    4. Test Adapter EnOcean (2) v0.3.x
    • Tobias Schnurr
      Tobias Schnurr last edited by
      Also mein FUD61NPN-230V (08/19) will leider immer noch nicht.
      Ich habe
      • die alte Instanz + Adapter gelöscht
      • ihn heute ( 08.12.2020) von der Github URL neu installiert
      • den FUD61 komplett zurückgesetzt
      • Gerät hinzufügen
      • Aktor auf LRN + Auto
        --> es kommt nichts an und die LED blinkt immer weiter
      Zuvor ein FT55 Taster lernt sich sofort ein.
      2020-12-08 19:31:17.309 - debug: enocean.0 (26528) sendTo "autodetect" to system.adapter.admin.0 from system.adapter.enocean.0
      2020-12-08 19:31:19.459 - debug: enocean.0 (26528) 55000707017af670fef4bc483000ffffffff4400
      2020-12-08 19:31:19.465 - info: enocean.0 (26528) undefined
      2020-12-08 19:31:19.465 - info: enocean.0 (26528) Create objects for F6-02-02 from Enocean GmbH with id: fef4bc48
      2020-12-08 19:31:19.494 - info: enocean.0 (26528) EEP F6-02-xx detected and added to devices
      2020-12-08 19:31:19.495 - info: enocean.0 (26528) Teach-In: RPS (F6) Telegram detected, you have to add this device manually if it wasn't added right now. The ID is "fef4bc48"
      2020-12-08 19:31:19.763 - debug: enocean.0 (26528) 55000707017af600fef4bc482000ffffffff4300
      2020-12-08 19:31:19.765 - info: enocean.0 (26528) undefined
      2020-12-08 19:31:19.766 - info: enocean.0 (26528) Create objects for F6-02-02 from Enocean GmbH with id: fef4bc48
      2020-12-08 19:31:19.773 - info: enocean.0 (26528) EEP F6-03-xx detected and added to devices
      2020-12-08 19:31:19.774 - info: enocean.0 (26528) Teach-In: RPS (F6) Telegram detected, you have to add this device manually if it wasn't added right now. The ID is "fef4bc48"
      2020-12-08 19:32:17.313 - info: enocean.0 (26528) Teachin mode de-activated
      2020-12-08 19:32:17.319 - info: enocean.0 (26528) state enocean.0.gateway.teachin deleted
      2020-12-08 19:35:30.401 - debug: enocean.0 (26528) sendTo "autodetect" to system.adapter.admin.0 from system.adapter.enocean.0
      2020-12-08 19:35:56.646 - info: enocean.0 (26528) ["/dev/ttyUSB0"]
      2020-12-08 19:35:56.647 - debug: enocean.0 (26528) sendTo "listSerial" to system.adapter.admin.0 from system.adapter.enocean.0
      2020-12-08 19:35:56.649 - debug: enocean.0 (26528) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.enocean.0
      2020-12-08 19:35:56.655 - debug: enocean.0 (26528) sendTo "getEEPList" to system.adapter.admin.0 from system.adapter.enocean.0
      2020-12-08 19:36:30.408 - info: enocean.0 (26528) Teachin mode de-activated
      2020-12-08 19:36:30.416 - info: enocean.0 (26528) state enocean.0.gateway.teachin deleted
      • Jey Cee
        Jey Cee Developer @Tobias Schnurr last edited by
        @Tobias-Schnurr hast du die Bestätigungstelegramme eingeschaltet?
        Tobias Schnurr 1 Reply Last reply Reply Quote 0
          TheAriba @mustang last edited by
          @mustang @Jey-Cee kann ich bestätigen. 2 TF61J lassen sich unabhängig voneinander steuern - bravo!!👍
          Jetzt müssen sich "nur noch" meine TF61D und TF100L einlernen lassen 🙂
          • Tobias Schnurr
            Tobias Schnurr @Jey Cee last edited by Tobias Schnurr
            @Jey-Cee
            Ja hab ich auch noch mal gemacht. Zeigt beim einlernen via oberen Drehschalter nichts zusätzliches im Log.
            Wenn ich den Adapter vom Strom nehme und wieder anschließe taucht mal kurz die ID auf - aber eingelernt wird er auch nicht. ( Aufkleber ID:5847CD3)
            enocean.0	2020-12-08 21:22:54.094	info	(26528) state enocean.0.gateway.teachin deleted
            enocean.0	2020-12-08 21:22:54.088	info	(26528) Teachin mode de-activated
            enocean.0	2020-12-08 21:22:38.358	debug	(26528) sendTo "getEEPList" to system.adapter.admin.0 from system.adapter.enocean.0
            enocean.0	2020-12-08 21:22:38.351	debug	(26528) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.enocean.0
            enocean.0	2020-12-08 21:22:38.348	debug	(26528) sendTo "listSerial" to system.adapter.admin.0 from system.adapter.enocean.0
            enocean.0	2020-12-08 21:22:38.347	info	(26528) ["/dev/ttyUSB0"]
            enocean.0	2020-12-08 20:21:59.391	debug	(26528) 55000a0701eba5020c000905847cd30000ffffffff4300
            enocean.0	2020-12-08 20:21:57.855	debug	(26528) 55000707017af67005847cd33000ffffffff4300
            enocean.0	2020-12-08 20:21:54.082	debug	(26528) sendTo "autodetect" to system.adapter.admin.0 from system.adapter.enocean.0
            enocean.0	2020-12-08 20:21:26.874	debug	(26528) sendTo "getEEPList" to system.adapter.admin.0 from system.adapter.enocean.0
            enocean.0	2020-12-08 20:21:26.869	debug	(26528) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.enocean.0
            enocean.0	2020-12-08 20:21:26.866	debug	(26528) sendTo "listSerial" to system.adapter.admin.0 from system.adapter.enocean.0
            enocean.0	2020-12-08 20:21:26.865	info	(26528) ["/dev/ttyUSB0"]
            enocean.0	2020-12-08 20:21:14.920	info	(26528) state enocean.0.gateway.teachin deleted
            enocean.0	2020-12-08 20:21:14.913	info	(26528) Teachin mode de-activated
            Und wenn ich über einen Taster schalte sehe ich die Bestätigungstelegramme auch im Debug Modus
            enocean.0	2020-12-08 19:49:47.877	debug	(26528) Message for ID 05847cd3 has been received.
            enocean.0	2020-12-08 19:49:47.874	debug	(26528) 55000a0701eba50264000905847cd30000ffffffff5000
            enocean.0	2020-12-08 19:49:41.638	debug	(26528) Message for ID 05847cd3 has been received.
            enocean.0	2020-12-08 19:49:41.635	debug	(26528) 55000707017af67005847cd33000ffffffff5300
            enocean.0	2020-12-08 19:49:41.222	debug	(26528) Message for ID fef7cb02 has been received.
            enocean.0	2020-12-08 19:49:41.219	debug	(26528) 55000707017af600fef7cb022000ffffffff3d00
            enocean.0	2020-12-08 19:49:41.014	debug	(26528) Message for ID fef7cb02 has been
              TheAriba last edited by
              By the way: Wie lernt man nun einen FTKB an? Die hatte ich in einer vorherigen Version einlernen können. Ich erinnere mich da die EEPs von Hand vergeben zu haben, hatte funktioniert.
              • Jey Cee
                @Tobias-Schnurr hast du mal denn zweiten FUD in der liste ausgewählt und es damit versucht? Wenn es dann nicht geht ist dein Aktor nicht im Anlernmodus modus.
                @EnoceanEltako sagte in Test Adapter EnOcean (2) v0.2.x:
                In dem man ihn in der Liste Auswählt.
                  TheAriba @Jey Cee last edited by
                  @Jey-Cee
                  anschließend auf Gerät hinzufügen. Dann Deckel auf und die Taste betätigen. Wird nicht erkannt. Oder mache ich wieder etwas falsch? 😄
                  • Jey Cee
                    Jey Cee Developer @TheAriba last edited by Jey Cee
                    @EnoceanEltako ich nehme an das ist richtig so. Die Infos hab ich aus der Anleitung, hab keinen da um das zu Überprüfen.
                    Edit: Kann nicht gehen da fehlt der Code fürs anlernen. Kommt morgen.
                      @Jey-Cee alles klar. Falls du ein log brauchst gib einfach Bescheid.
                      M Jey Cee 2 Replies Last reply Reply Quote 0
                        mustang @TheAriba last edited by
                        @Jey-Cee
                        Status-Update: Habe jetzt alle drei Aktoren 2x TF61J und einen TF-TA55J im Produktiveinsatz mit der Version 0.2.1. Sind alle einzeln steuerbar.
                        • Jey Cee
                          Ja bräuchte ich.
                          EDIT: Man man man, da muss man ganz schön Aufpassen. Von dem FTKB gibt es ja wieder verschiedene Varianten, die auch noch Unterschiedliche Profile haben.
                          EDIT2: Nachdem du das Log erstellt hast kannst du von Github neu installieren, da ist der FTKB-rw den du hast drin.
                            mane444 last edited by mane444
                            Hi, ich hab mal grad einen neuen FL62NP-230V getestet. Leider kommt nach dem Wechsel des cmd Objekts in Teach ein Warnmeldung im Log. Der Aktor lernt sich auch nicht an, kein Steuern möglich und keine Rückmeldung.
                            Vielleicht hilfts bei der Programmierung.
                            enocean.0	2020-12-09 18:15:51.672	warn	(5106) The data length for a RPS telegram is incorrect. The length is 0
                            enocean.0	2020-12-09 18:15:51.648	info	(5106) state 0410f374.CMD changed: 0 (ack = false) state: {"val":0,"ack":false,"ts":1607537751638,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607537751638}
                            enocean.0	2020-12-09 18:15:29.397	warn	(5106) The data length for a RPS telegram is incorrect. The length is 0
                            enocean.0	2020-12-09 18:15:29.370	info	(5106) state 0410f374.CMD changed: 2 (ack = false) state: {"val":2,"ack":false,"ts":1607537729359,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607537729359}
                            enocean.0	2020-12-09 18:15:10.618	info	(5106) 1
                            enocean.0	2020-12-09 18:15:10.593	info	(5106) 1
                            enocean.0	2020-12-09 18:15:10.580	info	(5106) Create objects for TF-14-02 from ELTAKO with id: 0410f374
                            enocean.0	2020-12-09 18:15:10.577	info	(5106) undefined
                            enocean.0	2020-12-09 18:15:10.574	info	(5106) new device
                            enocean.0	2020-12-09 18:15:10.549	info	(5106) Create objects for TF-13-11 from ELTAKO with id: 0410f374
                            enocean.0	2020-12-09 18:15:10.546	info	(5106) undefined
                            enocean.0	2020-12-09 18:15:10.538	info	(5106) new device
                              @mustang darf ich fragen wie du sie steuerst? Hast du ein Skript welches dir die Zeiten in Prozent umrechnet?
                                @Jey-Cee würde Gerät hinzufügen und dann mehrmals auslösen. Passt das?
                                • Jey Cee
                                  @EnoceanEltako ja
                                  • Jey Cee
                                    Jey Cee Developer @mane444 last edited by
                                    @mane444 Die Reihenfolge der EEPs im Objekt vom FL62NP ist fasch oder es Fehlt eine EEP. Das ist leider noch ein Bug.
                                    Die hier in dieser Reihenfolge müssen da drin sein:
                                    "TF-13-11",
                                    "TF-14-02"
                                    Das Objekt kannst du im Objekt tab mit dem Stift ganz rechts öffnen und dann Raw bearbeiten.
                                      TheAriba @Jey Cee last edited by TheAriba
                                      @Jey-Cee
                                      enocean.0	2020-12-09 20:58:22.561	info	(4317) state enocean.0.gateway.teachin deleted
                                      enocean.0	2020-12-09 20:58:22.555	info	(4317) Teachin mode de-activated
                                      enocean.0	2020-12-09 20:58:09.141	debug	(4317) 55000a0701eba5849500080584926b0100ffffffff4900
                                      enocean.0	2020-12-09 20:57:54.536	debug	(4317) 55000a0701eba586980008058492920000ffffffff4400
                                      enocean.0	2020-12-09 20:57:54.424	debug	(4317) 55000707017ad500058492920000ffffffff4300
                                      enocean.0	2020-12-09 20:57:54.120	debug	(4317) 55000a0701eba586980008058492920000ffffffff4400
                                      enocean.0	2020-12-09 20:57:53.960	debug	(4317) 55000707017ad500058492920000ffffffff4300
                                      enocean.0	2020-12-09 20:57:35.131	debug	(4317) 55000707017ad5090583fcec0000ffffffff5200
                                      enocean.0	2020-12-09 20:57:32.667	debug	(4317) 55000a0701eba583970008058492920000ffffffff4600
                                      enocean.0	2020-12-09 20:57:32.603	debug	(4317) 55000707017ad500058492920000ffffffff4400
                                      enocean.0	2020-12-09 20:57:32.444	debug	(4317) 55000a0701eba585970008058492920000ffffffff4600
                                      enocean.0	2020-12-09 20:57:32.364	debug	(4317) 55000707017ad500058492920000ffffffff4400
                                      enocean.0	2020-12-09 20:57:32.235	debug	(4317) 55000a0701eba584970008058492920000ffffffff4600
                                      enocean.0	2020-12-09 20:57:32.156	debug	(4317) 55000707017ad500058492920000ffffffff4400
                                      enocean.0	2020-12-09 20:57:32.028	debug	(4317) 55000a0701eba585970008058492920000ffffffff4600
                                      enocean.0	2020-12-09 20:57:31.932	debug	(4317) 55000707017ad500058492920000ffffffff4400
                                      enocean.0	2020-12-09 20:57:31.692	debug	(4317) 55000a0701eba585970008058492920000ffffffff4400
                                      enocean.0	2020-12-09 20:57:31.596	debug	(4317) 55000707017ad500058492920000ffffffff4400
                                      enocean.0	2020-12-09 20:57:31.452	debug	(4317) 55000a0701eba584970008058492920000ffffffff4400
                                      enocean.0	2020-12-09 20:57:31.372	debug	(4317) 55000707017ad500058492920000ffffffff4400
                                      enocean.0	2020-12-09 20:57:31.212	debug	(4317) 55000a0701eba585970008058492920000ffffffff4600
                                      enocean.0	2020-12-09 20:57:31.116	debug	(4317) 55000707017ad500058492920000ffffffff4400
                                      enocean.0	2020-12-09 20:57:30.972	debug	(4317) 55000a0701eba585970008058492920000ffffffff4400
                                      enocean.0	2020-12-09 20:57:30.876	debug	(4317) 55000707017ad500058492920000ffffffff4400
                                      enocean.0	2020-12-09 20:57:30.748	debug	(4317) 55000a0701eba585970008058492920000ffffffff4600
                                      enocean.0	2020-12-09 20:57:30.636	debug	(4317) 55000707017ad500058492920000ffffffff4400
                                      enocean.0	2020-12-09 20:57:30.476	debug	(4317) 55000a0701eba585980008058492920000ffffffff4400
                                      enocean.0	2020-12-09 20:57:30.364	debug	(4317) 55000707017ad500058492920000ffffffff4400
                                      enocean.0	2020-12-09 20:57:30.220	debug	(4317) 55000a0701eba585980008058492920000ffffffff4400
                                      enocean.0	2020-12-09 20:57:30.124	debug	(4317) 55000707017ad500058492920000ffffffff4400
                                      enocean.0	2020-12-09 20:57:30.060	debug	(4317) 55000707017ad509058492d40100ffffffff4a00
                                      enocean.0	2020-12-09 20:57:29.981	debug	(4317) 55000a0701eba583970008058492920000ffffffff4600
                                      enocean.0	2020-12-09 20:57:29.916	debug	(4317) 55000707017ad500058492920000ffffffff4400
                                      enocean.0	2020-12-09 20:57:29.740	debug	(4317) 55000a0701eba584970008058492920000ffffffff4400
                                      enocean.0	2020-12-09 20:57:29.668	debug	(4317) 55000707017ad500058492920000ffffffff4400
                                      enocean.0	2020-12-09 20:57:29.655	debug	(4317) sendTo "getEEPList" to system.adapter.admin.0 from system.adapter.enocean.0
                                      enocean.0	2020-12-09 20:57:29.651	debug	(4317) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.enocean.0
                                      enocean.0	2020-12-09 20:57:29.648	debug	(4317) sendTo "listSerial" to system.adapter.admin.0 from system.adapter.enocean.0
                                      enocean.0	2020-12-09 20:57:29.648	info	(4317) ["/dev/ttyAMA0","/dev/ttyUSB0"]
                                      enocean.0	2020-12-09 20:57:29.500	debug	(4317) 55000a0701eba585970008058492920000ffffffff4400
                                      enocean.0	2020-12-09 20:57:29.420	debug	(4317) 55000707017ad500058492920000ffffffff4400
                                      enocean.0	2020-12-09 20:57:29.244	debug	(4317) 55000a0701eba585980008058492920000ffffffff4600
                                      enocean.0	2020-12-09 20:57:29.132	debug	(4317) 55000707017ad500058492920000ffffffff4400
                                      enocean.0	2020-12-09 20:57:28.972	debug	(4317) 55000a0701eba585980008058492920000ffffffff4600
                                      enocean.0	2020-12-09 20:57:28.876	debug	(4317) 55000707017ad500058492920000ffffffff4400
                                      enocean.0	2020-12-09 19:57:28.541	debug	2
                                      enocean.0	2020-12-09 19:57:28.541	debug	(4317) 55000707017ad500058492920000ffffffff4400
                                      enocean.0	2020-12-09 19:57:28.268	debug	(4317) 55000a0701eba585980008058492920000ffffffff4600
                                      enocean.0	2020-12-09 19:57:28.140	debug	(4317) 55000707017ad500058492920000ffffffff4400
                                      enocean.0	2020-12-09 19:57:28.028	debug	(4317) 55000a0701eba585980008058492920000ffffffff4600
                                      enocean.0	2020-12-09 19:57:27.932	debug	(4317) 55000707017ad500058492920000ffffffff4400
                                      enocean.0	2020-12-09 19:57:27.772	debug	(4317) 55000a0701eba585980008058492920000ffffffff4600
                                      enocean.0	2020-12-09 19:57:27.661	debug	(4317) 55000707017ad500058492920000ffffffff4600
                                      enocean.0	2020-12-09 19:57:27.549	debug	(4317) 55000a0701eba586980008058492920000ffffffff4600
                                      enocean.0	2020-12-09 19:57:27.420	debug	(4317) 55000707017ad500058492920000ffffffff4400
                                      enocean.0	2020-12-09 19:57:27.324	debug	(4317) 55000707017ad5090582de300000ffffffff4a00
                                      enocean.0	2020-12-09 19:57:27.276	debug	(4317) 55000a0701eba586980008058492920000ffffffff4600
                                      enocean.0	2020-12-09 19:57:27.148	debug	(4317) 55000707017ad500058492920000ffffffff4400
                                      enocean.0	2020-12-09 19:57:26.988	debug	(4317) 55000a0701eba586980008058492920000ffffffff4600
                                      enocean.0	2020-12-09 19:57:26.924	debug	(4317) 55000a0701eba583960008058492d40100ffffffff4700
                                      enocean.0	2020-12-09 19:57:26.860	debug	(4317) 55000707017ad500058492920000ffffffff4400
                                      enocean.0	2020-12-09 19:57:26.732	debug	(4317) 55000a0701eba585980008058492920000ffffffff4600
                                      enocean.0	2020-12-09 19:57:26.621	debug	(4317) 55000707017ad500058492920000ffffffff4400
                                      enocean.0	2020-12-09 19:57:26.461	debug	(4317) 55000a0701eba586980008058492920000ffffffff4600
                                      enocean.0	2020-12-09 19:57:26.332	debug	(4317) 55000707017ad500058492920000ffffffff4400
                                      enocean.0	2020-12-09 19:57:26.204	debug	(4317) 55000a0701eba586980008058492920000ffffffff4600
                                      enocean.0	2020-12-09 19:57:26.092	debug	(4317) 55000707017ad500058492920000ffffffff4400
                                      enocean.0	2020-12-09 19:57:25.965	debug	(4317) 55000a0701eba586980008058492920000ffffffff4600
                                      enocean.0	2020-12-09 19:57:25.837	debug	(4317) 55000707017ad500058492920000ffffffff4400
                                      enocean.0	2020-12-09 19:57:25.597	debug	(4317) 55000a0701eba581970008058492920000ffffffff4600
                                      enocean.0	2020-12-09 19:57:25.533	debug	(4317) 55000707017ad500058492920000ffffffff4600
                                      enocean.0	2020-12-09 19:57:25.373	debug	(4317) 55000a0701eba586980008058492920000ffffffff4600
                                      enocean.0	2020-12-09 19:57:25.245	debug	(4317) 55000707017ad500058492920000ffffffff4400
                                      enocean.0	2020-12-09 19:57:24.493	debug	(4317) 55000a0701eba586980008058492920000ffffffff4600
                                      enocean.0	2020-12-09 19:57:24.333	debug	(4317) 55000707017ad500058492920000ffffffff4400
                                      enocean.0	2020-12-09 19:57:24.158	debug	(4317) 55000a0701eba586980008058492920000ffffffff4700
                                      enocean.0	2020-12-09 19:57:24.157	debug	(4317) 55000707017ad5090583fc820100ffffffff4900
                                      enocean.0	2020-12-09 19:57:24.013	debug	(4317) 55000707017ad500058492920000ffffffff4600
                                      enocean.0	2020-12-09 19:57:22.549	debug	(4317) sendTo "autodetect" to system.adapter.admin.0 from system.adapter.enocean.0
                                      enocean.0	2020-12-09 19:57:21.168	debug	(4317) Message for ID 0583fc82 has been received.
                                      enocean.0	2020-12-09 19:57:21.166	debug	(4317) 55000a0701eba5849800080583fc820100ffffffff4700
                                      enocean.0	2020-12-09 19:56:58.216	debug	(4317) sendTo "getEEPList" to system.adapter.admin.0 from system.adapter.enocean.0
                                      enocean.0	2020-12-09 19:56:58.206	debug	(4317) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.enocean.0
                                      enocean.0	2020-12-09 19:56:58.203	debug	(4317) sendTo "listSerial" to system.adapter.admin.0 from system.adapter.enocean.0
                                      enocean.0	2020-12-09 19:56:58.203	info	(4317) ["/dev/ttyAMA0","/dev/ttyUSB0"]
                                      Habe neu über GIT installiert und mal ein paar Fenstersensoren hinzugefügt. Glaube es fehlt eine EEP, der Status offen/zu wird nicht übermittelt.
                                      Siehe hier:
                                      enocean.0	2020-12-09 20:14:59.254	info	(22792) ["/dev/ttyAMA0","/dev/ttyUSB0"]
                                      enocean.0	2020-12-09 20:14:37.511	debug	(22792) Message for ID 05847880 has been received.
                                      enocean.0	2020-12-09 20:14:37.508	debug	(22792) 55000707017ad509058478800000ffffffff4900
                                      enocean.0	2020-12-09 20:14:02.846	debug	(22792) Message for ID 0584926b has been received.
                                      enocean.0	2020-12-09 20:14:02.843	debug	(22792) 55000707017ad5090584926b0100ffffffff4700
                                      enocean.0	2020-12-09 20:13:35.859	debug	(22792) Message for ID 05849292 has been received.
                                      enocean.0	2020-12-09 20:13:35.856	debug	(22792) 55000707017ad509058492920000ffffffff5000
                                      enocean.0	2020-12-09 20:13:26.053	debug	(22792) Message for ID 058492d4 has been received.
                                      enocean.0	2020-12-09 20:13:26.050	debug	(22792) 55000707017ad509058492d40000ffffffff5200
                                      enocean.0	2020-12-09 20:13:19.301	debug	(22792) Message for ID 0583fc82 has been received.
                                      enocean.0	2020-12-09 20:13:19.298	debug	(22792) 55000707017ad5090583fc820100ffffffff4600
                                      enocean.0	2020-12-09 20:13:15.291	debug	(22792) Message for ID 0582de30 has been received.
                                      enocean.0	2020-12-09 20:13:15.287	debug	(22792) 55000707017ad5090582de300000ffffffff4a00
                                      enocean.0	2020-12-09 20:12:57.642	debug	(22792) Message for ID 0582dde4 has been received.
                                      enocean.0	2020-12-09 20:12:57.639	debug	(22792) 55000707017ad5090582dde40100ffffffff4900
                                      enocean.0	2020-12-09 20:11:56.245	debug	(22792) Message for ID 0584924a has been received.
                                      enocean.0	2020-12-09 20:11:56.242	debug	(22792) 55000707017ad5090584924a0000ffffffff4700
                                      enocean.0	2020-12-09 20:11:53.114	debug	(22792) Message for ID 0584924a has been received.
                                      enocean.0	2020-12-09 20:11:53.107	debug	(22792) 55000707017ad5090584924a0000ffffffff4600
                                      enocean.0	2020-12-09 20:11:37.316	debug	(22792) sendTo "getEEPList" to system.adapter.admin.0 from system.adapter.enocean.0
                                      enocean.0	2020-12-09 20:11:37.313	debug	(22792) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.enocean.0
                                      enocean.0	2020-12-09 20:11:37.311	debug	(22792) sendTo "listSerial" to system.adapter.admin.0 from system.adapter.enocean.0
                                      enocean.0	2020-12-09 20:11:37.310	info	(22792) ["/dev/ttyAMA0","/dev/ttyUSB0"]
                                      enocean.0	2020-12-09 20:11:37.228	debug	(22792) Message for ID 0584924a has been received.
                                      enocean.0	2020-12-09 20:11:37.221	debug	(22792) 55000707017ad5080584924a0000ffffffff4700
                                      enocean.0	2020-12-09 20:11:34.089	debug	(22792) Message for ID 0584924a has been received.
                                      enocean.0	2020-12-09 20:11:34.086	debug	(22792) 55000707017ad5080584924a0000ffffffff4400
                                      enocean.0	2020-12-09 20:11:22.714	info	(22792) 8
                                      enocean.0	2020-12-09 20:11:22.708	info	(22792) 8
                                      enocean.0	2020-12-09 20:11:22.704	debug	(22792) sendTo "newDevice" to system.adapter.admin.0 from system.adapter.enocean.0
                                      enocean.0	2020-12-09 20:11:22.703	info	(22792) Create objects for TF-13-08 from ELTAKO with id: 0584924a
                                      enocean.0	2020-12-09 20:11:22.702	info	(22792) undefined
                                      enocean.0	2020-12-09 20:11:22.702	info	(22792) new device
                                      enocean.0	2020-12-09 20:11:22.698	debug	(22792) sendTo "newDevice" to system.adapter.admin.0 from system.adapter.enocean.0
                                      enocean.0	2020-12-09 20:11:22.696	info	(22792) Create objects for D5-00-01 from ELTAKO with id: 0584924a
                                      enocean.0	2020-12-09 20:11:22.696	info	(22792) undefined
                                      enocean.0	2020-12-09 20:11:22.695	info	(22792) new device
                                      enocean.0	2020-12-09 20:10:56.048	debug	(22792) Message for ID 05849295 has been received.
                                      enocean.0	2020-12-09 20:10:56.045	debug	(22792) 55000707017ad509058492950000ffffffff4d00
                                      enocean.0	2020-12-09 20:09:52.492	debug	(22792) Message for ID 0584924a has been received.
                                      enocean.0	2020-12-09 20:09:52.489	debug	(22792) 55000707017ad5090584924a0000ffffffff4700
                                      enocean.0	2020-12-09 20:09:42.027	debug	(22792) sendTo "getEEPList" to system.adapter.admin.0 from system.adapter.enocean.0
                                      enocean.0	2020-12-09 20:09:42.024	debug	(22792) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.enocean.0
                                      enocean.0	2020-12-09 20:09:42.022	debug	(22792) sendTo "listSerial" to system.adapter.admin.0 from system.adapter.enocean.0
                                      enocean.0	2020-12-09 20:09:42.022	info	(22792) ["/dev/ttyAMA0","/dev/ttyUSB0"]
                                      • Jey Cee
                                        @EnoceanEltako du hast recht. D5-00-01 fehlt.
                                          @Jey-Cee kann ich die einfach manuell hinzufügen? Oder müssen diese direkt beim Einlernen mitgegeben werden?
                                          • Jey Cee
                                            @EnoceanEltako kannst du manuell hinzufügen.
                                            31.7k
                                            79.9k
                                            eltako enocean enocean adapter tipp-funk
                                            38
                                            675
                                            134823
