    3. Entwicklung
    4. Zigbee bleibt gelb nach upgrade auf 1.4
      Thomas Braun Most Active @Mr.X last edited by Thomas Braun
      @Mr-X Lass den Stick immer stecken! Was ist das genau für eine Hardware?
      lsusb -v
      Wie verhält es sich, wenn du das System sauber rebootest?
      sudo reboot
        Mr.X @Thomas Braun last edited by
        @Thomas-Braun
        Bus 002 Device 002: ID 0781:5581 SanDisk Corp. Ultra
        Couldn't open device, some information will be missing
        Device Descriptor:
          bLength                18
          bDescriptorType         1
          bcdUSB               3.00
          bDeviceClass            0
          bDeviceSubClass         0
          bDeviceProtocol         0
          bMaxPacketSize0         9
          idVendor           0x0781 SanDisk Corp.
          idProduct          0x5581 Ultra
          bcdDevice            1.00
          iManufacturer           1
          iProduct                2
          iSerial                 3
          bNumConfigurations      1
          Configuration Descriptor:
            bLength                 9
            bDescriptorType         2
            wTotalLength       0x002c
            bNumInterfaces          1
            bConfigurationValue     1
            iConfiguration          0
            bmAttributes         0x80
              (Bus Powered)
            MaxPower              896mA
            Interface Descriptor:
              bLength                 9
              bDescriptorType         4
              bInterfaceNumber        0
              bAlternateSetting       0
              bNumEndpoints           2
              bInterfaceClass         8 Mass Storage
              bInterfaceSubClass      6 SCSI
              bInterfaceProtocol     80 Bulk-Only
              iInterface              0
              Endpoint Descriptor:
                bLength                 7
                bDescriptorType         5
                bEndpointAddress     0x81  EP 1 IN
                bmAttributes            2
                  Transfer Type            Bulk
                  Synch Type               None
                  Usage Type               Data
                wMaxPacketSize     0x0400  1x 1024 bytes
                bInterval               0
                bMaxBurst               1
                bLength                 7
                bDescriptorType         5
                bEndpointAddress     0x02  EP 2 OUT
                bmAttributes            2
                  Transfer Type            Bulk
                  Synch Type               None
                  Usage Type               Data
                bInterval               0
                bMaxBurst              15
        Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
        Device Descriptor:
          bLength                18
          bDescriptorType         1
          bcdUSB               3.00
          bDeviceClass            9 Hub
          bDeviceSubClass         0
          bDeviceProtocol         3
          bMaxPacketSize0         9
          idVendor           0x1d6b Linux Foundation
          idProduct          0x0003 3.0 root hub
          bcdDevice            5.04
          iManufacturer           3
          iProduct                2
          iSerial                 1
            bLength                 9
            bDescriptorType         2
            wTotalLength       0x001f
            bNumInterfaces          1
            iConfiguration          0
            bmAttributes         0xe0
              Self Powered
              Remote Wakeup
            MaxPower                0mA
              bLength                 9
              bDescriptorType         4
              bInterfaceNumber        0
              bAlternateSetting       0
              bNumEndpoints           1
              bInterfaceClass         9 Hub
              bInterfaceSubClass      0
              bInterfaceProtocol      0 Full speed (or root) hub
              iInterface              0
                bLength                 7
                bDescriptorType         5
                bmAttributes            3
                  Transfer Type            Interrupt
                  Synch Type               None
                  Usage Type               Data
                wMaxPacketSize     0x0004  1x 4 bytes
                bInterval              12
                bMaxBurst               0
        Bus 001 Device 003: ID 0451:16a8 Texas Instruments, Inc.
        Device Descriptor:
          bLength                18
          bDescriptorType         1
          bcdUSB               2.00
          bDeviceClass            2 Communications
          bDeviceSubClass         0
          bDeviceProtocol         0
          bMaxPacketSize0        32
          idVendor           0x0451 Texas Instruments, Inc.
          idProduct          0x16a8
          bcdDevice            0.09
          iManufacturer           1
          iProduct                2
          iSerial                 3
            bLength                 9
            bDescriptorType         2
            wTotalLength       0x0043
            bNumInterfaces          2
            iConfiguration          0
            bmAttributes         0x80
              (Bus Powered)
            MaxPower               50mA
              bLength                 9
              bDescriptorType         4
              bInterfaceNumber        0
              bAlternateSetting       0
              bNumEndpoints           1
              bInterfaceClass         2 Communications
              bInterfaceSubClass      2 Abstract (modem)
              bInterfaceProtocol      1 AT-commands (v.25ter)
              iInterface              0
              CDC Header:
                bcdCDC               1.10
              CDC ACM:
                bmCapabilities       0x02
                  line coding and serial state
              CDC Union:
                bMasterInterface        0
                bSlaveInterface         1
              CDC Call Management:
                bmCapabilities       0x00
                bDataInterface          1
                bLength                 7
                bDescriptorType         5
                bEndpointAddress     0x82  EP 2 IN
                bmAttributes            3
                  Synch Type               None
                  Usage Type               Data
                wMaxPacketSize     0x0040  1x 64 bytes
                bInterval              64
              bLength                 9
              bDescriptorType         4
              bInterfaceNumber        1
              bAlternateSetting       0
              bNumEndpoints           2
              bInterfaceClass        10 CDC Data
              iInterface              0
                bLength                 7
                bDescriptorType         5
                bEndpointAddress     0x84  EP 4 IN
                bmAttributes            2
                  Transfer Type            Bulk
                  Synch Type               None
                  Usage Type               Data
                bInterval               0
                bLength                 7
                bDescriptorType         5
                bEndpointAddress     0x04  EP 4 OUT
                bmAttributes            2
                  Transfer Type            Bulk
                  Synch Type               None
                  Usage Type               Data
                bInterval               0
        Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
        Device Descriptor:
          bLength                18
          bDescriptorType         1
          bcdUSB               2.10
          bDeviceClass            9 Hub
          bDeviceSubClass         0
          bDeviceProtocol         1 Single TT
          bMaxPacketSize0        64
          idVendor           0x2109 VIA Labs, Inc.
          idProduct          0x3431 Hub
          bcdDevice            4.21
          iManufacturer           0
          iProduct                1
          iSerial                 0
            bLength                 9
            bDescriptorType         2
            wTotalLength       0x0019
            bNumInterfaces          1
            iConfiguration          0
            bmAttributes         0xe0
              Self Powered
              Remote Wakeup
            MaxPower              100mA
              bLength                 9
              bDescriptorType         4
              bInterfaceNumber        0
              bAlternateSetting       0
              bNumEndpoints           1
              iInterface              0
                bLength                 7
                bDescriptorType         5
                bmAttributes            3
                  Synch Type               None
                  Usage Type               Data
                wMaxPacketSize     0x0001  1x 1 bytes
                bInterval              12
        Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
        Device Descriptor:
          bLength                18
          bDescriptorType         1
          bcdUSB               2.00
          bDeviceClass            9 Hub
          bDeviceSubClass         0
          bMaxPacketSize0        64
          idProduct          0x0002 2.0 root hub
          bcdDevice            5.04
          iManufacturer           3
          iProduct                2
          iSerial                 1
            bLength                 9
            bDescriptorType         2
            wTotalLength       0x0019
            bNumInterfaces          1
            iConfiguration          0
            bmAttributes         0xe0
              Self Powered
              Remote Wakeup
            MaxPower                0mA
              bLength                 9
              bDescriptorType         4
              bInterfaceNumber        0
              bAlternateSetting       0
              bNumEndpoints           1
              iInterface              0
                bLength                 7
                bDescriptorType         5
                bmAttributes            3
                  Synch Type               None
                  Usage Type               Data
                bInterval              12
          Mr.X last edited by
          Das kommt nach einen reboot im Log:
          Adapter ist nun grün. aber nach 10min. bis 1 Stunde wird der gelb
          zigbee.0
          2020-12-15 21:25:16.898
          error
          (1805) Device 0x90fd9ffffe8a09d4 "undefined" not described in statesMapping.
          zigbee.0
          2020-12-15 21:25:16.676
          info
          (1805) Zigbee started
          zigbee.0
          2020-12-15 21:25:16.675
          info
          (1805) 0xbc33acfffe0ebcf2 (addr 65202): HG06337 - Lidl Silvercrest smart plug (Router)
          zigbee.0
          2020-12-15 21:25:16.667
          info
          (1805) 0xbc33acfffe0ebd34 (addr 45265): HG06337 - Lidl Silvercrest smart plug (Router)
          zigbee.0
          2020-12-15 21:25:16.664
          info
          (1805) 0x842e14fffe556652 (addr 44502): HG06338 - Lidl Silvercrest 3 gang switch, possibly with USB (Router)
          zigbee.0
          2020-12-15 21:25:16.661
          info
          (1805) 0x0017880108b7ba14 (addr 55123): 8718699673147 - Philips Hue white A60 bulb E27 bluetooth (Router)
          zigbee.0
          2020-12-15 21:25:16.659
          info
          (1805) 0x90fd9ffffe8a09d4 (addr 21330): Not supported (model undefined)(Unknown)
          zigbee.0
          2020-12-15 21:25:16.658
          info
          (1805) 0x000b57fffec367c3 (addr 26913): LED1545G12 - IKEA TRADFRI LED bulb E26/E27 980 lumen, dimmable, white spectrum, opal white (Router)
          zigbee.0
          2020-12-15 21:25:16.656
          info
          (1805) 0x00158d0004041f71 (addr 53371): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
          zigbee.0
          2020-12-15 21:25:16.654
          info
          (1805) 0x005043c903241a3e (addr 47918): HS1SA - HEIMAN Smoke detector (EndDevice)
          zigbee.0
          2020-12-15 21:25:16.651
          info
          (1805) 0x005043c9032455a3 (addr 41038): HS1SA - HEIMAN Smoke detector (EndDevice)
          zigbee.0
          2020-12-15 21:25:16.650
          info
          (1805) 0x005043c90324538e (addr 39166): HS1SA - HEIMAN Smoke detector (EndDevice)
          zigbee.0
          2020-12-15 21:25:16.648
          info
          (1805) 0x005043c903245474 (addr 6269): HS1SA - HEIMAN Smoke detector (EndDevice)
          zigbee.0
          2020-12-15 21:25:16.646
          info
          (1805) 0x005043c903386694 (addr 44701): HS1SA - HEIMAN Smoke detector (EndDevice)
          zigbee.0
          2020-12-15 21:25:16.644
          info
          (1805) 0x00158d0004042192 (addr 65354): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
          zigbee.0
          2020-12-15 21:25:16.643
          info
          (1805) 0x000b57fffec1f6ec (addr 28034): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
          zigbee.0
          2020-12-15 21:25:16.640
          info
          (1805) 0x000b57fffe9e650d (addr 38936): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
          zigbee.0
          2020-12-15 21:25:16.637
          info
          (1805) 0x000b57fffe2b7dea (addr 5574): ICTC-G-1 - IKEA TRADFRI wireless dimmer (EndDevice)
          zigbee.0
          2020-12-15 21:25:16.635
          info
          (1805) 0x84182600000f74b5 (addr 9139): AC03641 - OSRAM LIGHTIFY LED Classic A60 clear (Router)
          zigbee.0
          2020-12-15 21:25:16.633
          info
          (1805) 0x90fd9ffffe6d32bc (addr 34524): LED1546G12 - IKEA TRADFRI LED bulb E26/E27 950 lumen, dimmable, white spectrum, clear (Router)
          zigbee.0
          2020-12-15 21:25:16.631
          info
          (1805) 0x00158d0003f045f4 (addr 42828): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
          zigbee.0
          2020-12-15 21:25:16.629
          info
          (1805) 0x00158d0004252ae8 (addr 42379): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (EndDevice)
          zigbee.0
          2020-12-15 21:25:16.627
          info
          (1805) 0x00158d000425298b (addr 62172): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (Unknown)
          zigbee.0
          2020-12-15 21:25:16.625
          info
          (1805) 0x00158d0002a374e8 (addr 51270): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
          zigbee.0
          2020-12-15 21:25:16.617
          info
          (1805) 0x00158d00041cd4e6 (addr 37917): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
          zigbee.0
          2020-12-15 21:25:16.603
          info
          (1805) Currently 23 devices are joined:
          zigbee.0
          2020-12-15 21:25:16.592
          info
          (1805) --> transmitPower : high
          zigbee.0
          2020-12-15 21:25:16.578
          info
          (1805) Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20190223}}
            @Mr-X Das System liegt auf dem SanDisk Datenträger? Boot über USB?
              @Thomas-Braun Ja, genau.
              Und grün wurde er erst jetzt nach dem zweiten boot.
              Momentan geht's, auch die Lidl Sachen.
              Sobald ich merke dass er aussteigt, kann ich den Log posten.
              Drehe jetzt ne Runde mit Doggi, und wenn ich wieder komme ist meist alles platt.
                @Mr-X Das ist der 2531-Stick, oder? Der kann mit 23 Geräten überfordert sein.
                  Mr.X @Thomas Braun last edited by Mr.X
                  @Thomas-Braun Ja, das stimmt.
                  Mich wundert aber dass dann mit 1.3.1 alles läuft.
                  habe jetzt 3 Lidl Sachen angelernt, davor lief alles Tipi topi unter 1.3.1
                    @Mr-X Kann ja sein, dass die drei neuen Geräte genau die drei sind, bei denen der Stick ausgereizt ist.
                      @Thomas-Braun und das würde dann die errors kreieren?
                      Könnte jetzt noch die drei neue löschen und auf 1.4 bleiben.
                        @Mr-X Nicht alle.
                          @Thomas-Braun
                          So, da wären wir wieder.
                          Ich habe gestern drei Geräte gelöscht. Gestern abend und heute früh vor der Arbeit lief alles.
                          Nun habe ich eben nachgeschaut: Adapter gelb.
                          Nach dem Adapter Neustart kommt das:
                          zigbee.0	2020-12-16 11:19:50.275	info	(1803) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          zigbee.0	2020-12-16 11:19:50.274	info	(1803) terminating
                          zigbee.0	2020-12-16 11:19:50.273	error	at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:27:71)
                          zigbee.0	2020-12-16 11:19:50.273	error	at Generator.next (<anonymous>)
                          zigbee.0	2020-12-16 11:19:50.273	error	at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:453:28)
                          zigbee.0	2020-12-16 11:19:50.273	error	at ZStackAdapter.dataRequestExtended (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:800:16)
                          zigbee.0	2020-12-16 11:19:50.273	error	at __awaiter (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:23:12)
                          zigbee.0	2020-12-16 11:19:50.273	error	at new Promise (<anonymous>)
                          zigbee.0	2020-12-16 11:19:50.273	error	at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:804:28)
                          zigbee.0	2020-12-16 11:19:50.273	error	at Znp.request (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:273:19)
                          zigbee.0	2020-12-16 11:19:50.273	error	(1803) Failed to stop zigbee (Error: Cannot request when znp has not been initialized yet
                          zigbee.0	2020-12-16 11:19:50.143	info	(1803) Zigbee: disabling joining new devices.
                          zigbee.0	2020-12-16 11:19:50.141	info	(1803) cleaned everything up...
                          zigbee.0	2020-12-16 11:19:50.139	info	(1803) Got terminate signal TERMINATE_YOURSELF
                          host.raspberrypi	2020-12-16 11:19:50.135	info	stopInstance system.adapter.zigbee.0 send kill signal
                          host.raspberrypi	2020-12-16 11:19:50.129	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
                            @Mr-X
                            Scheint mir an der Hardware zu liegen.
                            https://www.zigbee2mqtt.io/information/FAQ.html#modemmanager-is-installed
                            Was sagt eigentlich
                            dmesg
                            zu dem Stick? Irgendwo Meldungen zu undervoltage?
                              @Thomas-Braun Ne, nichts gesehen.
                              irgendwie scheint es jetzt mal einen Tag zu laufen.
                              Ich denke, ich belasse es erstmal so wie es ist, und warte auf den neuen Stick von Arteck.
                              Hoffe die Post braucht nicht allzulange.
                              Vielen Dank nochmals für deine Bemühungen !!!
                              zigbee
                              1524
