    4. Test Adapter HeatingControl v2.12.x
      mrMuppet @Rene_HM last edited by mrMuppet
      @Rene_HM Mir ist jetzt gerade keine Lösung eingefallen, wie ich das Log effizient kürze. Es geht um den Raum Schlafzimmer.
      2020-12-06 00:00:03.855 - info: heatingcontrol.0 (642325) public holiday today is true
      2020-12-06 00:00:04.118 - info: heatingcontrol.0 (642325) set thermostat hm-rpc.2.INT0000006.1.SET_POINT_TEMPERATURE to 18; current is 17
      2020-12-06 00:00:04.360 - info: feiertage.0 (2473751) Terminated (NO_ERROR): Without reason
      2020-12-06 00:00:04.878 - info: host.dnkr--mgmt instance system.adapter.feiertage.0 terminated with code 0 (NO_ERROR)
      2020-12-06 00:00:05.772 - info: heatingcontrol.0 (642325) handle actors Schlafzimmer current 20 target 17
      2020-12-06 00:00:05.774 - info: heatingcontrol.0 (642325) handle actors Kinderzimmer 1 current 20 target 18
      2020-12-06 00:00:05.778 - info: heatingcontrol.0 (642325) handle actors Kinderzimmer 2 current 19.3 target 18
      2020-12-06 00:00:05.781 - info: heatingcontrol.0 (642325) handle actors Bad current 19.9 target 19
      2020-12-06 00:00:05.785 - info: heatingcontrol.0 (642325) handle actors HWR current 18.5 target 16
      2020-12-06 00:00:05.788 - info: heatingcontrol.0 (642325) handle actors Dachzimmer current 19.8 target 18
      2020-12-06 00:00:05.791 - info: heatingcontrol.0 (642325) handle actors Gaeste WC current 19.3 target 18
      2020-12-06 00:00:05.794 - info: heatingcontrol.0 (642325) handle actors Flur current 19.7 target 17
      2020-12-06 00:00:05.797 - info: heatingcontrol.0 (642325) handle actors Wohnzimmer current 20.5 target 17
      2020-12-06 00:00:05.914 - info: heatingcontrol.0 (642325) 28 cron job(s) created
      2020-12-06 00:00:12.456 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for Kinderzimmer 1
      2020-12-06 00:01:00.082 - info: host.dnkr--mgmt instance system.adapter.schoolfree.0 started with pid 2475004
      2020-12-06 00:01:03.770 - info: schoolfree.0 (2475004) starting. Version 0.7.0 in /opt/iobroker/node_modules/iobroker.schoolfree, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 00:01:03.902 - warn: schoolfree.0 (2475004) schoolfree set state error: TypeError: Cannot read property 'name' of undefined
      2020-12-06 00:01:14.749 - info: schoolfree.0 (2475004) schoolfree request done
      2020-12-06 00:01:24.756 - info: schoolfree.0 (2475004) Terminated (NO_ERROR): Without reason
      2020-12-06 00:01:25.282 - info: host.dnkr--mgmt instance system.adapter.schoolfree.0 terminated with code 0 (NO_ERROR)
      2020-12-06 00:02:00.031 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 2476391
      2020-12-06 00:02:02.472 - info: daswetter.0 (2476391) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 00:02:24.041 - info: daswetter.0 (2476391) got wrong data structure! trying to repair...
      2020-12-06 00:02:30.058 - info: daswetter.0 (2476391) Terminated (NO_ERROR): Without reason
      2020-12-06 00:02:30.587 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 00:06:00.048 - info: host.dnkr--mgmt instance system.adapter.yr.0 started with pid 2481581
      2020-12-06 00:06:03.097 - info: yr.0 (2481581) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.yr, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 00:06:03.258 - info: yr.0 (2481581) got weather data from yr.no
      2020-12-06 00:06:08.452 - info: host.dnkr--mgmt instance system.adapter.yr.0 terminated with code 0 (NO_ERROR)
      2020-12-06 00:09:03.721 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for HWR
      2020-12-06 00:19:00.038 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 2498100
      2020-12-06 00:19:02.116 - info: daswetter.0 (2498100) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 00:19:23.020 - info: daswetter.0 (2498100) got wrong data structure! trying to repair...
      2020-12-06 00:19:29.170 - info: daswetter.0 (2498100) Terminated (NO_ERROR): Without reason
      2020-12-06 00:19:29.698 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 00:36:00.074 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 2519822
      2020-12-06 00:36:03.252 - info: daswetter.0 (2519822) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 00:36:19.213 - info: daswetter.0 (2519822) got wrong data structure! trying to repair...
      2020-12-06 00:36:24.100 - info: daswetter.0 (2519822) Terminated (NO_ERROR): Without reason
      2020-12-06 00:36:24.630 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 00:42:05.563 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for Kinderzimmer 1
      2020-12-06 00:53:00.116 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 2541380
      2020-12-06 00:53:01.759 - info: daswetter.0 (2541380) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 00:53:23.794 - info: daswetter.0 (2541380) got wrong data structure! trying to repair...
      2020-12-06 00:53:30.731 - info: daswetter.0 (2541380) Terminated (NO_ERROR): Without reason
      2020-12-06 00:53:31.261 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 01:02:00.074 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 2552896
      2020-12-06 01:02:03.300 - info: daswetter.0 (2552896) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 01:02:26.160 - info: daswetter.0 (2552896) got wrong data structure! trying to repair...
      2020-12-06 01:02:31.828 - info: daswetter.0 (2552896) Terminated (NO_ERROR): Without reason
      2020-12-06 01:02:32.366 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 01:06:00.051 - info: host.dnkr--mgmt instance system.adapter.yr.0 started with pid 2558015
      2020-12-06 01:06:02.125 - info: yr.0 (2558015) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.yr, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 01:06:02.301 - info: yr.0 (2558015) got weather data from yr.no
      2020-12-06 01:06:08.588 - info: host.dnkr--mgmt instance system.adapter.yr.0 terminated with code 0 (NO_ERROR)
      2020-12-06 01:19:00.126 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 2574508
      2020-12-06 01:19:01.705 - info: daswetter.0 (2574508) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 01:19:19.194 - info: daswetter.0 (2574508) got wrong data structure! trying to repair...
      2020-12-06 01:19:25.074 - info: daswetter.0 (2574508) Terminated (NO_ERROR): Without reason
      2020-12-06 01:19:25.605 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 01:22:07.812 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for HWR
      2020-12-06 01:35:18.421 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for Kinderzimmer 1
      2020-12-06 01:36:00.079 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 2596193
      2020-12-06 01:36:03.207 - info: daswetter.0 (2596193) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 01:36:26.483 - info: daswetter.0 (2596193) got wrong data structure! trying to repair...
      2020-12-06 01:36:31.447 - info: daswetter.0 (2596193) Terminated (NO_ERROR): Without reason
      2020-12-06 01:36:31.978 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 01:53:00.120 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 2617738
      2020-12-06 01:53:03.338 - info: daswetter.0 (2617738) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 01:53:24.959 - info: daswetter.0 (2617738) got wrong data structure! trying to repair...
      2020-12-06 01:53:30.386 - info: daswetter.0 (2617738) Terminated (NO_ERROR): Without reason
      2020-12-06 01:53:30.922 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 02:02:00.126 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 2629324
      2020-12-06 02:02:02.985 - info: daswetter.0 (2629324) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 02:02:24.567 - info: daswetter.0 (2629324) got wrong data structure! trying to repair...
      2020-12-06 02:02:31.511 - info: daswetter.0 (2629324) Terminated (NO_ERROR): Without reason
      2020-12-06 02:02:32.043 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 02:06:00.072 - info: host.dnkr--mgmt instance system.adapter.yr.0 started with pid 2634427
      2020-12-06 02:06:01.797 - info: yr.0 (2634427) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.yr, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 02:06:02.034 - info: yr.0 (2634427) got weather data from yr.no
      2020-12-06 02:06:07.676 - info: host.dnkr--mgmt instance system.adapter.yr.0 terminated with code 0 (NO_ERROR)
      2020-12-06 02:14:36.253 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for HWR
      2020-12-06 02:19:00.118 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 2650931
      2020-12-06 02:19:03.351 - info: daswetter.0 (2650931) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 02:19:25.414 - info: daswetter.0 (2650931) got wrong data structure! trying to repair...
      2020-12-06 02:19:30.904 - info: daswetter.0 (2650931) Terminated (NO_ERROR): Without reason
      2020-12-06 02:19:31.429 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 02:33:13.197 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for Kinderzimmer 1
      2020-12-06 02:36:00.079 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 2672648
      2020-12-06 02:36:02.789 - info: daswetter.0 (2672648) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 02:36:25.201 - info: daswetter.0 (2672648) got wrong data structure! trying to repair...
      2020-12-06 02:36:31.068 - info: daswetter.0 (2672648) Terminated (NO_ERROR): Without reason
      2020-12-06 02:36:31.592 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 02:53:00.120 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 2694250
      2020-12-06 02:53:02.260 - info: daswetter.0 (2694250) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 02:53:21.558 - info: daswetter.0 (2694250) got wrong data structure! trying to repair...
      2020-12-06 02:53:27.957 - info: daswetter.0 (2694250) Terminated (NO_ERROR): Without reason
      2020-12-06 02:53:28.482 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 03:00:51.748 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for HWR
      2020-12-06 03:01:30.405 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for Kinderzimmer 1
      2020-12-06 03:02:00.050 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 2705824
      2020-12-06 03:02:02.144 - info: daswetter.0 (2705824) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 03:02:24.093 - info: daswetter.0 (2705824) got wrong data structure! trying to repair...
      2020-12-06 03:02:28.489 - info: daswetter.0 (2705824) Terminated (NO_ERROR): Without reason
      2020-12-06 03:02:29.012 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 03:06:00.150 - info: host.dnkr--mgmt instance system.adapter.yr.0 started with pid 2710932
      2020-12-06 03:06:03.921 - info: yr.0 (2710932) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.yr, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 03:06:04.085 - info: yr.0 (2710932) got weather data from yr.no
      2020-12-06 03:06:09.365 - info: host.dnkr--mgmt instance system.adapter.yr.0 terminated with code 0 (NO_ERROR)
      2020-12-06 03:07:56.085 - error: iot.0 (775695) Error by device connection: "read ECONNRESET"
      2020-12-06 03:07:56.086 - info: iot.0 (775695) Connection changed: disconnect
      2020-12-06 03:07:56.086 - info: iot.0 (775695) Connection lost
      2020-12-06 03:08:01.298 - info: iot.0 (775695) Connection changed: connect
      2020-12-06 03:17:25.764 - warn: km200.0 (710735) Skip service data of /heatSources/numberOfStarts
      2020-12-06 03:17:25.774 - info: km200.0 (710735) Update State 11 err: TypeError: Cannot read property 'value' of undefinedat /opt/iobroker/node_modules/iobroker.km200/km200.js:556:35at runMicrotasks ()at processTicksAndRejections (internal/process/task_queues.js:97:5)
      2020-12-06 03:19:00.126 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 2727509
      2020-12-06 03:19:03.570 - info: daswetter.0 (2727509) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 03:19:25.553 - info: daswetter.0 (2727509) got wrong data structure! trying to repair...
      2020-12-06 03:19:31.332 - info: daswetter.0 (2727509) Terminated (NO_ERROR): Without reason
      2020-12-06 03:19:31.858 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 03:36:00.137 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 2749200
      2020-12-06 03:36:01.778 - info: daswetter.0 (2749200) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 03:36:23.047 - info: daswetter.0 (2749200) got wrong data structure! trying to repair...
      2020-12-06 03:36:29.154 - info: daswetter.0 (2749200) Terminated (NO_ERROR): Without reason
      2020-12-06 03:36:29.692 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 03:53:00.051 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 2770804
      2020-12-06 03:53:04.544 - info: daswetter.0 (2770804) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 03:53:22.551 - info: daswetter.0 (2770804) got wrong data structure! trying to repair...
      2020-12-06 03:53:29.576 - info: daswetter.0 (2770804) Terminated (NO_ERROR): Without reason
      2020-12-06 03:53:30.112 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 03:53:48.422 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for HWR
      2020-12-06 03:54:14.824 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for Kinderzimmer 1
      2020-12-06 04:02:00.048 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 2782223
      2020-12-06 04:02:01.806 - info: daswetter.0 (2782223) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 04:02:22.849 - info: daswetter.0 (2782223) got wrong data structure! trying to repair...
      2020-12-06 04:02:29.134 - info: daswetter.0 (2782223) Terminated (NO_ERROR): Without reason
      2020-12-06 04:02:29.659 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 04:06:00.126 - info: host.dnkr--mgmt instance system.adapter.yr.0 started with pid 2787343
      2020-12-06 04:06:01.990 - info: yr.0 (2787343) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.yr, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 04:06:02.177 - info: yr.0 (2787343) got weather data from yr.no
      2020-12-06 04:06:08.338 - info: host.dnkr--mgmt instance system.adapter.yr.0 terminated with code 0 (NO_ERROR)
      2020-12-06 04:19:00.086 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 2803955
      2020-12-06 04:19:02.900 - info: daswetter.0 (2803955) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 04:19:24.253 - info: daswetter.0 (2803955) got wrong data structure! trying to repair...
      2020-12-06 04:19:30.833 - info: daswetter.0 (2803955) Terminated (NO_ERROR): Without reason
      2020-12-06 04:19:31.363 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 04:36:00.047 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 2825514
      2020-12-06 04:36:03.256 - info: daswetter.0 (2825514) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 04:36:25.200 - info: daswetter.0 (2825514) got wrong data structure! trying to repair...
      2020-12-06 04:36:31.106 - info: daswetter.0 (2825514) Terminated (NO_ERROR): Without reason
      2020-12-06 04:36:31.631 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 04:47:24.489 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for HWR
      2020-12-06 04:47:40.027 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for Kinderzimmer 1
      2020-12-06 04:53:00.073 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 2847255
      2020-12-06 04:53:03.643 - info: daswetter.0 (2847255) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 04:53:24.625 - info: daswetter.0 (2847255) got wrong data structure! trying to repair...
      2020-12-06 04:53:30.531 - info: daswetter.0 (2847255) Terminated (NO_ERROR): Without reason
      2020-12-06 04:53:31.057 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 05:00:00.010 - info: harmony.0 (1015391) Scheduled restart.
      2020-12-06 05:00:00.016 - info: harmony.0 (1015391) [END] Terminating
      2020-12-06 05:00:00.039 - info: harmony.0 (1015391) terminating
      2020-12-06 05:00:00.040 - info: harmony.0 (1015391) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2020-12-06 05:00:00.114 - info: heatingcontrol.0 (642325) set thermostat hm-rpc.2.INT0000004.1.SET_POINT_TEMPERATURE to 7; current is 17
      2020-12-06 05:00:00.497 - info: heatingcontrol.0 (642325) set thermostat hm-rpc.2.INT0000005.1.SET_POINT_TEMPERATURE to 18; current is 17
      2020-12-06 05:00:00.744 - info: host.dnkr--mgmt instance system.adapter.harmony.0 scheduled normal terminated and will be restarted on schedule.
      2020-12-06 05:00:00.758 - info: host.dnkr--mgmt Restart adapter system.adapter.harmony.0 because enabled
      2020-12-06 05:00:01.325 - info: heatingcontrol.0 (642325) set thermostat hm-rpc.2.INT0000002.1.SET_POINT_TEMPERATURE to 18; current is 17
      2020-12-06 05:00:01.879 - info: host.dnkr--mgmt instance system.adapter.harmony.0 started with pid 2856284
      2020-12-06 05:00:02.178 - info: heatingcontrol.0 (642325) handle actors Schlafzimmer current 19.9 target 7
      2020-12-06 05:00:02.179 - info: heatingcontrol.0 (642325) handle actors Kinderzimmer 1 current 19.9 target 18
      2020-12-06 05:00:02.179 - info: heatingcontrol.0 (642325) handle actors Kinderzimmer 2 current 18.9 target 18
      2020-12-06 05:00:02.180 - info: heatingcontrol.0 (642325) handle actors Bad current 19.4 target 19
      2020-12-06 05:00:02.181 - info: heatingcontrol.0 (642325) handle actors HWR current 17.9 target 16
      2020-12-06 05:00:02.181 - info: heatingcontrol.0 (642325) handle actors Dachzimmer current 19 target 18
      2020-12-06 05:00:02.182 - info: heatingcontrol.0 (642325) handle actors Gaeste WC current 19.1 target 18
      2020-12-06 05:00:02.183 - info: heatingcontrol.0 (642325) handle actors Flur current 19.5 target 17
      2020-12-06 05:00:02.183 - info: heatingcontrol.0 (642325) handle actors Wohnzimmer current 20 target 17
      2020-12-06 05:00:02.216 - info: heatingcontrol.0 (642325) 28 cron job(s) created
      2020-12-06 05:00:05.271 - info: harmony.0 (2856284) starting. Version 1.2.2 in /opt/iobroker/node_modules/iobroker.harmony, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 05:00:05.639 - info: harmony.0 (2856284) [DISCOVER] Searching for Harmony Hubs on 192.168.178.100
      2020-12-06 05:00:06.833 - info: harmony.0 (2856284) [DISCOVER] Discovered Medienzentrale (192.168.178.100) and will try to connect
      2020-12-06 05:00:07.288 - info: harmony.0 (2856284) [CONNECT] Connecting to Medienzentrale (192.168.178.100)
      2020-12-06 05:00:08.493 - info: harmony.0 (2856284) [CONNECT] Connected to Medienzentrale (192.168.178.100)
      2020-12-06 05:00:09.785 - info: harmony.0 (2856284) [PROCESS] Synced hub config for Medienzentrale (192.168.178.100)
      2020-12-06 05:02:00.074 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 2858695
      2020-12-06 05:02:03.374 - info: daswetter.0 (2858695) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 05:02:25.506 - info: daswetter.0 (2858695) got wrong data structure! trying to repair...
      2020-12-06 05:02:32.554 - info: daswetter.0 (2858695) Terminated (NO_ERROR): Without reason
      2020-12-06 05:02:33.089 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 05:06:00.131 - info: host.dnkr--mgmt instance system.adapter.yr.0 started with pid 2863815
      2020-12-06 05:06:01.686 - info: yr.0 (2863815) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.yr, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 05:06:01.874 - info: yr.0 (2863815) got weather data from yr.no
      2020-12-06 05:06:08.450 - info: host.dnkr--mgmt instance system.adapter.yr.0 terminated with code 0 (NO_ERROR)
      2020-12-06 05:19:00.122 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 2880435
      2020-12-06 05:19:03.321 - info: daswetter.0 (2880435) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 05:19:27.420 - info: daswetter.0 (2880435) got wrong data structure! trying to repair...
      2020-12-06 05:19:33.800 - info: daswetter.0 (2880435) Terminated (NO_ERROR): Without reason
      2020-12-06 05:19:34.326 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 05:36:00.049 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 2902634
      2020-12-06 05:36:03.014 - info: daswetter.0 (2902634) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 05:36:23.157 - info: daswetter.0 (2902634) got wrong data structure! trying to repair...
      2020-12-06 05:36:29.237 - info: daswetter.0 (2902634) Terminated (NO_ERROR): Without reason
      2020-12-06 05:36:29.773 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 05:40:35.641 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for HWR
      2020-12-06 05:41:15.416 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for Kinderzimmer 1
      2020-12-06 05:53:00.115 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 2924392
      2020-12-06 05:53:01.727 - info: daswetter.0 (2924392) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 05:53:26.395 - info: daswetter.0 (2924392) got wrong data structure! trying to repair...
      2020-12-06 05:53:31.112 - info: daswetter.0 (2924392) Terminated (NO_ERROR): Without reason
      2020-12-06 05:53:31.635 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 06:01:02.383 - info: pushover.0 (642639) Send pushover notification: {"message":"Heizung eingeschaltet. WZ: 0 Kü: 15 Fl: 0 K1: 55.00000000000001 K2: 0 SZ: 0 Bad: 6 DZ: 0 HWR: 0 GKlo:0","title":"ioBroker","priority":"0"}
      2020-12-06 06:01:02.394 - info: km200.0 (710735) Set km200.0.heatingCircuits.hc1.activeSwitchProgram to 0
      2020-12-06 06:01:04.409 - info: km200.0 (710735) Update {'heatingCircuits.hc1.activeSwitchProgram': {type: 'state',id: 'heatingCircuits.hc1.activeSwitchProgram',common: {id: 'heatingCircuits.hc1.activeSwitchProgram',name: 'heatingCircuits.hc1.activeSwitchProgram',type: 'number',unit: '',read: true,write: true,role: 'level',states: '0:A;1:B',min: 0,max: 1,native: [Object]},native: { km200: [Object] }}}
      2020-12-06 06:02:00.123 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 2935814
      2020-12-06 06:02:01.807 - info: daswetter.0 (2935814) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 06:02:21.597 - info: daswetter.0 (2935814) got wrong data structure! trying to repair...
      2020-12-06 06:02:28.691 - info: daswetter.0 (2935814) Terminated (NO_ERROR): Without reason
      2020-12-06 06:02:29.218 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 06:06:00.047 - info: host.dnkr--mgmt instance system.adapter.yr.0 started with pid 2940931
      2020-12-06 06:06:03.214 - info: yr.0 (2940931) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.yr, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 06:06:03.393 - info: yr.0 (2940931) got weather data from yr.no
      2020-12-06 06:06:08.636 - info: host.dnkr--mgmt instance system.adapter.yr.0 terminated with code 0 (NO_ERROR)
      2020-12-06 06:19:00.067 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 2957586
      2020-12-06 06:19:02.877 - info: daswetter.0 (2957586) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 06:19:24.522 - info: daswetter.0 (2957586) got wrong data structure! trying to repair...
      2020-12-06 06:19:30.582 - info: daswetter.0 (2957586) Terminated (NO_ERROR): Without reason
      2020-12-06 06:19:31.110 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 06:33:22.333 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for HWR
      2020-12-06 06:36:00.050 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 2979411
      2020-12-06 06:36:01.800 - info: daswetter.0 (2979411) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 06:36:24.734 - info: daswetter.0 (2979411) got wrong data structure! trying to repair...
      2020-12-06 06:36:30.546 - info: daswetter.0 (2979411) Terminated (NO_ERROR): Without reason
      2020-12-06 06:36:31.072 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 06:39:03.082 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for Kinderzimmer 1
      2020-12-06 06:53:00.121 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 3001177
      2020-12-06 06:53:02.161 - info: daswetter.0 (3001177) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 06:53:21.889 - info: daswetter.0 (3001177) got wrong data structure! trying to repair...
      2020-12-06 06:53:28.277 - info: daswetter.0 (3001177) Terminated (NO_ERROR): Without reason
      2020-12-06 06:53:28.885 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 06:58:37.558 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for HWR
      2020-12-06 07:02:00.123 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 3012552
      2020-12-06 07:02:01.694 - info: daswetter.0 (3012552) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 07:02:19.913 - info: daswetter.0 (3012552) got wrong data structure! trying to repair...
      2020-12-06 07:02:27.110 - info: daswetter.0 (3012552) Terminated (NO_ERROR): Without reason
      2020-12-06 07:02:27.637 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 07:06:00.049 - info: host.dnkr--mgmt instance system.adapter.yr.0 started with pid 3017671
      2020-12-06 07:06:01.730 - info: yr.0 (3017671) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.yr, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 07:06:01.908 - info: yr.0 (3017671) got weather data from yr.no
      2020-12-06 07:06:08.604 - info: host.dnkr--mgmt instance system.adapter.yr.0 terminated with code 0 (NO_ERROR)
      2020-12-06 07:07:30.533 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for Kinderzimmer 1
      2020-12-06 07:19:00.126 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 3034317
      2020-12-06 07:19:01.929 - info: daswetter.0 (3034317) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 07:19:23.608 - info: daswetter.0 (3034317) got wrong data structure! trying to repair...
      2020-12-06 07:19:29.948 - info: daswetter.0 (3034317) Terminated (NO_ERROR): Without reason
      2020-12-06 07:19:30.471 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 07:21:42.473 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for HWR
      2020-12-06 07:22:07.276 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for Kinderzimmer 1
      2020-12-06 07:29:25.484 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for Bad
      2020-12-06 07:32:23.061 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for Kinderzimmer 1
      2020-12-06 07:36:00.124 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 3055898
      2020-12-06 07:36:03.214 - info: daswetter.0 (3055898) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 07:36:23.089 - info: daswetter.0 (3055898) got wrong data structure! trying to repair...
      2020-12-06 07:36:28.549 - info: daswetter.0 (3055898) Terminated (NO_ERROR): Without reason
      2020-12-06 07:36:29.074 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 07:41:38.858 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for HWR
      2020-12-06 07:49:28.985 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for Kinderzimmer 1
      2020-12-06 07:49:38.818 - error: hm-rpc.1 (642543) xmlrpc -> setValue ["00021A49A42668:5","STATE",true] BOOL
      2020-12-06 07:49:38.826 - error: hm-rpc.1 (642543) Error: XML-RPC fault: Generic error (UNREACH)
      2020-12-06 07:53:00.049 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 3077626
      2020-12-06 07:53:01.773 - info: daswetter.0 (3077626) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 07:53:23.911 - info: daswetter.0 (3077626) got wrong data structure! trying to repair...
      2020-12-06 07:53:30.410 - info: daswetter.0 (3077626) Terminated (NO_ERROR): Without reason
      2020-12-06 07:53:30.947 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 08:00:00.035 - info: heatingcontrol.0 (642325) set thermostat hm-rpc.2.INT0000004.1.SET_POINT_TEMPERATURE to 9; current is 21
      2020-12-06 08:00:00.211 - info: heatingcontrol.0 (642325) set thermostat hm-rpc.2.INT0000006.1.SET_POINT_TEMPERATURE to 20; current is 21
      2020-12-06 08:00:00.410 - info: heatingcontrol.0 (642325) set thermostat hm-rpc.0.HEQ0509687.2.SETPOINT to 20; current is 19
      2020-12-06 08:00:00.595 - info: heatingcontrol.0 (642325) set thermostat hm-rpc.1.000A1A499BC88A.1.SET_POINT_TEMPERATURE to 18; current is 16
      2020-12-06 08:00:00.819 - info: heatingcontrol.0 (642325) set thermostat hm-rpc.2.INT0000002.1.SET_POINT_TEMPERATURE to 18; current is 21
      2020-12-06 08:00:01.075 - info: heatingcontrol.0 (642325) set thermostat hm-rpc.1.000A1A499BC891.1.SET_POINT_TEMPERATURE to 19; current is 18
      2020-12-06 08:00:01.301 - info: heatingcontrol.0 (642325) set thermostat hm-rpc.0.JEQ0725588.2.SETPOINT to 19; current is 19.5
      2020-12-06 08:00:01.464 - info: heatingcontrol.0 (642325) set thermostat hm-rpc.2.INT0000001.1.SET_POINT_TEMPERATURE to 19; current is 21
      2020-12-06 08:00:01.579 - info: heatingcontrol.0 (642325) handle actors Schlafzimmer current 20.8 target 9
      2020-12-06 08:00:01.581 - info: heatingcontrol.0 (642325) handle actors Kinderzimmer 1 current 21.4 target 20
      2020-12-06 08:00:01.583 - info: heatingcontrol.0 (642325) handle actors Kinderzimmer 2 current 20.8 target 20
      2020-12-06 08:00:01.585 - info: heatingcontrol.0 (642325) handle actors Bad current 19.4 target 20
      2020-12-06 08:00:01.587 - info: heatingcontrol.0 (642325) handle actors HWR current 18.9 target 18
      2020-12-06 08:00:01.589 - info: heatingcontrol.0 (642325) handle actors Dachzimmer current 21.1 target 18
      2020-12-06 08:00:01.590 - info: heatingcontrol.0 (642325) handle actors Gaeste WC current 19.2 target 19
      2020-12-06 08:00:01.592 - info: heatingcontrol.0 (642325) handle actors Flur current 19.4 target 19
      2020-12-06 08:00:01.599 - info: heatingcontrol.0 (642325) handle actors Wohnzimmer current 20.6 target 19
      2020-12-06 08:00:01.625 - info: heatingcontrol.0 (642325) 28 cron job(s) created
      2020-12-06 08:00:10.711 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for HWR
      2020-12-06 08:02:00.122 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 3089019
      2020-12-06 08:02:02.116 - info: daswetter.0 (3089019) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 08:02:21.645 - info: daswetter.0 (3089019) got wrong data structure! trying to repair...
      2020-12-06 08:02:26.838 - info: daswetter.0 (3089019) Terminated (NO_ERROR): Without reason
      2020-12-06 08:02:27.364 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 08:03:33.639 - info: pushover.0 (642639) Send pushover notification: {"message":"Heizung ausgeschaltet. WZ: 0 Kü: 12 Fl: 0 K1: 0 K2: 20 SZ: 0 Bad: 1 DZ: 0 HWR: 0 GKlo: 20","title":"ioBroker","priority":"0"}
      2020-12-06 08:03:33.955 - info: km200.0 (710735) Set km200.0.heatingCircuits.hc1.activeSwitchProgram to 1
      2020-12-06 08:03:34.269 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for Kinderzimmer 1
      2020-12-06 08:03:35.959 - info: km200.0 (710735) Update {'heatingCircuits.hc1.activeSwitchProgram': {type: 'state',id: 'heatingCircuits.hc1.activeSwitchProgram',common: {id: 'heatingCircuits.hc1.activeSwitchProgram',name: 'heatingCircuits.hc1.activeSwitchProgram',type: 'number',unit: '',read: true,write: true,role: 'level',states: '0:A;1:B',min: 0,max: 1,native: [Object]},native: { km200: [Object] }}}
      2020-12-06 08:04:12.986 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for HWR
      2020-12-06 08:06:00.118 - info: host.dnkr--mgmt instance system.adapter.yr.0 started with pid 3094140
      2020-12-06 08:06:01.978 - info: yr.0 (3094140) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.yr, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 08:06:02.206 - info: yr.0 (3094140) got weather data from yr.no
      2020-12-06 08:06:08.637 - info: host.dnkr--mgmt instance system.adapter.yr.0 terminated with code 0 (NO_ERROR)
      2020-12-06 08:07:44.374 - info: admin.0 (642216) Request actual repository...
      2020-12-06 08:07:44.490 - info: host.dnkr--mgmt Update repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
      2020-12-06 08:07:49.670 - info: admin.0 (642216) Repository received successfully.
      2020-12-06 08:19:00.079 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 3110781
      2020-12-06 08:19:01.866 - info: daswetter.0 (3110781) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 08:19:22.713 - info: daswetter.0 (3110781) got wrong data structure! trying to repair...
      2020-12-06 08:19:27.160 - info: daswetter.0 (3110781) Terminated (NO_ERROR): Without reason
      2020-12-06 08:19:27.690 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 08:24:03.731 - error: hm-rpc.1 (642543) xmlrpc -> setValue ["00021A49A42668:5","STATE",true] BOOL
      2020-12-06 08:24:03.734 - error: hm-rpc.1 (642543) Error: XML-RPC fault: Generic error (UNREACH)
      2020-12-06 08:30:15.860 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for Kinderzimmer 1
      2020-12-06 08:36:00.121 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 3132379
      2020-12-06 08:36:01.959 - info: daswetter.0 (3132379) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 08:36:22.281 - info: daswetter.0 (3132379) got wrong data structure! trying to repair...
      2020-12-06 08:36:29.405 - info: daswetter.0 (3132379) Terminated (NO_ERROR): Without reason
      2020-12-06 08:36:29.935 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 08:53:00.118 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 3154248
      2020-12-06 08:53:01.798 - info: daswetter.0 (3154248) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 08:53:24.527 - info: daswetter.0 (3154248) got wrong data structure! trying to repair...
      2020-12-06 08:53:30.925 - info: daswetter.0 (3154248) Terminated (NO_ERROR): Without reason
      2020-12-06 08:53:31.451 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 08:58:18.682 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for HWR
      2020-12-06 09:00:00.865 - info: heatingcontrol.0 (642325) set thermostat hm-rpc.2.INT0000002.1.SET_POINT_TEMPERATURE to 20; current is 18
      2020-12-06 09:00:01.421 - info: heatingcontrol.0 (642325) set thermostat hm-rpc.2.INT0000001.1.SET_POINT_TEMPERATURE to 20; current is 19
      2020-12-06 09:00:01.572 - info: heatingcontrol.0 (642325) handle actors Schlafzimmer current 20.5 target 9
      2020-12-06 09:00:01.574 - info: heatingcontrol.0 (642325) handle actors Kinderzimmer 1 current 21.1 target 20
      2020-12-06 09:00:01.575 - info: heatingcontrol.0 (642325) handle actors Kinderzimmer 2 current 20.4 target 20
      2020-12-06 09:00:01.577 - info: heatingcontrol.0 (642325) handle actors Bad current 19.6 target 20
      2020-12-06 09:00:01.578 - info: heatingcontrol.0 (642325) handle actors HWR current 19.3 target 18
      2020-12-06 09:00:01.580 - info: heatingcontrol.0 (642325) handle actors Dachzimmer current 21.1 target 20
      2020-12-06 09:00:01.581 - info: heatingcontrol.0 (642325) handle actors Gaeste WC current 20.1 target 19
      2020-12-06 09:00:01.582 - info: heatingcontrol.0 (642325) handle actors Flur current 19.5 target 19
      2020-12-06 09:00:01.584 - info: heatingcontrol.0 (642325) handle actors Wohnzimmer current 20.6 target 20
      2020-12-06 09:00:01.608 - info: heatingcontrol.0 (642325) 28 cron job(s) created
      2020-12-06 09:02:00.156 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 3165646
      2020-12-06 09:02:03.512 - info: daswetter.0 (3165646) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 09:02:22.907 - info: daswetter.0 (3165646) got wrong data structure! trying to repair...
      2020-12-06 09:02:27.564 - info: daswetter.0 (3165646) Terminated (NO_ERROR): Without reason
      2020-12-06 09:02:28.098 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 09:05:41.226 - error: hm-rpc.0 (642528) Ping error: Error: response timeout
      2020-12-06 09:05:41.265 - info: hm-rpc.0 (642528) Disconnected
      2020-12-06 09:05:41.628 - info: hm-rpc.0 (642528) Connected
      2020-12-06 09:06:00.079 - info: host.dnkr--mgmt instance system.adapter.yr.0 started with pid 3170765
      2020-12-06 09:06:04.356 - info: yr.0 (3170765) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.yr, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 09:06:04.520 - info: yr.0 (3170765) got weather data from yr.no
      2020-12-06 09:06:09.723 - info: host.dnkr--mgmt instance system.adapter.yr.0 terminated with code 0 (NO_ERROR)
      2020-12-06 09:08:29.073 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for Kinderzimmer 1
      2020-12-06 09:19:00.071 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 3187437
      2020-12-06 09:19:02.212 - info: daswetter.0 (3187437) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 09:19:24.331 - info: daswetter.0 (3187437) got wrong data structure! trying to repair...
      2020-12-06 09:19:30.405 - info: daswetter.0 (3187437) Terminated (NO_ERROR): Without reason
      2020-12-06 09:19:30.939 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 09:23:32.451 - info: heatingcontrol.0 (642325) set thermostat hm-rpc.2.INT0000004.1.SET_POINT_TEMPERATURE to 19; current is 9
      2020-12-06 09:23:32.609 - info: heatingcontrol.0 (642325) handle actors Schlafzimmer current 20.2 target 19
      2020-12-06 09:23:32.610 - info: heatingcontrol.0 (642325) handle actors Kinderzimmer 1 current 20.8 target 20
      2020-12-06 09:23:32.612 - info: heatingcontrol.0 (642325) handle actors Kinderzimmer 2 current 20.1 target 20
      2020-12-06 09:23:32.613 - info: heatingcontrol.0 (642325) handle actors Bad current 19.6 target 20
      2020-12-06 09:23:32.615 - info: heatingcontrol.0 (642325) handle actors HWR current 19.3 target 18
      2020-12-06 09:23:32.616 - info: heatingcontrol.0 (642325) handle actors Dachzimmer current 20.8 target 20
      2020-12-06 09:23:32.617 - info: heatingcontrol.0 (642325) handle actors Gaeste WC current 20.1 target 19
      2020-12-06 09:23:32.618 - info: heatingcontrol.0 (642325) handle actors Flur current 19.5 target 19
      2020-12-06 09:23:32.620 - info: heatingcontrol.0 (642325) handle actors Wohnzimmer current 20.6 target 20
      2020-12-06 09:23:32.644 - info: heatingcontrol.0 (642325) 28 cron job(s) created
      2020-12-06 09:36:00.053 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 3208995
      2020-12-06 09:36:03.179 - info: daswetter.0 (3208995) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 09:36:26.040 - info: daswetter.0 (3208995) got wrong data structure! trying to repair...
      2020-12-06 09:36:31.843 - info: daswetter.0 (3208995) Terminated (NO_ERROR): Without reason
      2020-12-06 09:36:32.376 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 09:50:55.930 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for HWR
      2020-12-06 09:53:00.079 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 3230723
      2020-12-06 09:53:03.040 - info: daswetter.0 (3230723) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 09:53:24.844 - info: daswetter.0 (3230723) got wrong data structure! trying to repair...
      2020-12-06 09:53:31.176 - info: daswetter.0 (3230723) Terminated (NO_ERROR): Without reason
      2020-12-06 09:53:31.713 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 10:00:00.598 - info: heatingcontrol.0 (642325) set thermostat hm-rpc.0.HEQ0509687.2.SETPOINT to 19; current is 20
      2020-12-06 10:00:01.364 - info: heatingcontrol.0 (642325) handle actors Schlafzimmer current 20.1 target 19
      2020-12-06 10:00:01.366 - info: heatingcontrol.0 (642325) handle actors Kinderzimmer 1 current 20.5 target 20
      2020-12-06 10:00:01.367 - info: heatingcontrol.0 (642325) handle actors Kinderzimmer 2 current 20.1 target 20
      2020-12-06 10:00:01.369 - info: heatingcontrol.0 (642325) handle actors Bad current 19.6 target 19
      2020-12-06 10:00:01.370 - info: heatingcontrol.0 (642325) handle actors HWR current 19.2 target 18
      2020-12-06 10:00:01.371 - info: heatingcontrol.0 (642325) handle actors Dachzimmer current 20.5 target 20
      2020-12-06 10:00:01.372 - info: heatingcontrol.0 (642325) handle actors Gaeste WC current 19.7 target 19
      2020-12-06 10:00:01.374 - info: heatingcontrol.0 (642325) handle actors Flur current 19.5 target 19
      2020-12-06 10:00:01.375 - info: heatingcontrol.0 (642325) handle actors Wohnzimmer current 20.6 target 20
      2020-12-06 10:00:01.400 - info: heatingcontrol.0 (642325) 28 cron job(s) created
      2020-12-06 10:01:34.529 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for Kinderzimmer 1
      2020-12-06 10:02:00.120 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 3242074
      2020-12-06 10:02:02.189 - info: daswetter.0 (3242074) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 10:02:19.263 - info: daswetter.0 (3242074) got wrong data structure! trying to repair...
      2020-12-06 10:02:25.086 - info: daswetter.0 (3242074) Terminated (NO_ERROR): Without reason
      2020-12-06 10:02:25.609 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 10:06:00.053 - info: host.dnkr--mgmt instance system.adapter.yr.0 started with pid 3247188
      2020-12-06 10:06:01.960 - info: yr.0 (3247188) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.yr, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 10:06:02.132 - info: yr.0 (3247188) got weather data from yr.no
      2020-12-06 10:06:08.009 - info: host.dnkr--mgmt instance system.adapter.yr.0 terminated with code 0 (NO_ERROR)
      2020-12-06 10:19:00.078 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 3263818
      2020-12-06 10:19:02.257 - info: daswetter.0 (3263818) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 10:19:23.584 - info: daswetter.0 (3263818) got wrong data structure! trying to repair...
      2020-12-06 10:19:29.320 - info: daswetter.0 (3263818) Terminated (NO_ERROR): Without reason
      2020-12-06 10:19:29.856 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 10:34:56.403 - info: web.0 (1872739) ==>Connected system.user.admin from ::ffff:192.168.178.99
      2020-12-06 10:34:56.656 - info: web.0 (1872739) ==>Connected system.user.admin from ::ffff:192.168.178.99
      2020-12-06 10:35:07.529 - info: web.0 (1872739) ==>Connected system.user.admin from ::ffff:192.168.178.99
      2020-12-06 10:35:11.615 - info: web.0 (1872739) <==Disconnect system.user.admin from ::ffff:192.168.178.99 flot
      2020-12-06 10:35:13.584 - info: web.0 (1872739) ==>Connected system.user.admin from ::ffff:192.168.178.99
      2020-12-06 10:36:00.080 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 3285388
      2020-12-06 10:36:03.299 - info: daswetter.0 (3285388) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 10:36:19.568 - info: daswetter.0 (3285388) got wrong data structure! trying to repair...
      2020-12-06 10:36:25.968 - info: daswetter.0 (3285388) Terminated (NO_ERROR): Without reason
      2020-12-06 10:36:26.497 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 10:38:30.309 - info: web.0 (1872739) <==Disconnect system.user.admin from ::ffff:192.168.178.99 flot
      2020-12-06 10:38:30.384 - info: web.0 (1872739) ==>Connected system.user.admin from ::ffff:192.168.178.99
      2020-12-06 10:38:37.586 - info: web.0 (1872739) <==Disconnect system.user.admin from ::ffff:192.168.178.99 flot
      2020-12-06 10:38:38.217 - info: web.0 (1872739) ==>Connected system.user.admin from ::ffff:192.168.178.99
      2020-12-06 10:44:12.162 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for HWR
      2020-12-06 10:53:00.046 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 3307151
      2020-12-06 10:53:03.233 - info: daswetter.0 (3307151) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 10:53:23.713 - info: daswetter.0 (3307151) got wrong data structure! trying to repair...
      2020-12-06 10:53:30.539 - info: daswetter.0 (3307151) Terminated (NO_ERROR): Without reason
      2020-12-06 10:53:31.071 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 10:55:19.414 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for Kinderzimmer 1
      2020-12-06 11:02:00.172 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 3318552
      2020-12-06 11:02:02.751 - info: daswetter.0 (3318552) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 11:02:26.984 - info: daswetter.0 (3318552) got wrong data structure! trying to repair...
      2020-12-06 11:02:33.201 - info: daswetter.0 (3318552) Terminated (NO_ERROR): Without reason
      2020-12-06 11:02:33.725 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 11:06:00.040 - info: host.dnkr--mgmt instance system.adapter.yr.0 started with pid 3323665
      2020-12-06 11:06:02.174 - info: yr.0 (3323665) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.yr, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 11:06:02.327 - info: yr.0 (3323665) got weather data from yr.no
      2020-12-06 11:06:08.442 - info: host.dnkr--mgmt instance system.adapter.yr.0 terminated with code 0 (NO_ERROR)
      2020-12-06 11:19:00.130 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 3340321
      2020-12-06 11:19:04.720 - info: daswetter.0 (3340321) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 11:19:29.198 - info: daswetter.0 (3340321) got wrong data structure! trying to repair...
      2020-12-06 11:19:35.459 - info: daswetter.0 (3340321) Terminated (NO_ERROR): Without reason
      2020-12-06 11:19:35.994 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 11:36:00.120 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 3362026
      2020-12-06 11:36:01.871 - info: daswetter.0 (3362026) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 11:36:26.361 - info: daswetter.0 (3362026) got wrong data structure! trying to repair...
      2020-12-06 11:36:32.559 - info: daswetter.0 (3362026) Terminated (NO_ERROR): Without reason
      2020-12-06 11:36:33.094 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 11:37:03.490 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for HWR
      2020-12-06 11:38:26.173 - info: km200.0 (710735) Set km200.0.heatingCircuits.hc1.activeSwitchProgram to 0
      2020-12-06 11:38:26.255 - info: pushover.0 (642639) Send pushover notification: {"message":"Heizung eingeschaltet. WZ: 1 Kü: 1 Fl: 0 K1: 14.000000000000002 K2: 40 SZ: 0 Bad: 0 DZ: 14.000000000000002 HWR: 0 GKlo:14.000000000000002","title":"ioBroker","priority":"0"}
      2020-12-06 11:38:28.126 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for Kinderzimmer 1
      2020-12-06 11:38:28.178 - info: km200.0 (710735) Update {'heatingCircuits.hc1.activeSwitchProgram': {type: 'state',id: 'heatingCircuits.hc1.activeSwitchProgram',common: {id: 'heatingCircuits.hc1.activeSwitchProgram',name: 'heatingCircuits.hc1.activeSwitchProgram',type: 'number',unit: '',read: true,write: true,role: 'level',states: '0:A;1:B',min: 0,max: 1,native: [Object]},native: { km200: [Object] }}}
      2020-12-06 11:46:51.486 - info: ham.0 (642303) stateChange ham.0.Front-Door-Haustür.Front-Door-Haustür-Doorbell.Programmable-Switch-Event {"val":0,"ack":true,"ts":1607251611457,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1606556352329}
      2020-12-06 11:46:51.511 - info: ham.0 (642303) stateChange ham.0.Front-Door-Haustür.Front-Door-Haustür-DoorbellSwitch.Programmable-Switch-Event {"val":0,"ack":true,"ts":1607251611457,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1606556352352}
      2020-12-06 11:46:51.514 - info: ham.0 (642303) stateChange ham.0.Front-Door-Haustür.Front-Door-Haustür-Doorbell.Programmable-Switch-Event {"val":0,"ack":true,"ts":1607251611457,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1606556352329}
      2020-12-06 11:46:51.515 - info: ham.0 (642303) stateChange ham.0.Front-Door-Haustür.Front-Door-Haustür-DoorbellSwitch.Programmable-Switch-Event {"val":0,"ack":true,"ts":1607251611484,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1606556352352}
      2020-12-06 11:47:13.914 - info: ham.0 (642303) stateChange ham.0.Haustür.Lock.Lock-Current-State {"val":0,"ack":true,"ts":1607251633911,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1607251633911}
      2020-12-06 11:47:13.919 - info: ham.0 (642303) stateChange ham.0.Haustür.Lock.Lock-Target-State {"val":0,"ack":true,"ts":1607251633912,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1607251633912}
      2020-12-06 11:53:00.076 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 3383771
      2020-12-06 11:53:01.504 - info: daswetter.0 (3383771) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 11:53:24.281 - info: daswetter.0 (3383771) got wrong data structure! trying to repair...
      2020-12-06 11:53:30.623 - info: daswetter.0 (3383771) Terminated (NO_ERROR): Without reason
      2020-12-06 11:53:31.151 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 12:00:01.365 - info: heatingcontrol.0 (642325) handle actors Schlafzimmer current 19.9 target 19
      2020-12-06 12:00:01.401 - info: heatingcontrol.0 (642325) 28 cron job(s) created
      2020-12-06 12:02:00.122 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 3395158
      2020-12-06 12:02:03.040 - info: daswetter.0 (3395158) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 12:02:26.817 - info: daswetter.0 (3395158) got wrong data structure! trying to repair...
      2020-12-06 12:02:32.727 - info: daswetter.0 (3395158) Terminated (NO_ERROR): Without reason
      2020-12-06 12:02:33.254 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 12:03:25.907 - warn: km200.0 (710735) Skip service data of /heatSources/numberOfStarts
      2020-12-06 12:03:25.909 - info: km200.0 (710735) Update State 11 err: TypeError: Cannot read property 'value' of undefinedat /opt/iobroker/node_modules/iobroker.km200/km200.js:556:35at runMicrotasks ()at processTicksAndRejections (internal/process/task_queues.js:97:5)
      2020-12-06 12:06:00.110 - info: host.dnkr--mgmt instance system.adapter.yr.0 started with pid 3400248
      2020-12-06 12:06:01.978 - info: yr.0 (3400248) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.yr, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 12:06:02.241 - info: yr.0 (3400248) got weather data from yr.no
      2020-12-06 12:06:09.144 - info: host.dnkr--mgmt instance system.adapter.yr.0 terminated with code 0 (NO_ERROR)
      2020-12-06 12:07:31.462 - info: ham.0 (642303) stateChange ham.0.Front-Door-Haustür.Front-Door-Haustür-Doorbell.Programmable-Switch-Event {"val":0,"ack":true,"ts":1607252851449,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1606556352329}
      2020-12-06 12:07:31.463 - info: ham.0 (642303) stateChange ham.0.Front-Door-Haustür.Front-Door-Haustür-DoorbellSwitch.Programmable-Switch-Event {"val":0,"ack":true,"ts":1607252851451,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1606556352352}
      2020-12-06 12:07:31.463 - info: ham.0 (642303) stateChange ham.0.Front-Door-Haustür.Front-Door-Haustür-Doorbell.Programmable-Switch-Event {"val":0,"ack":true,"ts":1607252851453,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1606556352329}
      2020-12-06 12:07:31.463 - info: ham.0 (642303) stateChange ham.0.Front-Door-Haustür.Front-Door-Haustür-DoorbellSwitch.Programmable-Switch-Event {"val":0,"ack":true,"ts":1607252851455,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1606556352352}
      2020-12-06 12:14:31.855 - info: fritzbox.0 (642289) data from 192.168.178.1: 06.12.20 12:14:31;RING;0;024085996183;4937439;SIP0;
      2020-12-06 12:14:39.143 - info: fritzbox.0 (642289) data from 192.168.178.1: 06.12.20 12:14:39;CONNECT;0;1;024085996183;
      2020-12-06 12:19:00.104 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 3416918
      2020-12-06 12:19:02.110 - info: daswetter.0 (3416918) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 12:19:23.321 - info: daswetter.0 (3416918) got wrong data structure! trying to repair...
      2020-12-06 12:19:29.783 - info: daswetter.0 (3416918) Terminated (NO_ERROR): Without reason
      2020-12-06 12:19:30.319 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 12:30:06.725 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for HWR
      2020-12-06 12:31:18.117 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for Kinderzimmer 1
      2020-12-06 12:36:00.069 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 3438517
      2020-12-06 12:36:02.153 - info: daswetter.0 (3438517) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 12:36:22.780 - info: daswetter.0 (3438517) got wrong data structure! trying to repair...
      2020-12-06 12:36:27.914 - info: daswetter.0 (3438517) Terminated (NO_ERROR): Without reason
      2020-12-06 12:36:28.451 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 12:53:00.133 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 3460259
      2020-12-06 12:53:03.383 - info: daswetter.0 (3460259) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 12:53:26.533 - info: daswetter.0 (3460259) got wrong data structure! trying to repair...
      2020-12-06 12:53:32.181 - info: daswetter.0 (3460259) Terminated (NO_ERROR): Without reason
      2020-12-06 12:53:32.708 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 12:58:09.248 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for HWR
      2020-12-06 13:02:00.119 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 3471646
      2020-12-06 13:02:02.274 - info: daswetter.0 (3471646) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 13:02:24.303 - info: daswetter.0 (3471646) got wrong data structure! trying to repair...
      2020-12-06 13:02:30.663 - info: daswetter.0 (3471646) Terminated (NO_ERROR): Without reason
      2020-12-06 13:02:31.191 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 13:06:00.049 - info: host.dnkr--mgmt instance system.adapter.yr.0 started with pid 3476740
      2020-12-06 13:06:03.286 - info: yr.0 (3476740) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.yr, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 13:06:03.453 - info: yr.0 (3476740) got weather data from yr.no
      2020-12-06 13:06:08.658 - info: host.dnkr--mgmt instance system.adapter.yr.0 terminated with code 0 (NO_ERROR)
      2020-12-06 13:15:53.474 - info: fritzbox.0 (642289) data from 192.168.178.1: 06.12.20 13:15:53;DISCONNECT;0;3675;
      2020-12-06 13:19:00.047 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 started with pid 3493401
      2020-12-06 13:19:02.981 - info: daswetter.0 (3493401) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.20.0, js-controller: 3.1.6
      2020-12-06 13:19:24.553 - info: daswetter.0 (3493401) got wrong data structure! trying to repair...
      2020-12-06 13:19:31.737 - info: daswetter.0 (3493401) Terminated (NO_ERROR): Without reason
      2020-12-06 13:19:32.282 - info: host.dnkr--mgmt instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2020-12-06 13:19:40.366 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for Wohnzimmer
      2020-12-06 13:28:15.523 - info: heatingcontrol.0 (642325) CheckWindowOpen4Room nothing to do for Wohnzimmer
      P Rene_HM 2 Replies Last reply Reply Quote 0
        mrMuppet @Rene_HM last edited by
        @Rene_HM Ich sehe gerade, dass das Thermostat auf Auto steht! Kann das die Ursache sein? Habe dort nach meinem Wissen keine Heizpläne hinterlegt. Aber arbeitet die Automatik dann gegen den HeatingControl-Adapter?
          Pittini Developer @mrMuppet last edited by
          @mrMuppet sagte in Test Adapter HeatingControl v1.0.x:
          Mir ist jetzt gerade keine Lösung eingefallen, wie ich das Log effizient kürze.
            mrMuppet @Pittini last edited by
            @Pittini Leider tauchen bei mir in dem Log dann nur Einträge ab 08:58 Uhr auf. Die davor finde ich für wenn ich "log herunterladen" verwende.
            • Rene_HM
              Rene_HM Developer @mrMuppet last edited by
              Es geht um den Raum Schlafzimmer
              Schau einfach mal selbst: Nach 0:00 Uhr finde ich nur einmal das log
              info: heatingcontrol.0 (642325) set thermostat hm-rpc.2.INT0000006.1.SET_POINT_TEMPERATURE to 18; current is 17
              Danach kommt es erst wieder um 5:00Uhr (aber für andere Geräte). Das heisst, der Adapter schaltet um 0:00Uhr auf 18°C, und dann macht er nichts mehr.
              Der Auto-Modus der Thermostate sollte in jedem Fall ausgeschaltet sein.
                @Rene_HM ok. Dann mache ich heute Nacht noch mal einen Testlauf Im Manu-Modus. Mal sehen was sich da tut. Ich hatte lange einen Script laufen bei dem der Modus egal war. Deshalb hab ich da gar nicht drüber nach gedacht.
                  FuXXz2 last edited by
                  wie bekomme ich denn am besten die Datenpunkte von nicht vorhandenen Fenster Sensoren weg?
                  Ich benutze die Visualisierung für den HeatingControl Adapter und es werden mir alle Räume angezeigt, auch die wo kein Sensor ist.
                  Sobald man Sensoren aktiviert, scheint jeder Raum den Datenpunkt zu bekommen, egal ob er Sensoren hat oder nicht.
                  • Rene_HM
                    Rene_HM Developer @FuXXz2 last edited by
                    @FuXXz2 das habe ich bereits auf der todo-Liste für die 2.x...
                      FuXXz2 @Rene_HM last edited by
                      @Rene_HM Super, Danke
                        jeti @FuXXz2 last edited by
                        ich nutze den Adapter mit Z-Wave Eurotronic Spirit Thermostaten. Soweit klappt alles, nur will ich beim Fenster öffnen den Heizungsmode auf "off" stellen und bei Fenster wieder zu wieder auf "Heizen" (Die Thermostate können nur bis 8C herunter geregelt werden). Gibt es hierzu im Adapter die Möglichkeit, sonst bleibt nur der Umweg über ein Skript.
                        Danke und Gruß
                        • Rene_HM
                          Rene_HM Developer @jeti last edited by
                          @jeti Der Adapter kann nur die Soll-Temperatur reduzieren. 8°C Soll-Temperatur sollte doch ausreichen, dass das Ventil schliesst, oder?
                          J O 2 Replies Last reply Reply Quote 0
                            jeti @Rene_HM last edited by
                            @Rene_HM ich gebe dir in 90% der Fällen recht, dann baue ich mir mal ein Notfall skript dazu, danke für die Antwort!
                            • da_Woody
                              da_Woody @jeti last edited by
                              @jeti geht mich zwar nichts an, aber bei 8° raumtemperatur rollt sich ja schon die farbe von den wänden... das ist ja schon frostschutz temp...
                                jeti @da_Woody last edited by
                                @da_Woody wir schlafen auch jetzt mit offenem Fenster, daher meine Bedenken. Ich Beobachte mal die Temperatur, ich Logge erst seit kurzem mit daher habe ich auch keine Erfahrungswerte...
                                • O
                                  Oli @Rene_HM last edited by
                                  @Rene_HM
                                  ich habe mir heute die neuste Version deines Adapter, sowie die neuste Version der Vis gezogen.
                                  Es werden 3 Profile verwendet, die laut Datenpunkt für die Vis mit 1;2;3 deklariert sind und auch so in den entsprechenden Datenpunkt für das aktuelle Profil geschrieben werden.
                                  In der Vis Anzeige werden aber die Datenpunkte nicht richtig angezeigt, bei der Auswahl von Profil 1 wird Profil 1, statt 0 angezeigt und bei Profil 3 bringt er folgende Fehler im Log:
                                  heatingcontrol.0	2020-12-10 15:09:29.004	error	(2793) vis: error: for Profiles.3.Wohnzimmer.absolute.WindowOpenDecrease got null
                                  heatingcontrol.0	2020-12-10 15:09:28.921	error	(2793) vis: error: for Profiles.3.Wohnzimmer.absolute.VacationAbsentDecrease got null
                                  heatingcontrol.0	2020-12-10 15:09:28.835	error	(2793) vis: error: for Profiles.3.Wohnzimmer.absolute.PartyDecrease got null
                                  heatingcontrol.0	2020-12-10 15:09:28.748	error	(2793) vis: error: for Profiles.3.Wohnzimmer.absolute.GuestIncrease got null
                                  heatingcontrol.0	2020-12-10 15:09:28.665	error	(2793) vis: error: for Profiles.3.Wohnzimmer.absolute.AbsentDecrease got null
                                  heatingcontrol.0	2020-12-10 15:09:28.580	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Sun.Periods.4.time got null
                                  heatingcontrol.0	2020-12-10 15:09:28.497	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Sun.Periods.4.Temperature got null
                                  heatingcontrol.0	2020-12-10 15:09:28.412	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Sat.Periods.4.time got null
                                  heatingcontrol.0	2020-12-10 15:09:28.329	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Sat.Periods.4.Temperature got null
                                  heatingcontrol.0	2020-12-10 15:09:28.246	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Fri.Periods.4.time got null
                                  heatingcontrol.0	2020-12-10 15:09:28.158	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Fri.Periods.4.Temperature got null
                                  heatingcontrol.0	2020-12-10 15:09:28.075	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Thu.Periods.4.time got null
                                  heatingcontrol.0	2020-12-10 15:09:27.988	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Thu.Periods.4.Temperature got null
                                  heatingcontrol.0	2020-12-10 15:09:27.903	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Wed.Periods.4.time got null
                                  heatingcontrol.0	2020-12-10 15:09:27.818	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Wed.Periods.4.Temperature got null
                                  heatingcontrol.0	2020-12-10 15:09:27.728	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Tue.Periods.4.time got null
                                  heatingcontrol.0	2020-12-10 15:09:27.637	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Tue.Periods.4.Temperature got null
                                  heatingcontrol.0	2020-12-10 15:09:27.545	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Mon.Periods.4.time got null
                                  heatingcontrol.0	2020-12-10 15:09:27.460	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Mon.Periods.4.Temperature got null
                                  heatingcontrol.0	2020-12-10 15:09:27.376	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Sun.Periods.3.time got null
                                  heatingcontrol.0	2020-12-10 15:09:27.291	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Sun.Periods.3.Temperature got null
                                  heatingcontrol.0	2020-12-10 15:09:27.248	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Sat.Periods.3.time got null
                                  heatingcontrol.0	2020-12-10 15:09:27.157	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Sat.Periods.3.Temperature got null
                                  heatingcontrol.0	2020-12-10 15:09:27.072	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Fri.Periods.3.time got null
                                  heatingcontrol.0	2020-12-10 15:09:26.988	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Fri.Periods.3.Temperature got null
                                  heatingcontrol.0	2020-12-10 15:09:26.905	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Thu.Periods.3.time got null
                                  heatingcontrol.0	2020-12-10 15:09:26.822	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Thu.Periods.3.Temperature got null
                                  heatingcontrol.0	2020-12-10 15:09:26.738	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Wed.Periods.3.time got null
                                  heatingcontrol.0	2020-12-10 15:09:26.654	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Wed.Periods.3.Temperature got null
                                  heatingcontrol.0	2020-12-10 15:09:26.566	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Tue.Periods.3.time got null
                                  heatingcontrol.0	2020-12-10 15:09:26.482	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Tue.Periods.3.Temperature got null
                                  heatingcontrol.0	2020-12-10 15:09:26.398	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Mon.Periods.3.time got null
                                  heatingcontrol.0	2020-12-10 15:09:26.312	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Mon.Periods.3.Temperature got null
                                  heatingcontrol.0	2020-12-10 15:09:26.224	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Sun.Periods.2.time got null
                                  heatingcontrol.0	2020-12-10 15:09:26.140	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Sun.Periods.2.Temperature got null
                                  heatingcontrol.0	2020-12-10 15:09:26.057	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Sat.Periods.2.time got null
                                  heatingcontrol.0	2020-12-10 15:09:25.960	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Sat.Periods.2.Temperature got null
                                  heatingcontrol.0	2020-12-10 15:09:25.876	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Fri.Periods.2.time got null
                                  heatingcontrol.0	2020-12-10 15:09:25.792	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Fri.Periods.2.Temperature got null
                                  heatingcontrol.0	2020-12-10 15:09:25.707	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Thu.Periods.2.time got null
                                  heatingcontrol.0	2020-12-10 15:09:25.621	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Thu.Periods.2.Temperature got null
                                  heatingcontrol.0	2020-12-10 15:09:25.536	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Wed.Periods.2.time got null
                                  heatingcontrol.0	2020-12-10 15:09:25.453	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Wed.Periods.2.Temperature got null
                                  heatingcontrol.0	2020-12-10 15:09:25.369	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Tue.Periods.2.time got null
                                  heatingcontrol.0	2020-12-10 15:09:25.286	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Tue.Periods.2.Temperature got null
                                  heatingcontrol.0	2020-12-10 15:09:25.202	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Mon.Periods.2.time got null
                                  heatingcontrol.0	2020-12-10 15:09:25.116	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Mon.Periods.2.Temperature got null
                                  heatingcontrol.0	2020-12-10 15:09:25.031	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Sun.Periods.1.time got null
                                  heatingcontrol.0	2020-12-10 15:09:24.947	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Sun.Periods.1.Temperature got null
                                  heatingcontrol.0	2020-12-10 15:09:24.862	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Sat.Periods.1.time got null
                                  heatingcontrol.0	2020-12-10 15:09:24.748	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Sat.Periods.1.Temperature got null
                                  heatingcontrol.0	2020-12-10 15:09:24.662	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Fri.Periods.1.time got null
                                  heatingcontrol.0	2020-12-10 15:09:24.557	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Fri.Periods.1.Temperature got null
                                  heatingcontrol.0	2020-12-10 15:09:24.473	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Thu.Periods.1.time got null
                                  heatingcontrol.0	2020-12-10 15:09:24.372	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Thu.Periods.1.Temperature got null
                                  heatingcontrol.0	2020-12-10 15:09:24.287	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Wed.Periods.1.time got null
                                  heatingcontrol.0	2020-12-10 15:09:24.181	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Wed.Periods.1.Temperature got null
                                  heatingcontrol.0	2020-12-10 15:09:24.097	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Tue.Periods.1.time got null
                                  heatingcontrol.0	2020-12-10 15:09:24.014	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Tue.Periods.1.Temperature got null
                                  heatingcontrol.0	2020-12-10 15:09:23.928	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Mon.Periods.1.time got null
                                  heatingcontrol.0	2020-12-10 15:09:23.843	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Mon.Periods.1.Temperature got null
                                  heatingcontrol.0	2020-12-10 15:09:23.759	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Sun.Periods.0.time got null
                                  heatingcontrol.0	2020-12-10 15:09:23.675	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Sun.Periods.0.Temperature got null
                                  heatingcontrol.0	2020-12-10 15:09:23.591	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Sat.Periods.0.time got null
                                  heatingcontrol.0	2020-12-10 15:09:23.507	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Sat.Periods.0.Temperature got null
                                  heatingcontrol.0	2020-12-10 15:09:23.422	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Fri.Periods.0.time got null
                                  heatingcontrol.0	2020-12-10 15:09:23.338	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Fri.Periods.0.Temperature got null
                                  heatingcontrol.0	2020-12-10 15:09:23.252	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Thu.Periods.0.time got null
                                  heatingcontrol.0	2020-12-10 15:09:23.168	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Thu.Periods.0.Temperature got null
                                  heatingcontrol.0	2020-12-10 15:09:23.075	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Wed.Periods.0.time got null
                                  heatingcontrol.0	2020-12-10 15:09:22.989	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Wed.Periods.0.Temperature got null
                                  heatingcontrol.0	2020-12-10 15:09:22.901	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Tue.Periods.0.time got null
                                  heatingcontrol.0	2020-12-10 15:09:22.796	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Tue.Periods.0.Temperature got null
                                  heatingcontrol.0	2020-12-10 15:09:22.710	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Mon.Periods.0.time got null
                                  heatingcontrol.0	2020-12-10 15:09:22.624	error	(2793) vis: error: for Profiles.3.Wohnzimmer.Mon.Periods.0.Temperature got null
                                    Jetzt gerade hebt der Adapter völlig ab, merke das gerade weil es so kalt wird 🙂
                                    1. Das log wird ständig geflutet mit, das ist nur ein Auszug, das habe ich Seitenweise.
                                    heatingcontrol.0	2020-12-14 03:31:16.631	warn	(6889) more then 500 cron jobs existing for this adapter, this might be a configuration error! (754)
                                    heatingcontrol.0	2020-12-14 03:31:16.073	warn	(6889) more then 500 cron jobs existing for this adapter, this might be a configuration error! (741)
                                    heatingcontrol.0	2020-12-14 03:31:15.516	warn	(6889) more then 500 cron jobs existing for this adapter, this might be a configuration error! (728)
                                    heatingcontrol.0	2020-12-14 03:31:14.973	warn	(6889) more then 500 cron jobs existing for this adapter, this might be a configuration error! (715)
                                    heatingcontrol.0	2020-12-14 03:31:14.438	warn	(6889) more then 500 cron jobs existing for this adapter, this might be a configuration error! (702)
                                    heatingcontrol.0	2020-12-14 03:31:13.766	warn	(6889) more then 500 cron jobs existing for this adapter, this might be a configuration error! (689)
                                    heatingcontrol.0	2020-12-14 03:31:13.201	warn	(6889) more then 500 cron jobs existing for this adapter, this might be a configuration error! (676)
                                    heatingcontrol.0	2020-12-14 03:31:12.674	warn	(6889) more then 500 cron jobs existing for this adapter, this might be a configuration error! (663)
                                    heatingcontrol.0	2020-12-14 03:31:12.155	warn	(6889) more then 500 cron jobs existing for this adapter, this might be a configuration error! (650)
                                    heatingcontrol.0	2020-12-14 03:31:11.661	warn	(6889) more then 500 cron jobs existing for this adapter, this might be a configuration error! (637)
                                    heatingcontrol.0	2020-12-14 03:31:11.187	warn	(6889) more then 500 cron jobs existing for this adapter, this might be a configuration error! (624)
                                    heatingcontrol.0	2020-12-14 03:31:10.726	warn	(6889) more then 500 cron jobs existing for this adapter, this might be a configuration error! (611)
                                    heatingcontrol.0	2020-12-14 03:31:10.271	warn	(6889) more then 500 cron jobs existing for this adapter, this might be a configuration error! (598)
                                    heatingcontrol.0	2020-12-14 03:31:09.818	warn	(6889) more then 500 cron jobs existing for this adapter, this might be a configuration error! (585)
                                    heatingcontrol.0	2020-12-14 03:31:09.367	warn	(6889) more then 500 cron jobs existing for this adapter, this might be a configuration error! (572)
                                    heatingcontrol.0	2020-12-14 03:31:08.918	warn	(6889) more then 500 cron jobs existing for this adapter, this might be a configuration error! (559)
                                    heatingcontrol.0	2020-12-14 03:31:08.481	warn	(6889) more then 500 cron jobs existing for this adapter, this might be a configuration error! (546)
                                    heatingcontrol.0	2020-12-14 03:31:08.058	warn	(6889) more then 500 cron jobs existing for this adapter, this might be a configuration error! (533)
                                    heatingcontrol.0	2020-12-14 03:31:07.648	warn	(6889) more then 500 cron jobs existing for this adapter, this might be a configuration error! (520)
                                    heatingcontrol.0	2020-12-14 03:31:07.245	warn	(6889) more then 500 cron jobs existing for this adapter, this might be a configuration error! (507)
                                    Dann geht es im Sekundentakt hiermit weiter
                                    heatingcontrol.0	2020-12-14 03:58:58.257	info	(1479) handle actors Büro current 19.2 target 18
                                    heatingcontrol.0	2020-12-14 03:58:58.256	info	(1479) handle actors Büro current 19.2 target 18
                                    heatingcontrol.0	2020-12-14 03:58:58.256	info	(1479) handle actors Ankleide current 18.5 target 12
                                    heatingcontrol.0	2020-12-14 03:58:58.255	info	(1479) handle actors Ankleide current 18.5 target 12
                                    heatingcontrol.0	2020-12-14 03:58:58.254	info	(1479) handle actors Ankleide current 18.5 target 12
                                    heatingcontrol.0	2020-12-14 03:58:58.253	info	(1479) handle actors Schlafzimmer current 18.3 target 18
                                    heatingcontrol.0	2020-12-14 03:58:58.252	info	(1479) handle actors Büro current 19.2 target 18
                                    heatingcontrol.0	2020-12-14 03:58:58.193	info	(1479) 168 cron job(s) created
                                    heatingcontrol.0	2020-12-14 03:58:57.985	info	(1479) 154 cron job(s) created
                                    heatingcontrol.0	2020-12-14 03:58:57.820	info	(1479) 140 cron job(s) created
                                    heatingcontrol.0	2020-12-14 03:58:57.673	info	(1479) 126 cron job(s) created
                                    heatingcontrol.0	2020-12-14 03:58:57.543	info	(1479) 112 cron job(s) created
                                    heatingcontrol.0	2020-12-14 03:58:57.415	info	(1479) 98 cron job(s) created
                                    heatingcontrol.0	2020-12-14 03:58:57.306	info	(1479) 84 cron job(s) created
                                    heatingcontrol.0	2020-12-14 03:58:57.205	info	(1479) 70 cron job(s) created
                                    heatingcontrol.0	2020-12-14 03:58:57.109	info	(1479) 56 cron job(s) created
                                    heatingcontrol.0	2020-12-14 03:58:57.028	info	(1479) 42 cron job(s) created
                                    heatingcontrol.0	2020-12-14 03:58:56.960	info	(1479) 28 cron job(s) created
                                    heatingcontrol.0	2020-12-14 03:58:56.901	info	(1479) 14 cron job(s) created
                                    heatingcontrol.0	2020-12-14 03:58:56.817	info	(1479) change temperature override for room Büro
                                    heatingcontrol.0	2020-12-14 03:58:56.816	info	(1479) change temperature override for room Büro
                                    heatingcontrol.0	2020-12-14 03:58:56.815	info	(1479) change temperature override for room Büro
                                    heatingcontrol.0	2020-12-14 03:58:56.609	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:56.194	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:55.771	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:55.361	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:54.797	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:54.297	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:53.850	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:53.441	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:53.030	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:52.614	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:52.207	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:51.792	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:51.361	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:50.943	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:50.532	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:50.077	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:49.644	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:49.231	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:48.819	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:48.392	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:47.943	info	(1479) handle actors Esszimmer current 18.9 target 18
                                    heatingcontrol.0	2020-12-14 03:58:47.942	info	(1479) handle actors Esszimmer current 18.9 target 18
                                    heatingcontrol.0	2020-12-14 03:58:47.941	info	(1479) handle actors Esszimmer current 18.9 target 18
                                    heatingcontrol.0	2020-12-14 03:58:47.918	info	(1479) handle actors Wohnzimmer current 19.9 target 18
                                    heatingcontrol.0	2020-12-14 03:58:47.917	info	(1479) handle actors Wohnzimmer current 19.9 target 18
                                    heatingcontrol.0	2020-12-14 03:58:47.917	info	(1479) handle actors Diele current 17.6 target 12
                                    heatingcontrol.0	2020-12-14 03:58:47.916	info	(1479) handle actors Diele current 17.6 target 12
                                    heatingcontrol.0	2020-12-14 03:58:47.915	info	(1479) handle actors Diele current 17.6 target 12
                                    heatingcontrol.0	2020-12-14 03:58:47.915	info	(1479) handle actors Gästezimmer current 22.1 target 19
                                    heatingcontrol.0	2020-12-14 03:58:47.914	info	(1479) handle actors Gästezimmer current 22.1 target 19
                                    heatingcontrol.0	2020-12-14 03:58:47.913	info	(1479) handle actors Gästezimmer current 22.1 target 19
                                    heatingcontrol.0	2020-12-14 03:58:47.913	info	(1479) handle actors Ankleide current 18.5 target 12
                                    heatingcontrol.0	2020-12-14 03:58:47.912	info	(1479) handle actors Ankleide current 18.5 target 12
                                    heatingcontrol.0	2020-12-14 03:58:47.912	info	(1479) handle actors Büro current 19.2 target 18
                                    heatingcontrol.0	2020-12-14 03:58:47.911	info	(1479) handle actors Büro current 19.2 target 18
                                    heatingcontrol.0	2020-12-14 03:58:47.911	info	(1479) handle actors Wohnzimmer current 19.9 target 18
                                    heatingcontrol.0	2020-12-14 03:58:47.910	info	(1479) handle actors Wohnzimmer current 19.9 target 18
                                    heatingcontrol.0	2020-12-14 03:58:47.909	info	(1479) handle actors Wohnzimmer current 19.9 target 18
                                    heatingcontrol.0	2020-12-14 03:58:47.885	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:47.483	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:47.079	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:46.656	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:46.252	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:45.835	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:45.412	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:45.002	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:44.587	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:44.182	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:43.754	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:43.345	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:42.928	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:42.522	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:42.088	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:41.675	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:41.272	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:40.861	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:40.440	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:40.024	warn	(1479) more then 500 cron jobs existing for this adapter, this might be a configuration error! (560)
                                    heatingcontrol.0	2020-12-14 03:58:39.481	info	(1479) handle actors Wohnzimmer current 19.9 target 18
                                    heatingcontrol.0	2020-12-14 03:58:39.475	info	(1479) handle actors Wohnzimmer current 19.9 target 18
                                    heatingcontrol.0	2020-12-14 03:58:39.471	info	(1479) handle actors Wohnzimmer current 19.9 target 18
                                    heatingcontrol.0	2020-12-14 03:58:39.471	info	(1479) handle actors Diele current 17.6 target 12
                                    heatingcontrol.0	2020-12-14 03:58:39.469	info	(1479) handle actors Diele current 17.6 target 12
                                    heatingcontrol.0	2020-12-14 03:58:39.468	info	(1479) handle actors Diele current 17.6 target 12
                                    heatingcontrol.0	2020-12-14 03:58:39.468	info	(1479) handle actors Schlafzimmer current 18.3 target 18
                                    heatingcontrol.0	2020-12-14 03:58:39.457	info	(1479) handle actors Schlafzimmer current 18.3 target 18
                                    heatingcontrol.0	2020-12-14 03:58:39.417	info	(1479) handle actors Schlafzimmer current 18.3 target 18
                                    heatingcontrol.0	2020-12-14 03:58:39.416	info	(1479) handle actors Schlafzimmer current 18.3 target 18
                                    heatingcontrol.0	2020-12-14 03:58:39.414	info	(1479) handle actors Schlafzimmer current 18.3 target 18
                                    heatingcontrol.0	2020-12-14 03:58:39.413	info	(1479) handle actors Schlafzimmer current 18.3 target 18
                                    heatingcontrol.0	2020-12-14 03:58:39.412	info	(1479) handle actors Schlafzimmer current 18.3 target 18
                                    heatingcontrol.0	2020-12-14 03:58:39.408	info	(1479) handle actors Schlafzimmer current 18.3 target 18
                                    heatingcontrol.0	2020-12-14 03:58:39.408	info	(1479) handle actors Diele current 17.6 target 12
                                    heatingcontrol.0	2020-12-14 03:58:39.407	info	(1479) handle actors Diele current 17.6 target 12
                                    heatingcontrol.0	2020-12-14 03:58:39.406	info	(1479) handle actors Büro current 19.2 target 18
                                    heatingcontrol.0	2020-12-14 03:58:39.404	info	(1479) handle actors Büro current 19.2 target 18
                                    heatingcontrol.0	2020-12-14 03:58:39.403	info	(1479) handle actors Wohnzimmer current 19.9 target 18
                                    heatingcontrol.0	2020-12-14 03:58:39.400	info	(1479) handle actors Wohnzimmer current 19.9 target 18
                                    heatingcontrol.0	2020-12-14 03:58:39.038	info	(1479) handle actors Wohnzimmer current 19.9 target 18
                                    heatingcontrol.0	2020-12-14 03:58:39.038	info	(1479) handle actors Gästezimmer current 22.1 target 19
                                    heatingcontrol.0	2020-12-14 03:58:39.037	info	(1479) handle actors Gästezimmer current 22.1 target 19
                                    heatingcontrol.0	2020-12-14 03:58:39.036	info	(1479) handle actors Gästezimmer current 22.1 target 19
                                    heatingcontrol.0	2020-12-14 03:58:39.035	info	(1479) handle actors Ankleide current 18.5 target 12
                                    heatingcontrol.0	2020-12-14 03:58:39.034	info	(1479) handle actors Ankleide current 18.5 target 12
                                    heatingcontrol.0	2020-12-14 03:58:39.028	info	(1479) handle actors Ankleide current 18.5 target 12
                                    heatingcontrol.0	2020-12-14 03:58:39.027	info	(1479) handle actors Ankleide current 18.5 target 12
                                    heatingcontrol.0	2020-12-14 03:58:39.027	info	(1479) handle actors Schlafzimmer current 18.3 target 18
                                    heatingcontrol.0	2020-12-14 03:58:39.027	info	(1479) handle actors Wohnzimmer current 19.9 target 18
                                    heatingcontrol.0	2020-12-14 03:58:39.026	info	(1479) handle actors Wohnzimmer current 19.9 target 18
                                    heatingcontrol.0	2020-12-14 03:58:39.026	info	(1479) handle actors Esszimmer current 18.9 target 18
                                    heatingcontrol.0	2020-12-14 03:58:39.025	info	(1479) handle actors Esszimmer current 18.9 target 18
                                    heatingcontrol.0	2020-12-14 03:58:39.024	info	(1479) handle actors Esszimmer current 18.9 target 18
                                    heatingcontrol.0	2020-12-14 03:58:39.023	info	(1479) handle actors Esszimmer current 18.9 target 18
                                    Zwischendrin dann immer
                                    heatingcontrol.0	2020-12-14 03:31:33.074	warn	(6889) override temperature not valid: 0
                                    heatingcontrol.0	2020-12-14 03:31:33.073	warn	(6889) override temperature not valid: 0
                                    v522533 1 Reply Last reply Reply Quote 0
                                    • v522533
                                      v522533 @FuXXz2 last edited by
                                      @FuXXz2
                                      das hatten wir bei meinem Vater auch. Haben dann den Adapter neu installiert, dann gings wieder. Keine Ahnung woran das liegt
                                      • Rene_HM
                                        Rene_HM Developer last edited by
                                        @FuXXz2 sagte in Test Adapter HeatingControl v1.0.x:
                                        Das ist bekannt. Wenn man Profilwerte zu schnell nacheinander ändert, kommt das zu diesem Problem mit den unendlichen cron jobs... (dazu gab es auch ein github issue). In der 2.x habe ich das Verhalten diesbezüglich komplett geändert...
                                        Im Moment hilft hier nur ein restart vom Adapter und schön langsam die Profilwerte ändern...
                                        MichMein 1 Reply Last reply Reply Quote 1
                                        • MichMein
                                          MichMein @Rene_HM last edited by
                                          @Rene_HM sagte in Test Adapter HeatingControl v1.0.x:
                                          ... In der 2.x habe ich das ...
                                          Gibt es für 2.x schon einen Termin, oder kommt sie etwa pünktlich mit dem Christkind 😇
                                          • Rene_HM
                                            Rene_HM Developer @MichMein last edited by
                                            @MichMein mal schauen, ob ich das noch im Dezember schaffe... habe noch ein paar offene Baustellen...
                                            MichMein 1 Reply Last reply Reply Quote 0
                                            heating
                                            236
                                            3158
                                            1946563
