    4. Test Adapter radar2 v1.2.x GitHub
    • nik82
      nik82 Most Active @patrick039212 last edited by nik82
      ich würde auch gerne den Radar-Adapter installieren, aber bei jeder Installation zerschießt es mir den kompletten IOBroker,
      bleibt hier hängen und danach geht gar nichts mehr, muss komplett zurücksichern:
      $ ./iobroker add radar2 --host IOBROKER(Iobroker)
      NPM version: 6.11.3
      npm install iobroker.radar2@2.0.1 --loglevel error (System call)
      prebuild-install
      info begin Prebuild-install version 5.3.6
      prebuild-install info looking for cached prebuild @
      C:\iobroker\Iobroker\env\npm-cache_prebuilds\b5fa15-usb-v1.6.3-node-v64-win32-x64.tar.gzprebuild-install http request GET https://github.com/tessel/node-usb/releases/download/v1.6.3/usb-v1.6.3-node-v64-win32-x64.tar.gz
      prebuild-install
      http 200 https://github.com/tessel/node-usb/releases/download/v1.6.3/usb-v1.6.3-node-v64-win32-x64.tar.gz
      prebuild-install
      info downloading to @ C:\iobroker\Iobroker\env\npm-cache_prebuilds\b5fa15-usb-v1.6.3-node-v64-win32-x64.tar.gz.3948-d8d137107a5c8.tmp
      prebuild-install info renaming to @ C:\iobroker\Iobroker\env\npm-cache_prebuilds\b5fa15-usb-v1.6.3-node-v64-win32-x64.tar.gz
      prebuild-install info unpacking @ C:\iobroker\Iobroker\env\npm-cache_prebuilds\b5fa15-usb-v1.6.3-node-v64-win32-x64.tar.gz
      resolved to C:\iobroker\Iobroker\node_modules\usb\build\Release\usb_bindings.node
      required C:\iobroker\Iobroker\node_modules\usb\build\Release\usb_bindings.node successfullyprebuild-install info install Successfully installed prebuilt binary!
      gyp
      ERR! build error
      gyp ERR! stack Error: C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe failed with exit code: 1gyp ERR!
      stack at ChildProcess.onExit (C:\iobroker\Iobroker\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:193:23)gyp ERR! stack at ChildProcess.emit (events.js:198:13)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
      gyp
      ERR! System Windows_NT 10.0.18362gyp
      ERR! command "C:\iobroker\Iobroker\nodejs\node.exe" "C:\iobroker\Iobroker\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "build" "--fallback-to-build" "--module=C:\iobroker\Iobroker\node_modules\@abandonware\bluetooth-hci-socket\lib\binding\bluetooth_hci_socket.node" "--module_name=bluetooth_hci_socket" "--module_path=C:\iobroker\Iobroker\node_modules\@abandonware\bluetooth-hci-socket\lib\binding" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"gyp ERR! cwd C:\iobroker\Iobroker\node_modules@abandonware\bluetooth-hci-socket
      gyp ERR! node -v v10.17.0gyp ERR! node-gyp -v v5.0.3
      gyp ERR! not ok
      node-pre-gyp
      ERR! build error node-pre-gyp ERR! stack
      Error: Failed to execute 'C:\iobroker\Iobroker\nodejs\node.exe C:\iobroker\Iobroker\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js build --fallback-to-build --module=C:\iobroker\Iobroker\node_modules@abandonware\bluetooth-hci-socket\lib\binding\bluetooth_hci_socket.node --module_name=bluetooth_hci_socket --module_path=C:\iobroker\Iobroker\node_modules@abandonware\bluetooth-hci-socket\lib\binding --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack at ChildProcess.<anonymous> (C:\iobroker\Iobroker\node_modules\node-pre-gyp\lib\util\compile.js:83:29)node-pre-gyp ERR! stack at ChildProcess.emit (events.js:198:13)node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:982:16)node-pre-gyp
      ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
      node-pre-gyp
      ERR! System Windows_NT 10.0.18362node-pre-gyp ERR! command "C:\iobroker\Iobroker\nodejs\node.exe" "C:\iobroker\Iobroker\node_modules\node-pre-gyp\bin\node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR!
      cwd C:\iobroker\Iobroker\node_modules@abandonware\bluetooth-hci-socketnode-pre-gyp ERR! node -v v10.17.0node-pre-gyp ERR! node-pre-gyp -v v0.15.0
      node-pre-gyp ERR! not ok
      host.IOBROKER(Iobroker) install adapter radar2
      ERROR: (node:14884) UnhandledPromiseRejectionWarning: Error: Cannot find module 'mime' at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15) at Function.Module._load (internal/modules/cjs/loader.js:562:25) at Module.require (internal/modules/cjs/loader.js:692:17) at require (internal/modules/cjs/helpers.js:25:18) at Upload.uploadAdapter (C:\iobroker\Iobroker\node_modules\iobroker.js-controller\lib\setup\setupUpload.js:533:24) at packetManager.install.catch.then (C:\iobroker\Iobroker\node_modules\iobroker.js-controller\lib\setup\setupInstall.js:774:28) at process._tickCallback (internal/process/next_tick.js:68:7)(node:14884) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
      ERROR: (node:14884) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
      Habe eine Iobroker Windows Installation.
      Jemand eine Idee was ich noch machen kann oder ob evtl. irgend etwas fehlt das ich vorher noch installieren muss?
      Danke im Voraus.
      Als Info noch:
      c4c818e6-b865-440a-96d8-91ff07ad79af-image.png JS-Controller
      EDIT
      Problem erledigt, lag an der Iobroker Installation, nicht am Adapter.
      frankjoke 1 Reply Last reply Reply Quote 0
      • frankjoke
        frankjoke @nik82 last edited by
        @nik82
        Ich habe eden Adapter (V2.0.1) auf einem Windows-Testsystem laufen:
        Node.js
        v10.21.0 (There is a newer version: v10.23.0 - Recommended version v12.19.0)
        NPM
        6.14.4
        Wie hast du das Windows-System installiert? Scheinst Probleme mit node-Gyp für Windows zu haben und der normalen Installationsroutine zu haben!
        Kannst es mal mittels admin installieren (nicht auf der Kommandozeile)?
        Übrigens, Radar2 hat nur ca 30% seiner Funktionen unter Windows da er nur normale Netzwerkabfragen machen kann aber momentan leider kein BT mehr funktioniert!
        Ich verwende Windows nur zum Testen und Entwickeln ob sich die Adapter darauf installieren lassen oder nicht, aber nicht für wirkliche Installation da es zu viele Einschränkungen hat.
        nik82 1 Reply Last reply Reply Quote 0
        • nik82
          nik82 Most Active @frankjoke last edited by
          @frankjoke
          Danke für deine Hilfe, aber wie oben schon unten als EDIT geschrieben, war meine Installation zerschossen.
          Aber trotzdem danke.
          • Basti97
            Basti97 Most Active last edited by
            Ich habe nun den Adapter Radar2 installiert. Nachdem ich alle zusätzlich benötigten Installation durchgeführt habe. Funktoniert er gleich sofort. Nun habe ich aber trotzdem eine Frage wo kann ich einstellen das der Bluetooth Adapter nicht jedes mal alle Scant und in den Datenpunkt ubts Datenpunkt schreibt. Sondern nur die Zufuhr eingegebeneb bzw bekannten Geräten.
            • frankjoke
              frankjoke @Basti97 last edited by
              @Basti97
              Wenn du V2.01 verwendest dann kannst das einzelne Abspeichern in der Konfig (Speichern Sie unbekannte BT-Daten) verhindern. Die eine Variable wo alle unknown macs gelistet werden wird trotzdem generiert damit der Adapter weiß welche er schon gesehen hat!
              Basti97 1 Reply Last reply Reply Quote 0
              • Basti97
                Basti97 Most Active @frankjoke last edited by Basti97
                @frankjoke Ok Danke ja ich habe den neuesten. Ich gucke mal und probiere es mal aus. 😁😁 Aso und die unbekannten Macs die nicht gespeichert werden sollen werden dann nicht mehr aktualisiert oder?
                  Jan1 last edited by
                  Wie bekomme ich das eigentlich weg?
                  radar2.0	2020-12-05 14:17:13.657	warn	(360746) Adapter not running as root or iobroker has no sudo right, cannot use arp-scan!
                  Diginix 1 Reply Last reply Reply Quote 1
                  • Diginix
                    Diginix @Jan1 last edited by Diginix
                    @Jan1 Alle setcap Befehle wie in Post #2 beschrieben ausgeführt?
                      Jan1 @Diginix last edited by
                      @Diginix
                      Das da:
                      sudo apt-get install libcap2-bin arp-scan bluetooth bluez libbluetooth-dev libudev-dev net-tools
                      sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which arp-scan`)
                      sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which node`)
                      sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which arp`)
                      sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which hcitool`)
                      sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which hciconfig`)
                      sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which l2ping`)
                      Oder noch was anderes?
                        Thomas Braun Most Active @Jan1 last edited by
                        @Jan1
                        sudo -u iobroker groups
                          Jan1 @Thomas Braun last edited by
                          @Thomas-Braun
                          jan@Beelink:~$ sudo -u iobroker groups
                          iobroker tty dialout audio video bluetooth
                            Thomas Braun Most Active @Jan1 last edited by Thomas Braun
                            @Jan1 Füg den User mal der Gruppe sudo hinzu.
                            Ist zwar eigentlich nicht Sinn der Sache, aber kannst ja mal schauen ob es damit funktioniert.
                              @Thomas-Braun
                              welchen, iobroker oder jan?
                                @Jan1 Den jan haben wir nicht angeschaut.
                                Aber wenn der auch fehlt, dann beide.
                                  @Thomas-Braun
                                  stimmt, ging ja um iobroker 🙂
                                  Also dann mal:
                                  sudo adduser iobroker sudo
                                  und
                                  sudo adduser jan sudo
                                    @Jan1 Nein...
                                    sudo usermod -aG sudo iobroker
                                      Jan1 @Thomas Braun last edited by Jan1
                                      @Thomas-Braun
                                      ausgeführt
                                      wie überprüfe ich das nun noch?
                                        @Jan1
                                        Den Befehl von vorhin nochmal ausführen?
                                        Kann aber sein, dass der User iobroker erst einmal ausgeloggt werden muss. Starte am besten mal neu.
                                          @Thomas-Braun
                                          jou is drin
                                          iobroker tty dialout sudo audio video bluetooth
                                          mal schauen ob die Meldung damit erledigt ist.
                                            @Thomas-Braun
                                            Das war leider nicht die Lösung, da nach Neustart des Adapter schon wieder diese Meldung drinsteht:
                                            radar2.0	2020-12-06 11:28:47.062	warn	(6069) Adapter not running as root or iobroker has no sudo right, cannot use arp-scan!
                                            1.0k
                                            radar2 adapter
                                            49
                                            244
                                            36960
