    3. Entwicklung
    4. ZigBee neue/unbekannte Geräte - ab 1.3.0
    • Asgothian
      Asgothian Developer @Jan1 last edited by
      @Jan1 bitte poste mal die kompletten Zeilen, nicht nur den Teil den der Admin anzeigt.
      A.
        Spucki @Spucki last edited by
        Habe soebend die 1.3.9dev instralliert, da ist er drin :---)))))
          Jan1 @Asgothian last edited by Jan1
          @Asgothian
          wollte ich gerade tun, da mir das auch etwas abgeschnitten vorkam 🙂
          2020-11-28 14:05:39.396 - info: node-red.0 (439695) starting. Version 2.0.1 in /opt/iobroker/node_modules/iobroker.node-red, node: v14.15.1, js-controller: 3.1.6
          2020-11-28 14:05:39.938 - info: node-red.0 (439695) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
          2020-11-28 14:05:44.141 - warn: node-red.0 (439695) 28 Nov 14:05:44 - [warn] Projekte inaktiviert: editorTheme.projects.enabled=false
          2020-11-28 14:05:47.951 - info: host.Beelink stopInstance system.adapter.zigbee.0 (force=false, process=true)
          2020-11-28 14:05:47.952 - info: host.Beelink stopInstance system.adapter.zigbee.0 send kill signal
          2020-11-28 14:05:47.955 - info: zigbee.0 (400768) Got terminate signal TERMINATE_YOURSELF
          2020-11-28 14:05:47.957 - info: zigbee.0 (400768) cleaned everything up...
          2020-11-28 14:05:47.958 - info: zigbee.0 (400768) Zigbee: disabling joining new devices.
          2020-11-28 14:05:48.367 - info: zigbee.0 (400768) terminating
          2020-11-28 14:05:48.369 - info: zigbee.0 (400768) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2020-11-28 14:05:48.897 - info: host.Beelink instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2020-11-28 14:05:50.982 - info: host.Beelink instance system.adapter.zigbee.0 started with pid 440024
          2020-11-28 14:05:52.092 - debug: zigbee.0 (440024) Redis Objects: Use Redis connection: 127.0.0.1:9001
          2020-11-28 14:05:52.123 - debug: zigbee.0 (440024) Objects client ready ... initialize now
          2020-11-28 14:05:52.127 - debug: zigbee.0 (440024) Objects create System PubSub Client
          2020-11-28 14:05:52.128 - debug: zigbee.0 (440024) Objects create User PubSub Client
          2020-11-28 14:05:52.129 - debug: zigbee.0 (440024) Objects client initialize lua scripts
          2020-11-28 14:05:52.147 - debug: zigbee.0 (440024) Objects connected to redis: 127.0.0.1:9001
          2020-11-28 14:05:52.152 - debug: zigbee.0 (440024) objectDB connected
          2020-11-28 14:05:52.155 - debug: zigbee.0 (440024) Redis States: Use Redis connection: 127.0.0.1:9000
          2020-11-28 14:05:52.164 - debug: zigbee.0 (440024) States create User PubSub Client
          2020-11-28 14:05:52.167 - debug: zigbee.0 (440024) States create System PubSub Client
          2020-11-28 14:05:52.181 - debug: zigbee.0 (440024) States connected to redis: 127.0.0.1:9000
          2020-11-28 14:05:52.182 - debug: zigbee.0 (440024) statesDB connected
          2020-11-28 14:05:52.790 - info: zigbee.0 (440024) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.15.1, js-controller: 3.1.6
          2020-11-28 14:05:52.822 - debug: zigbee.0 (440024) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[16],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-Texas_Instruments_XDS110__02.03.00.18__Embed_with_CMSIS-DAP_L4300169-if00","adapter":"zstack"}}
          2020-11-28 14:05:52.877 - info: zigbee.0 (440024) Starting Zigbee npm ...
          2020-11-28 14:05:52.879 - debug: zigbee.0 (440024) Starting zigbee-herdsman...
          2020-11-28 14:05:53.013 - info: zigbee.0 (440024) Installed Version: https://github.com/ioBroker/ioBroker.zigbee/commit/master
          2020-11-28 14:05:53.070 - debug: zigbee.0 (440024) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2020_11_28-14_05_52.tar.gz success
          2020-11-28 14:05:55.079 - debug: zigbee.0 (440024) zigbee-herdsman started
          2020-11-28 14:05:55.081 - info: zigbee.0 (440024) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20200417}}
          2020-11-28 14:05:55.088 - debug: zigbee.0 (440024) Zigbee network parameters: {"panID":6754,"extendedPanID":"0xdddddddddddddddd","channel":16}
          2020-11-28 14:05:55.089 - info: zigbee.0 (440024) Unable to disable LED, unsupported function.
          2020-11-28 14:05:55.090 - info: zigbee.0 (440024) --> transmitPower : normal
          2020-11-28 14:05:55.098 - info: zigbee.0 (440024) Currently 14 devices are joined:
          2020-11-28 14:05:55.099 - debug: zigbee.0 (440024) Publish available for 0x00158d000208dc76 = true
          2020-11-28 14:05:55.101 - debug: zigbee.0 (440024) Publish available for 0x00158d00023ce458 = true
          2020-11-28 14:05:55.101 - debug: zigbee.0 (440024) Publish available for 0x00158d000249a9a8 = true
          2020-11-28 14:05:55.102 - debug: zigbee.0 (440024) Publish available for 0x00158d00025562c5 = true
          2020-11-28 14:05:55.102 - debug: zigbee.0 (440024) Publish available for 0x00158d0002fd3f30 = true
          2020-11-28 14:05:55.103 - debug: zigbee.0 (440024) Publish available for 0x00158d0003667aba = true
          2020-11-28 14:05:55.103 - debug: zigbee.0 (440024) Publish available for 0x00158d0002ea07ac = true
          2020-11-28 14:05:55.103 - debug: zigbee.0 (440024) Publish available for 0x00158d00030a3270 = true
          2020-11-28 14:05:55.104 - debug: zigbee.0 (440024) Publish available for 0x00158d00032c1109 = true
          2020-11-28 14:05:55.104 - debug: zigbee.0 (440024) Publish available for 0xccccccfffee04e28 = true
          2020-11-28 14:05:55.105 - debug: zigbee.0 (440024) Publish available for 0xec1bbdfffe9734c2 = true
          2020-11-28 14:05:55.105 - debug: zigbee.0 (440024) Publish available for 0xec1bbdfffe972471 = true
          2020-11-28 14:05:55.105 - debug: zigbee.0 (440024) Publish available for 0xec1bbdfffeb45b50 = true
          2020-11-28 14:05:55.106 - debug: zigbee.0 (440024) Publish available for 0x000b57fffe59d1f6 = true
          2020-11-28 14:05:55.106 - debug: zigbee.0 (440024) DeviceConfigure 0x00158d000208dc76 lumi.sensor_ht not needed
          2020-11-28 14:05:55.107 - debug: zigbee.0 (440024) DeviceConfigure 0x00158d00023ce458 lumi.sensor_ht not needed
          2020-11-28 14:05:55.107 - debug: zigbee.0 (440024) DeviceConfigure 0x00158d000249a9a8 lumi.sensor_ht not needed
          2020-11-28 14:05:55.107 - debug: zigbee.0 (440024) DeviceConfigure 0x00158d00025562c5 lumi.sensor_ht not needed
          2020-11-28 14:05:55.108 - debug: zigbee.0 (440024) DeviceConfigure 0x00158d0002fd3f30 lumi.sensor_motion.aq2 not needed
          2020-11-28 14:05:55.108 - debug: zigbee.0 (440024) DeviceConfigure 0x00158d0003667aba lumi.sensor_motion.aq2 not needed
          2020-11-28 14:05:55.108 - debug: zigbee.0 (440024) DeviceConfigure 0x00158d0002ea07ac lumi.sensor_motion.aq2 not needed
          2020-11-28 14:05:55.109 - debug: zigbee.0 (440024) DeviceConfigure 0x00158d00030a3270 lumi.sensor_motion.aq2 not needed
          2020-11-28 14:05:55.109 - debug: zigbee.0 (440024) DeviceConfigure 0x00158d00032c1109 lumi.sensor_motion.aq2 not needed
          2020-11-28 14:05:55.109 - debug: zigbee.0 (440024) DeviceConfigure 0xccccccfffee04e28 TRADFRI on/off switch not needed
          2020-11-28 14:05:55.109 - debug: zigbee.0 (440024) DeviceConfigure 0xec1bbdfffe9734c2 TRADFRI on/off switch not needed
          2020-11-28 14:05:55.110 - debug: zigbee.0 (440024) DeviceConfigure 0xec1bbdfffe972471 TRADFRI on/off switch not needed
          2020-11-28 14:05:55.110 - debug: zigbee.0 (440024) DeviceConfigure 0xec1bbdfffeb45b50 TRADFRI on/off switch not needed
          2020-11-28 14:05:55.110 - debug: zigbee.0 (440024) DeviceConfigure 0x000b57fffe59d1f6 V3-BTZB forced by adapter config
          2020-11-28 14:05:55.111 - debug: zigbee.0 (440024) DeviceConfigure 0x000b57fffe59d1f6 V3-BTZB needed
          2020-11-28 14:05:55.111 - info: zigbee.0 (440024) Configuring 0x000b57fffe59d1f6 V3-BTZB
          2020-11-28 14:05:55.117 - debug: zigbee.0 (440024) New device event: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x00158d000208dc76","_networkAddress":53206,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":24321,"inputClusters":[0,3,25,65535,18],"outputClusters":[0,4,3,5,25,65535,18],"deviceNetworkAddress":53206,"deviceIeeeAddress":"0x00158d000208dc76","clusters":{"genBasic":{"attributes":{"65281":{"1":2975,"4":17320,"5":147,"6":[0,1],"10":0,"100":2171,"101":5366},"modelId":"lumi.sensor_ht","manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":30,"dateCode":"20160516","swBuildId":"3000-0001"}},"msTemperatureMeasurement":{"attributes":{"measuredValue":2165}},"msRelativeHumidity":{"attributes":{"measuredValue":5408}}},"_binds":[],"meta":{}},{"ID":2,"profileID":260,"deviceID":24322,"inputClusters":[3,18],"outputClusters":[4,3,5,18],"deviceNetworkAddress":53206,"deviceIeeeAddress":"0x00158d000208dc76","clusters":{},"_binds":[],"meta":{}},{"ID":3,"profileID":260,"deviceID":24323,"inputClusters":[3,12],"outputClusters":[4,3,5,12],"deviceNetworkAddress":53206,"deviceIeeeAddress":"0x00158d000208dc76","clusters":{},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_ht","_applicationVersion":2,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":30,"_dateCode":"20160516","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1606567912397},"mapped":{"zigbeeModel":["lumi.sens","lumi.sensor_ht"],"model":"WSDCGQ01LM","vendor":"Xiaomi","description":"MiJia temperature & humidity sensor","supports":"temperature and humidity","meta":{"battery":{"voltageToPercentage":"3V_2100"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msRelativeHumidity","type":["attributeReport","readResponse"]}],"toZigbee":[],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"numeric","name":"temperature","property":"temperature","access":1,"unit":"°C","description":"Measured temperature value"},{"type":"numeric","name":"humidity","property":"humidity","access":1,"unit":"%","description":"Measured relative humidity"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x00158d000208dc76"}
          2020-11-28 14:05:55.119 - info: zigbee.0 (440024) 0x00158d000208dc76 (addr 53206): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (EndDevice)
          2020-11-28 14:05:55.130 - debug: zigbee.0 (440024) New device event: {"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d00023ce458","_networkAddress":35825,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":24321,"inputClusters":[0,3,25,65535,18],"outputClusters":[0,4,3,5,25,65535,18],"deviceNetworkAddress":35825,"deviceIeeeAddress":"0x00158d00023ce458","clusters":{"genBasic":{"attributes":{"65281":{"1":2785,"4":5032,"5":177,"6":[0,2],"10":0,"100":1966,"101":5763},"modelId":"lumi.sensor_ht","manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":30,"dateCode":"20160516","swBuildId":"3000-0001"}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1966}},"msRelativeHumidity":{"attributes":{"measuredValue":5742}}},"_binds":[],"meta":{}},{"ID":2,"profileID":260,"deviceID":24322,"inputClusters":[3,18],"outputClusters":[4,3,5,18],"deviceNetworkAddress":35825,"deviceIeeeAddress":"0x00158d00023ce458","clusters":{},"_binds":[],"meta":{}},{"ID":3,"profileID":260,"deviceID":24323,"inputClusters":[3,12],"outputClusters":[4,3,5,12],"deviceNetworkAddress":35825,"deviceIeeeAddress":"0x00158d00023ce458","clusters":{},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_ht","_applicationVersion":2,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":30,"_dateCode":"20160516","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1606567158897},"mapped":{"zigbeeModel":["lumi.sens","lumi.sensor_ht"],"model":"WSDCGQ01LM","vendor":"Xiaomi","description":"MiJia temperature & humidity sensor","supports":"temperature and humidity","meta":{"battery":{"voltageToPercentage":"3V_2100"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msRelativeHumidity","type":["attributeReport","readResponse"]}],"toZigbee":[],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"numeric","name":"temperature","property":"temperature","access":1,"unit":"°C","description":"Measured temperature value"},{"type":"numeric","name":"humidity","property":"humidity","access":1,"unit":"%","description":"Measured relative humidity"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x00158d00023ce458"}
          2020-11-28 14:05:55.131 - info: zigbee.0 (440024) 0x00158d00023ce458 (addr 35825): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (EndDevice)
          2020-11-28 14:05:55.132 - debug: zigbee.0 (440024) New device event: {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d000249a9a8","_networkAddress":56408,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":24321,"inputClusters":[0,3,25,65535,18],"outputClusters":[0,4,3,5,25,65535,18],"deviceNetworkAddress":56408,"deviceIeeeAddress":"0x00158d000249a9a8","clusters":{"genBasic":{"attributes":{"65281":{"1":2815,"4":5032,"5":16,"6":[0,2],"10":0,"100":1820,"101":5317},"modelId":"lumi.sensor_ht","manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":30,"dateCode":"20160516","swBuildId":"3000-0001"}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1843}},"msRelativeHumidity":{"attributes":{"measuredValue":5308}}},"_binds":[],"meta":{}},{"ID":2,"profileID":260,"deviceID":24322,"inputClusters":[3,18],"outputClusters":[4,3,5,18],"deviceNetworkAddress":56408,"deviceIeeeAddress":"0x00158d000249a9a8","clusters":{},"_binds":[],"meta":{}},{"ID":3,"profileID":260,"deviceID":24323,"inputClusters":[3,12],"outputClusters":[4,3,5,12],"deviceNetworkAddress":56408,"deviceIeeeAddress":"0x00158d000249a9a8","clusters":{},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_ht","_applicationVersion":2,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":30,"_dateCode":"20160516","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1606568145941},"mapped":{"zigbeeModel":["lumi.sens","lumi.sensor_ht"],"model":"WSDCGQ01LM","vendor":"Xiaomi","description":"MiJia temperature & humidity sensor","supports":"temperature and humidity","meta":{"battery":{"voltageToPercentage":"3V_2100"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msRelativeHumidity","type":["attributeReport","readResponse"]}],"toZigbee":[],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"numeric","name":"temperature","property":"temperature","access":1,"unit":"°C","description":"Measured temperature value"},{"type":"numeric","name":"humidity","property":"humidity","access":1,"unit":"%","description":"Measured relative humidity"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x00158d000249a9a8"}
          2020-11-28 14:05:55.133 - info: zigbee.0 (440024) 0x00158d000249a9a8 (addr 56408): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (EndDevice)
          2020-11-28 14:05:55.134 - debug: zigbee.0 (440024) New device event: {"type":"device","device":{"ID":5,"_type":"EndDevice","_ieeeAddr":"0x00158d00025562c5","_networkAddress":15287,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":24321,"inputClusters":[0,3,25,65535,18],"outputClusters":[0,4,3,5,25,65535,18],"deviceNetworkAddress":15287,"deviceIeeeAddress":"0x00158d00025562c5","clusters":{"genBasic":{"attributes":{"65281":{"1":2795,"4":5032,"5":23,"6":[0,1],"10":0,"100":2318,"101":4742},"modelId":"lumi.sensor_ht","manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":30,"dateCode":"20160516","swBuildId":"3000-0001"}},"msTemperatureMeasurement":{"attributes":{"measuredValue":2318}},"msRelativeHumidity":{"attributes":{"measuredValue":4793}}},"_binds":[],"meta":{}},{"ID":2,"profileID":260,"deviceID":24322,"inputClusters":[3,18],"outputClusters":[4,3,5,18],"deviceNetworkAddress":15287,"deviceIeeeAddress":"0x00158d00025562c5","clusters":{},"_binds":[],"meta":{}},{"ID":3,"profileID":260,"deviceID":24323,"inputClusters":[3,12],"outputClusters":[4,3,5,12],"deviceNetworkAddress":15287,"deviceIeeeAddress":"0x00158d00025562c5","clusters":{},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_ht","_applicationVersion":2,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":30,"_dateCode":"20160516","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1606566216148},"mapped":{"zigbeeModel":["lumi.sens","lumi.sensor_ht"],"model":"WSDCGQ01LM","vendor":"Xiaomi","description":"MiJia temperature & humidity sensor","supports":"temperature and humidity","meta":{"battery":{"voltageToPercentage":"3V_2100"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msRelativeHumidity","type":["attributeReport","readResponse"]}],"toZigbee":[],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"numeric","name":"temperature","property":"temperature","access":1,"unit":"°C","description":"Measured temperature value"},{"type":"numeric","name":"humidity","property":"humidity","access":1,"unit":"%","description":"Measured relative humidity"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x00158d00025562c5"}
          2020-11-28 14:05:55.135 - info: zigbee.0 (440024) 0x00158d00025562c5 (addr 15287): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (EndDevice)
          2020-11-28 14:05:55.136 - debug: zigbee.0 (440024) New device event: {"type":"device","device":{"ID":6,"_type":"EndDevice","_ieeeAddr":"0x00158d0002fd3f30","_networkAddress":15057,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":15057,"deviceIeeeAddress":"0x00158d0002fd3f30","clusters":{"genBasic":{"attributes":{"65281":{"1":3025,"3":30,"4":17320,"5":26,"6":[0,1],"10":0,"11":100,"100":0},"modelId":"lumi.sensor_motion.aq2","manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":1,"dateCode":"20170627","swBuildId":"3000-0001"}},"ssIasZone":{"attributes":{}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":116}},"msOccupancySensing":{"attributes":{"occupancy":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20170627","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1606568277689},"mapped":{"zigbeeModel":["lumi.sensor_motion.aq2"],"model":"RTCGQ11LM","vendor":"Xiaomi","description":"Aqara human body movement and illuminance sensor","supports":"occupancy and illuminance","meta":{"battery":{"voltageToPercentage":"3V_2100"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"binary","name":"occupancy","property":"occupancy","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected occupancy"},{"type":"numeric","name":"illuminance","property":"illuminance","access":1,"description":"Raw measured illuminance","unit":"lx"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x00158d0002fd3f30"}
          2020-11-28 14:05:55.138 - info: zigbee.0 (440024) 0x00158d0002fd3f30 (addr 15057): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
          2020-11-28 14:05:55.139 - debug: zigbee.0 (440024) New device event: {"type":"device","device":{"ID":7,"_type":"EndDevice","_ieeeAddr":"0x00158d0003667aba","_networkAddress":50038,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":50038,"deviceIeeeAddress":"0x00158d0003667aba","clusters":{"genBasic":{"attributes":{"65281":{"1":3025,"3":18,"4":17320,"5":28,"6":[0,1],"10":0,"11":20,"100":0},"modelId":"lumi.sensor_motion.aq2","manufacturerName":"LUMI","powerSource":3,"zclVersion":1}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":17}},"msOccupancySensing":{"attributes":{"occupancy":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_zclVersion":1,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1606567509213},"mapped":{"zigbeeModel":["lumi.sensor_motion.aq2"],"model":"RTCGQ11LM","vendor":"Xiaomi","description":"Aqara human body movement and illuminance sensor","supports":"occupancy and illuminance","meta":{"battery":{"voltageToPercentage":"3V_2100"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"binary","name":"occupancy","property":"occupancy","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected occupancy"},{"type":"numeric","name":"illuminance","property":"illuminance","access":1,"description":"Raw measured illuminance","unit":"lx"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x00158d0003667aba"}
          2020-11-28 14:05:55.140 - info: zigbee.0 (440024) 0x00158d0003667aba (addr 50038): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
          2020-11-28 14:05:55.141 - debug: zigbee.0 (440024) New device event: {"type":"device","device":{"ID":8,"_type":"EndDevice","_ieeeAddr":"0x00158d0002ea07ac","_networkAddress":64627,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":64627,"deviceIeeeAddress":"0x00158d0002ea07ac","clusters":{"genBasic":{"attributes":{"65281":{"1":3035,"3":24,"4":17320,"5":107,"6":[0,9],"10":0,"11":1,"100":0},"modelId":"lumi.sensor_motion.aq2","manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":1,"dateCode":"20170627","swBuildId":"3000-0001"}},"ssIasZone":{"attributes":{}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":0}},"msOccupancySensing":{"attributes":{"occupancy":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20170627","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1606568623522},"mapped":{"zigbeeModel":["lumi.sensor_motion.aq2"],"model":"RTCGQ11LM","vendor":"Xiaomi","description":"Aqara human body movement and illuminance sensor","supports":"occupancy and illuminance","meta":{"battery":{"voltageToPercentage":"3V_2100"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"binary","name":"occupancy","property":"occupancy","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected occupancy"},{"type":"numeric","name":"illuminance","property":"illuminance","access":1,"description":"Raw measured illuminance","unit":"lx"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x00158d0002ea07ac"}
          2020-11-28 14:05:55.142 - info: zigbee.0 (440024) 0x00158d0002ea07ac (addr 64627): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
          2020-11-28 14:05:55.143 - debug: zigbee.0 (440024) New device event: {"type":"device","device":{"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d00030a3270","_networkAddress":27111,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":27111,"deviceIeeeAddress":"0x00158d00030a3270","clusters":{"genBasic":{"attributes":{"65281":{"1":3005,"3":29,"4":17320,"5":23,"6":[0,28],"10":0,"11":72,"100":0},"modelId":"lumi.sensor_motion.aq2","manufacturerName":"LUMI","powerSource":3}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":64}},"msOccupancySensing":{"attributes":{"occupancy":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_interviewCompleted":false,"_interviewing":false,"meta":{},"_lastSeen":1606568629260},"mapped":{"zigbeeModel":["lumi.sensor_motion.aq2"],"model":"RTCGQ11LM","vendor":"Xiaomi","description":"Aqara human body movement and illuminance sensor","supports":"occupancy and illuminance","meta":{"battery":{"voltageToPercentage":"3V_2100"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"binary","name":"occupancy","property":"occupancy","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected occupancy"},{"type":"numeric","name":"illuminance","property":"illuminance","access":1,"description":"Raw measured illuminance","unit":"lx"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x00158d00030a3270"}
          2020-11-28 14:05:55.144 - info: zigbee.0 (440024) 0x00158d00030a3270 (addr 27111): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
          2020-11-28 14:05:55.145 - debug: zigbee.0 (440024) New device event: {"type":"device","device":{"ID":10,"_type":"EndDevice","_ieeeAddr":"0x00158d00032c1109","_networkAddress":40226,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":40226,"deviceIeeeAddress":"0x00158d00032c1109","clusters":{"genBasic":{"attributes":{"65281":{"1":3025,"3":23,"4":17320,"5":16,"6":[0,1],"10":0,"11":65,"100":0},"modelId":"lumi.sensor_motion.aq2","manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":1,"dateCode":"20170627","swBuildId":"3000-0001"}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":56}},"msOccupancySensing":{"attributes":{"occupancy":1}},"ssIasZone":{"attributes":{}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20170627","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1606568393630},"mapped":{"zigbeeModel":["lumi.sensor_motion.aq2"],"model":"RTCGQ11LM","vendor":"Xiaomi","description":"Aqara human body movement and illuminance sensor","supports":"occupancy and illuminance","meta":{"battery":{"voltageToPercentage":"3V_2100"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"binary","name":"occupancy","property":"occupancy","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected occupancy"},{"type":"numeric","name":"illuminance","property":"illuminance","access":1,"description":"Raw measured illuminance","unit":"lx"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x00158d00032c1109"}
          2020-11-28 14:05:55.146 - info: zigbee.0 (440024) 0x00158d00032c1109 (addr 40226): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
          2020-11-28 14:05:55.147 - debug: zigbee.0 (440024) New device event: {"type":"device","device":{"ID":14,"_type":"EndDevice","_ieeeAddr":"0xccccccfffee04e28","_networkAddress":6689,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"deviceID":2080,"inputClusters":[0,1,3,9,32,4096,64636],"outputClusters":[3,4,6,8,25,258,4096],"deviceNetworkAddress":6689,"deviceIeeeAddress":"0xccccccfffee04e28","clusters":{"genBasic":{"attributes":{"modelId":"TRADFRI on/off switch","manufacturerName":"IKEA of Sweden","powerSource":3,"zclVersion":3,"appVersion":34,"stackVersion":98,"hwVersion":1,"dateCode":"20190410","swBuildId":"2.2.008"}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":21}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"IKEA of Sweden","_powerSource":"Battery","_modelID":"TRADFRI on/off switch","_applicationVersion":34,"_stackVersion":98,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"20190410","_softwareBuildID":"2.2.008","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1606509742091},"mapped":{"zigbeeModel":["TRADFRI on/off switch"],"model":"E1743","vendor":"IKEA","description":"TRADFRI ON/OFF switch","supports":"on, off, brightness up/down/stop","fromZigbee":[{"cluster":"genOnOff","type":"commandOn"},{"cluster":"genOnOff","type":"commandOn"},{"cluster":"genOnOff","type":"commandOff"},{"cluster":"genOnOff","type":"commandOff"},{"cluster":"genLevelCtrl","type":["commandMove","commandMoveWithOnOff"]},{"cluster":"genLevelCtrl","type":"commandMoveWithOnOff"},{"cluster":"genLevelCtrl","type":"commandMove"},{"cluster":"genLevelCtrl","type":["commandStop","commandStopWithOnOff"]},{"cluster":"genLevelCtrl","type":"commandStopWithOnOff"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"enum","name":"action","property":"action","access":1,"values":["on","off","brightness_move_down","brightness_move_up","brightness_stop"],"description":"Triggered action (e.g. a button click)"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}],"toZigbee":[],"ota":{},"meta":{"configureKey":1,"disableActionGroup":true,"battery":{"dontDividePercentage":true}}},"name":"0xccccccfffee04e28"}
          2020-11-28 14:05:55.149 - info: zigbee.0 (440024) 0xccccccfffee04e28 (addr 6689): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
          2020-11-28 14:05:55.149 - debug: zigbee.0 (440024) New device event: {"type":"device","device":{"ID":15,"_type":"EndDevice","_ieeeAddr":"0xec1bbdfffe9734c2","_networkAddress":21546,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"deviceID":2080,"inputClusters":[0,1,3,9,32,4096,64636],"outputClusters":[3,4,6,8,25,258,4096],"deviceNetworkAddress":21546,"deviceIeeeAddress":"0xec1bbdfffe9734c2","clusters":{"genBasic":{"attributes":{"modelId":"TRADFRI on/off switch","manufacturerName":"IKEA of Sweden","powerSource":3,"zclVersion":3,"appVersion":34,"stackVersion":98,"hwVersion":1,"dateCode":"20190410","swBuildId":"2.2.008"}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":16}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"IKEA of Sweden","_powerSource":"Battery","_modelID":"TRADFRI on/off switch","_applicationVersion":34,"_stackVersion":98,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"20190410","_softwareBuildID":"2.2.008","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1604084119082},"mapped":{"zigbeeModel":["TRADFRI on/off switch"],"model":"E1743","vendor":"IKEA","description":"TRADFRI ON/OFF switch","supports":"on, off, brightness up/down/stop","fromZigbee":[{"cluster":"genOnOff","type":"commandOn"},{"cluster":"genOnOff","type":"commandOn"},{"cluster":"genOnOff","type":"commandOff"},{"cluster":"genOnOff","type":"commandOff"},{"cluster":"genLevelCtrl","type":["commandMove","commandMoveWithOnOff"]},{"cluster":"genLevelCtrl","type":"commandMoveWithOnOff"},{"cluster":"genLevelCtrl","type":"commandMove"},{"cluster":"genLevelCtrl","type":["commandStop","commandStopWithOnOff"]},{"cluster":"genLevelCtrl","type":"commandStopWithOnOff"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"enum","name":"action","property":"action","access":1,"values":["on","off","brightness_move_down","brightness_move_up","brightness_stop"],"description":"Triggered action (e.g. a button click)"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}],"toZigbee":[],"ota":{},"meta":{"configureKey":1,"disableActionGroup":true,"battery":{"dontDividePercentage":true}}},"name":"0xec1bbdfffe9734c2"}
          2020-11-28 14:05:55.151 - info: zigbee.0 (440024) 0xec1bbdfffe9734c2 (addr 21546): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
          2020-11-28 14:05:55.151 - debug: zigbee.0 (440024) New device event: {"type":"device","device":{"ID":16,"_type":"EndDevice","_ieeeAddr":"0xec1bbdfffe972471","_networkAddress":60529,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"deviceID":2080,"inputClusters":[0,1,3,9,32,4096,64636],"outputClusters":[3,4,6,8,25,258,4096],"deviceNetworkAddress":60529,"deviceIeeeAddress":"0xec1bbdfffe972471","clusters":{"genBasic":{"attributes":{"modelId":"TRADFRI on/off switch","manufacturerName":"IKEA of Sweden","powerSource":3,"zclVersion":3,"appVersion":34,"stackVersion":98,"hwVersion":1,"dateCode":"20190410","swBuildId":"2.2.008"}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":5}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"IKEA of Sweden","_powerSource":"Battery","_modelID":"TRADFRI on/off switch","_applicationVersion":34,"_stackVersion":98,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"20190410","_softwareBuildID":"2.2.008","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1606510533120},"mapped":{"zigbeeModel":["TRADFRI on/off switch"],"model":"E1743","vendor":"IKEA","description":"TRADFRI ON/OFF switch","supports":"on, off, brightness up/down/stop","fromZigbee":[{"cluster":"genOnOff","type":"commandOn"},{"cluster":"genOnOff","type":"commandOn"},{"cluster":"genOnOff","type":"commandOff"},{"cluster":"genOnOff","type":"commandOff"},{"cluster":"genLevelCtrl","type":["commandMove","commandMoveWithOnOff"]},{"cluster":"genLevelCtrl","type":"commandMoveWithOnOff"},{"cluster":"genLevelCtrl","type":"commandMove"},{"cluster":"genLevelCtrl","type":["commandStop","commandStopWithOnOff"]},{"cluster":"genLevelCtrl","type":"commandStopWithOnOff"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"enum","name":"action","property":"action","access":1,"values":["on","off","brightness_move_down","brightness_move_up","brightness_stop"],"description":"Triggered action (e.g. a button click)"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}],"toZigbee":[],"ota":{},"meta":{"configureKey":1,"disableActionGroup":true,"battery":{"dontDividePercentage":true}}},"name":"0xec1bbdfffe972471"}
          2020-11-28 14:05:55.153 - info: zigbee.0 (440024) 0xec1bbdfffe972471 (addr 60529): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
          2020-11-28 14:05:55.153 - debug: zigbee.0 (440024) New device event: {"type":"device","device":{"ID":20,"_type":"EndDevice","_ieeeAddr":"0xec1bbdfffeb45b50","_networkAddress":27434,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"deviceID":2080,"inputClusters":[0,1,3,9,32,4096,64636],"outputClusters":[3,4,6,8,25,258,4096],"deviceNetworkAddress":27434,"deviceIeeeAddress":"0xec1bbdfffeb45b50","clusters":{"genBasic":{"attributes":{"modelId":"TRADFRI on/off switch","manufacturerName":"IKEA of Sweden","powerSource":3,"zclVersion":3,"appVersion":34,"stackVersion":98,"hwVersion":1,"dateCode":"20190410","swBuildId":"2.2.008"}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":16}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"IKEA of Sweden","_powerSource":"Battery","_modelID":"TRADFRI on/off switch","_applicationVersion":34,"_stackVersion":98,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"20190410","_softwareBuildID":"2.2.008","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":1},"_lastSeen":1606561756278},"mapped":{"zigbeeModel":["TRADFRI on/off switch"],"model":"E1743","vendor":"IKEA","description":"TRADFRI ON/OFF switch","supports":"on, off, brightness up/down/stop","fromZigbee":[{"cluster":"genOnOff","type":"commandOn"},{"cluster":"genOnOff","type":"commandOn"},{"cluster":"genOnOff","type":"commandOff"},{"cluster":"genOnOff","type":"commandOff"},{"cluster":"genLevelCtrl","type":["commandMove","commandMoveWithOnOff"]},{"cluster":"genLevelCtrl","type":"commandMoveWithOnOff"},{"cluster":"genLevelCtrl","type":"commandMove"},{"cluster":"genLevelCtrl","type":["commandStop","commandStopWithOnOff"]},{"cluster":"genLevelCtrl","type":"commandStopWithOnOff"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"enum","name":"action","property":"action","access":1,"values":["on","off","brightness_move_down","brightness_move_up","brightness_stop"],"description":"Triggered action (e.g. a button click)"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}],"toZigbee":[],"ota":{},"meta":{"configureKey":1,"disableActionGroup":true,"battery":{"dontDividePercentage":true}}},"name":"0xec1bbdfffeb45b50"}
          2020-11-28 14:05:55.155 - info: zigbee.0 (440024) 0xec1bbdfffeb45b50 (addr 27434): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
          2020-11-28 14:05:55.156 - debug: zigbee.0 (440024) New device event: {"type":"device","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":55668,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":2}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":160}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":-1},"_lastSeen":1606568539553},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]}],"meta":{"configureKey":5},"exposes":[{"type":"lock","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"LOCK","value_off":"UNLOCK","description":"State of the lock"}]},{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x000b57fffe59d1f6"}
          2020-11-28 14:05:55.157 - info: zigbee.0 (440024) 0x000b57fffe59d1f6 (addr 55668): V3-BTZB - Danalock BT/ZB smartlock (EndDevice)
          2020-11-28 14:05:55.158 - info: zigbee.0 (440024) Zigbee started
          2020-11-28 14:05:56.117 - debug: zigbee.0 (440024) Publish available for 0x00158d000208dc76 = true
          2020-11-28 14:05:56.131 - debug: zigbee.0 (440024) Publish available for 0x00158d00023ce458 = true
          2020-11-28 14:05:56.132 - debug: zigbee.0 (440024) Publish available for 0x00158d000249a9a8 = true
          2020-11-28 14:05:56.134 - debug: zigbee.0 (440024) Publish available for 0x00158d00025562c5 = true
          2020-11-28 14:05:56.135 - debug: zigbee.0 (440024) Publish available for 0x00158d0002fd3f30 = true
          2020-11-28 14:05:56.138 - debug: zigbee.0 (440024) Publish available for 0x00158d0003667aba = true
          2020-11-28 14:05:56.142 - debug: zigbee.0 (440024) Publish available for 0x00158d0002ea07ac = true
          2020-11-28 14:05:56.145 - debug: zigbee.0 (440024) Publish available for 0x00158d00030a3270 = true
          2020-11-28 14:05:56.146 - debug: zigbee.0 (440024) Publish available for 0x00158d00032c1109 = true
          2020-11-28 14:05:56.150 - debug: zigbee.0 (440024) Publish available for 0xccccccfffee04e28 = true
          2020-11-28 14:05:56.151 - debug: zigbee.0 (440024) Publish available for 0xec1bbdfffe9734c2 = true
          2020-11-28 14:05:56.154 - debug: zigbee.0 (440024) Publish available for 0xec1bbdfffe972471 = true
          2020-11-28 14:05:56.156 - debug: zigbee.0 (440024) Publish available for 0xec1bbdfffeb45b50 = true
          2020-11-28 14:05:56.160 - debug: zigbee.0 (440024) Publish available for 0x000b57fffe59d1f6 = true
          2020-11-28 14:06:00.784 - info: zigbee.0 (440024) DeviceConfigure successful 0x000b57fffe59d1f6 V3-BTZB
          2020-11-28 14:06:03.284 - debug: zigbee.0 (440024) system.adapter.admin.0: logging true
          2020-11-28 14:06:58.101 - debug: zigbee.0 (440024) system.adapter.admin.0: logging false
          2020-11-28 14:07:28.846 - debug: zigbee.0 (440024) handleMessage. {"type":"attributeReport","device":{"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d00030a3270","_networkAddress":27111,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":27111,"deviceIeeeAddress":"0x00158d00030a3270","clusters":{"genBasic":{"attributes":{"65281":{"1":3005,"3":29,"4":17320,"5":23,"6":[0,28],"10":0,"11":72,"100":0},"modelId":"lumi.sensor_motion.aq2","manufacturerName":"LUMI","powerSource":3}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":60}},"msOccupancySensing":{"attributes":{"occupancy":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_interviewCompleted":false,"_interviewing":false,"meta":{},"_lastSeen":1606568848843,"_linkquality":81},"endpoint":"[Circular]","data":{"measuredValue":60},"linkquality":81,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":158,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
          2020-11-28 14:07:28.848 - debug: zigbee.0 (440024) Received Zigbee message from '0x00158d00030a3270', type 'attributeReport', cluster 'msIlluminanceMeasurement', data '{"measuredValue":60}' from endpoint 1 with groupID 0
          2020-11-28 14:07:28.849 - debug: zigbee.0 (440024) Type attributeReport device {"type":"device","device":{"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d00030a3270","_networkAddress":27111,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":27111,"deviceIeeeAddress":"0x00158d00030a3270","clusters":{"genBasic":{"attributes":{"65281":{"1":3005,"3":29,"4":17320,"5":23,"6":[0,28],"10":0,"11":72,"100":0},"modelId":"lumi.sensor_motion.aq2","manufacturerName":"LUMI","powerSource":3}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":60}},"msOccupancySensing":{"attributes":{"occupancy":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_interviewCompleted":false,"_interviewing":false,"meta":{},"_lastSeen":1606568848843,"_linkquality":81},"mapped":{"zigbeeModel":["lumi.sensor_motion.aq2"],"model":"RTCGQ11LM","vendor":"Xiaomi","description":"Aqara human body movement and illuminance sensor","supports":"occupancy and illuminance","meta":{"battery":{"voltageToPercentage":"3V_2100"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"binary","name":"occupancy","property":"occupancy","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected occupancy"},{"type":"numeric","name":"illuminance","property":"illuminance","access":1,"description":"Raw measured illuminance","unit":"lx"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x00158d00030a3270"} incoming event: {"type":"attributeReport","device":{"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d00030a3270","_networkAddress":27111,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":27111,"deviceIeeeAddress":"0x00158d00030a3270","clusters":{"genBasic":{"attributes":{"65281":{"1":3005,"3":29,"4":17320,"5":23,"6":[0,28],"10":0,"11":72,"100":0},"modelId":"lumi.sensor_motion.aq2","manufacturerName":"LUMI","powerSource":3}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":60}},"msOccupancySensing":{"attributes":{"occupancy":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_interviewCompleted":false,"_interviewing":false,"meta":{},"_lastSeen":1606568848843,"_linkquality":81},"endpoint":"[Circular]","data":{"measuredValue":60},"linkquality":81,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":158,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
          2020-11-28 14:07:28.854 - debug: zigbee.0 (440024) handleMessage. {"type":"attributeReport","device":{"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d00030a3270","_networkAddress":27111,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":27111,"deviceIeeeAddress":"0x00158d00030a3270","clusters":{"genBasic":{"attributes":{"65281":{"1":3005,"3":29,"4":17320,"5":23,"6":[0,28],"10":0,"11":72,"100":0},"modelId":"lumi.sensor_motion.aq2","manufacturerName":"LUMI","powerSource":3}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":60}},"msOccupancySensing":{"attributes":{"occupancy":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_interviewCompleted":false,"_interviewing":false,"meta":{},"_lastSeen":1606568848854,"_linkquality":90},"endpoint":"[Circular]","data":{"occupancy":1},"linkquality":90,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":159,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
          2020-11-28 14:07:28.855 - debug: zigbee.0 (440024) Received Zigbee message from '0x00158d00030a3270', type 'attributeReport', cluster 'msOccupancySensing', data '{"occupancy":1}' from endpoint 1 with groupID 0
          2020-11-28 14:07:28.856 - debug: zigbee.0 (440024) Type attributeReport device {"type":"device","device":{"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d00030a3270","_networkAddress":27111,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":27111,"deviceIeeeAddress":"0x00158d00030a3270","clusters":{"genBasic":{"attributes":{"65281":{"1":3005,"3":29,"4":17320,"5":23,"6":[0,28],"10":0,"11":72,"100":0},"modelId":"lumi.sensor_motion.aq2","manufacturerName":"LUMI","powerSource":3}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":60}},"msOccupancySensing":{"attributes":{"occupancy":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_interviewCompleted":false,"_interviewing":false,"meta":{},"_lastSeen":1606568848854,"_linkquality":90},"mapped":{"zigbeeModel":["lumi.sensor_motion.aq2"],"model":"RTCGQ11LM","vendor":"Xiaomi","description":"Aqara human body movement and illuminance sensor","supports":"occupancy and illuminance","meta":{"battery":{"voltageToPercentage":"3V_2100"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"binary","name":"occupancy","property":"occupancy","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected occupancy"},{"type":"numeric","name":"illuminance","property":"illuminance","access":1,"description":"Raw measured illuminance","unit":"lx"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x00158d00030a3270"} incoming event: {"type":"attributeReport","device":{"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d00030a3270","_networkAddress":27111,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":27111,"deviceIeeeAddress":"0x00158d00030a3270","clusters":{"genBasic":{"attributes":{"65281":{"1":3005,"3":29,"4":17320,"5":23,"6":[0,28],"10":0,"11":72,"100":0},"modelId":"lumi.sensor_motion.aq2","manufacturerName":"LUMI","powerSource":3}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":60}},"msOccupancySensing":{"attributes":{"occupancy":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_interviewCompleted":false,"_interviewing":false,"meta":{},"_lastSeen":1606568848854,"_linkquality":90},"endpoint":"[Circular]","data":{"occupancy":1},"linkquality":90,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":159,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
          2020-11-28 14:07:28.861 - debug: zigbee.0 (440024) Publish {"illuminance":60,"illuminance_lux":60}
          2020-11-28 14:07:28.863 - debug: zigbee.0 (440024) Publish {"occupancy":true}
          2020-11-28 14:07:38.866 - debug: zigbee.0 (440024) Publish {"occupancy":false}
          2020-11-28 14:08:08.038 - debug: zigbee.0 (440024) handleMessage. {"type":"commandOperationEventNotification","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":55668,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":2}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":160}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1606568888038,"_linkquality":69},"endpoint":"[Circular]","data":{"opereventsrc":1,"opereventcode":1,"userid":65535,"pin":0,"zigbeelocaltime":4294967295,"data":0},"linkquality":69,"groupID":0,"cluster":"closuresDoorLock","meta":{"zclTransactionSequenceNumber":20,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
          2020-11-28 14:08:08.042 - debug: zigbee.0 (440024) Received Zigbee message from '0x000b57fffe59d1f6', type 'commandOperationEventNotification', cluster 'closuresDoorLock', data '{"opereventsrc":1,"opereventcode":1,"userid":65535,"pin":0,"zigbeelocaltime":4294967295,"data":0}' from endpoint 1 with groupID 0
          2020-11-28 14:08:08.043 - debug: zigbee.0 (440024) Type commandOperationEventNotification device {"type":"device","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":55668,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":2}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":160}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1606568888038,"_linkquality":69},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]}],"meta":{"configureKey":5},"exposes":[{"type":"lock","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"LOCK","value_off":"UNLOCK","description":"State of the lock"}]},{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x000b57fffe59d1f6"} incoming event: {"type":"commandOperationEventNotification","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":55668,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":2}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":160}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1606568888038,"_linkquality":69},"endpoint":"[Circular]","data":{"opereventsrc":1,"opereventcode":1,"userid":65535,"pin":0,"zigbeelocaltime":4294967295,"data":0},"linkquality":69,"groupID":0,"cluster":"closuresDoorLock","meta":{"zclTransactionSequenceNumber":20,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
          2020-11-28 14:08:08.048 - debug: zigbee.0 (440024) handleMessage. {"type":"attributeReport","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":55668,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":160}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1606568888047,"_linkquality":69},"endpoint":"[Circular]","data":{"lockState":1},"linkquality":69,"groupID":0,"cluster":"closuresDoorLock","meta":{"zclTransactionSequenceNumber":21,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
          2020-11-28 14:08:08.050 - debug: zigbee.0 (440024) Received Zigbee message from '0x000b57fffe59d1f6', type 'attributeReport', cluster 'closuresDoorLock', data '{"lockState":1}' from endpoint 1 with groupID 0
          2020-11-28 14:08:08.051 - debug: zigbee.0 (440024) Type attributeReport device {"type":"device","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":55668,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":160}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1606568888047,"_linkquality":69},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]}],"meta":{"configureKey":5},"exposes":[{"type":"lock","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"LOCK","value_off":"UNLOCK","description":"State of the lock"}]},{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x000b57fffe59d1f6"} incoming event: {"type":"attributeReport","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":55668,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":160}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1606568888047,"_linkquality":69},"endpoint":"[Circular]","data":{"lockState":1},"linkquality":69,"groupID":0,"cluster":"closuresDoorLock","meta":{"zclTransactionSequenceNumber":21,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
          2020-11-28 14:08:08.057 - debug: zigbee.0 (440024) Publish {"action":"lock","action_user":65535,"action_source":1,"action_source_name":"rf"}
          2020-11-28 14:08:08.058 - debug: zigbee.0 (440024) Publish {"state":"LOCK","lock_state":"locked"}
          2020-11-28 14:08:21.866 - debug: zigbee.0 (440024) handleMessage. {"type":"commandOperationEventNotification","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":55668,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":160}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1606568901866,"_linkquality":72},"endpoint":"[Circular]","data":{"opereventsrc":1,"opereventcode":2,"userid":65535,"pin":0,"zigbeelocaltime":4294967295,"data":0},"linkquality":72,"groupID":0,"cluster":"closuresDoorLock","meta":{"zclTransactionSequenceNumber":22,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
          2020-11-28 14:08:21.873 - debug: zigbee.0 (440024) Received Zigbee message from '0x000b57fffe59d1f6', type 'commandOperationEventNotification', cluster 'closuresDoorLock', data '{"opereventsrc":1,"opereventcode":2,"userid":65535,"pin":0,"zigbeelocaltime":4294967295,"data":0}' from endpoint 1 with groupID 0
          2020-11-28 14:08:21.874 - debug: zigbee.0 (440024) Type commandOperationEventNotification device {"type":"device","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":55668,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":160}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1606568901866,"_linkquality":72},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]}],"meta":{"configureKey":5},"exposes":[{"type":"lock","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"LOCK","value_off":"UNLOCK","description":"State of the lock"}]},{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x000b57fffe59d1f6"} incoming event: {"type":"commandOperationEventNotification","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":55668,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":160}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1606568901866,"_linkquality":72},"endpoint":"[Circular]","data":{"opereventsrc":1,"opereventcode":2,"userid":65535,"pin":0,"zigbeelocaltime":4294967295,"data":0},"linkquality":72,"groupID":0,"cluster":"closuresDoorLock","meta":{"zclTransactionSequenceNumber":22,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
          2020-11-28 14:08:21.881 - debug: zigbee.0 (440024) handleMessage. {"type":"attributeReport","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":55668,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":2}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":160}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1606568901877,"_linkquality":69},"endpoint":"[Circular]","data":{"lockState":2},"linkquality":69,"groupID":0,"cluster":"closuresDoorLock","meta":{"zclTransactionSequenceNumber":23,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
          2020-11-28 14:08:21.882 - debug: zigbee.0 (440024) Received Zigbee message from '0x000b57fffe59d1f6', type 'attributeReport', cluster 'closuresDoorLock', data '{"lockState":2}' from endpoint 1 with groupID 0
          2020-11-28 14:08:21.883 - debug: zigbee.0 (440024) Type attributeReport device {"type":"device","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":55668,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":2}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":160}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1606568901877,"_linkquality":69},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]}],"meta":{"configureKey":5},"exposes":[{"type":"lock","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"LOCK","value_off":"UNLOCK","description":"State of the lock"}]},{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x000b57fffe59d1f6"} incoming event: {"type":"attributeReport","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":55668,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":2}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":160}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1606568901877,"_linkquality":69},"endpoint":"[Circular]","data":{"lockState":2},"linkquality":69,"groupID":0,"cluster":"closuresDoorLock","meta":{"zclTransactionSequenceNumber":23,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
          2020-11-28 14:08:21.887 - debug: zigbee.0 (440024) Publish {"action":"unlock","action_user":65535,"action_source":1,"action_source_name":"rf"}
          2020-11-28 14:08:21.888 - debug: zigbee.0 (440024) Publish {"state":"UNLOCK","lock_state":"unlocked"}
          2020-11-28 14:08:31.655 - debug: zigbee.0 (440024) system.adapter.admin.0: logging true
          2020-11-28 14:10:55.099 - debug: zigbee.0 (440024) Non-pingable device 0x00158d000208dc76 lumi.sensor_ht was last seen '1142.702' seconds ago.
          2020-11-28 14:10:55.099 - debug: zigbee.0 (440024) Non-pingable device 0x00158d00023ce458 lumi.sensor_ht was last seen '1896.202' seconds ago.
          2020-11-28 14:10:55.100 - debug: zigbee.0 (440024) Non-pingable device 0x00158d000249a9a8 lumi.sensor_ht was last seen '909.159' seconds ago.
          2020-11-28 14:10:55.100 - debug: zigbee.0 (440024) Non-pingable device 0x00158d00025562c5 lumi.sensor_ht was last seen '2838.952' seconds ago.
          2020-11-28 14:10:55.100 - debug: zigbee.0 (440024) Non-pingable device 0x00158d0002fd3f30 lumi.sensor_motion.aq2 was last seen '777.411' seconds ago.
          2020-11-28 14:10:55.101 - debug: zigbee.0 (440024) Non-pingable device 0x00158d0003667aba lumi.sensor_motion.aq2 was last seen '1545.888' seconds ago.
          2020-11-28 14:10:55.101 - debug: zigbee.0 (440024) Non-pingable device 0x00158d0002ea07ac lumi.sensor_motion.aq2 was last seen '431.579' seconds ago.
          2020-11-28 14:10:55.101 - debug: zigbee.0 (440024) Non-pingable device 0x00158d00030a3270 lumi.sensor_motion.aq2 was last seen '206.247' seconds ago.
          2020-11-28 14:10:55.102 - debug: zigbee.0 (440024) Non-pingable device 0x00158d00032c1109 lumi.sensor_motion.aq2 was last seen '661.472' seconds ago.
          2020-11-28 14:10:55.102 - debug: zigbee.0 (440024) Non-pingable device 0xccccccfffee04e28 TRADFRI on/off switch was last seen '59313.011' seconds ago.
          2020-11-28 14:10:55.102 - debug: zigbee.0 (440024) Non-pingable device 0xec1bbdfffe9734c2 TRADFRI on/off switch was last seen '2484936.02' seconds ago.
          2020-11-28 14:10:55.103 - debug: zigbee.0 (440024) Publish available for 0xec1bbdfffe9734c2 = false
          2020-11-28 14:10:55.103 - debug: zigbee.0 (440024) Non-pingable device 0xec1bbdfffe972471 TRADFRI on/off switch was last seen '58521.983' seconds ago.
          2020-11-28 14:10:55.104 - debug: zigbee.0 (440024) Non-pingable device 0xec1bbdfffeb45b50 TRADFRI on/off switch was last seen '7298.826' seconds ago.
          2020-11-28 14:12:02.257 - debug: zigbee.0 (440024) system.adapter.admin.0: logging false
          2020-11-28 14:13:18.525 - debug: zigbee.0 (440024) handleMessage. {"type":"attributeReport","device":{"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d00030a3270","_networkAddress":27111,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":27111,"deviceIeeeAddress":"0x00158d00030a3270","clusters":{"genBasic":{"attributes":{"65281":{"1":3005,"3":29,"4":17320,"5":23,"6":[0,28],"10":0,"11":72,"100":0},"modelId":"lumi.sensor_motion.aq2","manufacturerName":"LUMI","powerSource":3}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":57}},"msOccupancySensing":{"attributes":{"occupancy":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_interviewCompleted":false,"_interviewing":false,"meta":{},"_lastSeen":1606569198525,"_linkquality":90},"endpoint":"[Circular]","data":{"measuredValue":57},"linkquality":90,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":160,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
          2020-11-28 14:13:18.526 - debug: zigbee.0 (440024) Received Zigbee message from '0x00158d00030a3270', type 'attributeReport', cluster 'msIlluminanceMeasurement', data '{"measuredValue":57}' from endpoint 1 with groupID 0
          2020-11-28 14:13:18.527 - debug: zigbee.0 (440024) Type attributeReport device {"type":"device","device":{"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d00030a3270","_networkAddress":27111,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":27111,"deviceIeeeAddress":"0x00158d00030a3270","clusters":{"genBasic":{"attributes":{"65281":{"1":3005,"3":29,"4":17320,"5":23,"6":[0,28],"10":0,"11":72,"100":0},"modelId":"lumi.sensor_motion.aq2","manufacturerName":"LUMI","powerSource":3}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":57}},"msOccupancySensing":{"attributes":{"occupancy":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_interviewCompleted":false,"_interviewing":false,"meta":{},"_lastSeen":1606569198525,"_linkquality":90},"mapped":{"zigbeeModel":["lumi.sensor_motion.aq2"],"model":"RTCGQ11LM","vendor":"Xiaomi","description":"Aqara human body movement and illuminance sensor","supports":"occupancy and illuminance","meta":{"battery":{"voltageToPercentage":"3V_2100"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"binary","name":"occupancy","property":"occupancy","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected occupancy"},{"type":"numeric","name":"illuminance","property":"illuminance","access":1,"description":"Raw measured illuminance","unit":"lx"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x00158d00030a3270"} incoming event: {"type":"attributeReport","device":{"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d00030a3270","_networkAddress":27111,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":27111,"deviceIeeeAddress":"0x00158d00030a3270","clusters":{"genBasic":{"attributes":{"65281":{"1":3005,"3":29,"4":17320,"5":23,"6":[0,28],"10":0,"11":72,"100":0},"modelId":"lumi.sensor_motion.aq2","manufacturerName":"LUMI","powerSource":3}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":57}},"msOccupancySensing":{"attributes":{"occupancy":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_interviewCompleted":false,"_interviewing":false,"meta":{},"_lastSeen":1606569198525,"_linkquality":90},"endpoint":"[Circular]","data":{"measuredValue":57},"linkquality":90,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":160,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
          2020-11-28 14:13:18.530 - debug: zigbee.0 (440024) handleMessage. {"type":"attributeReport","device":{"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d00030a3270","_networkAddress":27111,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":27111,"deviceIeeeAddress":"0x00158d00030a3270","clusters":{"genBasic":{"attributes":{"65281":{"1":3005,"3":29,"4":17320,"5":23,"6":[0,28],"10":0,"11":72,"100":0},"modelId":"lumi.sensor_motion.aq2","manufacturerName":"LUMI","powerSource":3}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":57}},"msOccupancySensing":{"attributes":{"occupancy":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_interviewCompleted":false,"_interviewing":false,"meta":{},"_lastSeen":1606569198530,"_linkquality":90},"endpoint":"[Circular]","data":{"occupancy":1},"linkquality":90,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":161,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
          2020-11-28 14:13:18.531 - debug: zigbee.0 (440024) Received Zigbee message from '0x00158d00030a3270', type 'attributeReport', cluster 'msOccupancySensing', data '{"occupancy":1}' from endpoint 1 with groupID 0
          2020-11-28 14:13:18.532 - debug: zigbee.0 (440024) Type attributeReport device {"type":"device","device":{"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d00030a3270","_networkAddress":27111,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":27111,"deviceIeeeAddress":"0x00158d00030a3270","clusters":{"genBasic":{"attributes":{"65281":{"1":3005,"3":29,"4":17320,"5":23,"6":[0,28],"10":0,"11":72,"100":0},"modelId":"lumi.sensor_motion.aq2","manufacturerName":"LUMI","powerSource":3}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":57}},"msOccupancySensing":{"attributes":{"occupancy":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_interviewCompleted":false,"_interviewing":false,"meta":{},"_lastSeen":1606569198530,"_linkquality":90},"mapped":{"zigbeeModel":["lumi.sensor_motion.aq2"],"model":"RTCGQ11LM","vendor":"Xiaomi","description":"Aqara human body movement and illuminance sensor","supports":"occupancy and illuminance","meta":{"battery":{"voltageToPercentage":"3V_2100"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"binary","name":"occupancy","property":"occupancy","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected occupancy"},{"type":"numeric","name":"illuminance","property":"illuminance","access":1,"description":"Raw measured illuminance","unit":"lx"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x00158d00030a3270"} incoming event: {"type":"attributeReport","device":{"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d00030a3270","_networkAddress":27111,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":27111,"deviceIeeeAddress":"0x00158d00030a3270","clusters":{"genBasic":{"attributes":{"65281":{"1":3005,"3":29,"4":17320,"5":23,"6":[0,28],"10":0,"11":72,"100":0},"modelId":"lumi.sensor_motion.aq2","manufacturerName":"LUMI","powerSource":3}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":57}},"msOccupancySensing":{"attributes":{"occupancy":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_interviewCompleted":false,"_interviewing":false,"meta":{},"_lastSeen":1606569198530,"_linkquality":90},"endpoint":"[Circular]","data":{"occupancy":1},"linkquality":90,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":161,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
          2020-11-28 14:13:18.536 - debug: zigbee.0 (440024) Publish {"illuminance":57,"illuminance_lux":57}
          2020-11-28 14:13:18.537 - debug: zigbee.0 (440024) Publish {"occupancy":true}
          2020-11-28 14:13:24.444 - debug: zigbee.0 (440024) handleMessage. {"type":"readResponse","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":55668,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":2}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":160}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1606569204443,"_linkquality":57},"endpoint":"[Circular]","data":{"zclVersion":2},"linkquality":57,"groupID":0,"cluster":"genBasic","meta":{"zclTransactionSequenceNumber":4,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
          2020-11-28 14:13:24.444 - debug: zigbee.0 (440024) Received Zigbee message from '0x000b57fffe59d1f6', type 'readResponse', cluster 'genBasic', data '{"zclVersion":2}' from endpoint 1 with groupID 0
          2020-11-28 14:13:24.446 - debug: zigbee.0 (440024) Type readResponse device {"type":"device","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":55668,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":2}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":160}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1606569204443,"_linkquality":57},"mapped":{"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","supports":"lock/unlock, battery","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]}],"meta":{"configureKey":5},"exposes":[{"type":"lock","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"LOCK","value_off":"UNLOCK","description":"State of the lock"}]},{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)"}]},"name":"0x000b57fffe59d1f6"} incoming event: {"type":"readResponse","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":55668,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":55668,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"closuresDoorLock":{"attributes":{"lockState":2}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":160}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"meta":{}}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":5},"_lastSeen":1606569204443,"_linkquality":57},"endpoint":"[Circular]","data":{"zclVersion":2},"linkquality":57,"groupID":0,"cluster":"genBasic","meta":{"zclTransactionSequenceNumber":4,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
          2020-11-28 14:13:24.447 - debug: zigbee.0 (440024) Successfully pinged 0x000b57fffe59d1f6 V3-BTZB
          2020-11-28 14:13:28.538 - debug: zigbee.0 (440024) Publish {"occupancy":false}
          2020-11-28 14:14:00.042 - info: host.Beelink instance system.adapter.openweathermap.0 started with pid 449347
          2020-11-28 14:14:02.221 - info: openweathermap.0 (449347) starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v14.15.1, js-controller: 3.1.6
          2020-11-28 14:14:05.367 - info: openweathermap.0 (449347) Terminated (NO_ERROR): Without reason
          2020-11-28 14:14:05.889 - info: host.Beelink instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
          2020-11-28 14:14:11.275 - debug: zigbee.0 (440024) system.adapter.admin.0: logging true
          So und den Stick auch gleich mal upgedatet:
          zigbee.0	2020-11-28 15:44:46.473	info	(553242) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20201026}}
          Leider keine Änderungen an den Danalock DPs.
          • DK43
            DK43 last edited by
            Hi
            Hab hier von Silvercrest (Lidl) einen Bewegungssensor und einen Smart Plug.
            Adapter Version 1.3.1
            Der Stick ist ein cc2531 mit dieser Firmware: github.com/Koenkk/Z-Stack-firmware/tree/master/coordinator/Z-Stack_Home_1.2/bin/default/cc2531_default_20190608.hex
            Beim Bewegungssensor wird mir das hier angezeigt:
            Den smart plug konnte ich pairen. Wird als tuya angezeigt.
              Jan1 last edited by
              Noch mal zum Danalock V3. Könnte hier einer der das hat mal die DPs posten, welche zu erwarten sind und wenn ich in der APP in den Einstellungen auf Smarthome klicke, habe ich hier ein Z-Wave Symbol zum verbinden, sollte da nicht Zigbee stehen?
              Das Danalock war wohl schon mal geöffnet, könnte als was anderes im Karton gewesen sein, als drauf steht. Auf dem Karton steht zumindest mal Zigbee. Alternativ, wie kann ich sicher raus finden was ich für ein Schloss habe?
              • Asgothian
                Asgothian Developer @Jan1 last edited by
                @Jan1
                Das Sieht alles erst einmal gut aus. Die Steuerung des Locks geht über den Datenpunkt lockState:
                • locked bedeutet das das Schloss den Zustand "verschlossen" gemeldet hat
                • unlocked bedeutet das das Schloss den Zustand "unverschlossen" gemeldet hat
                • lock eintragen bewirkt das das Schloss den Befehl zum Abschliessen bekommt, und dessen Ausführung durch "locked" bestätigt.
                • unlock eintragen bewirkt das das Schloss den Befehl zum aufschliessen bekommt und dessen Ausführung durch "unlocked" bestätigt
                wenn bereits "unlocked" eingetragen ist, und der Befehl "unlock" abgesetzt wird sollte das Schloss die Falle für 1 bis 3 Sekunden zurück ziehen.
                Bitte teste das und poste das Log vom Test.
                A.
                  Jan1 @Asgothian last edited by Jan1
                  @Asgothian
                  Mein Held, ich hatte den Error40 (Problem sitzt 40cm vor dem Bildschirm) und hatte erwartet, dass hier noch ein DP erscheint, der speziell zum Steuern ausgewiesen ist. Hatte mich aber auch gewundert, dass der genannte DP beschreibbar ist, nur wenn man Blödsinn rein schreibt, passiert eben nix außer Fehler im Log.
                  Somit Danalock mit Zigbee Adapter abgehakt, es funktioniert wie es soll 😉
                  und hier noch das Log dazu:
                  zigbee.0	2020-11-29 10:49:42.833	debug	(119354) Publish {"state":"LOCK","lock_state":"locked"}
                  zigbee.0	2020-11-29 10:49:42.832	debug	(119354) Publish {"action":"lock","action_user":65535,"action_source":1,"action_source_name":"rf"}
                  zigbee.0	2020-11-29 10:49:42.824	debug	(119354) Type attributeReport device {"type":"device","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":57858,"_manufacturerID":4444,"_endpoints":[{"ID":1,"prof
                  zigbee.0	2020-11-29 10:49:42.823	debug	(119354) Received Zigbee message from '0x000b57fffe59d1f6', type 'attributeReport', cluster 'closuresDoorLock', data '{"lockState":1}' from endpoint 1 with groupID 0
                  zigbee.0	2020-11-29 10:49:42.816	debug	(119354) handleMessage. {"type":"attributeReport","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":57858,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileI
                  zigbee.0	2020-11-29 10:49:42.812	debug	(119354) Type commandOperationEventNotification device {"type":"device","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":57858,"_manufacturerID":4444,"_endpoin
                  zigbee.0	2020-11-29 10:49:42.809	debug	(119354) Received Zigbee message from '0x000b57fffe59d1f6', type 'commandOperationEventNotification', cluster 'closuresDoorLock', data '{"opereventsrc":1,"opereventcode":1,"userid":65535,"pin":0,"zig
                  zigbee.0	2020-11-29 10:49:42.804	debug	(119354) handleMessage. {"type":"commandOperationEventNotification","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":57858,"_manufacturerID":4444,"_endpoints":
                  zigbee.0	2020-11-29 10:49:38.809	debug	(119354) convert result {"readAfterWriteTime":200}
                  zigbee.0	2020-11-29 10:49:35.757	debug	(119354) Publish {"occupancy":true}
                  zigbee.0	2020-11-29 10:49:35.751	debug	(119354) Publish {"illuminance":43,"illuminance_lux":43}
                  zigbee.0	2020-11-29 10:49:35.745	debug	(119354) Type attributeReport device {"type":"device","device":{"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d00030a3270","_networkAddress":28017,"_manufacturerID":4151,"_endpoints":[{"ID":1,"input
                  zigbee.0	2020-11-29 10:49:35.744	debug	(119354) Received Zigbee message from '0x00158d00030a3270', type 'attributeReport', cluster 'msOccupancySensing', data '{"occupancy":1}' from endpoint 1 with groupID 0
                  zigbee.0	2020-11-29 10:49:35.744	debug	(119354) handleMessage. {"type":"attributeReport","device":{"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d00030a3270","_networkAddress":28017,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClus
                  zigbee.0	2020-11-29 10:49:35.739	debug	(119354) Type attributeReport device {"type":"device","device":{"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d00030a3270","_networkAddress":28017,"_manufacturerID":4151,"_endpoints":[{"ID":1,"input
                  zigbee.0	2020-11-29 10:49:35.738	debug	(119354) Received Zigbee message from '0x00158d00030a3270', type 'attributeReport', cluster 'msIlluminanceMeasurement', data '{"measuredValue":43}' from endpoint 1 with groupID 0
                  zigbee.0	2020-11-29 10:49:35.737	debug	(119354) handleMessage. {"type":"attributeReport","device":{"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d00030a3270","_networkAddress":28017,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClus
                  zigbee.0	2020-11-29 10:49:34.303	debug	(119354) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":57858,"deviceIeeeAddress":"0x000b57fffe59d1f6","clust
                  zigbee.0	2020-11-29 10:49:34.302	debug	(119354) convert state, lock, {}
                  zigbee.0	2020-11-29 10:49:34.302	debug	(119354) Mapped Model: {"zigbeeModel":["V3-BTZB"],"model":"V3-BTZB","vendor":"Danalock","description":"BT/ZB smartlock","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResp
                  zigbee.0	2020-11-29 10:49:34.301	debug	(119354) entity: {"type":"device","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":57858,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID
                  zigbee.0	2020-11-29 10:49:34.300	debug	(119354) State changes. dev: 0x000b57fffe59d1f6 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"val
                  zigbee.0	2020-11-29 10:49:34.299	debug	(119354) Change state 'lockState' at device 0x000b57fffe59d1f6 type 'V3-BTZB'
                  zigbee.0	2020-11-29 10:49:34.293	debug	(119354) User stateChange zigbee.0.000b57fffe59d1f6.lockState {"val":"lock","ack":false,"ts":1606643374288,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1606643374288}
                  zigbee.0	2020-11-29 10:49:24.000	debug	(119354) Publish {"temperature":22.38,"humidity":51.93}
                  zigbee.0	2020-11-29 10:49:23.999	debug	(119354) Publish {"voltage":2745,"battery":19}
                    Slyer_CH @DK43 last edited by
                    Hallo
                    Ich habe auch eine Anfrage bezüglich einem Smartgerät von Silvercrest (Lidl) und zwar der Steckerleiste HG06338-XX. Bei mir in der CH Version 😊 .
                    Bild Text
                    Habe es mit dem Conbee2 Stick gemacht.
                    Die Steckerleiste wird mit der Adapterversion 1.3.1 als TS011F bezeichnet. Dort hat man aber nur einen Datenpunkt zum ein und ausschalten obwohl drei schaltbare Dosen verbaut sind. Konnte aber alle drei dosen einzeln über die Entwickler Konsole steuern.
                        "devId": "zigbee.0.680ae2fffe72f0c9",
                        "ep": "1",
                        "cid": "genOnOff",
                        "cmd": "on",
                        "cmdType": "functional",
                        "zclData": {
                            "onOff": {}
                        "cfg": null
                    Mit Adapter Version 1.3.1
                    Mit der Adapter Version 1.3.9dev habe ich die Steckerleiste nochmals neu angelernt nun kommt sie als unbekanntes gerät.
                    Wäre cool wenn die Steckerleiste auch in die Datenbank der Geräte aufgenommen wird.
                    Auf GitHub gibt es auch eine anfrage für den deconz adapter falls diese Infos hilfreicher wären.
                    https://github.com/dresden-elektronik/deconz-rest-plugin/issues/3612
                    skynetforcats created this issue in dresden-elektronik/deconz-rest-plugin
                    closed [Device Support Request] Lidl 3 way SilverCrest Smart USB Extension Lead TY-HG06338-DK (Tuya TS011F) #3612
                    Z 1 Reply Last reply Reply Quote 1
                    • Z
                      zecki79 @Slyer_CH last edited by zecki79
                      Habe mir heute auch die SilverCrest (Lidl) Smart Plug HG06337(1-fach) und HG06338 (3-fach) besorgt.
                      Mein Zigbee-Adapter ist auf Version 1.3.9 Dev.
                      Der 1-fach Plug wird mit dem richtigen Namen erkannt, ich kann über state auch ein und aus schalten. Jedoch ändert sich der state nicht, wenn direkt am Smart-Plug geschalten wird.
                      der 3-fach Plug wird auch mit dem richtigen Namen erkannt, jedoch funktioniert das ein- ausschalten über state gar nicht (Fehlermeldung im log wenn der state geändert wird :(5029) No converter available for 'HG06338' with key 'state_l1') , aber wenn ich am Plug direkt schalte, wird der state im io broker richtig angezeigt.
                      Bitte um Hilfe!
                      Herzlichen Dank!
                      lg
                      D 1Topf 2 Replies Last reply Reply Quote 0
                        DocGame @zecki79 last edited by
                        Wäre es möglich diese Taster auch aufzunehmen?
                        Tuya TS0044
                        Vielen Dank im Voraus.....
                          ljmarkus last edited by
                          TS0502A -> Lidl LED-Leuchtpanel LIVARNOLUX
                          Adapter: Zigbee 1.3.1
                          (21040) Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20190608}}
                          2020_12_03_10_17_17_Lidl_Aktueller_Prospekt_03.12_16.12.2020_3_jedewoche_rabatte.de.png
                            Merschi last edited by
                            kann nachfolgendes Gerät mit aufgenommen werden?
                            https://www.revolt-power.de/Weltweit-steuerbares-Heizkoerper-Design-Thermostat-NX-4914-919.shtml
                            Ich habe festgestellt, das wohl Baugleich mit dem GS361A-H04 ist.
                            Aktuell passe ich bei Updates die 2 devices.js händisch an.
                            In der /opt/iobroker/node_modules/iobroker.zigbee/lib/devices.js mache ich ne Kopie des GS361A-H04.
                            In der /opt/iobroker/node_modules/zigbee-herdsman-converters/devices.js passe ich nach einer Kopie folgendes an:
                            // Revolt Thermostate
                                zigbeeModel: ['fvq6avy'],
                                fingerprint: [{modelID: 'fvq6avy\u0000', manufacturerName: '_TYST11_kfvq6avy'}],
                                model: 'GS361A-H04',
                                vendor: 'Revolt',
                            Damit funktionieren die bei mir bis jetzt ganz gut.
                              leon last edited by
                              Ich hätte da auch noch ein Gerät von Lidl.
                              TS0505A - Livarno Lux LED Strip 22W 2m
                              D H 2 Replies Last reply Reply Quote 0
                                DocGame @leon last edited by
                                Hier nochmals ein Gerät (War auch bei Lidl 😊 )
                                Mitlerweile habe ich schon wieder einige "Leichen" angemeldet. Hoffe Ihr hackt mal wieder einige rein.
                                Silvercrest HG06467
                                  helpingman @leon last edited by
                                  @leon Den TS0505A kannst du mit
                                      // LED Stripe Lidl
                                          models: ['TS0505A'],
                                          icon: 'img/innr_flex_FL130C.png',
                                          states: lightStatesWithColor,
                                          syncStates: [sync.brightness],
                                  in der devices.js ans laufen bringen.
                                  Wenn das Gerät mit aktualisiertem Converter dann HG06104A heißt dann so
                                      // LED Stripe Lidl
                                          models: ['HG06104A'],
                                  Gruß,
                                  Tom
                                  • 1Topf
                                    1Topf @zecki79 last edited by 1Topf
                                    @zecki79 Hi, hab genau wie Du 2 Dosen und den 3fach gekauft. Ich nutze einen CC2538. Die Teile liesen sich problemlos anlernen, wurden aber als Tuya TS011F angezeigt (auch grafisch), also auch der 3fach. Nach Adapterupdate von 1.3.1 auf 1.3.9 wird alles richtig angezeigt und auch das 3fach - Teil läßt sich nun richtig schalten (jede "Dose" getrennt), State wird korrekt erkannt, auch beim schalten direkt am Knopf. Keine Fehler, alles problemlos. Hier mal ein fettes Lob an denjenigen, der das hinbekommen hat. Super!! 👌
                                    Andi
                                      Tim12 @1Topf last edited by
                                      Würde mich freuen, wenn die Fernbedienung Schwaiger ZHF02 mit aufgenommen werden könnte:
                                      e01418ef-ce7d-4edb-9628-7dc6e492eedd-grafik.png f3a96e16-28ff-4b99-a378-4bbc053d159f-grafik.png 649771b3-1bae-4397-aaff-82b741ae1b88-grafik.png https://www.schwaiger.de/de/funkfernbedienung.html
                                        stefande @arteck last edited by
                                        Bei der Silvercrest (Lidl) Fernbedienung ist ein Tippfehler im herdmans-converter.
                                        Hier müsste brightenss_step_up durch brightness_step_up ersetzt werden.
                                                    fingerprint: [{modelID: 'TS1001', manufacturerName: '_TYZB01_bngwdjsr'}],
                                                    model: 'FB20-002',
                                                    vendor: 'Lidl',
                                                    description: 'Livarno Lux switch and dimming light remote control',
                                                    exposes: [e.action([
                                                        'on', 'off', 'brightness_stop', 'brightenss_step_up', 'brightness_step_down', 'brightness_move_up',
                                                        'brightness_move_down',
                                                    fromZigbee: [fz.command_on, fz.command_off, fz.command_step, fz.command_move, fz.command_stop],
                                                    toZigbee: [],
                                          arteck Developer Most Active @stefande last edited by
                                          hier gehts weiter
                                          https://forum.iobroker.net/topic/38971/zigbee-neue-version-1-4-0
                                          converter herdsman neuer adapter zigbee
                                          50
                                          231
                                          35995
