    4. Test Adapter EnOcean (2) v0.3.x
      mustang @Jey Cee last edited by mustang
      @Jey-Cee
      kann jetzt nicht die USB-Schnittstelle nicht auswählen - im Log:
      host.kksmart	2020-12-07 15:29:30.448	info	Restart adapter system.adapter.enocean.0 because enabled
      host.kksmart	2020-12-07 15:29:30.448	error	instance system.adapter.enocean.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.kksmart	2020-12-07 15:29:30.448	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
      host.kksmart	2020-12-07 15:29:30.448	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
      host.kksmart	2020-12-07 15:29:30.448	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.enocean/lib/definitions/EEPinclude.js:77:10)
      host.kksmart	2020-12-07 15:29:30.448	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
      host.kksmart	2020-12-07 15:29:30.448	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
      host.kksmart	2020-12-07 15:29:30.448	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
      host.kksmart	2020-12-07 15:29:30.447	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
      host.kksmart	2020-12-07 15:29:30.447	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
      host.kksmart	2020-12-07 15:29:30.447	error	Caught by controller[0]: at Object.Module._extensions..json (internal/modules/cjs/loader.js:797:27)
      host.kksmart	2020-12-07 15:29:30.447	error	Caught by controller[0]: at JSON.parse (<anonymous>)
      host.kksmart	2020-12-07 15:29:30.447	error	Caught by controller[0]: SyntaxError: /opt/iobroker/node_modules/iobroker.enocean/lib/definitions/eep/TF-13/TF-13-06.json: Unexpected token ' in JSON at position 614
      host.kksmart	2020-12-07 15:29:30.447	error	Caught by controller[0]: ^
      host.kksmart	2020-12-07 15:29:30.447	error	Caught by controller[0]: throw err;
      host.kksmart	2020-12-07 15:29:30.444	error	Caught by controller[0]: internal/modules/cjs/loader.js:800
      • Jey Cee
        Jey Cee Developer @mustang last edited by
        @mustang habs gefixt, nochmal installieren.
        M G 2 Replies Last reply Reply Quote 0
          @Jey-Cee
          Der Adapter macht jetzt keine Restarts mehr, nur leider lässt sich der TF61J (frisch resettet) wieder nicht steuern, obwohl laut Log zwei Telegramme gesendet wurden.
            TheAriba @mustang last edited by TheAriba
            @mustang @Jey-Cee weitermachen. Aufgeben ist keine Option 🙂
            Wie kann ich denn irgendwie helfen?
            Edit: bringt es evtl. was den Adapter komplett zu löschen?
              guergen @Jey Cee last edited by guergen
              @Jey-Cee So, mit Hilfe eines kleinen Scripts, kann ich den Leuchten im VIS einen Prozentsatz mitgeben und ein/aus schalten!
              Danke!
                mustang @TheAriba last edited by mustang
                @EnoceanEltako
                leider bringt löschen/neuinstallieren nichts - so hab ich das gemacht...
                  TheAriba @guergen last edited by
                  @guergen magst du das mal sharen? Dann könnte der nächste das vllt. direkt nutzen 🙂
                  Ich selber hab kein solchen Aktor.
                    guergen @TheAriba last edited by guergen
                    @EnoceanEltako Kein Problem, schnell mit Blockly zusammengeclickt...:
                    <block xmlns="https://developers.google.com/blockly/xml" type="on" id="8#Gqm:!ZB2}.8ppS/LIZ" x="138" y="63">
                      <field name="OID">enocean.0.018d089e.LVL</field>
                        <block type="controls_if" id="i$yRHT]H]*=Sxi;,6cD7">
                            <block type="logic_compare" id="m#g$B%~/b,XeABP@HOMo">
                              <field name="OP">NEQ</field>
                                <block type="on_source" id="qZFy@RHw0Wb)W0Ao)5HI">
                                <block type="on_source" id=".7b|8@jFz9qrJslJRs8O">
                                  <field name="ATTR">oldState.val</field>
                            <block type="control" id="b(t/x(+E0%w^fhLC/$WI">
                              <field name="OID">enocean.0.018d089e.CMD</field>
                                <block type="math_number" id="^fqcrPw.;Z:C+5.`_B*]">
                                  <field name="NUM">3</field>
                    Dann kann ich den Level-Wert übergeben und der Command 3 für Set Level wird gesendet.
                    0 und 100 funktioniert selbstverständlich auch!
                    • Jey Cee
                      Wie sind den bei euch die rssi Werte der Aktoren? Je höher der Wert desto schlechter der Empfang.
                      Ich hab einen Zwischenstecker der lässt sich Steuern, im Test Setup hat das immer Funktioniert. Jetzt ist er im Einsatz für die Weihnachtsbeleuchtung, da reagiert er so gut wie gar nicht.
                      Da der letzte rssi Wert bei 88 lag dachte ich es liegt am Empfang, also habe ich ihn direkt eingeschalten. Wodurch er ein Telegram sendet.
                      Zu meiner Überraschung kam das auch an, aber der rssi lag bei 99.
                      Also hab ich den USB Stick an eine andere Stelle gestellt. Der rssi lag dann bei 79 und der Zwischenstecker hat wieder Zuverlässig geschalten.
                      Meine Schlussfolgerung, die Sendeleistung ist geringer als die Empangsempfindlichkeit. Demnach sollte der rssi Wert immer unter gut unter 80 liegen um eine Zuverlässige Übertragung zu Gewährleisten.
                      G M 2 Replies Last reply Reply Quote 0
                        @Jey-Cee der Beste Wert ist -55dB der Schlechteste -70dB
                          @Jey-Cee
                          Bei meinem TF61J liegt der zwischen -82 und -92 - und der funktioniert damit seit Anfang Oktober einwandfrei.
                          Den Test für eine neue Version mache ich mit einem TF61J auf dem Tisch neben der Antenne. Da kann es normal nicht zu Verlusten von Telegrammen kommen.
                            @mustang @Jey-Cee mich wundert es dass man dann ja aber doch irgendwie steuern kann. Also grundsätzlich ist es ja möglich.
                              @EnoceanEltako
                              ...ich betreibe es momentan ja auch noch mit der Version 0.1.8 und mache nur jeweils zum Testen ein Upgrade auf 0.2.x
                                @mustang ok hast du auch die TF61J im gesamten Haus im Einsatz?
                                • Jey Cee
                                  @guergen bei Fhem habe ich gelesen das seit mitte 2016 ein anderes Teachin telegram bei den FUD61 verwendet wird. Kannst du mal das Teach-in FSUD (Nummer 5) probieren, das ist das alte Teach-in telegram.
                                    @Jey-Cee Meine sind von 2014 und haben mit dem teach-in 4 ja funktioniert, trotzdem noch einmal rauswerfen?
                                    • Jey Cee
                                      Jey Cee Developer @guergen last edited by Jey Cee
                                      @guergen sagte in Test Adapter EnOcean (2) v0.2.x:
                                      Oh man ich bin schon ganz verwirrt.
                                      EDIT: Bei wem funktioniert jetzt was nicht mit der Version von Gestern?
                                        @Jey-Cee Ich habe meine Version von git gestern um etwa 12:29h geladen. Funktioniert.
                                        FUD61NPN-230V von 2014
                                          @EnoceanEltako
                                          nein - es ist momentan nur ein TF61J und ein TF-TA55J im Haus zum Praxistest verbaut. Davon lässt sich mit Version 0.1.8 momentan nur der TF61J steuern. Einen TF61J habe ich nebenbei auf dem Schreibtisch zum testen für neue Versionen des Adapters, da es sich so schneller mit Resets und weiteren Tests konfigurieren lässt.
                                          Ich habe geplant die TF-TA55J als weitere Aktoren zu verbauen, wenn der Adapter soweit funktioniert, daß sich die Jalousien einzeln steuern lassen.
                                          Neue Versionen des Adapters werden von mir immer nur temporär eingespielt, da ich diverse Kontakte auslese, welche auch Einfluss auf die Jalousiesteuerung haben. Daher bleibt Version 0.1.8 für mich im Moment weiterhin produktiv.
                                          • Jey Cee
                                            @mustang Ich hab den Fehler gefunden warum du deinen TF61J nicht anlernen konntest. Der Fehler ist behoben und auf Github.
                                            Der TF-TA55J ist jetzt auch im Adapter.
                                            T M 2 Replies Last reply Reply Quote 0
                                            79.9k
                                            eltako enocean enocean adapter tipp-funk
                                            38
                                            675
                                            134874
