    4. [Neuer Adapter] EuSec
      MaTr75 @bropat last edited by
      @bropat
      Das habe ich im log stehen... Username und Passwort habe ich rausgelöscht. Hilft Dir das weiter?
      2020-12-05 15:43:14.037 - debug: eufy-security.0 (32132) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2020-12-05 15:43:14.096 - debug: eufy-security.0 (32132) Objects client ready ... initialize now
      2020-12-05 15:43:14.114 - debug: eufy-security.0 (32132) Objects create System PubSub Client
      2020-12-05 15:43:14.116 - debug: eufy-security.0 (32132) Objects create User PubSub Client
      2020-12-05 15:43:14.118 - debug: eufy-security.0 (32132) Objects client initialize lua scripts
      2020-12-05 15:43:14.156 - debug: eufy-security.0 (32132) Objects connected to redis: 127.0.0.1:9001
      2020-12-05 15:43:14.166 - debug: eufy-security.0 (32132) objectDB connected
      2020-12-05 15:43:14.170 - debug: eufy-security.0 (32132) Redis States: Use Redis connection: 127.0.0.1:9000
      2020-12-05 15:43:14.186 - debug: eufy-security.0 (32132) States create User PubSub Client
      2020-12-05 15:43:14.191 - debug: eufy-security.0 (32132) States create System PubSub Client
      2020-12-05 15:43:14.212 - debug: eufy-security.0 (32132) States connected to redis: 127.0.0.1:9000
      2020-12-05 15:43:14.214 - debug: eufy-security.0 (32132) statesDB connected
      2020-12-05 15:43:14.818 - info: eufy-security.0 (32132) starting. Version 0.0.4 in /opt/iobroker/node_modules/iobroker.eufy-security, node: v12.16.3
      2020-12-05 15:43:16.707 - debug: eufy-security.0 (32132) onReady(): Load previous login_hash: b1d8daf1964266c6c96f9a60cf6d54df
      2020-12-05 15:43:16.716 - debug: eufy-security.0 (32132) API.authenticate(): token: null token_expiration: null
      2020-12-05 15:43:16.720 - debug: eufy-security.0 (32132) API.request(): method: post endpoint: passport/login baseUrl: https://mysecurity.eufylife.com/api/v1 token: null data: {"email":"xUSERNAMEx","password":"xPASSWORDx"} headers: {"app_version":"v2.2.2_741","os_type":"android","os_version":"29","phone_model":"ONEPLUS A3003","country":"DE","language":"de","openudid":"805b7994cf631c97","uid":"","net_type":"wifi","mnc":"02","mcc":"262","sn":"b72f6c61dcbf","Model_type":"PHONE","timezone":"GMT+01:00"}
      2020-12-05 15:43:18.368 - debug: eufy-security.0 (32132) API.authenticate(): Response: {"code":100023,"msg":"Anfrage fehlgeschlagen."}
      2020-12-05 15:43:18.369 - error: eufy-security.0 (32132) API.authenticate(): Response code not ok (code: 100023 msg: Anfrage fehlgeschlagen.)
      2020-12-05 15:43:18.370 - error: eufy-security.0 (32132) EufySecurity.logon(): token error
      2020-12-05 15:43:20.168 - debug: eufy-security.0 (32132) system.adapter.admin.0: logging true
        @bropat Eine Idee: Kann es an bestimmten Sonderzeichen im Passort liegen?
          bropat @MaTr75 last edited by
          @MaTr75 said in [Neuer Adapter] Eufy-Security:
          @MaTr75 Das könnte sein. Hast du ein besonderes Sonderzeichen im Passwort? z.B. "
            @bropat ich hatte , und ( drin und habe nun eine neues PW erstellt mit einem !
            ändert leider nichts...
            • Marcel Meissel
              Marcel Meissel @bropat last edited by
              @bropat Vielen Dank für den Adapter!!! Ich habe die Battery Doorbell und 3 2K Indoor Kameras und versuche mich gerade an der Integration in ioBroker.
              In der Visualisierung habe ich ein Image mit der Quelle "eufy-security.0.T8010P23202717EF.cameras.T8210P0020271D23.last_camera_url". Das Image wird beim ersten laden auch bis zur Aktualisierung angezeigt, ist dann aber weg.
              Wie kann ich das lösen, daß immer das letzte Bild bleibt? Hat jemand einen Tip? Von der Doorbell gibt es ja leider keinen Stream.
              J B 2 Replies Last reply Reply Quote 0
                @bropat Jetzt läuft es bei mir. Es werden meine beiden Kameras angezeigt (Indoor Cam Pan&Tilt und die Wired Doorbell).
                Bei der Wired Doorbell würde ich gerne wissen, ob ich das Klingelsignal abfangen kann und darauf eine Automation aufsetzen kann. Geht das Irgendwie?
                  jens1987 @Marcel Meissel last edited by
                  @Marcel-Meissel Man muss dann einen Blockly schreiben der wenn der Datenpunkt aktualisiert wird, ein neuer Datenpunkt geschrieben wird mit der aktuellen URL. So war es bei dem Ring Adapter auch. Ich weiß aber leider auch nicht mehr wie genau einen Datenpunkt erzeugt.
                    jens1987 last edited by
                    Guten Morgen zusammen, danke für den tollen Adapter. Werde den jetzt auch mal testen. Habe schon lange drauf gewartet. Danke
                      bropat @tofriedrich last edited by
                      @tofriedrich Dieses Problem wurde mit der Version 0.0.7 behoben (#11).
                        @MaTr75 Wie hast du es schlussendlich gelöst?
                        Ja das geht so wie schon von jens1987 beschrieben 🙂
                          Stormbringer @bropat last edited by
                          @bropat Erst mal vielen Dank für den tollen Adapter, läuft Bombe.
                          Deswegen wollte ich jetzt auch allmählich meine Cams umstellen aber stehe jetzt vor dem selben Problem mit VIS einbinden.
                          Nach ewigen Kampf habe ich es jetzt geschafft den Stream in Motioneye einzubinden. Der läuft aber nur bei Bewegung kurz ab. Das anstoßen übern Adapter bringt da leider nichts. Die Cam ist in der Garage und sollte beim Tür öffnen eigentlich kurz den Status vom Garagentor anzeigen. Was mit einer strombetriebenen RTSP Cam super geklappt hat. Den RTMP Stream, den man mit dem Adapter anstoßen kann, geht nicht in VIS... einen RTSP Link wird Adaptertechnisch nicht gehen oder?
                          @MaTr75 wie hast du das gelöst? M
                          B M 2 Replies Last reply Reply Quote 0
                            bropat @Stormbringer last edited by bropat
                            @Stormbringer Vielen Dank für das Feedback 🙂
                            Beim Reverse Engineering des Eufy-P2P-Protokolls habe ich gesehen, dass es die Möglichkeit gibt den Livestream direkt von der Station in MP4 zu holen. Hier muss ich aber noch einige Zeit investieren um konkret etwas umsetzen zu können.
                            Im Moment war es am einfachsten über der HTTP-Schnittstelle den RTMP-Steam zu aktivieren/deaktivieren. 😉
                            Ein RTSP-Stream wird von Eufy nicht unterstützt.
                            Ein Feature, das ich im Adapter implementieren möchte, ist die Möglichkeit, den Livestream einfach in das VIS zu integrieren. Aber ich kann noch nicht sagen, wann das geschehen wird. Wer helfen möchte, ist herzlich willkommen :).
                              @bropat Wenns irgendwann in VIS integrierbar ist und man per Blockly einen Stream kurz aufrufen kann würde mir das reichen. Kann dir da leider nur nicht helfen, dazu reichen meine Fähigkeiten nicht. Aber wenn du sagt du bekommst das irgendwann mal auf die Reihe glaub ich dir und behalte die Cam 😉 Oder meinst sieht es schlecht aus per Blockly den Stream beim Tür öffnen abzurufen?
                              Glaubst du ist es auch möglich Bewegung per Adapter zu bekommen, wenn in der App Benachrichtigungen für Bewegungen ausgeschaltet sind? Würde die gerne vom Broker filtern lassen, wann ich welche bekomme. Wenn man die in der App aber ausschaltet kommt nichts mehr beim Adapter an. Denke was wird eher seitens Eufy nicht gehen oder?
                                MaTr75 @Stormbringer last edited by
                                @Stormbringer
                                mein Problem war, dass ich mich nicht einloggen konnte. Nachdem ich den Adapter mehrmals deinstalliert und installiert hatte und auch meine credentials neu eingetragen hatte, bekam ich irgendwann auch die Mail mit dem token. Seitdem bin ich zumindest mal drin und sehe meine Kameras.
                                Weiter bin ich noch nicht.
                                Ich möchte auch die Videobilder gar nicht abgreifen, sondern eher auf die Events gehen, um etwas zu automatisieren (Bewegungserkennung, Klingeln...)
                                  Stormbringer @MaTr75 last edited by
                                  @MaTr75 Danke für die Rückmeldung. Stimmt anfangs ist es ein bisschen Tricky bis er mal läuft. Aber deine Anforderungen kannst ja leicht umsetzen mit dem was der Adapter jetzt schon bietet 😉👍
                                    souhl @bropat last edited by souhl
                                    @bropat Ich habe den Adapter gerade installiert, aber er taucht bei mir gar nicht in der Adapterübersicht auf. Welche Logs helfen da?
                                    souhl@node2:/opt/iobroker$ npm i iobroker.eufy-security
                                    [sudo] password for souhl:
                                    > protobuf-typescript@6.8.8 postinstall /opt/iobroker/node_modules/protobuf-typescript
                                    > node scripts/postinstall
                                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):
                                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
                                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                    + iobroker.eufy-security@0.0.7
                                    added 21 packages from 62 contributors in 4.791s
                                    30 packages are looking for funding
                                      run `npm fund` for details
                                    souhl@node2:/opt/iobroker/node_modules/iobroker.eufy-security/build$ node main.js 0 --debug
                                    2020-12-11 19:20:27.868  - debug: eufy-security.0 (24207) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                    2020-12-11 19:20:27.881  - debug: eufy-security.0 (24207) Objects client ready ... initialize now
                                    2020-12-11 19:20:27.884  - debug: eufy-security.0 (24207) Objects create System PubSub Client
                                    2020-12-11 19:20:27.885  - debug: eufy-security.0 (24207) Objects create User PubSub Client
                                    2020-12-11 19:20:27.885  - debug: eufy-security.0 (24207) Objects client initialize lua scripts
                                    2020-12-11 19:20:27.891  - debug: eufy-security.0 (24207) Objects connected to redis: 127.0.0.1:9001
                                    2020-12-11 19:20:27.893  - debug: eufy-security.0 (24207) objectDB connected
                                    2020-12-11 19:20:27.894  - debug: eufy-security.0 (24207) Redis States: Use Redis connection: 127.0.0.1:9000
                                    2020-12-11 19:20:27.897  - debug: eufy-security.0 (24207) States create User PubSub Client
                                    2020-12-11 19:20:27.898  - debug: eufy-security.0 (24207) States create System PubSub Client
                                    2020-12-11 19:20:27.903  - debug: eufy-security.0 (24207) States connected to redis: 127.0.0.1:9000
                                    2020-12-11 19:20:27.903  - debug: eufy-security.0 (24207) statesDB connected
                                    2020-12-11 19:20:27.906  - error: eufy-security.0 (24207) eufy-security.0 invalid config
                                    2020-12-11 19:20:27.906  - warn: eufy-security.0 (24207) Terminated (INVALID_ADAPTER_CONFIG): Without reason
                                    B mfuhr 2 Replies Last reply Reply Quote 0
                                      bropat @souhl last edited by
                                      Hi @souhl, denke das Problem hat sich erübrigt laut issue auf Github. 🙂
                                        bropat @Marcel Meissel last edited by
                                        @Marcel-Meissel mit der Version 0.0.8 gibt es jetzt den State 😉
                                        • mfuhr
                                          mfuhr @souhl last edited by mfuhr
                                          @souhl
                                          Hallo, ich habe das selbe Problem das der Adapter nicht auftaucht, wie hast du das gelöst?
                                          Ich bin noch relativ neu mit dem IoBroker unterwegs, wenn´s geht eine Antwort für Anfänger 😉
                                          Danke Gruß
                                          Mario
                                            Solider @mfuhr last edited by
                                            @mfuhr
                                            Der Adapter taucht nicht auf oder die Instanz?
                                            Du hast die CustomInstall mit dem GitHub Link gemacht, richtig?
                                            Nach dem custom-install wird nämlich nicht automatisch eine Instanz erzeugt.
                                            Dazu einfach im ADAPTER reiter den "Eufy security" suchen (müsste blau sein) anklicken und unten links auf das plus klicken.
                                            Dann einfach unten rechts "Hinzufügen" und dann wird die Instanz erstellt
                                            für die 2FA muss der Code in den Objekten eingegeben werden. Da hab ich zuerst auch kurz gesucht.
                                            1.4k
                                            adapter cameras doorbell eufy eufycam security
                                            160
                                            1173
                                            451511
