    • JB_Sullivan
      JB_Sullivan @simatec last edited by
      @simatec - Sorry - hat ein bisschen länger gedauert
      So 1. Versuch
      Von GIT installiert nochmal Up geloaded - Instanz gestoppt und neu gestartet.
      IP für InfluxDB 127.0.0.1
      Funktioniert nicht !
      1. Versuch
        IP für InfluxDB leer
        Funktioniert auch nicht 😞
      backitup.0	2020-12-01 14:23:37.377	debug	(68) [iobroker/googledrive] done
      backitup.0	2020-12-01 14:23:37.214	debug	(68) [iobroker/googledrive] Google Drive: File "C:/iobroker/GLT/backups/influxDB_2020_12_01-14_22_18_backupiobroker.tar.gz" not found
      backitup.0	2020-12-01 14:22:29.663	debug	(68) [iobroker/googledrive] Google Drive: Copy historyDB_2020_12_01-14_17_57_backupiobroker.tar.gz...
      backitup.0	2020-12-01 14:22:19.644	debug	(68) [iobroker/googledrive] Google Drive: Copy iobroker_2020_12_01-14_17_36_backupiobroker.tar.gz...
      backitup.0	2020-12-01 14:22:18.879	debug	(68) [iobroker/influxDB] ****
      backitup.0	2020-12-01 14:22:18.878	debug	(68) [iobroker/influxDB] ****k****o****n****n****t****e**** ****n****i****c****h****t**** ****g****e****f****u****n****d****e****n**** ****w****e****r****d****e****n****.**** ****
      backitup.0	2020-12-01 14:22:18.878	debug	(68) [iobroker/influxDB] ****D****e****r**** ****B****e****f****e****h****l**** ****"****i****n****f****l****u****x****d****"**** ****i****s****t**** ****e****n****t****w****e****d****e****r**** ****
      backitup.0	2020-12-01 14:22:18.878	debug	(68) [iobroker/influxDB] [IGNORED] ****E****r****r****o****r****:**** ****C****o****m****m****a****n****d**** ****f****a****i****l****e****d****:**** ****i****n****f****l****u****x****d**** ****b****
      backitup.0	2020-12-01 14:22:18.876	debug	(68) [iobroker/influxDB] InfluxDB tmp directory was successfully deleted
      backitup.0	2020-12-01 14:22:18.873	debug	(68) [iobroker/influxDB] Try deleting the InfluxDB tmp directory
      backitup.0	2020-12-01 14:22:18.786	debug	(68) [iobroker/influxDB] path 2: influxd backup -portable -database iobroker -host :8088 C:/iobroker/GLT/backups/influxDB_2020_12_01-14_22_18_backupiobroker
      backitup.0	2020-12-01 14:22:18.785	debug	(68) [iobroker/influxDB] path 1: influxd backup -portable -database iobroker C:/iobroker/GLT/backups/influxDB_2020_12_01-14_22_18_backupiobroker
      backitup.0	2020-12-01 14:22:18.783	debug	(68) [iobroker/influxDB] Created InfuxDB Backup dir
      backitup.0	2020-12-01 14:22:18.774	debug	(68) [iobroker/influxDB] Start infulxDB Backup ...
      • simatec
        simatec Developer Most Active @JB_Sullivan last edited by
        @JB_Sullivan sagte in Test Adapter Backitup v1.7.x:
        influxd
        Gut danke für den Log. Der war Ausagekräftig.
        Teste mal jetzt vom Github (DEV Branch)
        • JB_Sullivan
          @simatec 👍 👍 👍 👍 👍 👍 👍 👍 👍 👍 👍
          ..... und läuft 😊 😊
          Allerdings kann ich nicht beurteilen, ob das was dort gesichert wurde auch das ist, was gesichert werden sollte. Ein Restore möchte ich jetzt gerade noch nicht machen.
          simatec 2 Replies Last reply Reply Quote 0
          • simatec
            @JB_Sullivan
            Das Backup sieht gut aus. 😉
            Alles drin, was drin sein muss
            • simatec
              Schade ... Suche noch Tester für den Restore 😄
              • JB_Sullivan
                @simatec
                Vielleicht heute Abend - dann bin ich wieder zu Hause am Testsystem. Mach das hier so nebenbei auf der Arbeit 🤐 🤐 🤐
                • simatec
                  simatec Developer Most Active last edited by simatec
                  Ab sofort steht auf Github und in Kürze auch im latest die 1.8.0-beta.2 zur Verfügung.
                  Changelog
                  1.8.0-beta.2 (30.11.2020)
                  • (simatec) influxDB Backup added
                  • (simatec) influxDB Restore added
                  • (simatec) Postgresql Backup added
                  • (simatec) Postgresql Restore added
                  • (simatec) translation added
                  • (simatec) new zigbee Restore added
                  • (simatec) dependencies updated
                  • (simatec) many small bugfixes
                  • (simatec) new redis Restore added
                  • (simatec) enable/disable option for Sentry Plugin
                  JB_Sullivan Gargano 2 Replies Last reply Reply Quote 0
                  • JB_Sullivan
                    @simatec
                    Noch ein kleiner Hinweis - das Backup funktioniert jetzt, aber im VIS der DP backitup.0.history.iobrokerLastTime wird immer noch mit einem Error belegt.
                    • Lenny.CB
                      Lenny.CB Most Active @simatec last edited by
                      @simatec sagte in Test Adapter Backitup v1.7.x:
                      @Lenny-CB
                      Nein du musst deine Datenbank nicht umziehen lassen.
                      Nur influx auf deinem iobroker System installieren, damit du dann den remote Backup ausführen kannst.
                      In den Einstellungen dann die IP deiner Influx Datenbank eintragen
                      kann man das nicht über ssh auf dem anderen Rechner ausführen?
                      wenn ich auf der ioBroker-Konsole diesen Befehl ausführe, wird auf dem Influx-Rechner im Ordner /tmp/mysnapshot das Backup erstellt.
                      ssh root@192.168.0.26 -t influxd backup -portable -database iobroker -host 192.168.0.26:8088 /tmp/mysnapshot
                      Das muss dann noch per ftp ans NAS gesendet werden. Könnte doch so klappen, oder?
                        lonsimbt @Lenny.CB last edited by
                        @simatec
                        Backup der influxdb funktioniert bei mir. Wichtig sind m.E. folgende Punkte, die auf der entsprechenden Konfigurationsseite des Adapters dokumentiert werden sollten:
                        • Auf dem iobroker Host muss das influx Paket installiert sein (aber nicht unbedingt die DB oder der influxdb service laufen)
                        • Auf dem influxdb Host muss in der Konfigurationsdatei /etc/influxdb/influxdb.conf die Bind-Adress für den rpc konfiguriert sein:
                          # Bind address to use for the RPC service for backup and restore.
                          bind-address = ":8088"
                        Restore habe ich mich auch noch nicht getraut 😉
                        Gruß Marco
                        • simatec
                          simatec Developer Most Active @lonsimbt last edited by
                          @lonsimbt
                          Danke fürs testen.
                          Mit der aktuellen Beta ist für ein lokales Backup die bind-address nicht wichtig.
                          Für ein lokales Backup einfach in der Config die IP weglassen.
                          Werde das aber noch dokumentieren.
                          • MathiasJ
                            MathiasJ last edited by
                            Heute das gleiche Spiel wieder.
                            Updates auf der NAS und Dropbox, jedoch nicht auf G-Drive.
                            Ich habe den Adapter mal von info auf debug umgestellt.
                            Mal schauen, was heute Nacht ca 01:30 - 02:00 passiert. Dann werde ich berichten.
                            • JB_Sullivan
                              Backup hat funktioniert, allerdings wurde auch heute Nacht ein ERROR, in den Datenpunkt geschrieben. backitup.0.history.iobrokerLastTime
                              Ist für die Zukunft ggf. geplant, auch in den backitup.0.history.json DP einen Hinweis auf die anderen gesicherten Dateien mit einzubauen? Bis jetzt wird ja nur die ioBroker Sicherung angezeigt.
                              • Gargano
                                Gargano @simatec last edited by
                                @simatec Wenn man die Beta 1 vorher installiert hat funktioniert der Update von Beta 2 über die Adapterseite nicht.
                                Meldung : is up to date.
                                • simatec
                                  simatec Developer Most Active @Gargano last edited by
                                  @Gargano Ist aktuell leider ein Problem von admin.
                                  Werde die nächsten Tage ne Version 1.8.1 pushen, damit das Update wieder möglich ist.
                                  • SBorg
                                    Mal ne Frage unabhängig von der Fehlermeldung:
                                    Email-Text:
                                    BackItUp:
                                    ****D****i****e**** ****S****i****c****h****e****r****u****n****g**** ****w****u****r****d****e**** ****n****i****c****h****t**** ****v****o****l****l****s****t****ä****n****d****i****g**** ****e****r****s****t****e****l****l****t****.**** ****B****i****t****t****e**** ****ü****b****e****r****p****r****ü****f****e**** ****d****i****e**** ****F****e****h****l****e****r****m****e****l****d****u****n****g****e****n****!****!****
                                    ****c****i****f****s****:**** ****E****r****r****o****r****:**** ****E****N****O****E****N****T****:**** ****n****o**** ****s****u****c****h**** ****f****i****l****e**** ****o****r**** ****d****i****r****e****c****t****o****r****y****,**** ****o****p****e****n**** ****'****/****o****p****t****/****i****o****b****r****o****k****e****r****/****b****a****c****k****u****p****s****/****i****n****f****l****u****x****D****B****_****2****0****2****0****_****1****2****_****0****3****-****0****2****_****0****8****_****2****4****_****b****a****c****k****u****p****i****o****b****r****o****k****e****r****.****t****a****r****.****g****z****'****
                                    "Tut das Not...", mir unbekanntes Format,... IMO nicht gerade lesefreundlich 😉
                                    • simatec
                                      simatec Developer Most Active @SBorg last edited by
                                      @SBorg Gibt Influx so aus. Muss mal schauen, dass ich die Sterne rausfiltern kann
                                      • simatec
                                        @SBorg sagte in Test Adapter Backitup v1.7.x:
                                        Versuche mal bitte die 1.8.0-beta.3 vom Github
                                        • SBorg
                                          SBorg Forum Testing Most Active @simatec last edited by
                                          @simatec Leider nein:
                                          BackItUp:
                                          ****c****i****f****s****:**** ****E****r****r****o****r****:**** ****E****N****O****E****N****T****:**** ****n****o**** ****s****u****c****h**** ****f****i****l****e**** ****o****r**** ****d****i****r****e****c****t****o****r****y****,**** ****o****p****e****n**** ****'****/****o****p****t****/****i****o****b****r****o****k****e****r****/****b****a****c****k****u****p****s****/****i****n****f****l****u****x****D****B****_****2****0****2****0****_****1****2****_****0****3****-****1****9****_****3****5****_****1****1****_****b****a****c****k****u****p****i****o****b****r****o****k****e****r****.****t****a****r****.****g****z****'****
                                          wird aber angelegt:
                                          • simatec
                                            @SBorg
                                            Bitte nach der Installation über Github einen Upload machen und den Adapter neustarten
                                            170
                                            2780
                                            2344095
