    4. Pushsafer
    Pushsafer
    • Bluefox
      Bluefox last edited by
      @pix: Ich habe pushsafer upgedated und auch Bildübertragung gemacht.
      Kannst du vom git ausprobieren?
        pix last edited by
        Hallo Bluefox,
        ist gerade knapp mit der Zeit. Aber am WE werd ichs hinbekommen. Danke für die Anpassung.
        Pix
          pix last edited by
          Hallo Bluefox,
          ich habe das Update von Github geladen und ein Testskript gebaut:
          sendTo("pushsafer", {
                  message:   'Test text',   // mandatory - your text message
                  title:     'SweetHome',   // optional  - your message's title, otherwise your app's name is used
                  device:    '322',          // optional  - a device id or device group id (empty or a = all devices)
                  sound:     '2',           // optional  - a number betwenn 0-28 (see pushsafers API description)
                  icon:      '2',           // optional  - a number betwenn 1-98 (see pushsafers API description)
                  vibration: '3'           // optional  - a number betwenn 0-3 (see pushsafers API description)
                  //picture:   '/Users/pix/Documents/iobroker/node_modules/iobroker.phantomjs/picture.png'  // optional - absolute path to picture or base64 coded image URL
                  //picture2:  'absolutePathToPicture2', // optional - absolute path to picture or base64 coded image URL
                  //picture3:  'absolutePathToPicture3', // optional - absolute path to picture or base64 coded image URL
                  //url:       'http://blabla',// optional - URL in the link
                  //urlTitle:  'Link to BLA'  // optional - title of URL
          Leider kommt nun immer dieser Fehler:
          2016-10-14 22:54:26.201  - [31merror[39m: host. pmessage messagebox.system.adapter.pushsafer.0 {"command":"send","message":{"message":"Test text","title":"SweetHome","device":"322","sound":"2","icon":"2","vibration":"3"},"from":"system.adapter.javascript.2","_id":22791782} Cannot read property 'log' of undefined
          2016-10-14 22:54:26.201  - [31merror[39m: host. TypeError: Cannot read property 'log' of undefined
              at sendNotification (/Users/pix/Documents/iobroker/node_modules/iobroker.pushsafer/pushsafer.js:89:44)
              at processMessage (/Users/pix/Documents/iobroker/node_modules/iobroker.pushsafer/pushsafer.js:62:5)
              at Adapter. <anonymous>(/Users/pix/Documents/iobroker/node_modules/iobroker.pushsafer/pushsafer.js:20:40)
              at emitOne (events.js:77:13)
              at Adapter.emit (events.js:169:7)
              at that.states.States.change (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2103:34)
              at RedisClient. <anonymous>(/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:90:25)
              at emitThree (events.js:97:13)
              at RedisClient.emit (events.js:175:7)
              at return_pub_sub (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/redis/index.js:782:18)</anonymous></anonymous>
          Der Adapter wurde in dieser Verison also nicht von mir verändert.
          Zum Testen des Bildversands komme ich nicht, wenn der Text schon nicht durchgeht. 322 für Device ist korrekt.
          Pix
            pix last edited by
            Test in den Adapter Einstellungen funktioniert leider nicht (auch nicht nach Neustart ioBroker):
            2016-10-15 00:10:33.322 - [31merror[39m: host. pmessage messagebox.system.adapter.pushsafer.0 {"command":"send","message":"This is test notification!","from":"system.adapter.admin.0","callback":{"message":"This is test notification!","id":6,"ack":false,"time":1476483033321},"_id":31033365} Cannot read property 'log' of undefined
            2016-10-15 00:10:33.322 - [31merror[39m: host. TypeError: Cannot read property 'log' of undefined
            Eingestellter Schlüssel ist natürlich korrekt!
            Pix
              pix last edited by
              alte Instanz gelöscht,
              Update von Github gemacht
              Neue Instanz gebaut
              Neuer Fehler beim Senden der Testnachricht aus Einstellungen:
              2016-10-15 18:40:53.905 - [32minfo[39m: pushsafer.0 starting. Version 0.1.5 in /Users/pix/Documents/iobroker/node_modules/iobroker.pushsafer
              2016-10-15 18:40:53.922 - [31merror[39m: uncaught exception: Cannot read property 'toString' of undefined
              2016-10-15 18:40:53.925 - [31merror[39m: TypeError: Cannot read property 'toString' of undefined
              at sendNotification (/Users/pix/Documents/iobroker/node_modules/iobroker.pushsafer/pushsafer.js:172:26)
              at /Users/pix/Documents/iobroker/node_modules/iobroker.pushsafer/pushsafer.js:70:13
              at Command.callback (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:438:21)
              at normal_reply (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/redis/index.js:714:21)
              at RedisClient.return_reply (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/redis/index.js:816:9)
              at JavascriptRedisParser.Parser.returnReply (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/redis/index.js:188:18)
              at JavascriptRedisParser.execute (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/redis/node_modules/redis-parser/lib/parser.js:415:12)
              at Socket. <anonymous>(/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/redis/index.js:267:27)
              2016-10-15 18:40:54.430 - [32minfo[39m: pushsafer.0 terminating
              2016-10-15 18:40:54.436 - [31merror[39m: host.MacMini-Ethernet.fritz.box instance system.adapter.pushsafer.0 terminated with code 0 (OK)</anonymous>
              • Bluefox
                Noch mal vom git updaten bitte.
                  pix last edited by
                  Hallo Bluefox,
                  Versand von Text funktioniert wieder. Vielen Dank. Habe meinen altern Änderungen über Bord geworfen :lol:
                  Beim Bildversand komme ich noch nicht weiter.
                  Was ist mit "absolute path to picture" gemeint? Ein URL zum Bild? Der Dateipfad auf meinem Server reicht nicht (zumindest nicht der Pfad, der in anderen Skripten zum Speichern von Logs und ähnlichem reicht).
                  Habe mal http://www.fastix.org/test/Data-URL-Generator.php eine Grafik codiert, aber den ganzen String kann man ja auch nicht speichern (der Ace-Editor mag das gar nicht). Ausserdem soll das ja auch on the fly passieren.
                  Kannst du mal ein Beispiel für den Grafikversand geben?
                  Danke!
                  Pix
                  EDIT: Testnachrichten vom Einstellungsfenster gehen immer noch nicht raus.
                  • Bluefox
                    Alles gefixt.
                    sendTo("pushsafer.0", "send", {
                       message: 'Hallo',
                       sound: "",
                       vibration: "",
                       picture: 'C:\\pWork\\iobroker-data\\files\\vis\\img\\bulb_on.png'
                    Wieder vom git.
                      pix last edited by
                      Hallo Bluefox,
                      jetzt klappt es. Allerdings musste ich bei meinem System den Pfad etwas anders schreiben:````
                      var pfadlokal = "/Users/pix/Documents/airsonosstarten.png";
                      sendTo('pushsafer.0', {
                      title: 'Foto Test', // optional - your message's title, otherwise your app's name is used
                      sound: '5', // optional - a number betwenn 0-28 (see pushsafers API description)
                      vibration: '3', // optional - a number betwenn 0-3 (see pushsafers API description)
                      picture: pfadlokal, // optional - absolute path to picture or base64 coded image URL
                      url: yrno,// optional - URL in the link
                      urlTitle: 'YR.no Wettervorhersage' // optional - title of URL
                      Vielen Dank!
                      Pix
                      • Bluefox
                        Es geht auch so:
                          rascal last edited by
                          Hey, ich habe das Problem, dass der Adapter nur ein Mal funktioniert, danach muss ich ihn neu starten, sonst sendet er nichts mehr.
                          Gesendet von meinem HUAWEI CRR-L09 mit Tapatalk
                            pix last edited by
                            Ich glaub, ich hab das gleiche Problem. Muss immer wieder Adapter neu starten.
                            Ist mir vorher nicht aufgefallen.
                            Pix
                            • Bluefox
                              @rascal:
                              Gesendet von meinem HUAWEI CRR-L09 mit Tapatalk `
                              Logs? Im debug?
                                pix last edited by
                                Adapter neu gestartet (debug-log) und mit hm-Aktor dreimal Pushsafer Versand ausgelöst.
                                Marker - 19.10.2016, 22:55:09
                                2016-10-19 22:55:12.399 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.alive {"val":true,"ack":true,"ts":1476910512399,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910422393}
                                2016-10-19 22:55:12.400 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.connected {"val":true,"ack":true,"ts":1476910512400,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910422394}
                                2016-10-19 22:55:12.400 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.memRss {"val":41.61,"ack":true,"ts":1476910512400,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910512400}
                                2016-10-19 22:55:12.401 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.memHeapTotal {"val":15.96,"ack":true,"ts":1476910512400,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910437391}
                                2016-10-19 22:55:12.401 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.memHeapUsed {"val":14.38,"ack":true,"ts":1476910512401,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910512401}
                                2016-10-19 22:55:12.401 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.uptime {"val":91,"ack":true,"ts":1476910512401,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910512401}
                                2016-10-19 22:55:12.519 - [32minfo[39m: host.MacMini-Ethernet.fritz.box object change system.adapter.pushsafer.0
                                2016-10-19 22:55:12.519 - [32minfo[39m: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.pushsafer.0
                                2016-10-19 22:55:12.519 - [32minfo[39m: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.pushsafer.0 killing pid 6594
                                2016-10-19 22:55:13.022 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.alive {"val":false,"ack":true,"ts":1476910513022,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910513022}
                                2016-10-19 22:55:13.024 - [32minfo[39m: pushsafer.0 terminating
                                2016-10-19 22:55:13.032 - [32minfo[39m: host.MacMini-Ethernet.fritz.box instance system.adapter.pushsafer.0 terminated with code 0 (OK)
                                2016-10-19 22:55:15.028 - [32minfo[39m: host.MacMini-Ethernet.fritz.box instance system.adapter.pushsafer.0 started with pid 6608
                                2016-10-19 22:55:15.485 - [34mdebug[39m: pushsafer.0 objectDB connected
                                2016-10-19 22:55:15.496 - [34mdebug[39m: pushsafer.0 statesDB connected
                                2016-10-19 22:55:15.506 - [32minfo[39m: host. States connected to redis 127.0.0.1:6379
                                2016-10-19 22:55:15.510 - [34mdebug[39m: host. redis get system.adapter.pushsafer.0.alive ok: {"val":false,"ack":true,"ts":1476910513033,"q":0,"from":"system.host.MacMini-Ethernet.fritz.box","lc":1476910513022}
                                2016-10-19 22:55:15.556 - [32minfo[39m: pushsafer.0 starting. Version 0.1.6 in /Users/pix/Documents/iobroker/node_modules/iobroker.pushsafer
                                2016-10-19 22:55:15.560 - [34mdebug[39m: host. redis keys 1 *.logging
                                2016-10-19 22:55:15.561 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.alive {"val":true,"ack":true,"ts":1476910515561,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910515561}
                                2016-10-19 22:55:15.562 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.connected {"val":true,"ack":true,"ts":1476910515561,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910515561}
                                2016-10-19 22:55:15.563 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.memRss {"val":36.59,"ack":true,"ts":1476910515562,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910515562}
                                2016-10-19 22:55:15.563 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.memHeapTotal {"val":18.85,"ack":true,"ts":1476910515563,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910515563}
                                2016-10-19 22:55:15.564 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.memHeapUsed {"val":12.43,"ack":true,"ts":1476910515564,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910515564}
                                2016-10-19 22:55:15.564 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.uptime {"val":1,"ack":true,"ts":1476910515564,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910515564}
                                2016-10-19 22:55:15.568 - [34mdebug[39m: host. redis mget 1 1
                                2016-10-19 22:55:17.981 - [32minfo[39m: javascript.0 script.js.common.Status.Status_Geraete: Status Heizung auf DIY Fernbedienung eingeschaltet
                                2016-10-19 22:55:17.981 - [32minfo[39m: javascript.2 script.js.Test.DIY_Schalter: Aktion ausgelöst
                                2016-10-19 22:55:17.984 - [34mdebug[39m: host. redis pmessage messagebox.system.adapter.pushsafer.0 messagebox.system.adapter.pushsafer.0 {"command":"send","message":{"message":"Test text","title":"Foto Test","device":"322","sound":"5","icon":"2","vibration":"3","picture":"/Users/pix/Documents/airsonosstarten.png"},"from":"system.adapter.javascript.2","_id":55262909}
                                2016-10-19 22:55:17.988 - [34mdebug[39m: pushsafer.0 Send pushsafer notification: Test text
                                2016-10-19 22:55:18.026 - [34mdebug[39m: pushsafer.0 Filter out double message [first was for 40ms]: {"message":"Test text","title":"Foto Test","device":"322","sound":"5","icon":"2","vibration":"3","picture":"/Users/pix/Documents/airsonosstarten.png"}
                                2016-10-19 22:55:24.728 - [32minfo[39m: javascript.2 script.js.Test.DIY_Schalter: Aktion ausgelöst
                                2016-10-19 22:55:24.728 - [32minfo[39m: javascript.0 script.js.common.Status.Status_Geraete: Status Heizung auf DIY Fernbedienung ausgeschaltet
                                2016-10-19 22:55:24.730 - [34mdebug[39m: host. redis pmessage messagebox.system.adapter.pushsafer.0 messagebox.system.adapter.pushsafer.0 {"command":"send","message":{"message":"Test text","title":"Foto Test","device":"322","sound":"5","icon":"2","vibration":"3","picture":"/Users/pix/Documents/airsonosstarten.png"},"from":"system.adapter.javascript.2","_id":55262910}
                                2016-10-19 22:55:24.732 - [34mdebug[39m: pushsafer.0 Filter out double message [first was for 1ms]: {"message":"Test text","title":"Foto Test","device":"322","sound":"5","icon":"2","vibration":"3","picture":"/Users/pix/Documents/airsonosstarten.png"}
                                2016-10-19 22:55:30.559 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.alive {"val":true,"ack":true,"ts":1476910530559,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910515561}
                                2016-10-19 22:55:30.560 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.connected {"val":true,"ack":true,"ts":1476910530560,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910515561}
                                2016-10-19 22:55:30.561 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.memRss {"val":40.67,"ack":true,"ts":1476910530561,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910530561}
                                2016-10-19 22:55:30.561 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.memHeapTotal {"val":19.84,"ack":true,"ts":1476910530561,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910530561}
                                2016-10-19 22:55:30.561 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.memHeapUsed {"val":13.31,"ack":true,"ts":1476910530561,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910530561}
                                2016-10-19 22:55:30.562 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.uptime {"val":16,"ack":true,"ts":1476910530562,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910530562}
                                2016-10-19 22:55:37.776 - [32minfo[39m: javascript.2 script.js.Test.DIY_Schalter: Aktion ausgelöst
                                2016-10-19 22:55:37.776 - [32minfo[39m: javascript.0 script.js.common.Status.Status_Geraete: Status Heizung auf DIY Fernbedienung eingeschaltet
                                2016-10-19 22:55:37.777 - [34mdebug[39m: host. redis pmessage messagebox.system.adapter.pushsafer.0 messagebox.system.adapter.pushsafer.0 {"command":"send","message":{"message":"Test text","title":"Foto Test","device":"322","sound":"5","icon":"2","vibration":"3","picture":"/Users/pix/Documents/airsonosstarten.png"},"from":"system.adapter.javascript.2","_id":55262911}
                                2016-10-19 22:55:37.782 - [34mdebug[39m: pushsafer.0 Filter out double message [first was for 4ms]: {"message":"Test text","title":"Foto Test","device":"322","sound":"5","icon":"2","vibration":"3","picture":"/Users/pix/Documents/airsonosstarten.png"}
                                Definitiv nur Versand beim ersten Auslösen nach Restart. Abstand zwischen den Sendungen siehe log, aber groß genug.
                                Hoffe, das hilft.
                                Pix
                                • Bluefox
                                  @pix:
                                  Hoffe, das hilft.
                                  Pix `
                                  Habe den Fehler gefunden. Bitte updaten.
                                    pix last edited by
                                    Läuft wieder, danke!
                                      starfish last edited by
                                      was kosten eigentlich die Nachrichtenkontingente? Es schimmert immer irgerndwie durch, dass Pushsafer was kostet, aber weder auf der Homepage, noch in Foren gibts Transparenz. Einzig, dass man sich erst registrieren muss, und dann sieht man was bei den Geräten ? Ich will aber den Preis vorher wissen, bevor ich mich irgendwo registriere. Habe ich irgendwas auf der HP übersehen?
                                      • eric2905
                                        eric2905 last edited by
                                        Im HowTo auf der Webseite sind Preise aufgeführt
                                        ==> https://www.pushsafer.com/de/howto
                                        Gruß,
                                        Eric
                                        Von unterwegs getippert
                                          @eric2905:
                                          Gruß,
                                          Eric `
                                          danke, hatte ich auch grad gefunden, aber Du warst schneller … 😄
                                          geht noch mit den Preisen - v.a. so ab 200K api calls.
                                          4749
