    4. Test Adapter fb-checkpresence v1.1.x
    • afuerhoff
      afuerhoff Developer @Master67 last edited by
      @Master67
      Im Reiter Instanzen den Expert Modus einschalten und dann die Log Stufe auf Debug setzen.
      Master67 1 Reply Last reply Reply Quote 0
      • Master67
        Master67 @afuerhoff last edited by Master67
        @afuerhoff .... ach wenn ich auf "info" klickte gibt es noch mehr (ich sollte mich doch mal mehr mit dem ioBroker beschäftigen)!
        Ich Liefer die Infos nach 🙂
        fb-checkpresence.0	2020-11-28 17:29:18.348	debug	(3053) history lastVal Dani false time: Fri Nov 27 2020 15:31:27 GMT+0100 (Central European Standard Time)
        fb-checkpresence.0	2020-11-28 17:29:18.348	debug	(3053) history lastVal Dani true time: Fri Nov 27 2020 15:28:25 GMT+0100 (Central European Standard Time)
        fb-checkpresence.0	2020-11-28 17:29:18.347	debug	(3053) history Dani cntActualDay: 2 cntHistory: 3
        fb-checkpresence.0	2020-11-28 17:29:18.346	debug	(3053) enableHistory.2 Dani true
        fb-checkpresence.0	2020-11-28 17:29:18.344	debug	(3053) sendTo "getHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2020-11-28 17:29:18.344	debug	(3053) history cntActualDay: 2
        influxdb.0	2020-11-28 17:29:18.339	info	(513) {"common":{"custom":{"influxdb.0":{"changesOnly":true,"debounce":0,"retention":31536000,"maxLength":10,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.influxdb.0","use
        fb-checkpresence.0	2020-11-28 17:29:18.336	debug	(3053) checkPresence first run
        fb-checkpresence.0	2020-11-28 17:29:18.336	debug	(3053) sendTo "getHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2020-11-28 17:29:18.335	debug	(3053) history lastVal Olaf false time: Fri Nov 27 2020 20:42:40 GMT+0100 (Central European Standard Time)
        fb-checkpresence.0	2020-11-28 17:29:18.335	debug	(3053) history lastVal Olaf true time: Fri Nov 27 2020 20:24:25 GMT+0100 (Central European Standard Time)
        fb-checkpresence.0	2020-11-28 17:29:18.334	debug	(3053) history Olaf cntActualDay: 2 cntHistory: 3
        fb-checkpresence.0	2020-11-28 17:29:18.333	debug	(3053) getActive [{"Name":"Olaf","Active":"false","Kommt":"2020.11.27 20:24:23","Geht":"2020.11.27 20:41:42"},{"Name":"Dani","Active":"false","Kommt":"2020.11.27 15:28:23","Geht":"2020.11.27 15:31:23
        fb-checkpresence.0	2020-11-28 17:29:18.329	debug	(3053) sendTo "getHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2020-11-28 17:29:18.328	debug	(3053) history cntActualDay: 2
        fb-checkpresence.0	2020-11-28 17:29:18.325	warn	(3053) ipaddress 192.168.178.75 from member Dani: undefined
        fb-checkpresence.0	2020-11-28 17:29:18.320	debug	(3053) sendTo "getHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2020-11-28 17:29:18.319	debug	(3053) getActive [{"Name":"Olaf","Active":"false","Kommt":"2020.11.27 20:24:23","Geht":"2020.11.27 20:41:42"},
        fb-checkpresence.0	2020-11-28 17:29:18.313	warn	(3053) ipaddress 192.168.178.36 from member Olaf: undefined
        fb-checkpresence.0	2020-11-28 17:29:18.309	warn	(3053) can not read external ip address
        fb-checkpresence.0	2020-11-28 17:29:18.309	debug	(3053) {"status":"ECONNREFUSED","data":null,"result":false,"resultData":null,"errNo":5,"errorMsg":"connect ECONNREFUSED 192.168.178.1:49443"}
        fb-checkpresence.0	2020-11-28 17:29:18.305	debug	(3053) {"status":"ECONNREFUSED","data":null,"result":false,"resultData":null,"errNo":5,"errorMsg":"connect ECONNREFUSED 192.168.178.1:49443"}
        fb-checkpresence.0	2020-11-28 17:29:18.301	error	(3053) soapAction GetInfo status=ECONNREFUSED errNo=5 connect ECONNREFUSED 192.168.178.1:49443
        fb-checkpresence.0	2020-11-28 17:29:18.296	debug	(3053) enableHistory.2 Olaf true
        fb-checkpresence.0	2020-11-28 17:29:18.296	debug	(3053) sendTo "enableHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2020-11-28 17:29:18.280	debug	(3053) chCount 0
        fb-checkpresence.0	2020-11-28 17:29:18.278	debug	(3053) response: 0 "<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:Header>\n<h:Challenge
        influxdb.0	2020-11-28 17:29:18.286	info	(513) {"common":{"custom":{"influxdb.0":{"changesOnly":true,"debounce":0,"retention":31536000,"maxLength":10,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.influxdb.0","use
        fb-checkpresence.0	2020-11-28 17:29:18.277	debug	(3053) sendTo "enableHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2020-11-28 17:29:18.268	debug	(3053) sendTo "getEnabledDPs" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2020-11-28 17:29:18.267	debug	(3053) createMemberObjects Dani
        fb-checkpresence.0	2020-11-28 17:29:18.267	debug	(3053) sendTo "getEnabledDPs" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2020-11-28 17:29:18.266	debug	(3053) createMemberObjects Olaf
        fb-checkpresence.0	2020-11-28 17:29:18.266	debug	(3053) function fb-devices false
        fb-checkpresence.0	2020-11-28 17:29:18.266	debug	(3053) createGlobalObjects
        fb-checkpresence.0	2020-11-28 17:29:18.265	debug	(3053) sslPort 49443
        fb-checkpresence.0	2020-11-28 17:29:18.261	debug	(3053) response: 0 "<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:Body>\n<u:GetSecurity
        fb-checkpresence.0	2020-11-28 17:29:17.642	info	(3053) service GetInfo is supported
        fb-checkpresence.0	2020-11-28 17:29:17.634	info	(3053) service GetSecurityPort is supported
        fb-checkpresence.0	2020-11-28 17:29:17.628	info	(3053) service X_AVM-DE_GetSpecificHostEntryByIP is supported
        fb-checkpresence.0	2020-11-28 17:29:17.621	info	(3053) service GetSpecificHostEntry is supported
        fb-checkpresence.0	2020-11-28 17:29:17.615	info	(3053) service X_AVM-DE_GetHostListPath is supported
        fb-checkpresence.0	2020-11-28 17:29:17.598	debug	(3053) configuration familymembers: [{"familymember":"Olaf","macaddress":"04:D6:AA:13:79:C7","ipaddress":"192.168.178.36","useip":true,"comment":"Willkommen Olaf","enabled":true},{"familymember":"Dan
        fb-checkpresence.0	2020-11-28 17:29:17.598	debug	(3053) configuration dateformat: <yyyy.mm.dd HH:MM:ss>
        fb-checkpresence.0	2020-11-28 17:29:17.597	debug	(3053) configuration history: <influxdb.0>
        fb-checkpresence.0	2020-11-28 17:29:17.597	debug	(3053) configuration user: <Master67>
        fb-checkpresence.0	2020-11-28 17:29:17.596	info	(3053) start fb-checkpresence: ip-address: fritz.box polling interval: 1 Min.
        fb-checkpresence.0	2020-11-28 17:29:17.580	info	(3053) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.20.0, js-controller: 3.1.6
        fb-checkpresence.0	2020-11-28 17:29:17.361	debug	(3053) statesDB connected
        fb-checkpresence.0	2020-11-28 17:29:17.360	debug	(3053) States connected to redis: 127.0.0.1:9000
        fb-checkpresence.0	2020-11-28 17:29:17.350	debug	(3053) States create System PubSub Client
        fb-checkpresence.0	2020-11-28 17:29:17.349	debug	(3053) States create User PubSub Client
        fb-checkpresence.0	2020-11-28 17:29:17.343	debug	(3053) Redis States: Use Redis connection: 127.0.0.1:9000
        fb-checkpresence.0	2020-11-28 17:29:17.342	debug	(3053) objectDB connected
        fb-checkpresence.0	2020-11-28 17:29:17.339	debug	(3053) Objects connected to redis: 127.0.0.1:9001
        fb-checkpresence.0	2020-11-28 17:29:17.323	debug	(3053) Objects client initialize lua scripts
        fb-checkpresence.0	2020-11-28 17:29:17.323	debug	(3053) Objects create User PubSub Client
        fb-checkpresence.0	2020-11-28 17:29:17.322	debug	(3053) Objects create System PubSub Client
        fb-checkpresence.0	2020-11-28 17:29:17.321	debug	(3053) Objects client ready ... initialize now
        fb-checkpresence.0	2020-11-28 17:29:17.303	debug	(3053) Redis Objects: Use Redis connection: 127.0.0.1:9001
        afuerhoff 1 Reply Last reply Reply Quote 0
        • afuerhoff
          @Master67
          Du nutzt in der Konfiguration IP-Adressen für Familienmitglieder. Sind da die korrekten eingetragen? Hast du mal in der Konfiguration "Familienmitglied hinzufügen" gedrückt und dann neu gespeichert. Sicherer sind da die Mac-Adressen, da diese eindeutig dem Gerät zugeordnet sind (wenn im Handy nicht die Verschleierung aktiviert ist). Bitte auch einmal die Fritzbox rebooten und vorher den Adapter stoppen und danach neu starten.
          • afuerhoff
            afuerhoff Developer last edited by afuerhoff
            Hallo, die 1.1.0 ist jetzt im latest verfügbar.
            Bitte noch einmal von dort installieren. Es gab noch eine kleine Änderung zur Github Version.
            Stephan Schleich 1 Reply Last reply Reply Quote 0
            • Stephan Schleich
              Stephan Schleich @afuerhoff last edited by
              @afuerhoff Woran liegt der Fehler? Keine Log Infos vorhanden ec605aa9-f112-42aa-b4e6-2da614b13892-image.png
              • afuerhoff
                afuerhoff Developer @Stephan Schleich last edited by afuerhoff
                @Stephan-Schleich sagte in Test Adapter fb-checkpresence v1.1.x:
                Ohne Log kann ich nur raten. Steht die Log Stufe der Instanz auf Debug? Danach Adapter neu starten und Log posten.
                Hast du vom Latest installiert?
                • Master67
                  @afuerhoff ..... auch mit der neue Version klappt das nicht, wenn ich jetzt noch den Haken bei "FB-Geräte erstellen" setzte schaltet sich der Adapter ab.
                  javascript.0	2020-11-29 10:52:10.152	info	(950) script.js.Meine_Geräte.eMail: {'errno':'ECONNRESET','code':'ECONNRESET','syscall':'read','source':'socket'}
                  host.ioBroker	2020-11-29 10:52:09.136	info	instance system.adapter.fb-checkpresence.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  fb-checkpresence.0	2020-11-29 10:52:08.599	info	(10625) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  fb-checkpresence.0	2020-11-29 10:52:08.598	info	(10625) terminating
                  fb-checkpresence.0	2020-11-29 10:52:08.598	info	(10625) cleaned everything up ...
                  fb-checkpresence.0	2020-11-29 10:52:08.598	info	(10625) Got terminate signal TERMINATE_YOURSELF
                  host.ioBroker	2020-11-29 10:52:08.596	info	stopInstance system.adapter.fb-checkpresence.0 send kill signal
                  host.ioBroker	2020-11-29 10:52:08.596	info	stopInstance system.adapter.fb-checkpresence.0 (force=false, process=true)
                  host.ioBroker	2020-11-29 10:52:08.595	info	"system.adapter.fb-checkpresence.0" disabled
                  fb-checkpresence.0	2020-11-29 10:52:08.581	error	(10625) createFbDeviceObjects -> can't read devices from fritzbox! Adapter stops
                  fb-checkpresence.0	2020-11-29 10:52:08.581	error	(10625) getDeviceList: "Can not read hostlist path"
                  fb-checkpresence.0	2020-11-29 10:52:08.580	error	(10625) soapAction /upnp/control/hosts X_AVM-DE_GetHostListPath status=ECONNREFUSED errNo=5 connect ECONNREFUSED 192.168.178.1:49443
                  fb-checkpresence.0	2020-11-29 10:52:08.561	info	(10625) createMemberObjects finished successfully
                  fb-checkpresence.0	2020-11-29 10:52:08.560	debug	(10625) enableHistory.2 Dani true
                  influxdb.0	2020-11-29 10:52:08.559	info	(513) {"common":{"custom":{"influxdb.0":{"changesOnly":true,"debounce":0,"retention":31536000,"maxLength":10,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.influxdb.0","use
                  fb-checkpresence.0	2020-11-29 10:52:08.493	debug	(10625) sendTo "enableHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
                  fb-checkpresence.0	2020-11-29 10:52:08.482	debug	(10625) sendTo "getEnabledDPs" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
                  fb-checkpresence.0	2020-11-29 10:52:08.463	debug	(10625) enableHistory.2 Olaf true
                  influxdb.0	2020-11-29 10:52:08.463	info	(513) {"common":{"custom":{"influxdb.0":{"changesOnly":true,"debounce":0,"retention":31536000,"maxLength":10,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.influxdb.0","use
                  fb-checkpresence.0	2020-11-29 10:52:08.458	debug	(10625) sendTo "enableHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
                  fb-checkpresence.0	2020-11-29 10:52:08.450	debug	(10625) sendTo "getEnabledDPs" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
                  fb-checkpresence.0	2020-11-29 10:52:08.392	info	(10625) createGlobalObjects finished successfully
                  fb-checkpresence.0	2020-11-29 10:52:08.295	info	(10625) service DeviceConfig1-Reboot is supported
                  fb-checkpresence.0	2020-11-29 10:52:08.291	warn	(10625) chkService: "service X_AVM-DE_HostFilter-GetWANAccessByIP is not supported! Can not find service file! Feature is deactivated"
                  fb-checkpresence.0	2020-11-29 10:52:08.290	warn	(10625) chkService: "service X_AVM-DE_HostFilter-DisallowWANAccessByIP is not supported! Can not find service file! Feature is deactivated"
                  fb-checkpresence.0	2020-11-29 10:52:08.290	info	(10625) service DeviceInfo1-GetInfo is supported
                  fb-checkpresence.0	2020-11-29 10:52:08.286	info	(10625) service WLANConfiguration3-GetInfo is supported
                  fb-checkpresence.0	2020-11-29 10:52:08.281	info	(10625) service WLANConfiguration3-SetEnable is supported
                  fb-checkpresence.0	2020-11-29 10:52:08.276	info	(10625) service WANPPPConnection1-GetInfo is supported
                  fb-checkpresence.0	2020-11-29 10:52:08.271	info	(10625) service DeviceInfo1-GetSecurityPort is supported
                  fb-checkpresence.0	2020-11-29 10:52:08.266	info	(10625) service Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
                  fb-checkpresence.0	2020-11-29 10:52:08.260	info	(10625) service Hosts1-GetSpecificHostEntry is supported
                  fb-checkpresence.0	2020-11-29 10:52:08.253	info	(10625) service Hosts1-X_AVM-DE_GetMeshListPath is supported
                  fb-checkpresence.0	2020-11-29 10:52:08.249	info	(10625) service Hosts1-X_AVM-DE_GetHostListPath is supported
                  fb-checkpresence.0	2020-11-29 10:52:08.243	debug	(10625) ssl-port {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:DeviceInfo:1"},"NewSecurityPort":"49443"},"errNo":0,"errorMsg":""}
                  fb-checkpresence.0	2020-11-29 10:52:08.237	debug	(10625) services loaded successfully{"root":{"$":{"xmlns":"urn:dslforum-org:device-1-0"},"specVersion":{"major":"1","minor":"0"},"systemVersion":{"HW":"233","Major":"161","Minor":"7","Patch":"13","Bu
                  fb-checkpresence.0	2020-11-29 10:52:08.195	debug	(10625) configuratuion mesh info: false
                  fb-checkpresence.0	2020-11-29 10:52:08.195	debug	(10625) configuration fb-devices true
                  fb-checkpresence.0	2020-11-29 10:52:08.194	debug	(10625) configuration familymembers: [{"familymember":"Olaf","macaddress":"04:D6:AA:13:79:C7","ipaddress":"192.168.178.36","useip":true,"comment":"Willkommen Olaf","enabled":true},{"familymember":"Da
                  fb-checkpresence.0	2020-11-29 10:52:08.194	debug	(10625) configuration dateformat: <yyyy.mm.dd HH:MM:ss>
                  fb-checkpresence.0	2020-11-29 10:52:08.194	debug	(10625) configuration history: <influxdb.0>
                  fb-checkpresence.0	2020-11-29 10:52:08.194	debug	(10625) configuration user: <Master67>
                  fb-checkpresence.0	2020-11-29 10:52:08.194	info	(10625) start fb-checkpresence: ip-address: "192.168.178.1" - interval devices: 1 Min. - interval members: 60 s
                  fb-checkpresence.0	2020-11-29 10:52:08.184	info	(10625) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.20.0, js-controller: 3.1.6
                  fb-checkpresence.0	2020-11-29 10:52:07.765	debug	(10625) statesDB connected
                  fb-checkpresence.0	2020-11-29 10:52:07.764	debug	(10625) States connected to redis: 127.0.0.1:9000
                  fb-checkpresence.0	2020-11-29 10:52:07.753	debug	(10625) States create System PubSub Client
                  fb-checkpresence.0	2020-11-29 10:52:07.752	debug	(10625) States create User PubSub Client
                  fb-checkpresence.0	2020-11-29 10:52:07.745	debug	(10625) Redis States: Use Redis connection: 127.0.0.1:9000
                  fb-checkpresence.0	2020-11-29 10:52:07.745	debug	(10625) objectDB connected
                  fb-checkpresence.0	2020-11-29 10:52:07.742	debug	(10625) Objects connected to redis: 127.0.0.1:9001
                  fb-checkpresence.0	2020-11-29 10:52:07.725	debug	(10625) Objects client initialize lua scripts
                  fb-checkpresence.0	2020-11-29 10:52:07.724	debug	(10625) Objects create User PubSub Client
                  fb-checkpresence.0	2020-11-29 10:52:07.724	debug	(10625) Objects create System PubSub Client
                  fb-checkpresence.0	2020-11-29 10:52:07.722	debug	(10625) Objects client ready ... initialize now
                  fb-checkpresence.0	2020-11-29 10:52:07.705	debug	(10625) Redis Objects: Use Redis connection: 127.0.0.1:9001
                  host.ioBroker	2020-11-29 10:52:07.395	info	instance system.adapter.fb-checkpresence.0 started with pid 10625
                  • afuerhoff
                    afuerhoff Developer @Master67 last edited by afuerhoff
                    @Master67
                    Hallo, ist das Passwort in der Konfiguration korrekt? Bitte noch einmal eingeben und dann speichern. Hast du in der Fritzbox die entsprechenden Einstellungen für den User aktiviert?
                    Benutzt du den Adapter schon länger?
                    • Master67
                      @afuerhoff sagte in Test Adapter fb-checkpresence v1.1.x:
                      @Master67
                      Das PW ist korrekt habe es grade in der FB und im Adapter erneuert!
                      Den Adapter nutze ich ca. 6 Wochen
                      Hier das Log wenn ich den Haken weg lasse.... so bleibt der Adapter Gelb
                      fb-checkpresence.0	2020-11-29 11:17:29.042	debug	(26966) loopDevices ends after 0,351008 s
                      fb-checkpresence.0	2020-11-29 11:17:29.042	debug	(26966) loopDevices starts
                      fb-checkpresence.0	2020-11-29 11:17:24.039	info	(26966) createMemberObjects finished successfully
                      fb-checkpresence.0	2020-11-29 11:17:24.038	debug	(26966) enableHistory.2 Dani true
                      influxdb.0	2020-11-29 11:17:24.038	info	(513) {"common":{"custom":{"influxdb.0":{"changesOnly":true,"debounce":0,"retention":31536000,"maxLength":10,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.influxdb.0","use
                      fb-checkpresence.0	2020-11-29 11:17:24.034	debug	(26966) sendTo "enableHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
                      fb-checkpresence.0	2020-11-29 11:17:24.026	debug	(26966) sendTo "getEnabledDPs" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
                      fb-checkpresence.0	2020-11-29 11:17:23.966	debug	(26966) enableHistory.2 Olaf true
                      influxdb.0	2020-11-29 11:17:23.965	info	(513) {"common":{"custom":{"influxdb.0":{"changesOnly":true,"debounce":0,"retention":31536000,"maxLength":10,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.influxdb.0","use
                      fb-checkpresence.0	2020-11-29 11:17:23.961	debug	(26966) sendTo "enableHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
                      fb-checkpresence.0	2020-11-29 11:17:23.952	debug	(26966) sendTo "getEnabledDPs" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
                      fb-checkpresence.0	2020-11-29 11:17:23.938	info	(26966) createGlobalObjects finished successfully
                      fb-checkpresence.0	2020-11-29 11:17:23.839	info	(26966) service DeviceConfig1-Reboot is supported
                      fb-checkpresence.0	2020-11-29 11:17:23.835	warn	(26966) chkService: "service X_AVM-DE_HostFilter-GetWANAccessByIP is not supported! Can not find service file! Feature is deactivated"
                      fb-checkpresence.0	2020-11-29 11:17:23.835	warn	(26966) chkService: "service X_AVM-DE_HostFilter-DisallowWANAccessByIP is not supported! Can not find service file! Feature is deactivated"
                      fb-checkpresence.0	2020-11-29 11:17:23.834	info	(26966) service DeviceInfo1-GetInfo is supported
                      fb-checkpresence.0	2020-11-29 11:17:23.829	info	(26966) service WLANConfiguration3-GetInfo is supported
                      fb-checkpresence.0	2020-11-29 11:17:23.824	info	(26966) service WLANConfiguration3-SetEnable is supported
                      fb-checkpresence.0	2020-11-29 11:17:23.816	info	(26966) service WANPPPConnection1-GetInfo is supported
                      fb-checkpresence.0	2020-11-29 11:17:23.809	info	(26966) service DeviceInfo1-GetSecurityPort is supported
                      fb-checkpresence.0	2020-11-29 11:17:23.804	info	(26966) service Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
                      fb-checkpresence.0	2020-11-29 11:17:23.799	info	(26966) service Hosts1-GetSpecificHostEntry is supported
                      fb-checkpresence.0	2020-11-29 11:17:23.795	info	(26966) service Hosts1-X_AVM-DE_GetMeshListPath is supported
                      fb-checkpresence.0	2020-11-29 11:17:23.790	info	(26966) service Hosts1-X_AVM-DE_GetHostListPath is supported
                      fb-checkpresence.0	2020-11-29 11:17:23.784	debug	(26966) ssl-port {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:DeviceInfo:1"},"NewSecurityPort":"49443"},"errNo":0,"errorMsg":""}
                      fb-checkpresence.0	2020-11-29 11:17:23.777	debug	(26966) services loaded successfully{"root":{"$":{"xmlns":"urn:dslforum-org:device-1-0"},"specVersion":{"major":"1","minor":"0"},"systemVersion":{"HW":"233","Major":"161","Minor":"7","Patch":"13","Bu
                      fb-checkpresence.0	2020-11-29 11:17:23.735	debug	(26966) configuratuion mesh info: false
                      fb-checkpresence.0	2020-11-29 11:17:23.735	debug	(26966) configuration fb-devices false
                      fb-checkpresence.0	2020-11-29 11:17:23.735	debug	(26966) configuration familymembers: [{"familymember":"Olaf","macaddress":"04:D6:AA:13:79:C7","ipaddress":"192.168.178.36","useip":true,"comment":"Willkommen Olaf","enabled":true},{"familymember":"Da
                      fb-checkpresence.0	2020-11-29 11:17:23.735	debug	(26966) configuration dateformat: <yyyy.mm.dd HH:MM:ss>
                      fb-checkpresence.0	2020-11-29 11:17:23.735	debug	(26966) configuration history: <influxdb.0>
                      fb-checkpresence.0	2020-11-29 11:17:23.734	debug	(26966) configuration user: <Master67>
                      fb-checkpresence.0	2020-11-29 11:17:23.734	info	(26966) start fb-checkpresence: ip-address: "192.168.178.1" - interval devices: 1 Min. - interval members: 60 s
                      fb-checkpresence.0	2020-11-29 11:17:23.724	info	(26966) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.20.0, js-controller: 3.1.6
                      fb-checkpresence.0	2020-11-29 11:17:23.378	debug	(26966) statesDB connected
                      fb-checkpresence.0	2020-11-29 11:17:23.378	debug	(26966) States connected to redis: 127.0.0.1:9000
                      fb-checkpresence.0	2020-11-29 11:17:23.367	debug	(26966) States create System PubSub Client
                      fb-checkpresence.0	2020-11-29 11:17:23.366	debug	(26966) States create User PubSub Client
                      fb-checkpresence.0	2020-11-29 11:17:23.359	debug	(26966) Redis States: Use Redis connection: 127.0.0.1:9000
                      fb-checkpresence.0	2020-11-29 11:17:23.359	debug	(26966) objectDB connected
                      fb-checkpresence.0	2020-11-29 11:17:23.356	debug	(26966) Objects connected to redis: 127.0.0.1:9001
                      fb-checkpresence.0	2020-11-29 11:17:23.339	debug	(26966) Objects client initialize lua scripts
                      fb-checkpresence.0	2020-11-29 11:17:23.339	debug	(26966) Objects create User PubSub Client
                      fb-checkpresence.0	2020-11-29 11:17:23.338	debug	(26966) Objects create System PubSub Client
                      fb-checkpresence.0	2020-11-29 11:17:23.337	debug	(26966) Objects client ready ... initialize now
                      fb-checkpresence.0	2020-11-29 11:17:23.316	debug	(26966) Redis Objects: Use Redis connection: 127.0.0.1:9001
                      host.ioBroker	2020-11-29 11:17:23.028	info	instance system.adapter.fb-checkpresence.0 started with pid 26966
                      Stephan Schleich afuerhoff 2 Replies Last reply Reply Quote 0
                      • Stephan Schleich
                        Stephan Schleich @Master67 last edited by Negalein
                        @afuerhoff
                        fb-checkpresence.0	2020-11-29 11:23:05.909	debug	(30099) loopDevices ends after 9,503538638 s
                        fb-checkpresence.0	2020-11-29 11:23:05.908	debug	(30099) getDeviceInfo blCnt: 30
                        fb-checkpresence.0	2020-11-29 11:23:05.907	debug	(30099) getDeviceInfo activeCnt: 21
                        fb-checkpresence.0	2020-11-29 11:23:03.590	debug	(30099) getMeshList2: [{"uid":"n-1","device_name":"fritz.box","device_model":"FRITZ!Box 7490","device_manufacturer":"AVM","device_firmware_version":"113.07.21","device_mac_address":"5C:49:79:DA:F0:E0"
                        fb-checkpresence.0	2020-11-29 11:23:00.219	silly	(30099) States user redis pmessage fb-checkpresence.0.guest.wlan/fb-checkpresence.0.guest.wlan:{"val":true,"ack":true,"ts":1606645380216,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system
                        fb-checkpresence.0	2020-11-29 11:23:00.210	debug	(30099) getGuestWlan: {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:WLANConfiguration:3"},"NewEnable":"1","NewStatus":"Disabled","NewMaxBitRate":"Auto","NewChannel
                        fb-checkpresence.0	2020-11-29 11:22:59.271	debug	(30099) external IP2: {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:WANIPConnection:1"},"NewEnable":"1","NewConnectionStatus":"Connected","NewPossibleConnectionTyp
                        fb-checkpresence.0	2020-11-29 11:22:57.589	debug	(30099) getDeviceList: [{"Index":"1","IPAddress":"192.168.178.30","MACAddress":"08:84:9D:54:BC:97","Active":"1","HostName":"FireTV-Stick-4K","InterfaceType":"802.11","X_AVM-DE_Port":"0","X_AVM-DE_Spee
                        fb-checkpresence.0	2020-11-29 11:22:56.405	debug	(30099) loopDevices starts
                        fb-checkpresence.0	2020-11-29 11:22:51.398	info	(30099) createMeshObjects finished successfully
                        fb-checkpresence.0	2020-11-29 11:22:49.974	info	(30099) createFbDeviceObjects finished successfully
                        fb-checkpresence.0	2020-11-29 11:22:48.093	debug	(30099) getDeviceList: [{"Index":"1","IPAddress":"192.168.178.30","MACAddress":"08:84:9D:54:BC:97","Active":"1","HostName":"FireTV-Stick-4K","InterfaceType":"802.11","X_AVM-DE_Port":"0","X_AVM-DE_Spee
                        fb-checkpresence.0	2020-11-29 11:22:46.813	info	(30099) createMemberObjects finished successfully
                        fb-checkpresence.0	2020-11-29 11:22:46.812	info	(30099) History function for UserEdit disabled. Please select a history adapter in the configuration dialog!
                        fb-checkpresence.0	2020-11-29 11:22:46.689	info	(30099) createGlobalObjects finished successfully
                        fb-checkpresence.0	2020-11-29 11:22:45.208	info	(30099) service DeviceConfig1-Reboot is supported
                        fb-checkpresence.0	2020-11-29 11:22:45.191	info	(30099) service X_AVM-DE_HostFilter-GetWANAccessByIP is supported
                        fb-checkpresence.0	2020-11-29 11:22:45.172	info	(30099) service X_AVM-DE_HostFilter-DisallowWANAccessByIP is supported
                        fb-checkpresence.0	2020-11-29 11:22:45.156	info	(30099) service DeviceInfo1-GetInfo is supported
                        fb-checkpresence.0	2020-11-29 11:22:45.137	info	(30099) service WLANConfiguration3-GetInfo is supported
                        fb-checkpresence.0	2020-11-29 11:22:45.111	info	(30099) service WLANConfiguration3-SetEnable is supported
                        fb-checkpresence.0	2020-11-29 11:22:45.071	info	(30099) service WANPPPConnection1-GetInfo is supported
                        fb-checkpresence.0	2020-11-29 11:22:45.048	info	(30099) service DeviceInfo1-GetSecurityPort is supported
                        fb-checkpresence.0	2020-11-29 11:22:45.030	info	(30099) service Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
                        fb-checkpresence.0	2020-11-29 11:22:45.011	info	(30099) service Hosts1-GetSpecificHostEntry is supported
                        fb-checkpresence.0	2020-11-29 11:22:44.990	info	(30099) service Hosts1-X_AVM-DE_GetMeshListPath is supported
                        fb-checkpresence.0	2020-11-29 11:22:44.967	info	(30099) service Hosts1-X_AVM-DE_GetHostListPath is supported
                        fb-checkpresence.0	2020-11-29 11:22:44.949	debug	(30099) ssl-port {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:DeviceInfo:1"},"NewSecurityPort":"49443"},"errNo":0,"errorMsg":""}
                        fb-checkpresence.0	2020-11-29 11:22:44.918	debug	(30099) services loaded successfully{"root":{"$":{"xmlns":"urn:dslforum-org:device-1-0"},"specVersion":{"major":"1","minor":"0"},"systemVersion":{"HW":"185","Major":"113","Minor":"7","Patch":"21","Bui
                        fb-checkpresence.0	2020-11-29 11:22:44.791	debug	(30099) configuratuion mesh info: true
                        fb-checkpresence.0	2020-11-29 11:22:44.791	debug	(30099) configuration fb-devices true
                        fb-checkpresence.0	2020-11-29 11:22:44.791	debug	(30099) configuration familymembers: [{"familymember":"UserEdit","macaddress":"30:07:4D:80:A5:AE","ipaddress":"192.168.178.22","useip":false,"comment":"Handy - UserEdit UserEdit","enabled":true}]
                        fb-checkpresence.0	2020-11-29 11:22:44.791	debug	(30099) configuration dateformat: <yyyy.mm.dd HH:MM:ss>
                        fb-checkpresence.0	2020-11-29 11:22:44.790	debug	(30099) configuration history: <>
                        fb-checkpresence.0	2020-11-29 11:22:44.790	debug	(30099) configuration user: <fbcheckpresence>
                        fb-checkpresence.0	2020-11-29 11:22:44.790	info	(30099) start fb-checkpresence: ip-address: "fritz.box" - interval devices: 1 Min. - interval members: 10 s
                        fb-checkpresence.0	2020-11-29 11:22:44.762	info	(30099) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v10.23.0, js-controller: 3.1.6
                        fb-checkpresence.0	2020-11-29 11:22:40.267	info	(29031) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        fb-checkpresence.0	2020-11-29 11:22:40.266	info	(29031) terminating
                        fb-checkpresence.0	2020-11-29 11:22:40.265	info	(29031) cleaned everything up ...
                        fb-checkpresence.0	2020-11-29 11:22:40.263	info	(29031) Got terminate signal TERMINATE_YOURSELF
                        • afuerhoff
                          @Stephan-Schleich
                          Kannst Du mal einen History Adapter in der Konfiguration auswählen.
                          So sieht alles gut aus. Kommt im Log ein Eintrag mit "loopFamily ends"?
                          E Stephan Schleich 2 Replies Last reply Reply Quote 0
                            e-s @afuerhoff last edited by
                            @afuerhoff
                            bei mir war nach dem update auch der Adapter gelb, erst nachdem ein device sich abgemeldet und wieder angemeldet hat, war der Adapter wahrscheinlich grün.
                            Also hatte erst keine Zeit nachzusehen woran es lag, aber als ich einiges später geschaut habe, war der Adapter grün. Im log war eben nur das ab und anmelden zu sehen.
                            • afuerhoff
                              afuerhoff Developer @e-s last edited by
                              @e-s @Stephan-Schleich
                              Manchmal ist die Ampel auf der ioBroker Seite nicht aktuell in der Darstellung. Das hab ich schon häufiger beobachtet. Aktualisiert sich dann nach einiger Zeit.
                              • afuerhoff
                                @Master67 sagte in Test Adapter fb-checkpresence v1.1.x:
                                Kommt bei Dir im Debug Modus im Log "loopFamily ends"?
                                Wie sind die Datenpunkte info.connection und info.lastUpdate gesetzt?
                                Master67 2 Replies Last reply Reply Quote 0
                                • Master67
                                  @afuerhoff Ja siehe...
                                  fb-checkpresence.0	2020-11-29 11:53:30.896	debug	(26966) loopDevices ends after 0,272304 s
                                  fb-checkpresence.0	2020-11-29 11:53:30.896	debug	(26966) loopDevices starts
                                  fb-checkpresence.0	2020-11-29 11:53:15.885	debug	(26966) loopFamily ends after 0,3967818 s
                                  fb-checkpresence.0	2020-11-29 11:53:15.885	warn	(26966) can not get active state from member Olaf
                                  fb-checkpresence.0	2020-11-29 11:53:15.883	warn	(26966) connectionCheck: "can not connect to fritzbox!"
                                  fb-checkpresence.0	2020-11-29 11:53:15.883	error	(26966) soapAction /upnp/control/deviceinfo GetInfo status=ECONNREFUSED errNo=5 connect ECONNREFUSED 192.168.178.1:49443
                                  fb-checkpresence.0	2020-11-29 11:52:30.835	debug	(26966) loopDevices ends after 0,240703 s
                                  fb-checkpresence.0	2020-11-29 11:52:30.835	debug	(26966) loopDevices starts
                                  fb-checkpresence.0	2020-11-29 11:52:15.824	debug	(26966) loopFamily ends after 0,4933583 s
                                  fb-checkpresence.0	2020-11-29 11:52:15.824	warn	(26966) can not get active state from member Olaf
                                  fb-checkpresence.0	2020-11-29 11:52:15.821	warn	(26966) connectionCheck: "can not connect to fritzbox!"
                                  fb-checkpresence.0	2020-11-29 11:52:15.821	error	(26966) soapAction /upnp/control/deviceinfo GetInfo status=ECONNREFUSED errNo=5 connect ECONNREFUSED 192.168.178.1:49443
                                  javascript.0	2020-11-29 11:52:13.705	info	(950) script.js.Meine_Geräte.eMail: {'errno':'ECONNRESET','code':'ECONNRESET','syscall':'read','source':'socket'}
                                  fb-checkpresence.0	2020-11-29 11:51:30.754	debug	(26966) loopDevices ends after 0,265831 s
                                  fb-checkpresence.0	2020-11-29 11:51:30.754	debug	(26966) loopDevices starts
                                  • afuerhoff
                                    @Master67
                                    Ok. Mir gehen langsam die Ideen aus. Die Fritzbox scheint nicht per Soap zu erreichen zu sein.
                                    Das kommt manchmal vor. Vor allem, wenn User oder Passwort nicht richtig gesetzt sind und nach einigem ausprobieren. Bitte nochmal einen Reboot der Fritzbox durchführen.
                                    • Master67
                                      keine Ahnung was du damit meinst!?, Sorry, ich muss mich selten mit dem ioBroker auseinandersetzten, weil wenn ich nen Adapter Installiert habe und die Aktoren das machen was sie sollen, schaue ich nur wegen den Updates in den iobroker oder wenn es mal einen Fehler gibt, das passiert aber nicht so oft, deshalb auch nach zwei Jahren Nutzung bin ich da noch "Anfänger" 🙂
                                      • Stephan Schleich
                                        @Stephan-Schleich
                                        History hab ich nun aktiviert und "loopFamily ends" kommt nicht, Fehler bleibt
                                        • afuerhoff
                                          @Master67
                                          Im Reiter Objekte von ioBroker gibt es im Adapter einen Info Ordner.
                                          • afuerhoff
                                            Kannst Du das Family Intervall mal etwas hochsetzen.
                                            avm fb-checkpresence fritzbox tr-064
                                            88
                                            947
                                            249639
