    4. Twinkly - Basisfunktionen mit ioBroker steuern
    • patrickbs96
      patrickbs96 Developer @W0RSCHD last edited by
      @W0RSCHD Ist eingebaut 🙂 Aktiviere dafür die folgende Einstellung:
      const USE_CURL_INSTEAD = true;
      W 1 Reply Last reply Reply Quote 2
        W0RSCHD @patrickbs96 last edited by W0RSCHD
        @patrickbs96
        Danke, Authentication funktioniert, es spuckt aber noch Fehler aus,
        hier mal der Log
        10:30:07.001	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: pm6be3o9Vac= Content-Type: application/json' http://192.168.178.175/xled/v1/fw/version
        10:30:07.074	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.firmware, state={"val":"2.3.5","ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
        10:31:06.063	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: getState(id=ping.0.iobroker.192_168_178_175, timerId=undefined) => {"val":true,"ack":true,"ts":1607247061634,"q":0,"from":"system.adapter.ping.0","user":"system.user.admin","lc":1607222544951}
        10:31:06.074	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.connected, state={"val":true,"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
        10:31:06.075	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: pm6be3o9Vac= Content-Type: application/json' http://192.168.178.175/xled/v1/led/mode
        10:31:06.338	warn	javascript.0 (11366) at script.js.Schaltungen.Twinkly_JS:190:29
        10:31:06.338	warn	javascript.0 (11366) at Object.<anonymous> (script.js.Schaltungen.Twinkly_JS:188:25)
        10:31:06.338	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.mode, state={"val":{"ack":true},"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
        10:31:06.339	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.on, state={"val":true,"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
        10:31:06.340	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: pm6be3o9Vac= Content-Type: application/json' http://192.168.178.175/xled/v1/led/out/brightness
        10:31:06.627	warn	javascript.0 (11366) at script.js.Schaltungen.Twinkly_JS:196:45
        10:31:06.627	warn	javascript.0 (11366) at Object.<anonymous> (script.js.Schaltungen.Twinkly_JS:195:25)
        10:31:06.628	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.bri, state={"val":{"ack":true},"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
        10:31:06.629	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: pm6be3o9Vac= Content-Type: application/json' http://192.168.178.175/xled/v1/device_name
        10:31:06.829	warn	javascript.0 (11366) at script.js.Schaltungen.Twinkly_JS:200:44
        10:31:06.829	warn	javascript.0 (11366) at Object.<anonymous> (script.js.Schaltungen.Twinkly_JS:199:25)
        10:31:06.829	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.name, state={"val":{"ack":true},"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
        10:31:06.830	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: pm6be3o9Vac= Content-Type: application/json' http://192.168.178.175/xled/v1/mqtt/config
        10:31:06.969	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.mqtt, state={"val":"{}","ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
        10:31:06.972	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: pm6be3o9Vac= Content-Type: application/json' http://192.168.178.175/xled/v1/timer
        10:31:07.088	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.timer, state={"val":"{}","ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
        10:31:07.093	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: pm6be3o9Vac= Content-Type: application/json' http://192.168.178.175/xled/v1/gestalt
        10:31:07.232	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.details, state={"val":"{\"product_name\":\"Twinkly\",\"product_version\":\"16\",\"hardware_version\":\"7\",\"flash_size\":16,\"led_type\":6,\"led_version\":\"1\",\"product_code\":\"TW225SEUP07\",\"device_name\":\"Twinkly_BA1A63\",\"uptime\":\"3842109\",\"hw_id\":\"00ba1a63\",\"mac\":\"84:f3:eb:ba:1a:63\",\"max_supported_led\":255,\"base_leds_number\":225,\"number_of_led\":225,\"led_profile\":\"RGB\",\"frame_rate\":25,\"movie_capacity\":719,\"copyright\":\"LEDWORKS 2017\"}","ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
        10:31:07.234	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: pm6be3o9Vac= Content-Type: application/json' http://192.168.178.175/xled/v1/fw/version
        10:31:07.383	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.firmware, state={"val":"2.3.5","ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
        10:32:06.064	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: getState(id=ping.0.iobroker.192_168_178_175, timerId=undefined) => {"val":true,"ack":true,"ts":1607247122573,"q":0,"from":"system.adapter.ping.0","user":"system.user.admin","lc":1607222544951}
        10:32:06.064	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.connected, state={"val":true,"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
        10:32:06.069	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: pm6be3o9Vac= Content-Type: application/json' http://192.168.178.175/xled/v1/led/mode
        10:32:06.148	warn	javascript.0 (11366) at script.js.Schaltungen.Twinkly_JS:190:29
        10:32:06.149	warn	javascript.0 (11366) at Object.<anonymous> (script.js.Schaltungen.Twinkly_JS:188:25)
        10:32:06.149	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.mode, state={"val":{"ack":true},"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
        10:32:06.150	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.on, state={"val":true,"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
        10:32:06.151	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: pm6be3o9Vac= Content-Type: application/json' http://192.168.178.175/xled/v1/led/out/brightness
        10:32:06.241	warn	javascript.0 (11366) at script.js.Schaltungen.Twinkly_JS:196:45
        10:32:06.242	warn	javascript.0 (11366) at Object.<anonymous> (script.js.Schaltungen.Twinkly_JS:195:25)
        10:32:06.242	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.bri, state={"val":{"ack":true},"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
        10:32:06.243	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: pm6be3o9Vac= Content-Type: application/json' http://192.168.178.175/xled/v1/device_name
        10:32:06.321	warn	javascript.0 (11366) at script.js.Schaltungen.Twinkly_JS:200:44
        10:32:06.322	warn	javascript.0 (11366) at Object.<anonymous> (script.js.Schaltungen.Twinkly_JS:199:25)
        10:32:06.322	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.name, state={"val":{"ack":true},"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
        10:32:06.324	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: pm6be3o9Vac= Content-Type: application/json' http://192.168.178.175/xled/v1/mqtt/config
        10:32:06.399	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.mqtt, state={"val":"{}","ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
        10:32:06.401	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: pm6be3o9Vac= Content-Type: application/json' http://192.168.178.175/xled/v1/timer
        10:32:06.485	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.timer, state={"val":"{}","ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
        10:32:06.489	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: pm6be3o9Vac= Content-Type: application/json' http://192.168.178.175/xled/v1/gestalt
        10:32:06.555	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.details, state={"val":"{\"product_name\":\"Twinkly\",\"product_version\":\"16\",\"hardware_version\":\"7\",\"flash_size\":16,\"led_type\":6,\"led_version\":\"1\",\"product_code\":\"TW225SEUP07\",\"device_name\":\"Twinkly_BA1A63\",\"uptime\":\"3901446\",\"hw_id\":\"00ba1a63\",\"mac\":\"84:f3:eb:ba:1a:63\",\"max_supported_led\":255,\"base_leds_number\":225,\"number_of_led\":225,\"led_profile\":\"RGB\",\"frame_rate\":25,\"movie_capacity\":719,\"copyright\":\"LEDWORKS 2017\"}","ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
        10:32:06.557	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: pm6be3o9Vac= Content-Type: application/json' http://192.168.178.175/xled/v1/fw/version
        10:32:06.618	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.firmware, state={"val":"2.3.5","ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
        Schalten kann ich auch noch nichts, es scheint nur die Authentifizierung zu klappen bis jetzt.
        patrickbs96 1 Reply Last reply Reply Quote 0
        • patrickbs96
          @W0RSCHD Könntest du bitte das erweiterte Logging aktivieren und mir dann das Log schicken? Ich habe das Gefühl als werden die Inhalte anders übermittelt als bei der 2. Generation.
            @patrickbs96
            hier mal ein Auszug
            14:34:03.146	info	javascript.0 (11366) Start javascript script.js.Schaltungen.Twinkly_JS
            14:34:03.201	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setTimeout(ms=2000)
            14:34:03.202	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: onStop(timeout=500)
            14:34:03.204	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: registered 0 subscriptions and 0 schedules
            14:34:03.215	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: getObject(id=javascript.0.Weihnachtsbaum, enumName=undefined) => {"common":{"name":"Twinkly","role":"state","type":"mixed"},"native":{},"type":"channel","from":"system.adapter.javascript.0","user":"system.user.admin","ts":1607163615438,"_id":"javascript.0.Weihnachtsbaum","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
            14:34:03.216	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setObject(id=javascript.0.Weihnachtsbaum, obj={"common":{"name":"Twinkly","role":"state","type":"mixed"},"native":{},"type":"channel","from":"system.adapter.javascript.0","user":"system.user.admin","ts":1607163615438,"_id":"javascript.0.Weihnachtsbaum","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}})
            14:34:05.203	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: subscribe: {"pattern":{"id":{},"change":"ne","ack":false,"q":0},"name":"script.js.Schaltungen.Twinkly_JS"}
            14:34:05.205	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setInterval(ms=60000)
            14:35:05.206	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: getState(id=ping.0.iobroker.192_168_178_175, timerId=undefined) => {"val":true,"ack":true,"ts":1607261680414,"q":0,"from":"system.adapter.ping.0","user":"system.user.admin","lc":1607256158755}
            14:35:05.207	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.connected, state={"val":true,"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
            14:35:05.208	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly._get] <led/mode>
            14:35:05.209	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.ensure_token] Authentication token expired, will refresh
            14:35:05.212	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [httpRequest.POST] curl -d '{"challenge":"AAECAwQFBgcICQoLDA0ODxAREhMUFRYXGBkaGxwdHh8="}' -H 'Content-Type: application/json' http://192.168.178.175/xled/v1/login
            14:35:05.212	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -d '{"challenge":"AAECAwQFBgcICQoLDA0ODxAREhMUFRYXGBkaGxwdHh8="}' -H 'Content-Type: application/json' http://192.168.178.175/xled/v1/login
            14:35:05.303	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doPostRequest] body: {"authentication_token":"vZa1C4f9U6E=","authentication_token_expires_in":14400,"challenge-response":"9f0fd8de4ee5869f596dbc60f9cafeea378ff79a","code":1000}
            14:35:05.305	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly._post] <verify>, {"challenge-response":"9f0fd8de4ee5869f596dbc60f9cafeea378ff79a"}, {"X-Auth-Token":"vZa1C4f9U6E="}
            14:35:05.306	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.ensure_token] Authentication token still valid (2020-12-6 18:35:05)
            14:35:05.307	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [httpRequest.POST] curl -d '{"challenge-response":"9f0fd8de4ee5869f596dbc60f9cafeea378ff79a"}' -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/verify
            14:35:05.308	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -d '{"challenge-response":"9f0fd8de4ee5869f596dbc60f9cafeea378ff79a"}' -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/verify
            14:35:05.376	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doPostRequest] body: {"code":1102}
            14:35:05.378	warn	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.POST.verify] 1102 (Error), Data: {"challenge-response":"9f0fd8de4ee5869f596dbc60f9cafeea378ff79a"}, Headers: {"X-Auth-Token":"vZa1C4f9U6E=","Content-Type":"application/json"}, Body: {"code":1102}
            14:35:05.380	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [httpRequest.GET] curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/led/mode
            14:35:05.380	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/led/mode
            14:35:05.480	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doGetRequest] body: "Invalid Token."
            14:35:05.485	warn	javascript.0 (11366) at script.js.Schaltungen.Twinkly_JS:190:29
            14:35:05.485	warn	javascript.0 (11366) at Object.<anonymous> (script.js.Schaltungen.Twinkly_JS:188:25)
            14:35:05.485	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.mode, state={"val":{"ack":true},"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
            14:35:05.486	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.on, state={"val":true,"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
            14:35:05.487	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly._get] <led/out/brightness>
            14:35:05.488	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.ensure_token] Authentication token still valid (2020-12-6 18:35:05)
            14:35:05.488	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [httpRequest.GET] curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/led/out/brightness
            14:35:05.489	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/led/out/brightness
            14:35:05.549	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doGetRequest] body: "Invalid Token."
            14:35:05.552	warn	javascript.0 (11366) at script.js.Schaltungen.Twinkly_JS:196:45
            14:35:05.553	warn	javascript.0 (11366) at Object.<anonymous> (script.js.Schaltungen.Twinkly_JS:195:25)
            14:35:05.553	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.bri, state={"val":{"ack":true},"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
            14:35:05.555	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly._get] <device_name>
            14:35:05.557	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.ensure_token] Authentication token still valid (2020-12-6 18:35:05)
            14:35:05.557	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [httpRequest.GET] curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/device_name
            14:35:05.557	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/device_name
            14:35:05.621	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doGetRequest] body: "Invalid Token."
            14:35:05.625	warn	javascript.0 (11366) at script.js.Schaltungen.Twinkly_JS:200:44
            14:35:05.626	warn	javascript.0 (11366) at Object.<anonymous> (script.js.Schaltungen.Twinkly_JS:199:25)
            14:35:05.626	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.name, state={"val":{"ack":true},"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
            14:35:05.627	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly._get] <mqtt/config>
            14:35:05.628	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.ensure_token] Authentication token still valid (2020-12-6 18:35:05)
            14:35:05.628	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [httpRequest.GET] curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/mqtt/config
            14:35:05.629	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/mqtt/config
            14:35:05.702	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doGetRequest] body: "Invalid Token."
            14:35:05.703	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.mqtt, state={"val":"{}","ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
            14:35:05.705	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly._get] <timer>
            14:35:05.705	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.ensure_token] Authentication token still valid (2020-12-6 18:35:05)
            14:35:05.706	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [httpRequest.GET] curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/timer
            14:35:05.706	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/timer
            14:35:05.774	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doGetRequest] body: "Invalid Token."
            14:35:05.776	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.timer, state={"val":"{}","ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
            14:35:05.777	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly._get] <gestalt>
            14:35:05.778	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.ensure_token] Authentication token still valid (2020-12-6 18:35:05)
            14:35:05.779	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [httpRequest.GET] curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/gestalt
            14:35:05.779	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/gestalt
            14:35:05.854	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doGetRequest] body: {"product_name":"Twinkly","product_version":"16","hardware_version":"7","flash_size":16,"led_type":6,"led_version":"1","product_code":"TW225SEUP07","device_name":"Twinkly_BA1A63","uptime":"1274275","rssi":-78,"hw_id":"00ba1a63","mac":"84:f3:eb:ba:1a:63","uuid":"7F272E77-662E-4E6C-A8A0-D50DCA470F74","max_supported_led":255,"base_leds_number":225,"number_of_led":225,"led_profile":"RGB","frame_rate":25,"movie_capacity":719,"copyright":"LEDWORKS 2017","code":1000}
            14:35:05.857	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.details, state={"val":"{\"product_name\":\"Twinkly\",\"product_version\":\"16\",\"hardware_version\":\"7\",\"flash_size\":16,\"led_type\":6,\"led_version\":\"1\",\"product_code\":\"TW225SEUP07\",\"device_name\":\"Twinkly_BA1A63\",\"uptime\":\"1274275\",\"hw_id\":\"00ba1a63\",\"mac\":\"84:f3:eb:ba:1a:63\",\"max_supported_led\":255,\"base_leds_number\":225,\"number_of_led\":225,\"led_profile\":\"RGB\",\"frame_rate\":25,\"movie_capacity\":719,\"copyright\":\"LEDWORKS 2017\"}","ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
            14:35:05.859	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly._get] <fw/version>
            14:35:05.860	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.ensure_token] Authentication token still valid (2020-12-6 18:35:05)
            14:35:05.860	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [httpRequest.GET] curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/fw/version
            14:35:05.861	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/fw/version
            14:35:05.919	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doGetRequest] body: {"version":"2.3.5","code":1000}
            14:35:05.920	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.firmware, state={"val":"2.3.5","ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
            • patrickbs96
              @W0RSCHD Versuche es bitte erneut. Da war noch ein Fehler in der curl Anfrage bei der Übergabe des Tokens...
                @patrickbs96 jetzt klappts juhuuu TOP, Danke 🙂
                Es kommt nur dieser Error dauernd im Log, aber an sich gehts
                javascript.0	2020-12-06 21:52:15.249	error	(11366) script.js.Schaltungen.Twinkly_JS: [Weihnachtsbaum.timer] [Twinkly.GET.timer] undefined (undefined), Headers: {"X-Auth-Token":"Knavqszdq6s=","Content-Type":"application/json"}
                • patrickbs96
                  patrickbs96 Developer @W0RSCHD last edited by patrickbs96
                  @W0RSCHD Super, das freut mich zu hören 🙂
                  Anscheinend wird der Twinkly-Code nicht immer übergeben, dadurch steht dort undefined. Ich habe den Fall ausgeschlossen und der sollte daher keine Fehler mehr produzieren.
                  Da es mit curl mit beiden Generationen funktioniert, habe ich die Verarbeitung für beide gleichgezogen. Dadurch entfällt dann auch die Einstellung für curl. Könntest du das eventuell auch einmal testen @siggi85 ?
                  EDIT: Noch nicht testen, bei mir kommen aktuell noch Fehler.
                  EDIT 2: Bei mir kamen plötzlich "Invalid Token" Meldung und hatten Probleme verursacht. Ich habe es hoffentlich behoben (Es kamen leider keine mehr mit denen ich das testen konnte.)
                  siggi85 W 2 Replies Last reply Reply Quote 2
                  • siggi85
                    siggi85 @patrickbs96 last edited by
                    @patrickbs96 Auch die neue Version des Skriptes funktioniert bei mir. Ich benutze weiterhin die Version ohne curl, aber hatte mit dem aktuellen Skript keine Probleme.
                    Ich habe übrigens den Link zu deinem Skript im ersten Beitrag ergänzt.
                      @patrickbs96 klappt nun auch hier ohne Error, Dankeschön! thumbsup
                      siggi85 1 Reply Last reply Reply Quote 0
                      • siggi85
                        siggi85 @W0RSCHD last edited by
                        @W0RSCHD Super!
                        @patrickbs96 Good job! 👍
                        • flipjiz
                          flipjiz last edited by
                          Moin! Vorweg: Danke für eure Arbeit 😄
                          Muss ich die Datei runterladen und irgendwo hinschieben oder einfach über die ioBroker Oberfläche ein neues Skript mit dem Inhalt hinzufügen?
                          Ich hab es einfach mal unter Common reingeworfen aber dort gibt es diese Fehler beim Starten:
                          2020-12-08 16:49:59.946 - info: javascript.0 (22601) Start javascript script.js.common.twinkly
                          2020-12-08 16:49:59.960 - error: javascript.0 (22601) script.js.common.twinkly compile failed:
                          at script.js.common.twinkly:221
                          2020-12-08 16:49:59.961 - error: javascript.0 (22601) }, POLLING_IN_SEK * 1_000);
                          2020-12-08 16:49:59.962 - error: javascript.0 (22601) ^
                          2020-12-08 16:49:59.963 - error: javascript.0 (22601) SyntaxError: Invalid or unexpected token
                          2020-12-08 16:49:59.964 - error: javascript.0 (22601) at new Script (vm.js:83:7)
                          2020-12-08 16:49:59.964 - error: javascript.0 (22601) at Object.createScript (vm.js:277:10)
                          2020-12-08 16:49:59.965 - error: javascript.0 (22601) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
                          2020-12-08 16:49:59.966 - error: javascript.0 (22601) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
                          2020-12-08 16:49:59.967 - error: javascript.0 (22601) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17)
                          2020-12-08 16:49:59.967 - error: javascript.0 (22601) at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17)
                          2020-12-08 16:49:59.968 - error: javascript.0 (22601) at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:616:17)
                          2020-12-08 16:49:59.969 - error: javascript.0 (22601) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                          2020-12-08 16:49:59.969 - error: javascript.0 (22601) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                          2020-12-08 16:49:59.970 - error: javascript.0 (22601) at process._tickCallback (internal/process/next_tick.js:68:7)
                          • patrickbs96
                            patrickbs96 Developer @flipjiz last edited by patrickbs96
                            @flipjiz Genau richtig, neues Skript unter Common erstellen und den Inhalt hineinkopieren. Danach musst du nur den Abschnitt mit den devices anpassen, so wie es in dem Beispiel im Skript oder auf der GitHub Seite gezeigt wird.
                            const devices = {
                                Twinkly1 : {                                         // State-Name in ioBroker
                                    name           : 'Twinkly Lichterkette 1',       // Name für ioBroker (Falls nicht hinterlegt wird der State-Name verwendet)
                                    ipAdresse      : '192.168.178.52',               // IP-Adresse von der Twinkly-Lichterkette
                                    connectedState : 'ping.0.Twinkly_Lichterkette_1' // State mit true/false der den aktuellen Status der Lichterkette überwacht (bspw. ping, tr-064)
                                Twinkly2 : {                                         // State-Name in ioBroker
                                    name           : 'Twinkly Lichterkette 2',       // Name für ioBroker (Falls nicht hinterlegt wird der State-Name verwendet)
                                    ipAdresse      : '192.168.178.53',               // IP-Adresse von der Twinkly-Lichterkette
                                    connectedState : 'ping.0.Twinkly_Lichterkette_2' // State mit true/false der den aktuellen Status der Lichterkette überwacht (bspw. ping, tr-064)
                            Ich vermute mal, dass dort ein Fehler bei den devices ist. Könntest du mir den Abschnitt einmal zeigen?
                            flipjiz 1 Reply Last reply Reply Quote 1
                            • flipjiz
                              flipjiz @patrickbs96 last edited by
                              @patrickbs96
                               * Settings
                              const PATH_ID          = 'javascript.0.MyDevices.Twinkly.'; // Pfad für die Datenpunkte
                              const POLLING_IN_SEK   = 60;                                // Wie oft sollen die Daten abgefragt werden
                              const EXTENDED_LOGGING = true;                             // Mehr Informationen loggen
                              const devices = {
                                  Twinkly : {                                   // State-Name in ioBroker
                                      name           : 'Twinkly',               // Name für ioBroker (Falls nicht hinterlegt wird der State-Name verwendet)
                                      ipAdresse      : '192.168.25.168',               // IP-Adresse von der Twinkly-Lichterkette
                                      connectedState : 'ping.0.Twinkly' // State mit true/false der den aktuellen Status der Lichterkette überwacht (bspw. ping, tr-064)
                              • patrickbs96
                                @flipjiz Das sieht soweit richtig aus. Kannst du mir das gesamte Skript einmal schicken?
                                • flipjiz
                                  @patrickbs96
                                  Ich habe im Skript einfach die Unterstriche in Zeile 221 und 222 entfernt:
                                              }, 2_000);
                                  zu
                                                  }, POLLING_IN_SEK * 1000);
                                              }, 2000);
                                  nun läuft es!
                                  patrickbs96 1 Reply Last reply Reply Quote 2
                                  • patrickbs96
                                    @flipjiz Komisch hätte nicht gedacht, dass das Fehler verursacht. Dann werde ich das mal im Skript korrigieren 🙂
                                    • patrickbs96
                                      patrickbs96 Developer @siggi85 last edited by
                                      @siggi85 @W0RSCHD Ich habe den Adapter soweit fertiggestellt. Mir fehlen zwar noch die Übersetzungen aber vom technischen her ist der fertig. Würde mich freuen, wenn ihr den testen würdet 🙂
                                        MCU @patrickbs96 last edited by MCU
                                        @patrickbs96 Wie muss man den Adapter einstellen, bekomme keinen Connect. Obwohl die Instanz auf grün ist.
                                        Beim Speichern bekomme ich immer:
                                        Bin angemeldet als User. v2.12.9(build 5611) als App von gestern.
                                        • patrickbs96
                                          patrickbs96 Developer @MCU last edited by
                                          @MCU Sorry, da war ich wohl etwas zu voreilig mit der Veröffentlichung... Ist mein erster Adapter gewesen, da hatte ich bei der Menge an Aufgaben für die Veröffentlichung das wohl vergessen... Ich habe die Anleitung angepasst.
                                          Ändert trotzdem nichts an deinem Fehler, es ist soweit alles richtig konfiguriert. Könntest du dir die neue Version holen, den Adapter dann auf Debug stellen und mir das Log schicken? Dann kann ich zumindest prüfen, weshalb der nicht startet.
                                          @apollon77 Die Fehlermeldung beim Speichern bekomme ich komischerweise jetzt auch (raspberry pi). Unter Windows habe ich keine Fehler erhalten. Komischerweise kriege ich die Fehlermeldung auch, wenn ich die Einstellungen direkt am Datenpunkt system.adapter.twinkly.0 ändere. Hast du eine Idee woran das liegen kann?
                                          apollon77 patrickbs96 M 3 Replies Last reply Reply Quote 0
                                            apollon77 @patrickbs96 last edited by
                                            @patrickbs96 welchen Fehler? Den oben mit dem invalid token? Dann checke mal das skript, dann ist da ein Fehler drin
                                            9163
