    3. Entwicklung
    4. ZigBee neue Version 1.4.0
      rasen1992 @hoktar last edited by
      Habe einen Tuya Heizkörperthermostaten, ich empfange alle Daten aber,
      Wenn ich die Temperatur Manuell einstelle dauert es ca bis zu 5 min bis die richtige Temperatur im Iobroker angezeigt wird (er ändert sie im Io in 0,5 schritten)
      Über den Iobroker kann ich die Termperatur leider garnicht steuern ...
      Kann mir bitte jemand helfen, hier der Log beim ändern der Temperatur
      2020-12-13 17:58:24.371 - debug: tuya.0 (2075) system.adapter.admin.0: logging false
      2020-12-13 17:58:24.373 - debug: zigbee.0 (26663) system.adapter.admin.0: logging false
      2020-12-13 17:58:32.677 - debug: zigbee.0 (26663) User stateChange zigbee.0.60a423fffea0fd5a.target_temperature {"val":20,"ack":false,"ts":1607878712673,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1607878712673}
      2020-12-13 17:58:32.681 - debug: zigbee.0 (26663) Change state 'target_temperature' at device 0x60a423fffea0fd5a type 'TS0601_thermostat'
      2020-12-13 17:58:32.682 - debug: zigbee.0 (26663) State changes. dev: 0x60a423fffea0fd5a model: TS0601_thermostat states: [{"stateDesc":{"id":"target_temperature","prop":"current_heating_setpoint","name":"Current Target Temperature","role":"value.temperature","write":true,"read":true,"type":"number","unit":"°C","min":0,"max":70},"value":20,"index":0,"timeout":0}] opt: {}
      2020-12-13 17:58:32.683 - debug: zigbee.0 (26663) entity: {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x60a423fffea0fd5a","_networkAddress":37247,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"deviceID":81,"inputClusters":[0,4,5,61184],"outputClusters":[25,10],"deviceNetworkAddress":37247,"deviceIeeeAddress":"0x60a423fffea0fd5a","clusters":{"genBasic":{"attributes":{"65503":"�Og'\u0012�Og'\u0012","65506":31,"65508":0,"modelId":"TS0601","manufacturerName":"_TZE200_ckud7u2l","powerSource":3,"zclVersion":3,"appVersion":83,"stackVersion":0,"hwVersion":1,"dateCode":""}}},"_binds":[],"meta":{}}],"_manufacturerName":"_TZE200_ckud7u2l","_powerSource":"Battery","_modelID":"TS0601","_applicationVersion":83,"_stackVersion":0,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"","_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1607878645574,"_linkquality":152},"mapped":{"zigbeeModel":["kud7u2l"],"fingerprint":[{"modelID":"TS0601","manufacturerName":"_TZE200_ckud7u2l"}],"model":"TS0601_thermostat","vendor":"TuYa","description":"Radiator valve with thermostat","whiteLabel":[{"vendor":"Moes","model":"HY369RT"},{"vendor":"SHOJZJ","model":"378RT"}],"meta":{"tuyaThermostatPreset":{"0":"away","1":"schedule","2":"manual","3":"comfort","4":"eco","5":"boost","6":"complex"}},"ota":{},"fromZigbee":[{"cluster":"manuSpecificTuya","type":"commandGetData"},{"cluster":"manuSpecificTuya","type":"commandSetDataResponse"},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"manuSpecificTuya","type":["commandSetTimeRequest"]}],"toZigbee":[{"key":["child_lock"]},{"key":["window_detection"]},{"key":["valve_detection"]},{"key":["current_heating_setpoint"]},{"key":["auto_lock"]},{"key":["local_temperature_calibration"]},{"key":["min_temperature"]},{"key":["max_temperature"]},{"key":["boost_time"]},{"key":["comfort_temperature"]},{"key":["eco_temperature"]},{"key":["force"]},{"key":["preset"]},{"key":["away_mode"]},{"key":["window_detect"]},{"key":["schedule"]},{"key":["week"]},{"key":["away_preset_temperature","away_preset_days"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]}],"exposes":[{"type":"lock","features":[{"type":"binary","name":"state","property":"child_lock","access":7,"value_on":"LOCK","value_off":"UNLOCK","description":"Enables/disables physical input on the device"}]},{"type":"switch","features":[{"type":"binary","name":"state","property":"window_detection","access":7,"value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE"}]},{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %","value_min":0,"value_max":100},{"type":"binary","name":"battery_low","property":"battery_low","access":1,"value_on":true,"value_off":false,"description":"Indicates if the battery of this device is almost empty"},{"type":"switch","features":[{"type":"binary","name":"state","property":"valve_detection","access":7,"value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE"}]},{"type":"numeric","name":"position","property":"position","access":1,"unit":"%","description":"Position"},{"type":"climate","features":[{"type":"numeric","name":"current_heating_setpoint","property":"current_heating_setpoint","access":7,"value_min":5,"value_max":35,"value_step":0.5,"unit":"°C","description":"Temperature setpoint"},{"type":"numeric","name":"local_temperature","property":"local_temperature","access":5,"unit":"°C","description":"Current temperature measured on the device"},{"type":"enum","name":"system_mode","property":"system_mode","access":7,"values":["heat"],"description":"Mode of this device"},{"type":"enum","name":"running_state","property":"running_state","access":5,"values":["idle","heat"],"description":"The current running state"},{"type":"binary","name":"away_mode","property":"away_mode","access":7,"value_on":"ON","value_off":"OFF","description":"Away mode"},{"type":"enum","name":"preset","property":"preset","access":7,"values":["schedule","manual","boost","complex","comfort","eco"],"description":"Mode of this device (similar to system_mode)"}]},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}]},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x60a423fffea0fd5a"}
      2020-12-13 17:58:32.685 - debug: zigbee.0 (26663) Mapped Model: {"zigbeeModel":["kud7u2l"],"fingerprint":[{"modelID":"TS0601","manufacturerName":"_TZE200_ckud7u2l"}],"model":"TS0601_thermostat","vendor":"TuYa","description":"Radiator valve with thermostat","whiteLabel":[{"vendor":"Moes","model":"HY369RT"},{"vendor":"SHOJZJ","model":"378RT"}],"meta":{"tuyaThermostatPreset":{"0":"away","1":"schedule","2":"manual","3":"comfort","4":"eco","5":"boost","6":"complex"}},"ota":{},"fromZigbee":[{"cluster":"manuSpecificTuya","type":"commandGetData"},{"cluster":"manuSpecificTuya","type":"commandSetDataResponse"},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"manuSpecificTuya","type":["commandSetTimeRequest"]}],"toZigbee":[{"key":["child_lock"]},{"key":["window_detection"]},{"key":["valve_detection"]},{"key":["current_heating_setpoint"]},{"key":["auto_lock"]},{"key":["local_temperature_calibration"]},{"key":["min_temperature"]},{"key":["max_temperature"]},{"key":["boost_time"]},{"key":["comfort_temperature"]},{"key":["eco_temperature"]},{"key":["force"]},{"key":["preset"]},{"key":["away_mode"]},{"key":["window_detect"]},{"key":["schedule"]},{"key":["week"]},{"key":["away_preset_temperature","away_preset_days"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]}],"exposes":[{"type":"lock","features":[{"type":"binary","name":"state","property":"child_lock","access":7,"value_on":"LOCK","value_off":"UNLOCK","description":"Enables/disables physical input on the device"}]},{"type":"switch","features":[{"type":"binary","name":"state","property":"window_detection","access":7,"value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE"}]},{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %","value_min":0,"value_max":100},{"type":"binary","name":"battery_low","property":"battery_low","access":1,"value_on":true,"value_off":false,"description":"Indicates if the battery of this device is almost empty"},{"type":"switch","features":[{"type":"binary","name":"state","property":"valve_detection","access":7,"value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE"}]},{"type":"numeric","name":"position","property":"position","access":1,"unit":"%","description":"Position"},{"type":"climate","features":[{"type":"numeric","name":"current_heating_setpoint","property":"current_heating_setpoint","access":7,"value_min":5,"value_max":35,"value_step":0.5,"unit":"°C","description":"Temperature setpoint"},{"type":"numeric","name":"local_temperature","property":"local_temperature","access":5,"unit":"°C","description":"Current temperature measured on the device"},{"type":"enum","name":"system_mode","property":"system_mode","access":7,"values":["heat"],"description":"Mode of this device"},{"type":"enum","name":"running_state","property":"running_state","access":5,"values":["idle","heat"],"description":"The current running state"},{"type":"binary","name":"away_mode","property":"away_mode","access":7,"value_on":"ON","value_off":"OFF","description":"Away mode"},{"type":"enum","name":"preset","property":"preset","access":7,"values":["schedule","manual","boost","complex","comfort","eco"],"description":"Mode of this device (similar to system_mode)"}]},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}]}
      2020-12-13 17:58:32.685 - debug: zigbee.0 (26663) convert current_heating_setpoint, 20, {}
      2020-12-13 17:58:32.686 - debug: zigbee.0 (26663) target: {"ID":1,"profileID":260,"deviceID":81,"inputClusters":[0,4,5,61184],"outputClusters":[25,10],"deviceNetworkAddress":37247,"deviceIeeeAddress":"0x60a423fffea0fd5a","clusters":{"genBasic":{"attributes":{"65503":"�Og'\u0012�Og'\u0012","65506":31,"65508":0,"modelId":"TS0601","manufacturerName":"_TZE200_ckud7u2l","powerSource":3,"zclVersion":3,"appVersion":83,"stackVersion":0,"hwVersion":1,"dateCode":""}}},"_binds":[],"meta":{}}
      2020-12-13 17:58:32.687 - debug: zigbee.0 (26663) convert result undefined
      2020-12-13 17:58:34.490 - debug: zigbee.0 (26663) system.adapter.admin.0: logging true
      2020-12-13 17:58:34.490 - debug: tuya.0 (2075) system.adapter.admin.0: logging true
      Thermostat https://de.aliexpress.com/item/1005001278184708.html?spm=a2g0s.9042311.0.0.33c44c4djWaufS
      Danke für die Hilfe
      Asgothian keksn 2 Replies Last reply Reply Quote 0
      • Asgothian
        Asgothian Developer @rasen1992 last edited by
        @rasen1992
        • Bitte die Kachel des Thermostat aus dem Zigbee-Adapter posten. Der Link zu AliExpress ist nicht aussagekräftig.
        • Zusätzlich die Kachel vom Koordinator mit posten.
        • Die Thermostate sind träge, das ist "normal"
        • auch die 0.5 grad schritte sind bei den mir bekannten TuYa Thermostaten bekannt.
        A.
          rasen1992 @Asgothian last edited by
          @Asgothian
          Danke für deine Antworten
          Asgothian R 2 Replies Last reply Reply Quote 0
          • Asgothian
            @rasen1992
            • Es gibt zu diesem Thermostat einen PR am Adapter. Diesen solltest du abwarten, dann geht schon einmal mehr als jetzt.
            • es gibt auch am Herdsman dazu einen PR, der einen Fehler bei der local temp calibration behebt. Wann der durch ist ist schwer vorher zu sagen.
            A.
              Tim12 @arteck last edited by
              @arteck said in ZigBee neue Version 1.4.0:
              und wovon ist hier die rede ??
              Vor ein paar Tagen wurde im Thread darauf hingewiesen, dass in der 1.4.0 einige RGB-Leuchtmittel des letzten Lidl-Angebots nicht voll unterstützt werden - sondern nur on/off und RGB. Color Temperature und Dimming States werden zwar angelegt, Wertänderungen werden aber von den Lampen nicht umgesetzt.
              Das konnte ich für das entsprechende RGB-Leuchtmittel mit GU10 Fassung auch feststellen. Habe die weißen LEDs aber mit der genannten Ergänzung in der devices.js der 1.3.1 bedienen können. Konkret geht es um dieses Produkt:
              c7665136-ffc2-451e-9fdb-fcf8b894f5b6-grafik.png vertrieben als
              LivarnoLux LED-Lampe
              Da der Fehler schon beschrieben war, wollte ich den beiden nur eine etwaige Zwischenlösung anbieten, bis die Lampen in einer 1.4.x wieder voll ansprechbar sind.
                arteck Developer Most Active @Tim12 last edited by arteck
                @Tim12
                installier die mal
                https://github.com/ioBroker/ioBroker.zigbee/tarball/arteck-patch-1
                geht es dann ??
                M T 2 Replies Last reply Reply Quote 0
                  Mr.X @arteck last edited by
                  Warte darauf, dass arteck wieder HW hat.
                  Bis dahin, konnte vielleicht jemand die Ursahe hierfür finden?
                  zigbee.0	2020-12-14 10:33:53.419	error	at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/@serialport/stream/lib/index.js:242:12
                  zigbee.0	2020-12-14 10:33:53.419	error	at SerialPort._error (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/@serialport/stream/lib/index.js:198:14)
                  zigbee.0	2020-12-14 10:33:53.419	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
                  zigbee.0	2020-12-14 10:33:53.419	error	at __awaiter (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
                  zigbee.0	2020-12-14 10:33:53.419	error	at new Promise (<anonymous>)
                  zigbee.0	2020-12-14 10:33:53.419	error	at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
                  zigbee.0	2020-12-14 10:33:53.419	error	at Generator.next (<anonymous>)
                  zigbee.0	2020-12-14 10:33:53.419	error	at Znp.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
                  zigbee.0	2020-12-14 10:33:53.419	error	(2014) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
                  zigbee.0	2020-12-14 10:33:53.418	error	(2014) Failed to start Zigbee
                  zigbee.0	2020-12-14 10:33:53.407	info	(2014) Starting Zigbee npm ...
                  zigbee.0	2020-12-14 10:33:53.406	info	(2014) Try to reconnect. 1 attempts left
                  zigbee.0	2020-12-14 10:33:43.407	info	(2014) Installed Version: iobroker.zigbee@1.4.0
                  Jetzt habe ich hier viel HW, und kann sie nicht nutzen.... 😞
                  • Asgothian
                    Asgothian Developer @Mr.X last edited by
                    @Mr-X sagte in ZigBee neue Version 1.4.0:
                    Steht da doch. Die Schnittstelle kann nicht geöffnet werden, sie existiert nicht.
                    Bitte prüfen:
                    • gibt es /dev/ttyACM0
                    • sind die Rechte so gesetzt das der ioBroker darauf zugreifen kann.
                    A.
                      el_malto @Asgothian last edited by
                      @Asgothian sagte in ZigBee neue Version 1.4.0:
                      @el_malto
                      Das log welches du oben hinter dem Spoiler hast zeigt einiges an "MEM_ERROR" Meldungen. Damit bleibt der Post den ich vor einer Stunde gemacht habe relevant. Du hast ein Hardware Problem mit dem cc2531
                      A.
                      @el_malto sagte in ZigBee neue Version 1.4.0:
                      @arteck sagte in ZigBee neue Version 1.4.0:
                      @el_malto er ist nicht kaputt.. es kommt nur mit der Menge der Geräte nicht mehr klar..
                      Mit der Menge der Geräte? Ich hab gerade mal 4(!) Geräte😅
                      Nur kurzes Update falls andere solche Errors auch mal haben.
                      Lösung war einfach den Stick einmal ab zu ziehen und wieder einstecken. Nun kommen keine Fehlermeldungen mehr im Log und alles lässt sich normal steuern.
                        Mr.X @Asgothian last edited by
                        @Asgothian Mit 1.3.1 funktionert alles tipi topi.
                        ACM0 gibt es wenn ich -lsusb auslese.
                        Wie schaue ich die Rechte nach? können die sich verändern wenn ich zwischen 1.4 und 1.3.1 hin und her switche?
                        Thomas Braun Asgothian 2 Replies Last reply Reply Quote 0
                          Thomas Braun Most Active @Mr.X last edited by
                          @Mr-X
                          ls -la /dev/ttyACM0
                          • Asgothian
                            Nein, eigentlich nicht.
                            Trotzdem ist es seltsam. Kannst du bitte schauen ob es bei der Installation der 1.4.0 Fehlermeldungen gibt ?
                            A.
                            • Asgothian
                              Asgothian Developer @el_malto last edited by
                              Das ist keine Lösung, sondern eine "abhilfemassnahme". Der Fehler wird wieder kommen, das zeigt die Erfahrung. Bei Dir wohl eher nicht so bald, da du nur wenig Geräte hast, aber er wird dennoch kommen.
                              A.
                                @Asgothian danke für die Info. Ich werde es mal beobachten.
                                  Mr.X @Thomas Braun last edited by
                                  @Thomas-Braun bin jetzt wieder auf 1.3.1 aber sollte doch keinen Unterschied mache, oder?
                                  crw-rw---- 1 root dialout 166, 0 Dec 15 08:01 /dev/ttyACM0
                                    @Mr-X
                                    Ist dein User auch Mitglied von dialout?
                                    sudo -u iobroker groups
                                      Mr.X @Thomas Braun last edited by Mr.X
                                      @Thomas-Braun Ohje, sowas habe ich noch nie gesehen:
                                      aber hier die Antwort:
                                      pi@raspberrypi:~ $ sudo -u iobroker groups
                                      iobroker tty dialout audio video bluetooth gpio i2c
                                      Danke für die Hilfen
                                        @Mr-X Das passt.
                                        who -r
                                        bringt?
                                          leon @leon last edited by
                                          Gibt es zu dem Problem was Neues?
                                            @leon said in ZigBee neue Version 1.4.0:
                                            mit ZigBee 1.4.0 konnte nun folgendes Lidl Produkt anlernen.
                                            Leider funktioniert colortemp = level.color.temperature nicht. Wenn man manuell eine Wert setzt passiert nichts. Auch im Log ist nicht zu sehen. Bei dem Philips Hue Strip funktioniert es.
                                            Andi
                                            alpha git neu zigbee
                                            62
                                            393
                                            93990
