2-byte-Zahl ab Position 0 ohne Bytes zu tauschen
                                    setState('Paradigma_Aussentemperatur', val /10, true);
                                    val = chunk.readUInt16LE(10) // liest eine 2-byte-Zahl ab Position 0 ohne Bytes zu tauschen
                                    setState('Paradigma_Solarrücklauf', val /10, true);
                                    val = chunk.readUInt16LE(12) // liest eine 2-byte-Zahl ab Position 0 ohne Bytes zu tauschen
                                    setState('Paradigma_Durchfluss', val /10, true);
                                    val = chunk.readUInt8(14) // liest eine 2-byte-Zahl ab Position 0 ohne Bytes zu tauschen
                                    setState('Paradigma_PWMPumpe', val /10, true);
                                    val = chunk.readUInt16LE(29) // liest eine 2-byte-Zahl ab Position 0 ohne Bytes zu tauschen
                                    setState('Paradigma_Tagesleistung', val , true);
                                    val = chunk.readUInt16LE(32) // liest eine 2-byte-Zahl ab Position 0 ohne Bytes zu tauschen
                                    setState('Paradigma_Gesamtleistung', val /10, true);
                                    val = chunk.readUInt8(17) // liest eine 2-byte-Zahl ab Position 0 ohne Bytes zu tauschen
                                    setState('Paradigma_Status', val, true);
                                switch(val) {
                                  case 0:
                                    setState('Paradigma_StatusText', 'Warten auf Sonne', true);
                                    break;
                                  case 1:
                                    setState('Paradigma_StatusText', 'Frostschutz', true);
                                    break;
                                  case 2:
                                    setState('Paradigma_StatusText', 'Anschieben', true);
                                    break;
                                  case 3:
                                    setState('Paradigma_StatusText', 'Einschaltverzögerung', true);
                                    break;
                                  case 4:
                                    setState('Paradigma_StatusText', 'erwärmt Speicher', true);
                                    break;
                                  case 5:
                                    setState('Paradigma_StatusText', 'Speicher voll', true);
                                    break;
                                  case 6:
                                    setState('Paradigma_StatusText', 'Kollektor überhitzt', true);
                                    break;
                                  case 7:
                                    setState('Paradigma_StatusText', 'Hand, Test oder Aus', true);
                                    break;
                                  case 8:
                                    setState('Paradigma_StatusText', 'Messung', true);
                                    break;
                                   default:
                                    setState('Paradigma_StatusText', val, true);
                                    val = chunk.readUInt8(18) // liest eine 2-byte-Zahl ab Position 0 ohne Bytes zu tauschen
                                    setState('Paradigma_Fehlercode', val /10, true);
                                switch(val) {
                                  case 0:
                                    setState('Paradigma_FehlercodeText', 'OK', true);
                                    break;
                                  case 1:
                                    setState('Paradigma_FehlercodeText', 'Kein Volumenstrom', true);
                                    break;
                                  case 2:
                                    setState('Paradigma_FehlercodeText', 'Luft in der Anlage', true);
                                    break;
                                  case 4:
                                    setState('Paradigma_FehlercodeText', 'Vor- u. Rücklauf vertauscht', true);
                                    break;
                                  case 5:
                                    setState('Paradigma_FehlercodeText', 'Zonenventil defekt', true);
                                    break;
                                  case 6:
                                    setState('Paradigma_FehlercodeText', 'Falsche Uhrzeit', true);
                                    break;
                                  case 7:
                                    setState('Paradigma_FehlercodeText', 'Druckabfall in der Anlage', true);
                                    break;
                                  case 9:
                                    setState('Paradigma_FehlercodeText', 'Falsche Hydraulik', true);
                                    break;
                                  case 10:
                                    setState('Paradigma_FehlercodeText', 'Rohrisolierung', true);
                                    break;
                                  case 11:
                                    setState('Paradigma_FehlercodeText', 'Stromversorgung n. konstant', true);
                                    break;
                                  case 12:
                                    setState('Paradigma_FehlercodeText', 'OLV defekt', true);
                                    break;
                                  case 13:
                                    setState('Paradigma_FehlercodeText', 'Zu wenig Volumenstrom', true);
                                    break;
                                  case 14:
                                    setState('Paradigma_FehlercodeText', 'Speicher unterkühlt durch Frostschutz', true);
                                    break;
                                  case 20:
                                    setState('Paradigma_FehlercodeText', 'Fühler Außentemperatur falsch montiert', true);
                                    break;
                                  case 21:
                                    setState('Paradigma_FehlercodeText', 'Ausfall Kollektorfühler', true);
                                    break;
                                  case 22:
                                    setState('Paradigma_FehlercodeText', 'Ausfall Fühler Solarrücklauf', true);
                                    break;
                                  case 23:
                                    setState('Paradigma_FehlercodeText', 'Störung Kollektrofühler', true);
                                    break;
                                  case 24:
                                    setState('Paradigma_FehlercodeText', 'Frostschutz', true);
                                    break;
                                  case 25:
                                    setState('Paradigma_FehlercodeText', 'Fühler TSA u. TAM vertauscht', true);
                                    break;
                                  case 26:
                                    setState('Paradigma_FehlercodeText', 'Ausfall Fühler Solarvorlauf', true);
                                    break;
                                  case 27:
                                    setState('Paradigma_FehlercodeText', 'Ausfall Fühler Außentemperatur', true);
                                    break;
                                  case 34:
                                    setState('Paradigma_FehlercodeText', 'Überhitzung Speicher 1', true);
                                    break;
                                  case 35:
                                    setState('Paradigma_FehlercodeText', 'Überhitzung Speicher 2', true);
                                    break;
                                  case 49:
                                    setState('Paradigma_FehlercodeText', 'Solarstation unterkühlt', true);
                                    break;
                                  case 50:
                                    setState('Paradigma_FehlercodeText', 'Kollektor eingefroren', true);
                                    break;
                                   default:
                                    setState('Paradigma_FehlercodeText', val, true);
                                //const hexDatenOhneLeerzeichen = "fc3e24010902870243014900000056010000000000000000000010100c0b1405000000000005440000000000000000000000090200000000000000000000000085fc3e24010902870243014a00000057010000";
                                const hexDatenOhneLeerzeichen = "fc3e240163007002d300f8ff000072010000000000010001100015141b0b1439000000000039440000000000000000000000630000000000000000000000000001fc3e240163007002d300f9ff0000";
                                //parser.push(hexDatenOhneLeerzeichen, "hex");
                                • AlCalzone
                                  @glitzi Ich fürchte mit dem Ready-Parser wird es auch nicht hinhauen. Wenn du da mal das Beispiel liest:
                                  all data after READY is received
                                  d.h. du bekommst nur einmal sämtliche Daten, die nach dem allerersten fc3e2401 kommen. Allerdings enthält schon dein Beispielcode zwei "Datenpakete". Mit meinem PreambleParser bekommst du die angegebene Anzahl an Bytes nach jedem fc3e2401 - nach deinem Code zu urteilen brauchst du 34 Bytes.
                                    @AlCalzone
                                    Kann das nicht funktionieren wenn ich alle x Sekunden die Daten von der Schnittstelle in einen Datenpunkt schreibe und den Parser damit neu triggere?
                                    Dann sollte ja auch das überlange Telegramm nicht stören.
                                    Dazu wäre noch interessant wie ich das vorher von der Schnittstelle in einen Datenpunkt bekomme?
                                    • AlCalzone
                                      Wenn es dich nicht stört, dass du dann einen Teil der Daten ignorierst.
                                      Ich bin mir nicht sicher, wie die Daten vom Serialport kommen. Musst du ein Paket schicken, damit Daten zurück kommen? Oder sendet die Solaranlage permanent/regelmäßig?
                                      Falls letzteres wäre es IMO besser, beim Skriptstart die Schnittstelle zu öffnen, einmal einen geeigneten Parser aufsetzen und dann nur noch aufs data-Event zu lauschen. Dann brauchst du auch keinen Umweg über Datenpunkte, wenn dich nachher eh nur die Nutzdaten interessieren.
                                        @glitzi
                                        Also dann so?
                                        const parser = port.pipe(new Ready({ delimiter: Buffer.from("fc3e2401", "hex") }))
                                        und das weglassen?
                                        • AlCalzone
                                          @glitzi Wie oben schon geschrieben... mit dem Ready-Parser bekommst du nur ein einziges Mal ein Datenpaket.
                                          @AlCalzone sagte in Daten Seriell von Paradigma Solaranlage lesen:
                                            @AlCalzone
                                            Auch wenn ich das jede 30s Triggere?
                                            communication heating javascript
                                            4409
