Test Adapter EnOcean (2) v0.3.x
@EnoceanEltako geht nur um Geräte anlernen, aber du hast keinen FUD61 oder?
Den TF61D und FSR61 kannst du Testen, die sind beide drin.
@Jey-Cee nein, habe nur den TF61D und den FSR61.
TF61D lässt sich nicht anlernen.
FSR61 muss ich morgen testen, ist in der Garage bei mir.
TF61D 584de13enocean.0 2020-12-06 20:38:32.353 info (20156) state enocean.0.gateway.teachin deleted enocean.0 2020-12-06 20:38:32.346 info (20156) Teachin mode de-activated enocean.0 2020-12-06 19:37:46.216 debug (20156) 55000707017ad5090582de300000ffffffff4c00 enocean.0 2020-12-06 19:37:45.896 debug (20156) sendTo "getEEPList" to system.adapter.admin.0 from system.adapter.enocean.0 enocean.0 2020-12-06 19:37:45.893 debug (20156) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.enocean.0 enocean.0 2020-12-06 19:37:45.892 debug (20156) sendTo "listSerial" to system.adapter.admin.0 from system.adapter.enocean.0 enocean.0 2020-12-06 19:37:45.891 info (20156) ["/dev/ttyAMA0","/dev/ttyUSB0"]
Der TF 100L lässt sich leider auch nicht einlernen. Restaret den Adapter sogar... EnoceanID 5936c86
host.raspberrypi 2020-12-06 19:47:35.828 info Restart adapter system.adapter.enocean.0 because enabled host.raspberrypi 2020-12-06 19:47:35.818 info instance system.adapter.enocean.0 terminated with code 0 (NO_ERROR) enocean.0 2020-12-06 19:47:35.271 info (22429) Terminated (NO_ERROR): Without reason enocean.0 2020-12-06 19:47:35.266 info (22429) terminating enocean.0 2020-12-06 19:47:35.256 info (22429) The serial port was closed. enocean.0 2020-12-06 19:47:35.247 info (22429) cleaned everything up... enocean.0 2020-12-06 19:47:35.244 error at processTicksAndRejections (internal/process/task_queues.js:97:5) enocean.0 2020-12-06 19:47:35.244 error at runMicrotasks (<anonymous>) enocean.0 2020-12-06 19:47:35.244 error at handleTeachIn.main (/opt/iobroker/node_modules/iobroker.enocean/lib/tools/Packet_handler.js:452:12) enocean.0 2020-12-06 19:47:35.244 error at addEltakoDevice (/opt/iobroker/node_modules/iobroker.enocean/lib/tools/Packet_handler.js:681:36) enocean.0 2020-12-06 19:47:35.244 error (22429) TypeError: Cannot read property 'name' of undefined enocean.0 2020-12-06 19:47:35.242 error (22429) unhandled promise rejection: Cannot read property 'name' of undefined Unhandled 2020-12-06 19:47:35.241 error promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). enocean.0 2020-12-06 19:47:35.232 debug (22429) 55000e070140d100d0fe030301007705936c860000ffffffff4a00 enocean.0 2020-12-06 19:47:35.056 debug (22429) 55000d0701fdd100d0ff0000041405936c860000ffffffff4600 enocean.0 2020-12-06 19:47:34.528 debug (22429) 55000707017af600fef5796b2000ffffffff3a00 enocean.0 2020-12-06 19:47:33.008 debug (22429) 55000707017af65005936c863000ffffffff4300 enocean.0 2020-12-06 19:47:32.704 debug (22429) 55000707017af610fef5796b3000ffffffff3c00 enocean.0 2020-12-06 19:47:32.496 debug (22429) 55000707017af67005936c863000ffffffff3d00 enocean.0 2020-12-06 19:47:32.416 debug (22429) 55000707017af600fef5796b2000ffffffff3c00 enocean.0 2020-12-06 19:47:32.224 debug (22429) 55000707017af610fef5796b3000ffffffff3c00 enocean.0 2020-12-06 19:47:32.048 debug (22429) 55000707017af65005936c863000ffffffff4300 enocean.0 2020-12-06 19:47:31.984 debug (22429) 55000707017af600fef5796b2000ffffffff3c00 enocean.0 2020-12-06 19:47:31.776 debug (22429) 55000707017af610fef5796b3000ffffffff3d00 enocean.0 2020-12-06 19:47:31.584 debug (22429) 55000707017af67005936c863000ffffffff4000 enocean.0 2020-12-06 19:47:31.520 debug (22429) 55000707017af600fef5796b2000ffffffff3c00 enocean.0 2020-12-06 19:47:31.377 debug (22429) 55000707017af67005936c863000ffffffff4300 enocean.0 2020-12-06 19:47:31.344 debug (22429) 55000707017af610fef5796b3000ffffffff3d00 enocean.0 2020-12-06 19:47:31.088 debug (22429) 55000707017af600fef5796b2000ffffffff3d00 enocean.0 2020-12-06 19:47:30.896 debug (22429) 55000707017af610fef5796b3000ffffffff3d00 enocean.0 2020-12-06 19:47:16.182 debug (22429) Message for ID 0583fcec has been received. enocean.0 2020-12-06 19:47:16.179 debug (22429) 55000707017ad5090583fcec0000ffffffff4f00 enocean.0 2020-12-06 19:47:08.184 debug (22429) sendTo "getEEPList" to system.adapter.admin.0 from system.adapter.enocean.0 enocean.0 2020-12-06 19:47:08.181 debug (22429) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.enocean.0 enocean.0 2020-12-06 19:47:08.174 debug (22429) sendTo "listSerial" to system.adapter.admin.0 from system.adapter.enocean.0 enocean.0 2020-12-06 19:47:08.173 info (22429) ["/dev/ttyAMA0","/dev/ttyUSB0"]
@Jey-Cee die (1) ist bei mir nicht drin... hatte mich schon gewundert...
Lade JETZT noch einmal von git! -
@Jey-Cee Jetzt war die (1)-Version da:
Eingetragen, gelesen, eingetragen, eingelesen:enocean.0 2020-12-07 12:41:53.010 debug (1207) Message for ID 008bab19 has been received. enocean.0 2020-12-07 12:41:53.006 debug (1207) 55000707017af650008bab193003ffffffff4300 enocean.0 2020-12-07 12:41:31.749 debug (1207) Packet type 2 received: 02 enocean.0 2020-12-07 12:41:31.749 debug (1207) 55000100026503 enocean.0 2020-12-07 12:41:31.740 debug (1207) Sent data: 550006070111a5ffd07c000000018d0a0aff0092 enocean.0 2020-12-07 12:41:31.740 warn (1207) The data length for a 4BS telegram is incorrect. The length is 0 enocean.0 2020-12-07 12:41:31.736 info (1207) state 018d0a0a.CMD changed: 4 (ack = true) state: {"val":4,"ack":true,"ts":1607341291734,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607341291734} enocean.0 2020-12-07 12:41:26.056 debug (1207) Packet type 2 received: 02 enocean.0 2020-12-07 12:41:26.056 debug (1207) 55000100026503 enocean.0 2020-12-07 12:41:26.039 debug (1207) Sent data: 550006070111a5ffd07c000000018d0a0aff0092 enocean.0 2020-12-07 12:41:26.039 warn (1207) The data length for a 4BS telegram is incorrect. The length is 0 enocean.0 2020-12-07 12:41:26.035 info (1207) state 018d0a0a.CMD changed: 0 (ack = false) state: {"val":0,"ack":false,"ts":1607341286033,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607341286033} enocean.0 2020-12-07 12:41:23.945 debug (1207) Packet type 2 received: 02 enocean.0 2020-12-07 12:41:23.944 debug (1207) 55000100026503 enocean.0 2020-12-07 12:41:23.923 debug (1207) Sent data: 550006070111a5ffd07c000000018d0a0aff0092 enocean.0 2020-12-07 12:41:23.923 warn (1207) The data length for a 4BS telegram is incorrect. The length is 0 enocean.0 2020-12-07 12:41:23.915 info (1207) state 018d0a0a.CMD changed: 4 (ack = false) state: {"val":4,"ack":false,"ts":1607341283911,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607341279733} enocean.0 2020-12-07 12:41:19.786 debug (1207) Packet type 2 received: 02 enocean.0 2020-12-07 12:41:19.786 debug (1207) 55000100026503 enocean.0 2020-12-07 12:41:19.770 debug (1207) Sent data: 550006070111a5ffd07c000000018d0a0aff0092 enocean.0 2020-12-07 12:41:19.769 warn (1207) The data length for a 4BS telegram is incorrect. The length is 0 enocean.0 2020-12-07 12:41:19.738 info (1207) state 018d0a0a.CMD changed: 4 (ack = false) state: {"val":4,"ack":false,"ts":1607341279733,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607341279733} enocean.0 2020-12-07 12:41:16.795 debug (1207) Packet type 2 received: 02 enocean.0 2020-12-07 12:41:16.795 debug (1207) 55000100026503 enocean.0 2020-12-07 12:41:16.781 debug (1207) Sent data: 550006070111a5ffd07c000000018d0a0aff0092 enocean.0 2020-12-07 12:41:16.781 warn (1207) The data length for a 4BS telegram is incorrect. The length is 0 enocean.0 2020-12-07 12:41:16.778 info (1207) state 018d0a0a.CMD changed: 5 (ack = false) state: {"val":5,"ack":false,"ts":1607341276775,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607341276775} enocean.0 2020-12-07 12:41:08.191 debug (1207) Packet type 2 received: 02 enocean.0 2020-12-07 12:41:08.190 debug (1207) 55000100026503 enocean.0 2020-12-07 12:41:08.181 debug (1207) Sent data: 550006070111a5ffd07c000000018d0a0aff0092 enocean.0 2020-12-07 12:41:08.180 warn (1207) The data length for a 4BS telegram is incorrect. The length is 0 enocean.0 2020-12-07 12:41:08.177 info (1207) state 018d0a0a.CMD changed: 4 (ack = false) state: {"val":4,"ack":false,"ts":1607341268174,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607341260575} enocean.0 2020-12-07 12:41:00.594 debug (1207) Packet type 2 received: 02 enocean.0 2020-12-07 12:41:00.593 debug (1207) 55000100026503 enocean.0 2020-12-07 12:41:00.583 debug (1207) Sent data: 550006070111a5ffd07c000000018d0a0aff0092 enocean.0 2020-12-07 12:41:00.582 warn (1207) The data length for a 4BS telegram is incorrect. The length is 0 enocean.0 2020-12-07 12:41:00.578 info (1207) state 018d0a0a.CMD changed: 4 (ack = false) state: {"val":4,"ack":false,"ts":1607341260575,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607341260575} enocean.0 2020-12-07 12:40:40.688 info (1207) undefined enocean.0 2020-12-07 12:40:40.679 info (1207) undefined enocean.0 2020-12-07 12:40:40.666 debug (1207) sendTo "newDevice" to system.adapter.admin.0 from system.adapter.enocean.0 enocean.0 2020-12-07 12:40:40.665 info (1207) Create objects for TF-13-06 from ELTAKO with id: 018d0a0a enocean.0 2020-12-07 12:40:40.665 info (1207) undefined enocean.0 2020-12-07 12:40:40.665 info (1207) new device enocean.0 2020-12-07 12:40:40.663 debug (1207) sendTo "newDevice" to system.adapter.admin.0 from system.adapter.enocean.0 enocean.0 2020-12-07 12:40:40.663 info (1207) Create objects for TF-13-07 from ELTAKO with id: 018d0a0a enocean.0 2020-12-07 12:40:40.662 info (1207) undefined enocean.0 2020-12-07 12:40:40.661 info (1207) new device enocean.0 2020-12-07 12:39:42.598 debug (1207) sendTo "getEEPList" to system.adapter.admin.0 from system.adapter.enocean.0 enocean.0 2020-12-07 12:39:42.558 debug (1207) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.enocean.0 enocean.0 2020-12-07 12:39:42.557 debug (1207) sendTo "listSerial" to system.adapter.admin.0 from system.adapter.enocean.0 enocean.0 2020-12-07 12:39:42.556 info (1207) ["/dev/ttyUSB0"]
Datenpunkte sind da, allerdings auf "write false" habe sie auf "write true" geändert, der FUD reagiert aber nicht.
also ich kann leider auch die TF61J nicht bedienen.
@EnoceanEltako ernsthaft. Ich glaub ich geb auf.
@guergen mach mal das Objekt vom device auf und schau in Raw.
Das sollte exakt (bis auf die ID) so aus sehen:
{ "type": "device", "common": { "name": "Licht Wohnzimmer" }, "native": { "id": "018d0a0a", "eep": [ "TF-13-06" ], "manufacturer": "ELTAKO" }, "from": "system.adapter.enocean.0", "user": "system.user.admin", "ts": 1607341240700, "_id": "enocean.0.018d0a0a", "acl": { "owner": "system.user.admin", "ownerGroup": "system.group.administrator", "object": 1636 } }
TF-13-07 ist nicht drin
@Jey-Cee Von Hand nachtragen hat nichts gebracht
@EnoceanEltako sagte in Test Adapter EnOcean (2) v0.2.x:
Hm der sendet auch kein Teachin telegram.
@guergen sagte in Test Adapter EnOcean (2) v0.2.x:
Tausch die beiden mal, also 07 oben und 96 unten.
@Jey-Cee Ändert nichts... reagiert nicht auch nicht auf CMD
enocean.0 2020-12-07 14:33:42.140 debug (1268) system.adapter.admin.0: logging true enocean.0 2020-12-07 14:33:32.071 debug (1268) Packet type 2 received: 02 enocean.0 2020-12-07 14:33:32.070 debug (1268) 55000100026500 enocean.0 2020-12-07 14:33:32.047 debug (1268) Sent data: 55000a0701eba502640009ffd07c000000018d0a0aff0004 enocean.0 2020-12-07 14:33:32.042 info (1268) state 018d0a0a.CMD changed: 1 (ack = false) state: {"val":1,"ack":false,"ts":1607348012040,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607348007424} enocean.0 2020-12-07 14:33:27.448 debug (1268) Packet type 2 received: 02 enocean.0 2020-12-07 14:33:27.448 debug (1268) 55000100026500 enocean.0 2020-12-07 14:33:27.431 debug (1268) Sent data: 55000a0701eba502640009ffd07c000000018d0a0aff0004 enocean.0 2020-12-07 14:33:27.427 info (1268) state 018d0a0a.CMD changed: 1 (ack = false) state: {"val":1,"ack":false,"ts":1607348007424,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607348007424} enocean.0 2020-12-07 14:32:07.860 debug (1268) Packet type 2 received: 02 enocean.0 2020-12-07 14:32:07.860 debug (1268) 55000100026500 enocean.0 2020-12-07 14:32:07.841 debug (1268) Sent data: 55000a0701eba502000008ffd07c000000018d0a0aff000b enocean.0 2020-12-07 14:32:07.838 info (1268) state 018d0a0a.CMD changed: 0 (ack = false) state: {"val":0,"ack":false,"ts":1607347927834,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607347927834} enocean.0 2020-12-07 14:32:03.063 debug (1268) Packet type 2 received: 02 enocean.0 2020-12-07 14:32:03.063 debug (1268) 55000100026500 enocean.0 2020-12-07 14:32:03.037 debug (1268) Sent data: 55000a0701eba502640009ffd07c000000018d0a0aff0004 enocean.0 2020-12-07 14:32:03.031 info (1268) state 018d0a0a.CMD changed: 1 (ack = false) state: {"val":1,"ack":false,"ts":1607347923028,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607347923028} enocean.0 2020-12-07 14:31:53.435 debug (1268) Packet type 2 received: 02 enocean.0 2020-12-07 14:31:53.434 debug (1268) 55000100026500 enocean.0 2020-12-07 14:31:53.410 debug (1268) Sent data: 55000a0701eba502260009ffd07c000000018d0a0aff00ea enocean.0 2020-12-07 14:31:53.400 info (1268) state 018d0a0a.CMD changed: 3 (ack = false) state: {"val":3,"ack":false,"ts":1607347913396,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607347913396} enocean.0 2020-12-07 14:31:36.417 debug (1268) Message for ID 018d0a0a has been received. enocean.0 2020-12-07 14:31:36.416 debug (1268) 55000a0701eba502260009018d0a0a0003ffffffff3d00
enocean.0 2020-12-07 14:35:00.306 debug (1268) system.adapter.admin.0: logging true enocean.0 2020-12-07 14:34:58.536 debug (1268) Message for ID 018d0a0a has been received. enocean.0 2020-12-07 14:34:58.535 debug (1268) 55000a0701eba502000008018d0a0a0003ffffffff3d00 enocean.0 2020-12-07 14:34:56.921 debug (1268) Message for ID 018d0a0a has been received. enocean.0 2020-12-07 14:34:56.920 debug (1268) 55000707017af650018d0a0a3003ffffffff3d00 enocean.0 2020-12-07 14:34:56.313 debug (1268) Message for ID fefe5a51 has been received. enocean.0 2020-12-07 14:34:56.311 debug (1268) 55000707017af600fefe5a512003ffffffff3700 enocean.0 2020-12-07 14:34:56.057 debug (1268) Message for ID fefe5a51 has been received. enocean.0 2020-12-07 14:34:56.056 debug (1268) 55000707017af610fefe5a512003ffffffff3d00 enocean.0 2020-12-07 14:34:53.802 debug (1268) system.adapter.admin.0: logging false enocean.0 2020-12-07 14:34:52.282 debug (1268) Message for ID 018d0a0a has been received. enocean.0 2020-12-07 14:34:52.281 debug (1268) 55000a0701eba5023d0009018d0a0a0003ffffffff3d00 enocean.0 2020-12-07 14:34:50.427 debug (1268) Message for ID fefe5a51 has been received. enocean.0 2020-12-07 14:34:50.426 debug (1268) 55000707017af600fefe5a512003ffffffff3800 enocean.0 2020-12-07 14:34:48.738 debug (1268) Message for ID fefe5a51 has been received. enocean.0 2020-12-07 14:34:48.730 debug (1268) 55000707017af610fefe5a513003ffffffff3800
Der Taster ist der fefe5a51
Das ist logisch weil das Anlernen ja auch schon nicht funktioniert hat. Das heist du musst den Aktor nochmal in den Anlernmodus bringen und dann das Teachin telegram senden.
@Jey-Cee Jetzt, wo alles eingetragen ist? Mache ich!
@Jey-Cee Ja, jetzt läuft es. Nur die Bedienung scheint etwas kompliziert zu sein, erst den level eintragen und dann cmd auf 3 setzen
@Jey-Cee die Unit "%"fehlt noch im LVL und die write habe ich auf true geändert.
Jetzt muss ich mir noch überlegen, wie der cmd mit den Prozent übergeben wird,,,, -
@Jey-Cee
Hab jetzt auch gerade mal folgendes gemacht:
Adapter 0.1.8 deinstalliert
Adapter 0.2.1 installiert
einen zurückgesetzten TF61J entsprechend Schritt 1 und 2 am Adapter eingerichtet.
Der TF61J lässt sich auch bei mir nicht steuern!enocean.0 2020-12-07 14:56:20.676 debug (4944) Message for ID 051b86c2 has been received. enocean.0 2020-12-07 14:56:20.648 debug (4944) 55000e070140d100d0fe0303010076051b86c20000ffffffff4900 enocean.0 2020-12-07 14:56:20.061 info (4944) Create objects for F6-02-02 from ELTAKO with id: 051b86c2 enocean.0 2020-12-07 14:56:20.060 info (4944) undefined enocean.0 2020-12-07 14:56:20.045 debug (4944) Message for ID 058cd41c has been received. enocean.0 2020-12-07 14:56:20.034 debug (4944) 550009070156a5fff80d058cd41c8100051b86c24400 enocean.0 2020-12-07 14:56:20.022 debug (4944) Packet type 2 received: 02 enocean.0 2020-12-07 14:56:20.022 debug (4944) 55000100026500 enocean.0 2020-12-07 14:56:19.969 info (4944) Create objects for TF-01-01 from ELTAKO with id: 051b86c2 enocean.0 2020-12-07 14:56:19.969 info (4944) undefined enocean.0 2020-12-07 14:56:19.969 debug (4944) Sent data: 550009070156a5fff80d804e614e0001051b86c2ff00da enocean.0 2020-12-07 14:56:19.968 info (4944) Eltako TF61J-230V detected enocean.0 2020-12-07 14:56:19.958 debug (4944) 55000d0701fdd100d0ff00000436051b86c20000ffffffff4700
Der TF61J hat im Lernmodus auch nicht bestätigt, daß ein Sender erkannt wurde.
enocean.0 2020-12-07 14:58:31.943 info (4944) state 051b86c2.CMD changed: 0 (ack = false) state: {"val":0,"ack":false,"ts":1607349511940,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607349511940} enocean.0 2020-12-07 14:58:30.527 debug (4944) Message for ID 058cd41c has been received. enocean.0 2020-12-07 14:58:30.524 debug (4944) 55000807013da50100058cd41c8100051b86c24400 enocean.0 2020-12-07 14:58:30.508 debug (4944) Packet type 2 received: 02 enocean.0 2020-12-07 14:58:30.508 debug (4944) 55000100026500 enocean.0 2020-12-07 14:58:30.482 debug (4944) Sent data: 55000807013da50100000801000000051b86c2ff0010 enocean.0 2020-12-07 14:58:30.474 info (4944) state 051b86c2.CMD changed: 2 (ack = false) state: {"val":2,"ack":false,"ts":1607349510468,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607349510468} enocean.0 2020-12-07 14:58:27.672 debug (4944) Message for ID 058cd41c has been received. enocean.0 2020-12-07 14:58:27.672 debug (4944) 55000807013da50000058cd41c8100051b86c24400 enocean.0 2020-12-07 14:58:27.641 debug (4944) Packet type 2 received: 02 enocean.0 2020-12-07 14:58:27.641 debug (4944) 55000100026500 enocean.0 2020-12-07 14:58:27.618 debug (4944) Sent data: 55000807013da50000010801000000051b86c2ff00a8 enocean.0 2020-12-07 14:58:27.612 info (4944) state 051b86c2.CMD changed: 1 (ack = false) state: {"val":1,"ack":false,"ts":1607349507606,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607349507606} enocean.0 2020-12-07 14:58:22.262 debug (4944) Message for ID 051b86c2 has been received. enocean.0 2020-12-07 14:58:22.261 debug (4944) 55000e070140d100d0fe0303000000051b86c20000ffffffff4a00 enocean.0 2020-12-07 14:56:20.676 debug (4944) Message for ID 051b86c2 has been received. enocean.0 2020-12-07 14:56:20.648 debug (4944) 55000e070140d100d0fe0303010076051b86c20000ffffffff4900
Die Kommandos wurden alle nicht vom TF61J erkannt.
@Jey-Cee Den zweiten, der ja mit der "alten "Version eingetragen wurde, habe ich jetzt auch rein bekommenFUD auf LRN gestellt, Teach in (4) und schon kann er die Werte annehmen!
Uups, jetzt reagieren beide auf alles....
@Jey-Cee Ja, jetzt geht es, zu Fuß den TF-13-07 drüber schreiben
@Jey-Cee
kann jetzt nicht die USB-Schnittstelle nicht auswählen - im Log:host.kksmart 2020-12-07 15:29:30.448 info Restart adapter system.adapter.enocean.0 because enabled host.kksmart 2020-12-07 15:29:30.448 error instance system.adapter.enocean.0 terminated with code 1 (JS_CONTROLLER_STOPPED) host.kksmart 2020-12-07 15:29:30.448 error Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10) host.kksmart 2020-12-07 15:29:30.448 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30) host.kksmart 2020-12-07 15:29:30.448 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.enocean/lib/definitions/EEPinclude.js:77:10) host.kksmart 2020-12-07 15:29:30.448 error Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18) host.kksmart 2020-12-07 15:29:30.448 error Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17) host.kksmart 2020-12-07 15:29:30.448 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3) host.kksmart 2020-12-07 15:29:30.447 error Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12) host.kksmart 2020-12-07 15:29:30.447 error Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32) host.kksmart 2020-12-07 15:29:30.447 error Caught by controller[0]: at Object.Module._extensions..json (internal/modules/cjs/loader.js:797:27) host.kksmart 2020-12-07 15:29:30.447 error Caught by controller[0]: at JSON.parse (<anonymous>) host.kksmart 2020-12-07 15:29:30.447 error Caught by controller[0]: SyntaxError: /opt/iobroker/node_modules/iobroker.enocean/lib/definitions/eep/TF-13/TF-13-06.json: Unexpected token ' in JSON at position 614 host.kksmart 2020-12-07 15:29:30.447 error Caught by controller[0]: ^ host.kksmart 2020-12-07 15:29:30.447 error Caught by controller[0]: throw err; host.kksmart 2020-12-07 15:29:30.444 error Caught by controller[0]: internal/modules/cjs/loader.js:800
