    4. Sleeptimer mit Countdown
      pix last edited by
      Exportiere mal dein Widget hier rein.
        a-flow last edited by
        Hier meine Widgets… Sie unterscheiden sich aber fast gar nicht von deinen!
        [{"tpl":"tplHqCircle","data":{"visibility-cond":">","visibility-val":"0","oid":"javascript.0.Countdown.Sleeptimer.countdown_seconds","min":"0","max":"javascript.0.Countdown.Sleeptimer.countdown_seconds","step":"1","displayPrevious":true,"readOnly":true,"unit":" s","visibility-oid":"","name":"Countdown","caption":"bis zur Aktivierung","hideNumber":false,"color":"#ffffff","thickness":"0.15","cursor":"","bgcolor":"#f00f36","linecap":true,"anticlockwise":false,"oid-working":"javascript.0.Countdown.Sleeptimer.countdown_seconds","oid-signal":"","angleArc":"360","angleOffset":"0","comment":"","digits":"0","is_comma":"true","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false},"style":{"left":"450px","top":"170px","width":"200px","height":"200px","z-index":"80","text-align":"center","color":"#e7f5f9","font-family":"","font-style":"","font-weight":"","font-size":"","background-color":"rgba(0,140,200,1)","border-radius":"490px"},"widgetSet":"hqwidgets"},{"tpl":"tplValueStringRaw","data":{"oid":"javascript.0.Countdown.Sleeptimer.countdown","visibility-cond":"==","visibility-val":1,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false},"style":{"left":"650px","top":"210px","z-index":"20","color":"white","width":"137px","height":"32px"},"widgetSet":"basic"},{"tpl":"tplJquiButtonState","data":{"oid":"javascript.0.Countdown.Sleeptimer.trigger30min","visibility-cond":"==","visibility-val":1,"buttontext":"30","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"value":"true"},"style":{"left":"670px","top":"270px"},"widgetSet":"jqui"},{"tpl":"tplJquiButtonState","data":{"oid":"javascript.0.Countdown.Sleeptimer.trigger60min","visibility-cond":"==","visibility-val":1,"buttontext":"60","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"value":"true"},"style":{"left":"670px","top":"310px"},"widgetSet":"jqui"}]
        Das Java-Skript habe ich unter folgendem Pfad abgelegt: /global/sleeptimer/. Im Skript selbst habe ich gar nichts geändert.
        • htrecksler
          htrecksler Forum Testing last edited by
          eines ganz schnell vorweg…
          Scripte die unter "global" liegen werden an alle anderen scripte angehängt. Es dort abzulegen ist sicher "suboptimal"
          • htrecksler
            sieht das bei dir unter Objekte –> Javascript.0 (außer den bose-Punkten) genauso aus?
            • htrecksler
              und das script ist auch gestartet?
                @htrecksler: Danke für Deine Mühe! Ich habe das Skript jetzt von GLOBAL nach COMMON gepackt. Alles andere, was du geschrieben hast, habe ich kontrolliert. Was mir nur aufgefallen ist, dass mir der Unterordner "1" im Ordner "Countdown" fehlt. Bei mir ist da lediglich der Ordner "Sleeptimer" aufgeführt.
                LEIDER läuft der Countdown immer noch nicht 😞
                  Arminhh last edited by
                  @a-flow:
                  LEIDER läuft der Countdown immer noch nicht 😞 `
                  Hallo Pix,
                  super Arbeit.
                  Dieser Unterordner wurde bei mir auch nicht angelegt. Versuche ich nacher mal per Hand. Unter Vis läuft soweit der Counter.
                  Würde evt. die Möglichkeit bestehen einen 3 ten Button wo eine individuelle Zeit möglich ist einzufügen?
                  mfg
                  Armin
                    pix last edited by
                    @a-flow:
                    Der Unterordner 1 im Ordner Countdown ist ein anderer Countdown als der Sleeptimer. Den brauchst du nicht.
                    Was läuft denn nicht?
                    Startet der Countdown nicht? Null er nicht? Zählt er nicht runter? Keine Aktion nach Ablauf?
                    @Arminhh:
                    Würde evt. die Möglichkeit bestehen einen 3 ten Button wo eine individuelle Zeit möglich ist einzufügen? `
                    Kannst du das umformulieren? In JavaScript hast du (fast) alle Möglichkeiten. Was ist eine individuelle Zeit? Fragst du, ob das jemand programmieren kann? 😄 🙂 😉
                    Pix
                      a-flow2 last edited by
                      nach einer kleinen Pause habe ich mich jetzt nochmal versucht das Skript zum Laufen zu bekommen. Leider klappt es immer noch nicht.
                      Nachstehend habe ich mal beschrieben, wie ich die Funktion in meine View eingebaut habe. Vielleicht habe ich irgendwas falsch gemacht oder einfach etwas vergessen.
                      Kopieren des Skripts
                      Das Skript von Pix habe ich einfach aus dem Forum in mein ioBroker unter Skripte kopiert (siehe Screenshots). Selbstverständlich habe ich das Skript auch gestartet.
                      Screenshot:
                      ! ![](</s><URL url=)http://www.a-flow.de/bilder/timer_01.jpg" /> ~~Importieren des Widgets
                      Das Widget-Code habe ich aus dem Forum kopiert und damit das Widget in Vis importiert. Anschließend habe ich, soweit ich es überblickt habe, sämtliche Pfadangaben im Widget zu Skript-Variablen angepasst (siehe Screenshot). Hier nochmal ausführlich, welche Pfadangaben ich geändert habe:
                      • *Button 30: Objekt-ID: javascript.0.Countdown.Sleeptimer.trigger30min
                      *Button 60: Objekt-ID: javascript.0.Countdown.Sleeptimer.trigger60min
                      *Kreisdiagramm: Objekt-ID: javascript.0.Countdown.Sleeptimer.countdown_seconds
                      *Kreisdiagramm: In Arbeit Zustand ID: javascript.0.Countdown.Sleeptimer.countdown_seconds
                      *Kreisdiagramm: Wert Max.: {javascript.0.Countdown.Sleeptimer.countdown_seconds}
                      Screenshot:
                      ! ![](</s><URL url=)http://www.a-flow.de/bilder/timer_02.jpg" /> ~~Wenn ich die View starte und dann auf einen der Buttons drücke, passiert nichts. Soweit ich es überblicke, wird auch nirgends eine Art Fehlerlog gespeichert.
                      Ich würde mich sehr freuen, wenn mir jemand hilft das Teil zum Laufen zu bekommen!
                      Viele Grüße
                      Andi~~~~
                        pix last edited by
                        Hallo Andi,
                        ist ein wenig schwieriger, nach zwei Monaten aus dem Thema wieder da hinein zukommen.
                        Hast du dieses Skript genutzt? http://forum.iobroker.net/viewtopic.php … 436#p31882
                        Bei Armin geht es, wie er schreibt~~@Arminhh:~~
                        Hallo Pix,
                        super Arbeit.
                        mfg
                        Armin `
                        Kommen irgendwann die Log-Zeilen
                        <size size="85">Countdown abgelaufen
                        X min Sleeptimer gestartet/gestoppt</size> ?
                        Ändern sich die Objekte nach dem Start einem Tastendruck auf 30 oder 60?
                        Pix
                          Ja, ich habe genau das Skript aus deinem Post genommen.
                          Soweit ich es erkennen kann, kommen keine Logs. Wo genau sollen die Logs kommen? In ioBroker/Logs oder in ioBroker/Skripte/Logs?
                          Vielleicht fehlt etwas Grundlegendes… ich habe bisher noch nicht mit Skripten gearbeitet und das ist das einzige Skript, was bei mir läuft.
                            pix last edited by
                            Okay, dann testen wir erstmal deine Installation.
                            Deaktiviere das Skript und erstelle ein Weiteres im Ordner "common"
                            Inhalt:
                            log('Hallo Welt!');
                            ````Wenn du dieses Skript gespeichert und aktiviert hast, sollte natürlich im Log "Hallo Welt" stehen.
                            Logs, welche das aktuell im Editor gezeigte Skript betreffen,w erden darunter dargestellt. Alle Logs aller Skript im Reiter Admin/Logs oder in der Logdatei auf dem Server.
                            Pix
                              stephan61 last edited by
                              Hallo Aflow hast du unter Instanzen javascript getsartet?
                              Gruß Stephan
                                @Stephan61: Javaskript unter Instanzen ist gestartet gewesen.
                                @Pix: Das mit dem Log schein zu funktionieren. Es erscheint folgendes im Log:
                                javascript-0
                                2016-10-18 11:51:21.323
                                info
                                script.js.common.Skript1: registered 0 subscriptions and 0 schedules
                                javascript-0
                                2016-10-18 11:51:21.322
                                info
                                script.js.common.Skript1: Hallo Welt!
                                javascript-0
                                2016-10-18 11:51:21.317
                                info
                                Start javascript script.js.common.Skript1
                                  baluderbär last edited by
                                  die Visualisierung gefällt mir (Widget) und würde sie gerne bei mir einbinden, inkl. des Skripts.
                                  Nur müsste das Skript ein wenig angepasst werden.
                                  <u>Funktionsweise</u>: Wenn Variable Alarmanlage=true, dann zeige das Widget mit dem Countdown und starte den Timer und werde unsichtbar, wenn Timer bei 0s.
                                  Kann mir jemand dabei helfen?
                                  Danke und Gruß Balu
                                    pix last edited by
                                    Hallo balu,
                                    es reicht, wenn der Countdown angezeigt wird, wenn die Restzeit/Timer größer als 0s ist.
                                    Du schreibst in den Einstellungen des Widgets unter Sichtbarkeit OID den Datenpunkt des TImers (in Sekunden) und als Bedingung > 0
                                    Ob die Alarmanlage dabei ein oder aus ist, spielt doch eigentlich keine Rolle.
                                    Pix
                                      Hallo Pix,
                                      erstmal danke. Das mit dem Widget habe ich verstanden.
                                      Wie muss ich das Skript anpassen, dass der Timer los läuft, wenn eine bestimmte Variable=true ist?
                                      Gruß Balu
                                      Edit: hab es jetzt angepasst, funktioniert sogar.
                                      Wer evtl. das gleiche "Problem" hat, hier das Skript.
                                      hm-rega.0.xxxxx startet den Timer (in meinem Fall wenn alle Personen abwesend sind)
                                      hm-rega.0.yyyyy schaltet dann den Alarm scharf
                                      ` > createState('countdown', 20);
                                      function count() {
                                      setTimeout(function () {
                                      var timer = getState('countdown').val || 20;
                                      if (timer > 1) {
                                      setState("hm-rega.0.xxxxx", false);
                                      setState('countdown', timer - 1);
                                      count();
                                      } else {
                                      setState('countdown', 0);
                                      setState("hm-rega.0.yyyyy", true);
                                      }, 1000);
                                      on("hm-rega.0.xxxxx", function (obj) {
                                      if (obj.newState.val === true || obj.newState.val === 'true' || obj.newState.val == 1) {
                                      setState('countdown', 20);
                                      setState("hm-rega.0.yyyyy", false);
                                      count();
                                      Super, wie einem hier geholfen wird. Daumen hoch
                                      Danke und Gruß
                                      Balu
                                      8982
