    3. Entwicklung
    4. ZigBee neue/unbekannte Geräte - ab 1.3.0
      Spucki @arteck last edited by
      @arteck
      QS-Zigbee-D02-TRIAC-LN
      Wie kann man den hinzufügen?
      VG
      Spucki
        Jan1 @Asgothian last edited by
        @Asgothian
        einmal zu und auf über die APP, was auch sofort in den Objekten angezeigt wurde:
        zigbee.0	2020-11-28 14:08:31.655	debug	(440024) system.adapter.admin.0: logging true
        zigbee.0	2020-11-28 14:08:21.888	debug	(440024) Publish {"state":"UNLOCK","lock_state":"unlocked"}
        zigbee.0	2020-11-28 14:08:21.887	debug	(440024) Publish {"action":"unlock","action_user":65535,"action_source":1,"action_source_name":"rf"}
        zigbee.0	2020-11-28 14:08:21.883	debug	(440024) Type attributeReport device {"type":"device","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":[{"ID":1,"prof
        zigbee.0	2020-11-28 14:08:21.882	debug	(440024) Received Zigbee message from '0x000b57fffe59d1f6', type 'attributeReport', cluster 'closuresDoorLock', data '{"lockState":2}' from endpoint 1 with groupID 0
        zigbee.0	2020-11-28 14:08:21.881	debug	(440024) handleMessage. {"type":"attributeReport","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileI
        zigbee.0	2020-11-28 14:08:21.874	debug	(440024) Type commandOperationEventNotification device {"type":"device","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoin
        zigbee.0	2020-11-28 14:08:21.873	debug	(440024) Received Zigbee message from '0x000b57fffe59d1f6', type 'commandOperationEventNotification', cluster 'closuresDoorLock', data '{"opereventsrc":1,"opereventcode":2,"userid":65535,"pin":0,"zig
        zigbee.0	2020-11-28 14:08:21.866	debug	(440024) handleMessage. {"type":"commandOperationEventNotification","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":
        zigbee.0	2020-11-28 14:08:08.058	debug	(440024) Publish {"state":"LOCK","lock_state":"locked"}
        zigbee.0	2020-11-28 14:08:08.057	debug	(440024) Publish {"action":"lock","action_user":65535,"action_source":1,"action_source_name":"rf"}
        zigbee.0	2020-11-28 14:08:08.051	debug	(440024) Type attributeReport device {"type":"device","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":[{"ID":1,"prof
        zigbee.0	2020-11-28 14:08:08.050	debug	(440024) Received Zigbee message from '0x000b57fffe59d1f6', type 'attributeReport', cluster 'closuresDoorLock', data '{"lockState":1}' from endpoint 1 with groupID 0
        zigbee.0	2020-11-28 14:08:08.048	debug	(440024) handleMessage. {"type":"attributeReport","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileI
        zigbee.0	2020-11-28 14:08:08.043	debug	(440024) Type commandOperationEventNotification device {"type":"device","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoin
        zigbee.0	2020-11-28 14:08:08.042	debug	(440024) Received Zigbee message from '0x000b57fffe59d1f6', type 'commandOperationEventNotification', cluster 'closuresDoorLock', data '{"opereventsrc":1,"opereventcode":1,"userid":65535,"pin":0,"zig
        zigbee.0	2020-11-28 14:08:08.038	debug	(440024) handleMessage. {"type":"commandOperationEventNotification","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":
        zigbee.0	2020-11-28 14:07:38.866	debug	(440024) Publish {"occupancy":false}
        zigbee.0	2020-11-28 14:07:28.863	debug	(440024) Publish {"occupancy":true}
        zigbee.0	2020-11-28 14:07:28.861	debug	(440024) Publish {"illuminance":60,"illuminance_lux":60}
        zigbee.0	2020-11-28 14:07:28.856	debug	(440024) Type attributeReport device {"type":"device","device":{"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d00030a3270","_networkAddress":27111,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profi
        zigbee.0	2020-11-28 14:07:28.855	debug	(440024) Received Zigbee message from '0x00158d00030a3270', type 'attributeReport', cluster 'msOccupancySensing', data '{"occupancy":1}' from endpoint 1 with groupID 0
        zigbee.0	2020-11-28 14:07:28.854	debug	(440024) handleMessage. {"type":"attributeReport","device":{"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d00030a3270","_networkAddress":27111,"_manufacturerID":4151,"_endpoints":[{"ID
        Bei Verbindungsproblemen dürfte so schnell nicht der Status gewechselt werden zumal das Schloss vom CC1352P_2 gerade mal 3m ohne Hindernisse im Weg entfernt ist.
        • Asgothian
          Asgothian Developer @Jan1 last edited by
          @Jan1 bitte poste mal die kompletten Zeilen, nicht nur den Teil den der Admin anzeigt.
          A.
            Spucki @Spucki last edited by
            Habe soebend die 1.3.9dev instralliert, da ist er drin :---)))))
              Jan1 @Asgothian last edited by Jan1
              @Asgothian
              wollte ich gerade tun, da mir das auch etwas abgeschnitten vorkam 🙂
              2020-11-28 14:05:39.396 - info: node-red.0 (439695) starting. Version 2.0.1 in /opt/iobroker/node_modules/iobroker.node-red, node: v14.15.1, js-controller: 3.1.6
              2020-11-28 14:05:39.938 - info: node-red.0 (439695) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
              2020-11-28 14:05:44.141 - warn: node-red.0 (439695) 28 Nov 14:05:44 - [warn] Projekte inaktiviert: editorTheme.projects.enabled=false
              2020-11-28 14:05:47.951 - info: host.Beelink stopInstance system.adapter.zigbee.0 (force=false, process=true)
              2020-11-28 14:05:47.952 - info: host.Beelink stopInstance system.adapter.zigbee.0 send kill signal
              2020-11-28 14:05:47.955 - info: zigbee.0 (400768) Got terminate signal TERMINATE_YOURSELF
              2020-11-28 14:05:47.957 - info: zigbee.0 (400768) cleaned everything up...
              2020-11-28 14:05:47.958 - info: zigbee.0 (400768) Zigbee: disabling joining new devices.
              2020-11-28 14:05:48.367 - info: zigbee.0 (400768) terminating
              2020-11-28 14:05:48.369 - info: zigbee.0 (400768) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2020-11-28 14:05:48.897 - info: host.Beelink instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2020-11-28 14:05:50.982 - info: host.Beelink instance system.adapter.zigbee.0 started with pid 440024
              2020-11-28 14:05:52.092 - debug: zigbee.0 (440024) Redis Objects: Use Redis connection: 127.0.0.1:9001
              2020-11-28 14:05:52.123 - debug: zigbee.0 (440024) Objects client ready ... initialize now
              2020-11-28 14:05:52.127 - debug: zigbee.0 (440024) Objects create System PubSub Client
              2020-11-28 14:05:52.128 - debug: zigbee.0 (440024) Objects create User PubSub Client
              2020-11-28 14:05:52.129 - debug: zigbee.0 (440024) Objects client initialize lua scripts
              2020-11-28 14:05:52.147 - debug: zigbee.0 (440024) Objects connected to redis: 127.0.0.1:9001
              2020-11-28 14:05:52.152 - debug: zigbee.0 (440024) objectDB connected
              2020-11-28 14:05:52.155 - debug: zigbee.0 (440024) Redis States: Use Redis connection: 127.0.0.1:9000
              2020-11-28 14:05:52.164 - debug: zigbee.0 (440024) States create User PubSub Client
              2020-11-28 14:05:52.167 - debug: zigbee.0 (440024) States create System PubSub Client
              2020-11-28 14:05:52.181 - debug: zigbee.0 (440024) States connected to redis: 127.0.0.1:9000
              2020-11-28 14:05:52.182 - debug: zigbee.0 (440024) statesDB connected
              2020-11-28 14:05:52.790 - info: zigbee.0 (440024) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.15.1, js-controller: 3.1.6
              2020-11-28 14:05:52.822 - debug: zigbee.0 (440024) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[16],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-Texas_Instruments_XDS110__02.03.00.18__Embed_with_CMSIS-DAP_L4300169-if00","adapter":"zstack"}}
              2020-11-28 14:05:52.877 - info: zigbee.0 (440024) Starting Zigbee npm ...
              2020-11-28 14:05:52.879 - debug: zigbee.0 (440024) Starting zigbee-herdsman...
              2020-11-28 14:05:53.013 - info: zigbee.0 (440024) Installed Version: https://github.com/ioBroker/ioBroker.zigbee/commit/master
              2020-11-28 14:05:53.070 - debug: zigbee.0 (440024) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2020_11_28-14_05_52.tar.gz success
              2020-11-28 14:05:55.079 - debug: zigbee.0 (440024) zigbee-herdsman started
              2020-11-28 14:05:55.081 - info: zigbee.0 (440024) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20200417}}
              2020-11-28 14:05:55.088 - debug: zigbee.0 (440024) Zigbee network parameters: {"panID":6754,"extendedPanID":"0xdddddddddddddddd","channel":16}
              2020-11-28 14:05:55.089 - info: zigbee.0 (440024) Unable to disable LED, unsupported function.
              2020-11-28 14:05:55.090 - info: zigbee.0 (440024) --> transmitPower : normal
              2020-11-28 14:05:55.098 - info: zigbee.0 (440024) Currently 14 devices are joined:
              2020-11-28 14:05:55.099 - debug: zigbee.0 (440024) Publish available for 0x00158d000208dc76 = true
              2020-11-28 14:05:55.101 - debug: zigbee.0 (440024) Publish available for 0x00158d00023ce458 = true
              2020-11-28 14:05:55.101 - debug: zigbee.0 (440024) Publish available for 0x00158d000249a9a8 = true
              2020-11-28 14:05:55.102 - debug: zigbee.0 (440024) Publish available for 0x00158d00025562c5 = true
              2020-11-28 14:05:55.102 - debug: zigbee.0 (440024) Publish available for 0x00158d0002fd3f30 = true
              2020-11-28 14:05:55.103 - debug: zigbee.0 (440024) Publish available for 0x00158d0003667aba = true
              2020-11-28 14:05:55.103 - debug: zigbee.0 (440024) Publish available for 0x00158d0002ea07ac = true
              2020-11-28 14:05:55.103 - debug: zigbee.0 (440024) Publish available for 0x00158d00030a3270 = true
              2020-11-28 14:05:55.104 - debug: zigbee.0 (440024) Publish available for 0x00158d00032c1109 = true
              2020-11-28 14:05:55.104 - debug: zigbee.0 (440024) Publish available for 0xccccccfffee04e28 = true
              2020-11-28 14:05:55.105 - debug: zigbee.0 (440024) Publish available for 0xec1bbdfffe9734c2 = true
              2020-11-28 14:05:55.105 - debug: zigbee.0 (440024) Publish available for 0xec1bbdfffe972471 = true
              2020-11-28 14:05:55.105 - debug: zigbee.0 (440024) Publish available for 0xec1bbdfffeb45b50 = true
              2020-11-28 14:05:55.106 - debug: zigbee.0 (440024) Publish available for 0x000b57fffe59d1f6 = true
              2020-11-28 14:05:55.106 - debug: zigbee.0 (440024) DeviceConfigure 0x00158d000208dc76 lumi.sensor_ht not needed
              2020-11-28 14:05:55.107 - debug: zigbee.0 (440024) DeviceConfigure 0x00158d00023ce458 lumi.sensor_ht not needed
              2020-11-28 14:05:55.107 - debug: zigbee.0 (440024) DeviceConfigure 0x00158d000249a9a8 lumi.sensor_ht not needed
              2020-11-28 14:05:55.107 - debug: zigbee.0 (440024) DeviceConfigure 0x00158d00025562c5 lumi.sensor_ht not needed
              2020-11-28 14:05:55.108 - debug: zigbee.0 (440024) DeviceConfigure 0x00158d0002fd3f30 lumi.sensor_motion.aq2 not needed
              2020-11-28 14:05:55.108 - debug: zigbee.0 (440024) DeviceConfigure 0x00158d0003667aba lumi.sensor_motion.aq2 not needed
              2020-11-28 14:05:55.108 - debug: zigbee.0 (440024) DeviceConfigure 0x00158d0002ea07ac lumi.sensor_motion.aq2 not needed
              2020-11-28 14:05:55.109 - debug: zigbee.0 (440024) DeviceConfigure 0x00158d00030a3270 lumi.sensor_motion.aq2 not needed
              2020-11-28 14:05:55.109 - debug: zigbee.0 (440024) DeviceConfigure 0x00158d00032c1109 lumi.sensor_motion.aq2 not needed
              2020-11-28 14:05:55.109 - debug: zigbee.0 (440024) DeviceConfigure 0xccccccfffee04e28 TRADFRI on/off switch not needed
              2020-11-28 14:05:55.109 - debug: zigbee.0 (440024) DeviceConfigure 0xec1bbdfffe9734c2 TRADFRI on/off switch not needed
              2020-11-28 14:05:55.110 - debug: zigbee.0 (440024) DeviceConfigure 0xec1bbdfffe972471 TRADFRI on/off switch not needed
              2020-11-28 14:05:55.110 - debug: zigbee.0 (440024) DeviceConfigure 0xec1bbdfffeb45b50 TRADFRI on/off switch not needed
              2020-11-28 14:05:55.110 - debug: zigbee.0 (440024) DeviceConfigure 0x000b57fffe59d1f6 V3-BTZB forced by adapter config
              2020-11-28 14:05:55.111 - debug: zigbee.0 (440024) DeviceConfigure 0x000b57fffe59d1f6 V3-BTZB needed
              2020-11-28 14:05:55.111 - info: zigbee.0 (440024) Configuring 0x000b57fffe59d1f6 V3-BTZB
              2020-11-28 14:05:55.117 - debug: zigbee.0 (440024) New device event: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x00158d000208dc76","_networkAddress":53206,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":24321,"inputClusters":[0,3,25,65535,18],"outputClusters":[0,4,3,5,25,65535,18],"deviceNetworkAddress":53206,"deviceIeeeAddress":"0x00158d000208dc76","clusters":{"genBasic":{"attributes":{"65281":{"1":2975,"4":17320,"5":147,"6":[0,1],"10":0,"100":2171,"101":5366},"modelId":"lumi.sensor_ht","manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":30,"dateCode":"20160516","swBuildId":"3000-0001"}},"msTemperatureMeasurement":{"attributes":{"measuredValue":2165}},"msRelativeHumidity":{"attributes":{"measuredValue":5408}}},"_binds":[],"meta":{}},{"ID":2,"profileID":260,"deviceID":24322,"inputClusters":[3,18],"outputClusters":[4,3,5,18],"deviceNetworkAddress":53206,"deviceIeeeAddress":"0x00158d000208dc76","clusters":{},"_binds":[],"meta":{}},{"ID":3,"profileID":260,"deviceID":24323,"inputClusters":[3,12],"outputClusters":[4,3,5,12],"deviceNetworkAddress":53206,"deviceIeeeAddress":"0x00158d000208dc76","clusters":{},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_ht","_applicationVersion":2,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":30,"_dateCode":"20160516","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1606567912397},"mapped":{"zigbeeModel":["lumi.sens","lumi.sensor_ht"],"model":"WSDCGQ01LM","vendor":"Xiaomi","description":"MiJia temperature & humidity sensor","supports":"temperature and humidity","meta":{"battery":{"voltageToPercentage":"3V_2100"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msRelativeHumidity","type":["attributeReport","readResponse"]}],"toZigbee":[],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"numeric","name":"temperature","property":"temperature","access":1,"unit":"°C","description":"Measured temperature value"},{"type":"numeric","name":"humidity","property":"humidity","access":1,"unit":"%","description":"Measured relative humidity"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x00158d000208dc76"}
              2020-11-28 14:05:55.119 - info: zigbee.0 (440024) 0x00158d000208dc76 (addr 53206): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (EndDevice)
              2020-11-28 14:05:55.130 - debug: zigbee.0 (440024) New device event: {"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d00023ce458","_networkAddress":35825,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":24321,"inputClusters":[0,3,25,65535,18],"outputClusters":[0,4,3,5,25,65535,18],"deviceNetworkAddress":35825,"deviceIeeeAddress":"0x00158d00023ce458","clusters":{"genBasic":{"attributes":{"65281":{"1":2785,"4":5032,"5":177,"6":[0,2],"10":0,"100":1966,"101":5763},"modelId":"lumi.sensor_ht","manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":30,"dateCode":"20160516","swBuildId":"3000-0001"}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1966}},"msRelativeHumidity":{"attributes":{"measuredValue":5742}}},"_binds":[],"meta":{}},{"ID":2,"profileID":260,"deviceID":24322,"inputClusters":[3,18],"outputClusters":[4,3,5,18],"deviceNetworkAddress":35825,"deviceIeeeAddress":"0x00158d00023ce458","clusters":{},"_binds":[],"meta":{}},{"ID":3,"profileID":260,"deviceID":24323,"inputClusters":[3,12],"outputClusters":[4,3,5,12],"deviceNetworkAddress":35825,"deviceIeeeAddress":"0x00158d00023ce458","clusters":{},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_ht","_applicationVersion":2,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":30,"_dateCode":"20160516","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1606567158897},"mapped":{"zigbeeModel":["lumi.sens","lumi.sensor_ht"],"model":"WSDCGQ01LM","vendor":"Xiaomi","description":"MiJia temperature & humidity sensor","supports":"temperature and humidity","meta":{"battery":{"voltageToPercentage":"3V_2100"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msRelativeHumidity","type":["attributeReport","readResponse"]}],"toZigbee":[],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"numeric","name":"temperature","property":"temperature","access":1,"unit":"°C","description":"Measured temperature value"},{"type":"numeric","name":"humidity","property":"humidity","access":1,"unit":"%","description":"Measured relative humidity"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x00158d00023ce458"}
              2020-11-28 14:05:55.131 - info: zigbee.0 (440024) 0x00158d00023ce458 (addr 35825): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (EndDevice)
              2020-11-28 14:05:55.132 - debug: zigbee.0 (440024) New device event: {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d000249a9a8","_networkAddress":56408,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":24321,"inputClusters":[0,3,25,65535,18],"outputClusters":[0,4,3,5,25,65535,18],"deviceNetworkAddress":56408,"deviceIeeeAddress":"0x00158d000249a9a8","clusters":{"genBasic":{"attributes":{"65281":{"1":2815,"4":5032,"5":16,"6":[0,2],"10":0,"100":1820,"101":5317},"modelId":"lumi.sensor_ht","manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":30,"dateCode":"20160516","swBuildId":"3000-0001"}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1843}},"msRelativeHumidity":{"attributes":{"measuredValue":5308}}},"_binds":[],"meta":{}},{"ID":2,"profileID":260,"deviceID":24322,"inputClusters":[3,18],"outputClusters":[4,3,5,18],"deviceNetworkAddress":56408,"deviceIeeeAddress":"0x00158d000249a9a8","clusters":{},"_binds":[],"meta":{}},{"ID":3,"profileID":260,"deviceID":24323,"inputClusters":[3,12],"outputClusters":[4,3,5,12],"deviceNetworkAddress":56408,"deviceIeeeAddress":"0x00158d000249a9a8","clusters":{},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_ht","_applicationVersion":2,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":30,"_dateCode":"20160516","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1606568145941},"mapped":{"zigbeeModel":["lumi.sens","lumi.sensor_ht"],"model":"WSDCGQ01LM","vendor":"Xiaomi","description":"MiJia temperature & humidity sensor","supports":"temperature and humidity","meta":{"battery":{"voltageToPercentage":"3V_2100"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msRelativeHumidity","type":["attributeReport","readResponse"]}],"toZigbee":[],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"numeric","name":"temperature","property":"temperature","access":1,"unit":"°C","description":"Measured temperature value"},{"type":"numeric","name":"humidity","property":"humidity","access":1,"unit":"%","description":"Measured relative humidity"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x00158d000249a9a8"}
              2020-11-28 14:05:55.133 - info: zigbee.0 (440024) 0x00158d000249a9a8 (addr 56408): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (EndDevice)
              2020-11-28 14:05:55.134 - debug: zigbee.0 (440024) New device event: {"type":"device","device":{"ID":5,"_type":"EndDevice","_ieeeAddr":"0x00158d00025562c5","_networkAddress":15287,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":24321,"inputClusters":[0,3,25,65535,18],"outputClusters":[0,4,3,5,25,65535,18],"deviceNetworkAddress":15287,"deviceIeeeAddress":"0x00158d00025562c5","clusters":{"genBasic":{"attributes":{"65281":{"1":2795,"4":5032,"5":23,"6":[0,1],"10":0,"100":2318,"101":4742},"modelId":"lumi.sensor_ht","manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":30,"dateCode":"20160516","swBuildId":"3000-0001"}},"msTemperatureMeasurement":{"attributes":{"measuredValue":2318}},"msRelativeHumidity":{"attributes":{"measuredValue":4793}}},"_binds":[],"meta":{}},{"ID":2,"profileID":260,"deviceID":24322,"inputClusters":[3,18],"outputClusters":[4,3,5,18],"deviceNetworkAddress":15287,"deviceIeeeAddress":"0x00158d00025562c5","clusters":{},"_binds":[],"meta":{}},{"ID":3,"profileID":260,"deviceID":24323,"inputClusters":[3,12],"outputClusters":[4,3,5,12],"deviceNetworkAddress":15287,"deviceIeeeAddress":"0x00158d00025562c5","clusters":{},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_ht","_applicationVersion":2,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":30,"_dateCode":"20160516","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1606566216148},"mapped":{"zigbeeModel":["lumi.sens","lumi.sensor_ht"],"model":"WSDCGQ01LM","vendor":"Xiaomi","description":"MiJia temperature & humidity sensor","supports":"temperature and humidity","meta":{"battery":{"voltageToPercentage":"3V_2100"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msRelativeHumidity","type":["attributeReport","readResponse"]}],"toZigbee":[],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"numeric","name":"temperature","property":"temperature","access":1,"unit":"°C","description":"Measured temperature value"},{"type":"numeric","name":"humidity","property":"humidity","access":1,"unit":"%","description":"Measured relative humidity"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x00158d00025562c5"}
              2020-11-28 14:05:55.135 - info: zigbee.0 (440024) 0x00158d00025562c5 (addr 15287): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (EndDevice)
              2020-11-28 14:05:55.136 - debug: zigbee.0 (440024) New device event: {"type":"device","device":{"ID":6,"_type":"EndDevice","_ieeeAddr":"0x00158d0002fd3f30","_networkAddress":15057,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":15057,"deviceIeeeAddress":"0x00158d0002fd3f30","clusters":{"genBasic":{"attributes":{"65281":{"1":3025,"3":30,"4":17320,"5":26,"6":[0,1],"10":0,"11":100,"100":0},"modelId":"lumi.sensor_motion.aq2","manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":1,"dateCode":"20170627","swBuildId":"3000-0001"}},"ssIasZone":{"attributes":{}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":116}},"msOccupancySensing":{"attributes":{"occupancy":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20170627","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1606568277689},"mapped":{"zigbeeModel":["lumi.sensor_motion.aq2"],"model":"RTCGQ11LM","vendor":"Xiaomi","description":"Aqara human body movement and illuminance sensor","supports":"occupancy and illuminance","meta":{"battery":{"voltageToPercentage":"3V_2100"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"binary","name":"occupancy","property":"occupancy","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected occupancy"},{"type":"numeric","name":"illuminance","property":"illuminance","access":1,"description":"Raw measured illuminance","unit":"lx"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x00158d0002fd3f30"}
              2020-11-28 14:05:55.138 - info: zigbee.0 (440024) 0x00158d0002fd3f30 (addr 15057): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
              2020-11-28 14:05:55.139 - debug: zigbee.0 (440024) New device event: {"type":"device","device":{"ID":7,"_type":"EndDevice","_ieeeAddr":"0x00158d0003667aba","_networkAddress":50038,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":50038,"deviceIeeeAddress":"0x00158d0003667aba","clusters":{"genBasic":{"attributes":{"65281":{"1":3025,"3":18,"4":17320,"5":28,"6":[0,1],"10":0,"11":20,"100":0},"modelId":"lumi.sensor_motion.aq2","manufacturerName":"LUMI","powerSource":3,"zclVersion":1}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":17}},"msOccupancySensing":{"attributes":{"occupancy":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_zclVersion":1,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1606567509213},"mapped":{"zigbeeModel":["lumi.sensor_motion.aq2"],"model":"RTCGQ11LM","vendor":"Xiaomi","description":"Aqara human body movement and illuminance sensor","supports":"occupancy and illuminance","meta":{"battery":{"voltageToPercentage":"3V_2100"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"binary","name":"occupancy","property":"occupancy","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected occupancy"},{"type":"numeric","name":"illuminance","property":"illuminance","access":1,"description":"Raw measured illuminance","unit":"lx"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x00158d0003667aba"}
              2020-11-28 14:05:55.140 - info: zigbee.0 (440024) 0x00158d0003667aba (addr 50038): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
              2020-11-28 14:05:55.141 - debug: zigbee.0 (440024) New device event: {"type":"device","device":{"ID":8,"_type":"EndDevice","_ieeeAddr":"0x00158d0002ea07ac","_networkAddress":64627,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":64627,"deviceIeeeAddress":"0x00158d0002ea07ac","clusters":{"genBasic":{"attributes":{"65281":{"1":3035,"3":24,"4":17320,"5":107,"6":[0,9],"10":0,"11":1,"100":0},"modelId":"lumi.sensor_motion.aq2","manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":1,"dateCode":"20170627","swBuildId":"3000-0001"}},"ssIasZone":{"attributes":{}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":0}},"msOccupancySensing":{"attributes":{"occupancy":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20170627","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1606568623522},"mapped":{"zigbeeModel":["lumi.sensor_motion.aq2"],"model":"RTCGQ11LM","vendor":"Xiaomi","description":"Aqara human body movement and illuminance sensor","supports":"occupancy and illuminance","meta":{"battery":{"voltageToPercentage":"3V_2100"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"binary","name":"occupancy","property":"occupancy","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected occupancy"},{"type":"numeric","name":"illuminance","property":"illuminance","access":1,"description":"Raw measured illuminance","unit":"lx"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x00158d0002ea07ac"}
              2020-11-28 14:05:55.142 - info: zigbee.0 (440024) 0x00158d0002ea07ac (addr 64627): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
              2020-11-28 14:05:55.143 - debug: zigbee.0 (440024) New device event: {"type":"device","device":{"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d00030a3270","_networkAddress":27111,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":27111,"deviceIeeeAddress":"0x00158d00030a3270","clusters":{"genBasic":{"attributes":{"65281":{"1":3005,"3":29,"4":17320,"5":23,"6":[0,28],"10":0,"11":72,"100":0},"modelId":"lumi.sensor_motion.aq2","manufacturerName":"LUMI","powerSource":3}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":64}},"msOccupancySensing":{"attributes":{"occupancy":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_interviewCompleted":false,"_interviewing":false,"meta":{},"_lastSeen":1606568629260},"mapped":{"zigbeeModel":["lumi.sensor_motion.aq2"],"model":"RTCGQ11LM","vendor":"Xiaomi","description":"Aqara human body movement and illuminance sensor","supports":"occupancy and illuminance","meta":{"battery":{"voltageToPercentage":"3V_2100"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"binary","name":"occupancy","property":"occupancy","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected occupancy"},{"type":"numeric","name":"illuminance","property":"illuminance","access":1,"description":"Raw measured illuminance","unit":"lx"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x00158d00030a3270"}
              2020-11-28 14:05:55.144 - info: zigbee.0 (440024) 0x00158d00030a3270 (addr 27111): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
              2020-11-28 14:05:55.145 - debug: zigbee.0 (440024) New device event: {"type":"device","device":{"ID":10,"_type":"EndDevice","_ieeeAddr":"0x00158d00032c1109","_networkAddress":40226,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":40226,"deviceIeeeAddress":"0x00158d00032c1109","clusters":{"genBasic":{"attributes":{"65281":{"1":3025,"3":23,"4":17320,"5":16,"6":[0,1],"10":0,"11":65,"100":0},"modelId":"lumi.sensor_motion.aq2","manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":1,"dateCode":"20170627","swBuildId":"3000-0001"}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":56}},"msOccupancySensing":{"attributes":{"occupancy":1}},"ssIasZone":{"attributes":{}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20170627","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1606568393630},"mapped":{"zigbeeModel":["lumi.sensor_motion.aq2"],"model":"RTCGQ11LM","vendor":"Xiaomi","description":"Aqara human body movement and illuminance sensor","supports":"occupancy and illuminance","meta":{"battery":{"voltageToPercentage":"3V_2100"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"binary","name":"occupancy","property":"occupancy","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected occupancy"},{"type":"numeric","name":"illuminance","property":"illuminance","access":1,"description":"Raw measured illuminance","unit":"lx"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x00158d00032c1109"}
              2020-11-28 14:05:55.146 - info: zigbee.0 (440024) 0x00158d00032c1109 (addr 40226): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
              2020-11-28 14:05:55.147 - debug: zigbee.0 (440024) New device event: {"type":"device","device":{"ID":14,"_type":"EndDevice","_ieeeAddr":"0xccccccfffee04e28","_networkAddress":6689,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"deviceID":2080,"inputClusters":[0,1,3,9,32,4096,64636],"outputClusters":[3,4,6,8,25,258,4096],"deviceNetworkAddress":6689,"deviceIeeeAddress":"0xccccccfffee04e28","clusters":{"genBasic":{"attributes":{"modelId":"TRADFRI on/off switch","manufacturerName":"IKEA of Sweden","powerSource":3,"zclVersion":3,"appVersion":34,"stackVersion":98,"hwVersion":1,"dateCode":"20190410","swBuildId":"2.2.008"}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":21}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"IKEA of Sweden","_powerSource":"Battery","_modelID":"TRADFRI on/off switch","_applicationVersion":34,"_stackVersion":98,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"20190410","_softwareBuildID":"2.2.008","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1606509742091},"mapped":{"zigbeeModel":["TRADFRI on/off switch"],"model":"E1743","vendor":"IKEA","description":"TRADFRI ON/OFF switch","supports":"on, off, brightness up/down/stop","fromZigbee":[{"cluster":"genOnOff","type":"commandOn"},{"cluster":"genOnOff","type":"commandOn"},{"cluster":"genOnOff","type":"commandOff"},{"cluster":"genOnOff","type":"commandOff"},{"cluster":"genLevelCtrl","type":["commandMove","commandMoveWithOnOff"]},{"cluster":"genLevelCtrl","type":"commandMoveWithOnOff"},{"cluster":"genLevelCtrl","type":"commandMove"},{"cluster":"genLevelCtrl","type":["commandStop","commandStopWithOnOff"]},{"cluster":"genLevelCtrl","type":"commandStopWithOnOff"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"enum","name":"action","property":"action","access":1,"values":["on","off","brightness_move_down","brightness_move_up","brightness_stop"],"description":"Triggered action (e.g. a button click)"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}],"toZigbee":[],"ota":{},"meta":{"configureKey":1,"disableActionGroup":true,"battery":{"dontDividePercentage":true}}},"name":"0xccccccfffee04e28"}
              2020-11-28 14:05:55.149 - info: zigbee.0 (440024) 0xccccccfffee04e28 (addr 6689): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
              2020-11-28 14:05:55.149 - debug: zigbee.0 (440024) New device event: {"type":"device","device":{"ID":15,"_type":"EndDevice","_ieeeAddr":"0xec1bbdfffe9734c2","_networkAddress":21546,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"deviceID":2080,"inputClusters":[0,1,3,9,32,4096,64636],"outputClusters":[3,4,6,8,25,258,4096],"deviceNetworkAddress":21546,"deviceIeeeAddress":"0xec1bbdfffe9734c2","clusters":{"genBasic":{"attributes":{"modelId":"TRADFRI on/off switch","manufacturerName":"IKEA of Sweden","powerSource":3,"zclVersion":3,"appVersion":34,"stackVersion":98,"hwVersion":1,"dateCode":"20190410","swBuildId":"2.2.008"}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":16}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"IKEA of Sweden","_powerSource":"Battery","_modelID":"TRADFRI on/off switch","_applicationVersion":34,"_stackVersion":98,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"20190410","_softwareBuildID":"2.2.008","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1604084119082},"mapped":{"zigbeeModel":["TRADFRI on/off switch"],"model":"E1743","vendor":"IKEA","description":"TRADFRI ON/OFF switch","supports":"on, off, brightness up/down/stop","fromZigbee":[{"cluster":"genOnOff","type":"commandOn"},{"cluster":"genOnOff","type":"commandOn"},{"cluster":"genOnOff","type":"commandOff"},{"cluster":"genOnOff","type":"commandOff"},{"cluster":"genLevelCtrl","type":["commandMove","commandMoveWithOnOff"]},{"cluster":"genLevelCtrl","type":"commandMoveWithOnOff"},{"cluster":"genLevelCtrl","type":"commandMove"},{"cluster":"genLevelCtrl","type":["commandStop","commandStopWithOnOff"]},{"cluster":"genLevelCtrl","type":"commandStopWithOnOff"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"enum","name":"action","property":"action","access":1,"values":["on","off","brightness_move_down","brightness_move_up","brightness_stop"],"description":"Triggered action (e.g. a button click)"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}],"toZigbee":[],"ota":{},"meta":{"configureKey":1,"disableActionGroup":true,"battery":{"dontDividePercentage":true}}},"name":"0xec1bbdfffe9734c2"}
              2020-11-28 14:05:55.151 - info: zigbee.0 (440024) 0xec1bbdfffe9734c2 (addr 21546): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
              2020-11-28 14:05:55.151 - debug: zigbee.0 (440024) New device event: {"type":"device","device":{"ID":16,"_type":"EndDevice","_ieeeAddr":"0xec1bbdfffe972471","_networkAddress":60529,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"deviceID":2080,"inputClusters":[0,1,3,9,32,4096,64636],"outputClusters":[3,4,6,8,25,258,4096],"deviceNetworkAddress":60529,"deviceIeeeAddress":"0xec1bbdfffe972471","clusters":{"genBasic":{"attributes":{"modelId":"TRADFRI on/off switch","manufacturerName":"IKEA of Sweden","powerSource":3,"zclVersion":3,"appVersion":34,"stackVersion":98,"hwVersion":1,"dateCode":"20190410","swBuildId":"2.2.008"}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":5}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"IKEA of Sweden","_powerSource":"Battery","_modelID":"TRADFRI on/off switch","_applicationVersion":34,"_stackVersion":98,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"20190410","_softwareBuildID":"2.2.008","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1606510533120},"mapped":{"zigbeeModel":["TRADFRI on/off switch"],"model":"E1743","vendor":"IKEA","description":"TRADFRI ON/OFF switch","supports":"on, off, brightness up/down/stop","fromZigbee":[{"cluster":"genOnOff","type":"commandOn"},{"cluster":"genOnOff","type":"commandOn"},{"cluster":"genOnOff","type":"commandOff"},{"cluster":"genOnOff","type":"commandOff"},{"cluster":"genLevelCtrl","type":["commandMove","commandMoveWithOnOff"]},{"cluster":"genLevelCtrl","type":"commandMoveWithOnOff"},{"cluster":"genLevelCtrl","type":"commandMove"},{"cluster":"genLevelCtrl","type":["commandStop","commandStopWithOnOff"]},{"cluster":"genLevelCtrl","type":"commandStopWithOnOff"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"enum","name":"action","property":"action","access":1,"values":["on","off","brightness_move_down","brightness_move_up","brightness_stop"],"description":"Triggered action (e.g. a button click)"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}],"toZigbee":[],"ota":{},"meta":{"configureKey":1,"disableActionGroup":true,"battery":{"dontDividePercentage":true}}},"name":"0xec1bbdfffe972471"}
              2020-11-28 14:05:55.153 - info: zigbee.0 (440024) 0xec1bbdfffe972471 (addr 60529): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
              2020-11-28 14:05:55.153 - debug: zigbee.0 (440024) New device event: {"type":"device","device":{"ID":20,"_type":"EndDevice","_ieeeAddr":"0xec1bbdfffeb45b50","_networkAddress":27434,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"deviceID":2080,"inputClusters":[0,1,3,9,32,4096,64636],"outputClusters":[3,4,6,8,25,258,4096],"deviceNetworkAddress":27434,"deviceIeeeAddress":"0xec1bbdfffeb45b50","clusters":{"genBasic":{"attributes":{"modelId":"TRADFRI on/off switch","manufacturerName":"IKEA of Sweden","powerSource":3,"zclVersion":3,"appVersion":34,"stackVersion":98,"hwVersion":1,"dateCode":"20190410","swBuildId":"2.2.008"}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":16}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"IKEA of Sweden","_powerSource":"Battery","_modelID":"TRADFRI on/off switch","_applicationVersion":34,"_stackVersion":98,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"20190410","_softwareBuildID":"2.2.008","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1606561756278},"mapped":{"zigbeeModel":["TRADFRI on/off switch"],"model":"E1743","vendor":"IKEA","description":"TRADFRI ON/OFF switch","supports":"on, off, brightness up/down/stop","fromZigbee":[{"cluster":"genOnOff","type":"commandOn"},{"cluster":"genOnOff","type":"commandOn"},{"cluster":"genOnOff","type":"commandOff"},{"cluster":"genOnOff","type":"commandOff"},{"cluster":"genLevelCtrl","type":["commandMove","commandMoveWithOnOff"]},{"cluster":"genLevelCtrl","type":"commandMoveWithOnOff"},{"cluster":"genLevelCtrl","type":"commandMove"},{"cluster":"genLevelCtrl","type":["commandStop","commandStopWithOnOff"]},{"cluster":"genLevelCtrl","type":"commandStopWithOnOff"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"enum","name":"action","property":"action","access":1,"values":["on","off","brightness_move_down","brightness_move_up","brightness_stop"],"description":"Triggered action (e.g. a button click)"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}],"toZigbee":[],"ota":{},"meta":{"configureKey":1,"disableActionGroup":true,"battery":{"dontDividePercentage":true}}},"name":"0xec1bbdfffeb45b50"}
              2020-11-28 14:05:55.155 - info: zigbee.0 (440024) 0xec1bbdfffeb45b50 (addr 27434): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
              2020-11-28 14:05:55.156 - debug: zigbee.0 (440024) New device event: {"type":"device","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":55668,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":2}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":160}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":-1},"_lastSeen":1606568539553},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]}],"meta":{"configureKey":5},"exposes":[{"type":"lock","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"LOCK","value_off":"UNLOCK","description":"State of the lock"}]},{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x000b57fffe59d1f6"}
              2020-11-28 14:05:55.157 - info: zigbee.0 (440024) 0x000b57fffe59d1f6 (addr 55668): V3-BTZB - Danalock BT/ZB smartlock (EndDevice)
              2020-11-28 14:05:55.158 - info: zigbee.0 (440024) Zigbee started
              2020-11-28 14:05:56.117 - debug: zigbee.0 (440024) Publish available for 0x00158d000208dc76 = true
              2020-11-28 14:05:56.131 - debug: zigbee.0 (440024) Publish available for 0x00158d00023ce458 = true
              2020-11-28 14:05:56.132 - debug: zigbee.0 (440024) Publish available for 0x00158d000249a9a8 = true
              2020-11-28 14:05:56.134 - debug: zigbee.0 (440024) Publish available for 0x00158d00025562c5 = true
              2020-11-28 14:05:56.135 - debug: zigbee.0 (440024) Publish available for 0x00158d0002fd3f30 = true
              2020-11-28 14:05:56.138 - debug: zigbee.0 (440024) Publish available for 0x00158d0003667aba = true
              2020-11-28 14:05:56.142 - debug: zigbee.0 (440024) Publish available for 0x00158d0002ea07ac = true
              2020-11-28 14:05:56.145 - debug: zigbee.0 (440024) Publish available for 0x00158d00030a3270 = true
              2020-11-28 14:05:56.146 - debug: zigbee.0 (440024) Publish available for 0x00158d00032c1109 = true
              2020-11-28 14:05:56.150 - debug: zigbee.0 (440024) Publish available for 0xccccccfffee04e28 = true
              2020-11-28 14:05:56.151 - debug: zigbee.0 (440024) Publish available for 0xec1bbdfffe9734c2 = true
              2020-11-28 14:05:56.154 - debug: zigbee.0 (440024) Publish available for 0xec1bbdfffe972471 = true
              2020-11-28 14:05:56.156 - debug: zigbee.0 (440024) Publish available for 0xec1bbdfffeb45b50 = true
              2020-11-28 14:05:56.160 - debug: zigbee.0 (440024) Publish available for 0x000b57fffe59d1f6 = true
              2020-11-28 14:06:00.784 - info: zigbee.0 (440024) DeviceConfigure successful 0x000b57fffe59d1f6 V3-BTZB
              2020-11-28 14:06:03.284 - debug: zigbee.0 (440024) system.adapter.admin.0: logging true
              2020-11-28 14:06:58.101 - debug: zigbee.0 (440024) system.adapter.admin.0: logging false
              2020-11-28 14:07:28.846 - debug: zigbee.0 (440024) handleMessage. {"type":"attributeReport","device":{"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d00030a3270","_networkAddress":27111,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":27111,"deviceIeeeAddress":"0x00158d00030a3270","clusters":{"genBasic":{"attributes":{"65281":{"1":3005,"3":29,"4":17320,"5":23,"6":[0,28],"10":0,"11":72,"100":0},"modelId":"lumi.sensor_motion.aq2","manufacturerName":"LUMI","powerSource":3}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":60}},"msOccupancySensing":{"attributes":{"occupancy":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_interviewCompleted":false,"_interviewing":false,"meta":{},"_lastSeen":1606568848843,"_linkquality":81},"endpoint":"[Circular]","data":{"measuredValue":60},"linkquality":81,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":158,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
              2020-11-28 14:07:28.848 - debug: zigbee.0 (440024) Received Zigbee message from '0x00158d00030a3270', type 'attributeReport', cluster 'msIlluminanceMeasurement', data '{"measuredValue":60}' from endpoint 1 with groupID 0
              2020-11-28 14:07:28.849 - debug: zigbee.0 (440024) Type attributeReport device {"type":"device","device":{"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d00030a3270","_networkAddress":27111,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":27111,"deviceIeeeAddress":"0x00158d00030a3270","clusters":{"genBasic":{"attributes":{"65281":{"1":3005,"3":29,"4":17320,"5":23,"6":[0,28],"10":0,"11":72,"100":0},"modelId":"lumi.sensor_motion.aq2","manufacturerName":"LUMI","powerSource":3}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":60}},"msOccupancySensing":{"attributes":{"occupancy":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_interviewCompleted":false,"_interviewing":false,"meta":{},"_lastSeen":1606568848843,"_linkquality":81},"mapped":{"zigbeeModel":["lumi.sensor_motion.aq2"],"model":"RTCGQ11LM","vendor":"Xiaomi","description":"Aqara human body movement and illuminance sensor","supports":"occupancy and illuminance","meta":{"battery":{"voltageToPercentage":"3V_2100"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"binary","name":"occupancy","property":"occupancy","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected occupancy"},{"type":"numeric","name":"illuminance","property":"illuminance","access":1,"description":"Raw measured illuminance","unit":"lx"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x00158d00030a3270"} incoming event: {"type":"attributeReport","device":{"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d00030a3270","_networkAddress":27111,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":27111,"deviceIeeeAddress":"0x00158d00030a3270","clusters":{"genBasic":{"attributes":{"65281":{"1":3005,"3":29,"4":17320,"5":23,"6":[0,28],"10":0,"11":72,"100":0},"modelId":"lumi.sensor_motion.aq2","manufacturerName":"LUMI","powerSource":3}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":60}},"msOccupancySensing":{"attributes":{"occupancy":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_interviewCompleted":false,"_interviewing":false,"meta":{},"_lastSeen":1606568848843,"_linkquality":81},"endpoint":"[Circular]","data":{"measuredValue":60},"linkquality":81,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":158,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
              2020-11-28 14:07:28.854 - debug: zigbee.0 (440024) handleMessage. {"type":"attributeReport","device":{"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d00030a3270","_networkAddress":27111,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":27111,"deviceIeeeAddress":"0x00158d00030a3270","clusters":{"genBasic":{"attributes":{"65281":{"1":3005,"3":29,"4":17320,"5":23,"6":[0,28],"10":0,"11":72,"100":0},"modelId":"lumi.sensor_motion.aq2","manufacturerName":"LUMI","powerSource":3}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":60}},"msOccupancySensing":{"attributes":{"occupancy":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_interviewCompleted":false,"_interviewing":false,"meta":{},"_lastSeen":1606568848854,"_linkquality":90},"endpoint":"[Circular]","data":{"occupancy":1},"linkquality":90,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":159,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
              2020-11-28 14:07:28.855 - debug: zigbee.0 (440024) Received Zigbee message from '0x00158d00030a3270', type 'attributeReport', cluster 'msOccupancySensing', data '{"occupancy":1}' from endpoint 1 with groupID 0
              2020-11-28 14:07:28.856 - debug: zigbee.0 (440024) Type attributeReport device {"type":"device","device":{"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d00030a3270","_networkAddress":27111,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":27111,"deviceIeeeAddress":"0x00158d00030a3270","clusters":{"genBasic":{"attributes":{"65281":{"1":3005,"3":29,"4":17320,"5":23,"6":[0,28],"10":0,"11":72,"100":0},"modelId":"lumi.sensor_motion.aq2","manufacturerName":"LUMI","powerSource":3}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":60}},"msOccupancySensing":{"attributes":{"occupancy":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_interviewCompleted":false,"_interviewing":false,"meta":{},"_lastSeen":1606568848854,"_linkquality":90},"mapped":{"zigbeeModel":["lumi.sensor_motion.aq2"],"model":"RTCGQ11LM","vendor":"Xiaomi","description":"Aqara human body movement and illuminance sensor","supports":"occupancy and illuminance","meta":{"battery":{"voltageToPercentage":"3V_2100"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"binary","name":"occupancy","property":"occupancy","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected occupancy"},{"type":"numeric","name":"illuminance","property":"illuminance","access":1,"description":"Raw measured illuminance","unit":"lx"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x00158d00030a3270"} incoming event: {"type":"attributeReport","device":{"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d00030a3270","_networkAddress":27111,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":27111,"deviceIeeeAddress":"0x00158d00030a3270","clusters":{"genBasic":{"attributes":{"65281":{"1":3005,"3":29,"4":17320,"5":23,"6":[0,28],"10":0,"11":72,"100":0},"modelId":"lumi.sensor_motion.aq2","manufacturerName":"LUMI","powerSource":3}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":60}},"msOccupancySensing":{"attributes":{"occupancy":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_interviewCompleted":false,"_interviewing":false,"meta":{},"_lastSeen":1606568848854,"_linkquality":90},"endpoint":"[Circular]","data":{"occupancy":1},"linkquality":90,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":159,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
              2020-11-28 14:07:28.861 - debug: zigbee.0 (440024) Publish {"illuminance":60,"illuminance_lux":60}
              2020-11-28 14:07:28.863 - debug: zigbee.0 (440024) Publish {"occupancy":true}
              2020-11-28 14:07:38.866 - debug: zigbee.0 (440024) Publish {"occupancy":false}
              2020-11-28 14:08:08.038 - debug: zigbee.0 (440024) handleMessage. {"type":"commandOperationEventNotification","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":55668,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":2}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":160}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1606568888038,"_linkquality":69},"endpoint":"[Circular]","data":{"opereventsrc":1,"opereventcode":1,"userid":65535,"pin":0,"zigbeelocaltime":4294967295,"data":0},"linkquality":69,"groupID":0,"cluster":"closuresDoorLock","meta":{"zclTransactionSequenceNumber":20,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
              2020-11-28 14:08:08.042 - debug: zigbee.0 (440024) Received Zigbee message from '0x000b57fffe59d1f6', type 'commandOperationEventNotification', cluster 'closuresDoorLock', data '{"opereventsrc":1,"opereventcode":1,"userid":65535,"pin":0,"zigbeelocaltime":4294967295,"data":0}' from endpoint 1 with groupID 0
              2020-11-28 14:08:08.043 - debug: zigbee.0 (440024) Type commandOperationEventNotification device {"type":"device","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":55668,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":2}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":160}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1606568888038,"_linkquality":69},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]}],"meta":{"configureKey":5},"exposes":[{"type":"lock","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"LOCK","value_off":"UNLOCK","description":"State of the lock"}]},{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x000b57fffe59d1f6"} incoming event: {"type":"commandOperationEventNotification","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":55668,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":2}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":160}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1606568888038,"_linkquality":69},"endpoint":"[Circular]","data":{"opereventsrc":1,"opereventcode":1,"userid":65535,"pin":0,"zigbeelocaltime":4294967295,"data":0},"linkquality":69,"groupID":0,"cluster":"closuresDoorLock","meta":{"zclTransactionSequenceNumber":20,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
              2020-11-28 14:08:08.048 - debug: zigbee.0 (440024) handleMessage. {"type":"attributeReport","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":55668,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":160}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1606568888047,"_linkquality":69},"endpoint":"[Circular]","data":{"lockState":1},"linkquality":69,"groupID":0,"cluster":"closuresDoorLock","meta":{"zclTransactionSequenceNumber":21,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
              2020-11-28 14:08:08.050 - debug: zigbee.0 (440024) Received Zigbee message from '0x000b57fffe59d1f6', type 'attributeReport', cluster 'closuresDoorLock', data '{"lockState":1}' from endpoint 1 with groupID 0
              2020-11-28 14:08:08.051 - debug: zigbee.0 (440024) Type attributeReport device {"type":"device","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":55668,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":160}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1606568888047,"_linkquality":69},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]}],"meta":{"configureKey":5},"exposes":[{"type":"lock","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"LOCK","value_off":"UNLOCK","description":"State of the lock"}]},{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x000b57fffe59d1f6"} incoming event: {"type":"attributeReport","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":55668,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":160}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1606568888047,"_linkquality":69},"endpoint":"[Circular]","data":{"lockState":1},"linkquality":69,"groupID":0,"cluster":"closuresDoorLock","meta":{"zclTransactionSequenceNumber":21,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
              2020-11-28 14:08:08.057 - debug: zigbee.0 (440024) Publish {"action":"lock","action_user":65535,"action_source":1,"action_source_name":"rf"}
              2020-11-28 14:08:08.058 - debug: zigbee.0 (440024) Publish {"state":"LOCK","lock_state":"locked"}
              2020-11-28 14:08:21.866 - debug: zigbee.0 (440024) handleMessage. {"type":"commandOperationEventNotification","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":55668,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":160}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1606568901866,"_linkquality":72},"endpoint":"[Circular]","data":{"opereventsrc":1,"opereventcode":2,"userid":65535,"pin":0,"zigbeelocaltime":4294967295,"data":0},"linkquality":72,"groupID":0,"cluster":"closuresDoorLock","meta":{"zclTransactionSequenceNumber":22,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
              2020-11-28 14:08:21.873 - debug: zigbee.0 (440024) Received Zigbee message from '0x000b57fffe59d1f6', type 'commandOperationEventNotification', cluster 'closuresDoorLock', data '{"opereventsrc":1,"opereventcode":2,"userid":65535,"pin":0,"zigbeelocaltime":4294967295,"data":0}' from endpoint 1 with groupID 0
              2020-11-28 14:08:21.874 - debug: zigbee.0 (440024) Type commandOperationEventNotification device {"type":"device","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":55668,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":160}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1606568901866,"_linkquality":72},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]}],"meta":{"configureKey":5},"exposes":[{"type":"lock","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"LOCK","value_off":"UNLOCK","description":"State of the lock"}]},{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x000b57fffe59d1f6"} incoming event: {"type":"commandOperationEventNotification","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":55668,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":160}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1606568901866,"_linkquality":72},"endpoint":"[Circular]","data":{"opereventsrc":1,"opereventcode":2,"userid":65535,"pin":0,"zigbeelocaltime":4294967295,"data":0},"linkquality":72,"groupID":0,"cluster":"closuresDoorLock","meta":{"zclTransactionSequenceNumber":22,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
              2020-11-28 14:08:21.881 - debug: zigbee.0 (440024) handleMessage. {"type":"attributeReport","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":55668,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":2}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":160}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1606568901877,"_linkquality":69},"endpoint":"[Circular]","data":{"lockState":2},"linkquality":69,"groupID":0,"cluster":"closuresDoorLock","meta":{"zclTransactionSequenceNumber":23,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
              2020-11-28 14:08:21.882 - debug: zigbee.0 (440024) Received Zigbee message from '0x000b57fffe59d1f6', type 'attributeReport', cluster 'closuresDoorLock', data '{"lockState":2}' from endpoint 1 with groupID 0
              2020-11-28 14:08:21.883 - debug: zigbee.0 (440024) Type attributeReport device {"type":"device","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":55668,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":2}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":160}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1606568901877,"_linkquality":69},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]}],"meta":{"configureKey":5},"exposes":[{"type":"lock","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"LOCK","value_off":"UNLOCK","description":"State of the lock"}]},{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x000b57fffe59d1f6"} incoming event: {"type":"attributeReport","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":55668,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":2}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":160}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1606568901877,"_linkquality":69},"endpoint":"[Circular]","data":{"lockState":2},"linkquality":69,"groupID":0,"cluster":"closuresDoorLock","meta":{"zclTransactionSequenceNumber":23,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
              2020-11-28 14:08:21.887 - debug: zigbee.0 (440024) Publish {"action":"unlock","action_user":65535,"action_source":1,"action_source_name":"rf"}
              2020-11-28 14:08:21.888 - debug: zigbee.0 (440024) Publish {"state":"UNLOCK","lock_state":"unlocked"}
              2020-11-28 14:08:31.655 - debug: zigbee.0 (440024) system.adapter.admin.0: logging true
              2020-11-28 14:10:55.099 - debug: zigbee.0 (440024) Non-pingable device 0x00158d000208dc76 lumi.sensor_ht was last seen '1142.702' seconds ago.
              2020-11-28 14:10:55.099 - debug: zigbee.0 (440024) Non-pingable device 0x00158d00023ce458 lumi.sensor_ht was last seen '1896.202' seconds ago.
              2020-11-28 14:10:55.100 - debug: zigbee.0 (440024) Non-pingable device 0x00158d000249a9a8 lumi.sensor_ht was last seen '909.159' seconds ago.
              2020-11-28 14:10:55.100 - debug: zigbee.0 (440024) Non-pingable device 0x00158d00025562c5 lumi.sensor_ht was last seen '2838.952' seconds ago.
              2020-11-28 14:10:55.100 - debug: zigbee.0 (440024) Non-pingable device 0x00158d0002fd3f30 lumi.sensor_motion.aq2 was last seen '777.411' seconds ago.
              2020-11-28 14:10:55.101 - debug: zigbee.0 (440024) Non-pingable device 0x00158d0003667aba lumi.sensor_motion.aq2 was last seen '1545.888' seconds ago.
              2020-11-28 14:10:55.101 - debug: zigbee.0 (440024) Non-pingable device 0x00158d0002ea07ac lumi.sensor_motion.aq2 was last seen '431.579' seconds ago.
              2020-11-28 14:10:55.101 - debug: zigbee.0 (440024) Non-pingable device 0x00158d00030a3270 lumi.sensor_motion.aq2 was last seen '206.247' seconds ago.
              2020-11-28 14:10:55.102 - debug: zigbee.0 (440024) Non-pingable device 0x00158d00032c1109 lumi.sensor_motion.aq2 was last seen '661.472' seconds ago.
              2020-11-28 14:10:55.102 - debug: zigbee.0 (440024) Non-pingable device 0xccccccfffee04e28 TRADFRI on/off switch was last seen '59313.011' seconds ago.
              2020-11-28 14:10:55.102 - debug: zigbee.0 (440024) Non-pingable device 0xec1bbdfffe9734c2 TRADFRI on/off switch was last seen '2484936.02' seconds ago.
              2020-11-28 14:10:55.103 - debug: zigbee.0 (440024) Publish available for 0xec1bbdfffe9734c2 = false
              2020-11-28 14:10:55.103 - debug: zigbee.0 (440024) Non-pingable device 0xec1bbdfffe972471 TRADFRI on/off switch was last seen '58521.983' seconds ago.
              2020-11-28 14:10:55.104 - debug: zigbee.0 (440024) Non-pingable device 0xec1bbdfffeb45b50 TRADFRI on/off switch was last seen '7298.826' seconds ago.
              2020-11-28 14:12:02.257 - debug: zigbee.0 (440024) system.adapter.admin.0: logging false
              2020-11-28 14:13:18.525 - debug: zigbee.0 (440024) handleMessage. {"type":"attributeReport","device":{"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d00030a3270","_networkAddress":27111,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":27111,"deviceIeeeAddress":"0x00158d00030a3270","clusters":{"genBasic":{"attributes":{"65281":{"1":3005,"3":29,"4":17320,"5":23,"6":[0,28],"10":0,"11":72,"100":0},"modelId":"lumi.sensor_motion.aq2","manufacturerName":"LUMI","powerSource":3}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":57}},"msOccupancySensing":{"attributes":{"occupancy":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_interviewCompleted":false,"_interviewing":false,"meta":{},"_lastSeen":1606569198525,"_linkquality":90},"endpoint":"[Circular]","data":{"measuredValue":57},"linkquality":90,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":160,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
              2020-11-28 14:13:18.526 - debug: zigbee.0 (440024) Received Zigbee message from '0x00158d00030a3270', type 'attributeReport', cluster 'msIlluminanceMeasurement', data '{"measuredValue":57}' from endpoint 1 with groupID 0
              2020-11-28 14:13:18.527 - debug: zigbee.0 (440024) Type attributeReport device {"type":"device","device":{"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d00030a3270","_networkAddress":27111,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":27111,"deviceIeeeAddress":"0x00158d00030a3270","clusters":{"genBasic":{"attributes":{"65281":{"1":3005,"3":29,"4":17320,"5":23,"6":[0,28],"10":0,"11":72,"100":0},"modelId":"lumi.sensor_motion.aq2","manufacturerName":"LUMI","powerSource":3}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":57}},"msOccupancySensing":{"attributes":{"occupancy":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_interviewCompleted":false,"_interviewing":false,"meta":{},"_lastSeen":1606569198525,"_linkquality":90},"mapped":{"zigbeeModel":["lumi.sensor_motion.aq2"],"model":"RTCGQ11LM","vendor":"Xiaomi","description":"Aqara human body movement and illuminance sensor","supports":"occupancy and illuminance","meta":{"battery":{"voltageToPercentage":"3V_2100"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"binary","name":"occupancy","property":"occupancy","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected occupancy"},{"type":"numeric","name":"illuminance","property":"illuminance","access":1,"description":"Raw measured illuminance","unit":"lx"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x00158d00030a3270"} incoming event: {"type":"attributeReport","device":{"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d00030a3270","_networkAddress":27111,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":27111,"deviceIeeeAddress":"0x00158d00030a3270","clusters":{"genBasic":{"attributes":{"65281":{"1":3005,"3":29,"4":17320,"5":23,"6":[0,28],"10":0,"11":72,"100":0},"modelId":"lumi.sensor_motion.aq2","manufacturerName":"LUMI","powerSource":3}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":57}},"msOccupancySensing":{"attributes":{"occupancy":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_interviewCompleted":false,"_interviewing":false,"meta":{},"_lastSeen":1606569198525,"_linkquality":90},"endpoint":"[Circular]","data":{"measuredValue":57},"linkquality":90,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":160,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
              2020-11-28 14:13:18.530 - debug: zigbee.0 (440024) handleMessage. {"type":"attributeReport","device":{"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d00030a3270","_networkAddress":27111,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":27111,"deviceIeeeAddress":"0x00158d00030a3270","clusters":{"genBasic":{"attributes":{"65281":{"1":3005,"3":29,"4":17320,"5":23,"6":[0,28],"10":0,"11":72,"100":0},"modelId":"lumi.sensor_motion.aq2","manufacturerName":"LUMI","powerSource":3}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":57}},"msOccupancySensing":{"attributes":{"occupancy":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_interviewCompleted":false,"_interviewing":false,"meta":{},"_lastSeen":1606569198530,"_linkquality":90},"endpoint":"[Circular]","data":{"occupancy":1},"linkquality":90,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":161,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
              2020-11-28 14:13:18.531 - debug: zigbee.0 (440024) Received Zigbee message from '0x00158d00030a3270', type 'attributeReport', cluster 'msOccupancySensing', data '{"occupancy":1}' from endpoint 1 with groupID 0
              2020-11-28 14:13:18.532 - debug: zigbee.0 (440024) Type attributeReport device {"type":"device","device":{"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d00030a3270","_networkAddress":27111,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":27111,"deviceIeeeAddress":"0x00158d00030a3270","clusters":{"genBasic":{"attributes":{"65281":{"1":3005,"3":29,"4":17320,"5":23,"6":[0,28],"10":0,"11":72,"100":0},"modelId":"lumi.sensor_motion.aq2","manufacturerName":"LUMI","powerSource":3}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":57}},"msOccupancySensing":{"attributes":{"occupancy":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_interviewCompleted":false,"_interviewing":false,"meta":{},"_lastSeen":1606569198530,"_linkquality":90},"mapped":{"zigbeeModel":["lumi.sensor_motion.aq2"],"model":"RTCGQ11LM","vendor":"Xiaomi","description":"Aqara human body movement and illuminance sensor","supports":"occupancy and illuminance","meta":{"battery":{"voltageToPercentage":"3V_2100"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"binary","name":"occupancy","property":"occupancy","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected occupancy"},{"type":"numeric","name":"illuminance","property":"illuminance","access":1,"description":"Raw measured illuminance","unit":"lx"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x00158d00030a3270"} incoming event: {"type":"attributeReport","device":{"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d00030a3270","_networkAddress":27111,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":27111,"deviceIeeeAddress":"0x00158d00030a3270","clusters":{"genBasic":{"attributes":{"65281":{"1":3005,"3":29,"4":17320,"5":23,"6":[0,28],"10":0,"11":72,"100":0},"modelId":"lumi.sensor_motion.aq2","manufacturerName":"LUMI","powerSource":3}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":57}},"msOccupancySensing":{"attributes":{"occupancy":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_interviewCompleted":false,"_interviewing":false,"meta":{},"_lastSeen":1606569198530,"_linkquality":90},"endpoint":"[Circular]","data":{"occupancy":1},"linkquality":90,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":161,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
              2020-11-28 14:13:18.536 - debug: zigbee.0 (440024) Publish {"illuminance":57,"illuminance_lux":57}
              2020-11-28 14:13:18.537 - debug: zigbee.0 (440024) Publish {"occupancy":true}
              2020-11-28 14:13:24.444 - debug: zigbee.0 (440024) handleMessage. {"type":"readResponse","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":55668,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":2}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":160}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1606569204443,"_linkquality":57},"endpoint":"[Circular]","data":{"zclVersion":2},"linkquality":57,"groupID":0,"cluster":"genBasic","meta":{"zclTransactionSequenceNumber":4,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
              2020-11-28 14:13:24.444 - debug: zigbee.0 (440024) Received Zigbee message from '0x000b57fffe59d1f6', type 'readResponse', cluster 'genBasic', data '{"zclVersion":2}' from endpoint 1 with groupID 0
              2020-11-28 14:13:24.446 - debug: zigbee.0 (440024) Type readResponse device {"type":"device","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":55668,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":2}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":160}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1606569204443,"_linkquality":57},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]}],"meta":{"configureKey":5},"exposes":[{"type":"lock","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"LOCK","value_off":"UNLOCK","description":"State of the lock"}]},{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x000b57fffe59d1f6"} incoming event: {"type":"readResponse","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":55668,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":2}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":160}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1606569204443,"_linkquality":57},"endpoint":"[Circular]","data":{"zclVersion":2},"linkquality":57,"groupID":0,"cluster":"genBasic","meta":{"zclTransactionSequenceNumber":4,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
              2020-11-28 14:13:24.447 - debug: zigbee.0 (440024) Successfully pinged 0x000b57fffe59d1f6 V3-BTZB
              2020-11-28 14:13:28.538 - debug: zigbee.0 (440024) Publish {"occupancy":false}
              2020-11-28 14:14:00.042 - info: host.Beelink instance system.adapter.openweathermap.0 started with pid 449347
              2020-11-28 14:14:02.221 - info: openweathermap.0 (449347) starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v14.15.1, js-controller: 3.1.6
              2020-11-28 14:14:05.367 - info: openweathermap.0 (449347) Terminated (NO_ERROR): Without reason
              2020-11-28 14:14:05.889 - info: host.Beelink instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
              2020-11-28 14:14:11.275 - debug: zigbee.0 (440024) system.adapter.admin.0: logging true
              So und den Stick auch gleich mal upgedatet:
              zigbee.0	2020-11-28 15:44:46.473	info	(553242) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20201026}}
              Leider keine Änderungen an den Danalock DPs.
              • DK43
                DK43 last edited by
                Hi
                Hab hier von Silvercrest (Lidl) einen Bewegungssensor und einen Smart Plug.
                Adapter Version 1.3.1
                Der Stick ist ein cc2531 mit dieser Firmware: github.com/Koenkk/Z-Stack-firmware/tree/master/coordinator/Z-Stack_Home_1.2/bin/default/cc2531_default_20190608.hex
                Beim Bewegungssensor wird mir das hier angezeigt:
                Den smart plug konnte ich pairen. Wird als tuya angezeigt.
                  Jan1 last edited by
                  Noch mal zum Danalock V3. Könnte hier einer der das hat mal die DPs posten, welche zu erwarten sind und wenn ich in der APP in den Einstellungen auf Smarthome klicke, habe ich hier ein Z-Wave Symbol zum verbinden, sollte da nicht Zigbee stehen?
                  Das Danalock war wohl schon mal geöffnet, könnte als was anderes im Karton gewesen sein, als drauf steht. Auf dem Karton steht zumindest mal Zigbee. Alternativ, wie kann ich sicher raus finden was ich für ein Schloss habe?
                  • Asgothian
                    Asgothian Developer @Jan1 last edited by
                    @Jan1
                    Das Sieht alles erst einmal gut aus. Die Steuerung des Locks geht über den Datenpunkt lockState:
                    • locked bedeutet das das Schloss den Zustand "verschlossen" gemeldet hat
                    • unlocked bedeutet das das Schloss den Zustand "unverschlossen" gemeldet hat
                    • lock eintragen bewirkt das das Schloss den Befehl zum Abschliessen bekommt, und dessen Ausführung durch "locked" bestätigt.
                    • unlock eintragen bewirkt das das Schloss den Befehl zum aufschliessen bekommt und dessen Ausführung durch "unlocked" bestätigt
                    wenn bereits "unlocked" eingetragen ist, und der Befehl "unlock" abgesetzt wird sollte das Schloss die Falle für 1 bis 3 Sekunden zurück ziehen.
                    Bitte teste das und poste das Log vom Test.
                    A.
                      Jan1 @Asgothian last edited by Jan1
                      @Asgothian
                      Mein Held, ich hatte den Error40 (Problem sitzt 40cm vor dem Bildschirm) und hatte erwartet, dass hier noch ein DP erscheint, der speziell zum Steuern ausgewiesen ist. Hatte mich aber auch gewundert, dass der genannte DP beschreibbar ist, nur wenn man Blödsinn rein schreibt, passiert eben nix außer Fehler im Log.
                      Somit Danalock mit Zigbee Adapter abgehakt, es funktioniert wie es soll 😉
                      und hier noch das Log dazu:
                      zigbee.0	2020-11-29 10:49:42.833	debug	(119354) Publish {"state":"LOCK","lock_state":"locked"}
                      zigbee.0	2020-11-29 10:49:42.832	debug	(119354) Publish {"action":"lock","action_user":65535,"action_source":1,"action_source_name":"rf"}
                      zigbee.0	2020-11-29 10:49:42.824	debug	(119354) Type attributeReport device {"type":"device","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":57858,"_manufacturerID":4444,"_endpoints":[{"ID":1,"prof
                      zigbee.0	2020-11-29 10:49:42.823	debug	(119354) Received Zigbee message from '0x000b57fffe59d1f6', type 'attributeReport', cluster 'closuresDoorLock', data '{"lockState":1}' from endpoint 1 with groupID 0
                      zigbee.0	2020-11-29 10:49:42.816	debug	(119354) handleMessage. {"type":"attributeReport","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":57858,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileI
                      zigbee.0	2020-11-29 10:49:42.812	debug	(119354) Type commandOperationEventNotification device {"type":"device","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":57858,"_manufacturerID":4444,"_endpoin
                      zigbee.0	2020-11-29 10:49:42.809	debug	(119354) Received Zigbee message from '0x000b57fffe59d1f6', type 'commandOperationEventNotification', cluster 'closuresDoorLock', data '{"opereventsrc":1,"opereventcode":1,"userid":65535,"pin":0,"zig
                      zigbee.0	2020-11-29 10:49:42.804	debug	(119354) handleMessage. {"type":"commandOperationEventNotification","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":57858,"_manufacturerID":4444,"_endpoints":
                      zigbee.0	2020-11-29 10:49:38.809	debug	(119354) convert result {"readAfterWriteTime":200}
                      zigbee.0	2020-11-29 10:49:35.757	debug	(119354) Publish {"occupancy":true}
                      zigbee.0	2020-11-29 10:49:35.751	debug	(119354) Publish {"illuminance":43,"illuminance_lux":43}
                      zigbee.0	2020-11-29 10:49:35.745	debug	(119354) Type attributeReport device {"type":"device","device":{"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d00030a3270","_networkAddress":28017,"_manufacturerID":4151,"_endpoints":[{"ID":1,"input
                      zigbee.0	2020-11-29 10:49:35.744	debug	(119354) Received Zigbee message from '0x00158d00030a3270', type 'attributeReport', cluster 'msOccupancySensing', data '{"occupancy":1}' from endpoint 1 with groupID 0
                      zigbee.0	2020-11-29 10:49:35.744	debug	(119354) handleMessage. {"type":"attributeReport","device":{"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d00030a3270","_networkAddress":28017,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClus
                      zigbee.0	2020-11-29 10:49:35.739	debug	(119354) Type attributeReport device {"type":"device","device":{"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d00030a3270","_networkAddress":28017,"_manufacturerID":4151,"_endpoints":[{"ID":1,"input
                      zigbee.0	2020-11-29 10:49:35.738	debug	(119354) Received Zigbee message from '0x00158d00030a3270', type 'attributeReport', cluster 'msIlluminanceMeasurement', data '{"measuredValue":43}' from endpoint 1 with groupID 0
                      zigbee.0	2020-11-29 10:49:35.737	debug	(119354) handleMessage. {"type":"attributeReport","device":{"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d00030a3270","_networkAddress":28017,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClus
                      zigbee.0	2020-11-29 10:49:34.303	debug	(119354) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":57858,"deviceIeeeAddress":"0x000b57fffe59d1f6","clust
                      zigbee.0	2020-11-29 10:49:34.302	debug	(119354) convert state, lock, {}
                      zigbee.0	2020-11-29 10:49:34.302	debug	(119354) Mapped Model: {"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResp
                      zigbee.0	2020-11-29 10:49:34.301	debug	(119354) entity: {"type":"device","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":57858,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID
                      zigbee.0	2020-11-29 10:49:34.300	debug	(119354) State changes. dev: 0x000b57fffe59d1f6 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"val
                      zigbee.0	2020-11-29 10:49:34.299	debug	(119354) Change state 'lockState' at device 0x000b57fffe59d1f6 type 'V3-BTZB'
                      zigbee.0	2020-11-29 10:49:34.293	debug	(119354) User stateChange zigbee.0.000b57fffe59d1f6.lockState {"val":"lock","ack":false,"ts":1606643374288,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1606643374288}
                      zigbee.0	2020-11-29 10:49:24.000	debug	(119354) Publish {"temperature":22.38,"humidity":51.93}
                      zigbee.0	2020-11-29 10:49:23.999	debug	(119354) Publish {"voltage":2745,"battery":19}
                        Slyer_CH @DK43 last edited by
                        Hallo
                        Ich habe auch eine Anfrage bezüglich einem Smartgerät von Silvercrest (Lidl) und zwar der Steckerleiste HG06338-XX. Bei mir in der CH Version 😊 .
                        Bild Text
                        Habe es mit dem Conbee2 Stick gemacht.
                        Die Steckerleiste wird mit der Adapterversion 1.3.1 als TS011F bezeichnet. Dort hat man aber nur einen Datenpunkt zum ein und ausschalten obwohl drei schaltbare Dosen verbaut sind. Konnte aber alle drei dosen einzeln über die Entwickler Konsole steuern.
                            "devId": "zigbee.0.680ae2fffe72f0c9",
                            "ep": "1",
                            "cid": "genOnOff",
                            "cmd": "on",
                            "cmdType": "functional",
                            "zclData": {
                                "onOff": {}
                            "cfg": null
                        Mit Adapter Version 1.3.1
                        Mit der Adapter Version 1.3.9dev habe ich die Steckerleiste nochmals neu angelernt nun kommt sie als unbekanntes gerät.
                        Wäre cool wenn die Steckerleiste auch in die Datenbank der Geräte aufgenommen wird.
                        Auf GitHub gibt es auch eine anfrage für den deconz adapter falls diese Infos hilfreicher wären.
                        https://github.com/dresden-elektronik/deconz-rest-plugin/issues/3612
                        skynetforcats created this issue in dresden-elektronik/deconz-rest-plugin
                        closed [Device Support Request] Lidl 3 way SilverCrest Smart USB Extension Lead TY-HG06338-DK (Tuya TS011F) #3612
                        Z 1 Reply Last reply Reply Quote 1
                        • Z
                          zecki79 @Slyer_CH last edited by zecki79
                          Habe mir heute auch die SilverCrest (Lidl) Smart Plug HG06337(1-fach) und HG06338 (3-fach) besorgt.
                          Mein Zigbee-Adapter ist auf Version 1.3.9 Dev.
                          Der 1-fach Plug wird mit dem richtigen Namen erkannt, ich kann über state auch ein und aus schalten. Jedoch ändert sich der state nicht, wenn direkt am Smart-Plug geschalten wird.
                          der 3-fach Plug wird auch mit dem richtigen Namen erkannt, jedoch funktioniert das ein- ausschalten über state gar nicht (Fehlermeldung im log wenn der state geändert wird :(5029) No converter available for 'HG06338' with key 'state_l1') , aber wenn ich am Plug direkt schalte, wird der state im io broker richtig angezeigt.
                          Bitte um Hilfe!
                          Herzlichen Dank!
                          lg
                          D 1Topf 2 Replies Last reply Reply Quote 0
                            DocGame @zecki79 last edited by
                            Wäre es möglich diese Taster auch aufzunehmen?
                            Tuya TS0044
                            Vielen Dank im Voraus.....
                              ljmarkus last edited by
                              TS0502A -> Lidl LED-Leuchtpanel LIVARNOLUX
                              Adapter: Zigbee 1.3.1
                              (21040) Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20190608}}
                              2020_12_03_10_17_17_Lidl_Aktueller_Prospekt_03.12_16.12.2020_3_jedewoche_rabatte.de.png
                                Merschi last edited by
                                kann nachfolgendes Gerät mit aufgenommen werden?
                                https://www.revolt-power.de/Weltweit-steuerbares-Heizkoerper-Design-Thermostat-NX-4914-919.shtml
                                Ich habe festgestellt, das wohl Baugleich mit dem GS361A-H04 ist.
                                Aktuell passe ich bei Updates die 2 devices.js händisch an.
                                In der /opt/iobroker/node_modules/iobroker.zigbee/lib/devices.js mache ich ne Kopie des GS361A-H04.
                                In der /opt/iobroker/node_modules/zigbee-herdsman-converters/devices.js passe ich nach einer Kopie folgendes an:
                                // Revolt Thermostate
                                    zigbeeModel: ['fvq6avy'],
                                    fingerprint: [{modelID: 'fvq6avy\u0000', manufacturerName: '_TYST11_kfvq6avy'}],
                                    model: 'GS361A-H04',
                                    vendor: 'Revolt',
                                Damit funktionieren die bei mir bis jetzt ganz gut.
                                  leon last edited by
                                  Ich hätte da auch noch ein Gerät von Lidl.
                                  TS0505A - Livarno Lux LED Strip 22W 2m
                                  D H 2 Replies Last reply Reply Quote 0
                                    DocGame @leon last edited by
                                    Hier nochmals ein Gerät (War auch bei Lidl 😊 )
                                    Mitlerweile habe ich schon wieder einige "Leichen" angemeldet. Hoffe Ihr hackt mal wieder einige rein.
                                    Silvercrest HG06467
                                      helpingman @leon last edited by
                                      @leon Den TS0505A kannst du mit
                                          // LED Stripe Lidl
                                              models: ['TS0505A'],
                                              icon: 'img/innr_flex_FL130C.png',
                                              states: lightStatesWithColor,
                                              syncStates: [sync.brightness],
                                      in der devices.js ans laufen bringen.
                                      Wenn das Gerät mit aktualisiertem Converter dann HG06104A heißt dann so
                                          // LED Stripe Lidl
                                              models: ['HG06104A'],
                                      Gruß,
                                      Tom
                                      • 1Topf
                                        1Topf @zecki79 last edited by 1Topf
                                        @zecki79 Hi, hab genau wie Du 2 Dosen und den 3fach gekauft. Ich nutze einen CC2538. Die Teile liesen sich problemlos anlernen, wurden aber als Tuya TS011F angezeigt (auch grafisch), also auch der 3fach. Nach Adapterupdate von 1.3.1 auf 1.3.9 wird alles richtig angezeigt und auch das 3fach - Teil läßt sich nun richtig schalten (jede "Dose" getrennt), State wird korrekt erkannt, auch beim schalten direkt am Knopf. Keine Fehler, alles problemlos. Hier mal ein fettes Lob an denjenigen, der das hinbekommen hat. Super!! 👌
                                        Andi
                                          Tim12 @1Topf last edited by
                                          Würde mich freuen, wenn die Fernbedienung Schwaiger ZHF02 mit aufgenommen werden könnte:
                                          e01418ef-ce7d-4edb-9628-7dc6e492eedd-grafik.png f3a96e16-28ff-4b99-a378-4bbc053d159f-grafik.png 649771b3-1bae-4397-aaff-82b741ae1b88-grafik.png https://www.schwaiger.de/de/funkfernbedienung.html
                                            stefande @arteck last edited by
                                            Bei der Silvercrest (Lidl) Fernbedienung ist ein Tippfehler im herdmans-converter.
                                            Hier müsste brightenss_step_up durch brightness_step_up ersetzt werden.
                                                        fingerprint: [{modelID: 'TS1001', manufacturerName: '_TYZB01_bngwdjsr'}],
                                                        model: 'FB20-002',
                                                        vendor: 'Lidl',
                                                        description: 'Livarno Lux switch and dimming light remote control',
                                                        exposes: [e.action([
                                                            'on', 'off', 'brightness_stop', 'brightenss_step_up', 'brightness_step_down', 'brightness_move_up',
                                                            'brightness_move_down',
                                                        fromZigbee: [fz.command_on, fz.command_off, fz.command_step, fz.command_move, fz.command_stop],
                                                        toZigbee: [],
                                            converter herdsman neuer adapter zigbee
                                            50
                                            231
                                            35996
