    3. Entwicklung
    4. ZigBee neue Version 1.4.0
      exv2 last edited by
      Ich hoffe das mir einer helfen kann.
      Ich bekomme meine installierte Version 1.1.0 nicht auf Version 1.4.0 upgedatet.
      Bei der Installation kommt folgene Meldung
      $ ./iobroker upgrade zigbee
      Update zigbee from @1.1.0 to @1.4.0
      host.server Adapter "system.adapter.zigbee.0" is stopped.
      NPM version: 6.14.4
      npm install iobroker.zigbee@1.4.0 --loglevel error (System call)
      gyp
       ERR! find Python gyp ERR! find Python Python is not set from command line or npm configurationgyp ERR! find Python Python is not set from environment variable PYTHONgyp ERR! find Python checking if "python" can be usedgyp ERR! find Python - "python" is not in PATH or produced an errorgyp ERR! find Python checking if "python2" can be usedgyp ERR! find Python - "python2" is not in PATH or produced an errorgyp ERR! find Python checking if "python3" can be usedgyp ERR! find Python - "python3" is not in PATH or produced an errorgyp ERR! find Python checking if the py launcher can be used to find Python 2gyp ERR! find Python - "py.exe" is not in PATH or produced an errorgyp ERR! find Python checking if Python is C:\Python27\python.exegyp ERR! find Python - "C:\Python27\python.exe" could not be rungyp ERR! find Python checking if Python is C:\Python37\python.exegyp ERR! find Python - "C:\Python37\python.exe" could not be rungyp ERR! find Python gyp ERR! find Python **********************************************************gyp ERR! find Python You need to install the latest version of Python.gyp ERR! find Python Node-gyp should be able to find and use Python. If not,gyp ERR! find Python you can try one of the following options:gyp ERR! find Python - Use the switch --python="C:\Path\To\python.exe"gyp ERR! find Python   (accepted by both node-gyp and npm)gyp ERR! find Python - Set the environment variable PYTHONgyp ERR! find Python - Set the npm configuration variable python:gyp ERR! find Python   npm config set python "C:\Path\To\python.exe"gyp ERR! find Python For more information consult the documentation at:gyp ERR! find Python https://github.com/nodejs/node-gyp#installationgyp ERR! find Python **********************************************************gyp ERR! find Python gyp ERR! configure error gyp ERR! stack Error: Could not find any Python installation to usegyp ERR! stack     at PythonFinder.fail (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:307:47)gyp ERR! stack     at PythonFinder.runChecks (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:136:21)gyp ERR! stack     at PythonFinder.<anonymous> (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:225:16)gyp ERR! stack     at PythonFinder.execFileCallback (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:271:16)gyp ERR! stack     at exithandler (child_process.js:310:5)gyp ERR! stack     at ChildProcess.errorhandler (child_process.js:322:5)gyp ERR! stack     at ChildProcess.emit (events.js:310:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:273:12)gyp ERR! stack     at onErrorNT (internal/child_process.js:469:16)gyp ERR! stack     at processTicksAndRejections (internal/process/task_queues.js:84:21)gyp ERR! System Windows_NT 10.0.14393gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"gyp ERR! cwd C:\ioBroker\node_modules\@serialport\bindingsgyp ERR! node -v v12.16.2gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
      npm
      ERR!
      code ELIFECYCLEnpm ERR! errno 1npm ERR! @serialport/bindings@9.0.3 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`npm ERR!
       Exit status 1npm ERR! npm ERR! Failed at the @serialport/bindings@9.0.3 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR! A complete log of this run can be found in:npm ERR!     C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_logs\2020-12-07T15_55_37_322Z-debug.log
      ERROR: host.server Cannot install iobroker.zigbee@1.4.0: 1
      ERROR: process exited with code 25
      ioBroker läuft bauf einen Windows Server.
      Python ist in der Version 3.9 installiert.
      Vielen Dank schon mal für eure Hilfe.
      • Asgothian
        Asgothian Developer @exv2 last edited by
        @exv2 Bitte dafür einen neuen Thread aufmachen. Das ist nicht zigbee-adapter spezifisch, sondern es scheint das in deiner node/iobroker installation etwas nicht passt.
        A.
          hoktar last edited by hoktar
          Ich glaube die RGB-Lampe vom Lidl wird nicht richtig unterstützt. Ich kann sie zwar anlernen, aber außer An/Aus und die RGB Farben kann ich nichts machen. Habe sie heute auch schon umgetauscht , aber auch mit der neuen keine Veränderung. Eigentlich sollte sie doch auch in Weiß leuchten und die Farbtemperatur einstellen können. Dimmen kann ich gar nicht genau sagen ob das funktioniert oder nicht.
          MfG Bastian
          RGB zigbee lampe.JPG RGB zigbee lampe restart.JPG RGB zigbee lampe Lidl.JPG RGB zigbee lampe Geräteinfo.JPG RGB zigbee lampe Bild.JPG
          I S 2 Replies Last reply Reply Quote 0
          • JackDaniel
            JackDaniel @Asgothian last edited by
            Node JS Version - v12.20.0
            ioBroker.Zigbee Version -1.4.0
            HW des Koordinators - dieser hier
            das kommt beim löschversuch
            zigbee.0	2020-12-07 18:07:21.101	debug	(541206) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
            zigbee.0	2020-12-07 18:07:21.100	debug	(541206) getMap result: {"lqis":[{"parent":"0x00124b001940be55","networkAddress":2054,"ieeeAddr":"0x000d6ffffe63cff3","lqi":71,"relationship":1,"depth":1,"status":"online"},{"parent":"0x00124b001940be
            zigbee.0	2020-12-07 18:07:21.099	debug	(541206) Get map succeeded [{"parent":"0x00124b001940be55","networkAddress":2054,"ieeeAddr":"0x000d6ffffe63cff3","lqi":71,"relationship":1,"depth":1,"status":"online"},{"parent":"0x00124b001940be55","
            zigbee.0	2020-12-07 18:07:21.098	debug	(541206) Routing table succeeded for '0x000d6ffffe2fd9f5'
            zigbee.0	2020-12-07 18:07:21.098	debug	(541206) Routing for '0x000d6ffffe2fd9f5': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":61554,"status":"ACTIVE","nextHop":47570},{"destinationAddress":27862,"status":"ACTIVE","
            zigbee.0	2020-12-07 18:07:21.022	debug	(541206) LQI succeeded for '0x000d6ffffe2fd9f5'
            zigbee.0	2020-12-07 18:07:20.956	debug	(541206) Routing table succeeded for '0xd0cf5efffeea9a16'
            zigbee.0	2020-12-07 18:07:20.955	debug	(541206) Routing for '0xd0cf5efffeea9a16': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":13418,"status":"ACTIVE","nextHop":13418},{"destinationAddress":52810,"status":"ACTIVE","
            zigbee.0	2020-12-07 18:07:20.874	debug	(541206) LQI succeeded for '0xd0cf5efffeea9a16'
            zigbee.0	2020-12-07 18:07:20.653	debug	(541206) Routing table succeeded for '0x000d6ffffebe5831'
            zigbee.0	2020-12-07 18:07:20.652	debug	(541206) Routing for '0x000d6ffffebe5831': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":0,"status":"INACTIVE","nextHop":0},{"destinationAddress":25033,"status":"ACTIVE","nextHo
            zigbee.0	2020-12-07 18:07:20.627	debug	(541206) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
            zigbee.0	2020-12-07 18:07:20.627	debug	(541206) getBinding result: [{"bind_source":"zigbee.0.086bd7fffe5f8d3f","bind_source_ep":"1","bind_target":"1","unbind_from_coordinator":false,"id":"bind_086bd7fffe5f8d3f_1_1_undefined"}]
            zigbee.0	2020-12-07 18:07:20.591	debug	(541206) LQI succeeded for '0x000d6ffffebe5831'
            zigbee.0	2020-12-07 18:07:20.514	debug	(541206) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
            zigbee.0	2020-12-07 18:07:20.513	debug	(541206) getDevices result: [{"type":"device","common":{"name":"Rollo Kinderzimmer","type":"E1757","icon":"img/Ikea_fyrtur.png"},"native":{"id":"000d6ffffe2de624"},"from":"system.adapter.zigbee.0","us
            zigbee.0	2020-12-07 18:07:20.454	debug	(541206) sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
            zigbee.0	2020-12-07 18:07:20.453	debug	(541206) List of ports: [{"comName":"/dev/ttyACM1"},{"comName":"/dev/ttyACM0"},{"comName":"/dev/ttyUSB0"},{"comName":"/dev/ttyS1"},{"comName":"/dev/ttyS10"},{"comName":"/dev/ttyS11"},{"comName":"/dev/
            zigbee.0	2020-12-07 18:07:20.429	debug	(541206) sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
            zigbee.0	2020-12-07 18:07:20.429	debug	(541206) getGroups result: {}
            zigbee.0	2020-12-07 18:07:20.402	debug	(541206) Routing table succeeded for 'Coordinator'
            zigbee.0	2020-12-07 18:07:20.402	debug	(541206) Routing for 'Coordinator': {"table":[{"destinationAddress":61554,"status":"ACTIVE","nextHop":13418},{"destinationAddress":45744,"status":"ACTIVE","nextHop":13418},{"destinationAddress":52810,
            zigbee.0	2020-12-07 18:07:20.399	debug	(541206) LQI succeeded for 'Coordinator'
            zigbee.0	2020-12-07 18:07:20.365	debug	(541206) sendTo "getLibData" to system.adapter.admin.0 from system.adapter.zigbee.0
            zigbee.0	2020-12-07 18:07:20.364	debug	(541206) sendTo "getCoordinatorInfo" to system.adapter.admin.0 from system.adapter.zigbee.0
            zigbee.0	2020-12-07 18:07:20.332	debug	(541206) getCoorinatorInfo result: {"installSource":"iobroker.zigbee@1.4.0","channel":"26","port":"/dev/ttyACM0","type":"zStack30x","revision":20200211,"version":"2.2.7.2"}
            chromecast.0	2020-12-07 18:07:17.218	info	(120990) TV_Wohnzimmer - not enabled
            chromecast.0	2020-12-07 18:07:17.170	info	(120990) TV_Wohnzimmer - not enabled
            zigbee.0	2020-12-07 18:07:15.430	debug	(541206) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
            zigbee.0	2020-12-07 18:07:15.430	debug	(541206) getBinding result: [{"bind_source":"zigbee.0.086bd7fffe5f8d3f","bind_source_ep":"1","bind_target":"1","unbind_from_coordinator":false,"id":"bind_086bd7fffe5f8d3f_1_1_undefined"}]
            zigbee.0	2020-12-07 18:07:15.371	debug	(541206) sendTo "delBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
            zigbee.0	2020-12-07 18:07:15.370	error	at async /opt/iobroker/node_modules/iobroker.zigbee/lib/binding.js:255:21
            zigbee.0	2020-12-07 18:07:15.370	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
            zigbee.0	2020-12-07 18:07:15.370	error	at Binding.doBindUnbind (/opt/iobroker/node_modules/iobroker.zigbee/lib/binding.js:102:111)
            zigbee.0	2020-12-07 18:07:15.370	error	at Binding.getBindEp (/opt/iobroker/node_modules/iobroker.zigbee/lib/binding.js:89:28)
            zigbee.0	2020-12-07 18:07:15.370	error	(541206) Failed to doBindUnbind TypeError: Cannot read property 'split' of undefined
            zigbee.0	2020-12-07 18:07:15.369	debug	(541206) source: {"type":"device","device":{"ID":5,"_type":"EndDevice","_ieeeAddr":"0x086bd7fffe5f8d3f","_networkAddress":2137,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"deviceID":
            zigbee.0	2020-12-07 18:07:15.367	debug	(541206) found state: {"val":"{\"bind_source\":\"zigbee.0.086bd7fffe5f8d3f\",\"bind_source_ep\":\"1\",\"bind_target\":\"1\",\"unbind_from_coordinator\":false}","ack":true,"ts":1600584776907,"q":0,"fr
            zigbee.0	2020-12-07 18:07:15.365	debug	(541206) delBinding message: "bind_086bd7fffe5f8d3f_1_1_undefined"
            chromecast.0	2020-12-07 18:07:10.877	info	(120990) TV_Wohnzimmer - not enabled
            chromecast.0	2020-12-07 18:07:10.744	info	(120990) TV_Wohnzimmer - not enabled
            zigbee.0	2020-12-07 18:07:08.706	debug	(541206) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
            zigbee.0	2020-12-07 18:07:08.706	debug	(541206) getMap result: {"lqis":[{"parent":"0x00124b001940be55","networkAddress":2054,"ieeeAddr":"0x000d6ffffe63cff3","lqi":71,"relationship":1,"depth":1,"status":"online"},{"parent":"0x00124b001940b
            zigbee.0	2020-12-07 18:07:08.706	debug	(541206) Get map succeeded [{"parent":"0x00124b001940be55","networkAddress":2054,"ieeeAddr":"0x000d6ffffe63cff3","lqi":71,"relationship":1,"depth":1,"status":"online"},{"parent":"0x00124b001940be55",
            zigbee.0	2020-12-07 18:07:08.705	debug	(541206) Routing table succeeded for '0x000d6ffffe2fd9f5'
            zigbee.0	2020-12-07 18:07:08.705	debug	(541206) Routing for '0x000d6ffffe2fd9f5': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":61554,"status":"ACTIVE","nextHop":47570},{"destinationAddress":27862,"status":"ACTIVE",
            zigbee.0	2020-12-07 18:07:08.642	debug	(541206) LQI succeeded for '0x000d6ffffe2fd9f5'
            zigbee.0	2020-12-07 18:07:08.578	debug	(541206) Routing table succeeded for '0xd0cf5efffeea9a16'
            zigbee.0	2020-12-07 18:07:08.577	debug	(541206) Routing for '0xd0cf5efffeea9a16': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":13418,"status":"ACTIVE","nextHop":13418},{"destinationAddress":52810,"status":"ACTIVE",
            zigbee.0	2020-12-07 18:07:08.494	debug	(541206) LQI succeeded for '0xd0cf5efffeea9a16'
            zigbee.0	2020-12-07 18:07:08.260	debug	(541206) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
            zigbee.0	2020-12-07 18:07:08.259	debug	(541206) getBinding result: [{"bind_source":"zigbee.0.086bd7fffe5f8d3f","bind_source_ep":"1","bind_target":"1","unbind_from_coordinator":false,"id":"bind_086bd7fffe5f8d3f_1_1_undefined"}]
            zigbee.0	2020-12-07 18:07:08.224	debug	(541206) Routing table succeeded for '0x000d6ffffebe5831'
            zigbee.0	2020-12-07 18:07:08.223	debug	(541206) Routing for '0x000d6ffffebe5831': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":0,"status":"INACTIVE","nextHop":0},{"destinationAddress":25033,"status":"ACTIVE","nextH
            zigbee.0	2020-12-07 18:07:08.162	debug	(541206) LQI succeeded for '0x000d6ffffebe5831'
            zigbee.0	2020-12-07 18:07:08.045	debug	(541206) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
            und das wenn ich die bindung ändern will
            zigbee.0	2020-12-07 18:09:02.654	debug	(541206) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
            zigbee.0	2020-12-07 18:09:02.653	debug	(541206) getMap result: {"lqis":[{"parent":"0x00124b001940be55","networkAddress":2054,"ieeeAddr":"0x000d6ffffe63cff3","lqi":71,"relationship":1,"depth":1,"status":"online"},{"parent":"0x00124b001940be
            zigbee.0	2020-12-07 18:09:02.652	debug	(541206) Get map succeeded [{"parent":"0x00124b001940be55","networkAddress":2054,"ieeeAddr":"0x000d6ffffe63cff3","lqi":71,"relationship":1,"depth":1,"status":"online"},{"parent":"0x00124b001940be55","
            zigbee.0	2020-12-07 18:09:02.651	debug	(541206) Routing table succeeded for '0x000d6ffffe2fd9f5'
            zigbee.0	2020-12-07 18:09:02.650	debug	(541206) Routing for '0x000d6ffffe2fd9f5': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":61554,"status":"ACTIVE","nextHop":47570},{"destinationAddress":27862,"status":"ACTIVE","
            zigbee.0	2020-12-07 18:09:02.581	debug	(541206) LQI succeeded for '0x000d6ffffe2fd9f5'
            zigbee.0	2020-12-07 18:09:02.517	debug	(541206) Routing table succeeded for '0xd0cf5efffeea9a16'
            zigbee.0	2020-12-07 18:09:02.516	debug	(541206) Routing for '0xd0cf5efffeea9a16': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":13418,"status":"ACTIVE","nextHop":13418},{"destinationAddress":52810,"status":"ACTIVE","
            zigbee.0	2020-12-07 18:09:02.437	debug	(541206) LQI succeeded for '0xd0cf5efffeea9a16'
            zigbee.0	2020-12-07 18:09:02.221	debug	(541206) Routing table succeeded for '0x000d6ffffebe5831'
            zigbee.0	2020-12-07 18:09:02.220	debug	(541206) Routing for '0x000d6ffffebe5831': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":0,"status":"INACTIVE","nextHop":0},{"destinationAddress":25033,"status":"ACTIVE","nextHo
            zigbee.0	2020-12-07 18:09:02.179	debug	(541206) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
            zigbee.0	2020-12-07 18:09:02.179	debug	(541206) getBinding result: [{"bind_source":"zigbee.0.086bd7fffe5f8d3f","bind_source_ep":"1","bind_target":"1","unbind_from_coordinator":false,"id":"bind_086bd7fffe5f8d3f_1_1_undefined"}]
            zigbee.0	2020-12-07 18:09:02.160	debug	(541206) LQI succeeded for '0x000d6ffffebe5831'
            zigbee.0	2020-12-07 18:09:02.051	debug	(541206) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
            zigbee.0	2020-12-07 18:09:02.050	debug	(541206) getDevices result: [{"type":"device","common":{"name":"Rollo Kinderzimmer","type":"E1757","icon":"img/Ikea_fyrtur.png"},"native":{"id":"000d6ffffe2de624"},"from":"system.adapter.zigbee.0","us
            zigbee.0	2020-12-07 18:09:02.027	debug	(541206) sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
            zigbee.0	2020-12-07 18:09:02.027	debug	(541206) List of ports: [{"comName":"/dev/ttyACM1"},{"comName":"/dev/ttyACM0"},{"comName":"/dev/ttyUSB0"},{"comName":"/dev/ttyS1"},{"comName":"/dev/ttyS10"},{"comName":"/dev/ttyS11"},{"comName":"/dev/
            zigbee.0	2020-12-07 18:09:01.972	debug	(541206) Routing table succeeded for 'Coordinator'
            zigbee.0	2020-12-07 18:09:01.972	debug	(541206) Routing for 'Coordinator': {"table":[{"destinationAddress":61554,"status":"ACTIVE","nextHop":13418},{"destinationAddress":45744,"status":"ACTIVE","nextHop":13418},{"destinationAddress":52810,
            zigbee.0	2020-12-07 18:09:01.969	debug	(541206) LQI succeeded for 'Coordinator'
            zigbee.0	2020-12-07 18:09:01.957	debug	(541206) sendTo "getLibData" to system.adapter.admin.0 from system.adapter.zigbee.0
            zigbee.0	2020-12-07 18:09:01.956	debug	(541206) sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
            zigbee.0	2020-12-07 18:09:01.956	debug	(541206) getGroups result: {}
            zigbee.0	2020-12-07 18:09:01.955	debug	(541206) sendTo "getCoordinatorInfo" to system.adapter.admin.0 from system.adapter.zigbee.0
            zigbee.0	2020-12-07 18:09:01.955	debug	(541206) getCoorinatorInfo result: {"installSource":"iobroker.zigbee@1.4.0","channel":"26","port":"/dev/ttyACM0","type":"zStack30x","revision":20200211,"version":"2.2.7.2"}
            mystrom-wifi-switch.1	2020-12-07 18:09:01.480	info	(533412) result from http://192.168.1.64:{"power":15.14,"Ws":15.25,"relay":true,"temperature":21.31}
            mystrom-wifi-switch.0	2020-12-07 18:08:59.750	info	(533396) result from http://192.168.1.61:{"power":0,"Ws":1.75,"relay":true,"temperature":4.68}
            chromecast.0	2020-12-07 18:08:59.629	info	(120990) TV_Wohnzimmer - not enabled
            chromecast.0	2020-12-07 18:08:59.628	info	(120990) TV_Wohnzimmer - not enabled
            chromecast.0	2020-12-07 18:08:59.617	info	(120990) TV_Wohnzimmer - not enabled
            chromecast.0	2020-12-07 18:08:59.606	info	(120990) TV_Wohnzimmer - not enabled
            chromecast.0	2020-12-07 18:08:59.603	info	(120990) TV_Wohnzimmer - not enabled
            chromecast.0	2020-12-07 18:08:59.332	info	(120990) TV_Wohnzimmer - not enabled
            chromecast.0	2020-12-07 18:08:59.331	info	(120990) TV_Wohnzimmer - not enabled
            chromecast.0	2020-12-07 18:08:59.330	info	(120990) TV_Wohnzimmer - not enabled
            chromecast.0	2020-12-07 18:08:59.302	info	(120990) TV_Wohnzimmer - not enabled
            chromecast.0	2020-12-07 18:08:59.298	info	(120990) TV_Wohnzimmer - not enabled
            zigbee.0	2020-12-07 18:08:58.876	debug	(541206) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
            zigbee.0	2020-12-07 18:08:58.875	debug	(541206) getBinding result: [{"bind_source":"zigbee.0.086bd7fffe5f8d3f","bind_source_ep":"1","bind_target":"1","unbind_from_coordinator":false,"id":"bind_086bd7fffe5f8d3f_1_1_undefined"}]
            zigbee.0	2020-12-07 18:08:58.826	debug	(541206) sendTo "editBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
            zigbee.0	2020-12-07 18:08:58.825	error	at async /opt/iobroker/node_modules/iobroker.zigbee/lib/binding.js:255:21
            zigbee.0	2020-12-07 18:08:58.825	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
            zigbee.0	2020-12-07 18:08:58.825	error	at runMicrotasks (<anonymous>)
            zigbee.0	2020-12-07 18:08:58.825	error	at Binding.doBindUnbind (/opt/iobroker/node_modules/iobroker.zigbee/lib/binding.js:102:111)
            zigbee.0	2020-12-07 18:08:58.825	error	at Binding.getBindEp (/opt/iobroker/node_modules/iobroker.zigbee/lib/binding.js:89:28)
            zigbee.0	2020-12-07 18:08:58.825	error	(541206) Failed to doBindUnbind TypeError: Cannot read property 'split' of undefined
            zigbee.0	2020-12-07 18:08:58.823	debug	(541206) source: {"type":"device","device":{"ID":5,"_type":"EndDevice","_ieeeAddr":"0x086bd7fffe5f8d3f","_networkAddress":2137,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"deviceID":
            zigbee.0	2020-12-07 18:08:58.821	debug	(541206) found state: {"val":"{\"bind_source\":\"zigbee.0.086bd7fffe5f8d3f\",\"bind_source_ep\":\"1\",\"bind_target\":\"1\",\"unbind_from_coordinator\":false}","ack":true,"ts":1600584776907,"q":0,"fr
            zigbee.0	2020-12-07 18:08:58.819	debug	(541206) delBinding message: "bind_086bd7fffe5f8d3f_1_1_undefined"
            zigbee.0	2020-12-07 18:08:58.818	debug	(541206) editBinding message: {"id":"bind_086bd7fffe5f8d3f_1_1_undefined","bind_source":"zigbee.0.086bd7fffe5f8d3f","bind_source_ep":"1","bind_target":"zigbee.0.d0cf5efffeea0fc4","bind_target_ep":"1"
            chromecast.0	2020-12-07 18:08:51.236	info	(120990) TV_Wohnzimmer - not enabled
            chromecast.0	2020-12-07 18:08:51.006	info	(120990) TV_Wohnzimmer - not enabled
            unifi.0	2020-12-07 18:08:50.171	info	(530746) Update done
            zigbee.0	2020-12-07 18:08:48.437	debug	(541206) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
            zigbee.0	2020-12-07 18:08:48.436	debug	(541206) getMap result: {"lqis":[{"parent":"0x00124b001940be55","networkAddress":2054,"ieeeAddr":"0x000d6ffffe63cff3","lqi":71,"relationship":1,"depth":1,"status":"online"},{"parent":"0x00124b001940b
            zigbee.0	2020-12-07 18:08:48.435	debug	(541206) Get map succeeded [{"parent":"0x00124b001940be55","networkAddress":2054,"ieeeAddr":"0x000d6ffffe63cff3","lqi":71,"relationship":1,"depth":1,"status":"online"},{"parent":"0x00124b001940be55",
            zigbee.0	2020-12-07 18:08:48.434	debug	(541206) Routing table succeeded for '0x000d6ffffe2fd9f5'
            zigbee.0	2020-12-07 18:08:48.433	debug	(541206) Routing for '0x000d6ffffe2fd9f5': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":61554,"status":"ACTIVE","nextHop":47570},{"destinationAddress":27862,"status":"ACTIVE",
            zigbee.0	2020-12-07 18:08:48.370	debug	(541206) LQI succeeded for '0x000d6ffffe2fd9f5'
            zigbee.0	2020-12-07 18:08:48.307	debug	(541206) Routing table succeeded for '0xd0cf5efffeea9a16'
            zigbee.0	2020-12-07 18:08:48.306	debug	(541206) Routing for '0xd0cf5efffeea9a16': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":13418,"status":"ACTIVE","nextHop":13418},{"destinationAddress":52810,"status":"ACTIVE",
            zigbee.0	2020-12-07 18:08:48.237	debug	(541206) LQI succeeded for '0xd0cf5efffeea9a16'
            zigbee.0	2020-12-07 18:08:48.052	debug	(541206) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
            zigbee.0	2020-12-07 18:08:48.051	debug	(541206) getBinding result: [{"bind_source":"zigbee.0.086bd7fffe5f8d3f","bind_source_ep":"1","bind_target":"1","unbind_from_coordinator":false,"id":"bind_086bd7fffe5f8d3f_1_1_undefined"}]
            zigbee.0	2020-12-07 18:08:48.018	debug	(541206) Routing table succeeded for '0x000d6ffffebe5831'
            zigbee.0	2020-12-07 18:08:48.017	debug	(541206) Routing for '0x000d6ffffebe5831': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":0,"status":"INACTIVE","nextHop":0},{"destinationAddress":25033,"status":"ACTIVE","nextH
            zigbee.0	2020-12-07 18:08:47.941	debug	(541206) LQI succeeded for '0x000d6ffffebe5831'
            zigbee.0	2020-12-07 18:08:47.833	debug	(541206) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
            @Asgothian sagte in ZigBee neue Version 1.4.0:
            @JackDaniel
            Ich wollte mir mal ein Bild von dem Fehler machen - irgendwie kommt da immer das raus:
            Im Ernst - ohne weitere Referenzen kann an mit der Fehlermeldung NICHTS getan werden.
            • Node JS Version
            • ioBroker.Zigbee Version
            • HW des Koordinators
            • Kachel des Koordinators im ioBroker.Zigbee (sofern iobroker.Zigbee Version1.4.0)
            • betroffene Geräte (Beschreibung, Kachel, welche DP's hast du versucht zu "binden"
            • ggf. auftretende debug Meldungen beim "bind"
            • ggf. auftretende debug Meldungen beim "unbind"
              (Ja, fuer die beiden letzten Punkte ist es notwendig den Adapter im Debug zu starten und das ganze noch einmal zu probieren)
            Ansonsten: Logs in code Tags, damit es so aussieht - dann kann man das nicht nur lesen sondern sogar auch verstehen:
            at Binding.getBindEp (/opt/iobroker/node_modules/iobroker.zigbee/lib/binding.js:89:28) at Binding.doBindUnbind (/opt/iobroker/node_modules/iobroker.zigbee/lib/binding.js:102:111)
            at runMicrotasks () at processTicksAndRejections (internal/process/task_queues.js:97:5)
            A.
            Asgothian JackDaniel 2 Replies Last reply Reply Quote 0
            • I
              io_laurent @hoktar last edited by
              @hoktar für weißes Licht mal beim Datenpunkt Color den Wert "FFFFFF" eingeben (=RGB-Wert für weiß). Dimmen über Brightness Datenpunkt eingeben, Wert 0-100. Beim Datenpunkt Colortemp musst du mal ausprobieren, glaube Werte zwischen 250-650, aber wie gesagt, mußt du selbst mal tüfteln. Das sollte eigentlich funktionieren...
                hoktar @io_laurent last edited by hoktar
                @io_laurent Genau das Habe ich ja versucht. bei #ffffff mischt er nur aus den RGB-Leds weiß zusammen. Ich bekomme aber egal was ich einstelle nicht die weißen LEDs an. Nach dem anlernen haben aber ganz klar die Weißen geleuchtet, also sind auch welche verbaut.
                Habe ja noch welche ohne RGB, bei denen funktioniert es super. Farbtemperatur, dimmen und An/Aus.
                mfg
                edit: auch #000000 und #000000ff gehen nicht darauf reagiert die Lampe gar nicht.
                I L 2 Replies Last reply Reply Quote 0
                • I
                  @hoktar Sorry, dann hab ich keine Ahnung, müssen die Profis ran:) dachte, dir fehlen die richtigen Werte, weil im Screenshot keine eingetragen waren.
                  • Asgothian
                    Asgothian Developer @JackDaniel last edited by
                    @JackDaniel ok, damit kann ich da morgen nachschauen.
                    A.
                    JackDaniel 1 Reply Last reply Reply Quote 0
                    • Asgothian
                      Asgothian Developer @io_laurent last edited by
                      @io_laurent sind sie schon. Die Lampen sind
                      • noch neu
                      • Tuya inside, also hochgradig nicht Standard.
                      Wenn ich das richtig verstand en habe sollte im zigbee2mqtt bereits ein PR zu dem Problem existieren.
                      A.
                      • JackDaniel
                        @Asgothian
                        danke im voraus 👍
                          Frank579 @Asgothian last edited by
                          @Asgothian
                          Danke für die tolle Arbeit 👍👍👍
                          Hallo ich nutze den Adapter mit einem conbee II (ich weiß ist noch experimentell ) ich habe das Problem das ein Ikea Taster, über den Ikea Router , zwar funktioniert aber sei dem er über den Router läuft den Batterie Zustand nicht mehr aktualisiert.. ist da etwas bekannt ?
                            arteck Developer Most Active @Frank579 last edited by
                            @Frank579 welcher Router ??
                              Frank579 @arteck last edited by
                              @arteck
                              @arteck sagte in ZigBee neue Version 1.4.0:
                              der Ikea Tradfri repeater, sorry hätte ich erwähnen sollen ....
                                el_malto @arteck last edited by
                                Sehr cooles Update und Neuerungen. Vielen Dank dafür.
                                die Möglichkeit den Stick über TCP anzusprechen
                                mit dem Programmen ser2net oder usbip kann man den Stick auslagern .. es ist kein Multihost mehr nötig.
                                meine empfehlung ser2net. einfacher einzurichten und man braucht es nur auf dem Rechner wo der Stick dran hängt. ich habe es seid ca.4 Monaten am laufen am Rock64 LAN angebunden.
                                mit WLAN geht es auch, währe ich aber vorsichtig.. wenn das WLAN Signal weg ist merkt es der Adapter nicht
                                Hat das schon jemand mit einen Windows Rechner probiert bzw. erfolgreich eingebunden?
                                Ich habe auf meinen Server Windows Server 2016 drauf und ioBroker läuft in einer Hyper-V VM mit Debian 10 Buster. Meinen CC2531 habe ich mit "VirtualHere" zur VM durchgereicht. Das funktioniert auch ohne Probleme. Ich muss nur die Clienten Software auf der VM nach neustart immer per Hand starten (geht mit der Free Version nicht automatisch). Mit der Free Version kann man ein USB Gerät durchreichen, was mir auch reicht, da ich nur den CC2531 durchreichen will.
                                Habe in der Doku von VirtualHere gelesen das der Port :7575 genutzt wird. Wenn ich IP:Port im Adapter eintrage, kann der Adapter leider keine Verbindung zum Stick herstellen. Auf dem Server kommen folgende Fehlermeldungen im Log von VirtualHere:
                                2020-12-07 21:31:40 INFO :192.168.0.108 connected as connection 3
                                2020-12-07 21:31:47 ERROR :Error received message is too big (comp=553713391, uncomp=16654337)
                                2020-12-07 21:31:50 INFO :Connection 3 successfully removed (reason:timeout)
                                2020-12-07 21:32:03 INFO :192.168.0.108 connected as connection 4
                                2020-12-07 21:32:10 ERROR :Error received message is too big (comp=553713391, uncomp=16654337)
                                2020-12-07 21:32:14 INFO :Connection 4 successfully removed (reason:timeout)
                                usw...
                                Irgendwelche Anfragen kommen wohl beim Server an.
                                Hat das schon jemand ans laufen bekommen oder kann eine andere kostenlose Software für Windows empfehlen die mit dem Adapter kompatible ist? Würde gern nur eine Server Software (Windows) laufen lassen müssen und nicht noch eine auf dem Clienten (VM) wenn der Adapter das nun unterstützt.
                                  leon @hoktar last edited by
                                  @hoktar
                                  Genau das gleiche Problem habe ich bei der Lidl Strip. Asgothian ist da wohl schon dran.
                                  • Slowman
                                    Slowman last edited by
                                    Bekomme zur Zeit bei den Stick folgende Fehlermeldung:
                                    zigbee.0	2020-12-08 11:15:24.843	error	at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:24:58)
                                    zigbee.0	2020-12-08 11:15:24.843	error	at Generator.next (<anonymous>)
                                    zigbee.0	2020-12-08 11:15:24.843	error	at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:339:27)
                                    zigbee.0	2020-12-08 11:15:24.843	error	(7768) Error on send command to 0x7cb03eaa0a0082cd. Error: Error: Command 0x7cb03eaa0a0082cd/3 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultRespons
                                    host.iobroker	2020-12-08 11:15:15.646	info	instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
                                    Kann damit gar nichts anfangen
                                    • Asgothian
                                      Asgothian Developer @Slowman last edited by
                                      @Slowman
                                      Die Meldung Ist abgehackt. Das wichtige (das Ende) fehlt. Bitte das log herunter laden, die zeile(n) finden, dann neu posten.
                                      A.
                                      M Slowman 2 Replies Last reply Reply Quote 0
                                        Mr.X @Asgothian last edited by
                                        ich war jetzt ein halbes Jahr glücklich, weil der Zigbee Kram endlich mal lief.
                                        Dann habe ich jetzt upgedatet, um den Lidl Kram zu integrieren, und nun ist der Adappter wieder ständig offline 😞
                                        Würde mich über eine Hilfestellung freuen.
                                        Folgendes steht im Log:
                                        <zigbee.0 2020-12-08 16:49:01.564 error at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/@serialport/stream/lib/index.js:242:12
                                        zigbee.0 2020-12-08 16:49:01.564 error at SerialPort._error (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/@serialport/stream/lib/index.js:198:14)
                                        zigbee.0 2020-12-08 16:49:01.564 error at SerialPort.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
                                        zigbee.0 2020-12-08 16:49:01.564 error at __awaiter (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
                                        zigbee.0 2020-12-08 16:49:01.564 error at new Promise (<anonymous>)
                                        zigbee.0 2020-12-08 16:49:01.564 error at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
                                        zigbee.0 2020-12-08 16:49:01.564 error at Generator.next (<anonymous>)
                                        zigbee.0 2020-12-08 16:49:01.564 error at Znp.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
                                        zigbee.0 2020-12-08 16:49:01.564 error (12100) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
                                        zigbee.0 2020-12-08 16:49:01.563 error (12100) Failed to start Zigbee
                                        zigbee.0 2020-12-08 16:48:56.338 info (12100) Installed Version: iobroker.zigbee@1.4.0
                                        zigbee.0 2020-12-08 16:48:56.323 info (12100) Starting Zigbee npm ...
                                        zigbee.0 2020-12-08 16:48:56.321 info (12100) Try to reconnect. 1 attempts left>
                                          Thomas Braun Most Active @Mr.X last edited by
                                          @Mr-X sagte in ZigBee neue Version 1.4.0:
                                          Da scheint noch was anderes auf den Port zuzugreifen.
                                          Adapter wurde wie installiert? Aus dem Verwahrort oder aus git?
                                          Node Installation korrekt?
                                          Und bitte Text auch in CodeTags einbetten, das liest sich dann besser.
                                            Mr.X @Thomas Braun last edited by
                                            @Thomas-Braun Sorry, habe das eigentlich in die <> Coder-Klammer gesetzt.
                                            Also ich habe von 1.3 (oder so) auf latest 1.4 update gemacht, davor lief alles sauber.
                                            am Rpi 4 stecken keine anderen USB devices, nur der CC2531.
                                            Denke, dass mit Node alles OK ist, wenn es davor Monate lang ohne probs lief.
                                            alpha git neu zigbee
                                            62
                                            393
                                            94048
