    4. JavaScript
    5. Suche anwesensheits skript
      denjo @Thomas Braun last edited by
      @Thomas-Braun sagte in Suche anwesensheits skript:
      which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
      Linux raspberrypi 5.4.72-v7l+ #1356 SMP Thu Oct 22 13:57:51 BST 2020 armv7l
      The programs included with the Debian GNU/Linux system are free software;
      the exact distribution terms for each program are described in the
      individual files in /usr/share/doc/*/copyright.
      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
      permitted by applicable law.
      Last login: Tue Dec  8 12:25:29 2020 from 192.168.178.121
      pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
      /usr/bin/nodejs
      v12.20.0
      /usr/bin/node
      v12.20.0
      /usr/bin/npm
      6.14.8
      nodejs:
        Installiert:           12.20.0-1nodesource1
        Installationskandidat: 12.20.0-1nodesource1
        Versionstabelle:
       *** 12.20.0-1nodesource1 500
              500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
              100 /var/lib/dpkg/status
           10.21.0~dfsg-1~deb10u1+rpi1 500
      pi@raspberrypi:~ $
        Thomas Braun Most Active @denjo last edited by
        @denjo
        Gut, das passt.
        apt policy build-essential
          @Thomas-Braun
          pi@raspberrypi:~ $ apt policy build-essential
          build-essential:
            Installiert:           12.6
            Installationskandidat: 12.6
            Versionstabelle:
           *** 12.6 500
          pi@raspberrypi:~ $
            @denjo
            apt policy libpam0g-dev
              @Thomas-Braun
              pi@raspberrypi:~ $ apt policy libpam0g-dev
              libpam0g-dev:
                Installiert:           1.3.1-5+rpt2
                Installationskandidat: 1.3.1-5+rpt2
                Versionstabelle:
               *** 1.3.1-5+rpt2 500
                      500 http://archive.raspberrypi.org/debian buster/main armhf Packages
                   1.3.1-5 500
              pi@raspberrypi:~ $
                @denjo
                Das passt soweit. Ich würde den Adapter allerdings nicht aus git ziehen, sondern aus dem Verwahrort 'default/stable'
                  @Thomas-Braun also ganz normal über adapter meinst du???
                    @denjo Ja, ganz normal aus der Liste der Adapter.
                    latest:	4.2.1 for 24 days
                    stable:	4.2.1 for 24 days
                    D 4 Replies Last reply Reply Quote 0
                      @Thomas-Braun mache ich gerade
                      am anfang habe ich imer ein error stehen ist das normal
                      $ ./iobroker add tr-064  --host raspberrypi
                      NPM version: 6.14.8
                      npm install iobroker.tr-064@4.2.1 --loglevel error --prefix "/opt/iobroker" (System call)
                        @Thomas-Braun so adapter ist wieder da und die objekte trotzdem dauert das leider ewigkeiten bis er erkennt das jemand false ist
                          @Thomas-Braun und jetzt war ich ca für 1 sekunde falso dann wieder true sofort wobei ich nix geändert habe. echt komisch alles
                            Jan1 @denjo last edited by Jan1
                            @denjo sagte in Suche anwesensheits skript:
                            Das Loglevel ist auf error gestellt, also nur ne Info für Dich wie der geloggt wird, mehr ist das nicht 😉
                            Was läuft denn für ne FW auf der Fritz? Da gabs mal eine, die nervig bei der WLAN Geschichte war.
                              denjo @Jan1 last edited by
                              @Jan1 7.21 und ich bin immer noch true wobei ich seit 10 min kein wlan an habe.
                              und in der fritzbox steht das
                                @denjo
                                Ich bin gerade nicht zu Hause, aber in den Einstellungen des TR-064 gibts eine Option, die die Erkennung anders realisiert. Hast die angehakt?
                                7.21 ist doch ne Labor oder? Wenn schon Labor, dann wäre 7.24 aktuell.
                                Falls es mit dem TR-064 nicht klappt, versuchs mal mit dem Radar2, der macht das etwas anders und bei der Erkennung etwas schneller.
                                  @Jan1 nur das kann man einstellen
                                    @denjo
                                    Ja und bei MDNS fehlt der Haken.
                                    Schau doch mal was da dabei steht 😉
                                      @Jan1 keine veränderung und bei radar dauert es auch ewig, und nein 7.21 ist die aktuellste FW der fritz
                                      Albert K 1 Reply Last reply Reply Quote 0
                                        @Thomas-Braun so also ich habe es jetzt mal beobachtet in der fritzbox. wenn ich offline gehe dann steht zwar das ich nicht mehr verbunden bin aber ich gehe erst viel später in untere offline liste
                                          @denjo
                                          Ja, das meinte ich ja mit der längeren Verzögerung.
                                          • Albert K
                                            Albert K @denjo last edited by
                                            @denjo
                                            hast denn jetzt mal einen ping auf die fritzbox gemacht? Nur um auszuschließen dass du keine Netzwerk Latenz hast?
                                            9512
