    • simatec
      simatec Developer Most Active @Landmilch last edited by
      @Landmilch
      Bist du von Node 10 gewechselt?
        Thomas Braun Most Active @Landmilch last edited by
        @Landmilch
        node sauber im System?
        which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
        Nach dem Stromausfall das Dateisystem mal angeschaut?
        dmesg | grep -i ext4
          Landmilch @Thomas Braun last edited by
          @Thomas-Braun said in Test Adapter shuttercontrol v1.0.x:
          /usr/bin/nodejs
          v12.20.0
          /usr/bin/node
          v12.20.0
          /usr/bin/npm
          6.14.8
          nodejs:
            Installiert:           12.20.0-1nodesource1
            Installationskandidat: 12.20.0-1nodesource1
            Versionstabelle:
           *** 12.20.0-1nodesource1 500
                  500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                  100 /var/lib/dpkg/status
               10.21.0~dfsg-1~deb10u1+rpi1 500
          [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M cma=256M  smsc95xx.macaddr=DC:A6:32:1A:7D:07 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
          [    0.622209] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
          [    0.622245] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
          [    5.752019] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
          [    5.770323] EXT4-fs (mmcblk0p2): 3 orphan inodes deleted
          [    5.770352] EXT4-fs (mmcblk0p2): recovery complete
          [    7.938790] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
          [    7.938864] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [    9.964169] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
            Landmilch @simatec last edited by
            @simatec said in Test Adapter shuttercontrol v1.0.x:
            @Landmilch
            Das habe ich schon vor langer Zeit gemacht. Danach ist der Adapter über Monate einwandfrei gelaufen.
              @Thomas-Braun Die anderen Adapter laufen im übrigen einwandfrei.
                Thomas Braun Most Active @Landmilch last edited by Thomas Braun
                @Landmilch
                node ist okay, aber dein Dateisystem hat 'nen Schuss.
                SD-Kartentausch ist dringend angezeigt. Inkl. Neuinstallation und einspielen des Backups.
                Ein gesundes ext4 sieht so aus:
                pi@raspberrypi:~ $ dmesg | grep -i ext4
                [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1  smsc95xx.macaddr=DC:A6:32:5A:48:0E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=/dev/mmcblk0p7 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                [    1.324821] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
                [    1.324919] VFS: Mounted root (ext4 filesystem) readonly on device 179:7.
                [    3.162491] EXT4-fs (mmcblk0p7): re-mounted. Opts: (null)
                  @Thomas-Braun Vielen Dank für Euren schnellen Support. Würde am liebsten gleich auf SSD-Festplatte umstellen. Gibt es irgendwo eine Anleitung dafür, wie man das am besten macht?
                    @Landmilch
                    So auf die Schnelle für dich gegoogelt:
                    https://www.tomshardware.com/how-to/boot-raspberry-pi-4-usb
                    Mit aktueller Firmware geht das bei dann los. Der Kram davor ist nicht erforderlich bei aktueller Firmware.
                    1. Launch raspi-config
                      handy80 last edited by
                      Hallo Kollegen der Haus-Automation,
                      ich habe seit ein paar Wochen Shuttercontrol aktiv und obwohl er noch Probleme mit compact mode hat möchte ich hier gern bei bleiben. Allerdings öffnen sich meine Rolladen nicht (schließen geht) 🙂 Klingt lustig, isses aber nicht so wirklich 😉
                      Vielleicht wird jemand von euch schlau aus dem Log und kann mir helfen:
                      PS Wo sehe ich wann effektiv z.B. Schlafzimmerrollo.Hinten hoch gefahren werden sollten?
                      shuttercontrol.0	2020-11-28 10:55:00.006	debug	(1119) Sun Elevation: 14.7°
                      shuttercontrol.0	2020-11-28 10:55:00.005	debug	(1119) Sun Azimut: 159.2°
                      shuttercontrol.0	2020-11-28 10:55:00.004	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 10:54:37.272	debug	(1119) system.adapter.admin.0: logging true
                      shuttercontrol.0	2020-11-28 10:50:00.006	debug	(1119) Sun Elevation: 14.4°
                      shuttercontrol.0	2020-11-28 10:50:00.005	debug	(1119) Sun Azimut: 158°
                      shuttercontrol.0	2020-11-28 10:50:00.004	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 10:45:00.005	debug	(1119) Sun Elevation: 14.1°
                      shuttercontrol.0	2020-11-28 10:45:00.004	debug	(1119) Sun Azimut: 156.9°
                      shuttercontrol.0	2020-11-28 10:45:00.004	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 10:40:00.005	debug	(1119) Sun Elevation: 13.8°
                      shuttercontrol.0	2020-11-28 10:40:00.004	debug	(1119) Sun Azimut: 155.7°
                      shuttercontrol.0	2020-11-28 10:40:00.003	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 10:35:00.010	debug	(1119) Sun Elevation: 13.5°
                      shuttercontrol.0	2020-11-28 10:35:00.004	debug	(1119) Sun Azimut: 154.6°
                      shuttercontrol.0	2020-11-28 10:35:00.003	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 10:30:00.005	debug	(1119) Sun Elevation: 13.2°
                      shuttercontrol.0	2020-11-28 10:30:00.004	debug	(1119) Sun Azimut: 153.4°
                      shuttercontrol.0	2020-11-28 10:30:00.003	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 10:25:00.006	debug	(1119) Sun Elevation: 12.8°
                      shuttercontrol.0	2020-11-28 10:25:00.005	debug	(1119) Sun Azimut: 152.3°
                      shuttercontrol.0	2020-11-28 10:25:00.004	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 10:20:00.006	debug	(1119) Sun Elevation: 12.4°
                      shuttercontrol.0	2020-11-28 10:20:00.005	debug	(1119) Sun Azimut: 151.2°
                      shuttercontrol.0	2020-11-28 10:20:00.004	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 10:15:00.006	debug	(1119) Sun Elevation: 12.1°
                      shuttercontrol.0	2020-11-28 10:15:00.005	debug	(1119) Sun Azimut: 150°
                      shuttercontrol.0	2020-11-28 10:15:00.004	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 10:10:00.006	debug	(1119) Sun Elevation: 11.7°
                      shuttercontrol.0	2020-11-28 10:10:00.005	debug	(1119) Sun Azimut: 148.9°
                      shuttercontrol.0	2020-11-28 10:10:00.004	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 10:05:00.006	debug	(1119) Sun Elevation: 11.3°
                      shuttercontrol.0	2020-11-28 10:05:00.005	debug	(1119) Sun Azimut: 147.8°
                      shuttercontrol.0	2020-11-28 10:05:00.004	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 10:00:00.006	debug	(1119) Sun Elevation: 10.8°
                      shuttercontrol.0	2020-11-28 10:00:00.005	debug	(1119) Sun Azimut: 146.7°
                      shuttercontrol.0	2020-11-28 10:00:00.004	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 09:55:00.005	debug	(1119) Sun Elevation: 10.4°
                      shuttercontrol.0	2020-11-28 09:55:00.004	debug	(1119) Sun Azimut: 145.6°
                      shuttercontrol.0	2020-11-28 09:55:00.003	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 09:50:00.007	debug	(1119) Sun Elevation: 10°
                      shuttercontrol.0	2020-11-28 09:50:00.005	debug	(1119) Sun Azimut: 144.5°
                      shuttercontrol.0	2020-11-28 09:50:00.004	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 09:45:00.006	debug	(1119) Sun Elevation: 9.5°
                      shuttercontrol.0	2020-11-28 09:45:00.005	debug	(1119) Sun Azimut: 143.4°
                      shuttercontrol.0	2020-11-28 09:45:00.004	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 09:40:00.006	debug	(1119) Sun Elevation: 9°
                      shuttercontrol.0	2020-11-28 09:40:00.005	debug	(1119) Sun Azimut: 142.3°
                      shuttercontrol.0	2020-11-28 09:40:00.004	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 09:35:51.769	debug	(1119) Küchenrollo.Hinten Old value = 0. New value = 100. automatic is active
                      shuttercontrol.0	2020-11-28 09:35:51.768	debug	(1119) Shutter state changed: Küchenrollo.Hinten old value = 0 new value = 100
                      shuttercontrol.0	2020-11-28 09:35:51.768	debug	(1119) Küchenrollo.Hinten opened manually to 100. Old value = 0. New value = 100. Possibility to activate sunprotect enabled.
                      shuttercontrol.0	2020-11-28 09:35:19.269	debug	(1119) Küchenrollo.Hinten Updated trigger action to Manu_Mode to prevent moving after window close
                      shuttercontrol.0	2020-11-28 09:35:19.268	debug	(1119) Küchenrollo.Hinten drived manually to 15.5. Old value = 0. New value = 15.5
                      shuttercontrol.0	2020-11-28 09:35:19.267	debug	(1119) Shutter state changed: Küchenrollo.Hinten old value = 0 new value = 15.5
                      shuttercontrol.0	2020-11-28 09:35:12.975	debug	(1119) Wohnzimmerrollo.Seite Old value = 0. New value = 100. automatic is active
                      shuttercontrol.0	2020-11-28 09:35:12.975	debug	(1119) Shutter state changed: Wohnzimmerrollo.Seite old value = 0 new value = 100
                      shuttercontrol.0	2020-11-28 09:35:12.974	debug	(1119) Wohnzimmerrollo.Seite opened manually to 100. Old value = 0. New value = 100. Possibility to activate sunprotect enabled.
                      shuttercontrol.0	2020-11-28 09:35:00.006	debug	(1119) Sun Elevation: 8.6°
                      shuttercontrol.0	2020-11-28 09:35:00.005	debug	(1119) Sun Azimut: 141.3°
                      shuttercontrol.0	2020-11-28 09:35:00.004	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 09:34:55.578	debug	(1119) Wohnzimmerrollo.Vorne Old value = 0. New value = 100. automatic is active
                      shuttercontrol.0	2020-11-28 09:34:55.577	debug	(1119) Shutter state changed: Wohnzimmerrollo.Vorne old value = 0 new value = 100
                      shuttercontrol.0	2020-11-28 09:34:55.574	debug	(1119) Wohnzimmerrollo.Vorne opened manually to 100. Old value = 0. New value = 100. Possibility to activate sunprotect enabled.
                      shuttercontrol.0	2020-11-28 09:34:42.287	debug	(1119) Wohnzimmerrollo.Seite Updated trigger action to Manu_Mode to prevent moving after window close
                      shuttercontrol.0	2020-11-28 09:34:42.286	debug	(1119) Wohnzimmerrollo.Seite drived manually to 14. Old value = 0. New value = 14
                      shuttercontrol.0	2020-11-28 09:34:42.285	debug	(1119) Shutter state changed: Wohnzimmerrollo.Seite old value = 0 new value = 14
                      shuttercontrol.0	2020-11-28 09:30:00.006	debug	(1119) Sun Elevation: 8.1°
                      shuttercontrol.0	2020-11-28 09:30:00.006	debug	(1119) Sun Azimut: 140.2°
                      shuttercontrol.0	2020-11-28 09:30:00.005	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 09:28:45.441	debug	(1119) Schlafzimmerrollo.Hinten Updated trigger action to Manu_Mode to prevent moving after window close
                      shuttercontrol.0	2020-11-28 09:28:45.440	debug	(1119) Schlafzimmerrollo.Hinten drived manually to 95. Old value = 0. New value = 95
                      shuttercontrol.0	2020-11-28 09:28:45.439	debug	(1119) Shutter state changed: Schlafzimmerrollo.Hinten old value = 0 new value = 95
                      shuttercontrol.0	2020-11-28 09:28:37.435	debug	(1119) Schlafzimmerrollo.Seite Updated trigger action to Manu_Mode to prevent moving after window close
                      shuttercontrol.0	2020-11-28 09:28:37.434	debug	(1119) Schlafzimmerrollo.Seite drived manually to 5. Old value = 100. New value = 5
                      shuttercontrol.0	2020-11-28 09:28:37.433	debug	(1119) Shutter state changed: Schlafzimmerrollo.Seite old value = 100 new value = 5
                      shuttercontrol.0	2020-11-28 09:28:36.439	debug	(1119) Schlafzimmerrollo.Seite Updated trigger action to Manu_Mode to prevent moving after window close
                      shuttercontrol.0	2020-11-28 09:28:36.438	debug	(1119) Schlafzimmerrollo.Seite drived manually to 7. Old value = 100. New value = 7
                      shuttercontrol.0	2020-11-28 09:28:36.437	debug	(1119) Shutter state changed: Schlafzimmerrollo.Seite old value = 100 new value = 7
                      shuttercontrol.0	2020-11-28 09:28:35.404	debug	(1119) Schlafzimmerrollo.Seite Updated trigger action to Manu_Mode to prevent moving after window close
                      shuttercontrol.0	2020-11-28 09:28:35.403	debug	(1119) Schlafzimmerrollo.Seite drived manually to 12. Old value = 100. New value = 12
                      shuttercontrol.0	2020-11-28 09:28:35.402	debug	(1119) Shutter state changed: Schlafzimmerrollo.Seite old value = 100 new value = 12
                      shuttercontrol.0	2020-11-28 09:28:34.336	debug	(1119) Schlafzimmerrollo.Seite Updated trigger action to Manu_Mode to prevent moving after window close
                      shuttercontrol.0	2020-11-28 09:28:34.335	debug	(1119) Schlafzimmerrollo.Seite drived manually to 18. Old value = 100. New value = 18
                      shuttercontrol.0	2020-11-28 09:28:34.334	debug	(1119) Shutter state changed: Schlafzimmerrollo.Seite old value = 100 new value = 18
                      shuttercontrol.0	2020-11-28 09:28:33.336	debug	(1119) Schlafzimmerrollo.Seite Updated trigger action to Manu_Mode to prevent moving after window close
                      shuttercontrol.0	2020-11-28 09:28:33.336	debug	(1119) Schlafzimmerrollo.Seite drived manually to 23. Old value = 100. New value = 23
                      shuttercontrol.0	2020-11-28 09:28:33.334	debug	(1119) Shutter state changed: Schlafzimmerrollo.Seite old value = 100 new value = 23
                      shuttercontrol.0	2020-11-28 09:28:32.331	debug	(1119) Schlafzimmerrollo.Seite Updated trigger action to Manu_Mode to prevent moving after window close
                      shuttercontrol.0	2020-11-28 09:28:32.330	debug	(1119) Schlafzimmerrollo.Seite drived manually to 28. Old value = 100. New value = 28
                      shuttercontrol.0	2020-11-28 09:28:32.329	debug	(1119) Shutter state changed: Schlafzimmerrollo.Seite old value = 100 new value = 28
                      shuttercontrol.0	2020-11-28 09:28:31.278	debug	(1119) Schlafzimmerrollo.Seite Updated trigger action to Manu_Mode to prevent moving after window close
                      shuttercontrol.0	2020-11-28 09:28:31.277	debug	(1119) Schlafzimmerrollo.Seite drived manually to 34. Old value = 100. New value = 34
                      shuttercontrol.0	2020-11-28 09:28:31.276	debug	(1119) Shutter state changed: Schlafzimmerrollo.Seite old value = 100 new value = 34
                      shuttercontrol.0	2020-11-28 09:28:30.242	debug	(1119) Schlafzimmerrollo.Seite Updated trigger action to Manu_Mode to prevent moving after window close
                      shuttercontrol.0	2020-11-28 09:28:30.238	debug	(1119) Schlafzimmerrollo.Seite drived manually to 39. Old value = 100. New value = 39
                      shuttercontrol.0	2020-11-28 09:28:30.237	debug	(1119) Shutter state changed: Schlafzimmerrollo.Seite old value = 100 new value = 39
                      shuttercontrol.0	2020-11-28 09:28:29.207	debug	(1119) Schlafzimmerrollo.Seite Updated trigger action to Manu_Mode to prevent moving after window close
                      shuttercontrol.0	2020-11-28 09:28:29.206	debug	(1119) Schlafzimmerrollo.Seite drived manually to 44. Old value = 100. New value = 44
                      shuttercontrol.0	2020-11-28 09:28:29.205	debug	(1119) Shutter state changed: Schlafzimmerrollo.Seite old value = 100 new value = 44
                      shuttercontrol.0	2020-11-28 09:28:28.134	debug	(1119) Schlafzimmerrollo.Seite Updated trigger action to Manu_Mode to prevent moving after window close
                      shuttercontrol.0	2020-11-28 09:28:28.133	debug	(1119) Schlafzimmerrollo.Seite drived manually to 50. Old value = 100. New value = 50
                      shuttercontrol.0	2020-11-28 09:28:28.132	debug	(1119) Shutter state changed: Schlafzimmerrollo.Seite old value = 100 new value = 50
                      shuttercontrol.0	2020-11-28 09:28:27.093	debug	(1119) Schlafzimmerrollo.Seite Updated trigger action to Manu_Mode to prevent moving after window close
                      shuttercontrol.0	2020-11-28 09:28:27.092	debug	(1119) Schlafzimmerrollo.Seite drived manually to 55. Old value = 100. New value = 55
                      shuttercontrol.0	2020-11-28 09:28:27.091	debug	(1119) Shutter state changed: Schlafzimmerrollo.Seite old value = 100 new value = 55
                      shuttercontrol.0	2020-11-28 09:28:26.113	debug	(1119) Schlafzimmerrollo.Seite Updated trigger action to Manu_Mode to prevent moving after window close
                      shuttercontrol.0	2020-11-28 09:28:26.113	debug	(1119) Schlafzimmerrollo.Seite drived manually to 60. Old value = 100. New value = 60
                      shuttercontrol.0	2020-11-28 09:28:26.112	debug	(1119) Shutter state changed: Schlafzimmerrollo.Seite old value = 100 new value = 60
                      shuttercontrol.0	2020-11-28 09:28:25.027	debug	(1119) Schlafzimmerrollo.Seite Updated trigger action to Manu_Mode to prevent moving after window close
                      shuttercontrol.0	2020-11-28 09:28:25.026	debug	(1119) Schlafzimmerrollo.Seite drived manually to 66. Old value = 100. New value = 66
                      shuttercontrol.0	2020-11-28 09:28:25.025	debug	(1119) Shutter state changed: Schlafzimmerrollo.Seite old value = 100 new value = 66
                      shuttercontrol.0	2020-11-28 09:28:24.037	debug	(1119) Schlafzimmerrollo.Seite Updated trigger action to Manu_Mode to prevent moving after window close
                      shuttercontrol.0	2020-11-28 09:28:24.037	debug	(1119) Schlafzimmerrollo.Seite drived manually to 71. Old value = 100. New value = 71
                      shuttercontrol.0	2020-11-28 09:28:24.036	debug	(1119) Shutter state changed: Schlafzimmerrollo.Seite old value = 100 new value = 71
                      shuttercontrol.0	2020-11-28 09:28:22.999	debug	(1119) Schlafzimmerrollo.Seite Updated trigger action to Manu_Mode to prevent moving after window close
                      shuttercontrol.0	2020-11-28 09:28:22.999	debug	(1119) Schlafzimmerrollo.Seite drived manually to 76. Old value = 100. New value = 76
                      shuttercontrol.0	2020-11-28 09:28:22.998	debug	(1119) Shutter state changed: Schlafzimmerrollo.Seite old value = 100 new value = 76
                      shuttercontrol.0	2020-11-28 09:28:21.968	debug	(1119) Schlafzimmerrollo.Seite Updated trigger action to Manu_Mode to prevent moving after window close
                      shuttercontrol.0	2020-11-28 09:28:21.967	debug	(1119) Schlafzimmerrollo.Seite drived manually to 82. Old value = 100. New value = 82
                      shuttercontrol.0	2020-11-28 09:28:21.965	debug	(1119) Shutter state changed: Schlafzimmerrollo.Seite old value = 100 new value = 82
                      shuttercontrol.0	2020-11-28 09:28:20.894	debug	(1119) Schlafzimmerrollo.Seite Updated trigger action to Manu_Mode to prevent moving after window close
                      shuttercontrol.0	2020-11-28 09:28:20.894	debug	(1119) Schlafzimmerrollo.Seite drived manually to 87. Old value = 100. New value = 87
                      shuttercontrol.0	2020-11-28 09:28:20.892	debug	(1119) Shutter state changed: Schlafzimmerrollo.Seite old value = 100 new value = 87
                      shuttercontrol.0	2020-11-28 09:28:19.898	debug	(1119) Schlafzimmerrollo.Seite Updated trigger action to Manu_Mode to prevent moving after window close
                      shuttercontrol.0	2020-11-28 09:28:19.897	debug	(1119) Schlafzimmerrollo.Seite drived manually to 92. Old value = 100. New value = 92
                      shuttercontrol.0	2020-11-28 09:28:19.896	debug	(1119) Shutter state changed: Schlafzimmerrollo.Seite old value = 100 new value = 92
                      shuttercontrol.0	2020-11-28 09:28:18.814	debug	(1119) Schlafzimmerrollo.Seite Updated trigger action to Manu_Mode to prevent moving after window close
                      shuttercontrol.0	2020-11-28 09:28:18.814	debug	(1119) Schlafzimmerrollo.Seite drived manually to 98. Old value = 100. New value = 98
                      shuttercontrol.0	2020-11-28 09:28:18.813	debug	(1119) Shutter state changed: Schlafzimmerrollo.Seite old value = 100 new value = 98
                      shuttercontrol.0	2020-11-28 09:25:00.006	debug	(1119) Sun Elevation: 7.6°
                      shuttercontrol.0	2020-11-28 09:25:00.005	debug	(1119) Sun Azimut: 139.1°
                      shuttercontrol.0	2020-11-28 09:25:00.004	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 09:20:00.006	debug	(1119) Sun Elevation: 7°
                      shuttercontrol.0	2020-11-28 09:20:00.005	debug	(1119) Sun Azimut: 138.1°
                      shuttercontrol.0	2020-11-28 09:20:00.004	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 09:15:00.005	debug	(1119) Sun Elevation: 6.5°
                      shuttercontrol.0	2020-11-28 09:15:00.004	debug	(1119) Sun Azimut: 137°
                      shuttercontrol.0	2020-11-28 09:15:00.003	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 09:10:00.013	debug	(1119) Sun Elevation: 6°
                      shuttercontrol.0	2020-11-28 09:10:00.005	debug	(1119) Sun Azimut: 136°
                      shuttercontrol.0	2020-11-28 09:10:00.004	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 09:05:00.006	debug	(1119) Sun Elevation: 5.4°
                      shuttercontrol.0	2020-11-28 09:05:00.005	debug	(1119) Sun Azimut: 135°
                      shuttercontrol.0	2020-11-28 09:05:00.004	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 09:00:00.006	debug	(1119) Sun Elevation: 4.9°
                      shuttercontrol.0	2020-11-28 09:00:00.005	debug	(1119) Sun Azimut: 133.9°
                      shuttercontrol.0	2020-11-28 09:00:00.004	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 08:57:18.434	debug	(1119) system.adapter.admin.0: logging false
                      shuttercontrol.0	2020-11-28 08:55:47.291	debug	(1119) system.adapter.admin.0: logging true
                      shuttercontrol.0	2020-11-28 08:55:00.006	debug	(1119) Sun Elevation: 4.3°
                      shuttercontrol.0	2020-11-28 08:55:00.005	debug	(1119) Sun Azimut: 132.9°
                      shuttercontrol.0	2020-11-28 08:55:00.004	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 08:50:00.006	debug	(1119) Sun Elevation: 3.7°
                      shuttercontrol.0	2020-11-28 08:50:00.005	debug	(1119) Sun Azimut: 131.9°
                      shuttercontrol.0	2020-11-28 08:50:00.004	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 08:45:00.006	debug	(1119) Sun Elevation: 3.2°
                      shuttercontrol.0	2020-11-28 08:45:00.005	debug	(1119) Sun Azimut: 130.9°
                      shuttercontrol.0	2020-11-28 08:45:00.004	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 08:40:00.005	debug	(1119) Sun Elevation: 2.6°
                      shuttercontrol.0	2020-11-28 08:40:00.004	debug	(1119) Sun Azimut: 129.9°
                      shuttercontrol.0	2020-11-28 08:40:00.003	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 08:35:00.006	debug	(1119) Sun Elevation: 2°
                      shuttercontrol.0	2020-11-28 08:35:00.005	debug	(1119) Sun Azimut: 128.9°
                      shuttercontrol.0	2020-11-28 08:35:00.004	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 08:30:00.007	debug	(1119) Sun Elevation: 1.4°
                      shuttercontrol.0	2020-11-28 08:30:00.006	debug	(1119) Sun Azimut: 127.9°
                      shuttercontrol.0	2020-11-28 08:30:00.005	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 08:25:00.006	debug	(1119) Sun Elevation: 0.7°
                      shuttercontrol.0	2020-11-28 08:25:00.005	debug	(1119) Sun Azimut: 126.9°
                      shuttercontrol.0	2020-11-28 08:25:00.004	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 08:20:00.006	debug	(1119) Sun Elevation: 0.1°
                      shuttercontrol.0	2020-11-28 08:20:00.005	debug	(1119) Sun Azimut: 125.9°
                      shuttercontrol.0	2020-11-28 08:20:00.004	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 08:15:00.006	debug	(1119) Sun Elevation: -0.5°
                      shuttercontrol.0	2020-11-28 08:15:00.005	debug	(1119) Sun Azimut: 125°
                      shuttercontrol.0	2020-11-28 08:15:00.004	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 08:10:00.006	debug	(1119) Sun Elevation: -1.2°
                      shuttercontrol.0	2020-11-28 08:10:00.005	debug	(1119) Sun Azimut: 124°
                      shuttercontrol.0	2020-11-28 08:10:00.004	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 08:05:00.006	debug	(1119) Sun Elevation: -1.8°
                      shuttercontrol.0	2020-11-28 08:05:00.005	debug	(1119) Sun Azimut: 123°
                      shuttercontrol.0	2020-11-28 08:05:00.004	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 08:00:00.007	debug	(1119) Sun Elevation: -2.5°
                      shuttercontrol.0	2020-11-28 08:00:00.006	debug	(1119) Sun Azimut: 122.1°
                      shuttercontrol.0	2020-11-28 08:00:00.005	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 07:55:00.005	debug	(1119) Sun Elevation: -3.1°
                      shuttercontrol.0	2020-11-28 07:55:00.005	debug	(1119) Sun Azimut: 121.1°
                      shuttercontrol.0	2020-11-28 07:55:00.004	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 07:50:00.006	debug	(1119) Sun Elevation: -3.8°
                      shuttercontrol.0	2020-11-28 07:50:00.005	debug	(1119) Sun Azimut: 120.1°
                      shuttercontrol.0	2020-11-28 07:50:00.004	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 07:45:00.005	debug	(1119) Sun Elevation: -4.5°
                      shuttercontrol.0	2020-11-28 07:45:00.004	debug	(1119) Sun Azimut: 119.2°
                      shuttercontrol.0	2020-11-28 07:45:00.003	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 07:40:00.006	debug	(1119) Sun Elevation: -5.1°
                      shuttercontrol.0	2020-11-28 07:40:00.005	debug	(1119) Sun Azimut: 118.3°
                      shuttercontrol.0	2020-11-28 07:40:00.004	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 07:35:00.005	debug	(1119) Sun Elevation: -5.8°
                      shuttercontrol.0	2020-11-28 07:35:00.005	debug	(1119) Sun Azimut: 117.3°
                      shuttercontrol.0	2020-11-28 07:35:00.004	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 07:30:00.005	debug	(1119) Sun Elevation: -6.5°
                      shuttercontrol.0	2020-11-28 07:30:00.004	debug	(1119) Sun Azimut: 116.4°
                      shuttercontrol.0	2020-11-28 07:30:00.003	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 07:25:00.006	debug	(1119) Sun Elevation: -7.2°
                      shuttercontrol.0	2020-11-28 07:25:00.005	debug	(1119) Sun Azimut: 115.4°
                      shuttercontrol.0	2020-11-28 07:25:00.004	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 07:20:00.006	debug	(1119) Sun Elevation: -7.9°
                      shuttercontrol.0	2020-11-28 07:20:00.005	debug	(1119) Sun Azimut: 114.5°
                      shuttercontrol.0	2020-11-28 07:20:00.004	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 07:15:00.006	debug	(1119) Sun Elevation: -8.6°
                      shuttercontrol.0	2020-11-28 07:15:00.005	debug	(1119) Sun Azimut: 113.6°
                      shuttercontrol.0	2020-11-28 07:15:00.004	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 07:10:00.005	debug	(1119) Sun Elevation: -9.4°
                      shuttercontrol.0	2020-11-28 07:10:00.004	debug	(1119) Sun Azimut: 112.6°
                      shuttercontrol.0	2020-11-28 07:10:00.003	debug	(1119) calculate astrodata ...
                      shuttercontrol.0	2020-11-28 07:05:00.006	debug	(1119) Sun Elevation: -10.1°
                      • simatec
                        simatec Developer Most Active @handy80 last edited by
                        @handy80
                        Poste mal bitte deine setting von shuttercontrol als json ...
                        Ist der state von shuttercontrol.0.control.autoSleep auf true?
                          handy80 @simatec last edited by
                          @simatec
                          shuttercontrol.0.control.autoSleep steht auf false.
                            "_id": "system.adapter.shuttercontrol.0",
                            "common": {
                              "name": "shuttercontrol",
                              "version": "1.0.4",
                              "title": "shuttercontrol",
                              "authors": [
                                "simatec <nais@gmx.net>"
                              "keywords": [
                                "ioBroker",
                                "Smart Home",
                                "home automation",
                                "Rollladen",
                                "Jalousie",
                                "Rollladensteuerung"
                              "license": "MIT",
                              "platform": "Javascript/Node.js",
                              "main": "main.js",
                              "icon": "shuttercontrol.png",
                              "enabled": true,
                              "extIcon": "https://raw.githubusercontent.com/simatec/ioBroker.shuttercontrol/master/admin/shuttercontrol.png",
                              "readme": "https://github.com/simatec/ioBroker.shuttercontrol/blob/master/README.md",
                              "loglevel": "debug",
                              "mode": "daemon",
                              "type": "climate-control",
                              "compact": true,
                              "materialize": true,
                              "stopBeforeUpdate": true,
                              "dependencies": [
                                  "admin": ">=3.0.0"
                              "installedFrom": "iobroker.shuttercontrol@1.0.4",
                              "installedVersion": "1.0.4",
                              "host": "ioBroker",
                              "compactGroup": 1,
                              "runAsCompactMode": false,
                              "plugins": {
                                "sentry": {
                                  "dsn": "https://5f58df7167d846e3a90bae5414d4fc09@sentry.iobroker.net/62"
                              "contributors": [
                                "Rene G. <info@rg-engineering.eu>"
                            "native": {
                              "livingAutomatic": "livingSunriseSunset",
                              "W_shutterDownLiving": "22:00",
                              "W_shutterUpLivingMin": "05:00",
                              "W_shutterUpLivingMax": "06:00",
                              "driveDelayUpLiving": "10",
                              "WE_shutterDownLiving": "22:00",
                              "WE_shutterUpLivingMin": "05:00",
                              "WE_shutterUpLivingMax": "06:00",
                              "sleepAutomatic": "sleepSunriseSunset",
                              "W_shutterDownSleep": "20:00",
                              "W_shutterUpSleepMin": "06:00",
                              "W_shutterUpSleepMax": "06:30",
                              "driveDelayUpSleep": "10",
                              "WE_shutterDownSleep": "21:00",
                              "WE_shutterUpSleepMin": "06:00",
                              "WE_shutterUpSleepMax": "06:30",
                              "childrenAutomatic": "childrenGoldenHour",
                              "W_shutterDownChildren": "20:00",
                              "W_shutterUpChildrenMin": "06:00",
                              "W_shutterUpChildrenMax": "06:30",
                              "driveDelayUpChildren": "10",
                              "WE_shutterDownChildren": "21:00",
                              "WE_shutterUpChildrenMin": "06:00",
                              "WE_shutterUpChildrenMax": "06:30",
                              "latitude": "51.4814735",
                              "longitude": "6.74913907732166",
                              "sunProtEndElevation": "10",
                              "astroDelayUp": "0",
                              "astroDelayDown": "30",
                              "driveDelayUpAstro": "10",
                              "LateAllDown": false,
                              "LateAllDownTime": "22:15",
                              "SummerStart": "01.03.",
                              "SummerEnd": "30.09.",
                              "XMasStart": "01.12.",
                              "XMasEnd": "06.01.",
                              "publicHolidays": true,
                              "publicHolInstance": "feiertage.0",
                              "HolidayDP": "",
                              "currentShutterState": false,
                              "noGoTime": "0",
                              "triggerAutoSleep": "hm-rpc.0.MEQ1234567.2.STATE",
                              "triggerAutoLiving": "hm-rpc.0.MEQ1234567.2.STATE",
                              "triggerAutoChildren": "hm-rpc.0.MEQ1234567.2.STATE",
                              "heightDownSun": "30",
                              "direction": "120",
                              "type": "off",
                              "directionRange": "50",
                              "actualValueTemp": "",
                              "actualValueLight": "",
                              "actualValueTempInside": "",
                              "KeepSunProtect": false,
                              "typeDown": "off",
                              "typeUp": "off",
                              "triggerStateShutter": "true",
                              "triggerChangeShutter": "off",
                              "triggerDriveShutter": "100",
                              "autoDriveShutter": "off",
                              "heightDownShutter": "0",
                              "heightUpShutter": "100",
                              "triggerID": "",
                              "LateDown": false,
                              "inSummerNotDown": true,
                              "driveAfterClose": false,
                              "useXmasLevel": false,
                              "XmasLevel": "0",
                              "events": [
                                  "enabled": true,
                                  "shutterName": "Bürorollo.Hinten",
                                  "name": "fhem.0.buRolloHinten.pct",
                                  "triggerID": "",
                                  "typeUp": "manual-only",
                                  "typeDown": "sunset",
                                  "type": "only direction",
                                  "heightDownSun": "70",
                                  "direction": "290",
                                  "directionRange": "15",
                                  "tempInside": "23",
                                  "tempSensor": "",
                                  "outsideTempSensor": "",
                                  "tempOutside": "23",
                                  "lightSensor": "",
                                  "valueLight": "15",
                                  "heightUp": "100",
                                  "heightDown": "0",
                                  "triggerState": "true",
                                  "triggerDrive": "100",
                                  "triggerChange": "upDown",
                                  "elevation": "4",
                                  "autoDrive": "off",
                                  "hysteresisOutside": "",
                                  "hysteresisInside": "",
                                  "hysteresisLight": "",
                                  "currentAction": "",
                                  "currentHeight": "",
                                  "oldHeight": "",
                                  "firstCompleteUp": "",
                                  "triggerHeight": "",
                                  "LateDown": false,
                                  "inSummerNotDown": false,
                                  "KeepSunProtect": true,
                                  "triggerAction": "",
                                  "XmasLevel": ""
                                  "enabled": true,
                                  "shutterName": "Schlafzimmerrollo.Hinten",
                                  "name": "fhem.0.srRolloHinten.pct",
                                  "triggerID": "",
                                  "typeUp": "sleep-auto",
                                  "typeDown": "sleep-auto",
                                  "type": "off",
                                  "direction": "120",
                                  "tempInside": "23",
                                  "tempSensor": "",
                                  "lightSensor": "",
                                  "valueLight": "15",
                                  "heightUp": "100",
                                  "heightDown": "0",
                                  "triggerChange": "off",
                                  "elevation": "8",
                                  "autoDrive": "off",
                                  "hysteresisOutside": "5",
                                  "hysteresisInside": "5",
                                  "hysteresisLight": "5",
                                  "oldHeight": "",
                                  "LateDown": false,
                                  "XmasLevel": "0"
                                  "enabled": true,
                                  "shutterName": "Schlafzimmerrollo.Seite",
                                  "name": "fhem.0.HUEDevice6.pct",
                                  "triggerID": "",
                                  "type": "off",
                                  "direction": "120",
                                  "tempInside": "23",
                                  "tempSensor": "",
                                  "lightSensor": "",
                                  "valueLight": "15",
                                  "heightUp": "95",
                                  "heightDown": "0",
                                  "elevation": "8",
                                  "autoDrive": "off",
                                  "oldHeight": "",
                                  "LateDown": false,
                                  "XmasLevel": "0"
                                  "enabled": true,
                                  "shutterName": "Wohnzimmerrollo.Seite",
                                  "name": "fhem.0.wzRolloSeite.pct",
                                  "triggerID": "",
                                  "typeUp": "living-auto",
                                  "typeDown": "living-auto",
                                  "type": "off",
                                  "direction": "120",
                                  "tempInside": "23",
                                  "tempSensor": "",
                                  "lightSensor": "",
                                  "valueLight": "15",
                                  "heightUp": "100",
                                  "heightDown": "0",
                                  "elevation": "8",
                                  "autoDrive": "off",
                                  "oldHeight": "",
                                  "LateDown": false,
                                  "XmasLevel": "0"
                                  "enabled": true,
                                  "shutterName": "Wohnzimmerrollo.Vorne",
                                  "name": "fhem.0.wzRolloVorne.pct",
                                  "triggerID": "",
                                  "typeUp": "children-auto",
                                  "typeDown": "children-auto",
                                  "type": "off",
                                  "direction": "120",
                                  "tempInside": "23",
                                  "tempSensor": "",
                                  "lightSensor": "",
                                  "valueLight": "15",
                                  "heightUp": "100",
                                  "heightDown": "0",
                                  "elevation": "8",
                                  "autoDrive": "off",
                                  "oldHeight": "",
                                  "LateDown": false,
                                  "XmasLevel": "0"
                                  "enabled": true,
                                  "shutterName": "Küchenrollo.Hinten",
                                  "name": "fhem.0.kuRolloTuer.pct",
                                  "triggerID": "",
                                  "typeUp": "off",
                                  "typeDown": "off",
                                  "type": "off",
                                  "direction": "120",
                                  "tempInside": "23",
                                  "tempSensor": "",
                                  "lightSensor": "",
                                  "valueLight": "15",
                                  "heightUp": "100",
                                  "heightDown": "0",
                                  "elevation": "8",
                                  "autoDrive": "off",
                                  "oldHeight": "",
                                  "LateDown": false,
                                  "XmasLevel": "0"
                          • simatec
                            @handy80
                            Stelle mal auf true wenn du den Automatikbereich wählst
                            • Nightfly1983
                              Nightfly1983 @simatec last edited by
                              @simatec Die XMAS Funktion würde mich schon interessieren in der Weihnachtszeit, nur leider scheint diese noch nicht zu funktionieren, zumindest fahren, trotz eingeschalteter Funktion, die Rollläden ganz normal zu. Jemand eine Idee, oder jemand, bei dem es funktioniert?
                              Rene_HM M 2 Replies Last reply Reply Quote 0
                              • Rene_HM
                                Rene_HM Developer @Nightfly1983 last edited by
                                Die XMAS Funktion würde...
                                Ich denke, du verwendest nicht die Bereiche für die betreffenden Jalousien? Bei "Sonnenuntergang" (siehe unten) fehlt noch etwas.
                                Wenn man Wohnbereich / Schlafbereich verwendet, funktioniert es.
                                Der PR ist in Vorbereitung, muss aber noch testen. In meinem github liegt der bugfix bereits...
                                simatec coyote 2 Replies Last reply Reply Quote 0
                                • simatec
                                  simatec Developer Most Active @Rene_HM last edited by
                                  @Rene_HM
                                  Bitte dann in den DEV Branch pushen
                                  • coyote
                                    coyote Most Active @Rene_HM last edited by
                                    @Rene_HM habe es gestern mit Wohn/Schlafbereich AUTO probiert, da geht es auch noch nicht. Nur so als Info 🙂 oder ist das in deinem github auch schon mit gefixt?
                                      MartyBr @Nightfly1983 last edited by
                                      @Nightfly1983 Hallo, ich bin ja nur Laie, aber bei mir hat das von Anfang an funktioniert. Großes Lob an @simatec !!!!!!
                                      Wichtig ist, dass sich die Zeiteinstellungen für Sommer und XMas nicht überschneiden.
                                      Anbei mein Json-File mit den Einstellungen, da sollte alles drinstehen.
                                      system.adapter.shuttercontrol.0 (1).json
                                      • Rene_HM
                                        Rene_HM Developer @coyote last edited by Rene_HM
                                        @coyote sagte in Test Adapter shuttercontrol v1.0.x:
                                        habe es gestern mit Wohn/Schlafbereich AUTO probiert, da geht es auch noch nicht. Nur so als Info oder ist das in deinem github auch schon mit gefixt?
                                        Hast du dafür ein debug-log? Für den o.g. Fall (Sonnenuntergang) habe ich einen Fehler gefunden, dieser Fall hier (Wohn/Schlafbereich auto) ist mir noch nicht klar...
                                        und vor allem: was geht nicht?
                                        • coyote
                                          @Rene_HM sorry, ich muss morgen mal noch abwarten, hatte einen Fehler gemacht und 0% anstatt 100% eingegeben. Klar, dass sie dann runter fahren, das Log von heute sah nämlich gut aus, bis auf diesen Fehler.
                                          Von daher kann ich jetzt noch nicht genau sagen, ob die X-Mas Funktion wirklich nicht mit Wohn/Schlafbereich AUTO geht oder nicht.
                                          Morgen werde ich es sehen, falls es nicht geht, gibts ein debug log dazu.
                                          simatec 1 Reply Last reply Reply Quote 1
                                          • simatec
                                            simatec Developer Most Active @coyote last edited by
                                            @coyote
                                            Ja ein debuglog und eventuell die json deiner Config wären sehr hilfreich.
                                            332
                                            7408
                                            10581034
