    4. Daten Seriell von Paradigma Solaranlage lesen
      glitzi @AlCalzone last edited by
      @AlCalzone
      Vom Github ist installiert, Version 4.10.6
      Sobald das Skrip läuft, stürzt die Instanz von Java ohne Meldungen im Log ab,
      const Delimiter = require('@serialport/parser-delimiter')
      const Ready = require('@serialport/parser-ready')
      createState('Paradigma_Kollektor');
      createState('Paradigma_Speichertemperatur');
      createState('Paradigma_Solarvorlauf');
      createState('Paradigma_Aussentemperatur');
      createState('Paradigma_Solarrücklauf');
      createState('Paradigma_Durchfluss');
      createState('Paradigma_PWMPumpe');
      createState('Paradigma_Tagesleistung');
      createState('Paradigma_Gesamtleistung');
      createState('Paradigma_Status');
      createState('Paradigma_StatusText');
      createState('Paradigma_Fehlercode');
      createState('Paradigma_FehlercodeText');
      const { Transform } = require('stream');
      class PreambleParser extends Transform {
      	 * @param {Buffer} preamble
      	 * @param {number} payloadLength
      	constructor(preamble, payloadLength) {
      		super();
      		this.receiveBuffer = Buffer.allocUnsafe(0);
      		this.preamble = preamble;
      		this.payloadLength = payloadLength;
      	_transform(chunk, encoding, callback) {
      		this.receiveBuffer = Buffer.concat([this.receiveBuffer, chunk]);
      		while (this.receiveBuffer.length >= this.preamble.length) {
      			// Check if the buffer starts with the preamble
      			const preambleIndex = this.receiveBuffer.indexOf(this.preamble);
      			if (preambleIndex === -1) {
      				// not found, wait for the next chunk
      				break;
      			// Skip bytes before the preamble
      			this.receiveBuffer = skipBytes(this.receiveBuffer, preambleIndex);
      			// Check if we still have enough data
      			if (
      				this.preamble.length + this.payloadLength
      				// Yes, emit it
      				this.push(
      					this.receiveBuffer.slice(
      						this.preamble.length,
      						this.preamble.length + this.payloadLength,
      				// And skip the bytes
      					this.receiveBuffer,
      		callback();
      /** Skips the first n bytes of a buffer and returns the rest */
      function skipBytes(buf, n) {
      	return Buffer.from(buf.slice(n));
      const parser = new PreambleParser(
      	Buffer.from("fc3e2401", "hex"), // Start der Datenpakete
      	38, // Wie viele Bytes nach dem Start ausgewertet werden
      parser.on('data', chunk => {
          console.log(chunk.toString("hex"));
      // Bei jedem Dateneingang:
      const hexDatenOhneLeerzeichen =
      	"0120000233fc3e24010902870243014900000056010000000000000000000010100c0b1405000000000005440000000000000000000000090200000000000000000000000085fc3e24010902870243014a00000057010000";
      parser.write(hexDatenOhneLeerzeichen, "hex");
      • AlCalzone
        AlCalzone Developer @glitzi last edited by
        @glitzi sagte in Daten Seriell von Paradigma Solaranlage lesen:
        woran machst du das fest?
        Außerdem: die letzten Dinge, die wir besprochen hatten, sind doch gar nicht drin?
          @AlCalzone
          ja die Änderungen sind nicht drin, habe mal alles weggelassen um den Fehler einzugrenzen.
          Wie stelle ich das fest:
          • im Editor kommt Instanz ist nicht aktiv oder so ähnlich.
          • bei den Instanzen im Admin wird das Lämpchen orange (Lebenszeichen und Verbunden gehen in Fehler)
          • Nach einem Neustart über den Button geht es wieder bis ich das Skript wieder neu starte, danach das gleiche Spiel.
          • CPU Last, sonst liege ich unter 1%, nach mehrere Abstürzen von javaskript.0 steigert sich die Last auf 10%. Nach einem Neustart von ioBroker wieder alles unter 1%
          • AlCalzone
            @glitzi Dann muss irgendetwas im normalen ioBroker-Log stehen.
              @AlCalzone
              Im Editor nach ca. 20 Sekunden
              LOG ist Leer
              Instanzen
              • AlCalzone
                @glitzi Da ist dann was ganz im Argen. Leeres Log ist in der Regel nicht gut. Mach doch mal den Log in einem zweiten Browser-Fenster auf und beobachte da, was passiert wenn du das Skript startest.
                  @AlCalzone
                  man kann leider auch im zweiten Fenster nichts sehen...
                  • AlCalzone
                    @glitzi Auch nicht bevor du das Skript startest?
                      @AlCalzone
                      Doch klar, vor dem Start habe ich es gelöscht um einfacher zu sehn ob etwas kommt.
                      • AlCalzone
                        @glitzi Hmm aber einen Absturz sollte man im Log sehen.
                          glitzi @AlCalzone last edited by glitzi
                          @AlCalzone
                          Jetzt habe fast ich eine LÖSUNG:
                          Mir Readline funktioniert es!
                          Es kommt nur dieser Fehler wenn ich einzelne Teile auswerte und in einen Datenpunkt schreiben will, scheint was mit der Konvertierung zu sein?
                          21:25:38.455	info	javascript.0 (7696) Stop script script.js.Paradigma.verworfen_Serielle_Daten_von_Paradigma_lesen
                          21:25:39.521	info	javascript.0 (7696) Start javascript script.js.Paradigma.verworfen_Serielle_Daten_von_Paradigma_lesen
                          21:25:39.528	info	javascript.0 (7696) script.js.Paradigma.verworfen_Serielle_Daten_von_Paradigma_lesen: registered 0 subscriptions and 0 schedules
                          21:25:39.927	info	javascript.0 (7696) script.js.Paradigma.verworfen_Serielle_Daten_von_Paradigma_lesen: 3c005402aa00feff00003c0100000000000100010c001519020c14410000000000414400000000000000000000003c00000000000000000000000000cb
                          21:25:39.929	error	javascript.0 (7696) script.js.Paradigma.verworfen_Serielle_Daten_von_Paradigma_lesen: TypeError: chunk.readUInt16LE is not a function
                          21:25:39.929	error	javascript.0 (7696) at ReadLineParser.<anonymous> (script.js.Paradigma.verworfen_Serielle_Daten_von_Paradigma_lesen:35:14)
                          const SerialPort = require('serialport')
                          const Readline = require('@serialport/parser-readline')
                          const port = new SerialPort('/dev/ttyUSB0')
                          const parser = port.pipe(new Readline({ delimiter: 'fc3e2401', encoding: 'HEX' }))
                              if (Date.now() - lastCheck < 10000) return;
                              lastCheck = Date.now();
                          	val = chunk.readUInt16LE(0) // liest eine 2-byte-Zahl ab Position 0 ohne Bytes zu tauschen
                              setState('Paradigma_Kollektor', val /10, true);
                          let lastCheck = 0; // 0 sorgt dafür, dass gleich zu Beginn einmal ausgelesen wird
                          // Port bei Skriptende schließen:
                          onStop(() => {
                            port.close();
                          • AlCalzone
                            AlCalzone Developer @glitzi last edited by AlCalzone
                            Readline liest Text, die Funktion erwartet einen Buffer. Der Readline-Parser ist auch nur eine spezielle Variante des Delimiter-Parsers, d.h. er gibt dir zurück, was vor deinem Code kommt, nicht das danach.
                            Ich verstehe nicht warum das andere nicht gehen soll. Es muss doch irgendwo irgendwas stehen. Zeig mir bitte mal das vollständige Skript mit dem anderen Parser.
                              @AlCalzone
                              wie kann man denn den Text verarbeiten, mit Readline würde es ja gehen!
                              Anbei das andere Skript:
                              		super();
                              				break;
                              			if (
                              				// Yes, emit it
                              				this.push(
                              					this.receiveBuffer,
                              		callback();
                              • AlCalzone
                                @glitzi Fehler gefunden - da hatte sich eine Endlosschleife eingeschlichen.
                                Anbei dein Skript mit 2 kleinen Änderungen.
                                1. Die beiden Parser am Anfang brauchst du nicht importieren, wenn du sie nicht nutzt
                                2. else in Zeile 59-61 eingefügt
                                createState("Paradigma_Kollektor");
                                createState("Paradigma_Speichertemperatur");
                                createState("Paradigma_Solarvorlauf");
                                createState("Paradigma_Aussentemperatur");
                                createState("Paradigma_Solarrücklauf");
                                createState("Paradigma_Durchfluss");
                                createState("Paradigma_PWMPumpe");
                                createState("Paradigma_Tagesleistung");
                                createState("Paradigma_Gesamtleistung");
                                createState("Paradigma_Status");
                                createState("Paradigma_StatusText");
                                createState("Paradigma_Fehlercode");
                                createState("Paradigma_FehlercodeText");
                                const { Transform } = require("stream");
                                    super();
                                        break;
                                      if (
                                        // Yes, emit it
                                        this.push(
                                          this.receiveBuffer,
                                      } else {
                                        // no, wait until we do
                                        break;
                                    callback();
                                  38 // Wie viele Bytes nach dem Start ausgewertet werden
                                parser.on("data", (chunk) => {
                                  @AlCalzone
                                  Es ist vollbracht 👍
                                  es Funktioniert DANKE!!!!! Ein besonderes Dankeschön an @AlCalzone!
                                  Hier das Fertige Skript für alle Paradigma Nutzer die sich über folgenden Link einen Adapter gelötet haben.
                                  Seite mit Bauanleitung:
                                      super();
                                          break;
                                        if (
                                          // Yes, emit it
                                          this.push(
                                            this.receiveBuffer,
                                        } else {
                                          break;
                                      callback();
                                  if (Date.now() - lastCheck < 30000) return;
                                      //console.log(chunk.toString("hex"));
                                      val = chunk.readUInt16LE(2) // liest eine 2-byte-Zahl ab Position 0 ohne Bytes zu tauschen
                                      setState('Paradigma_Speichertemperatur', val /10, true);
                                      val = chunk.readUInt16LE(4) // liest eine 2-byte-Zahl ab Position 0 ohne Bytes zu tauschen
                                      setState('Paradigma_Solarvorlauf', val /10, true);
                                      val = chunk.readInt16LE(6) // liest eine 2-byte-Zahl ab Position 0 ohne Bytes zu tauschen
                                      setState('Paradigma_Aussentemperatur', val /10, true);
                                      val = chunk.readUInt16LE(10) // liest eine 2-byte-Zahl ab Position 0 ohne Bytes zu tauschen
                                      setState('Paradigma_Solarrücklauf', val /10, true);
                                      val = chunk.readUInt16LE(12) // liest eine 2-byte-Zahl ab Position 0 ohne Bytes zu tauschen
                                      setState('Paradigma_Durchfluss', val /10, true);
                                      val = chunk.readUInt8(14) // liest eine 2-byte-Zahl ab Position 0 ohne Bytes zu tauschen
                                      setState('Paradigma_PWMPumpe', val /10, true);
                                      val = chunk.readUInt16LE(29) // liest eine 2-byte-Zahl ab Position 0 ohne Bytes zu tauschen
                                      setState('Paradigma_Tagesleistung', val , true);
                                      val = chunk.readUInt16LE(32) // liest eine 2-byte-Zahl ab Position 0 ohne Bytes zu tauschen
                                      setState('Paradigma_Gesamtleistung', val , true);
                                      val = chunk.readUInt8(17) // liest eine 2-byte-Zahl ab Position 0 ohne Bytes zu tauschen
                                      setState('Paradigma_Status', val, true);
                                  switch(val) {
                                    case 0:
                                      setState('Paradigma_StatusText', 'Warten auf Sonne', true);
                                      break;
                                    case 1:
                                      setState('Paradigma_StatusText', 'Frostschutz', true);
                                      break;
                                    case 2:
                                      setState('Paradigma_StatusText', 'Anschieben', true);
                                      break;
                                    case 3:
                                      setState('Paradigma_StatusText', 'Einschaltverzögerung', true);
                                      break;
                                    case 4:
                                      setState('Paradigma_StatusText', 'erwärmt Speicher', true);
                                      break;
                                    case 5:
                                      setState('Paradigma_StatusText', 'Speicher voll', true);
                                      break;
                                    case 6:
                                      setState('Paradigma_StatusText', 'Kollektor überhitzt', true);
                                      break;
                                    case 7:
                                      setState('Paradigma_StatusText', 'Hand, Test oder Aus', true);
                                      break;
                                    case 8:
                                      setState('Paradigma_StatusText', 'Messung', true);
                                      break;
                                     default:
                                      setState('Paradigma_StatusText', val, true);
                                      val = chunk.readUInt8(18) // liest eine 2-byte-Zahl ab Position 0 ohne Bytes zu tauschen
                                      setState('Paradigma_Fehlercode', val, true);
                                  switch(val) {
                                    case 0:
                                      setState('Paradigma_FehlercodeText', 'OK', true);
                                      break;
                                    case 1:
                                      setState('Paradigma_FehlercodeText', 'Kein Volumenstrom', true);
                                      break;
                                    case 2:
                                      setState('Paradigma_FehlercodeText', 'Luft in der Anlage', true);
                                      break;
                                    case 4:
                                      setState('Paradigma_FehlercodeText', 'Vor- u. Rücklauf vertauscht', true);
                                      break;
                                    case 5:
                                      setState('Paradigma_FehlercodeText', 'Zonenventil defekt', true);
                                      break;
                                    case 6:
                                      setState('Paradigma_FehlercodeText', 'Falsche Uhrzeit', true);
                                      break;
                                    case 7:
                                      setState('Paradigma_FehlercodeText', 'Druckabfall in der Anlage', true);
                                      break;
                                    case 9:
                                      setState('Paradigma_FehlercodeText', 'Falsche Hydraulik', true);
                                      break;
                                    case 10:
                                      setState('Paradigma_FehlercodeText', 'Rohrisolierung', true);
                                      break;
                                    case 11:
                                      setState('Paradigma_FehlercodeText', 'Stromversorgung n. konstant', true);
                                      break;
                                    case 12:
                                      setState('Paradigma_FehlercodeText', 'OLV defekt', true);
                                      break;
                                    case 13:
                                      setState('Paradigma_FehlercodeText', 'Zu wenig Volumenstrom', true);
                                      break;
                                    case 14:
                                      setState('Paradigma_FehlercodeText', 'Speicher unterkühlt durch Frostschutz', true);
                                      break;
                                    case 20:
                                      setState('Paradigma_FehlercodeText', 'Fühler Außentemperatur falsch montiert', true);
                                      break;
                                    case 21:
                                      setState('Paradigma_FehlercodeText', 'Ausfall Kollektorfühler', true);
                                      break;
                                    case 22:
                                      setState('Paradigma_FehlercodeText', 'Ausfall Fühler Solarrücklauf', true);
                                      break;
                                    case 23:
                                      setState('Paradigma_FehlercodeText', 'Störung Kollektrofühler', true);
                                      break;
                                    case 24:
                                      setState('Paradigma_FehlercodeText', 'Frostschutz', true);
                                      break;
                                    case 25:
                                      setState('Paradigma_FehlercodeText', 'Fühler TSA u. TAM vertauscht', true);
                                      break;
                                    case 26:
                                      setState('Paradigma_FehlercodeText', 'Ausfall Fühler Solarvorlauf', true);
                                      break;
                                    case 27:
                                      setState('Paradigma_FehlercodeText', 'Ausfall Fühler Außentemperatur', true);
                                      break;
                                    case 34:
                                      setState('Paradigma_FehlercodeText', 'Überhitzung Speicher 1', true);
                                      break;
                                    case 35:
                                      setState('Paradigma_FehlercodeText', 'Überhitzung Speicher 2', true);
                                      break;
                                    case 49:
                                      setState('Paradigma_FehlercodeText', 'Solarstation unterkühlt', true);
                                      break;
                                    case 50:
                                      setState('Paradigma_FehlercodeText', 'Kollektor eingefroren', true);
                                      break;
                                     default:
                                      setState('Paradigma_FehlercodeText', val, true);
                                   const SerialPort = require('serialport');
                                  // Port öffnen
                                  const port = new SerialPort('/dev/ttyUSB0');
                                  port.pipe(parser);
                                  onStop(() => {
                                    port.close();
                                  communication heating javascript
                                  4415
