    3. Entwicklung
    4. ZigBee neue Version 1.4.0
      arteck Developer Most Active @Slowman last edited by arteck
      @Slowman lern den nochmal an ohne den zu löschen..
      wobei ES GIBT PROBLEME mit den BWM im z2m projekt..
      Slowman 1 Reply Last reply Reply Quote 0
        DocGame @Asgothian last edited by DocGame
        @Asgothian Hier der Log:
        Cannot compare "" and "1.3.2" admin.js:153
        Cannot compare "" and "0.2.15" admin.js:153
        Uncaught TypeError: d.groups.map is not a function
            showDevices http://192.168.178.51:8081/adapter/zigbee/admin.js:352
            getDevices http://192.168.178.51:8081/adapter/zigbee/admin.js:498
            onack http://192.168.178.51:8081/socket.io/socket.io.js:8
            onpacket http://192.168.178.51:8081/socket.io/socket.io.js:8
            exports http://192.168.178.51:8081/socket.io/socket.io.js:8
            emit http://192.168.178.51:8081/socket.io/socket.io.js:6
            ondecoded http://192.168.178.51:8081/socket.io/socket.io.js:6
            add http://192.168.178.51:8081/socket.io/socket.io.js:6
            ondata http://192.168.178.51:8081/socket.io/socket.io.js:6
            onPacket http://192.168.178.51:8081/socket.io/socket.io.js:7
            setTransport http://192.168.178.51:8081/socket.io/socket.io.js:7
            onData http://192.168.178.51:8081/socket.io/socket.io.js:7
            onmessage http://192.168.178.51:8081/socket.io/socket.io.js:8
        admin.js:352:41
        Und hier ein kurzer Auszug aus dem iobrokerlog:
        zigbee.0	2020-12-10 10:11:55.272	debug	(5674) Failed to execute LQI for '0x84182600000e47bf'. "Error: AREQ - ZDO - mgmtLqiRsp after 10000ms\n at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:46:35
        zigbee.0	2020-12-10 10:11:50.338	debug	(5674) system.adapter.admin.0: logging true
        zigbee.0	2020-12-10 10:11:45.256	debug	(5674) Routing table succeeded for '0x7cb03eaa0a07b6c8'
        zigbee.0	2020-12-10 10:11:45.256	debug	(5674) Routing for '0x7cb03eaa0a07b6c8': {"neighbors":[{"linkquality":50,"networkAddress":41629,"ieeeAddr":"0x7cb03eaa0a04cfa1","relationship":2,"depth":1},{"linkquality":58,"networkAddress":21257,"i
        zigbee.0	2020-12-10 10:11:45.256	debug	(5674) Failed to execute routing table for '0x7cb03eaa0a07b6c8'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitre
        zigbee.0	2020-12-10 10:11:35.240	debug	(5674) LQI succeeded for '0x7cb03eaa0a07b6c8'
        zigbee.0	2020-12-10 10:11:34.732	debug	(5674) Routing table succeeded for '0x7cb03eaa0a050960'
        zigbee.0	2020-12-10 10:11:34.732	debug	(5674) Routing for '0x7cb03eaa0a050960': {"neighbors":[{"linkquality":40,"networkAddress":6075,"ieeeAddr":"0x00124b001e7328ee","relationship":2,"depth":2},{"linkquality":84,"networkAddress":35223,"ie
        zigbee.0	2020-12-10 10:11:34.732	debug	(5674) Failed to execute routing table for '0x7cb03eaa0a050960'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitre
        zigbee.0	2020-12-10 10:11:24.717	debug	(5674) LQI succeeded for '0x7cb03eaa0a050960'
        zigbee.0	2020-12-10 10:11:24.257	debug	(5674) Routing table succeeded for '0x7cb03eaa0a04cfa1'
        zigbee.0	2020-12-10 10:11:24.256	debug	(5674) Routing for '0x7cb03eaa0a04cfa1': {"neighbors":[{"linkquality":36,"networkAddress":0,"ieeeAddr":"0x00124b001ca60d31","relationship":2,"depth":1},{"linkquality":162,"networkAddress":26902,"ieee
        zigbee.0	2020-12-10 10:11:24.256	debug	(5674) Failed to execute routing table for '0x7cb03eaa0a04cfa1'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitre
        zigbee.0	2020-12-10 10:11:14.241	debug	(5674) LQI succeeded for '0x7cb03eaa0a04cfa1'
        zigbee.0	2020-12-10 10:11:13.900	debug	(5674) No converter available for 'AB3257001NJ' with cluster 'genOta' and type 'commandQueryNextImageRequest'
        zigbee.0	2020-12-10 10:11:13.899	debug	(5674) Type commandQueryNextImageRequest device {"type":"device","device":{"ID":23,"_type":"Router","_ieeeAddr":"0x7cb03eaa00acad07","_networkAddress":65510,"_manufacturerID":48042,"_endpoints":[{"ID
        zigbee.0	2020-12-10 10:11:13.899	debug	(5674) Received Zigbee message from '0x7cb03eaa00acad07', type 'commandQueryNextImageRequest', cluster 'genOta', data '{"fieldControl":0,"manufacturerCode":4364,"imageType":39,"fileVersion":16909577}
        zigbee.0	2020-12-10 10:11:13.899	debug	(5674) handleMessage. {"type":"commandQueryNextImageRequest","device":{"ID":23,"_type":"Router","_ieeeAddr":"0x7cb03eaa00acad07","_networkAddress":65510,"_manufacturerID":48042,"_endpoints":[{"ID":3,
        zigbee.0	2020-12-10 10:11:13.777	debug	(5674) Routing table succeeded for '0x7cb03eaa00ad0e31'
        zigbee.0	2020-12-10 10:11:13.777	debug	(5674) Routing for '0x7cb03eaa00ad0e31': {"neighbors":[{"linkquality":18,"networkAddress":52961,"ieeeAddr":"0x7cb03eaa0a07b6c8","relationship":2,"depth":2},{"linkquality":80,"networkAddress":26902,"i
        zigbee.0	2020-12-10 10:11:13.777	debug	(5674) Failed to execute routing table for '0x7cb03eaa00ad0e31'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitre
        zigbee.0	2020-12-10 10:11:03.761	debug	(5674) LQI succeeded for '0x7cb03eaa00ad0e31'
        zigbee.0	2020-12-10 10:11:03.385	debug	(5674) Routing table succeeded for '0x7cb03eaa0a07cf0e'
        zigbee.0	2020-12-10 10:11:03.385	debug	(5674) Routing for '0x7cb03eaa0a07cf0e': {"neighbors":[{"linkquality":26,"networkAddress":6075,"ieeeAddr":"0x00124b001e7328ee","relationship":2,"depth":1},{"linkquality":46,"networkAddress":5778,"iee
        zigbee.0	2020-12-10 10:11:03.385	debug	(5674) Failed to execute routing table for '0x7cb03eaa0a07cf0e'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitre
        zigbee.0	2020-12-10 10:10:53.368	debug	(5674) LQI succeeded for '0x7cb03eaa0a07cf0e'
        zigbee.0	2020-12-10 10:10:53.064	debug	(5674) Routing table succeeded for '0x84182600000e434f'
        zigbee.0	2020-12-10 10:10:53.064	debug	(5674) Routing for '0x84182600000e434f': {"neighbors":[{"linkquality":66,"networkAddress":20576,"ieeeAddr":"0x04cf8cdf3c794714","relationship":1,"depth":1},{"linkquality":90,"networkAddress":14442,"i
        zigbee.0	2020-12-10 10:10:53.064	debug	(5674) Failed to execute routing table for '0x84182600000e434f'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitre
        zigbee.0	2020-12-10 10:10:44.795	debug	(5674) system.adapter.admin.0: logging false
        zigbee.0	2020-12-10 10:10:43.048	debug	(5674) LQI succeeded for '0x84182600000e434f'
        zigbee.0	2020-12-10 10:10:42.609	debug	(5674) Routing table succeeded for 'Coordinator'
        zigbee.0	2020-12-10 10:10:42.609	debug	(5674) Routing for 'Coordinator': {"table":[{"destinationAddress":7044,"status":"DISCOVERY_FAILED","nextHop":65534},{"destinationAddress":58390,"status":"DISCOVERY_FAILED","nextHop":65534},{"destinat
        zigbee.0	2020-12-10 10:10:42.591	debug	(5674) LQI succeeded for 'Coordinator'
        zigbee.0	2020-12-10 10:10:42.519	debug	(5674) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
        arteck Asgothian 2 Replies Last reply Reply Quote 0
          arteck Developer Most Active @DocGame last edited by
          @DocGame hast du irgenwas aus dem Netz genommen.. also Router die nicht am Strom hängen. Lampen die aus sind per Schalter
          • Slowman
            Slowman @arteck last edited by
            @arteck
            Mit dem mehrmaligen Anlernen hat es zum Erfolg geführt. Der 1. BWM gleich beim 1x und der 2. BWM wollte erst beim 3x. Aber es funktioniert erst Mal.
            • Asgothian
              Asgothian Developer @DocGame last edited by
              @DocGame ok, damit kann ich nachschauen wo es hängt und einen Patch einhängen das nur noch die betroffene Kachel nicht geht.
              A.
                DocGame @arteck last edited by
                @arteck @Asgothian
                Da ich ja in beiden Ansichten im Moment nichts sehe habe ich die Available-States ca.20 Stromgebundenen (Repeater) Geräte angeschaut. Diese sind alle True.
                • Asgothian
                  @DocGame Installier mal bitte von meinem Github Repository. Wenn das der Fehler war sollte er behoben sein, dann mach ich nen PR auf den Hauptzweig
                  (https://github.com/asgothian/ioBroker.zigbee)
                  A.
                    @Asgothian Das sieht doch mal gut aus (Was immer auch die Ursache war....) 👍 😊 Danke nochmals
                    • MathiasJ
                      MathiasJ last edited by
                      Muß mich auch zu Wort melden.
                      Ich habe die Zigbee-Steckdosen von Osram zu Hause.
                      Nach 5 Minuten sind zwei nicht mehr erreichbar. Wenn ich die Instanz neu starte, sind alle wieder da, aber nur für 5 Minuten.
                      Im Log sehe ich da leider nicht viel, nur daß ein timeout-error kommt, wenn sich nach 10000ms nichts tut.
                      Hat jemand eine Idee?
                      • Slowman
                        Slowman @MathiasJ last edited by
                        @MathiasJ
                        Versuche mal bitte das was mir @arteck bei meinen BWM geraten hatte. Lerne die Dosen nochmal an ohne vorher diese zu löschen. Meine Osram Dosen funktionieren mit der 1.4.0 wunderbar.
                          dondaik @Slowman last edited by
                          ok, trotz neu anlernen reagieren meine test-lidl-steckdosen ähnlich .... nicht mal das nicht mehr vorhandensein einer steckdose wird erkannt oder ortsveränderungen einer steckdose ... das gilt auch für das schalten der steckdose per hand ... 😞 .. ok, man könnte sagen lidl halt 🙂 ... doch in den nächsten tagen rollen 4 osram steckdosen an, dann wird man sehen.
                          doch für heute: gute nacht.
                          • V
                            vikk88 @dondaik last edited by
                            @dondaik falls du noch nach einer Alternative suchst
                            [10,73€ 24% OFF]BlitzWolf® BW-SHP13 ZigBee 3.0 Smart WIFI-Buchse 16A EU-Stecker Strommessung APP Fernbedienung Timer Arbeiten Sie mit Amazon Alexa Google Home Intelligentes Zuhause from Unterhaltungselektronik on banggood
                            https://banggood.app.link/KE9t4zcC7bb
                            Die habe ich im Einsatz. Laufen bei mir seit Monaten stabil. Sind kleiner als die osram und haben Strommessung integriert. Ich habe sie für nen 10 bei Ali bekommen, sind dort aber momentan nicht verfügbar.
                            H S 2 Replies Last reply Reply Quote 1
                              hukio @vikk88 last edited by
                              @vikk88 said in ZigBee neue Version 1.4.0:
                              kann ich nur bestätigen. Sind stabiler als OSRAM. Über banggood billig und schnell zu bekommen.
                                el_malto last edited by
                                Ich kann meine TRADFRI bulb E27 CWS opal 600lm nicht mehr dimmen. An aus geht normal. Aber wenn ich brightness ändere passiert nichts.
                                Log:
                                zigbee.0	2020-12-11 19:04:53.900	error	at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:24:58)
                                zigbee.0	2020-12-11 19:04:53.900	error	at Generator.next (<anonymous>)
                                zigbee.0	2020-12-11 19:04:53.900	error	at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:657:27)
                                zigbee.0	2020-12-11 19:04:53.900	error	(61906) Error on send command to 0x14b457fffe43566d. Error: Error: Command 0x14b457fffe43566d/1 genLevelCtrl.moveToLevelWithOnOff({"level":50,"transtime":10}, {"timeout":10000,"disableResponse":false
                                • Asgothian
                                  Asgothian Developer @el_malto last edited by
                                  @el_malto Poste bitte das komplette Log. Dein Log ist abgeschnitten.
                                  A.
                                    dondaik @hukio last edited by
                                    danke!
                                    werde den link mal speichern. im moment läuft ja, sagen wir die testphase, um so 20 fs20 steckdosen mal langsam abzulösen ( auch wenn ich es nicht einsehe diese unkaputtbaren steckdosen auszumustern ... doch das mesh würde funkprobleme lösen)
                                    im moment zeigt der adapter mir seine zähne - seit der installation ist iobroker instabil und lahm ... doch mehr noch der adapter und seine funktionen - hoffe das das sich ändert!!
                                    Ps.: eine empfehlung für temperatur-feuchte sensoren bräuchte ich auch ....
                                      Thomas Braun Most Active @dondaik last edited by
                                      @dondaik sagte in ZigBee neue Version 1.4.0:
                                      Hört sich für mich eher danach an, als wenn du im default/stable Verwahrort besser aufgehoben wärst.
                                        el_malto @Asgothian last edited by el_malto
                                        @Asgothian nein, das sind wirklich die einzigen Zeilen im Log.
                                        Jetzt kommt sogar nur noch eine Zeile im Log:
                                        zigbee.0	2020-12-12 00:48:33.192	error	(61906) Error on send command to 0x14b457fffe43566d. Error: Error: Command 0x14b457fffe43566d/1 genLevelCtrl.moveToLevelWithOnOff({"level":229,"transtime":10}, {"timeout":10000,"disableResponse":false
                                        EDIT:
                                        Jetzt kommen wieder mehr Fehlermeldungen im Log:
                                        2020-12-12 01:07:57.949 - error: zigbee.0 (64060) Error on send command to 0x14b457fffe43566d. Error: Error: Command 0x14b457fffe43566d/1 genLevelCtrl.moveToLevelWithOnOff({"level":254,"transtime":10}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (Data request failed with error: 'undefined' (26))
                                        at ZStackAdapter. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:657:27)
                                        at Generator.next ()
                                        2020-12-12 01:07:57.970 - error: zigbee.0 (64060) Error on send command to 0x14b457fffe43566d. Error: Error: Command 0x14b457fffe43566d/1 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (Data request failed with error: 'undefined' (26))
                                        Und es kommt mir so vor als wenn der Adapter total träge ist. Mal kann ich die Lampe normal an machen, mal geht die erst nach 10 Sekunden an ode gar nicht.
                                        • MathiasJ
                                          So, neu angelernt,
                                          die Steckdose hat er wieder verloren.......
                                          Wie oft muß man den Adapter Zigbee neu starten, damit der funktioniert?
                                          Also ich komme auf 288 mal in 24 Stunden 👎
                                          Bin beim überlegen, alle Geräte abzulernen und den Adapter zu deinstallieren.
                                          Sorry aber so nen Schrott hab ich lange nimmer gesehen!
                                          V J Asgothian Schmakus 4 Replies Last reply Reply Quote -1
                                          • V
                                            vikk88 @MathiasJ last edited by vikk88
                                            @MathiasJ sorry aber den Adapter als Schrott zu bezeichnen finde ich mehr als daneben. Gerade wenn man bedenkt wie viel Stunden an Freizeit die Leute zum Entwickeln da rein stecken und dann auch noch viel im Forum unterwegs sind und Leuten helfen. Die Osram Plugs haben leider in der Vergangenheit schon immer mal wieder Probleme gemacht, hatte ich auch mit einem. Dieser läuft aber mittlerweile und momentan stabil. Vielleicht liegt es ja an deiner Hardware oder anderen Faktoren. Und das das nervt kann ich verstehen aber das ist hier halt ein Projekt und nichts was du fertig im Laden kaufst.
                                            alpha git neu zigbee
                                            62
                                            393
                                            94004
