    4. JavaScript
    5. [Vorlage] Flexibles Timerskript + Vis
      AndreasW63 last edited by Negalein
      ich habe das Timerskript seit einigen Tagen im Einsatz.
      Bei einem der Tasks funktioniert das Ausschalten nach "Sonnenaufgang" nicht.
      Zu diesem Zeitpunkt habe ich folgende Meldungen im Logfile des IOBroker:
      javascript.0	2020-12-01 08:18:13.064	info	(19670) script.js.Timerskript: GoToTommorrow requested, TodayAstroIsOver automatically set to true, skipping check
      javascript.0	2020-12-01 08:18:13.062	info	(19670) script.js.Timerskript: Timer 2, DVES_212_Terrasse, switched off
      javascript.0	2020-12-01 08:18:13.058	warn	(19670) at processTimers (internal/timers.js:497:7)
      javascript.0	2020-12-01 08:18:13.058	warn	(19670) at listOnTimeout (internal/timers.js:554:17)
      javascript.0	2020-12-01 08:18:13.058	warn	(19670) at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/schedule.js:510:7)
      javascript.0	2020-12-01 08:18:13.057	warn	(19670) at /opt/iobroker/node_modules/node-schedule/lib/schedule.js:552:11
      javascript.0	2020-12-01 08:18:13.057	warn	(19670) at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/schedule.js:173:10)
      javascript.0	2020-12-01 08:18:13.056	warn	(19670) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1273:34)
      javascript.0	2020-12-01 08:18:13.056	warn	(19670) at Object.<anonymous> (script.js.Timerskript:608:13)
      javascript.0	2020-12-01 08:18:13.055	warn	(19670) at DoAction (script.js.Timerskript:673:21)
      javascript.0	2020-12-01 08:18:13.055	warn	(19670) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1358:20)
      javascript.0	2020-12-01 08:18:13.051	warn	(19670) You are assigning a boolean to the state "sonoff.0.DVES_212_Terrasse.Time" which expects a string. Please fix your code to use a string or change the state type to boolean. This warning might
      javascript.0	2020-12-01 08:18:13.017	info	(19670) script.js.Timerskript: GoToTommorrow requested, TodayAstroIsOver automatically set to true, skipping check
      Kann mir jemand eine Tip geben wo ich ansetzen kann?
      Gruß Andreas
        Pittini Developer @AndreasW63 last edited by Pittini
        @AndreasW63 sagte in [Vorlage] Flexibles Timerskript + Vis:
        Gruß Andreas
        Doch, es funktioniert, nur versucht Du offenbar das "aus", also false in nen Datenpunkt zu schreiben der ne Zeit als String erwartet. Siehe Log:
          AndreasW63 @Pittini last edited by
          @Pittini
          Danke für deine prompte Antwort.
          Ja, da habe ich im Eifer des Gefechtes den falschen Datenpunkt ausgewählt ........
          "Entschuldigen Sie die Störung......" 😉
          Gruß Andreas
          • Rene55
            Rene55 @AndreasW63 last edited by
            @Pittini
            Darf ich hier auch nochmals eine Frage stellen? Ich möchte gerne meine Gosund (mit Tasmota) über das Timerscript steuern. Beim einlesen der TimerTargets laufe ich auf einen Fehler:
            javascript.0	2020-12-01 16:36:33.659	error	(8821) Error in callback: TypeError: Cannot read property 'common' of null
            javascript.0	2020-12-01 16:36:33.637	warn	(8821) Object "mqtt.0.SmartHome.Gosund4.cmnd" does not exist
            DerDatenpunkt den ich ausgewählt habe war eigentlich "mqtt.0.SmartHome.Gosund4.cmnd.POWER", womit es eigentlich funktionieren müsste. Muss ich noch etwas anderes einstellen?
            LG Rainer
              Pittini Developer @Rene55 last edited by
              @Rene55 sagte in [Vorlage] Flexibles Timerskript + Vis:
              LG Rainer
              Zeig mal nen Screenshot von dem konfigurierten Datenpunkt, "eigentlich" is immer sone Sache. Der Fehler im Log sagt lediglich aus dasses den state angeblich nicht gibt, jetzt heists rausfinden warum.
              • Rene55
                Rene55 @Pittini last edited by
                @Pittini
                Hier der Screenshot rund um den Gosund:!
                P gelberlemmy 2 Replies Last reply Reply Quote 0
                  @Pittini
                  Ich seh da nirgends ne TimerTarget Zuweisung. Wo is die? Und was steht im Raw von dem Button Datenpunkt?
                    wie kann ich die Timereinträge sortieren ?
                    Zu einzelnen Objekten habe ich weitere Schaltzeiten hinterlegt. Es wäre schön wenn die Objekte untereinander stehen würden.
                    Gruß Andreas
                      Gruß Andreas
                      Sortierung ist nicht implementiert und auch nicht geplant. Die Reihenfolge in der Du anlegst is auch die Anzeigereihenfolge.
                      • Rene55
                        @Pittini
                        Ich hatte nach dem Fehler natürlich den TimerTarget wieder entfernt.
                        Hier nochmals der Screenshot: Gosund4.png
                        und der daraus resultierende Logeintrag:
                        Ich hoffe, dass ich hiermit weiterhelfen kann.
                        LG Rainer
                          FuXXz2 last edited by
                          Vorerst danke für das tolle Timerscript👍
                          Ich habe dazu zwei fragen.
                          1. Mein test Timer funktioniert zwar, aber ich bekomme folgende Einträge ins log, bei jedem Schaltvorgang:
                          javascript.0	2020-12-04 14:41:00.014	error	(24887) at processTimers (internal/timers.js:497:7)
                          javascript.0	2020-12-04 14:41:00.014	error	(24887) at listOnTimeout (internal/timers.js:554:17)
                          javascript.0	2020-12-04 14:41:00.013	error	(24887) at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/schedule.js:510:7)
                          javascript.0	2020-12-04 14:41:00.013	error	(24887) at /opt/iobroker/node_modules/node-schedule/lib/schedule.js:552:11
                          javascript.0	2020-12-04 14:41:00.013	error	(24887) at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/schedule.js:173:10)
                          javascript.0	2020-12-04 14:41:00.013	error	(24887) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1291:34)
                          javascript.0	2020-12-04 14:41:00.013	error	(24887) at Object.<anonymous> (script.js.tests.Pittini_iobroker-Timer:608:13)
                          javascript.0	2020-12-04 14:41:00.012	error	(24887) at DoAction (script.js.tests.Pittini_iobroker-Timer:676:48)
                          javascript.0	2020-12-04 14:41:00.012	error	(24887) at Meldung (script.js.tests.Pittini_iobroker-Timer:111:13)
                          javascript.0	2020-12-04 14:41:00.012	error	(24887) Error in callback: ReferenceError: WriteEventLog is not defined
                          1. Sieht bei mir die Zeiteingabe komisch aus. Da hat er irgendwelche Stylings nicht genutzt.
                          qqolli P 2 Replies Last reply Reply Quote 0
                          • qqolli
                            qqolli @FuXXz2 last edited by
                            @FuXXz2
                            bei mir sieht/sah es auch immer so aus. Habe es aber nie richtig "ordentlich" hinbekommen. Falls Du eine Lösung findest, wäre ich auch dankbar dafür wenn Du sie teilen würdest 🙂
                              Pittini Developer @FuXXz2 last edited by
                              @FuXXz2 sagte in [Vorlage] Flexibles Timerskript + Vis:
                              Na, steht doch da was der Fehler ist. Stell mal UseEventLog in den Einstellungen auf false wie auch sowohl in der Anleitung als auch im Skript selber ausdrücklich gefordert.
                              Ja, ich kenn das Problem, wüsste aber nicht was ich dagegen machen sollte, is auch nicht bei jedem und bisher hab ich noch nicht rausgefunden was bei jenen wo es funktioniert anders wär. Evtl. kann euch der Entwickler vom MaterialDesign CSS/Skript da helfen, hab Ihr da schon mal nachgefragt?: https://forum.iobroker.net/topic/30363/projekt-mdcss-v2-material-design-css-version-2/634
                              • Rene55
                                @Pittini Ich hatte den raw vom Datenpunkt noch vergessen. Hier ist er:
                                  "common": {
                                    "name": "SmartHome/Gosund4/cmnd/POWER",
                                    "write": true,
                                    "read": true,
                                    "role": "state",
                                    "desc": "mqtt client variable",
                                    "type": "string",
                                    "custom": {
                                      "influxdb.0": {
                                        "enabled": true,
                                        "changesOnly": false,
                                        "debounce": "",
                                        "maxLength": 10,
                                        "retention": "31536000",
                                        "changesRelogInterval": 0,
                                        "changesMinDelta": "",
                                        "storageType": "String",
                                        "aliasId": ""
                                  "native": {
                                    "topic": "SmartHome/Gosund4/cmnd/POWER"
                                  "type": "state",
                                  "from": "system.adapter.influxdb.0",
                                  "user": "system.user.admin",
                                  "ts": 1606836913713,
                                  "_id": "mqtt.0.SmartHome.Gosund4.cmnd.POWER",
                                  "acl": {
                                    "object": 1636,
                                    "state": 1636,
                                    "owner": "system.user.admin",
                                LG Rainer
                                • Q
                                  quorle last edited by
                                  Servus @Pittini ich hab nun dein Timerscript einmal eingebunden. Hätte aber dazu noch eine Frage, kann man mit diesem Script einen Intervall machen. Sprich jeweils für eine bestimmte Zeit einschalten und dann wieder für eine bestimmte Zeit ausschalten. Und dies sollte sich dann immer widerholen.
                                    Pittini Developer @quorle last edited by
                                    @quorle sagte in [Vorlage] Flexibles Timerskript + Vis:
                                    Naja, für nen reinen Intervall brauchst kein Timerskript, dasn 4 Zeiler. Und nein, ist nicht drin oder vorgesehen.
                                      Ok, ich seh zwei Probleme. Zum einen ist der Power true/false kein Boolean Datenpunkt und zum anderen der channel kein echter channel. Erstell mal ein kleines Skript mit diesem Einzeiler, lass es einmal laufen und starte dann das Timerskript nochmal und gugg was der Fehler macht.
                                      setObject("mqtt.0.SmartHome.Gosund4.cmnd", { type: 'channel', common: { name: "" }, native: {} }); //Channel machen
                                      Bleibt der Fehler gleich, versuch in den Timereinstellungen nicht die Option Anschalten oder Ausschalten zu verwenden, sondern versuchs mal mit "Wert setzen" und als Wert mal true oder false zu verwenden.
                                      • Rene55
                                        @Pittini Ich bin jetzt ein Stück weiter. Dein Fix-Script hat den Channel angelegt und das Timerscript kann das Device anlegen und schalten.
                                        Mit den eingebauten Funktionen Einschalten und Ausschalten klappt es, obwohl sich ioBroker dann beschwert, dass er hierfür einen String erwartet, aber ein boolean bekommt.
                                        You are assigning a boolean to the state "mqtt.0.SmartHome.Gosund4.cmnd.POWER" which expects a string. Please fix your code to use a string or change the state type to boolean. This warning might become an error in future versions.
                                        Das senden des Wertes "true" hat den gleichen Effekt: Schalten ja aber mit gleicher Warnung.
                                        Kann ich mit leben bis halt "in future versions". Danke für die professionelle Hilfe - hätte ich alleine nicht hinbekommen.
                                        LG Rainer
                                          Ja, das ist was ich oben schon schrieb, der mqtt Adapter will nen String obwohls eigentlich ja nen bool ist, deswegen das gemaule. Werd mal überlegen wie ich auf den Sonderfall reagier. Schreib am besten ein Issue auf Git damits nicht untergeht und ichs nicht vergess.
                                          • Rene55
                                            @Pittini gemacht:
                                            Nochmals Danke fürs Script und die Hilfe.
                                            LG Rainer
                                            javascript template
                                            40
                                            500
                                            111651
