    4. JavaScript
    5. Suche anwesensheits skript
      denjo @Albert K last edited by
      @Albert-K
      pi@raspberrypi:~ $ ping fritz.box
      PING fritz.box (192.168.178.1) 56(84) bytes of data.
      64 bytes from fritz.box (192.168.178.1): icmp_seq=1 ttl=64 time=0.499 ms
      64 bytes from fritz.box (192.168.178.1): icmp_seq=2 ttl=64 time=0.468 ms
      64 bytes from fritz.box (192.168.178.1): icmp_seq=3 ttl=64 time=0.558 ms
      64 bytes from fritz.box (192.168.178.1): icmp_seq=4 ttl=64 time=0.513 ms
      64 bytes from fritz.box (192.168.178.1): icmp_seq=5 ttl=64 time=0.432 ms
      64 bytes from fritz.box (192.168.178.1): icmp_seq=6 ttl=64 time=0.486 ms
      64 bytes from fritz.box (192.168.178.1): icmp_seq=7 ttl=64 time=0.521 ms
      64 bytes from fritz.box (192.168.178.1): icmp_seq=8 ttl=64 time=0.479 ms
      64 bytes from fritz.box (192.168.178.1): icmp_seq=9 ttl=64 time=0.486 ms
      64 bytes from fritz.box (192.168.178.1): icmp_seq=10 ttl=64 time=0.510 ms
      64 bytes from fritz.box (192.168.178.1): icmp_seq=11 ttl=64 time=0.515 ms
      64 bytes from fritz.box (192.168.178.1): icmp_seq=12 ttl=64 time=0.587 ms
      64 bytes from fritz.box (192.168.178.1): icmp_seq=13 ttl=64 time=1.64 ms
      ^C
      --- fritz.box ping statistics ---
      13 packets transmitted, 13 received, 0% packet loss, time 492ms
      rtt min/avg/max/mdev = 0.432/0.591/1.640/0.306 ms
      Albert K 1 Reply Last reply Reply Quote 0
      • Albert K
        Albert K @denjo last edited by
        @denjo
        Lass es mal länger laufen, so etwa eine Minute
          @Albert-K
          64 bytes from fritz.box (192.168.178.1): icmp_seq=1 ttl=64 time=0.476 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=2 ttl=64 time=0.602 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=3 ttl=64 time=0.530 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=4 ttl=64 time=0.571 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=5 ttl=64 time=0.588 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=6 ttl=64 time=0.591 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=7 ttl=64 time=0.421 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=8 ttl=64 time=0.553 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=9 ttl=64 time=0.616 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=10 ttl=64 time=0.425 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=11 ttl=64 time=0.440 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=12 ttl=64 time=0.568 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=13 ttl=64 time=0.509 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=14 ttl=64 time=0.448 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=15 ttl=64 time=0.555 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=16 ttl=64 time=0.597 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=17 ttl=64 time=0.576 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=18 ttl=64 time=0.558 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=19 ttl=64 time=0.573 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=20 ttl=64 time=0.541 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=21 ttl=64 time=0.587 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=22 ttl=64 time=0.354 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=23 ttl=64 time=0.622 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=24 ttl=64 time=0.556 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=25 ttl=64 time=1.30 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=26 ttl=64 time=0.546 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=27 ttl=64 time=0.576 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=28 ttl=64 time=0.565 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=29 ttl=64 time=0.539 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=30 ttl=64 time=0.474 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=31 ttl=64 time=0.600 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=32 ttl=64 time=0.579 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=33 ttl=64 time=0.438 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=34 ttl=64 time=0.615 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=35 ttl=64 time=0.557 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=36 ttl=64 time=0.633 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=37 ttl=64 time=0.604 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=38 ttl=64 time=0.616 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=39 ttl=64 time=0.549 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=40 ttl=64 time=0.724 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=41 ttl=64 time=0.419 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=42 ttl=64 time=0.624 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=43 ttl=64 time=0.604 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=44 ttl=64 time=0.550 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=45 ttl=64 time=0.714 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=46 ttl=64 time=0.543 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=47 ttl=64 time=0.647 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=48 ttl=64 time=0.721 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=49 ttl=64 time=0.540 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=50 ttl=64 time=0.635 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=51 ttl=64 time=0.508 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=52 ttl=64 time=0.602 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=53 ttl=64 time=0.643 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=54 ttl=64 time=0.530 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=55 ttl=64 time=0.510 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=56 ttl=64 time=0.390 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=57 ttl=64 time=1.20 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=58 ttl=64 time=0.610 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=59 ttl=64 time=0.580 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=60 ttl=64 time=0.633 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=61 ttl=64 time=0.629 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=62 ttl=64 time=0.627 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=63 ttl=64 time=0.711 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=64 ttl=64 time=0.616 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=65 ttl=64 time=0.533 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=66 ttl=64 time=0.633 ms
          64 bytes from fritz.box (192.168.178.1): icmp_seq=67 ttl=64 time=0.608 ms
          ^C
          67 packets transmitted, 67 received, 0% packet loss, time 708ms
          rtt min/avg/max/mdev = 0.354/0.587/1.303/0.139 ms
          pi@raspberrypi:~ $
          • Albert K
            @denjo
            sieht ok aus.
            Und der Poll Intervall im TR064 Adapter ist auf wieviel Sekunden gestellt?
              @Albert-K 10 sekunden, kann es sein das meine fritzbox überlastet ist mit den ganzen wlan geräten. habe durch iobroker usw in den letzten jahren halt echt viele.
              habe gerade 34 geräte online und fritzbox 7580
                @Albert-K oder der raspi 4 zu wenig ram 2GB ???
                • Albert K
                  @denjo
                  Glaube ich nicht. Ich habe etwa 70 Smart Home Geräte und noch fast keine Probleme.
                  Wo allerdings ein von AVM bestätigtes Problem besteht ist die Auslastung bei bestimmten Anzeigen. ZB die Auflistung aller Netzwerk Geräte, speziell wenn viele davon dhcp nutzen. Dort sollte öfter mal ganz unten nach der Liste der Button "Entfernen" geklickt werden.
                  Meine 7490 war dadurch so lahm dass sie gar nicht mehr reagiert hat. Das hatte dann auch Auswirkungen auf meinen iobroker.
                    @Albert-K okay werde es heut abend mal weiter probieren. Danke erst mal
                    • Albert K
                      @denjo
                      Es gibt eine nette App für android "RasPi Check". Damit kannst Du die Auslastung sehen und SSH Befehle absetzen.
                      Ich habe einen Raspi 4/4GB, etwa 30 Adapter. CPU Auslastung etwa30 bis 40%, RAM unter 50%. Mit einem 2GB Raspi könnte es also u.U schon knapp werden.
                      • Negalein
                        @denjo
                        die 7.21 ist zT der größte Verhau.
                        Bei meiner 7580 hab ich die selben Probleme wie du.
                        Ich steig auf Unifi um, da funktionierts wunderbar.
                        D Albert K 3 Replies Last reply Reply Quote 0
                          denjo @Negalein last edited by
                          @Negalein hab mir jetzt ein 8gb bestellt und was ist unifi
                            Thomas Braun Most Active @denjo last edited by
                            @denjo Da klemmt es eher nicht auf dem Pi, sondern auf der Fritte.
                            Also deswegen hättest du keinen neuen Pi bestellen müssen.
                            • Albert K
                              Albert K @Negalein last edited by Albert K
                              @Negalein
                              Unifi ist schon nice. Vor allem wenn USG/USwitch/APs und Cloud Key vorhanden. Aber glaube nicht dass es da keine Probleme gibt 🙂
                              Da habe ich schon Nächte durchgeschwitzt 😰 (kommerzielles Umfeld) Brauchst auf jeden Fall gute Englisch Kenntnisse 🙂
                              Meine Fritzbox 7490 läuft nach mehrmaliger Säuberungs Aktion nun aber wieder spürbar besser.
                                @Negalein kurze frage ich kenne mich damit aber nicht so aus wie ihr:
                                kann der Adapter nicht angepasst werden das er merk wie in den einem bild von mir wenn das gerät keine verbindung mehr hat?
                                  Homoran Global Moderator Administrators @denjo last edited by
                                  @denjo Wenn die Fritzbox es erst nach 10 Minuten als offline meldet, kann der Adapter es vorher auch nicht wissen
                                    Jan1 last edited by Jan1
                                    TR-064 4 Sekunden vom deaktivieren des Handy WLAN bis zur false Meldung im Adapter. Also bei Euch stimmt was nicht. Auf true wars dann nach 3 Sekunden beim Aktivieren.
                                    Ich habe die 7590 mit BETA 7.24
                                    D Negalein Albert K 3 Replies Last reply Reply Quote 0
                                      denjo @Homoran last edited by
                                      @Homoran also wenn ich keine verindung mehr habe sieht das so aus wie im bild.
                                        denjo @Jan1 last edited by
                                        @Jan1 es soll wohl an der FW der Fritz liegen und true geht bei mir auch mega schnell aber false dauert manchmal 5-10 min
                                        • Negalein
                                          Negalein Global Moderator @Jan1 last edited by
                                          @Jan1 sagte in Suche anwesensheits skript:
                                          Ich denke eher bei AVM.
                                          Die schaffen es nicht eine FW stabil auf allen für die FW angebotenen Geräte zu bringen.
                                            @Negalein ja das stimmt auch
                                            9564
