    3. Entwicklung
    4. [Neuer Adapter] Xiaomi Luftfilter
    • Fenriswolf
      Fenriswolf @dontobi last edited by
      @dontobi
      leider immer noch Fehler:
      mihome-airpurifier.0	2020-11-29 15:45:16.453	info	(7663) Terminated (NO_ERROR): Without reason
      mihome-airpurifier.0	2020-11-29 15:45:16.444	info	(7663) terminating
      mihome-airpurifier.0	2020-11-29 15:45:16.413	info	(7663) cleaned everything up...
      mihome-airpurifier.0	2020-11-29 15:45:16.411	error	(7663) TypeError: Cannot read property 'toString' of undefined at MiHomeAirPurifier.<anonymous> (/opt/iobroker/node_modules/iobroker.mihome-airpurifier/build/main.js:293:37) at Generator.next
      mihome-airpurifier.0	2020-11-29 15:45:16.410	error	(7663) unhandled promise rejection: Cannot read property 'toString' of undefined
      mihome-airpurifier.0	2020-11-29 15:45:16.409	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      mihome-airpurifier.0	2020-11-29 15:45:16.406	debug	(7663) subscribeToValues
      mihome-airpurifier.0	2020-11-29 15:45:16.405	debug	(7663) filterHoursUsed: undefined
      mihome-airpurifier.0	2020-11-29 15:45:16.404	debug	(7663) filterLifeRemaining: undefined
      mihome-airpurifier.0	2020-11-29 15:45:16.402	debug	(7663) led: undefined
      mihome-airpurifier.0	2020-11-29 15:45:16.401	debug	(7663) buzzer: undefined
      mihome-airpurifier.0	2020-11-29 15:45:16.400	debug	(7663) pm25: undefined
      mihome-airpurifier.0	2020-11-29 15:45:16.398	debug	(7663) humidity: undefined
      mihome-airpurifier.0	2020-11-29 15:45:16.396	debug	(7663) manuallevel: NaN
      mihome-airpurifier.0	2020-11-29 15:45:16.394	debug	(7663) mode: undefined
      mihome-airpurifier.0	2020-11-29 15:45:16.392	debug	(7663) power: undefined
      mihome-airpurifier.0	2020-11-29 15:45:16.391	debug	(7663) checkValues
      mihome-airpurifier.0	2020-11-29 15:45:16.389	info	(7663) Connected!
      mihome-airpurifier.0	2020-11-29 15:45:15.839	debug	(7663) Connect to device: 192.168.99.122
      mihome-airpurifier.0	2020-11-29 15:45:15.837	info	(7663) Connecting...
      mihome-airpurifier.0	2020-11-29 15:45:15.831	info	(7663) Started
      mihome-airpurifier.0	2020-11-29 15:45:15.795	info	(7663) starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.mihome-airpurifier, node: v12.20.0, js-controller: 3.1.6
      dontobi 1 Reply Last reply Reply Quote 0
      • dontobi
        dontobi @Fenriswolf last edited by
        @Fenriswolf So wie es scheint, gibt es zwischen der 2. Serie und der 3. Serie größere Abweichungen, wie die Daten abgefragt werden. Der Error von dir wir bei meinem 2H nicht erzeugt. In dem Fall ließt der Adapter die Temperatur aus.
        Das wird also eine größere Aktion und dafür muss ich mich tiefer in den Adapter und miio einarbeiten. Aber vielleicht kann mir ja noch jemand helfen.
        • 9
          9_Mad-Max_5 last edited by
          Hat es jemand geschafft den chinesischen 2S auszulesen?
          Device ID: 31556799X
          Model info: Unknown
          Address: 192.168.2.136
          Token: ???
          Support: Unknown
          Das ist leider alles was meiner mir miio auspuckt...
          • dontobi
            dontobi @9_Mad-Max_5 last edited by
            @9_Mad-Max_5 Ich hab es damals mit miio auch nicht geschaft. Es gibt eine angepasste App, mit der man die ID auslesen kann. Google mal danach.
              MrLee @dontobi last edited by
              @dontobi
              Moin!
              So, bin jetzt auch mal zum testen gekommen.
              Purifier 3H, im WLAN eingebunden, bisher über HAM gesteuert (soweit möglich).
              Leider stürtzt der Adapter bei mir ab:
              host.iobroker_host	2020-12-14 09:01:47.629	error	instance system.adapter.mihome-airpurifier.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              host.iobroker_host	2020-12-14 09:01:47.628	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
              host.iobroker_host	2020-12-14 09:01:47.628	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
              host.iobroker_host	2020-12-14 09:01:47.628	error	Caught by controller[0]: at Object.<anonymous> (/usr/local/iobroker/node_modules/miio/lib/devices/air-purifier.js:11:18)
              host.iobroker_host	2020-12-14 09:01:47.628	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
              host.iobroker_host	2020-12-14 09:01:47.628	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
              host.iobroker_host	2020-12-14 09:01:47.628	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
              host.iobroker_host	2020-12-14 09:01:47.628	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
              host.iobroker_host	2020-12-14 09:01:47.627	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
              host.iobroker_host	2020-12-14 09:01:47.627	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
              host.iobroker_host	2020-12-14 09:01:47.627	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:723:23)
              host.iobroker_host	2020-12-14 09:01:47.627	error	Caught by controller[0]: SyntaxError: Unexpected token =
              host.iobroker_host	2020-12-14 09:01:47.627	error	Caught by controller[0]: ^
              host.iobroker_host	2020-12-14 09:01:47.626	error	Caught by controller[0]: fs1 = -1;
              host.iobroker_host	2020-12-14 09:01:47.626	error	Caught by controller[0]: /usr/local/iobroker/node_modules/miio/lib/devices/capabilities/fan-speed.js:7
              Kann ich irgendwie unterstützen?
              Mr.Lee
                Thomas Braun Most Active @MrLee last edited by
                @MrLee
                Ich glaube, da ist deine Grundinstallation schon krumm.
                Das Verzeichnis /usr/local/iobroker sollte nicht vorhanden sein.
                Schau mal ob nodeJS richtig tickt:
                which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                • Fenriswolf
                  Moin,
                  ich hatte mit @dontobi schon ein wenig getestet, bzw. @dontobi hatte einige Änderungen gemacht und ich getestet. Es gibt immer noch Probleme mit dem 3H.
                  Also nicht wundern, wenn da immernoch Probleme auftreten.
                    MrLee @Thomas Braun last edited by
                    @Thomas-Braun
                    Moin!
                    Danke für den Hinweis, aber meine installation ist etwas "anders" von den Pfaden ...
                    Hatte bisher aber keinen negativen Einfluß.
                    Mr.Lee
                      @MrLee sagte in [Neuer Adapter] Xiaomi Luftfilter:
                      Das sieht man... Was hast du denn da 'umgebogen'? Und warum?
                        SaiBot1981 last edited by
                        Moin, falls du für den H3 auch noch weiter entwickelst wäre das klassen
                        • dontobi
                          dontobi @SaiBot1981 last edited by
                          @SaiBot1981 Ich bin dabei den Code zu sichten und lese mich in Sachen Adapter Entwicklung ein. Außerdem bin ich in JS nicht so fit und muss auch da noch einiges lernen.
                            moeff last edited by
                            Hi, komme leider auch nicht weiter. Token ist korrekt (mehrfach geprüft).
                            host.iobroker	2020-12-25 02:16:31.218	error	instance system.adapter.mihome-airpurifier.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                            host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
                            host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/miio/lib/devices/air-purifier.js:11:18)
                            host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
                            host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
                            host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                            host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                            host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
                            host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:723:23)
                            host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: SyntaxError: Unexpected token =
                            host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: ^
                            host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: fs1 = -1;
                            host.iobroker	2020-12-25 02:16:31.218	error	Caught by controller[0]: /opt/iobroker/node_modules/miio/lib/devices/capabilities/fan-speed.js:7
                            • dontobi
                              dontobi @moeff last edited by
                              @moeff Leider komme ich derzeit nicht dazu mir den Adapter anzusehen. Daher werde ich erst einmal den Support für die 3er Serie raus nehmen, damit sich die Meldungen hier nicht häufen.
                              Vielleicht kann mir jemand bei dem Support der 3er Serie helfen. Am besten jemand, der auch ein solches Gerät hat. Jedoch sollte dieser ein wenig Vorkenntnisse in Sachen Programmierung mitbringen.
                              Frohe Weihnachten.
                              M E 2 Replies Last reply Reply Quote 0
                                moeff @dontobi last edited by
                                @dontobi vielen Dank für die schnelle Antwort. Es handelt sich in meinem Falle um den 2H. Gibt es eine frühere Version die du empfehlen kannst?
                                • dontobi
                                  @moeff said in [Neuer Adapter] Xiaomi Luftfilter:
                                  Ich hab auch den 2H und mit meiner Version (mein GitHub Repo) klappt dieser.
                                    moeff @dontobi last edited by moeff
                                    @dontobi ich nutze = https://github.com/JoJ123/ioBroker.mihome-airpurifier auf 0.1.8
                                    gibt es noch eine andere ?
                                    omg zu blöd:
                                    https://github.com/dontobi/ioBroker.mihome-airpurifier
                                    aber mit der bekomme ich nur oben genannten Fehler.
                                      moeff @moeff last edited by
                                      omg zu blöd:
                                      Hab den 2h nun über den miio adapter ohne Probleme eingebunden bekommen.
                                      dasquiddi 1 Reply Last reply Reply Quote 0
                                        Ente @dontobi last edited by Ente
                                        @dontobi
                                        Den 3h habe ich. Leider sieht es mit Programmierung eher mau aus.
                                        VG
                                        Chris
                                        • dasquiddi
                                          dasquiddi @moeff last edited by
                                          @moeff
                                          Wie konntest du das Problem lösen? Ich stehe vo dem gleichen Problem
                                          dontobi M 2 Replies Last reply Reply Quote 0
                                          • dontobi
                                            dontobi @dasquiddi last edited by
                                            @dasquiddi am besten installierst du den Adapter komplett neu. Also erst den alten deinstallieren und dann über.den GitHub Link meine Version des Adapters installieren.
                                            188
                                            28044
