    4. [gelöst] sayIt und Sonos Volume 0
    • I
      iben last edited by
      @Bluefox:
      radio oder files ??? `
      radio
      • Bluefox
        Bluefox last edited by
        Probier mal vom git installieren
        • I
          iben last edited by
          Danke mit der git-Version 1.0.0 gehts.
          Kann man das faden irgendwo abstellen? Das führt nämlich dazu, dass das Achtung schwer zu hören ist.
          • Bluefox
            Werde ich einstellbar machen.
            • Bluefox
              Habe auf dem git neue Version.
              Allerdings, ich habe da mehr geändert, weil die Sonos NPM Pakete auch upgedated wurden.
              • I
                iben last edited by
                Jetz erhlate ich folgende Meldung:
                sonos-0	2016-10-23 14:33:04.874	info	http sonos server listening on port 8080
                sonos-0	2016-10-23 14:33:04.827	info	starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.sonos
                host-ubuntu2cpu	2016-10-23 14:33:03.921	info	instance system.adapter.sonos.0 started with pid 1436
                host-ubuntu2cpu	2016-10-23 14:32:33.913	info	Restart adapter system.adapter.sonos.0 because enabled
                host-ubuntu2cpu	2016-10-23 14:32:33.912	error	instance system.adapter.sonos.0 terminated with code 0 (OK)
                sonos-0	2016-10-23 14:32:33.901	info	terminating
                sonos-0	2016-10-23 14:32:33.894	info	terminating
                ReferenceError:	2016-10-23 14:32:33.893	error	at Timer.listOnTimeout (timers.js:92:15)
                ReferenceError:	2016-10-23 14:32:33.893	error	at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2124:38)
                ReferenceError:	2016-10-23 14:32:33.893	error	at Adapter.emit (events.js:172:7)
                ReferenceError:	2016-10-23 14:32:33.893	error	at emitTwo (events.js:87:13)
                ReferenceError:	2016-10-23 14:32:33.893	error	at Adapter. (/opt/iobroker/node_modules/iobroker.sonos/sonos.js:89:17)
                ReferenceError:	2016-10-23 14:32:33.893	error	at text2speech (/opt/iobroker/node_modules/iobroker.sonos/sonos.js:494:47)
                ReferenceError:	2016-10-23 14:32:33.893	error	uuid is not defined
                uncaught	2016-10-23 14:32:33.891	error	exception: uuid is not defined
                sonos-0	2016-10-23 14:32:33.885	info	try to control id sonos.0.root.192_168_1_12.tts with {"val":"55;http://192.168.1.112:8082/state/sayit.0.tts.mp3","ack":false,"ts":1477225953878,"q":0,"from":"system.adapter.sayit.0","lc":147722595387
                sayit-0	2016-10-23 14:32:33.877	info	Copied file "/opt/iobroker/node_modules/iobroker.sayit/say.mp3" to "/opt/iobroker/cache/3669a9e00fed6ac73f01a751fec72960.mp3"
                sayit-0	2016-10-23 14:32:33.854	info	Set "sonos.0.root.192_168_1_12.tts: 55;http://192.168.1.112:8082/state/sayit.0.tts.mp3
                sayit-0	2016-10-23 14:32:32.482	info	saying: Achtung! Das ist ein Test!
                javascript-0	2016-10-23 14:32:32.473	info	script.js.zsayit: registered 0 subscriptions and 0 schedules
                javascript-0	2016-10-23 14:32:32.463	info	Start javascript script.js.zsayit
                sonos 1.1.0
                sayit 1.1.2
                • Bluefox
                  Update bitte noch mal vom git.
                  • I
                    iben last edited by
                    sonos 1.1.1
                    host-ubuntu2cpu	2016-10-23 16:39:11.514	info	Restart adapter system.adapter.sonos.0 because enabled
                    host-ubuntu2cpu	2016-10-23 16:39:11.513	error	instance system.adapter.sonos.0 terminated with code 0 (OK)
                    sonos-0	2016-10-23 16:39:11.501	info	terminating
                    sonos-0	2016-10-23 16:39:11.493	info	terminating
                    TypeError:	2016-10-23 16:39:11.492	error	at Timer.listOnTimeout (timers.js:92:15)
                    TypeError:	2016-10-23 16:39:11.492	error	at ontimeout [as _onTimeout] (timers.js:202:24)
                    TypeError:	2016-10-23 16:39:11.492	error	at playOnSonos (/opt/iobroker/node_modules/iobroker.sonos/sonos.js:668:59)
                    TypeError:	2016-10-23 16:39:11.492	error	player.getState is not a function
                    uncaught	2016-10-23 16:39:11.490	error	exception: player.getState is not a function
                    sonos-0	2016-10-23 16:39:11.475	info	try to control id sonos.0.root.192_168_1_12.tts with {"val":"55;http://192.168.1.112:8082/state/sayit.0.tts.mp3","ack":false,"ts":1477233551469,"q":0,"from":"system.adapter.sayit.0","lc":147722595387
                    sayit-0	2016-10-23 16:39:11.467	info	Copied file "/opt/iobroker/node_modules/iobroker.sayit/say.mp3" to "/opt/iobroker/cache/3669a9e00fed6ac73f01a751fec72960.mp3"
                    sayit-0	2016-10-23 16:39:11.458	info	Set "sonos.0.root.192_168_1_12.tts: 55;http://192.168.1.112:8082/state/sayit.0.tts.mp3
                    javascript-0	2016-10-23 16:39:11.143	info	script.js.zsayit: registered 0 subscriptions and 0 schedules
                    sayit-0	2016-10-23 16:39:11.162	info	saying: Achtung! Das ist ein Test!
                    javascript-0	2016-10-23 16:39:11.140	info	Start javascript script.js.zsayit
                    • Bluefox
                      Und jetzt? (vom git)
                      • I
                        iben last edited by
                        Ist nix zu hören, wenn Radio läuft wird auch nix unterbrochen Radio läuft weiter.
                        inMem	2016-10-23 18:07:59.123	debug	message sonos.0.* sonos.0.root.192_168_1_12.current_elapsed_s val=00:00, ack=true, ts=1477238879119, q=0, from=system.adapter.sonos.0, lc=1477129976014
                        inMem	2016-10-23 18:07:59.118	debug	message sonos.0.* sonos.0.root.192_168_1_12.current_elapsed val=0, ack=true, ts=1477238879116, q=0, from=system.adapter.sonos.0, lc=1477129976014
                        sonos-0	2016-10-23 18:07:57.807	debug	Play on sonos[RINCON_000E5851FD7601400]: http://192.168.1.112:8082/state/sayit.0.tts.mp3, Volume: 55
                        sonos-0	2016-10-23 18:07:57.798	debug	Play TTS file 55;http://192.168.1.112:8082/state/sayit.0.tts.mp3 on 192_168_1_12
                        sonos-0	2016-10-23 18:07:57.797	info	try to control id sonos.0.root.192_168_1_12.tts with {"val":"55;http://192.168.1.112:8082/state/sayit.0.tts.mp3","ack":false,"ts":1477238877793,"q":0,"from":"system.adapter.sayit.0","lc":147723887779
                        inMem	2016-10-23 18:07:57.796	debug	message sonos.0.* sonos.0.root.192_168_1_12.tts val=55;http://192.168.1.112:8082/state/sayit.0.tts.mp3, ack=false, ts=1477238877793, q=0, from=system.adapter.sayit.0, lc=1477238877793
                        javascript-0	2016-10-23 18:07:57.779	info	script.js.zsayit: registered 0 subscriptions and 0 schedules
                        sayit-0	2016-10-23 18:07:57.786	info	Set "sonos.0.root.192_168_1_12.tts: 55;http://192.168.1.112:8082/state/sayit.0.tts.mp3
                        sayit-0	2016-10-23 18:07:57.785	info	saying: Achtung! Das ist ein Test!
                        javascript-0	2016-10-23 18:07:57.668	info	Start javascript script.js.zsayit
                        javascript-1	2016-10-23 18:07:57.663	info	Stop script script.js.zsayit
                        javascript-2	2016-10-23 18:07:57.660	info	Stop script script.js.zsayit
                        javascript-0	2016-10-23 18:07:57.655	info	Stop script script.js.zsayit
                        • Bluefox
                          Das modul sonos-discovery wurde komplett geändert. Deswegen sollte iobroker.sonos auch ziemlich überarbeitet werden.
                          Jetzt (auf den ersten blick) läuft TTS und wird sogar bei radio weiter laufen.
                          • I
                            iben last edited by
                            Jetzt erst den Fehler gefunden: "Fade in" und "Fade out" waren nicht gefüllt, deshalb war wohl nichts zu hören.
                            Danke!
                            2451
