    4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
      tombox @marsroth last edited by
      @marsroth Das ist korrekt ich benötige Zugangsdaten um den Loginvorgang komplett abzubilden.
        AntiHeld889 @tombox last edited by
        @tombox said in Test Adapter VW Connect v0.0.x:
        Ich habe den Audi Login gefixt Bitte mal via github installieren und neustarten. Bisher habe ich keine Daten bekommen bin mir aber unsicher ob es an den Zugangsdaten liegt.
        Habe es gerade mal probiert, aber geht leider bei mir nicht 😞
        host.HomeServer	2020-12-01 19:56:00.435	info	Restart adapter system.adapter.vw-connect.0 because enabled
        host.HomeServer	2020-12-01 19:56:00.435	error	instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.HomeServer	2020-12-01 19:56:00.435	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
        host.HomeServer	2020-12-01 19:56:00.435	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
        host.HomeServer	2020-12-01 19:56:00.435	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
        host.HomeServer	2020-12-01 19:56:00.435	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
        host.HomeServer	2020-12-01 19:56:00.435	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
        host.HomeServer	2020-12-01 19:56:00.435	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
        host.HomeServer	2020-12-01 19:56:00.435	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
        host.HomeServer	2020-12-01 19:56:00.435	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1057:18)
        host.HomeServer	2020-12-01 19:56:00.435	error	Caught by controller[0]: Error: /opt/iobroker/node_modules/canvas/build/Release/canvas.node: file too short
        host.HomeServer	2020-12-01 19:56:00.434	error	Caught by controller[0]: ^
        host.HomeServer	2020-12-01 19:56:00.434	error	Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
        host.HomeServer	2020-12-01 19:56:00.434	error	Caught by controller[0]: internal/modules/cjs/loader.js:1057
        host.HomeServer	2020-12-01 19:56:00.100	info	instance system.adapter.vw-connect.0 started with pid 25445
          tombox @AntiHeld889 last edited by
          @AntiHeld889 canvas neuinstallieren sollte helfen
            Jetzt läufts, vielen Dank 🙂
            • Wszene
              Wszene @aba320 last edited by
              @aba320
              Die Mail habe ich auch bekommen
              Und Ja heute konnte ich mich noch nicht mit meinen Kodiaq und auch meine Frau nicht mit ihrem Scala verbinden
                aba320 @Wszene last edited by
                @Wszene hab deswegen meinen adapter, der bis19 uhr funktionierte, zur Zeit deaktiviert und alle Objekte gelöscht. werde morgen nach 9 uhr die app probieren und wenn die wieder geht den adapter wieder aktivieren. Die objekte hab ich gelöscht damit ich morgen keine datenleichen übrigbehalte. Dies löschen hab ich schon öfters gemacht und manchmal sind dann tatsächlich alte objekte, die neuerdings nicht mehr so heißen oder nicht mehr genutzt werden, auch weg. dadurch weiß man sicher welche objekte tatsächlich aktuell sind.
                Gruß Achim
                Wszene 1 Reply Last reply Reply Quote 0
                  tombox @jhg last edited by tombox
                  Ich habe auf github den id login überarbeitet und eingefügt. Jetzt sollte ein status auch für id.3 kommen.
                  Einfach via github neuinstallieren und instanze neustarten
                  ? A 2 Replies Last reply Reply Quote 0
                    Jan1 last edited by Jan1
                    @tombox
                    Bei Audi ist wohl ein kleiner Fehler im Adapter:
                    Der DP Temperatur in C° ist boolean, sollte doch aber String sein.
                      tombox @Jan1 last edited by
                      @Jan1 ist behoben datenpunkt löschen und neuinstallieren
                        A Former User @tombox last edited by
                        Was soll ich sagen ... klappt wunderbar!
                        DANKE Tombox!
                        • Wszene
                          @aba320
                          Ich habe es jetzt auch ma so gemacht wie du geschrieben hast
                          1. Instanz gestoppt
                          2. alle Objekte gelöscht
                          3. Adapter Update gemacht
                          4. Instanz gestartet
                          die Fehler im Log sind immer noch da
                          vw-connect.0	2020-12-03 08:27:09.382	error	(1675) status update Failed
                          vw-connect.0	2020-12-03 08:27:09.380	error	(1675) 429
                          vw-connect.0	2020-12-03 08:27:03.337	info	(1675) starting. Version 0.0.21 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v12.20.0, js-controller: 3.1.6
                          T A 2 Replies Last reply Reply Quote 0
                            tombox @Wszene last edited by
                            @Wszene Was ist genau das Problem
                            • Wszene
                              Wszene @tombox last edited by
                              @tombox
                              Ich habe das Problem das wenn ich den Adapter aktiv habe kann ich über die APP z.B. die Standheizung nicht mehr anschalten
                              Ich muss dann immer den Adapter stoppen und mich in der App neu einloggen dann kann ich nach dem 3-4ten Versuch die Standheizung schalten
                              Wenn ich nach dem stoppen des Adapters ca. 30min warte kann ich direkt über die App schalten
                              Gibt es denn eine Möglichkeit die Standheizung auch über die VIS anzuschalten?
                                @Wszene hallo,
                                also ich hab mit dem Adapter keine neuen Probleme. hier mal ein log nach neustart. der Fehler "failing to refresh" mit nummer "400" tritt seit Wochen genau alle 54 minuten auf.... ansonten sind die Daten bei mir aktuell. adapter vers 0.21 Wagen Skoda Scala. aber mal sehen was Skoda in den nächsten Tagen macht . das app update soll "nach dem 4.1.2" verfügbar werden. ich warte also mal ab.
                                vw-connect.0	2020-12-04 01:53:01.474	error	(27052) 400
                                vw-connect.0	2020-12-04 01:53:01.468	error	(27052) Failing to refresh token.
                                host.raspberrypiiobroker	2020-12-04 01:45:13.752	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                host.raspberrypiiobroker	2020-12-04 01:45:13.658	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                host.raspberrypiiobroker	2020-12-04 01:45:08.882	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                                host.raspberrypiiobroker	2020-12-04 01:45:08.148	info	instance system.adapter.dwd.1 started with pid 29507
                                host.raspberrypiiobroker	2020-12-04 01:45:04.118	info	instance system.adapter.dwd.0 started with pid 29492
                                host.raspberrypiiobroker	2020-12-04 01:45:00.088	info	instance system.adapter.daswetter.0 started with pid 29473
                                host.raspberrypiiobroker	2020-12-04 01:30:21.863	info	instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
                                ical.1	2020-12-04 01:30:21.332	info	(28758) Terminated (NO_ERROR): Without reason
                                host.raspberrypiiobroker	2020-12-04 01:30:17.871	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                                ical.1	2020-12-04 01:30:16.184	info	(28758) processing URL: termine https://calendar.google.com/calendar/ical/dqk5mocnel98rb8s49b8dbppns%40group.calendar.google.com/private-8619eac97e9958684b0dc5575e2bd118/basic.ics
                                ical.1	2020-12-04 01:30:15.583	info	(28758) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.19.1, js-controller: 3.1.6
                                host.raspberrypiiobroker	2020-12-04 01:30:13.314	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                host.raspberrypiiobroker	2020-12-04 01:30:12.135	info	instance system.adapter.ical.1 started with pid 28758
                                host.raspberrypiiobroker	2020-12-04 01:30:11.308	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                host.raspberrypiiobroker	2020-12-04 01:30:08.106	info	instance system.adapter.daswetter.0 started with pid 28743
                                host.raspberrypiiobroker	2020-12-04 01:30:04.075	info	instance system.adapter.dwd.0 started with pid 28727
                                host.raspberrypiiobroker	2020-12-04 01:30:00.046	info	instance system.adapter.dwd.1 started with pid 28708
                                host.raspberrypiiobroker	2020-12-04 01:15:13.291	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                host.raspberrypiiobroker	2020-12-04 01:15:13.198	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                host.raspberrypiiobroker	2020-12-04 01:15:10.008	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                                host.raspberrypiiobroker	2020-12-04 01:15:08.111	info	instance system.adapter.dwd.1 started with pid 28003
                                host.raspberrypiiobroker	2020-12-04 01:15:04.079	info	instance system.adapter.dwd.0 started with pid 27988
                                host.raspberrypiiobroker	2020-12-04 01:15:00.048	info	instance system.adapter.daswetter.0 started with pid 27969
                                hm-rega.0	2020-12-04 01:11:08.724	warn	(781) Script "!# dutycycle.fn 0.3 string stderr; string stdout; system.Exec("/bin/sh -c '" # '" ignored, because still pending.
                                host.raspberrypiiobroker	2020-12-04 01:00:22.158	info	instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
                                ical.1	2020-12-04 01:00:21.621	info	(27176) Terminated (NO_ERROR): Without reason
                                host.raspberrypiiobroker	2020-12-04 01:00:18.405	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                                ical.1	2020-12-04 01:00:16.502	info	(27176) processing URL: termine https://calendar.google.com/calendar/ical/dqk5mocnel98rb8s49b8dbppns%40group.calendar.google.com/private-8619eac97e9958684b0dc5575e2bd118/basic.ics
                                ical.1	2020-12-04 01:00:15.914	info	(27176) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.19.1, js-controller: 3.1.6
                                host.raspberrypiiobroker	2020-12-04 01:00:13.802	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                host.raspberrypiiobroker	2020-12-04 01:00:12.723	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                host.raspberrypiiobroker	2020-12-04 01:00:12.147	info	instance system.adapter.ical.1 started with pid 27176
                                host.raspberrypiiobroker	2020-12-04 01:00:08.114	info	instance system.adapter.daswetter.0 started with pid 27155
                                host.raspberrypiiobroker	2020-12-04 01:00:04.083	info	instance system.adapter.dwd.0 started with pid 27138
                                host.raspberrypiiobroker	2020-12-04 01:00:00.054	info	instance system.adapter.dwd.1 started with pid 27119
                                vw-connect.0	2020-12-04 00:58:57.886	info	(27052) starting. Version 0.0.21 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v12.19.1, js-controller: 3.1.6
                                host.raspberrypiiobroker	2020-12-04 00:58:54.426	info	instance system.adapter.vw-connect.0 started with pid 27052
                                host.raspberrypiiobroker	2020-12-04 00:58:54.366	info	"system.adapter.vw-connect.0" enabled
                                normal müsste aus der vis der Start der Standheizung möglich sein. ich hab keine und kann das daher nicht testen , aber im objectsbereich "remote" gibt es ein Objekt da man ansprechen können müsste.
                                  aba320 @tombox last edited by
                                  @tombox Hallo, erst mal vielen Dank für die Adapterentwicklung. habe heute morgen einen neuen Fehler im Log entdeckt . als Anlage das log der vergangenen Nacht. (Neustart vw connect 0:58. ich hab alle 6Minuten für "update Interval" eingestellt und update erzwingen steht auf 0. man kann sehr schön sehen dass alle 54 Minuten also beim jedem 9. update der "update Refresh" fehler kommt. das ist aber schon seit mehreren Versionen so. aber um 7.05 kommt der neue Fehler " (27052) Error: read ECONNRESET" den kann ich nicht einordenen. die objekte haben aber neuere Zeitstempel (im moment 7:29).
                                  hm-rega.0	2020-12-04 07:17:09.202	warn	(781) Script "!# dutycycle.fn 0.3 string stderr; string stdout; system.Exec("/bin/sh -c '" # '" ignored, because still pending.
                                  vw-connect.0	2020-12-04 07:17:01.473	error	(27052) 400
                                  vw-connect.0	2020-12-04 07:17:01.473	error	(27052) Failing to refresh token.
                                  host.raspberrypiiobroker	2020-12-04 07:15:12.737	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 07:15:12.640	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 07:15:09.550	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                                  host.raspberrypiiobroker	2020-12-04 07:15:08.145	info	instance system.adapter.dwd.1 started with pid 12210
                                  host.raspberrypiiobroker	2020-12-04 07:15:04.110	info	instance system.adapter.dwd.0 started with pid 12195
                                  host.raspberrypiiobroker	2020-12-04 07:15:00.074	info	instance system.adapter.daswetter.0 started with pid 12176
                                  vw-connect.0	2020-12-04 07:11:08.673	error	(27052) Error: read ECONNRESET
                                  vw-connect.0	2020-12-04 07:11:08.662	error	(27052) Error: read ECONNRESET
                                  vw-connect.0	2020-12-04 07:11:08.646	error	(27052) Error: read ECONNRESET
                                  vw-connect.0	2020-12-04 07:11:08.638	error	(27052) Error: read ECONNRESET
                                  vw-connect.0	2020-12-04 07:05:08.646	error	(27052) Error: read ECONNRESET
                                  host.raspberrypiiobroker	2020-12-04 07:00:21.659	info	instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
                                  ical.1	2020-12-04 07:00:21.143	info	(11719) Terminated (NO_ERROR): Without reason
                                  host.raspberrypiiobroker	2020-12-04 07:00:17.433	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                                  ical.1	2020-12-04 07:00:16.018	info	(11719) processing URL: termine https://calendar.google.com/calendar/ical/dqk5mocnel98rb8s49b8dbppns%40group.calendar.google.com/private-8619eac97e9958684b0dc5575e2bd118/basic.ics
                                  ical.1	2020-12-04 07:00:15.509	info	(11719) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.19.1, js-controller: 3.1.6
                                  host.raspberrypiiobroker	2020-12-04 07:00:13.717	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 07:00:12.727	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 07:00:12.651	info	instance system.adapter.ical.1 started with pid 11719
                                  host.raspberrypiiobroker	2020-12-04 07:00:08.203	info	instance system.adapter.daswetter.0 started with pid 11698
                                  host.raspberrypiiobroker	2020-12-04 07:00:04.141	info	instance system.adapter.dwd.0 started with pid 11676
                                  hm-rega.0	2020-12-04 07:00:02.334	warn	(781) Script "!# dutycycle.fn 0.3 string stderr; string stdout; system.Exec("/bin/sh -c '" # '" ignored, because still pending.
                                  host.raspberrypiiobroker	2020-12-04 07:00:00.076	info	instance system.adapter.dwd.1 started with pid 11661
                                  pushover.0	2020-12-04 06:54:09.003	info	(1487) Send pushover notification: {"message":"Heizung normal","title":"Heizung","sound":"pushover","priority":"0"}
                                  hm-rega.0	2020-12-04 06:47:08.260	warn	(781) Script "!# dutycycle.fn 0.3 string stderr; string stdout; system.Exec("/bin/sh -c '" # '" ignored, because still pending.
                                  pushover.0	2020-12-04 06:45:40.258	info	(1487) Send pushover notification: {"message":"Dienst an","title":"Heizung","sound":"pushover","priority":-2}
                                  host.raspberrypiiobroker	2020-12-04 06:45:12.454	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 06:45:12.371	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 06:45:09.796	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                                  host.raspberrypiiobroker	2020-12-04 06:45:08.110	info	instance system.adapter.dwd.1 started with pid 11118
                                  host.raspberrypiiobroker	2020-12-04 06:45:04.076	info	instance system.adapter.dwd.0 started with pid 11098
                                  host.raspberrypiiobroker	2020-12-04 06:45:00.046	info	instance system.adapter.daswetter.0 started with pid 11083
                                  hm-rega.0	2020-12-04 06:41:08.450	warn	(781) Script "!# system.fn 0.1 !# !# Dieses Script gibt die FW-Versionsnummer und mehr systems" ignored, because still pending.
                                  pushover.0	2020-12-04 06:37:54.053	info	(1487) Send pushover notification: {"message":"Reise an","title":"Heizung","sound":"pushover","priority":-2}
                                  hm-rega.0	2020-12-04 06:35:07.995	warn	(781) Script "!# dutycycle.fn 0.3 string stderr; string stdout; system.Exec("/bin/sh -c '" # '" ignored, because still pending.
                                  host.raspberrypiiobroker	2020-12-04 06:30:21.925	info	instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
                                  ical.1	2020-12-04 06:30:21.398	info	(10490) Terminated (NO_ERROR): Without reason
                                  host.raspberrypiiobroker	2020-12-04 06:30:17.069	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                                  ical.1	2020-12-04 06:30:16.288	info	(10490) processing URL: termine https://calendar.google.com/calendar/ical/dqk5mocnel98rb8s49b8dbppns%40group.calendar.google.com/private-8619eac97e9958684b0dc5575e2bd118/basic.ics
                                  ical.1	2020-12-04 06:30:15.731	info	(10490) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.19.1, js-controller: 3.1.6
                                  host.raspberrypiiobroker	2020-12-04 06:30:12.494	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 06:30:12.196	info	instance system.adapter.ical.1 started with pid 10490
                                  host.raspberrypiiobroker	2020-12-04 06:30:09.977	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 06:30:08.166	info	instance system.adapter.daswetter.0 started with pid 10470
                                  host.raspberrypiiobroker	2020-12-04 06:30:04.134	info	instance system.adapter.dwd.0 started with pid 10455
                                  host.raspberrypiiobroker	2020-12-04 06:30:00.080	info	instance system.adapter.dwd.1 started with pid 10440
                                  hm-rega.0	2020-12-04 06:29:08.464	warn	(781) Script "!# system.fn 0.1 !# !# Dieses Script gibt die FW-Versionsnummer und mehr systems" ignored, because still pending.
                                  hm-rega.0	2020-12-04 06:23:08.188	warn	(781) Script "!# system.fn 0.1 !# !# Dieses Script gibt die FW-Versionsnummer und mehr systems" ignored, because still pending.
                                  vw-connect.0	2020-12-04 06:23:01.514	error	(27052) 400
                                  vw-connect.0	2020-12-04 06:23:01.504	error	(27052) Failing to refresh token.
                                  host.raspberrypiiobroker	2020-12-04 06:15:12.449	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 06:15:11.262	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 06:15:09.550	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                                  host.raspberrypiiobroker	2020-12-04 06:15:08.130	info	instance system.adapter.dwd.1 started with pid 9726
                                  host.raspberrypiiobroker	2020-12-04 06:15:04.098	info	instance system.adapter.dwd.0 started with pid 9711
                                  host.raspberrypiiobroker	2020-12-04 06:15:00.064	info	instance system.adapter.daswetter.0 started with pid 9696
                                  hm-rpc.2	2020-12-04 06:08:05.658	info	(826) Connected
                                  hm-rpc.2	2020-12-04 06:08:05.657	info	(826) new CUxD devices/channels after filter: 0
                                  hm-rpc.2	2020-12-04 06:08:05.588	info	(826) binrpc -> listDevices 18
                                  hm-rpc.2	2020-12-04 06:07:35.485	info	(826) Disconnected
                                  hm-rpc.2	2020-12-04 06:07:35.474	error	(826) Ping error: Error: response timeout
                                  systeminfo.0	2020-12-04 06:01:04.006	warn	(1570) Error TypeError: Cannot read property 'toString' of null in doPoll for System.Led_Red
                                  systeminfo.0	2020-12-04 06:01:03.006	warn	(1570) Error TypeError: Cannot read property 'toString' of null in doPoll for System.Led_Green
                                  host.raspberrypiiobroker	2020-12-04 06:00:21.591	info	instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
                                  ical.1	2020-12-04 06:00:21.063	info	(9047) Terminated (NO_ERROR): Without reason
                                  host.raspberrypiiobroker	2020-12-04 06:00:17.329	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                                  ical.1	2020-12-04 06:00:15.953	info	(9047) processing URL: termine https://calendar.google.com/calendar/ical/dqk5mocnel98rb8s49b8dbppns%40group.calendar.google.com/private-8619eac97e9958684b0dc5575e2bd118/basic.ics
                                  ical.1	2020-12-04 06:00:15.447	info	(9047) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.19.1, js-controller: 3.1.6
                                  host.raspberrypiiobroker	2020-12-04 06:00:13.346	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 06:00:12.561	info	instance system.adapter.ical.1 started with pid 9047
                                  host.raspberrypiiobroker	2020-12-04 06:00:10.147	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 06:00:08.187	info	instance system.adapter.daswetter.0 started with pid 9026
                                  host.raspberrypiiobroker	2020-12-04 06:00:04.124	info	instance system.adapter.dwd.0 started with pid 9009
                                  host.raspberrypiiobroker	2020-12-04 06:00:00.072	info	instance system.adapter.dwd.1 started with pid 8990
                                  hm-rpc.2	2020-12-04 05:55:30.469	info	(826) Connected
                                  hm-rpc.2	2020-12-04 05:55:30.468	info	(826) new CUxD devices/channels after filter: 0
                                  hm-rpc.2	2020-12-04 05:55:30.391	info	(826) binrpc -> listDevices 18
                                  hm-rpc.2	2020-12-04 05:55:00.308	info	(826) Disconnected
                                  hm-rpc.2	2020-12-04 05:55:00.303	error	(826) Ping error: Error: response timeout
                                  host.raspberrypiiobroker	2020-12-04 05:45:12.708	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 05:45:12.407	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 05:45:08.869	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                                  host.raspberrypiiobroker	2020-12-04 05:45:08.152	info	instance system.adapter.dwd.1 started with pid 8356
                                  host.raspberrypiiobroker	2020-12-04 05:45:04.122	info	instance system.adapter.dwd.0 started with pid 8341
                                  host.raspberrypiiobroker	2020-12-04 05:45:00.089	info	instance system.adapter.daswetter.0 started with pid 8322
                                  host.raspberrypiiobroker	2020-12-04 05:30:21.892	info	instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
                                  ical.1	2020-12-04 05:30:21.355	info	(7694) Terminated (NO_ERROR): Without reason
                                  host.raspberrypiiobroker	2020-12-04 05:30:17.318	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                                  ical.1	2020-12-04 05:30:16.244	info	(7694) processing URL: termine https://calendar.google.com/calendar/ical/dqk5mocnel98rb8s49b8dbppns%40group.calendar.google.com/private-8619eac97e9958684b0dc5575e2bd118/basic.ics
                                  ical.1	2020-12-04 05:30:15.701	info	(7694) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.19.1, js-controller: 3.1.6
                                  host.raspberrypiiobroker	2020-12-04 05:30:12.528	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 05:30:12.196	info	instance system.adapter.ical.1 started with pid 7694
                                  host.raspberrypiiobroker	2020-12-04 05:30:10.033	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 05:30:08.165	info	instance system.adapter.daswetter.0 started with pid 7679
                                  host.raspberrypiiobroker	2020-12-04 05:30:04.110	info	instance system.adapter.dwd.0 started with pid 7660
                                  host.raspberrypiiobroker	2020-12-04 05:30:00.076	info	instance system.adapter.dwd.1 started with pid 7645
                                  vw-connect.0	2020-12-04 05:29:01.503	error	(27052) 400
                                  vw-connect.0	2020-12-04 05:29:01.491	error	(27052) Failing to refresh token.
                                  hm-rega.0	2020-12-04 05:17:08.531	warn	(781) Script "!# system.fn 0.1 !# !# Dieses Script gibt die FW-Versionsnummer und mehr systems" ignored, because still pending.
                                  host.raspberrypiiobroker	2020-12-04 05:15:12.998	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 05:15:12.887	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 05:15:08.907	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                                  host.raspberrypiiobroker	2020-12-04 05:15:08.157	info	instance system.adapter.dwd.1 started with pid 7000
                                  host.raspberrypiiobroker	2020-12-04 05:15:04.127	info	instance system.adapter.dwd.0 started with pid 6981
                                  host.raspberrypiiobroker	2020-12-04 05:15:00.094	info	instance system.adapter.daswetter.0 started with pid 6966
                                  hm-rega.0	2020-12-04 05:11:08.201	warn	(781) Script "!# system.fn 0.1 !# !# Dieses Script gibt die FW-Versionsnummer und mehr systems" ignored, because still pending.
                                  hm-rega.0	2020-12-04 05:05:08.112	warn	(781) Script "!# system.fn 0.1 !# !# Dieses Script gibt die FW-Versionsnummer und mehr systems" ignored, because still pending.
                                  host.raspberrypiiobroker	2020-12-04 05:00:22.265	info	instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
                                  ical.1	2020-12-04 05:00:21.729	info	(6340) Terminated (NO_ERROR): Without reason
                                  host.raspberrypiiobroker	2020-12-04 05:00:17.417	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                                  ical.1	2020-12-04 05:00:16.623	info	(6340) processing URL: termine https://calendar.google.com/calendar/ical/dqk5mocnel98rb8s49b8dbppns%40group.calendar.google.com/private-8619eac97e9958684b0dc5575e2bd118/basic.ics
                                  ical.1	2020-12-04 05:00:16.072	info	(6340) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.19.1, js-controller: 3.1.6
                                  host.raspberrypiiobroker	2020-12-04 05:00:12.702	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 05:00:12.211	info	instance system.adapter.ical.1 started with pid 6340
                                  host.raspberrypiiobroker	2020-12-04 05:00:10.272	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 05:00:08.182	info	instance system.adapter.daswetter.0 started with pid 6315
                                  host.raspberrypiiobroker	2020-12-04 05:00:04.130	info	instance system.adapter.dwd.0 started with pid 6284
                                  host.raspberrypiiobroker	2020-12-04 05:00:00.083	info	instance system.adapter.dwd.1 started with pid 6262
                                  hm-rega.0	2020-12-04 04:59:08.082	warn	(781) Script "!# dutycycle.fn 0.3 string stderr; string stdout; system.Exec("/bin/sh -c '" # '" ignored, because still pending.
                                  hm-rega.0	2020-12-04 04:53:08.297	warn	(781) Script "!# system.fn 0.1 !# !# Dieses Script gibt die FW-Versionsnummer und mehr systems" ignored, because still pending.
                                  host.raspberrypiiobroker	2020-12-04 04:45:13.794	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 04:45:13.353	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 04:45:09.329	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                                  host.raspberrypiiobroker	2020-12-04 04:45:08.160	info	instance system.adapter.dwd.1 started with pid 5633
                                  host.raspberrypiiobroker	2020-12-04 04:45:04.129	info	instance system.adapter.dwd.0 started with pid 5617
                                  host.raspberrypiiobroker	2020-12-04 04:45:00.096	info	instance system.adapter.daswetter.0 started with pid 5595
                                  vw-connect.0	2020-12-04 04:35:01.481	error	(27052) 400
                                  vw-connect.0	2020-12-04 04:35:01.475	error	(27052) Failing to refresh token.
                                  host.raspberrypiiobroker	2020-12-04 04:30:22.144	info	instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
                                  ical.1	2020-12-04 04:30:21.610	info	(4975) Terminated (NO_ERROR): Without reason
                                  host.raspberrypiiobroker	2020-12-04 04:30:17.174	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                                  ical.1	2020-12-04 04:30:16.498	info	(4975) processing URL: termine https://calendar.google.com/calendar/ical/dqk5mocnel98rb8s49b8dbppns%40group.calendar.google.com/private-8619eac97e9958684b0dc5575e2bd118/basic.ics
                                  ical.1	2020-12-04 04:30:15.967	info	(4975) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.19.1, js-controller: 3.1.6
                                  host.raspberrypiiobroker	2020-12-04 04:30:13.024	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 04:30:12.218	info	instance system.adapter.ical.1 started with pid 4975
                                  host.raspberrypiiobroker	2020-12-04 04:30:10.529	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 04:30:08.188	info	instance system.adapter.daswetter.0 started with pid 4956
                                  host.raspberrypiiobroker	2020-12-04 04:30:04.130	info	instance system.adapter.dwd.0 started with pid 4940
                                  host.raspberrypiiobroker	2020-12-04 04:30:00.080	info	instance system.adapter.dwd.1 started with pid 4921
                                  host.raspberrypiiobroker	2020-12-04 04:15:13.215	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 04:15:13.057	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 04:15:09.463	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                                  host.raspberrypiiobroker	2020-12-04 04:15:08.140	info	instance system.adapter.dwd.1 started with pid 4280
                                  host.raspberrypiiobroker	2020-12-04 04:15:04.110	info	instance system.adapter.dwd.0 started with pid 4265
                                  host.raspberrypiiobroker	2020-12-04 04:15:00.076	info	instance system.adapter.daswetter.0 started with pid 4246
                                  host.raspberrypiiobroker	2020-12-04 04:00:22.011	info	instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
                                  ical.1	2020-12-04 04:00:21.481	info	(3599) Terminated (NO_ERROR): Without reason
                                  host.raspberrypiiobroker	2020-12-04 04:00:17.101	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                                  ical.1	2020-12-04 04:00:16.368	info	(3599) processing URL: termine https://calendar.google.com/calendar/ical/dqk5mocnel98rb8s49b8dbppns%40group.calendar.google.com/private-8619eac97e9958684b0dc5575e2bd118/basic.ics
                                  ical.1	2020-12-04 04:00:15.711	info	(3599) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.19.1, js-controller: 3.1.6
                                  host.raspberrypiiobroker	2020-12-04 04:00:12.612	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 04:00:12.209	info	instance system.adapter.ical.1 started with pid 3599
                                  host.raspberrypiiobroker	2020-12-04 04:00:10.469	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 04:00:08.180	info	instance system.adapter.daswetter.0 started with pid 3578
                                  host.raspberrypiiobroker	2020-12-04 04:00:04.143	info	instance system.adapter.dwd.0 started with pid 3556
                                  host.raspberrypiiobroker	2020-12-04 04:00:00.083	info	instance system.adapter.dwd.1 started with pid 3541
                                  hm-rega.0	2020-12-04 03:53:08.355	warn	(781) Script "!# system.fn 0.1 !# !# Dieses Script gibt die FW-Versionsnummer und mehr systems" ignored, because still pending.
                                  host.raspberrypiiobroker	2020-12-04 03:45:13.906	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 03:45:13.638	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 03:45:09.171	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                                  host.raspberrypiiobroker	2020-12-04 03:45:08.154	info	instance system.adapter.dwd.1 started with pid 2869
                                  host.raspberrypiiobroker	2020-12-04 03:45:04.120	info	instance system.adapter.dwd.0 started with pid 2850
                                  host.raspberrypiiobroker	2020-12-04 03:45:00.086	info	instance system.adapter.daswetter.0 started with pid 2835
                                  hm-rpc.2	2020-12-04 03:44:25.289	info	(826) Connected
                                  hm-rpc.2	2020-12-04 03:44:25.288	info	(826) new CUxD devices/channels after filter: 0
                                  hm-rpc.2	2020-12-04 03:44:25.216	info	(826) binrpc -> listDevices 18
                                  hm-rpc.2	2020-12-04 03:44:00.135	error	(826) Error on listDevices: Error: response timeout
                                  hm-rpc.2	2020-12-04 03:43:25.127	info	(826) Disconnected
                                  hm-rpc.2	2020-12-04 03:43:25.117	error	(826) Ping error: Error: response timeout
                                  vw-connect.0	2020-12-04 03:41:01.460	error	(27052) 400
                                  vw-connect.0	2020-12-04 03:41:01.454	error	(27052) Failing to refresh token.
                                  hm-rega.0	2020-12-04 03:35:08.376	warn	(781) Script "!# system.fn 0.1 !# !# Dieses Script gibt die FW-Versionsnummer und mehr systems" ignored, because still pending.
                                  host.raspberrypiiobroker	2020-12-04 03:30:22.015	info	instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
                                  ical.1	2020-12-04 03:30:21.483	info	(2205) Terminated (NO_ERROR): Without reason
                                  host.raspberrypiiobroker	2020-12-04 03:30:17.144	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                                  ical.1	2020-12-04 03:30:16.377	info	(2205) processing URL: termine https://calendar.google.com/calendar/ical/dqk5mocnel98rb8s49b8dbppns%40group.calendar.google.com/private-8619eac97e9958684b0dc5575e2bd118/basic.ics
                                  ical.1	2020-12-04 03:30:15.780	info	(2205) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.19.1, js-controller: 3.1.6
                                  host.raspberrypiiobroker	2020-12-04 03:30:13.164	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 03:30:12.218	info	instance system.adapter.ical.1 started with pid 2205
                                  host.raspberrypiiobroker	2020-12-04 03:30:10.496	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 03:30:08.187	info	instance system.adapter.daswetter.0 started with pid 2186
                                  host.raspberrypiiobroker	2020-12-04 03:30:04.137	info	instance system.adapter.dwd.0 started with pid 2171
                                  host.raspberrypiiobroker	2020-12-04 03:30:00.080	info	instance system.adapter.dwd.1 started with pid 2156
                                  hm-rpc.2	2020-12-04 03:29:50.094	info	(826) Connected
                                  hm-rpc.2	2020-12-04 03:29:50.093	info	(826) new CUxD devices/channels after filter: 0
                                  hm-rpc.2	2020-12-04 03:29:50.008	info	(826) binrpc -> listDevices 18
                                  hm-rpc.2	2020-12-04 03:29:19.906	info	(826) Disconnected
                                  hm-rpc.2	2020-12-04 03:29:19.859	error	(826) Ping error: Error: response timeout
                                  hm-rega.0	2020-12-04 03:29:08.344	warn	(781) Script "!# system.fn 0.1 !# !# Dieses Script gibt die FW-Versionsnummer und mehr systems" ignored, because still pending.
                                  host.raspberrypiiobroker	2020-12-04 03:15:13.702	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 03:15:13.617	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 03:15:09.214	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                                  host.raspberrypiiobroker	2020-12-04 03:15:08.138	info	instance system.adapter.dwd.1 started with pid 1351
                                  host.raspberrypiiobroker	2020-12-04 03:15:04.106	info	instance system.adapter.dwd.0 started with pid 1336
                                  host.raspberrypiiobroker	2020-12-04 03:15:00.071	info	instance system.adapter.daswetter.0 started with pid 1321
                                  hm-rega.0	2020-12-04 03:11:08.390	warn	(781) Script "!# system.fn 0.1 !# !# Dieses Script gibt die FW-Versionsnummer und mehr systems" ignored, because still pending.
                                  host.raspberrypiiobroker	2020-12-04 03:00:21.855	info	instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
                                  ical.1	2020-12-04 03:00:21.337	info	(532) Terminated (NO_ERROR): Without reason
                                  host.raspberrypiiobroker	2020-12-04 03:00:17.167	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                                  ical.1	2020-12-04 03:00:16.198	info	(532) processing URL: termine https://calendar.google.com/calendar/ical/dqk5mocnel98rb8s49b8dbppns%40group.calendar.google.com/private-8619eac97e9958684b0dc5575e2bd118/basic.ics
                                  ical.1	2020-12-04 03:00:15.663	info	(532) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.19.1, js-controller: 3.1.6
                                  host.raspberrypiiobroker	2020-12-04 03:00:12.860	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 03:00:12.164	info	instance system.adapter.ical.1 started with pid 532
                                  host.raspberrypiiobroker	2020-12-04 03:00:09.997	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 03:00:08.133	info	instance system.adapter.daswetter.0 started with pid 507
                                  host.raspberrypiiobroker	2020-12-04 03:00:04.101	info	instance system.adapter.dwd.0 started with pid 487
                                  host.raspberrypiiobroker	2020-12-04 03:00:00.072	info	instance system.adapter.dwd.1 started with pid 467
                                  hm-rega.0	2020-12-04 02:47:08.992	warn	(781) Script "!# dutycycle.fn 0.3 string stderr; string stdout; system.Exec("/bin/sh -c '" # '" ignored, because still pending.
                                  vw-connect.0	2020-12-04 02:47:01.471	error	(27052) 400
                                  vw-connect.0	2020-12-04 02:47:01.465	error	(27052) Failing to refresh token.
                                  host.raspberrypiiobroker	2020-12-04 02:45:13.601	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 02:45:13.542	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 02:45:09.155	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                                  host.raspberrypiiobroker	2020-12-04 02:45:08.154	info	instance system.adapter.dwd.1 started with pid 32283
                                  host.raspberrypiiobroker	2020-12-04 02:45:04.123	info	instance system.adapter.dwd.0 started with pid 32267
                                  host.raspberrypiiobroker	2020-12-04 02:45:00.093	info	instance system.adapter.daswetter.0 started with pid 32247
                                  host.raspberrypiiobroker	2020-12-04 02:30:22.210	info	instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
                                  ical.1	2020-12-04 02:30:21.678	info	(31607) Terminated (NO_ERROR): Without reason
                                  host.raspberrypiiobroker	2020-12-04 02:30:17.461	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                                  ical.1	2020-12-04 02:30:16.570	info	(31607) processing URL: termine https://calendar.google.com/calendar/ical/dqk5mocnel98rb8s49b8dbppns%40group.calendar.google.com/private-8619eac97e9958684b0dc5575e2bd118/basic.ics
                                  ical.1	2020-12-04 02:30:15.977	info	(31607) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.19.1, js-controller: 3.1.6
                                  host.raspberrypiiobroker	2020-12-04 02:30:13.206	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 02:30:12.185	info	instance system.adapter.ical.1 started with pid 31607
                                  host.raspberrypiiobroker	2020-12-04 02:30:10.756	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 02:30:08.152	info	instance system.adapter.daswetter.0 started with pid 31592
                                  host.raspberrypiiobroker	2020-12-04 02:30:04.083	info	instance system.adapter.dwd.0 started with pid 31572
                                  host.raspberrypiiobroker	2020-12-04 02:30:00.046	info	instance system.adapter.dwd.1 started with pid 31556
                                  hm-rega.0	2020-12-04 02:23:08.631	warn	(781) Script "!# system.fn 0.1 !# !# Dieses Script gibt die FW-Versionsnummer und mehr systems" ignored, because still pending.
                                  hm-rega.0	2020-12-04 02:17:08.415	warn	(781) Script "!# dutycycle.fn 0.3 string stderr; string stdout; system.Exec("/bin/sh -c '" # '" ignored, because still pending.
                                  host.raspberrypiiobroker	2020-12-04 02:15:13.187	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 02:15:13.122	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 02:15:09.802	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                                  host.raspberrypiiobroker	2020-12-04 02:15:08.109	info	instance system.adapter.dwd.1 started with pid 30915
                                  host.raspberrypiiobroker	2020-12-04 02:15:04.075	info	instance system.adapter.dwd.0 started with pid 30896
                                  host.raspberrypiiobroker	2020-12-04 02:15:00.045	info	instance system.adapter.daswetter.0 started with pid 30880
                                  hm-rega.0	2020-12-04 02:05:08.216	warn	(781) Script "!# dutycycle.fn 0.3 string stderr; string stdout; system.Exec("/bin/sh -c '" # '" ignored, because still pending.
                                  host.raspberrypiiobroker	2020-12-04 02:00:24.398	info	instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
                                  ical.1	2020-12-04 02:00:23.883	info	(30211) Terminated (NO_ERROR): Without reason
                                  host.raspberrypiiobroker	2020-12-04 02:00:20.732	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                                  ical.1	2020-12-04 02:00:17.252	info	(30211) processing URL: termine https://calendar.google.com/calendar/ical/dqk5mocnel98rb8s49b8dbppns%40group.calendar.google.com/private-8619eac97e9958684b0dc5575e2bd118/basic.ics
                                  ical.1	2020-12-04 02:00:16.620	info	(30211) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.19.1, js-controller: 3.1.6
                                  host.raspberrypiiobroker	2020-12-04 02:00:13.658	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 02:00:12.920	info	instance system.adapter.ical.1 started with pid 30211
                                  host.raspberrypiiobroker	2020-12-04 02:00:11.168	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypiiobroker	2020-12-04 02:00:08.176	info	instance system.adapter.daswetter.0 started with pid 30183
                                  host.raspberrypiiobroker	2020-12-04 02:00:04.114	info	instance system.adapter.dwd.0 started with pid 30162
                                  host.raspberrypiiobroker	2020-12-04 02:00:00.080	info	instance system.adapter.dwd.1 started with pid 30147
                                  App version 0.21 wagen Skoda scala.
                                  • Wszene
                                    @aba320 sagte in Test Adapter VW Connect v0.0.x für VW We Connect, ID:
                                    @Wszene hallo,
                                    Die Datenpunkte habe ich auch schon gesehen aber ich habe momentan keine Idee wie ich das Thema angehen kann
                                    Am Schönsten wäre es ja so eine Ansicht wie in der App zu machen
                                    standheizungpng
                                    Die Standheizung bzw. die Lüftung ist für mich der einzige Grund die App zu nutzen.
                                    Wenn ich das über die VIS machen könnte bräuchte ich Diese dann nicht mehr
                                    J T 2 Replies Last reply Reply Quote 0
                                      jhg @Wszene last edited by
                                      Eben auch den aktualisierten Adapter installiert.
                                      Der ID.3 wird erkannt und es kommen auch direkt eine Menge Informationen.
                                      Mal schauen was er morgen noch anzeigt, nachdem ich gefahren bin.
                                      Die Gesamtkilometer fehlen mir aktuell.
                                      Aber sonst sind viele Informationen da.
                                      @tombox Vielen Dank für die Arbeit.
                                        @Wszene Ich würde mir das nochmal im Detail anschauen wenn die neue skoda app da ist
                                        Wszene 1 Reply Last reply Reply Quote 1
                                        • Wszene
                                          @tombox sagte in Test Adapter VW Connect v0.0.x für VW We Connect, ID:
                                          Ich danke dir
                                            Der ID.3 übermittelt wohl im Moment weder die Gesamtkilometer noch den aktuellen Standort.
                                            Der Adapter stellt wohl wirklich alle Informationen dar, die verfügbar sind.
                                            Und das ist auch alles recht zeitnah.
                                            Soweit also alles prima.
                                            audi id.3 myaudi seat skoda skoda connect volkswagen vw id we connect wecharge
                                            391
                                            3049
                                            1510026
