    4. Apple Homekit Siri
    Apple Homekit Siri
    • wendy2702
      wendy2702 last edited by
      ich versuche gerade den Homekit Adapter auf meinem Debian Wheezy zu installieren. Leider schlägt das immer fehl:
      ! $ ./iobroker add homekit
      ! npm install iobroker.homekit –production --prefix "/opt/iobroker" (System call)
      ! In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
      ! compilation terminated.
      ! make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Fehler 1
      ! gyp
      ! ERR! build error
      ! gyp ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
      ! gyp ERR! stack at emitTwo (events.js:87:13)gyp ERR! stack at ChildProcess.emit (events.js:172:7)
      ! gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:200:12)
      ! gyp ERR! System Linux 3.16-0.bpo.2-amd64
      ! gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      ! gyp ERR! cwd /opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/mdns
      ! gyp ERR! node -v v4.5.0
      ! gyp ERR! node-gyp -v v3.4.0
      ! gyp ERR! not ok
      ! npm
      ! ERR! Linux 3.16-0.bpo.2-amd64
      ! npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.homekit" "–production" "--prefix" "/opt/iobroker"npm ERR! node v4.5.0
      ! npm ERR! npm v2.15.9
      ! npm ERR! code ELIFECYCLE
      ! npm ERR! mdns@2.2.11 install: node-gyp rebuild
      ! npm ERR! Exit status 1
      ! npm ERR!
      ! npm ERR! Failed at the mdns@2.2.11 install script 'node-gyp rebuild'.
      ! npm ERR! This is most likely a problem with the mdns package,
      ! npm ERR! not with npm itself.npm ERR! Tell the author that this fails on your system:
      ! npm ERR! node-gyp rebuild
      ! npm ERR! You can get information on how to open an issue for this project with:
      ! npm ERR! npm bugs mdns
      ! npm ERR! Or if that isn't available, you can get their info via:
      ! npm ERR!
      ! npm ERR! npm owner ls mdns
      ! npm ERR! There is likely additional logging output above.
      ! npm ERR! Please include the following file with any support request:
      ! npm ERR! /npm-debug.log
      ! ERROR: host.openmediavault Cannot install iobroker.homekit: 1
      ! ERROR: process exited with code 25
      Node Version ist 4.5.0 –> ist das schon zu alt?
      Vielleicht sonst noch jemand eine Idee was fehlen könnte?
      EDIT:hat sich erledigt: fehlendes Paket installiert:
      ! sudo apt-get install libavahi-compat-libdnssd-dev
      Danke und Gruß
        chka last edited by
        den Fehler habe ich auch
          Stefnas last edited by
          @chka:
          den Fehler habe ich auch `
          bei mir hat folgendes geholfen:
          apt-get install git-core libnss-mdns libavahi-compat-libdnssd-dev -y
          ich habe meinen homekit adapter aktuell laufen, nur leider findet mein handy auf einnmal die bridge nicht mehr. am vormittag zuhause noch gefunden und am nachmittag nicht mehr, seitdem ist nichts zu machen…neustart und neuinstallation blieb erfolglos...jemand eine idee?
            JW86 last edited by
            @Stefnas:
            @chka:
            den Fehler habe ich auch ich habe meinen homekit adapter aktuell laufen, nur leider findet mein handy auf einnmal die bridge nicht mehr. am vormittag zuhause noch gefunden und am nachmittag nicht mehr, seitdem ist nichts zu machen…neustart und neuinstallation blieb erfolglos...jemand eine idee?
            Ändere mal den "Username". Wichtig ist das du wieder etwas in Form einer MAC Adresse angibst (XX:XX:XX:XX:XX:XX in HEX).
            Anschließend wird die Bridge aber wieder als neues Gerät erkannt und du musst das Pairing wieder durchführen.
              @JW86:
              Anschließend wird die Bridge aber wieder als neues Gerät erkannt und du musst das Pairing wieder durchführen. `
              Danke. Prüfe ich heute Abend und gebe bescheid…
                @JW86:
                Danke hat funktioniert. Siri funktioniert nun ohne Probleme mit meinen Homematicthermostaten, außer das Wandthermostat lässt sich nicht abfragen, ändern…aber das coolste überhaupt ist das sogar der Botcac Connected Staubsauger erkannt wird und sogar steuerbar ist...sensationell, ist das Zufall oder gewollt?
                  Solear last edited by
                  Kann jetzt bitte noch einmal jemand genau sagen, was momentan mit diesem Adapter machbar ist?
                  Ich verstehe noch nicht genau, wie der funktioniert.
                  Brauche ich ein Hardware-Home-fähiges Teil?
                  Oder nur die Steuersoftware-App wie die von elagto?
                  Ist es egal welche?
                  Kann ich mit Siri dann Glühbirnen über Homematic Strommessstecker schalten? Darum geht es mir letztlich.
                    @Solear:
                    Ist es egal welche?
                    Kann ich mit Siri dann Glühbirnen über Homematic Strommessstecker schalten? Darum geht es mir letztlich. `
                    • Brauche ich ein Hardware-Home-fähiges Teil?
                    Nein habe ich ebenfalls nicht.
                    • Oder nur die Steuersoftware-App wie die von elagto
                    Nein, kannst auch direkt die von Apple nehmen "Home".
                    • Ist es egal welche?
                    Denke schon, bei mir funktioniert "Home" von Apple und die von "Elgato".
                    Bei mir werden zur Zeit alle Homematic Thermostate (Homematic 105155 Funk-Heizkörperthermostat für Smart Home / Hausautomation) und ein Zwischenstecker (Homematic 130248 Funk-Schaltaktor 1fach mit Leistungsmessung, Zwischenstecker für Smart Home / Hausautomation) erkannt und ich kann diese darüber steuern ob noch mehr Geräte funktionieren kann ich Dir nicht sagen da mir keine weiteren vorliegen. Zufällig habe ich gesehen das mein Neato Botvac Connected Staubsauger ebenfalls darüber ansteuerbar ist…
                      Vielen Dank, Stefnas!
                      Das hat soweit geklappt. Homekit ist installiert und aktiviert.
                      Ich hatte schon schon, dass auf dem iPhone kein Homekit Server gefunden worden ist. Das konnte ich erst beheben als ich die Macadresse in den Homekit-Adaptereinstellungen etwas verändert habe.
                      Es werden auch viele Geräte erkannt, u.a die Strommessschalter und UP-Dimmer. Aber, es steht dann immer "Kommunikation nicht möglich".
                      Im Log steht nichts, da läuft öfter aber homekit vorbei mit Statusaktualisierungen (also das klappt, aber zwischen iPhone und Homekit-Adapter scheint was nicht zu klappen).
                      Was könnte das sein?
                      In den Adaptereinstellungen Homekit, was besagt die Mac-Adresse?
                      Mein iobroker läuft in einer VM unter Ubuntu auf VMWare Workstation/Windows 8.1
                        @Solear:
                        Was könnte das sein? `
                        Das Problem kann ich bei mir nachvollziehen, allerdings nur dann wenn die Apple Home App offen ist. Ich habe deshalb folgendes gemacht:
                        • Installation Homekit Adapter
                        • Einrichtung Homekit Adapter
                        • Verbinden mit Apple Home und einrichten der einzelnen Geräte (Name + Raumzuordnung), Fehlermeldungen hierbei habe ich einfach ignoriert und weitergemacht
                        • Nach der kompletten Einrichtung habe ich die Apple Home App geschlossen und ioBroker neugestartet
                        Danach funktioniert das alles bei mir stabil, die Verbindung bricht immer dann ab wenn ich die Apple Home App öffne, dann ist es so das mal eine Verbindung besteht und mal nicht, dann kann ich im ioBroker aber auch beobachten das die Instanz mal grün und mal rot ist. Ich lasse deshalb die Home App einfach zu und alles geht wie es soll, außer meinem Wandthermostat, dieses mag nicht so wie ich, hat da jemand eine Idee?
                          charlyphyro last edited by
                          Bekomme eine Fehlermeldung vllt kann mir einer helfen!
                          Hängt es an einem hm-module?
                          Viele Grüße Charly
                          inMem 2016-10-26 18:22:34.901 debug message * system.adapter.homekit.0.alive val=false, ack=true, ts=1477498954899, q=0, from=system.adapter.homekit.0, lc=1477498954899
                          TypeError: 2016-10-26 18:22:34.898 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
                          TypeError: 2016-10-26 18:22:34.898 error at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                          TypeError: 2016-10-26 18:22:34.898 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
                          TypeError: 2016-10-26 18:22:34.898 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
                          TypeError: 2016-10-26 18:22:34.898 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                          TypeError: 2016-10-26 18:22:34.898 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
                          TypeError: 2016-10-26 18:22:34.898 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
                          TypeError: 2016-10-26 18:22:34.898 error at Socket. (/opt/iobroker/node_modules/iobroker.homekit/main.js:200:60)
                          TypeError: 2016-10-26 18:22:34.898 error at /opt/iobroker/node_modules/iobroker.homekit/main.js:18:13
                          TypeError: 2016-10-26 18:22:34.898 error at main (/opt/iobroker/node_modules/iobroker.homekit/main.js:324:26)
                          TypeError: 2016-10-26 18:22:34.898 error Cannot read property 'PARENT_TYPE' of undefined
                          Gesendet von iPad mit Tapatalk
                            holgerwolf last edited by
                            ist gibt ja jetzt einen Homekit2.0 (V0.1.6) Adapter. Wurde hier nirgendwo angekündigt oder habe ich was übersehen.
                            Damit habe ich erstmal die Installationsprobleme von der Vorgänger Version weg.
                            Nach dem Starten des Adapters kann ich diesen auch in der Apple Home App sehen und die Bridge konfigurieren. Darauf sehe ich kurz alle Geräte aus der Adapter-Liste aber dann schmiert der Adapter ab:
                            host.lemaker	2016-11-04 11:09:57.577	info	Restart adapter system.adapter.homekit2.0 because enabled
                            host.lemaker	2016-11-04 11:09:57.575	error	instance system.adapter.homekit2.0 terminated with code 0 (OK)
                            inMem	2016-11-04 11:09:57.493	debug	message * system.adapter.homekit2.0.alive val=false, ack=true, ts=1478254197476, q=0, from=system.adapter.homekit2.0, lc=1478254197476
                            TypeError:	2016-11-04 11:09:57.461	error	at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                            TypeError:	2016-11-04 11:09:57.461	error	at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:333:8)
                            TypeError:	2016-11-04 11:09:57.461	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
                            TypeError:	2016-11-04 11:09:57.461	error	at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                            TypeError:	2016-11-04 11:09:57.461	error	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:229:12)
                            TypeError:	2016-11-04 11:09:57.461	error	at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:305:9)
                            TypeError:	2016-11-04 11:09:57.461	error	at Socket. (/opt/iobroker/node_modules/iobroker.homekit2/main.js:200:60)
                            TypeError:	2016-11-04 11:09:57.461	error	at /opt/iobroker/node_modules/iobroker.homekit2/main.js:18:13
                            TypeError:	2016-11-04 11:09:57.461	error	at main (/opt/iobroker/node_modules/iobroker.homekit2/main.js:280:67)
                            TypeError:	2016-11-04 11:09:57.461	error	at Object.createAccessory_Humidity [as Humidity] (/opt/iobroker/node_modules/iobroker.homekit2/main.js:513:41)
                            TypeError:	2016-11-04 11:09:57.461	error	Cannot read property 'CurrentRelativeHumidity' of undefined
                            uncaught	2016-11-04 11:09:57.456	error	exception: Cannot read property 'CurrentRelativeHumidity' of undefined
                            homekit2.0	2016-11-04 11:09:57.425	debug	> iobroker subscribe Humidity hm-rpc.0.HEQ0118211.1.HUMIDITY
                            homekit2.0	2016-11-04 11:09:57.408	debug	< hap Type for Humidity = HM-WDS100-C6-O
                            homekit2.0	2016-11-04 11:09:57.404	debug	Accessory: Switch Object: State
                            homekit2.0	2016-11-04 11:09:57.328	info	hap-nodejs starting...
                            homekit2.0	2016-11-04 11:09:57.318	debug	received all objects
                            homekit2.0	2016-11-04 11:09:56.415	debug	received all states
                            homekit2.0	2016-11-04 11:09:54.335	debug	requesting all objects
                            homekit2.0	2016-11-04 11:09:54.328	debug	requesting all states
                            homekit2.0	2016-11-04 11:09:54.307	info	starting. Version 0.1.6 in /opt/iobroker/node_modules/iobroker.homekit2
                            homekit2.0	2016-11-04 11:09:54.113	debug	statesDB connected
                            homekit2.0	2016-11-04 11:09:54.050	debug	objectDB connected
                            host.lemaker	2016-11-04 11:09:50.072	info	instance system.adapter.homekit2.0 started with pid 494
                            Scheint wohl zu sein, dass er mit einem Wert 'CurrentRelativeHumidity' nicht klar kommt.
                            Ich habe auch mal alle Geräte aus der Adapter-Liste entfernt. Bis auf einen einfachen Schalter. Es wird trotzdem versucht alle Geräte einzulesen und der Adapter bleibt mit der gleichen Meldung wie oben stehen.
                            Holger
                              Bei mir funktioniert die neue Homekit-Version auch nicht. Sie ließ sich problemlos installieren, auch Geräte werden angezeigt ohne Verbindungsfehler, klickt man jedoch Geräte an und legt Schalter um, kommt folgende Fehlermeldung im Log:
                              ` > homekit2.0 2016-11-04 11:20:08.855 debug inMem message * hm-rpc.0.NEQ0400915.1undefined
                              homekit2.0 2016-11-04 11:20:08.850 debug homekit2.0 CHANGED: hm-rpc.0.NEQ0400915.1undefined = false
                              hm-rpc.0 2016-11-04 11:20:08.843 error hm-rpc.0 binrpc -> setValue: no dpType for hm-rpc.0.NEQ0400915.1undefined! `
                              Die Verknüpfung zwischen Homekit und rpc-Adapter scheint nicht zu funktionieren.
                              Habe das "Haus" auch gelöscht und neu in Homekit angelegt, kommt derselbe Fehler.
                                Ich hab auch ein Problem, passiert aber nur wegen dem Amazon dash Button. Wenn ich ihn lösche läuft es soweit durch.
                                  Fugazzy last edited by
                                  3: Leider doch nicht
                                  2: Durch Neuinstallation von mdns ist der Fehler nun weg:
                                  Der Adapter läuft aber trotzdem nicht````
                                  error host.bananapi instance system.adapter.homekit2.0 terminated with code 0 (OK)
                                  1: Ich habe nun auch die neue Version installiert bekommen, aber im Log gibts folgende Meldungen:
                                  homekit2.0 2016-11-05 21:19:09.606 error at EventedHTTPServer.emit (events.js:166:7)
                                  homekit2.0 2016-11-05 21:19:09.606 error at emitNone (events.js:67:13)
                                  homekit2.0 2016-11-05 21:19:09.606 error at HAPServer._onListening (/opt/iobroker/node_modules/iobroker.homekit2/node_modules/hap-nodejs/lib/HAPServer.js:182:8)
                                  homekit2.0 2016-11-05 21:19:09.606 error at HAPServer.emit (events.js:166:7)
                                  homekit2.0 2016-11-05 21:19:09.606 error at Bridge.Accessory._onListening (/opt/iobroker/node_modules/iobroker.homekit2/node_modules/hap-nodejs/lib/Accessory.js:510:20)
                                  homekit2.0 2016-11-05 21:19:09.606 error at Advertiser.startAdvertising (/opt/iobroker/node_modules/iobroker.homekit2/node_modules/hap-nodejs/lib/Advertiser.js:43:30)
                                  homekit2.0 2016-11-05 21:19:09.606 error at Object.create [as createAdvertisement] (/opt/iobroker/node_modules/iobroker.homekit2/node_modules/hap-nodejs/node_modules/mdns/lib/advertisement.js:64:10)
                                  homekit2.0 2016-11-05 21:19:09.606 error at new Advertisement (/opt/iobroker/node_modules/iobroker.homekit2/node_modules/hap-nodejs/node_modules/mdns/lib/advertisement.js:56:10)
                                  homekit2.0 2016-11-05 21:19:09.606 error at Error (native)
                                  homekit2.0 2016-11-05 21:19:09.606 error Error: dns service error: unknown
                                  homekit2.0 2016-11-05 21:19:09.599 error uncaught exception: dns service error: unknown
                                  Bananapi Pro, jessie, Node 4.6.1
                                    JW86 last edited by
                                    Ich habe mal eine Vorabversion meines Adapters http://forum.iobroker.net/viewtopic.php?f=23&t=4136 veröffentlicht.
                                    250
                                    52376
