    4. Test Adapter EnOcean (2) v0.3.x
      guergen @Tobias Schnurr last edited by
      @Tobias-Schnurr das klappt bei mir mit den Geräten auch grade nicht🙄
      • Tobias Schnurr
        Tobias Schnurr @Jey Cee last edited by
        @Jey-Cee
        enocean.0	2020-12-03 22:22:34.837	info	(23110) state enocean.0.gateway.teachin deleted
        enocean.0	2020-12-03 22:22:34.833	info	(23110) Teachin mode de-activated
        enocean.0	2020-12-03 22:22:07.327	debug	(23110) sendTo "getEEPList" to system.adapter.admin.0 from system.adapter.enocean.0
        enocean.0	2020-12-03 22:22:07.322	debug	(23110) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.enocean.0
        enocean.0	2020-12-03 22:22:07.318	debug	(23110) sendTo "listSerial" to system.adapter.admin.0 from system.adapter.enocean.0
        enocean.0	2020-12-03 22:22:07.316	info	(23110) ["/dev/ttyUSB0"]
        enocean.0	2020-12-03 21:21:21.983	debug	(23110) sendTo "getEEPList" to system.adapter.admin.0 from system.adapter.enocean.0
        enocean.0	2020-12-03 21:21:21.979	debug	(23110) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.enocean.0
        enocean.0	2020-12-03 21:21:21.970	debug	(23110) sendTo "listSerial" to system.adapter.admin.0 from system.adapter.enocean.0
        enocean.0	2020-12-03 21:21:21.966	info	(23110) ["/dev/ttyUSB0"]
        enocean.0	2020-12-03 21:21:18.915	debug	(23110) Packet type 2 received: 02
        enocean.0	2020-12-03 21:21:18.914	debug	(23110) 5500050102db00ffe864000a
        enocean.0	2020-12-03 21:21:18.900	debug	(23110) Sent data: 5500010005700838
        enocean.0	2020-12-03 21:21:18.899	debug	(23110) Packet type 2 received: 02
        enocean.0	2020-12-03 21:21:18.898	debug	(23110) 5500030002b3000100
        enocean.0	2020-12-03 21:21:18.885	debug	(23110) Sent data: 55000100057025fb
        enocean.0	2020-12-03 21:21:18.867	debug	(23110) Packet type 2 received: 02
        enocean.0	2020-12-03 21:21:18.867	debug	(23110) 5500030002b3000001
        enocean.0	2020-12-03 21:21:18.859	debug	(23110) Sent data: 5500010005700a36
        enocean.0	2020-12-03 21:21:18.857	debug	(23110) Packet type 2 received: 02
        enocean.0	2020-12-03 21:21:18.855	debug	(23110) 55002100022600020f000002060900058cd0c8454f0103474154455741594354524c0000000000
        enocean.0	2020-12-03 21:21:18.832	debug	(23110) Sent data: 5500010005700309
        enocean.0	2020-12-03 21:21:18.553	info	(23110) starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.enocean, node: v12.19.0, js-controller: 3.1.6
        enocean.0	2020-12-03 21:21:18.326	debug	(23110) statesDB connected
        enocean.0	2020-12-03 21:21:18.325	debug	(23110) States connected to redis: 127.0.0.1:9000
        enocean.0	2020-12-03 21:21:18.318	debug	(23110) States create System PubSub Client
        enocean.0	2020-12-03 21:21:18.314	debug	(23110) States create User PubSub Client
        enocean.0	2020-12-03 21:21:18.307	debug	(23110) Redis States: Use Redis connection: 127.0.0.1:9000
        enocean.0	2020-12-03 21:21:18.305	debug	(23110) objectDB connected
        enocean.0	2020-12-03 21:21:18.298	debug	(23110) Objects connected to redis: 127.0.0.1:9001
        enocean.0	2020-12-03 21:21:18.287	debug	(23110) Objects client initialize lua scripts
        enocean.0	2020-12-03 21:21:18.286	debug	(23110) Objects create User PubSub Client
        enocean.0	2020-12-03 21:21:18.284	debug	(23110) Objects create System PubSub Client
        enocean.0	2020-12-03 21:21:18.281	debug	(23110) Objects client ready ... initialize now
        enocean.0	2020-12-03 21:21:18.235	debug	(23110) Redis Objects: Use Redis connection: 127.0.0.1:9001
        host.raspberrypi	2020-12-03 21:21:17.297	info	instance system.adapter.enocean.0 started with pid 23110
        • Jey Cee
          Jey Cee Developer @Tobias Schnurr last edited by
          @Tobias-Schnurr sagte in Test Adapter EnOcean (2) v0.1.x:
          gehe auf Gerät hinzufügen und setze den Aktor in den Lern-Modus ( Oben Stellung LRN, Unten Stellung Auto oder EC1)
          Mache ich da noch was falsch?
          Nachdem im Log kein Telegram von deinem Aktor angekommen ist hab ich mal geschaut wieviele Versionen es davon gibt. Dieses Gerät gibt es seit 2009 mit 10 Versionen.
          Das heist als erstes müssen wir mal wissen wann dein Gerät Produziert wurde, das steht entweder in der Anleitung oder ist auf dem Gerät aufgedruckt (KW 10/17 oder ähnlich).
          Tobias Schnurr 1 Reply Last reply Reply Quote 0
          • Jey Cee
            Jey Cee Developer @TheAriba last edited by
            @EnoceanEltako sagte in Test Adapter EnOcean (2) v0.1.x:
            muss dann wieder alles zurückgesetzt werden oder kann einfach drüber installiert werden?
            Sollte dann ausreichend sein die neue Version einfach drüber zu installieren.
            • Jey Cee
              Anfragen für neue Geräte bitte wenn möglich in Zukunft über Github, ich verliere Langsam etwas den Überblick. Verwendet das Template 'Device request':
              https://github.com/Jey-Cee/ioBroker.enocean/issues/new/choose
              • Tobias Schnurr
                @Jey-Cee
                Also das ist ein Neugerät dieses Jahr gekauft.Ich schaue später noch mal auf den Aufkleber aber ich meine definitv in 2020 gefertigt.
                Laut Bedienungsanleitungen bei Eltako ist die neuste Version ab ab KW 46/17.
                Falls ich die Signal sonst noch mit irgendeinem Tool "belauschen" kann und die der Output weiter hilft gerne melden.
                  guergen @guergen last edited by
                  Mittlerweile habe ich mit die Info´s von den FUD61NPN-230V zusammengesucht:
                  die Dimmwerte und An/Aus wird auch übergeben, aber steuern kann ich es noch nicht.
                  Das mit den Base-ID´s hab ich noch nicht raus...
                  • Jey Cee
                    Jey Cee Developer @guergen last edited by
                    @guergen es wäre gut wenn du erklärst wie du den Fud61 angelernt hast, dann hilft das vielleicht auch @Tobias-Schnurr weiter.
                    @guergen sagte in Test Adapter EnOcean (2) v0.2.x:
                    Das musst du auch nicht verstehen wenn du keine Geräte aus der Serie 14 hast.
                    Aktuell gibt es hier nur das Problem das du maximal den ersten angelernten Aktor steuern kannst, das ist ein Problem im Zusammenhang mit den Eltako Geräten.
                      guergen @Jey Cee last edited by guergen
                      @Jey-Cee @Tobias-Schnurr
                      Ich habe die FUD zu Fuß eingetragen:
                      Zuerst einen DP angelegt mit folgenden RAW-Daten:
                        "type": "device",
                        "common": {
                          "name": "Licht Wohnzimmer"
                        "native": {
                          "id": "018d0a0a",
                          "manufacturer": "Enocean GmbH",
                          "eep": [
                            "TF-13-07",
                            "TF-13-05",
                            "TF-13-06"
                        "from": "system.adapter.enocean.0",
                        "user": "system.user.admin",
                        "ts": 1607017427335,
                        "_id": "enocean.0.018d0a0a",
                        "acl": {
                          "object": 1636,
                          "owner": "system.user.admin",
                      Anschliessend habe ich mir die DP-Formate aus der.json kopiert und alles eingetragen:
                      Level:
                        "type": "state",
                        "common": {
                          "name": "Level",
                          "role": "value.level",
                          "type": "number",
                          "read": true,
                          "write": true,
                          "unit": "%",
                          "def": 0
                        "native": {},
                        "ts": 1607016375019,
                        "_id": "enocean.0.018d0a0a.LVL",
                        "acl": {
                          "object": 1636,
                          "state": 1636
                      rssi:
                        "type": "state",
                        "common": {
                          "name": "Signal Strength",
                          "role": "value.rssi",
                          "type": "number",
                          "read": true,
                          "write": false,
                          "unit": "dBm"
                        "native": {},
                        "_id": "enocean.0.018d0a0a.rssi",
                        "acl": {
                          "object": 1636,
                          "state": 1636
                      und ON:
                        "type": "state",
                        "common": {
                          "name": "On",
                          "role": "state",
                          "type": "boolean",
                          "read": true,
                          "write": false,
                          "states": "0:false; 1:true",
                          "def": 0
                        "native": {},
                        "_id": "enocean.0.018d0a0a.ON",
                        "acl": {
                          "object": 1636,
                          "state": 1636
                      Command, Dimming Speed und Blocklevel ebenfalls, aber da kommen keine Info´s rein Zumindest kann ich die Beleuchtung schon einmal visualisieren und kann so langsam mein FHEM in Rente schicken.
                      Meine Enocean PTM215 werden automatisch erkannt als F6-02-02.
                      • Jey Cee
                        @guergen jetzt ist klar warum du den Aktor nicht steuern kannst, du hast ihn gar nicht angelernt.
                        Von wann ist dein Aktor?
                          @Jey-Cee 23/14 & 27/14
                          Angelernt hab ich sie ja gar nicht bekommen.... daher zu Fuß
                            guergen @guergen last edited by guergen
                            Unter FHEM wird mir der FUD als A5-38-08 angezeigt, vielleicht hilft das!
                            Und der PT210 als F6-02-01.
                            ein weiterer PT210 als F6-10-00
                            G Jey Cee 2 Replies Last reply Reply Quote 0
                              Die FUD sind Version 8 habe ich grade herausgefunden
                              • Jey Cee
                                In Fhem oder im Adapter?
                                  @Jey-Cee In Fhem wurde er als PTM210 mit F6-10-00 erkannt. Im EnOcean-Adapter wurden alle 4 Taster (PTM215) als F6-02-02 automatisch erkannt.
                                    teddy @Jey Cee last edited by teddy
                                    @Jey-Cee said in Test Adapter EnOcean (2) v0.2.x:
                                    FSR14 ... die Sender (Base) ID von ioBroker für jeden Kanal eine eigene sein muss
                                    Hi Jey-Cee, diese Base ID kann man sich aussuchen (einfach 4 hex bytes und los) oder ist die schon irgendwo abgespeichert? Vielen Dank
                                    • Jey Cee
                                      @Tobias-Schnurr @guergen bitte mal von Github neu installieren, die Version bleibt gleich. Für die FUD habe ich jetzt ein zweites Gerät angelegt für manuelles Teachin.
                                      @teddy diese Frage erübrigt sich von selbst wenn du die Anweisungen im Adapter befolgst.
                                      G T 2 Replies Last reply Reply Quote 0
                                        @Jey-Cee Installiert habe ich es von git.
                                        Jetzt aber mal eine ganz doofe Frage: Wie lernt men den egtl richtig an? In der Anleitung steht nicht wirklich hochdeutsch...
                                        Bestätigungstelegramme hab ich an, sonst würden im Broker ja keine Daten aktualisiert.
                                        Ich habe es mit einer Brücke zwischen L und an(hoch)/aus(runter) versucht.
                                        Wahrscheinlich muss ich den Broker als Sensor anlernen mit Auto/LRN, oder?
                                        Jey Cee G 2 Replies Last reply Reply Quote 0
                                        • Jey Cee
                                          @guergen ich schreib das Heute abend zusammen wie man den FUD anlernen muss.
                                            @Jey-Cee Auto/LRN wäre richtig, jedoch sendet der Stick scheinbar nichts, da die LED nicht aus geht! Bei einem anderen Taster am FUD habe ich das grade noch einmal gemacht, um sicher zu gehen, dass er/es funktioniert
                                            31.7k
                                            79.9k
                                            eltako enocean enocean adapter tipp-funk
                                            38
                                            675
                                            134831
